[Darshan-commits] [Darshan] branch, dev-modular, updated. darshan-2.3.1-73-g9801de5
Service Account git at mcs.anl.gov
Mon Mar 30 13:46:32 CDT 2015
This is an automated email from the git hooks/post-receive script. It was
generated because a ref change was pushed to the repository containing
the project "".
The branch, dev-modular has been updated
       via  9801de536d56164d4df5c9a61002247d51366667 (commit)
      from  910d55f263a84e56b822e0c331f7f518fb832dee (commit)
Those revisions listed above that are new to this repository have
not appeared on any other notification email; so we list those
revisions in full, below.
- Log -----------------------------------------------------------------
commit 9801de536d56164d4df5c9a61002247d51366667
Author: Shane Snyder <ssnyder at mcs.anl.gov>
Date:   Mon Mar 30 13:45:50 2015 -0500
    more POSIX wrappers added and improved docs
Summary of changes:
 darshan-log-format.h                |   13 ++-
 darshan-posix-log-format.h          |   23 +++-
 darshan-runtime/darshan.h           |   35 +++++
 darshan-runtime/lib/darshan-posix.c |  235 ++++++++++++++++++++---------------
 darshan-util/darshan-posix-parser.c |   18 +++
 5 files changed, 216 insertions(+), 108 deletions(-)
Diff of changes:
diff --git a/darshan-log-format.h b/darshan-log-format.h
index 45bc9ba..7c49cbb 100644
--- a/darshan-log-format.h
+++ b/darshan-log-format.h
@@ -53,12 +53,22 @@ static char * const darshan_module_names[] =
     "PNETCDF"
+/* the darshan_log_map structure is used to indicate the location of
+ * specific module data in a Darshan log. Note that 'off' and 'len' are
+ * the respective offset and length of the data in the file, in *uncompressed*
+ * terms -- this is nonintuitive since the data is compressed, but this is
+ * done so we can utilize the gzread interface for all Darshan log reading
+ * utilities.
 struct darshan_log_map
     uint64_t off;
     uint64_t len;
+/* the darshan header stores critical metadata needed for correctly
+ * reading the contents of the corresponding Darshan log
 struct darshan_header
     char version_string[8];
@@ -67,7 +77,7 @@ struct darshan_header
     struct darshan_log_map mod_map[DARSHAN_MAX_MODS];
-/* statistics for the job as a whole */
+/* job-level metadata stored for this application */
 #define DARSHAN_JOB_METADATA_LEN 1024 /* including null terminator! */
 struct darshan_job
@@ -79,6 +89,7 @@ struct darshan_job
     char metadata[DARSHAN_JOB_METADATA_LEN];
+/* minimal record stored for each file/object accessed by Darshan */
 struct darshan_record
     char* name;
diff --git a/darshan-posix-log-format.h b/darshan-posix-log-format.h
index 0eae1fa..6eaba76 100644
--- a/darshan-posix-log-format.h
+++ b/darshan-posix-log-format.h
@@ -8,6 +8,7 @@
 #include "darshan-log-format.h"
+/* integer statistics for POSIX file records */
 enum darshan_posix_indices
     POSIX_OPENS,              /* count of posix opens */
@@ -27,16 +28,16 @@ enum darshan_posix_indices
     POSIX_FDSYNCS,
 #endif
     POSIX_MODE,                /* mode of file */
-#if 0
     POSIX_BYTES_READ,          /* total bytes read */
     POSIX_BYTES_WRITTEN,       /* total bytes written */
     POSIX_MAX_BYTE_READ,       /* highest offset byte read */
     POSIX_MAX_BYTE_WRITTEN,    /* highest offset byte written */
-    CONSEC_READS,              /* count of consecutive reads */
-    CONSEC_WRITES,             /* count of consecutive writes */
-    SEQ_READS,                 /* count of sequential reads */
-    SEQ_WRITES,                /* count of sequential writes */
-    RW_SWITCHES,               /* number of times switched between read and write */
+    POSIX_CONSEC_READS,        /* count of consecutive reads */
+    POSIX_CONSEC_WRITES,       /* count of consecutive writes */
+    POSIX_SEQ_READS,           /* count of sequential reads */
+    POSIX_SEQ_WRITES,          /* count of sequential writes */
+    POSIX_RW_SWITCHES,         /* number of times switched between read and write */
+#if 0
     MEM_NOT_ALIGNED,           /* count of accesses not mem aligned */
     MEM_ALIGNMENT,             /* mem alignment in bytes */
     FILE_NOT_ALIGNED,          /* count of accesses not file aligned */
@@ -95,7 +96,7 @@ enum darshan_posix_indices
     POSIX_NUM_INDICES,
-/* floating point statistics */
+/* floating point statistics for POSIX file records */
 enum darshan_posix_f_indices
     /* NOTE: adjust cp_normalize_timestamps() function if any TIMESTAMPS are
@@ -126,6 +127,14 @@ enum darshan_posix_f_indices
     POSIX_F_NUM_INDICES,
+/* file record structure for POSIX files. a record is created and stored for
+ * every POSIX file opened by the original application. For the POSIX module,
+ * the record includes:
+ *      - a corresponding record identifier (created by hashing the file path)
+ *      - the rank of the process which opened the file (-1 for shared files)
+ *      - integer file I/O statistics (open, read/write counts, etc)
+ *      - floating point I/O statistics (timestamps, cumulative timers, etc.)
