[Darshan-commits] [Darshan] branch, dev-modular, updated. darshan-2.3.1-65-g0448ed3
Service Account
git at mcs.anl.gov
Wed Mar 25 09:22:16 CDT 2015
This is an automated email from the git hooks/post-receive script. It was
generated because a ref change was pushed to the repository containing
the project "".
The branch, dev-modular has been updated
via 0448ed3c6ad5cc81e5c7800d9b605690e560e2f9 (commit)
from 165a27fc58a7791bf3cc0f6e9986a2ba9db311ab (commit)
Those revisions listed above that are new to this repository have
not appeared on any other notification email; so we list those
revisions in full, below.
- Log -----------------------------------------------------------------
commit 0448ed3c6ad5cc81e5c7800d9b605690e560e2f9
Author: Shane Snyder <ssnyder at mcs.anl.gov>
Date: Wed Mar 25 09:20:57 2015 -0500
code cleanup + posix read/write wrappers
Summary of changes:
darshan-posix-log-format.h | 191 +++++++------
darshan-runtime/configure | 4 +-
darshan-runtime/configure.in | 4 +-
darshan-runtime/darshan-config.in | 1 -
darshan-runtime/lib/darshan-core.c | 4 +-
darshan-runtime/lib/darshan-posix.c | 426 ++++++++++++++++++++++++---
darshan-util/darshan-posix-logutils.c | 4 +-
darshan-util/darshan-posix-parser.c | 44 +++-
doc/darshan-modularization-design-notes.txt | 13 -
9 files changed, 533 insertions(+), 158 deletions(-)
Diff of changes:
diff --git a/darshan-posix-log-format.h b/darshan-posix-log-format.h
index cc0d46d..0eae1fa 100644
--- a/darshan-posix-log-format.h
+++ b/darshan-posix-log-format.h
@@ -8,121 +8,130 @@
#include "darshan-log-format.h"
-/* TODO: DARSHAN_* OR CP_* */
enum darshan_posix_indices
- CP_POSIX_READS, /* count of posix reads */
- CP_POSIX_WRITES, /* count of posix writes */
- CP_POSIX_OPENS, /* count of posix opens */
- CP_POSIX_SEEKS, /* count of posix seeks */
- CP_POSIX_STATS, /* count of posix stat/lstat/fstats */
- CP_POSIX_MMAPS, /* count of posix mmaps */
- CP_POSIX_FREADS,
- CP_POSIX_FWRITES,
- CP_POSIX_FOPENS,
- CP_POSIX_FSEEKS,
- CP_POSIX_FSYNCS,
- CP_POSIX_FDSYNCS,
- CP_MODE, /* mode of file */
- CP_BYTES_READ, /* total bytes read */
- CP_BYTES_WRITTEN, /* total bytes written */
- CP_MAX_BYTE_READ, /* highest offset byte read */
- CP_MAX_BYTE_WRITTEN, /* highest offset byte written */
- CP_CONSEC_READS, /* count of consecutive reads */
- CP_CONSEC_WRITES, /* count of consecutive writes */
- CP_SEQ_READS, /* count of sequential reads */
- CP_SEQ_WRITES, /* count of sequential writes */
- CP_RW_SWITCHES, /* number of times switched between read and write */
- CP_MEM_NOT_ALIGNED, /* count of accesses not mem aligned */
- CP_MEM_ALIGNMENT, /* mem alignment in bytes */
- CP_FILE_NOT_ALIGNED, /* count of accesses not file aligned */
- CP_FILE_ALIGNMENT, /* file alignment in bytes */
- CP_MAX_READ_TIME_SIZE,
- CP_MAX_WRITE_TIME_SIZE,
+ POSIX_OPENS, /* count of posix opens */
+ POSIX_READS, /* count of posix reads */
+ POSIX_WRITES, /* count of posix writes */
+#if 0
+ POSIX_SEEKS, /* count of posix seeks */
+ POSIX_STATS, /* count of posix stat/lstat/fstats */
+ POSIX_MMAPS, /* count of posix mmaps */
+#endif
+ POSIX_FOPENS,
+ POSIX_FREADS,
+ POSIX_FWRITES,
+#if 0
+ POSIX_FSEEKS,
+ POSIX_FSYNCS,
+ POSIX_FDSYNCS,
+#endif
+ POSIX_MODE, /* mode of file */
+#if 0
+ POSIX_BYTES_READ, /* total bytes read */
+ POSIX_BYTES_WRITTEN, /* total bytes written */
+ POSIX_MAX_BYTE_READ, /* highest offset byte read */
+ POSIX_MAX_BYTE_WRITTEN, /* highest offset byte written */
+ CONSEC_READS, /* count of consecutive reads */
+ CONSEC_WRITES, /* count of consecutive writes */
+ SEQ_READS, /* count of sequential reads */
+ SEQ_WRITES, /* count of sequential writes */
+ RW_SWITCHES, /* number of times switched between read and write */
+ MEM_NOT_ALIGNED, /* count of accesses not mem aligned */
+ MEM_ALIGNMENT, /* mem alignment in bytes */
+ FILE_NOT_ALIGNED, /* count of accesses not file aligned */
+ FILE_ALIGNMENT, /* file alignment in bytes */
+#endif
+ POSIX_MAX_READ_TIME_SIZE,
