[Darshan-commits] [Darshan] branch, master, updated. darshan-2.3.1-pre2-16-g95c9e3c
Service Account git at mcs.anl.gov
Fri Mar 13 11:58:36 CDT 2015
This is an automated email from the git hooks/post-receive script. It was
generated because a ref change was pushed to the repository containing
the project "".
The branch, master has been updated
       via  95c9e3c47c2dd9398b07049fd8dd0c93d76544ce (commit)
      from  166d21ff45e1863c46305843495464760a0b3035 (commit)
Those revisions listed above that are new to this repository have
not appeared on any other notification email; so we list those
revisions in full, below.
- Log -----------------------------------------------------------------
commit 95c9e3c47c2dd9398b07049fd8dd0c93d76544ce
Author: Phil Carns <carns at mcs.anl.gov>
Date:   Fri Mar 13 12:58:07 2015 -0400
    update version numbers
Summary of changes:
 darshan-runtime/configure                   | 4240 ++++++++++-----------------
 darshan-runtime/configure.in                |    2 +-
 darshan-runtime/darshan-runtime-config.h.in |    3 +
 darshan-util/configure                      |   20 +-
 darshan-util/configure.in                   |    2 +-
 5 files changed, 1566 insertions(+), 2701 deletions(-)
Diff of changes:
diff --git a/darshan-runtime/configure b/darshan-runtime/configure
index c953800..e40f42d 100755
--- a/darshan-runtime/configure
+++ b/darshan-runtime/configure
@@ -1,18 +1,20 @@
 #! /bin/sh
 # Guess values for system-dependent variables and create Makefiles.
-# Generated by GNU Autoconf 2.63 for darshan-runtime 2.3.1-pre2.
+# Generated by GNU Autoconf 2.69 for darshan-runtime 2.3.1.
+# Copyright (C) 1992-1996, 1998-2012 Free Software Foundation, Inc.
-# Copyright (C) 1992, 1993, 1994, 1995, 1996, 1998, 1999, 2000, 2001,
-# 2002, 2003, 2004, 2005, 2006, 2007, 2008 Free Software Foundation, Inc.
 # This configure script is free software; the Free Software Foundation
 # gives unlimited permission to copy, distribute and modify it.
-## M4sh Initialization.  ##
+## M4sh Initialization. ##
 # Be more Bourne compatible
 DUALCASE=1; export DUALCASE # for MKS sh
-if test -n "${ZSH_VERSION+set}" && (emulate sh) >/dev/null 2>&1; then
+if test -n "${ZSH_VERSION+set}" && (emulate sh) >/dev/null 2>&1; then :
   emulate sh
   NULLCMD=:
   # Pre-4.2 versions of Zsh do word splitting on ${1+"$@"}, which
@@ -20,23 +22,15 @@ if test -n "${ZSH_VERSION+set}" && (emulate sh) >/dev/null 2>&1; then
   alias -g '${1+"$@"}'='"$@"'
   setopt NO_GLOB_SUBST
 else
-  case `(set -o) 2>/dev/null` in
-  *posix*) set -o posix ;;
+  case `(set -o) 2>/dev/null` in #(
+  *posix*) :
+    set -o posix ;; #(
 esac
 fi
-# PATH needs CR
-# Avoid depending upon Character Ranges.
-as_cr_letters='abcdefghijklmnopqrstuvwxyz'
-as_cr_LETTERS='ABCDEFGHIJKLMNOPQRSTUVWXYZ'
-as_cr_Letters=$as_cr_letters$as_cr_LETTERS
-as_cr_digits='0123456789'
-as_cr_alnum=$as_cr_Letters$as_cr_digits
 as_nl='
 export as_nl
@@ -44,7 +38,13 @@ export as_nl
 as_echo='\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\'
 as_echo=$as_echo$as_echo$as_echo$as_echo$as_echo
 as_echo=$as_echo$as_echo$as_echo$as_echo$as_echo$as_echo
-if (test "X`printf %s $as_echo`" = "X$as_echo") 2>/dev/null; then
+# Prefer a ksh shell builtin over an external printf program on Solaris,
+# but without wasting forks for bash or zsh.
+if test -z "$BASH_VERSION$ZSH_VERSION" \
+    && (test "X`print -r -- $as_echo`" = "X$as_echo") 2>/dev/null; then
+  as_echo='print -r --'
+  as_echo_n='print -rn --'
+elif (test "X`printf %s $as_echo`" = "X$as_echo") 2>/dev/null; then
   as_echo='printf %s\n'
   as_echo_n='printf %s'
 else
@@ -55,7 +55,7 @@ else
     as_echo_body='eval expr "X$1" : "X\\(.*\\)"'
     as_echo_n_body='eval
       arg=$1;
-      case $arg in
+      case $arg in #(
       *"$as_nl"*)
 	expr "X$arg" : "X\\(.*\\)$as_nl";
 	arg=`expr "X$arg" : ".*$as_nl\\(.*\\)"`;;
@@ -78,13 +78,6 @@ if test "${PATH_SEPARATOR+set}" != set; then
 fi
-# Support unset when possible.
-if ( (MAIL=60; unset MAIL) || exit) >/dev/null 2>&1; then
-  as_unset=unset
-else
-  as_unset=false
-fi
 # IFS
 # We need space, tab and new line, in precisely that order.  Quoting is
@@ -94,15 +87,16 @@ fi
 IFS=" ""	$as_nl"
 # Find who we are.  Look in the path if we contain no directory separator.
-case $0 in
+as_myself=
+case $0 in #((
   *[\\/]* ) as_myself=$0 ;;
   *) as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
 for as_dir in $PATH
 do
   IFS=$as_save_IFS
   test -z "$as_dir" && as_dir=.
-  test -r "$as_dir/$0" && as_myself=$as_dir/$0 && break
-done
+    test -r "$as_dir/$0" && as_myself=$as_dir/$0 && break
+  done
 IFS=$as_save_IFS
@@ -114,12 +108,16 @@ if test "x$as_myself" = x; then
 fi
 if test ! -f "$as_myself"; then
   $as_echo "$as_myself: error: cannot find myself; rerun with an absolute file name" >&2
-  { (exit 1); exit 1; }
+  exit 1
 fi
-# Work around bugs in pre-3.0 UWIN ksh.
