[Darshan-commits] [Darshan] branch, dev-modular, updated. darshan-2.3.1-69-g1a85617
Service Account git at mcs.anl.gov
Wed Mar 25 12:58:05 CDT 2015
This is an automated email from the git hooks/post-receive script. It was
generated because a ref change was pushed to the repository containing
the project "".
The branch, dev-modular has been updated
       via  1a856178c65897ea196c36962133c2e1adf6cbba (commit)
      from  969f0b8dc38ae7776b80843c8077028f1f47eb8e (commit)
Those revisions listed above that are new to this repository have
not appeared on any other notification email; so we list those
revisions in full, below.
- Log -----------------------------------------------------------------
commit 1a856178c65897ea196c36962133c2e1adf6cbba
Author: Shane Snyder <ssnyder at mcs.anl.gov>
Date:   Wed Mar 25 12:57:23 2015 -0500
    shared record reduction enhancements
Summary of changes:
 darshan-runtime/darshan-core.h      |    3 -
 darshan-runtime/darshan.h           |    2 +-
 darshan-runtime/lib/darshan-core.c  |    5 +-
 darshan-runtime/lib/darshan-mpiio.c |    8 ++--
 darshan-runtime/lib/darshan-posix.c |   82 ++++++++++++++++++++++++++++------
 darshan-util/darshan-logutils.c     |    2 -
 6 files changed, 75 insertions(+), 27 deletions(-)
Diff of changes:
diff --git a/darshan-runtime/darshan-core.h b/darshan-runtime/darshan-core.h
index b68f2fa..55fb657 100644
--- a/darshan-runtime/darshan-core.h
+++ b/darshan-runtime/darshan-core.h
@@ -16,16 +16,13 @@
 /* TODO: this goes where ? -- shared libs */
 #define DARSHAN_MPI_CALL(func) func
 #define DARSHAN_CORE_MAX_RECORDS 1024
 /* TODO: revisit this default size if we change memory per module */
 #define DARSHAN_CORE_COMP_BUF_SIZE (2 * 1024 * 1024)
 #define DARSHAN_CORE_MOD_SET(flags, id) (flags | (1 << id))
 #define DARSHAN_CORE_MOD_UNSET(flags, id) (flags & ~(1 << id))
 #define DARSHAN_CORE_MOD_ISSET(flags, id) (flags & (1 << id))
 /* in memory structure to keep up with job level data */
diff --git a/darshan-runtime/darshan.h b/darshan-runtime/darshan.h
index c88f9bc..e9a8f33 100644
--- a/darshan-runtime/darshan.h
+++ b/darshan-runtime/darshan.h
@@ -40,7 +40,7 @@ struct darshan_module_funcs
         int *rec_size /* size of records being stored for this module */
     /* reduce records which are shared globally across this module */
-    void (*reduce_records)(
+    void (*record_reduction_op)(
         void* infile_v,
         void* inoutfile_v,
         int *len,
diff --git a/darshan-runtime/lib/darshan-core.c b/darshan-runtime/lib/darshan-core.c
index da24bda..d62d308 100644
--- a/darshan-runtime/lib/darshan-core.c
+++ b/darshan-runtime/lib/darshan-core.c
@@ -508,7 +508,8 @@ static void darshan_core_shutdown()
             /* if there are globally shared files, do a shared file reduction */
-            if(shared_rec_count)
+            if(shared_rec_count && this_mod->mod_funcs.prepare_for_reduction &&
+               this_mod->mod_funcs.record_reduction_op)
                 this_mod->mod_funcs.prepare_for_reduction(mod_shared_recs, &shared_rec_count,
                     &red_send_buf, &red_recv_buf, &rec_sz);
@@ -522,7 +523,7 @@ static void darshan_core_shutdown()