+ POSIX_MAX_WRITE_TIME_SIZE,
+#if 0
/* buckets */
- CP_SIZE_READ_0_100, /* count of posix read size ranges */
- CP_SIZE_READ_100_1K,
- CP_SIZE_READ_1K_10K,
- CP_SIZE_READ_10K_100K,
- CP_SIZE_READ_100K_1M,
- CP_SIZE_READ_1M_4M,
- CP_SIZE_READ_4M_10M,
- CP_SIZE_READ_10M_100M,
- CP_SIZE_READ_100M_1G,
- CP_SIZE_READ_1G_PLUS,
+ SIZE_READ_0_100, /* count of posix read size ranges */
+ SIZE_READ_100_1K,
+ SIZE_READ_1K_10K,
+ SIZE_READ_10K_100K,
+ SIZE_READ_100K_1M,
+ SIZE_READ_1M_4M,
+ SIZE_READ_4M_10M,
+ SIZE_READ_10M_100M,
+ SIZE_READ_100M_1G,
+ SIZE_READ_1G_PLUS,
/* buckets */
- CP_SIZE_WRITE_0_100, /* count of posix write size ranges */
- CP_SIZE_WRITE_100_1K,
- CP_SIZE_WRITE_1K_10K,
- CP_SIZE_WRITE_10K_100K,
- CP_SIZE_WRITE_100K_1M,
- CP_SIZE_WRITE_1M_4M,
- CP_SIZE_WRITE_4M_10M,
- CP_SIZE_WRITE_10M_100M,
- CP_SIZE_WRITE_100M_1G,
- CP_SIZE_WRITE_1G_PLUS,
+ SIZE_WRITE_0_100, /* count of posix write size ranges */
+ SIZE_WRITE_100_1K,
+ SIZE_WRITE_1K_10K,
+ SIZE_WRITE_10K_100K,
+ SIZE_WRITE_100K_1M,
+ SIZE_WRITE_1M_4M,
+ SIZE_WRITE_4M_10M,
+ SIZE_WRITE_10M_100M,
+ SIZE_WRITE_100M_1G,
+ SIZE_WRITE_1G_PLUS,
/* counters */
- CP_STRIDE1_STRIDE, /* the four most frequently appearing strides */
- CP_STRIDE2_STRIDE,
- CP_STRIDE3_STRIDE,
- CP_STRIDE4_STRIDE,
- CP_STRIDE1_COUNT, /* count of each of the most frequent strides */
- CP_STRIDE2_COUNT,
- CP_STRIDE3_COUNT,
- CP_STRIDE4_COUNT,
- CP_ACCESS1_ACCESS, /* the four most frequently appearing access sizes */
- CP_ACCESS2_ACCESS,
- CP_ACCESS3_ACCESS,
- CP_ACCESS4_ACCESS,
- CP_ACCESS1_COUNT, /* count of each of the most frequent access sizes */
- CP_ACCESS2_COUNT,
- CP_ACCESS3_COUNT,
- CP_ACCESS4_COUNT,
- CP_DEVICE, /* device id reported by stat */
- CP_SIZE_AT_OPEN,
- CP_FASTEST_RANK,
- CP_FASTEST_RANK_BYTES,
- CP_SLOWEST_RANK,
- CP_SLOWEST_RANK_BYTES,
+ STRIDE1_STRIDE, /* the four most frequently appearing strides */
+ STRIDE2_STRIDE,
+ STRIDE3_STRIDE,
+ STRIDE4_STRIDE,
+ STRIDE1_COUNT, /* count of each of the most frequent strides */
+ STRIDE2_COUNT,
+ STRIDE3_COUNT,
+ STRIDE4_COUNT,
+ ACCESS1_ACCESS, /* the four most frequently appearing access sizes */
+ ACCESS2_ACCESS,
+ ACCESS3_ACCESS,
+ ACCESS4_ACCESS,
+ ACCESS1_COUNT, /* count of each of the most frequent access sizes */
+ ACCESS2_COUNT,
+ ACCESS3_COUNT,
+ ACCESS4_COUNT,
+ DEVICE, /* device id reported by stat */
+ SIZE_AT_OPEN,
+ FASTEST_RANK,
+ FASTEST_RANK_BYTES,
+ SLOWEST_RANK,
+ SLOWEST_RANK_BYTES,
+#endif
- CP_NUM_INDICES,
+ POSIX_NUM_INDICES,
/* floating point statistics */
-enum darshan_f_posix_indices
+enum darshan_posix_f_indices
/* NOTE: adjust cp_normalize_timestamps() function if any TIMESTAMPS are
* added or modified in this list
- CP_F_OPEN_TIMESTAMP = 0, /* timestamp of first open */
- CP_F_READ_START_TIMESTAMP, /* timestamp of first read */
- CP_F_WRITE_START_TIMESTAMP, /* timestamp of first write */
- CP_F_CLOSE_TIMESTAMP, /* timestamp of last close */
- CP_F_READ_END_TIMESTAMP, /* timestamp of last read */
- CP_F_WRITE_END_TIMESTAMP, /* timestamp of last write */
- CP_F_POSIX_READ_TIME, /* cumulative posix read time */
- CP_F_POSIX_WRITE_TIME, /* cumulative posix write time */
- CP_F_POSIX_META_TIME, /* cumulative posix meta time */
- CP_F_MAX_READ_TIME,
- CP_F_MAX_WRITE_TIME,
+ POSIX_F_OPEN_TIMESTAMP = 0, /* timestamp of first open */
+ POSIX_F_READ_START_TIMESTAMP, /* timestamp of first read */
+ POSIX_F_WRITE_START_TIMESTAMP, /* timestamp of first write */
+ POSIX_F_READ_END_TIMESTAMP, /* timestamp of last read */
+ POSIX_F_WRITE_END_TIMESTAMP, /* timestamp of last write */
+ POSIX_F_CLOSE_TIMESTAMP, /* timestamp of last close */
+ POSIX_F_READ_TIME, /* cumulative posix read time */
+ POSIX_F_WRITE_TIME, /* cumulative posix write time */
+ POSIX_F_META_TIME, /* cumulative posix meta time */
+ POSIX_F_MAX_READ_TIME,
+ POSIX_F_MAX_WRITE_TIME,
+#if 0
/* Total I/O and meta time consumed by fastest and slowest ranks,
* reported in either MPI or POSIX time depending on how the file
* was accessed.