-for as_var in ENV MAIL MAILPATH
-do ($as_unset $as_var) >/dev/null 2>&1 && $as_unset $as_var
+# Unset variables that we do not need and which cause bugs (e.g. in
+# pre-3.0 UWIN ksh).  But do not cause bugs in bash 2.01; the "|| exit 1"
+# suppresses any "Segmentation fault" message there.  '((' could
+# trigger a bug in pdksh 5.2.14.
+for as_var in BASH_ENV ENV MAIL MAILPATH
+do eval test x\${$as_var+set} = xset \
+  && ( (unset $as_var) || exit 1) >/dev/null 2>&1 && unset $as_var || :
 done
 PS1='$ '
 PS2='> '
@@ -131,330 +129,344 @@ export LC_ALL
 LANGUAGE=C
 export LANGUAGE
-# Required to use basename.
-if expr a : '\(a\)' >/dev/null 2>&1 &&
-   test "X`expr 00001 : '.*\(...\)'`" = X001; then
-  as_expr=expr
-else
-  as_expr=false
-fi
-if (basename -- /) >/dev/null 2>&1 && test "X`basename -- / 2>&1`" = "X/"; then
-  as_basename=basename
-else
-  as_basename=false
-fi
-# Name of the executable.
-as_me=`$as_basename -- "$0" ||
-$as_expr X/"$0" : '.*/\([^/][^/]*\)/*$' \| \
-	 X"$0" : 'X\(//\)$' \| \
-	 X"$0" : 'X\(/\)' \| . 2>/dev/null ||
-$as_echo X/"$0" |
-    sed '/^.*\/\([^/][^/]*\)\/*$/{
-	    s//\1/
-	    q
-	  /^X\/\(\/\/\)$/{
-	    s//\1/
-	    q
-	  /^X\/\(\/\).*/{
-	    s//\1/
-	    q
-	  s/.*/./; q'`
 # CDPATH.
-$as_unset CDPATH
+(unset CDPATH) >/dev/null 2>&1 && unset CDPATH
+# Use a proper internal environment variable to ensure we don't fall
+  # into an infinite loop, continuously re-executing ourselves.
+  if test x"${_as_can_reexec}" != xno && test "x$CONFIG_SHELL" != x; then
+    _as_can_reexec=no; export _as_can_reexec;
+    # We cannot yet assume a decent shell, so we have to provide a
+# neutralization value for shells without unset; and this also
+# works around shells that cannot unset nonexistent variables.
+# Preserve -v and -x to the replacement shell.
+BASH_ENV=/dev/null
+ENV=/dev/null
+(unset BASH_ENV) >/dev/null 2>&1 && unset BASH_ENV ENV
+case $- in # ((((
+  *v*x* | *x*v* ) as_opts=-vx ;;
+  *v* ) as_opts=-v ;;
+  *x* ) as_opts=-x ;;
+  * ) as_opts= ;;
+esac
+exec $CONFIG_SHELL $as_opts "$as_myself" ${1+"$@"}
+# Admittedly, this is quite paranoid, since all the known shells bail
+# out after a failed `exec'.
+$as_echo "$0: could not re-execute with $CONFIG_SHELL" >&2
+as_fn_exit 255
+  fi
+  # We don't want this to propagate to other subprocesses.
+          { _as_can_reexec=; unset _as_can_reexec;}
 if test "x$CONFIG_SHELL" = x; then
-  if (eval ":") 2>/dev/null; then
-  as_have_required=yes
+  as_bourne_compatible="if test -n \"\${ZSH_VERSION+set}\" && (emulate sh) >/dev/null 2>&1; then :
+  emulate sh
+  NULLCMD=:
+  # Pre-4.2 versions of Zsh do word splitting on \${1+\"\$@\"}, which
+  # is contrary to our usage.  Disable this feature.
+  alias -g '\${1+\"\$@\"}'='\"\$@\"'
+  setopt NO_GLOB_SUBST
 else
-  as_have_required=no
+  case \`(set -o) 2>/dev/null\` in #(
+  *posix*) :
+esac
 fi
-  if test $as_have_required = yes &&	 (eval ":
-(as_func_return () {
-  (exit \$1)
-as_func_success () {
-  as_func_return 0
-as_func_failure () {
-  as_func_return 1
-as_func_ret_success () {
-  return 0
-as_func_ret_failure () {
-  return 1
+  as_required="as_fn_return () { (exit \$1); }
+as_fn_success () { as_fn_return 0; }
+as_fn_failure () { as_fn_return 1; }
+as_fn_ret_success () { return 0; }
+as_fn_ret_failure () { return 1; }
 exitcode=0
-if as_func_success; then
-else
-  exitcode=1
-  echo as_func_success failed.
-fi
-if as_func_failure; then
-  exitcode=1
-  echo as_func_failure succeeded.
-fi
-if as_func_ret_success; then
-else
-  exitcode=1
-  echo as_func_ret_success failed.
-fi
-if as_func_ret_failure; then
-  exitcode=1
-  echo as_func_ret_failure succeeded.
-fi
-if ( set x; as_func_ret_success y && test x = \"\$1\" ); then
+as_fn_success || { exitcode=1; echo as_fn_success failed.; }
+as_fn_failure && { exitcode=1; echo as_fn_failure succeeded.; }
+as_fn_ret_success || { exitcode=1; echo as_fn_ret_success failed.; }
+as_fn_ret_failure && { exitcode=1; echo as_fn_ret_failure succeeded.; }
+if ( set x; as_fn_ret_success y && test x = \"\$1\" ); then :
+else
+  exitcode=1; echo positional parameters were not saved.
+fi
+test x\$exitcode = x0 || exit 1
+test -x / || exit 1"
+  as_suggested="  as_lineno_1=";as_suggested=$as_suggested$LINENO;as_suggested=$as_suggested" as_lineno_1a=\$LINENO
+  as_lineno_2=";as_suggested=$as_suggested$LINENO;as_suggested=$as_suggested" as_lineno_2a=\$LINENO
+  eval 'test \"x\$as_lineno_1'\$as_run'\" != \"x\$as_lineno_2'\$as_run'\" &&
+  test \"x\`expr \$as_lineno_1'\$as_run' + 1\`\" = \"x\$as_lineno_2'\$as_run'\"' || exit 1
+test \$(( 1 + 1 )) = 2 || exit 1"
+  if (eval "$as_required") 2>/dev/null; then :
+  as_have_required=yes
 else
-  exitcode=1
-  echo positional parameters were not saved.