 struct darshan_posix_file
     darshan_record_id f_id;
diff --git a/darshan-runtime/darshan.h b/darshan-runtime/darshan.h
index c378fb5..2849ff8 100644
--- a/darshan-runtime/darshan.h
+++ b/darshan-runtime/darshan.h
@@ -66,6 +66,41 @@
 /* macros for manipulating module's counter variables */
 /* NOTE: */
+#define DARSHAN_COUNTER_SET(__rec_p, __counter, __value) do{ \
+    (__rec_p)->counters[__counter] = __value; \
+} while(0)
+#define DARSHAN_COUNTER_F_SET(__rec_p, __counter, __value) do{ \
+    (__rec_p)->fcounters[__counter] = __value; \
+} while(0)
+#define DARSHAN_COUNTER_INC(__rec_p, __counter, __value) do{ \
+} while(0)
+#define DARSHAN_COUNTER_F_INC(__rec_p, __counter, __value) do{ \
+} while(0)
+#define DARSHAN_COUNTER_F_INC_NO_OVERLAP(__rec_p, __tm1, __tm2, __last, __counter) do{ \
+    if(__tm1 > __last) \
+        DARSHAN_COUNTER_F_INC(__rec_p, __counter, (__tm2 - __tm1)); \
+    else \
+        DARSHAN_COUNTER_F_INC(__rec_p, __counter, (__tm2 - __last)); \
+    if(__tm2 > __last) \
+        __last = __tm2; \
+} while(0)
+#define DARSHAN_COUNTER_VALUE(__rec_p, __counter) \
+    ((__rec_p)->counters[__counter])
+#define DARSHAN_COUNTER_F_VALUE(__rec_p, __counter) \
+    ((__rec_p)->fcounters[__counter])
+#define DARSHAN_COUNTER_MAX(__rec_p, __counter, __value) do{ \
+    if((__rec_p)->counters[__counter] < __value) \
+} while(0)
 /* module developers provide the following functions to darshan-core */
 struct darshan_module_funcs
diff --git a/darshan-runtime/lib/darshan-posix.c b/darshan-runtime/lib/darshan-posix.c
index a1301d0..5a5fb66 100644
--- a/darshan-runtime/lib/darshan-posix.c
+++ b/darshan-runtime/lib/darshan-posix.c
@@ -65,15 +65,44 @@ static void posix_record_reduction_op(void* infile_v, void* inoutfile_v,
 static void posix_get_output_data(void **buffer, int *size);
 static void posix_shutdown(void);
+enum posix_io_type
+    POSIX_READ = 1,
+    POSIX_WRITE = 2,
+/* The posix_file_runtime structure maintains necessary runtime metadata
+ * for the POSIX file record (darshan_posix_file structure, defined in
+ * darshan-posix-log-format.h) pointed to by 'file_record'. This metadata
+ * assists with the instrumenting of specific statistics in the file record.