- CP_F_FASTEST_RANK_TIME,
- CP_F_SLOWEST_RANK_TIME,
- CP_F_VARIANCE_RANK_TIME,
- CP_F_VARIANCE_RANK_BYTES,
+ F_FASTEST_RANK_TIME,
+ F_SLOWEST_RANK_TIME,
+ F_VARIANCE_RANK_TIME,
+ F_VARIANCE_RANK_BYTES,
+#endif
- CP_F_NUM_INDICES,
+ POSIX_F_NUM_INDICES,
struct darshan_posix_file
darshan_record_id f_id;
int64_t rank;
- int64_t counters[CP_NUM_INDICES];
- double fcounters[CP_F_NUM_INDICES];
+ int64_t counters[POSIX_NUM_INDICES];
+ double fcounters[POSIX_F_NUM_INDICES];
#endif /* __DARSHAN_POSIX_LOG_FORMAT_H */
diff --git a/darshan-runtime/configure b/darshan-runtime/configure
index 6322a34..1b62d50 100755
--- a/darshan-runtime/configure
+++ b/darshan-runtime/configure
@@ -4079,10 +4079,10 @@ fi
done
-# libc functions wrapped by darshan
#CP_WRAPPERS="-Wl,-u,MPI_Init,-u,MPI_Wtime,-wrap,write,-wrap,open,-wrap,creat,-wrap,creat64,-wrap,open64,-wrap,close,-wrap,read,-wrap,lseek,-wrap,lseek64,-wrap,pread,-wrap,pwrite,-wrap,readv,-wrap,writev,-wrap,__xstat,-wrap,__lxstat,-wrap,__fxstat,-wrap,__xstat64,-wrap,__lxstat64,-wrap,__fxstat64,-wrap,mmap,-wrap,mmap64,-wrap,fopen,-wrap,fclose,-wrap,fread,-wrap,fwrite,-wrap,fseek,-wrap,fopen64,-wrap,pread64,-wrap,pwrite64,-wrap,fsync,-wrap,fdatasync,-wrap,ncmpi_create,-wrap,ncmpi_open,-wrap,ncmpi_close,-wrap,H5Fcreate,-wrap,H5Fopen,-wrap,H5Fclose,-wrap,aio_write,-wrap,aio_write64,-wrap,aio_read,-wrap,aio_read64,-wrap,lio_listio,-wrap,lio_listio64,-wrap,aio_return,-wrap,aio_return64,-wrap,mkstemp,-wrap,mkostemp,-wrap,mkstemps,-wrap,mkostemps"
-CP_WRAPPERS="-Wl,-u,MPI_Init,-u,MPI_Wtime,-wrap,open,-wrap,open64,-wrap,close"
+# libc functions wrapped by darshan
+CP_WRAPPERS="-Wl,-u,MPI_Init,-u,MPI_Wtime,-wrap,open,-wrap,open64,-wrap,creat,-wrap,creat64,-wrap,read,-wrap,write,-wrap,pread,-wrap,pwrite,-wrap,pread64,-wrap,pwrite64,-wrap,readv,-wrap,writev,-wrap,close"
# We need to know the value of the $libdir and $bindir variables so that
# we can reference the correct path in the darshan compiler wrappers.
diff --git a/darshan-runtime/configure.in b/darshan-runtime/configure.in
index 80f96da..c218a4b 100644
--- a/darshan-runtime/configure.in
+++ b/darshan-runtime/configure.in
@@ -187,10 +187,10 @@ CFLAGS="$old_cflags"
AC_CHECK_HEADERS(mntent.h sys/mount.h)
diff --git a/darshan-runtime/darshan-config.in b/darshan-runtime/darshan-config.in
index a0d0af0..bfeffdd 100755
--- a/darshan-runtime/darshan-config.in
+++ b/darshan-runtime/darshan-config.in
@@ -11,7 +11,6 @@ DARSHAN_LD_FLAGS="@LDFLAGS@"