+  as_have_required=no
 fi
+  if test x$as_have_required = xyes && (eval "$as_suggested") 2>/dev/null; then :
-test \$exitcode = 0) || { (exit 1); exit 1; }
-  as_lineno_1=\$LINENO
-  as_lineno_2=\$LINENO
-  test \"x\$as_lineno_1\" != \"x\$as_lineno_2\" &&
-  test \"x\`expr \$as_lineno_1 + 1\`\" = \"x\$as_lineno_2\") || { (exit 1); exit 1; }
-") 2> /dev/null; then
 else
-  as_candidate_shells=
-    as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
+  as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
+as_found=false
 for as_dir in /bin$PATH_SEPARATOR/usr/bin$PATH_SEPARATOR$PATH
 do
   IFS=$as_save_IFS
-  case $as_dir in
+  as_found=:
+  case $as_dir in #(
 	   for as_base in sh bash ksh sh5; do
-	     as_candidate_shells="$as_candidate_shells $as_dir/$as_base"
+	     # Try only shells that exist, to save several forks.
+	     as_shell=$as_dir/$as_base
+	     if { test -f "$as_shell" || test -f "$as_shell.exe"; } &&
+		    { $as_echo "$as_bourne_compatible""$as_required" | as_run=a "$as_shell"; } 2>/dev/null; then :
+  CONFIG_SHELL=$as_shell as_have_required=yes
+		   if { $as_echo "$as_bourne_compatible""$as_suggested" | as_run=a "$as_shell"; } 2>/dev/null; then :
+  break 2
+fi
+fi
 	   done;;
        esac
+  as_found=false
 done
+$as_found || { if { test -f "$SHELL" || test -f "$SHELL.exe"; } &&
+	      { $as_echo "$as_bourne_compatible""$as_required" | as_run=a "$SHELL"; } 2>/dev/null; then :
+  CONFIG_SHELL=$SHELL as_have_required=yes
+fi; }
 IFS=$as_save_IFS
-      for as_shell in $as_candidate_shells $SHELL; do
-	 # Try only shells that exist, to save several forks.
-	 if { test -f "$as_shell" || test -f "$as_shell.exe"; } &&
-		{ ("$as_shell") 2> /dev/null <<\_ASEOF
-  emulate sh
-  NULLCMD=:
-  # Pre-4.2 versions of Zsh do word splitting on ${1+"$@"}, which
-  # is contrary to our usage.  Disable this feature.
-  alias -g '${1+"$@"}'='"$@"'
-  setopt NO_GLOB_SUBST
-else
-esac
-fi
-_ASEOF
-}; then
-  CONFIG_SHELL=$as_shell
-	       if { "$as_shell" 2> /dev/null <<\_ASEOF
-  emulate sh
-  NULLCMD=:
-else
+      if test "x$CONFIG_SHELL" != x; then :
+  export CONFIG_SHELL
+BASH_ENV=/dev/null
+ENV=/dev/null
+case $- in # ((((
+  * ) as_opts= ;;
 esac
-fi
-  (exit $1)
-  as_func_return 0
-  as_func_return 1
-  return 0
-  return 1
-exitcode=0
-else
-  exitcode=1
-fi
-  exitcode=1
-fi
-else
-  exitcode=1
+exit 255
+fi
+    if test x$as_have_required = xno; then :
+  $as_echo "$0: This script requires a shell more modern than all"
+  $as_echo "$0: the shells that I found on your system."
+  if test x${ZSH_VERSION+set} = xset ; then
+    $as_echo "$0: In particular, zsh $ZSH_VERSION has bugs and should"
+    $as_echo "$0: be upgraded to zsh 4.3.4 or later."
+  else
+    $as_echo "$0: Please tell bug-autoconf at gnu.org about your system,
+$0: including any error possibly output before this
+$0: message. Then install a modern shell, or manually run
+$0: the script under such a shell if you do have one."
+  fi
+  exit 1
 fi
-  exitcode=1
 fi
-if ( set x; as_func_ret_success y && test x = "$1" ); then
-else
-  exitcode=1
 fi
+SHELL=${CONFIG_SHELL-/bin/sh}
+export SHELL
+# Unset more variables known to interfere with behavior of common tools.
+CLICOLOR_FORCE= GREP_OPTIONS=
+unset CLICOLOR_FORCE GREP_OPTIONS
-test $exitcode = 0) || { (exit 1); exit 1; }
-  as_lineno_1=$LINENO
-  as_lineno_2=$LINENO
-  test "x$as_lineno_1" != "x$as_lineno_2" &&
-  test "x`expr $as_lineno_1 + 1`" = "x$as_lineno_2") || { (exit 1); exit 1; }
-_ASEOF
-}; then
-  break
-fi
-fi
-      done
-      if test "x$CONFIG_SHELL" != x; then
-  for as_var in BASH_ENV ENV
-	do ($as_unset $as_var) >/dev/null 2>&1 && $as_unset $as_var
-	done
-	export CONFIG_SHELL
-	exec "$CONFIG_SHELL" "$as_myself" ${1+"$@"}
-fi
+## M4sh Shell Functions. ##
+# as_fn_unset VAR
+# Portably unset VAR.
+as_fn_unset ()
+  { eval $1=; unset $1;}
+as_unset=as_fn_unset
+# as_fn_set_status STATUS
+# Set $? to STATUS, without forking.
+as_fn_set_status ()
+  return $1
+} # as_fn_set_status
-    if test $as_have_required = no; then
-  echo This script requires a shell more modern than all the
-      echo shells that I found on your system.  Please install a
-      echo modern shell, or manually run the script under such a
-      echo shell if you do have one.
-fi
+# as_fn_exit STATUS
+# Exit the shell with STATUS, even in a "trap 0" or "set -e" context.
+as_fn_exit ()
+  set +e
+  as_fn_set_status $1
+  exit $1
+} # as_fn_exit
+# as_fn_mkdir_p
+# Create "$as_dir" as a directory, including parents if necessary.