+ * 'hlink' is a hash table link structure used to add/remove this record
+ * from the hash table of POSIX file records for this process.
 struct posix_file_runtime
     struct darshan_posix_file* file_record;
+    int64_t offset;
+    int64_t last_byte_read;
+    int64_t last_byte_written;
+    enum posix_io_type last_io_type;
     double last_meta_end;
     double last_read_end;
     double last_write_end;
     UT_hash_handle hlink;
+/* The posix_file_runtime_ref structure is used to associate a POSIX
+ * file descriptor with an already existing POSIX file record. This is
+ * necessary as many POSIX I/O functions take only an input file descriptor,
+ * but POSIX file records are indexed by their full file paths (i.e., darshan
+ * record identifiers for POSIX files are created by hashing the file path).
+ * In other words, this structure is necessary as it allows us to look up a
+ * file record either by a pathname (posix_file_runtime) or by POSIX file
+ * descriptor (posix_file_runtime_ref), depending on which parameters are
+ * available. This structure includes another hash table link, since separate
+ * hashes are maintained for posix_file_runtime structures and posix_file_runtime_ref
+ * structures.
 struct posix_file_runtime_ref
     struct posix_file_runtime* file;
@@ -81,6 +110,10 @@ struct posix_file_runtime_ref
+/* The posix_runtime structure maintains necessary state for storing
+ * POSIX file records and for coordinating with darshan-core at
+ * shutdown time.
 struct posix_runtime
     struct posix_file_runtime* file_runtime_array;
@@ -101,44 +134,6 @@ static int my_rank = -1;
 #define POSIX_LOCK() pthread_mutex_lock(&posix_runtime_mutex)
 #define POSIX_UNLOCK() pthread_mutex_unlock(&posix_runtime_mutex)
-#define POSIX_SET(__file, __counter, __value) do {\
-    (__file)->file_record->counters[__counter] = __value; \
-} while(0)
-#define POSIX_F_SET(__file, __counter, __value) do {\
-    (__file)->file_record->fcounters[__counter] = __value; \
-} while(0)
-#define POSIX_INC(__file, __counter, __value) do {\
-    (__file)->file_record->counters[__counter] += __value; \
-} while(0)
-#define POSIX_F_INC(__file, __counter, __value) do {\
-    (__file)->file_record->fcounters[__counter] += __value; \
-} while(0)
-#define POSIX_F_INC_NO_OVERLAP(__file, __tm1, __tm2, __last, __counter) do { \
-    if(__tm1 > __last) \
-        POSIX_F_INC(__file, __counter, (__tm2-__tm1)); \
-    else \
-        POSIX_F_INC(__file, __counter, (__tm2 - __last)); \
-    if(__tm2 > __last) \
-        __last = __tm2; \
-} while(0)
-#define POSIX_VALUE(__file, __counter) \
-    ((__file)->file_record->counters[__counter])
-#define POSIX_F_VALUE(__file, __counter) \
-    ((__file)->file_record->fcounters[__counter])
-#define POSIX_MAX(__file, __counter, __value) do {\
-    if((__file)->file_record->counters[__counter] < __value) \
-} while(0)
 #define POSIX_RECORD_OPEN(__ret, __path, __mode, __stream_flag, __tm1, __tm2) do { \
     struct posix_file_runtime* file; \
     char* exclude; \
@@ -155,119 +150,123 @@ static int my_rank = -1;
     /* CP_STAT_FILE(file, __path, __ret); */ \
     file->file_record->rank = my_rank; \
     if(__mode) \
-        POSIX_SET(file, POSIX_MODE, __mode); \
-    /* file->offset = 0; */ \
-    /* file->last_byte_written = 0; */ \
-    /* file->last_byte_read = 0; */ \
+        DARSHAN_COUNTER_SET(file->file_record, POSIX_MODE, __mode); \
+    file->offset = 0; \
+    file->last_byte_written = 0; \
+    file->last_byte_read = 0; \
     if(__stream_flag)\