# dependencies on PnetCDF and HDF5 symbols (if the app used a library which
# in turn used one of those HLLs).
-# TODO: extra -lmpi in POST_LD_FLAGS -- link ordering issue
PRE_LD_FLAGS="-L$DARSHAN_LIB_PATH $DARSHAN_LD_FLAGS -ldarshan -lz $CP_WRAPPERS"
POST_LD_FLAGS="-L$DARSHAN_LIB_PATH -ldarshan -lz -lrt -lpthread"
diff --git a/darshan-runtime/lib/darshan-core.c b/darshan-runtime/lib/darshan-core.c
index a415882..e969bf7 100644
--- a/darshan-runtime/lib/darshan-core.c
+++ b/darshan-runtime/lib/darshan-core.c
@@ -27,8 +27,8 @@
#include "uthash.h"
#include "darshan-core.h"
-/* TODO is __progname_full needed here */
extern char* __progname;
+extern char* __progname_full;
/* internal variable delcarations */
static struct darshan_core_runtime *darshan_core = NULL;
@@ -193,7 +193,7 @@ static void darshan_core_initialize(int argc, char **argv)
if(argc == 0)
chars_left = DARSHAN_EXE_LEN-strlen(darshan_core->exe);
- strncat(darshan_core->exe, __progname, chars_left);
+ strncat(darshan_core->exe, __progname_full, chars_left);
strncat(darshan_core->exe, " <unknown args>", chars_left);
diff --git a/darshan-runtime/lib/darshan-posix.c b/darshan-runtime/lib/darshan-posix.c
index 0a5ae13..3248d75 100644
--- a/darshan-runtime/lib/darshan-posix.c
+++ b/darshan-runtime/lib/darshan-posix.c
@@ -69,31 +69,46 @@ typedef int64_t off64_t;
#endif
+/* TODO: more libc, fgetc, etc etc etc. */
DARSHAN_FORWARD_DECL(open, int, (const char *path, int flags, ...));
DARSHAN_FORWARD_DECL(open64, int, (const char *path, int flags, ...));
+DARSHAN_FORWARD_DECL(creat, int, (const char* path, mode_t mode));
+DARSHAN_FORWARD_DECL(creat64, int, (const char* path, mode_t mode));
+DARSHAN_FORWARD_DECL(read, ssize_t, (int fd, void *buf, size_t count));
+DARSHAN_FORWARD_DECL(write, ssize_t, (int fd, const void *buf, size_t count));
+DARSHAN_FORWARD_DECL(pread, ssize_t, (int fd, void *buf, size_t count, off_t offset));
+DARSHAN_FORWARD_DECL(pwrite, ssize_t, (int fd, const void *buf, size_t count, off_t offset));
+DARSHAN_FORWARD_DECL(pread64, ssize_t, (int fd, void *buf, size_t count, off64_t offset));
+DARSHAN_FORWARD_DECL(pwrite64, ssize_t, (int fd, const void *buf, size_t count, off64_t offset));
+DARSHAN_FORWARD_DECL(readv, ssize_t, (int fd, const struct iovec *iov, int iovcnt));
+DARSHAN_FORWARD_DECL(writev, ssize_t, (int fd, const struct iovec *iov, int iovcnt));
DARSHAN_FORWARD_DECL(close, int, (int fd));
-struct posix_runtime_file
+struct posix_file_runtime
struct darshan_posix_file* file_record;
+ double last_meta_end;
+ double last_read_end;
+ double last_write_end;
UT_hash_handle hlink;
-struct posix_runtime_file_ref
+struct posix_file_runtime_ref
- struct posix_runtime_file* file;
+ struct posix_file_runtime* file;
int fd;
- struct posix_runtime_file* file_runtime_array;
+ struct posix_file_runtime* file_runtime_array;
struct darshan_posix_file* file_record_array;
int file_array_size;
int file_array_ndx;
- struct posix_runtime_file* file_hash;
- struct posix_runtime_file_ref* fd_hash;
+ struct posix_file_runtime* file_hash;
+ struct posix_file_runtime_ref* fd_hash;
void *red_buf;
int shared_rec_count;
@@ -120,9 +135,9 @@ NULL
static void posix_runtime_initialize(void);
-static struct posix_runtime_file* posix_file_by_name(const char *name);
-static struct posix_runtime_file* posix_file_by_name_setfd(const char* name, int fd);
-static struct posix_runtime_file* posix_file_by_fd(int fd);
+static struct posix_file_runtime* posix_file_by_name(const char *name);
+static struct posix_file_runtime* posix_file_by_name_setfd(const char* name, int fd);
+static struct posix_file_runtime* posix_file_by_fd(int fd);
static void posix_file_close_fd(int fd);
static void posix_disable_instrumentation(void);
@@ -175,7 +190,7 @@ static void posix_shutdown(void);
} while(0)
#define POSIX_RECORD_OPEN(__ret, __path, __mode, __stream_flag, __tm1, __tm2) do { \
- struct posix_runtime_file* file; \
+ struct posix_file_runtime* file; \
char* exclude; \
int tmp_index = 0; \
if(__ret < 0) break; \
@@ -187,15 +202,120 @@ static void posix_shutdown(void);
if(exclude) break; \
file = posix_file_by_name_setfd(__path, __ret); \
if(!file) break; \
+ /* CP_STAT_FILE(file, __path, __ret); */ \
file->file_record->rank = my_rank; \
if(__mode) \
- POSIX_SET(file, CP_MODE, __mode); \
+ POSIX_SET(file, POSIX_MODE, __mode); \
+ /* file->offset = 0; */ \