+as_fn_mkdir_p ()
+  -*) as_dir=./$as_dir;;
+  esac
+  test -d "$as_dir" || eval $as_mkdir_p || {
+    as_dirs=
+    while :; do
+      *\'*) as_qdir=`$as_echo "$as_dir" | sed "s/'/'\\\\\\\\''/g"`;; #'(
+      *) as_qdir=$as_dir;;
+      esac
+      as_dirs="'$as_qdir' $as_dirs"
+      as_dir=`$as_dirname -- "$as_dir" ||
+$as_expr X"$as_dir" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \
+	 X"$as_dir" : 'X\(//\)[^/]' \| \
+	 X"$as_dir" : 'X\(//\)$' \| \
+	 X"$as_dir" : 'X\(/\)' \| . 2>/dev/null ||
+$as_echo X"$as_dir" |
+    sed '/^X\(.*[^/]\)\/\/*[^/][^/]*\/*$/{
+	    s//\1/
+	    q
+	  /^X\(\/\/\)[^/].*/{
+	    s//\1/
+	    q
+	  /^X\(\/\/\)$/{
+	    s//\1/
+	    q
+	  /^X\(\/\).*/{
+	    s//\1/
+	    q
+	  s/.*/./; q'`
+      test -d "$as_dir" && break
+    done
+    test -z "$as_dirs" || eval "mkdir $as_dirs"
+  } || test -d "$as_dir" || as_fn_error $? "cannot create directory $as_dir"
-fi
-fi
+} # as_fn_mkdir_p
+# as_fn_executable_p FILE
+# Test if FILE is an executable regular file.
+as_fn_executable_p ()
+  test -f "$1" && test -x "$1"
+} # as_fn_executable_p
+# as_fn_append VAR VALUE
+# Append the text in VALUE to the end of the definition contained in VAR. Take
+# advantage of any shell optimizations that allow amortized linear growth over
+# repeated appends, instead of the typical quadratic growth present in naive
+# implementations.
+if (eval "as_var=1; as_var+=2; test x\$as_var = x12") 2>/dev/null; then :
+  eval 'as_fn_append ()
+    eval $1+=\$2
+else
+  as_fn_append ()
+    eval $1=\$$1\$2
+fi # as_fn_append
+# as_fn_arith ARG...
+# Perform arithmetic evaluation on the ARGs, and store the result in the
+# global $as_val. Take advantage of shells that can avoid forks. The arguments
+# must be portable across $(()) and expr.
+if (eval "test \$(( 1 + 1 )) = 2") 2>/dev/null; then :
+  eval 'as_fn_arith ()
+    as_val=$(( $* ))
+else
+  as_fn_arith ()
+    as_val=`expr "$@" || test $? -eq 1`
+fi # as_fn_arith
-(eval "as_func_return () {
-  (exit \$1)
-  as_func_return 0
-  as_func_return 1
-  return 0
-  return 1
+# as_fn_error STATUS ERROR [LINENO LOG_FD]
+# Output "`basename $0`: error: ERROR" to stderr. If LINENO and LOG_FD are
+# provided, also output the error to LOG_FD, referencing LINENO. Then exit the
+# script with STATUS, using 1 if that was 0.
+as_fn_error ()
+  as_status=$1; test $as_status -eq 0 && as_status=1
+  if test "$4"; then
+    as_lineno=${as_lineno-"$3"} as_lineno_stack=as_lineno_stack=$as_lineno_stack
+    $as_echo "$as_me:${as_lineno-$LINENO}: error: $2" >&$4
+  fi
+  $as_echo "$as_me: error: $2" >&2
+  as_fn_exit $as_status
+} # as_fn_error
-exitcode=0
+if expr a : '\(a\)' >/dev/null 2>&1 &&
+   test "X`expr 00001 : '.*\(...\)'`" = X001; then
+  as_expr=expr
 else
-  exitcode=1
-fi
-  exitcode=1
+  as_expr=false
 fi
+if (basename -- /) >/dev/null 2>&1 && test "X`basename -- / 2>&1`" = "X/"; then
+  as_basename=basename
 else
-  exitcode=1
-fi
-  exitcode=1
+  as_basename=false
 fi
+if (as_dir=`dirname -- /` && test "X$as_dir" = X/) >/dev/null 2>&1; then
+  as_dirname=dirname
 else
-  exitcode=1
+  as_dirname=false
 fi
-test \$exitcode = 0") || {
-  echo No shell found that supports shell functions.
-  echo Please tell bug-autoconf at gnu.org about your system,
-  echo including any error possibly output before this message.
-  echo This can help us improve future autoconf versions.
-  echo Configuration will now proceed without shell functions.
+as_me=`$as_basename -- "$0" ||
+$as_expr X/"$0" : '.*/\([^/][^/]*\)/*$' \| \
+	 X"$0" : 'X\(//\)$' \| \
+	 X"$0" : 'X\(/\)' \| . 2>/dev/null ||
+$as_echo X/"$0" |
+    sed '/^.*\/\([^/][^/]*\)\/*$/{
+	    s//\1/
+	    q
+	  /^X\/\(\/\/\)$/{
+	    s//\1/
+	    q
+	  /^X\/\(\/\).*/{
+	    s//\1/
+	    q
+	  s/.*/./; q'`
+# Avoid depending upon Character Ranges.
+as_cr_letters='abcdefghijklmnopqrstuvwxyz'
+as_cr_LETTERS='ABCDEFGHIJKLMNOPQRSTUVWXYZ'
+as_cr_Letters=$as_cr_letters$as_cr_LETTERS
+as_cr_digits='0123456789'
+as_cr_alnum=$as_cr_Letters$as_cr_digits
-  test "x`expr $as_lineno_1 + 1`" = "x$as_lineno_2" || {
-  # Create $as_me.lineno as a copy of $as_myself, but with $LINENO
-  # uniformly replaced by the line number.  The first 'sed' inserts a
-  # line-number line after each line using $LINENO; the second 'sed'
-  # does the real work.  The second script uses 'N' to pair each
-  # line-number line with the line containing $LINENO, and appends
-  # trailing '-' during substitution so that $LINENO is not a special
-  # case at line end.