-        POSIX_INC(file, POSIX_FOPENS, 1); \
+        DARSHAN_COUNTER_INC(file->file_record, POSIX_FOPENS, 1); \
     else \
-        POSIX_INC(file, POSIX_OPENS, 1); \
-    if(POSIX_F_VALUE(file, POSIX_F_OPEN_TIMESTAMP) == 0) \
-        POSIX_F_SET(file, POSIX_F_OPEN_TIMESTAMP, __tm1); \
-    POSIX_F_INC_NO_OVERLAP(file, __tm1, __tm2, file->last_meta_end, POSIX_F_META_TIME); \
+        DARSHAN_COUNTER_INC(file->file_record, POSIX_OPENS, 1); \
+    if(DARSHAN_COUNTER_F_VALUE(file->file_record, POSIX_F_OPEN_TIMESTAMP) == 0) \
+        DARSHAN_COUNTER_F_SET(file->file_record, POSIX_F_OPEN_TIMESTAMP, __tm1); \
+    DARSHAN_COUNTER_F_INC_NO_OVERLAP(file->file_record, __tm1, __tm2, file->last_meta_end, POSIX_F_META_TIME); \
 } while(0)
 #define POSIX_RECORD_READ(__ret, __fd, __pread_flag, __pread_offset, __aligned, __stream_flag, __tm1, __tm2) do{ \
-    /* size_t stride; \
-    int64_t this_offset; */ \
+    /* size_t stride; */\
+    int64_t this_offset; \
     /* int64_t file_alignment; */ \
     double __elapsed = __tm2-__tm1; \
     if(__ret < 0) break; \
     file = posix_file_by_fd(__fd); \
     if(!file) break; \
-    /* if(__pread_flag) \
+    if(__pread_flag) \
         this_offset = __pread_offset; \
     else \
         this_offset = file->offset; \
-    file_alignment = CP_VALUE(file, CP_FILE_ALIGNMENT); \
+    /* file_alignment = CP_VALUE(file, CP_FILE_ALIGNMENT); */\
     if(this_offset > file->last_byte_read) \
-        CP_INC(file, CP_SEQ_READS, 1); \
+        DARSHAN_COUNTER_INC(file->file_record, POSIX_SEQ_READS, 1); \
     if(this_offset == (file->last_byte_read + 1)) \
-        CP_INC(file, CP_CONSEC_READS, 1); \
-    if(this_offset > 0 && this_offset > file->last_byte_read \
+        DARSHAN_COUNTER_INC(file->file_record, POSIX_CONSEC_READS, 1); \
+    /* if(this_offset > 0 && this_offset > file->last_byte_read \
         && file->last_byte_read != 0) \
         stride = this_offset - file->last_byte_read - 1; \
     else \
-        stride = 0; \
+        stride = 0; */\
     file->last_byte_read = this_offset + __ret - 1; \
     file->offset = this_offset + __ret; \
-    CP_MAX(file, CP_MAX_BYTE_READ, (this_offset + __ret -1)); \
-    CP_INC(file, CP_BYTES_READ, __ret); */\
+    DARSHAN_COUNTER_MAX(file->file_record, POSIX_MAX_BYTE_READ, (this_offset + __ret - 1)); \
+    DARSHAN_COUNTER_INC(file->file_record, POSIX_BYTES_READ, __ret); \
     if(__stream_flag)\
-        POSIX_INC(file, POSIX_FREADS, 1); \
+        DARSHAN_COUNTER_INC(file->file_record, POSIX_FREADS, 1); \
     else\
-        POSIX_INC(file, POSIX_READS, 1); \
+        DARSHAN_COUNTER_INC(file->file_record, POSIX_READS, 1); \
     /* CP_BUCKET_INC(file, CP_SIZE_READ_0_100, __ret); \
     cp_access_counter(file, stride, CP_COUNTER_STRIDE); \
     if(!__aligned) \
         CP_INC(file, CP_MEM_NOT_ALIGNED, 1); \
     if(file_alignment > 0 && (this_offset % file_alignment) != 0) \
         CP_INC(file, CP_FILE_NOT_ALIGNED, 1); \
-    cp_access_counter(file, __ret, CP_COUNTER_ACCESS); \
-    if(file->last_io_type == CP_WRITE) \
-        CP_INC(file, CP_RW_SWITCHES, 1); \
-    file->last_io_type = CP_READ; */ \
-    POSIX_F_INC_NO_OVERLAP(file, __tm1, __tm2, file->last_read_end, POSIX_F_READ_TIME);  \
-    if(POSIX_F_VALUE(file, POSIX_F_READ_START_TIMESTAMP) == 0) \
-        POSIX_F_SET(file, POSIX_F_READ_START_TIMESTAMP, __tm1); \
-    POSIX_F_SET(file, POSIX_F_READ_END_TIMESTAMP, __tm2); \
-    if(POSIX_F_VALUE(file, POSIX_F_MAX_READ_TIME) < __elapsed){ \
-        POSIX_F_SET(file, POSIX_F_MAX_READ_TIME, __elapsed); \
