[Darshan-commits] [Darshan] branch, dev-modular, updated. darshan-2.3.1-76-gd72958d
Service Account
git at mcs.anl.gov
Tue Mar 31 17:05:30 CDT 2015
This is an automated email from the git hooks/post-receive script. It was
generated because a ref change was pushed to the repository containing
the project "".
The branch, dev-modular has been updated
via d72958deef26f9e8b81f83ecd8f0a627e20c5c9e (commit)
from 6af7ad398b4ba7ce8eb1c571cc00aeb20b6a4d1c (commit)
Those revisions listed above that are new to this repository have
not appeared on any other notification email; so we list those
revisions in full, below.
- Log -----------------------------------------------------------------
commit d72958deef26f9e8b81f83ecd8f0a627e20c5c9e
Author: Shane Snyder <ssnyder at mcs.anl.gov>
Date: Tue Mar 31 17:05:04 2015 -0500
more posix wrappers: stat family
Summary of changes:
darshan-posix-log-format.h | 6 +-
darshan-runtime/darshan-posix-ld-opts | 6 +
darshan-runtime/lib/darshan-posix.c | 197 ++++++++++++++++++++++++++++++++-
darshan-util/darshan-posix-parser.c | 6 +
4 files changed, 210 insertions(+), 5 deletions(-)
Diff of changes:
diff --git a/darshan-posix-log-format.h b/darshan-posix-log-format.h
index 23e8b29..e699ab5 100644
--- a/darshan-posix-log-format.h
+++ b/darshan-posix-log-format.h
@@ -15,8 +15,8 @@ enum darshan_posix_indices
POSIX_READS, /* count of posix reads */
POSIX_WRITES, /* count of posix writes */
POSIX_SEEKS, /* count of posix seeks */
-#if 0
POSIX_STATS, /* count of posix stat/lstat/fstats */
+#if 0
POSIX_MMAPS, /* count of posix mmaps */
#endif
POSIX_FOPENS, /* count of posix fopens */
@@ -39,8 +39,8 @@ enum darshan_posix_indices
MEM_NOT_ALIGNED, /* count of accesses not mem aligned */
MEM_ALIGNMENT, /* mem alignment in bytes */
FILE_NOT_ALIGNED, /* count of accesses not file aligned */
- FILE_ALIGNMENT, /* file alignment in bytes */
#endif
+ FILE_ALIGNMENT, /* file alignment in bytes */
POSIX_MAX_READ_TIME_SIZE,
POSIX_MAX_WRITE_TIME_SIZE,
#if 0
@@ -84,7 +84,9 @@ enum darshan_posix_indices
ACCESS3_COUNT,
ACCESS4_COUNT,
DEVICE, /* device id reported by stat */
+#endif
SIZE_AT_OPEN,
+#if 0
FASTEST_RANK,
FASTEST_RANK_BYTES,
SLOWEST_RANK,
diff --git a/darshan-runtime/darshan-posix-ld-opts b/darshan-runtime/darshan-posix-ld-opts
index 581d6b9..dea658e 100644
--- a/darshan-runtime/darshan-posix-ld-opts
+++ b/darshan-runtime/darshan-posix-ld-opts
@@ -17,6 +17,12 @@
--wrap=lseek
--wrap=lseek64
--wrap=fseek
+--wrap=__xstat
+--wrap=__xstat64
+--wrap=__lxstat
+--wrap=__lxstat64
+--wrap=__fxstat
+--wrap=__fxstat64
--wrap=fsync
--wrap=fdatasync
--wrap=close
diff --git a/darshan-runtime/lib/darshan-posix.c b/darshan-runtime/lib/darshan-posix.c
index 94a800b..41b2838 100644
--- a/darshan-runtime/lib/darshan-posix.c
+++ b/darshan-runtime/lib/darshan-posix.c
@@ -56,12 +56,20 @@ DARSHAN_FORWARD_DECL(fwrite, size_t, (const void *ptr, size_t size, size_t nmemb
DARSHAN_FORWARD_DECL(lseek, off_t, (int fd, off_t offset, int whence));
DARSHAN_FORWARD_DECL(lseek64, off64_t, (int fd, off64_t offset, int whence));
DARSHAN_FORWARD_DECL(fseek, int, (FILE *stream, long offset, int whence));
-/* stats */