-  # (Raja R Harinath suggested sed '=', and Paul Eggert wrote the
-  # scripts with optimization help from Paolo Bonzini.  Blame Lee
-  # E. McMahon (1931-1989) for sed's syntax.  :-)
+  as_lineno_1=$LINENO as_lineno_1a=$LINENO
+  as_lineno_2=$LINENO as_lineno_2a=$LINENO
+  eval 'test "x$as_lineno_1'$as_run'" != "x$as_lineno_2'$as_run'" &&
+  test "x`expr $as_lineno_1'$as_run' + 1`" = "x$as_lineno_2'$as_run'"' || {
+  # Blame Lee E. McMahon (1931-1989) for sed's syntax.  :-)
   sed -n '
     p
     /[$]LINENO/=
@@ -471,9 +483,12 @@ test \$exitcode = 0") || {
       s/-\n.*//
     ' >$as_me.lineno &&
   chmod +x "$as_me.lineno" ||
-    { $as_echo "$as_me: error: cannot create $as_me.lineno; rerun with a POSIX shell" >&2
-   { (exit 1); exit 1; }; }
+    { $as_echo "$as_me: error: cannot create $as_me.lineno; rerun with a POSIX shell" >&2; as_fn_exit 1; }
+  # If we had to re-execute with $CONFIG_SHELL, we're ensured to have
+  # already done that, so ensure we don't try to do so again and fall
+  # in an infinite loop.  This has already happened in practice.
   # Don't try to exec as it changes $[0], causing all sort of problems
   # (the dirname of $[0] is not the place where we might find the
   # original and so on.  Autoconf is especially sensitive to this).
@@ -482,29 +497,18 @@ test \$exitcode = 0") || {
   exit
-if (as_dir=`dirname -- /` && test "X$as_dir" = X/) >/dev/null 2>&1; then
-  as_dirname=dirname
-else
-  as_dirname=false
-fi
 ECHO_C= ECHO_N= ECHO_T=
-case `echo -n x` in
+case `echo -n x` in #(((((
 -n*)
-  case `echo 'x\c'` in
+  case `echo 'xy\c'` in
   *c*) ECHO_T='	';;	# ECHO_T is single tab character.
-  *)   ECHO_C='\c';;
+  xy)  ECHO_C='\c';;
+  *)   echo `echo ksh88 bug on AIX 6.1` > /dev/null
+       ECHO_T='	';;
   esac;;
   ECHO_N='-n';;
 esac
-  as_expr=expr
-else
-  as_expr=false
-fi
 rm -f conf$$ conf$$.exe conf$$.file
 if test -d conf$$.dir; then
@@ -519,49 +523,29 @@ if (echo >conf$$.file) 2>/dev/null; then
     # ... but there are two gotchas:
     # 1) On MSYS, both `ln -s file dir' and `ln file dir' fail.
     # 2) DJGPP < 2.04 has no symlinks; `ln -s' creates a wrapper executable.
-    # In both cases, we have to default to `cp -p'.
+    # In both cases, we have to default to `cp -pR'.
     ln -s conf$$.file conf$$.dir 2>/dev/null && test ! -f conf$$.exe ||
-      as_ln_s='cp -p'
+      as_ln_s='cp -pR'
   elif ln conf$$.file conf$$ 2>/dev/null; then
     as_ln_s=ln
   else
-    as_ln_s='cp -p'
+    as_ln_s='cp -pR'
   fi
 else
-  as_ln_s='cp -p'
+  as_ln_s='cp -pR'
 fi
 rm -f conf$$ conf$$.exe conf$$.dir/conf$$.file conf$$.file
 rmdir conf$$.dir 2>/dev/null
 if mkdir -p . 2>/dev/null; then
-  as_mkdir_p=:
+  as_mkdir_p='mkdir -p "$as_dir"'
 else
   test -d ./-p && rmdir ./-p
   as_mkdir_p=false
 fi
-if test -x / >/dev/null 2>&1; then
-  as_test_x='test -x'
-else
-  if ls -dL / >/dev/null 2>&1; then
-    as_ls_L_option=L
-  else
-    as_ls_L_option=
-  fi
-  as_test_x='
-    eval sh -c '\''
-      if test -d "$1"; then
-	test -d "$1/.";
-      else
-	case $1 in
-	-*)set "./$1";;
-	esac;
-	case `ls -ld'$as_ls_L_option' "$1" 2>/dev/null` in
-	???[sx]*):;;*)false;;esac;fi
-    '\'' sh
-fi
-as_executable_p=$as_test_x
+as_test_x='test -x'
+as_executable_p=as_fn_executable_p
 # Sed expression to map a string onto a valid CPP name.
 as_tr_cpp="eval sed 'y%*$as_cr_letters%P$as_cr_LETTERS%;s%[^_$as_cr_alnum]%_%g'"
@@ -570,11 +554,11 @@ as_tr_cpp="eval sed 'y%*$as_cr_letters%P$as_cr_LETTERS%;s%[^_$as_cr_alnum]%_%g'"
 as_tr_sh="eval sed 'y%*+%pp%;s%[^_$as_cr_alnum]%_%g'"
-exec 7<&0 </dev/null 6>&1
+test -n "$DJDIR" || exec 7<&0 </dev/null
+exec 6>&1
 # Name of the host.
-# hostname on some systems (SVR3.2, Linux) returns a bogus exit status,
+# hostname on some systems (SVR3.2, old GNU/Linux) returns a bogus exit status,
 # so uname gets run too.
 ac_hostname=`(hostname || uname -n) 2>/dev/null | sed 1q`
@@ -589,14 +573,14 @@ cross_compiling=no
 subdirs=
 MFLAGS=
 MAKEFLAGS=
-SHELL=${CONFIG_SHELL-/bin/sh}
 # Identity of this package.
 PACKAGE_NAME='darshan-runtime'
 PACKAGE_TARNAME='darshan-runtime'
-PACKAGE_VERSION='2.3.1-pre2'
-PACKAGE_STRING='darshan-runtime 2.3.1-pre2'
+PACKAGE_VERSION='2.3.1'
+PACKAGE_STRING='darshan-runtime 2.3.1'
 PACKAGE_BUGREPORT=''
+PACKAGE_URL=''
 ac_unique_file="darshan.h"
 # Factoring default headers for most tests.
@@ -688,6 +672,7 @@ bindir
 program_transform_name
 prefix
 exec_prefix
+PACKAGE_URL
 PACKAGE_BUGREPORT
 PACKAGE_STRING
 PACKAGE_VERSION
@@ -781,8 +766,9 @@ do
   fi
   case $ac_option in
-  *=*)	ac_optarg=`expr "X$ac_option" : '[^=]*=\(.*\)'` ;;
-  *)	ac_optarg=yes ;;
+  *=?*) ac_optarg=`expr "X$ac_option" : '[^=]*=\(.*\)'` ;;
+  *=)   ac_optarg= ;;
+  *)    ac_optarg=yes ;;