+ /* file->last_byte_written = 0; */ \
+ /* file->last_byte_read = 0; */ \
if(__stream_flag)\
- POSIX_INC(file, CP_POSIX_FOPENS, 1); \
+ POSIX_INC(file, POSIX_FOPENS, 1); \
+ else \
+ POSIX_INC(file, POSIX_OPENS, 1); \
+ if(POSIX_F_VALUE(file, POSIX_F_OPEN_TIMESTAMP) == 0) \
+ POSIX_F_SET(file, POSIX_F_OPEN_TIMESTAMP, __tm1); \
+ POSIX_F_INC_NO_OVERLAP(file, __tm1, __tm2, file->last_meta_end, POSIX_F_META_TIME); \
+} while(0)
+#define POSIX_RECORD_READ(__ret, __fd, __pread_flag, __pread_offset, __aligned, __stream_flag, __tm1, __tm2) do{ \
+ /* size_t stride; \
+ int64_t this_offset; */ \
+ /* int64_t file_alignment; */ \
+ double __elapsed = __tm2-__tm1; \
+ if(__ret < 0) break; \
+ file = posix_file_by_fd(__fd); \
+ if(!file) break; \
+ /* if(__pread_flag) \
+ this_offset = __pread_offset; \
+ else \
+ this_offset = file->offset; \
+ file_alignment = CP_VALUE(file, CP_FILE_ALIGNMENT); \
+ if(this_offset > file->last_byte_read) \
+ CP_INC(file, CP_SEQ_READS, 1); \
+ if(this_offset == (file->last_byte_read + 1)) \
+ CP_INC(file, CP_CONSEC_READS, 1); \
+ if(this_offset > 0 && this_offset > file->last_byte_read \
+ && file->last_byte_read != 0) \
+ stride = this_offset - file->last_byte_read - 1; \
+ else \
+ stride = 0; \
+ file->last_byte_read = this_offset + __ret - 1; \
+ file->offset = this_offset + __ret; \
+ CP_MAX(file, CP_MAX_BYTE_READ, (this_offset + __ret -1)); \
+ CP_INC(file, CP_BYTES_READ, __ret); */\
+ if(__stream_flag)\
+ POSIX_INC(file, POSIX_FREADS, 1); \
+ else\
+ POSIX_INC(file, POSIX_READS, 1); \
+ /* CP_BUCKET_INC(file, CP_SIZE_READ_0_100, __ret); \
+ cp_access_counter(file, stride, CP_COUNTER_STRIDE); \
+ if(!__aligned) \
+ CP_INC(file, CP_MEM_NOT_ALIGNED, 1); \
+ if(file_alignment > 0 && (this_offset % file_alignment) != 0) \
+ CP_INC(file, CP_FILE_NOT_ALIGNED, 1); \
+ cp_access_counter(file, __ret, CP_COUNTER_ACCESS); \
+ if(file->last_io_type == CP_WRITE) \
+ CP_INC(file, CP_RW_SWITCHES, 1); \
+ file->last_io_type = CP_READ; */ \
+ POSIX_F_INC_NO_OVERLAP(file, __tm1, __tm2, file->last_read_end, POSIX_F_READ_TIME); \
+ if(POSIX_F_VALUE(file, POSIX_F_READ_START_TIMESTAMP) == 0) \
+ POSIX_F_SET(file, POSIX_F_READ_START_TIMESTAMP, __tm1); \
+ POSIX_F_SET(file, POSIX_F_READ_END_TIMESTAMP, __tm2); \
+ if(POSIX_F_VALUE(file, POSIX_F_MAX_READ_TIME) < __elapsed){ \
+ POSIX_F_SET(file, POSIX_F_MAX_READ_TIME, __elapsed); \
+ POSIX_SET(file, POSIX_MAX_READ_TIME_SIZE, __ret); } \
+} while(0)
+#define POSIX_RECORD_WRITE(__ret, __fd, __pwrite_flag, __pwrite_offset, __aligned, __stream_flag, __tm1, __tm2) do{ \
+ /* if(__pwrite_flag) \
+ this_offset = __pwrite_offset; \
+ else \
+ if(this_offset > file->last_byte_written) \
+ CP_INC(file, CP_SEQ_WRITES, 1); \
+ if(this_offset == (file->last_byte_written + 1)) \
+ CP_INC(file, CP_CONSEC_WRITES, 1); \
+ if(this_offset > 0 && this_offset > file->last_byte_written \
+ && file->last_byte_written != 0) \
+ stride = this_offset - file->last_byte_written - 1; \
else \
- POSIX_INC(file, CP_POSIX_OPENS, 1); \
- if(POSIX_F_VALUE(file, CP_F_OPEN_TIMESTAMP) == 0) \
- POSIX_F_SET(file, CP_F_OPEN_TIMESTAMP, __tm1); \
+ stride = 0; \
+ file->last_byte_written = this_offset + __ret - 1; \
+ CP_MAX(file, CP_MAX_BYTE_WRITTEN, (this_offset + __ret -1)); \
+ CP_INC(file, CP_BYTES_WRITTEN, __ret); */ \
+ if(__stream_flag) \
+ POSIX_INC(file, POSIX_FWRITES, 1); \
+ else \
+ POSIX_INC(file, POSIX_WRITES, 1); \
+ /* CP_BUCKET_INC(file, CP_SIZE_WRITE_0_100, __ret); \
+ if(!__aligned) \
+ if(file->last_io_type == CP_READ) \
+ file->last_io_type = CP_WRITE; */ \
+ POSIX_F_INC_NO_OVERLAP(file, __tm1, __tm2, file->last_write_end, POSIX_F_WRITE_TIME); \
+ if(POSIX_F_VALUE(file, POSIX_F_WRITE_START_TIMESTAMP) == 0) \
+ POSIX_F_SET(file, POSIX_F_WRITE_START_TIMESTAMP, __tm1); \
+ POSIX_F_SET(file, POSIX_F_WRITE_END_TIMESTAMP, __tm2); \
+ if(POSIX_F_VALUE(file, POSIX_F_MAX_WRITE_TIME) < __elapsed){ \
+ POSIX_F_SET(file, POSIX_F_MAX_WRITE_TIME, __elapsed); \
+ POSIX_SET(file, POSIX_MAX_WRITE_TIME_SIZE, __ret); } \
} while(0)
int DARSHAN_DECL(open)(const char *path, int flags, ...)
@@ -226,9 +346,7 @@ int DARSHAN_DECL(open)(const char *path, int flags, ...)
POSIX_LOCK();
posix_runtime_initialize();
POSIX_RECORD_OPEN(ret, path, mode, 0, tm1, tm2);
POSIX_UNLOCK();
return(ret);
@@ -262,16 +380,239 @@ int DARSHAN_DECL(open64)(const char *path, int flags, ...)