-/* mmaps */
+DARSHAN_FORWARD_DECL(__xstat, int, (int vers, const char* path, struct stat *buf));
+DARSHAN_FORWARD_DECL(__xstat64, int, (int vers, const char* path, struct stat64 *buf));
+DARSHAN_FORWARD_DECL(__lxstat, int, (int vers, const char* path, struct stat *buf));
+DARSHAN_FORWARD_DECL(__lxstat64, int, (int vers, const char* path, struct stat64 *buf));
+DARSHAN_FORWARD_DECL(__fxstat, int, (int vers, int fd, struct stat *buf));
+DARSHAN_FORWARD_DECL(__fxstat64, int, (int vers, int fd, struct stat64 *buf));
+/* TODO mmaps */
DARSHAN_FORWARD_DECL(fsync, int, (int fd));
DARSHAN_FORWARD_DECL(fdatasync, int, (int fd));
DARSHAN_FORWARD_DECL(close, int, (int fd));
DARSHAN_FORWARD_DECL(fclose, int, (FILE *fp));
+/* TODO mkstemp */
+/* TODO aio */
+/* TODO listio */
static void posix_runtime_initialize(void);
static struct posix_file_runtime* posix_file_by_name(const char *name);
@@ -275,6 +283,33 @@ static int my_rank = -1;
DARSHAN_COUNTER_SET(file->file_record, POSIX_MAX_WRITE_TIME_SIZE, __ret); } \
} while(0)
+#define POSIX_LOOKUP_RECORD_STAT(__path, __statbuf, __tm1, __tm2) do { \
+ char* exclude; \
+ int tmp_index = 0; \
+ struct posix_file_runtime* file; \
+ while((exclude = darshan_path_exclusions[tmp_index])) { \
+ if(!(strncmp(exclude, __path, strlen(exclude)))) \
+ break; \
+ tmp_index++; \
+ if(exclude) break; \
+ file = posix_file_by_name(__path); \
+ if(file) \
+ POSIX_RECORD_STAT(file, __statbuf, __tm1, __tm2); \
+} while(0)
+#define POSIX_RECORD_STAT(__file, __statbuf, __tm1, __tm2) do { \
+ if(!DARSHAN_COUNTER_VALUE((__file)->file_record, POSIX_STATS) && !DARSHAN_COUNTER_VALUE((__file)->file_record, POSIX_OPENS)){ \
+ DARSHAN_COUNTER_SET((__file)->file_record, FILE_ALIGNMENT, (__statbuf)->st_blksize); \
+ DARSHAN_COUNTER_SET((__file)->file_record, SIZE_AT_OPEN, (__statbuf)->st_size); \
+ (__file)->file_record->rank = my_rank; \
+ DARSHAN_COUNTER_F_INC_NO_OVERLAP((__file)->file_record, __tm1, __tm2, (__file)->last_meta_end, POSIX_F_META_TIME); \
+ DARSHAN_COUNTER_INC((__file)->file_record, POSIX_STATS, 1); \
+} while(0)
* Wrappers for POSIX I/O functions of interest *
@@ -764,7 +799,7 @@ int DARSHAN_DECL(fseek)(FILE *stream, long offset, int whence)
file = posix_file_by_fd(fileno(stream));
if(file)
- file->offset = ftell(stream); /* TODO: this seems wrong. ftell? */
+ file->offset = ftell(stream);
DARSHAN_COUNTER_F_INC_NO_OVERLAP(file->file_record,
tm1, tm2, file->last_meta_end, POSIX_F_META_TIME);
DARSHAN_COUNTER_INC(file->file_record, POSIX_FSEEKS, 1);
@@ -775,6 +810,162 @@ int DARSHAN_DECL(fseek)(FILE *stream, long offset, int whence)
return(ret);
+int DARSHAN_DECL(__xstat)(int vers, const char *path, struct stat *buf)
+ int ret;
+ double tm1, tm2;
+ MAP_OR_FAIL(__xstat);
+ tm1 = darshan_core_wtime();
+ ret = __real___xstat(vers, path, buf);
+ tm2 = darshan_core_wtime();
+ if(ret < 0 || !S_ISREG(buf->st_mode))
+ return(ret);
+ POSIX_LOCK();
+ posix_runtime_initialize();
+ POSIX_LOOKUP_RECORD_STAT(path, buf, tm1, tm2);
+ POSIX_UNLOCK();
+ return(ret);
+int DARSHAN_DECL(__xstat64)(int vers, const char *path, struct stat64 *buf)
+ int ret;
+ double tm1, tm2;