-        POSIX_SET(file, POSIX_MAX_READ_TIME_SIZE, __ret); } \
+    cp_access_counter(file, __ret, CP_COUNTER_ACCESS); */\
+    if(file->last_io_type == POSIX_WRITE) \
+        DARSHAN_COUNTER_INC(file->file_record, POSIX_RW_SWITCHES, 1); \
+    file->last_io_type = POSIX_READ; \
+    DARSHAN_COUNTER_F_INC_NO_OVERLAP(file->file_record, __tm1, __tm2, file->last_read_end, POSIX_F_READ_TIME); \
+    if(DARSHAN_COUNTER_F_VALUE(file->file_record, POSIX_F_READ_START_TIMESTAMP) == 0) \
+        DARSHAN_COUNTER_F_SET(file->file_record, POSIX_F_READ_START_TIMESTAMP, __tm1); \
+    DARSHAN_COUNTER_F_SET(file->file_record, POSIX_F_READ_END_TIMESTAMP, __tm2); \
+    if(DARSHAN_COUNTER_F_VALUE(file->file_record, POSIX_F_MAX_READ_TIME) < __elapsed){ \
+        DARSHAN_COUNTER_F_SET(file->file_record, POSIX_F_MAX_READ_TIME, __elapsed); \
+        DARSHAN_COUNTER_SET(file->file_record, POSIX_MAX_READ_TIME_SIZE, __ret); } \
 } while(0)
 #define POSIX_RECORD_WRITE(__ret, __fd, __pwrite_flag, __pwrite_offset, __aligned, __stream_flag, __tm1, __tm2) do{ \
     if(!file) break; \
-    /* if(__pwrite_flag) \
+    if(__pwrite_flag) \
         this_offset = __pwrite_offset; \
     else \
     if(this_offset > file->last_byte_written) \
-        CP_INC(file, CP_SEQ_WRITES, 1); \
+        DARSHAN_COUNTER_INC(file->file_record, POSIX_SEQ_WRITES, 1); \
     if(this_offset == (file->last_byte_written + 1)) \
-        CP_INC(file, CP_CONSEC_WRITES, 1); \
-    if(this_offset > 0 && this_offset > file->last_byte_written \
+        DARSHAN_COUNTER_INC(file->file_record, POSIX_CONSEC_WRITES, 1); \
+    /* if(this_offset > 0 && this_offset > file->last_byte_written \
         && file->last_byte_written != 0) \
         stride = this_offset - file->last_byte_written - 1; \
     else \
-        stride = 0; \
+        stride = 0; */\
     file->last_byte_written = this_offset + __ret - 1; \
-    CP_MAX(file, CP_MAX_BYTE_WRITTEN, (this_offset + __ret -1)); \
-    CP_INC(file, CP_BYTES_WRITTEN, __ret); */ \
+    DARSHAN_COUNTER_MAX(file->file_record, POSIX_MAX_BYTE_WRITTEN, (this_offset + __ret - 1)); \
+    DARSHAN_COUNTER_INC(file->file_record, POSIX_BYTES_WRITTEN, __ret); \
     if(__stream_flag) \
-        POSIX_INC(file, POSIX_FWRITES, 1); \
+        DARSHAN_COUNTER_INC(file->file_record, POSIX_FWRITES, 1); \
     else \
-        POSIX_INC(file, POSIX_WRITES, 1); \
+        DARSHAN_COUNTER_INC(file->file_record, POSIX_WRITES, 1); \
     /* CP_BUCKET_INC(file, CP_SIZE_WRITE_0_100, __ret); \
     if(!__aligned) \
-    if(file->last_io_type == CP_READ) \
-    file->last_io_type = CP_WRITE; */ \
-    POSIX_F_INC_NO_OVERLAP(file, __tm1, __tm2, file->last_write_end, POSIX_F_WRITE_TIME); \
-    if(POSIX_F_VALUE(file, POSIX_F_WRITE_START_TIMESTAMP) == 0) \
-        POSIX_F_SET(file, POSIX_F_WRITE_START_TIMESTAMP, __tm1); \
-    POSIX_F_SET(file, POSIX_F_WRITE_END_TIMESTAMP, __tm2); \
-    if(POSIX_F_VALUE(file, POSIX_F_MAX_WRITE_TIME) < __elapsed){ \
-        POSIX_F_SET(file, POSIX_F_MAX_WRITE_TIME, __elapsed); \
-        POSIX_SET(file, POSIX_MAX_WRITE_TIME_SIZE, __ret); } \
+    if(file->last_io_type == POSIX_READ) \
+    file->last_io_type = POSIX_WRITE; \
+    DARSHAN_COUNTER_F_INC_NO_OVERLAP(file->file_record, __tm1, __tm2, file->last_write_end, POSIX_F_WRITE_TIME); \
+    if(DARSHAN_COUNTER_F_VALUE(file->file_record, POSIX_F_WRITE_START_TIMESTAMP) == 0) \
+        DARSHAN_COUNTER_F_SET(file->file_record, POSIX_F_WRITE_START_TIMESTAMP, __tm1); \
+    DARSHAN_COUNTER_F_SET(file->file_record, POSIX_F_WRITE_END_TIMESTAMP, __tm2); \