POSIX_LOCK();
+ POSIX_RECORD_OPEN(ret, path, mode, 0, tm1, tm2);
+ POSIX_UNLOCK();
+ return(ret);
+int DARSHAN_DECL(creat)(const char* path, mode_t mode)
+ int ret;
+ double tm1, tm2;
+ MAP_OR_FAIL(creat);
+ tm1 = darshan_core_wtime();
+ ret = __real_creat(path, mode);
+ tm2 = darshan_core_wtime();
+ POSIX_LOCK();
+ posix_runtime_initialize();
+ POSIX_UNLOCK();
+ return(ret);
+int DARSHAN_DECL(creat64)(const char* path, mode_t mode)
+ int ret;
+ double tm1, tm2;
+ MAP_OR_FAIL(creat64);
+ ret = __real_creat64(path, mode);
+ POSIX_LOCK();
POSIX_UNLOCK();
return(ret);
+ssize_t DARSHAN_DECL(read)(int fd, void *buf, size_t count)
+ ssize_t ret;
+ int aligned_flag = 0;
+ double tm1, tm2;
+ MAP_OR_FAIL(write);
+ /* if((unsigned long)buf % darshan_mem_alignment == 0) aligned_flag = 1; */
+ ret = __real_read(fd, buf, count);
+ POSIX_LOCK();
+ POSIX_RECORD_READ(ret, fd, 0, 0, aligned_flag, 0, tm1, tm2);
+ POSIX_UNLOCK();
+ return(ret);
+ssize_t DARSHAN_DECL(write)(int fd, const void *buf, size_t count)
+ ssize_t ret;
+ double tm1, tm2;
+ ret = __real_write(fd, buf, count);
+ POSIX_LOCK();
+ POSIX_RECORD_WRITE(ret, fd, 0, 0, aligned_flag, 0, tm1, tm2);
+ POSIX_UNLOCK();
+ return(ret);
+ssize_t DARSHAN_DECL(pread)(int fd, void *buf, size_t count, off_t offset)
+ ssize_t ret;
+ double tm1, tm2;
+ MAP_OR_FAIL(pread);
+ ret = __real_pread(fd, buf, count, offset);
+ POSIX_LOCK();
+ POSIX_RECORD_READ(ret, fd, 1, offset, aligned_flag, 0, tm1, tm2);
+ POSIX_UNLOCK();
+ return(ret);
+ssize_t DARSHAN_DECL(pwrite)(int fd, const void *buf, size_t count, off_t offset)
+ ssize_t ret;
+ double tm1, tm2;
+ MAP_OR_FAIL(pwrite);
+ ret = __real_pwrite(fd, buf, count, offset);
+ POSIX_LOCK();
+ POSIX_RECORD_WRITE(ret, fd, 1, offset, aligned_flag, 0, tm1, tm2);
+ POSIX_UNLOCK();
+ return(ret);
+ssize_t DARSHAN_DECL(pread64)(int fd, void *buf, size_t count, off64_t offset)
+ ssize_t ret;
+ double tm1, tm2;
+ MAP_OR_FAIL(pread64);
+ ret = __real_pread64(fd, buf, count, offset);
+ POSIX_LOCK();
+ POSIX_UNLOCK();
+ return(ret);
+ssize_t DARSHAN_DECL(pwrite64)(int fd, const void *buf, size_t count, off64_t offset)
+ ssize_t ret;
+ double tm1, tm2;
+ MAP_OR_FAIL(pwrite64);
+ ret = __real_pwrite64(fd, buf, count, offset);
+ POSIX_LOCK();
+ POSIX_UNLOCK();
+ return(ret);
+ssize_t DARSHAN_DECL(readv)(int fd, const struct iovec *iov, int iovcnt)
+ ssize_t ret;
+ /* int aligned_flag = 1; */
+ int i;
+ double tm1, tm2;
+ MAP_OR_FAIL(readv);
+ for(i=0; i<iovcnt; i++)
+ if(((unsigned long)iov[i].iov_base % darshan_mem_alignment) != 0)
+ aligned_flag = 0;
+ ret = __real_readv(fd, iov, iovcnt);
+ POSIX_LOCK();
+ POSIX_UNLOCK();
+ return(ret);
+ssize_t DARSHAN_DECL(writev)(int fd, const struct iovec *iov, int iovcnt)
+ ssize_t ret;
+ int i;
+ double tm1, tm2;
+ MAP_OR_FAIL(writev);
+ aligned_flag = 0;
+ ret = __real_writev(fd, iov, iovcnt);
+ POSIX_LOCK();
+ POSIX_UNLOCK();
+ return(ret);
int DARSHAN_DECL(close)(int fd)
double tm1, tm2;
int ret;
@@ -283,11 +624,13 @@ int DARSHAN_DECL(close)(int fd)
POSIX_LOCK();
file = posix_file_by_fd(fd);
if(file)
- POSIX_F_SET(file, CP_F_CLOSE_TIMESTAMP, darshan_core_wtime());
+ POSIX_F_SET(file, POSIX_F_CLOSE_TIMESTAMP, darshan_core_wtime());
+ POSIX_F_INC_NO_OVERLAP(file, tm1, tm2, file->last_meta_end, POSIX_F_META_TIME);
posix_file_close_fd(fd);
POSIX_UNLOCK();
@@ -333,12 +676,13 @@ static void posix_runtime_initialize()
/* set maximum number of file records according to max memory limit */
/* NOTE: maximum number of records is based on the size of a posix file record */
+ /* TODO: should we base memory usage off file record or total runtime structure sizes? */
posix_runtime->file_array_size = mem_limit / sizeof(struct darshan_posix_file);
posix_runtime->file_array_ndx = 0;
/* allocate array of runtime file records */