   esac
   # Accept the important Cygnus configure options, so we can diagnose typos.
@@ -827,8 +813,7 @@ do
     ac_useropt=`expr "x$ac_option" : 'x-*disable-\(.*\)'`
     # Reject names that are not valid shell variable names.
     expr "x$ac_useropt" : ".*[^-+._$as_cr_alnum]" >/dev/null &&
-      { $as_echo "$as_me: error: invalid feature name: $ac_useropt" >&2
+      as_fn_error $? "invalid feature name: $ac_useropt"
     ac_useropt_orig=$ac_useropt
     ac_useropt=`$as_echo "$ac_useropt" | sed 's/[-+.]/_/g'`
     case $ac_user_opts in
@@ -854,8 +839,7 @@ do
     ac_useropt=`expr "x$ac_option" : 'x-*enable-\([^=]*\)'`
@@ -1059,8 +1043,7 @@ do
     ac_useropt=`expr "x$ac_option" : 'x-*with-\([^=]*\)'`
-      { $as_echo "$as_me: error: invalid package name: $ac_useropt" >&2
+      as_fn_error $? "invalid package name: $ac_useropt"
@@ -1076,8 +1059,7 @@ do
     ac_useropt=`expr "x$ac_option" : 'x-*without-\(.*\)'`
@@ -1107,17 +1089,17 @@ do
   | --x-librar=* | --x-libra=* | --x-libr=* | --x-lib=* | --x-li=* | --x-l=*)
     x_libraries=$ac_optarg ;;
-  -*) { $as_echo "$as_me: error: unrecognized option: $ac_option
-Try \`$0 --help' for more information." >&2
+  -*) as_fn_error $? "unrecognized option: \`$ac_option'
+Try \`$0 --help' for more information"
     ac_envvar=`expr "x$ac_option" : 'x\([^=]*\)='`
-    expr "x$ac_envvar" : ".*[^_$as_cr_alnum]" >/dev/null &&
-      { $as_echo "$as_me: error: invalid variable name: $ac_envvar" >&2
+    case $ac_envvar in #(
+      '' | [0-9]* | *[!_$as_cr_alnum]* )
+      as_fn_error $? "invalid variable name: \`$ac_envvar'" ;;
+    esac
     eval $ac_envvar=\$ac_optarg
     export $ac_envvar ;;
@@ -1126,7 +1108,7 @@ Try \`$0 --help' for more information." >&2
     $as_echo "$as_me: WARNING: you should use --build, --host, --target" >&2
     expr "x$ac_option" : ".*[^-._$as_cr_alnum]" >/dev/null &&
       $as_echo "$as_me: WARNING: invalid host type: $ac_option" >&2
-    : ${build_alias=$ac_option} ${host_alias=$ac_option} ${target_alias=$ac_option}
+    : "${build_alias=$ac_option} ${host_alias=$ac_option} ${target_alias=$ac_option}"
   esac
@@ -1134,15 +1116,13 @@ done
 if test -n "$ac_prev"; then
   ac_option=--`echo $ac_prev | sed 's/_/-/g'`
-  { $as_echo "$as_me: error: missing argument to $ac_option" >&2
+  as_fn_error $? "missing argument to $ac_option"
 fi
 if test -n "$ac_unrecognized_opts"; then
   case $enable_option_checking in
     no) ;;
-    fatal) { $as_echo "$as_me: error: unrecognized options: $ac_unrecognized_opts" >&2
-   { (exit 1); exit 1; }; } ;;
+    fatal) as_fn_error $? "unrecognized options: $ac_unrecognized_opts" ;;
     *)     $as_echo "$as_me: WARNING: unrecognized options: $ac_unrecognized_opts" >&2 ;;
   esac
 fi
@@ -1165,8 +1145,7 @@ do
     [\\/$]* | ?:[\\/]* )  continue;;
     NONE | '' ) case $ac_var in *prefix ) continue;; esac;;
   esac
-  { $as_echo "$as_me: error: expected an absolute directory name for --$ac_var: $ac_val" >&2
+  as_fn_error $? "expected an absolute directory name for --$ac_var: $ac_val"
 done
 # There might be people who depend on the old broken behavior: `$host'
@@ -1180,8 +1159,6 @@ target=$target_alias
 if test "x$host_alias" != x; then
   if test "x$build_alias" = x; then
     cross_compiling=maybe
-    $as_echo "$as_me: WARNING: If you wanted to set the --build type, don't use --host.
-    If a cross compiler is detected then cross compile mode will be used." >&2
   elif test "x$build_alias" != "x$host_alias"; then
     cross_compiling=yes
   fi
@@ -1196,11 +1173,9 @@ test "$silent" = yes && exec 6>/dev/null
 ac_pwd=`pwd` && test -n "$ac_pwd" &&
 ac_ls_di=`ls -di .` &&
 ac_pwd_ls_di=`cd "$ac_pwd" && ls -di .` ||
-  { $as_echo "$as_me: error: working directory cannot be determined" >&2
+  as_fn_error $? "working directory cannot be determined"
 test "X$ac_ls_di" = "X$ac_pwd_ls_di" ||
-  { $as_echo "$as_me: error: pwd does not report name of working directory" >&2
+  as_fn_error $? "pwd does not report name of working directory"
 # Find the source files, if location was not specified.
@@ -1239,13 +1214,11 @@ else
 fi
 if test ! -r "$srcdir/$ac_unique_file"; then
   test "$ac_srcdir_defaulted" = yes && srcdir="$ac_confdir or .."
-  { $as_echo "$as_me: error: cannot find sources ($ac_unique_file) in $srcdir" >&2
+  as_fn_error $? "cannot find sources ($ac_unique_file) in $srcdir"
 fi
 ac_msg="sources are in $srcdir, but \`cd $srcdir' does not work"
 ac_abs_confdir=`(
-	cd "$srcdir" && test -r "./$ac_unique_file" || { $as_echo "$as_me: error: $ac_msg" >&2
+	cd "$srcdir" && test -r "./$ac_unique_file" || as_fn_error $? "$ac_msg"
 	pwd)`
 # When building in place, set srcdir=.
 if test "$ac_abs_confdir" = "$ac_pwd"; then
@@ -1271,7 +1244,7 @@ if test "$ac_init_help" = "long"; then
   # Omit some internal or obsolete options to make the list less imposing.
   # This message is too long to be a string in the A/UX 3.1 sh.
   cat <<_ACEOF
-\`configure' configures darshan-runtime 2.3.1-pre2 to adapt to many kinds of systems.