                     DARSHAN_MPI_CALL(PMPI_Type_commit)(&red_type);
                     /* register a reduction operator for this module */
-                    DARSHAN_MPI_CALL(PMPI_Op_create)(this_mod->mod_funcs.reduce_records,
+                    DARSHAN_MPI_CALL(PMPI_Op_create)(this_mod->mod_funcs.record_reduction_op,
                         1, &red_op);
                     /* reduce shared file records for this module */
diff --git a/darshan-runtime/lib/darshan-mpiio.c b/darshan-runtime/lib/darshan-mpiio.c
index 8f5d27f..72654b2 100644
--- a/darshan-runtime/lib/darshan-mpiio.c
+++ b/darshan-runtime/lib/darshan-mpiio.c
@@ -171,7 +171,7 @@ static void mpiio_runtime_initialize()
         .disable_instrumentation = &mpiio_disable_instrumentation,
         .prepare_for_reduction = NULL,
-        .reduce_records = NULL,
+        .record_reduction_op = NULL,
         .get_output_data = &mpiio_get_output_data,
         .shutdown = &mpiio_shutdown
@@ -275,7 +275,7 @@ static void posix_file_close_fd(int fd);
 static void posix_prepare_for_reduction(darshan_record_id *shared_recs,
     int *shared_rec_count, void **send_buf, void **recv_buf, int *rec_size);
-static void posix_reduce_records(void* infile_v, void* inoutfile_v,
+static void posix_record_reduction_op(void* infile_v, void* inoutfile_v,
     int *len, MPI_Datatype *datatype);
 static void posix_get_output_data(void **buffer, int *size);
 static void posix_shutdown(void);
@@ -451,7 +451,7 @@ static void posix_runtime_initialize()
         .disable_instrumentation = &posix_disable_instrumentation,
         .prepare_for_reduction = &posix_prepare_for_reduction,
-        .reduce_records = &posix_reduce_records,
+        .record_reduction_op = &posix_record_reduction_op,
         .get_output_data = &posix_get_output_data,
         .shutdown = &posix_shutdown
@@ -691,7 +691,7 @@ static void posix_prepare_for_reduction(
     return;
     void* infile_v,
     void* inoutfile_v,
     int *len,
diff --git a/darshan-runtime/lib/darshan-posix.c b/darshan-runtime/lib/darshan-posix.c
index 9ca2bfd..3852a98 100644
--- a/darshan-runtime/lib/darshan-posix.c
+++ b/darshan-runtime/lib/darshan-posix.c
@@ -144,7 +144,7 @@ static void posix_file_close_fd(int fd);
 static void posix_disable_instrumentation(void);
@@ -648,7 +648,7 @@ static void posix_runtime_initialize()
@@ -899,7 +899,7 @@ static void posix_prepare_for_reduction(
     return;
     void* infile_v,
     void* inoutfile_v,
     int *len,
@@ -909,29 +909,81 @@ static void posix_reduce_records(
     struct darshan_posix_file *infile = infile_v;
     struct darshan_posix_file *inoutfile = inoutfile_v;
     int i;
+    int j;
     assert(posix_runtime);
-    for(i = 0; i < *len; i++)
+    for(i=0; i<*len; i++)
         memset(&tmp_file, 0, sizeof(struct darshan_posix_file));
         tmp_file.f_id = infile->f_id;
         tmp_file.rank = -1;
-        tmp_file.counters[POSIX_OPENS] = infile->counters[POSIX_OPENS] +
-            inoutfile->counters[POSIX_OPENS];
-        if((infile->fcounters[POSIX_F_OPEN_TIMESTAMP] > inoutfile->fcounters[POSIX_F_OPEN_TIMESTAMP]) &&
-            (inoutfile->fcounters[POSIX_F_OPEN_TIMESTAMP] > 0))