posix_runtime->file_runtime_array = malloc(posix_runtime->file_array_size *
- sizeof(struct posix_runtime_file));
+ sizeof(struct posix_file_runtime));
posix_runtime->file_record_array = malloc(posix_runtime->file_array_size *
sizeof(struct darshan_posix_file));
if(!posix_runtime->file_runtime_array || !posix_runtime->file_record_array)
@@ -347,7 +691,7 @@ static void posix_runtime_initialize()
return;
memset(posix_runtime->file_runtime_array, 0, posix_runtime->file_array_size *
memset(posix_runtime->file_record_array, 0, posix_runtime->file_array_size *
@@ -357,9 +701,9 @@ static void posix_runtime_initialize()
return;
- struct posix_runtime_file *file = NULL;
+ struct posix_file_runtime *file = NULL;
char *newname = NULL;
darshan_record_id file_id;
@@ -405,10 +749,10 @@ static struct posix_runtime_file* posix_file_by_name(const char *name)
return(file);
- struct posix_runtime_file_ref* ref;
+ struct posix_file_runtime_ref* ref;
if(!posix_runtime || instrumentation_disabled)
return(NULL);
@@ -445,9 +789,9 @@ static struct posix_runtime_file* posix_file_by_name_setfd(const char* name, int
return(file);
return(NULL);
@@ -462,7 +806,7 @@ static struct posix_runtime_file* posix_file_by_fd(int fd)
return;
@@ -512,7 +856,7 @@ static void posix_prepare_for_reduction(
void **recv_buf,
int *rec_size)
- struct posix_runtime_file *file;
+ struct posix_file_runtime *file;
struct darshan_posix_file *tmp_array;
int i;
@@ -578,19 +922,19 @@ static void posix_reduce_records(
tmp_file.f_id = infile->f_id;
tmp_file.rank = -1;
- tmp_file.counters[CP_POSIX_OPENS] = infile->counters[CP_POSIX_OPENS] +
- inoutfile->counters[CP_POSIX_OPENS];
+ tmp_file.counters[POSIX_OPENS] = infile->counters[POSIX_OPENS] +
+ inoutfile->counters[POSIX_OPENS];
- if((infile->fcounters[CP_F_OPEN_TIMESTAMP] > inoutfile->fcounters[CP_F_OPEN_TIMESTAMP]) &&
- (inoutfile->fcounters[CP_F_OPEN_TIMESTAMP] > 0))
- tmp_file.fcounters[CP_F_OPEN_TIMESTAMP] = inoutfile->fcounters[CP_F_OPEN_TIMESTAMP];
+ if((infile->fcounters[POSIX_F_OPEN_TIMESTAMP] > inoutfile->fcounters[POSIX_F_OPEN_TIMESTAMP]) &&
+ (inoutfile->fcounters[POSIX_F_OPEN_TIMESTAMP] > 0))
+ tmp_file.fcounters[POSIX_F_OPEN_TIMESTAMP] = inoutfile->fcounters[POSIX_F_OPEN_TIMESTAMP];
else
- tmp_file.fcounters[CP_F_OPEN_TIMESTAMP] = infile->fcounters[CP_F_OPEN_TIMESTAMP];
+ tmp_file.fcounters[POSIX_F_OPEN_TIMESTAMP] = infile->fcounters[POSIX_F_OPEN_TIMESTAMP];
- if(infile->fcounters[CP_F_CLOSE_TIMESTAMP] > inoutfile->fcounters[CP_F_CLOSE_TIMESTAMP])
- tmp_file.fcounters[CP_F_CLOSE_TIMESTAMP] = infile->fcounters[CP_F_CLOSE_TIMESTAMP];
+ if(infile->fcounters[POSIX_F_CLOSE_TIMESTAMP] > inoutfile->fcounters[POSIX_F_CLOSE_TIMESTAMP])
+ tmp_file.fcounters[POSIX_F_CLOSE_TIMESTAMP] = infile->fcounters[POSIX_F_CLOSE_TIMESTAMP];
else
- tmp_file.fcounters[CP_F_CLOSE_TIMESTAMP] = inoutfile->fcounters[CP_F_CLOSE_TIMESTAMP];
+ tmp_file.fcounters[POSIX_F_CLOSE_TIMESTAMP] = inoutfile->fcounters[POSIX_F_CLOSE_TIMESTAMP];
/* update pointers */
*inoutfile = tmp_file;
@@ -629,7 +973,7 @@ static void posix_get_output_data(
static void posix_shutdown()
- struct posix_runtime_file_ref *ref, *tmp;
+ struct posix_file_runtime_ref *ref, *tmp;
HASH_ITER(hlink, posix_runtime->fd_hash, ref, tmp)
diff --git a/darshan-util/darshan-posix-logutils.c b/darshan-util/darshan-posix-logutils.c
index 8e0107f..c312e4e 100644
--- a/darshan-util/darshan-posix-logutils.c
+++ b/darshan-util/darshan-posix-logutils.c
@@ -37,9 +37,9 @@ int darshan_log_get_posix_file(darshan_fd fd, struct darshan_posix_file *file)
/* swap bytes if necessary */
DARSHAN_BSWAP64(&file->f_id);
DARSHAN_BSWAP64(&file->rank);
- for(i=0; i<CP_NUM_INDICES; i++)
+ for(i=0; i<POSIX_NUM_INDICES; i++)
DARSHAN_BSWAP64(&file->counters[i]);
- for(i=0; i<CP_F_NUM_INDICES; i++)