+\`configure' configures darshan-runtime 2.3.1 to adapt to many kinds of systems.
 Usage: $0 [OPTION]... [VAR=VALUE]...
@@ -1285,7 +1258,7 @@ Configuration:
       --help=short        display options specific to this package
       --help=recursive    display the short help of all the included packages
   -V, --version           display version information and exit
-  -q, --quiet, --silent   do not print \`checking...' messages
+  -q, --quiet, --silent   do not print \`checking ...' messages
       --cache-file=FILE   cache test results in FILE [disabled]
   -C, --config-cache      alias for \`--cache-file=config.cache'
   -n, --no-create         do not create output files
@@ -1332,7 +1305,7 @@ fi
 if test -n "$ac_init_help"; then
   case $ac_init_help in
-     short | recursive ) echo "Configuration of darshan-runtime 2.3.1-pre2:";;
+     short | recursive ) echo "Configuration of darshan-runtime 2.3.1:";;
    esac
   cat <<\_ACEOF
@@ -1366,13 +1339,14 @@ Some influential environment variables:
   LDFLAGS     linker flags, e.g. -L<lib dir> if you have libraries in a
               nonstandard directory <lib dir>
   LIBS        libraries to pass to the linker, e.g. -l<library>
-  CPPFLAGS    C/C++/Objective C preprocessor flags, e.g. -I<include dir> if
+  CPPFLAGS    (Objective) C/C++ preprocessor flags, e.g. -I<include dir> if
               you have headers in a nonstandard directory <include dir>
   CPP         C preprocessor
 Use these variables to override the choices made by `configure' or to help
 it to find libraries and programs with nonstandard names/locations.
+Report bugs to the package provider.
 _ACEOF
 ac_status=$?
 fi
@@ -1435,22 +1409,360 @@ fi
 test -n "$ac_init_help" && exit $ac_status
 if $ac_init_version; then
   cat <<\_ACEOF
-darshan-runtime configure 2.3.1-pre2
-generated by GNU Autoconf 2.63
+darshan-runtime configure 2.3.1
+generated by GNU Autoconf 2.69
-Copyright (C) 1992, 1993, 1994, 1995, 1996, 1998, 1999, 2000, 2001,
-2002, 2003, 2004, 2005, 2006, 2007, 2008 Free Software Foundation, Inc.
+Copyright (C) 2012 Free Software Foundation, Inc.
 _ACEOF
   exit
 fi
+## Autoconf initialization. ##
+# ac_fn_c_try_compile LINENO
+# Try to compile conftest.$ac_ext, and return whether this succeeded.
+ac_fn_c_try_compile ()
+  as_lineno=${as_lineno-"$1"} as_lineno_stack=as_lineno_stack=$as_lineno_stack
+  rm -f conftest.$ac_objext
+  if { { ac_try="$ac_compile"
+case "(($ac_try" in
+  *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;;
+  *) ac_try_echo=$ac_try;;
+esac
+eval ac_try_echo="\"\$as_me:${as_lineno-$LINENO}: $ac_try_echo\""
+$as_echo "$ac_try_echo"; } >&5
+  (eval "$ac_compile") 2>conftest.err
+  ac_status=$?
+  if test -s conftest.err; then
+    grep -v '^ *+' conftest.err >conftest.er1
+    cat conftest.er1 >&5
+    mv -f conftest.er1 conftest.err
+  fi
+  $as_echo "$as_me:${as_lineno-$LINENO}: \$? = $ac_status" >&5
+  test $ac_status = 0; } && {
+	 test -z "$ac_c_werror_flag" ||
+	 test ! -s conftest.err
+       } && test -s conftest.$ac_objext; then :
+  ac_retval=0
+else
+  $as_echo "$as_me: failed program was:" >&5
+sed 's/^/| /' conftest.$ac_ext >&5
+	ac_retval=1
+fi
+  eval $as_lineno_stack; ${as_lineno_stack:+:} unset as_lineno
+  as_fn_set_status $ac_retval
+} # ac_fn_c_try_compile
+# ac_fn_c_try_cpp LINENO
+# Try to preprocess conftest.$ac_ext, and return whether this succeeded.
+ac_fn_c_try_cpp ()
+  if { { ac_try="$ac_cpp conftest.$ac_ext"
+esac
+  (eval "$ac_cpp conftest.$ac_ext") 2>conftest.err
+  ac_status=$?
+  fi
+  test $ac_status = 0; } > conftest.i && {
+	 test -z "$ac_c_preproc_warn_flag$ac_c_werror_flag" ||
+       }; then :
+  ac_retval=0
+else
+    ac_retval=1
+fi
+} # ac_fn_c_try_cpp
+# ac_fn_c_check_header_mongrel LINENO HEADER VAR INCLUDES
+# Tests whether HEADER exists, giving a warning if it cannot be compiled using
+# the include files in INCLUDES and setting the cache variable VAR
+# accordingly.
+ac_fn_c_check_header_mongrel ()
+  if eval \${$3+:} false; then :
+  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for $2" >&5
+$as_echo_n "checking for $2... " >&6; }
+if eval \${$3+:} false; then :
+  $as_echo_n "(cached) " >&6
+fi
+eval ac_res=\$$3
+	       { $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_res" >&5
+$as_echo "$ac_res" >&6; }
+else
+  # Is the header compilable?
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking $2 usability" >&5
+$as_echo_n "checking $2 usability... " >&6; }
+cat confdefs.h - <<_ACEOF >conftest.$ac_ext
+/* end confdefs.h.  */
+$4
+#include <$2>
+_ACEOF
+if ac_fn_c_try_compile "$LINENO"; then :
+  ac_header_compiler=yes
+else
+  ac_header_compiler=no
+fi
+rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_header_compiler" >&5
+$as_echo "$ac_header_compiler" >&6; }
+# Is the header present?
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking $2 presence" >&5
+$as_echo_n "checking $2 presence... " >&6; }
+#include <$2>
+_ACEOF
+if ac_fn_c_try_cpp "$LINENO"; then :
+  ac_header_preproc=yes
+else
+  ac_header_preproc=no
+fi
+rm -f conftest.err conftest.i conftest.$ac_ext
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_header_preproc" >&5
+$as_echo "$ac_header_preproc" >&6; }
+# So?  What about this header?