+ MAP_OR_FAIL(__xstat64);
+ ret = __real___xstat64(vers, path, buf);
+ return(ret);
+ POSIX_LOCK();
+ POSIX_UNLOCK();
+ return(ret);
+int DARSHAN_DECL(__lxstat)(int vers, const char *path, struct stat *buf)
+ int ret;
+ double tm1, tm2;
+ MAP_OR_FAIL(__lxstat);
+ ret = __real___lxstat(vers, path, buf);
+ return(ret);
+ POSIX_LOCK();
+ POSIX_UNLOCK();
+ return(ret);
+int DARSHAN_DECL(__lxstat64)(int vers, const char *path, struct stat64 *buf)
+ int ret;
+ double tm1, tm2;
+ MAP_OR_FAIL(__lxstat64);
+ ret = __real___lxstat64(vers, path, buf);
+ return(ret);
+ POSIX_LOCK();
+ POSIX_UNLOCK();
+ return(ret);
+int DARSHAN_DECL(__fxstat)(int vers, int fd, struct stat *buf)
+ int ret;
+ double tm1, tm2;
+ MAP_OR_FAIL(__fxstat);
+ ret = __real___fxstat(vers, fd, buf);
+ return(ret);
+ /* TODO */
+#if 0
+ /* skip logging if this was triggered internally */
+ if((void*)buf == (void*)&cp_stat_buf)
+ return(ret);
+#endif
+ POSIX_LOCK();
+ file = posix_file_by_fd(fd);
+ if(file)
+ POSIX_RECORD_STAT(file, buf, tm1, tm2);
+ POSIX_UNLOCK();
+ return(ret);
+int DARSHAN_DECL(__fxstat64)(int vers, int fd, struct stat64 *buf)
+ int ret;
+ double tm1, tm2;
+ MAP_OR_FAIL(__fxstat64);
+ ret = __real___fxstat64(vers, fd, buf);
+ return(ret);
+ /* TODO */
+#if 0
+ return(ret);
+#endif
+ POSIX_LOCK();
+ if(file)
+ POSIX_UNLOCK();
+ return(ret);
int DARSHAN_DECL(fsync)(int fd)
int ret;
diff --git a/darshan-util/darshan-posix-parser.c b/darshan-util/darshan-posix-parser.c
index bc7e324..eddf56c 100644
--- a/darshan-util/darshan-posix-parser.c
+++ b/darshan-util/darshan-posix-parser.c
@@ -174,6 +174,7 @@ int main(int argc, char **argv)
"\t\tPOSIX_READS:\t%"PRIu64"\n"
"\t\tPOSIX_WRITES:\t%"PRIu64"\n"
"\t\tPOSIX_SEEKS:\t%"PRIu64"\n"
+ "\t\tPOSIX_STATS:\t%"PRIu64"\n"
"\t\tPOSIX_FOPENS:\t%"PRIu64"\n"
"\t\tPOSIX_FREADS:\t%"PRIu64"\n"
"\t\tPOSIX_FWRITES:\t%"PRIu64"\n"
@@ -190,8 +191,10 @@ int main(int argc, char **argv)
"\t\tPOSIX_SEQ_READS:\t%"PRIu64"\n"
"\t\tPOSIX_SEQ_WRITES:\t%"PRIu64"\n"
"\t\tPOSIX_RW_SWITCHES:\t%"PRIu64"\n"
+ "\t\tFILE_ALIGNMENT:\t%"PRIu64"\n"
"\t\tPOSIX_MAX_READ_TIME_SIZE:\t%"PRIu64"\n"
"\t\tPOSIX_MAX_WRITE_TIME_SIZE:\t%"PRIu64"\n"
+ "\t\tSIZE_AT_OPEN:\t%"PRIu64"\n"
"\t\tPOSIX_F_OPEN_TIMESTAMP:\t%lf\n"
"\t\tPOSIX_F_READ_START_TIMESTAMP:\t%lf\n"
"\t\tPOSIX_F_WRITE_START_TIMESTAMP:\t%lf\n"
@@ -206,6 +209,7 @@ int main(int argc, char **argv)
next_file.counters[POSIX_READS],
next_file.counters[POSIX_WRITES],
next_file.counters[POSIX_SEEKS],
+ next_file.counters[POSIX_STATS],
next_file.counters[POSIX_FOPENS],
next_file.counters[POSIX_FREADS],
next_file.counters[POSIX_FWRITES],
@@ -222,8 +226,10 @@ int main(int argc, char **argv)
next_file.counters[POSIX_SEQ_READS],
next_file.counters[POSIX_SEQ_WRITES],
next_file.counters[POSIX_RW_SWITCHES],
+ next_file.counters[FILE_ALIGNMENT],
next_file.counters[POSIX_MAX_READ_TIME_SIZE],
next_file.counters[POSIX_MAX_WRITE_TIME_SIZE],
+ next_file.counters[SIZE_AT_OPEN],
next_file.fcounters[POSIX_F_OPEN_TIMESTAMP],
next_file.fcounters[POSIX_F_READ_START_TIMESTAMP],
next_file.fcounters[POSIX_F_WRITE_START_TIMESTAMP],
hooks/post-receive
More information about the Darshan-commits