+ for(i=0; i<POSIX_F_NUM_INDICES; i++)
DARSHAN_BSWAP64(&file->fcounters[i]);
diff --git a/darshan-util/darshan-posix-parser.c b/darshan-util/darshan-posix-parser.c
index cf829d1..29102a9 100644
--- a/darshan-util/darshan-posix-parser.c
+++ b/darshan-util/darshan-posix-parser.c
@@ -153,7 +153,7 @@ int main(int argc, char **argv)
if(ret == 0)
- printf("# no files opened.");
+ printf("# no files opened.\n");
darshan_log_close(fd);
return(0);
@@ -168,9 +168,45 @@ int main(int argc, char **argv)
printf("\tRecord %d: id=%"PRIu64" (path=%s, rank=%"PRId64")\n",
i, next_file.f_id, ref->rec.name, next_file.rank);
- printf("\t\tPOSIX_OPENS:\t%"PRIu64"\n\t\tF_OPEN_TIMESTAMP:\t%lf\n\t\tF_CLOSE_TIMESTAMP:\t%lf\n",
- next_file.counters[CP_POSIX_OPENS], next_file.fcounters[CP_F_OPEN_TIMESTAMP],
- next_file.fcounters[CP_F_CLOSE_TIMESTAMP]);
+ printf(
+ "\t\tPOSIX_OPENS:\t%"PRIu64"\n"
+ "\t\tPOSIX_READS:\t%"PRIu64"\n"
+ "\t\tPOSIX_WRITES:\t%"PRIu64"\n"
+ "\t\tPOSIX_FOPENS:\t%"PRIu64"\n"
+ "\t\tPOSIX_FREADS:\t%"PRIu64"\n"
+ "\t\tPOSIX_FWRITES:\t%"PRIu64"\n"
+ "\t\tPOSIX_MODE:\t%"PRIu64"\n"
+ "\t\tPOSIX_MAX_READ_TIME_SIZE:\t%"PRIu64"\n"
+ "\t\tPOSIX_MAX_WRITE_TIME_SIZE:\t%"PRIu64"\n"
+ "\t\tPOSIX_F_OPEN_TIMESTAMP:\t%lf\n"
+ "\t\tPOSIX_F_READ_START_TIMESTAMP:\t%lf\n"
+ "\t\tPOSIX_F_WRITE_START_TIMESTAMP:\t%lf\n"
+ "\t\tPOSIX_F_READ_END_TIMESTAMP:\t%lf\n"
+ "\t\tPOSIX_F_WRITE_END_TIMESTAMP:\t%lf\n"
+ "\t\tPOSIX_F_CLOSE_TIMESTAMP:\t%lf\n"
+ "\t\tPOSIX_F_READ_TIME:\t%lf\n"
+ "\t\tPOSIX_F_WRITE_TIME:\t%lf\n"
+ "\t\tPOSIX_F_MAX_READ_TIME:\t%lf\n"
+ "\t\tPOSIX_F_MAX_WRITE_TIME:\t%lf\n",
+ next_file.counters[POSIX_OPENS],
+ next_file.counters[POSIX_READS],
+ next_file.counters[POSIX_WRITES],
+ next_file.counters[POSIX_FOPENS],
+ next_file.counters[POSIX_FREADS],
+ next_file.counters[POSIX_FWRITES],
+ next_file.counters[POSIX_MODE],
+ next_file.counters[POSIX_MAX_READ_TIME_SIZE],
+ next_file.counters[POSIX_MAX_WRITE_TIME_SIZE],
+ next_file.fcounters[POSIX_F_OPEN_TIMESTAMP],
+ next_file.fcounters[POSIX_F_READ_START_TIMESTAMP],
+ next_file.fcounters[POSIX_F_WRITE_START_TIMESTAMP],
+ next_file.fcounters[POSIX_F_READ_END_TIMESTAMP],
+ next_file.fcounters[POSIX_F_WRITE_END_TIMESTAMP],
+ next_file.fcounters[POSIX_F_CLOSE_TIMESTAMP],
+ next_file.fcounters[POSIX_F_READ_TIME],
+ next_file.fcounters[POSIX_F_WRITE_TIME],
+ next_file.fcounters[POSIX_F_MAX_READ_TIME],
+ next_file.fcounters[POSIX_F_MAX_WRITE_TIME]);
i++;
} while((ret = darshan_log_get_posix_file(fd, &next_file)) == 1);
diff --git a/doc/darshan-modularization-design-notes.txt b/doc/darshan-modularization-design-notes.txt
index 4a6ace8..be6673e 100644
--- a/doc/darshan-modularization-design-notes.txt
+++ b/doc/darshan-modularization-design-notes.txt
@@ -110,16 +110,3 @@ API:
- strip down to basic example
- just do one or two posix counters to start, but exercise all of the
API and code organization stuff
-TODO NOTES:
- - why are darshan mutexes recursive?
- - how do we allow modules to specify there necessary linker/wrapper flags
- - configurable amount of max runtime memory
- - fs mount information -- should we export this info from darshan-core?
- - would the posix module be the only one to leverage this info?
- - it is used to correlate filenames with mount points, but not sure what is needed where
- - test fortran and c apps to make sure command line args are handled properly (see email with Phil 11/4)
- - when is DARSHAN_MPI_CALL macro needed? All MPI functions, or just those intercepted by darshan?
- - darshan link order causes issues when compiling mpi-io-test -- had to add extra -lmpi to resolve
- - is there more coordination between core and modules for shared file reductions?
- - do we change darshan file extension (.dz? .darshan?)
hooks/post-receive
More information about the Darshan-commits