+    if(DARSHAN_COUNTER_F_VALUE(file->file_record, POSIX_F_MAX_WRITE_TIME) < __elapsed){ \
+        DARSHAN_COUNTER_F_SET(file->file_record, POSIX_F_MAX_WRITE_TIME, __elapsed); \
+        DARSHAN_COUNTER_SET(file->file_record, POSIX_MAX_WRITE_TIME_SIZE, __ret); } \
 } while(0)
+ *      Wrappers for POSIX I/O functions of interest      *
 int DARSHAN_DECL(open)(const char *path, int flags, ...)
     int mode = 0;
@@ -577,10 +576,12 @@ int DARSHAN_DECL(close)(int fd)
     file = posix_file_by_fd(fd);
     if(file)
-        POSIX_F_SET(file, POSIX_F_CLOSE_TIMESTAMP, darshan_core_wtime());
-        POSIX_F_INC_NO_OVERLAP(file, tm1, tm2, file->last_meta_end, POSIX_F_META_TIME);
+            POSIX_F_CLOSE_TIMESTAMP, darshan_core_wtime());
+             tm1, tm2, file->last_meta_end, POSIX_F_META_TIME);
         posix_file_close_fd(fd);
     POSIX_UNLOCK();
@@ -588,8 +589,11 @@ int DARSHAN_DECL(close)(int fd)
     return(ret);
+ * Internal functions for manipulating POSIX module state *
+/* initialize internal POSIX module data structures and register with darshan-core */
 static void posix_runtime_initialize()
     int mem_limit;
@@ -597,7 +601,7 @@ static void posix_runtime_initialize()
         .disable_instrumentation = &posix_disable_instrumentation,
         .prepare_for_reduction = &posix_prepare_for_reduction,
-        .record_reduction_op = &posix_record_reduction_op,
+        .record_reduction_op = NULL,//&posix_record_reduction_op,
         .get_output_data = &posix_get_output_data,
         .shutdown = &posix_shutdown
@@ -648,6 +652,7 @@ static void posix_runtime_initialize()
     return;
+/* get a POSIX file record for the given file path */
 static struct posix_file_runtime* posix_file_by_name(const char *name)
     struct posix_file_runtime *file = NULL;
@@ -696,6 +701,9 @@ static struct posix_file_runtime* posix_file_by_name(const char *name)
     return(file);
+/* get a POSIX file record for the given file path, and also create a
+ * reference structure using the returned file descriptor
 static struct posix_file_runtime* posix_file_by_name_setfd(const char* name, int fd)
@@ -736,6 +744,7 @@ static struct posix_file_runtime* posix_file_by_name_setfd(const char* name, int
     return(file);
+/* get a POSIX file record for the given file descriptor */
 static struct posix_file_runtime* posix_file_by_fd(int fd)
     struct posix_file_runtime_ref* ref;
@@ -751,6 +760,7 @@ static struct posix_file_runtime* posix_file_by_fd(int fd)
     return(NULL);
+/* free up reference data structures for the given file descriptor */
 static void posix_file_close_fd(int fd)
@@ -770,6 +780,7 @@ static void posix_file_close_fd(int fd)
     return;
+/* compare function for sorting file records by descending rank */
 static int posix_file_compare(const void* a, const void* b)
     const struct darshan_posix_file* f_a = a;
@@ -783,7 +794,9 @@ static int posix_file_compare(const void* a, const void* b)
     return 0;
+ * Functions exported by this module for coordinating with darshan-core *
 static void posix_disable_instrumentation()
@@ -877,6 +890,28 @@ static void posix_record_reduction_op(
         tmp_file.counters[POSIX_MODE] = infile->counters[POSIX_MODE];
+        /* sum */
+        for(j=POSIX_BYTES_READ; j<=POSIX_BYTES_WRITTEN; j++)
+            tmp_file.counters[j] = infile->counters[j] + inoutfile->counters[j];
+        /* max */
+        for(j=POSIX_MAX_BYTE_READ; j<=POSIX_MAX_BYTE_WRITTEN; j++)
+            tmp_file.counters[j] = (
+                (infile->counters[j] > inoutfile->counters[j]) ?