-            tmp_file.fcounters[POSIX_F_OPEN_TIMESTAMP] = inoutfile->fcounters[POSIX_F_OPEN_TIMESTAMP];
+        /* sum */
+        for(j=POSIX_OPENS; j<=POSIX_FWRITES; j++)
+            tmp_file.counters[j] = infile->counters[j] + inoutfile->counters[j];
+        tmp_file.counters[POSIX_MODE] = infile->counters[POSIX_MODE];
+        /* min non-zero (if available) value */
+        for(j=POSIX_F_OPEN_TIMESTAMP; j<=POSIX_F_WRITE_START_TIMESTAMP; j++)
+            if(infile->fcounters[j] > inoutfile->fcounters[j] && inoutfile->fcounters[j] > 0)
+                tmp_file.fcounters[j] = inoutfile->fcounters[j];
+            else
+                tmp_file.fcounters[j] = infile->fcounters[j];
+        /* max */
+        for(j=POSIX_F_READ_END_TIMESTAMP; j<=POSIX_F_CLOSE_TIMESTAMP; j++)
+            if(infile->fcounters[j] > inoutfile->fcounters[j])
+            else
+        /* sum */
+        for(j=POSIX_F_READ_TIME; j<=POSIX_F_META_TIME; j++)
+            tmp_file.fcounters[j] = infile->fcounters[j] + inoutfile->fcounters[j];
+        /* max (special case) */
+        if(infile->fcounters[POSIX_F_MAX_READ_TIME] >
+            inoutfile->fcounters[POSIX_F_MAX_READ_TIME])
+            tmp_file.fcounters[POSIX_F_MAX_READ_TIME] =
+                infile->fcounters[POSIX_F_MAX_READ_TIME];
+            tmp_file.counters[POSIX_MAX_READ_TIME_SIZE] =
+                infile->counters[POSIX_MAX_READ_TIME_SIZE];
         else
-            tmp_file.fcounters[POSIX_F_OPEN_TIMESTAMP] = infile->fcounters[POSIX_F_OPEN_TIMESTAMP];
-        if(infile->fcounters[POSIX_F_CLOSE_TIMESTAMP] > inoutfile->fcounters[POSIX_F_CLOSE_TIMESTAMP])
-            tmp_file.fcounters[POSIX_F_CLOSE_TIMESTAMP] = infile->fcounters[POSIX_F_CLOSE_TIMESTAMP];
+                inoutfile->fcounters[POSIX_F_MAX_READ_TIME];
+                inoutfile->counters[POSIX_MAX_READ_TIME_SIZE];
+        if(infile->fcounters[POSIX_F_MAX_WRITE_TIME] >
+            inoutfile->fcounters[POSIX_F_MAX_WRITE_TIME])
+            tmp_file.fcounters[POSIX_F_MAX_WRITE_TIME] =
+                infile->fcounters[POSIX_F_MAX_WRITE_TIME];
+            tmp_file.counters[POSIX_MAX_WRITE_TIME_SIZE] =
+                infile->counters[POSIX_MAX_WRITE_TIME_SIZE];
         else
-            tmp_file.fcounters[POSIX_F_CLOSE_TIMESTAMP] = inoutfile->fcounters[POSIX_F_CLOSE_TIMESTAMP];
+                inoutfile->fcounters[POSIX_F_MAX_WRITE_TIME];
+                inoutfile->counters[POSIX_MAX_WRITE_TIME_SIZE];
         /* update pointers */
         *inoutfile = tmp_file;
diff --git a/darshan-util/darshan-logutils.c b/darshan-util/darshan-logutils.c
index ebb4ced..a94eda3 100644
--- a/darshan-util/darshan-logutils.c
+++ b/darshan-util/darshan-logutils.c
@@ -22,8 +22,6 @@
 static int darshan_log_seek(darshan_fd fd, off_t offset);
 static int darshan_log_read(darshan_fd fd, void *buf, int len);
 static int darshan_log_write(darshan_fd fd, void *buf, int len);
-static int darshan_decompress_buffer(char *comp_buf, int comp_buf_sz,
-    char *decomp_buf, int *inout_decomp_buf_sz);
 /* darshan_log_open()
hooks/post-receive
More information about the Darshan-commits mailing list