+                infile->counters[j] :
+                inoutfile->counters[j]);
+        /* sum */
+        for(j=POSIX_CONSEC_READS; j<=POSIX_RW_SWITCHES; j++)
         /* min non-zero (if available) value */
         for(j=POSIX_F_OPEN_TIMESTAMP; j<=POSIX_F_WRITE_START_TIMESTAMP; j++)
diff --git a/darshan-util/darshan-posix-parser.c b/darshan-util/darshan-posix-parser.c
index 7519e5e..c645d38 100644
--- a/darshan-util/darshan-posix-parser.c
+++ b/darshan-util/darshan-posix-parser.c
@@ -177,6 +177,15 @@ int main(int argc, char **argv)
             "\t\tPOSIX_FREADS:\t%"PRIu64"\n"
             "\t\tPOSIX_FWRITES:\t%"PRIu64"\n"
             "\t\tPOSIX_MODE:\t%"PRIu64"\n"
+            "\t\tPOSIX_BYTES_READ:\t%"PRIu64"\n"
+            "\t\tPOSIX_BYTES_WRITTEN:\t%"PRIu64"\n"
+            "\t\tPOSIX_MAX_BYTE_READ:\t%"PRIu64"\n"
+            "\t\tPOSIX_MAX_BYTE_WRITTEN:\t%"PRIu64"\n"
+            "\t\tPOSIX_CONSEC_READS:\t%"PRIu64"\n"
+            "\t\tPOSIX_CONSEC_WRITES:\t%"PRIu64"\n"
+            "\t\tPOSIX_SEQ_READS:\t%"PRIu64"\n"
+            "\t\tPOSIX_SEQ_WRITES:\t%"PRIu64"\n"
+            "\t\tPOSIX_RW_SWITCHES:\t%"PRIu64"\n"
             "\t\tPOSIX_MAX_READ_TIME_SIZE:\t%"PRIu64"\n"
             "\t\tPOSIX_MAX_WRITE_TIME_SIZE:\t%"PRIu64"\n"
             "\t\tPOSIX_F_OPEN_TIMESTAMP:\t%lf\n"
@@ -196,6 +205,15 @@ int main(int argc, char **argv)
             next_file.counters[POSIX_FREADS],
             next_file.counters[POSIX_FWRITES],
             next_file.counters[POSIX_MODE],
+            next_file.counters[POSIX_BYTES_READ],
+            next_file.counters[POSIX_BYTES_WRITTEN],
+            next_file.counters[POSIX_MAX_BYTE_READ],
+            next_file.counters[POSIX_MAX_BYTE_WRITTEN],
+            next_file.counters[POSIX_CONSEC_READS],
+            next_file.counters[POSIX_CONSEC_WRITES],
+            next_file.counters[POSIX_SEQ_READS],
+            next_file.counters[POSIX_SEQ_WRITES],
+            next_file.counters[POSIX_RW_SWITCHES],
             next_file.counters[POSIX_MAX_READ_TIME_SIZE],
             next_file.counters[POSIX_MAX_WRITE_TIME_SIZE],
             next_file.fcounters[POSIX_F_OPEN_TIMESTAMP],
hooks/post-receive
More information about the Darshan-commits mailing list