+case $ac_header_compiler:$ac_header_preproc:$ac_c_preproc_warn_flag in #((
+  yes:no: )
+    { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: $2: accepted by the compiler, rejected by the preprocessor!" >&5
+$as_echo "$as_me: WARNING: $2: accepted by the compiler, rejected by the preprocessor!" >&2;}
+    { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: $2: proceeding with the compiler's result" >&5
+$as_echo "$as_me: WARNING: $2: proceeding with the compiler's result" >&2;}
+  no:yes:* )
+    { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: $2: present but cannot be compiled" >&5
+$as_echo "$as_me: WARNING: $2: present but cannot be compiled" >&2;}
+    { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: $2:     check for missing prerequisite headers?" >&5
+$as_echo "$as_me: WARNING: $2:     check for missing prerequisite headers?" >&2;}
+    { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: $2: see the Autoconf documentation" >&5
+$as_echo "$as_me: WARNING: $2: see the Autoconf documentation" >&2;}
+    { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: $2:     section \"Present But Cannot Be Compiled\"" >&5
+$as_echo "$as_me: WARNING: $2:     section \"Present But Cannot Be Compiled\"" >&2;}
+esac
+else
+  eval "$3=\$ac_header_compiler"
+fi
+eval ac_res=\$$3
+fi
+} # ac_fn_c_check_header_mongrel
+# ac_fn_c_try_run LINENO
+# Try to link conftest.$ac_ext, and return whether this succeeded. Assumes
+# that executables *can* be run.
+ac_fn_c_try_run ()
+  if { { ac_try="$ac_link"
+esac
+  (eval "$ac_link") 2>&5
+  ac_status=$?
+  test $ac_status = 0; } && { ac_try='./conftest$ac_exeext'
+  { { case "(($ac_try" in
+esac
+  (eval "$ac_try") 2>&5
+  ac_status=$?
+  test $ac_status = 0; }; }; then :
+  ac_retval=0
+else
+  $as_echo "$as_me: program exited with status $ac_status" >&5
+       ac_retval=$ac_status
+fi
+  rm -rf conftest.dSYM conftest_ipa8_conftest.oo
+} # ac_fn_c_try_run
+# ac_fn_c_check_header_compile LINENO HEADER VAR INCLUDES
+# Tests whether HEADER exists and can be compiled using the include files in
+# INCLUDES, setting the cache variable VAR accordingly.
+ac_fn_c_check_header_compile ()
+else
+  cat confdefs.h - <<_ACEOF >conftest.$ac_ext
+$4
+#include <$2>
+_ACEOF
+  eval "$3=yes"
+else
+  eval "$3=no"
+fi
+fi
+eval ac_res=\$$3
+} # ac_fn_c_check_header_compile
+# ac_fn_c_try_link LINENO
+ac_fn_c_try_link ()
+  rm -f conftest.$ac_objext conftest$ac_exeext
+esac
+  (eval "$ac_link") 2>conftest.err
+  ac_status=$?
+  fi
+       } && test -s conftest$ac_exeext && {
+	 test "$cross_compiling" = yes ||
+	 test -x conftest$ac_exeext
+       }; then :
+  ac_retval=0
+else
+	ac_retval=1
+fi
+  # Delete the IPA/IPO (Inter Procedural Analysis/Optimization) information
+  # created by the PGI compiler (conftest_ipa8_conftest.oo), as it would
+  # interfere with the next link command; also delete a directory that is
+  # left behind by Apple's compiler.  We do this before executing the actions.
+} # ac_fn_c_try_link
+# ac_fn_c_check_type LINENO TYPE VAR INCLUDES
+# Tests whether TYPE exists after having included INCLUDES, setting cache
+# variable VAR accordingly.
+ac_fn_c_check_type ()
+else
+  eval "$3=no"
+$4
+int
+main ()
+if (sizeof ($2))
+	 return 0;
+  return 0;
+_ACEOF
+$4
+int
+main ()
+if (sizeof (($2)))
+	    return 0;
+  return 0;
+_ACEOF
+else
+  eval "$3=yes"
+fi
+fi
+fi
+eval ac_res=\$$3
+} # ac_fn_c_check_type
 cat >config.log <<_ACEOF
 This file contains any messages produced by compilers while
 running configure, to aid debugging if configure makes a mistake.
-It was created by darshan-runtime $as_me 2.3.1-pre2, which was
-generated by GNU Autoconf 2.63.  Invocation command line was
+It was created by darshan-runtime $as_me 2.3.1, which was
+generated by GNU Autoconf 2.69.  Invocation command line was
   $ $0 $@
@@ -1486,8 +1798,8 @@ for as_dir in $PATH
 do
   IFS=$as_save_IFS
-  $as_echo "PATH: $as_dir"
-done
+    $as_echo "PATH: $as_dir"
+  done
 IFS=$as_save_IFS
 } >&5
@@ -1524,9 +1836,9 @@ do
       ac_arg=`$as_echo "$ac_arg" | sed "s/'/'\\\\\\\\''/g"` ;;
     esac
     case $ac_pass in
-    1) ac_configure_args0="$ac_configure_args0 '$ac_arg'" ;;
+    1) as_fn_append ac_configure_args0 " '$ac_arg'" ;;
     2)
-      ac_configure_args1="$ac_configure_args1 '$ac_arg'"
+      as_fn_append ac_configure_args1 " '$ac_arg'"
       if test $ac_must_keep_next = true; then
 	ac_must_keep_next=false # Got value, back to normal.
       else
@@ -1542,13 +1854,13 @@ do
 	  -* ) ac_must_keep_next=true ;;
 	esac
       fi
-      ac_configure_args="$ac_configure_args '$ac_arg'"
+      as_fn_append ac_configure_args " '$ac_arg'"
     esac
   done
 done
-$as_unset ac_configure_args0 || test "${ac_configure_args0+set}" != set || { ac_configure_args0=; export ac_configure_args0; }
-$as_unset ac_configure_args1 || test "${ac_configure_args1+set}" != set || { ac_configure_args1=; export ac_configure_args1; }
+{ ac_configure_args0=; unset ac_configure_args0;}
+{ ac_configure_args1=; unset ac_configure_args1;}
 # When interrupted or exit'd, cleanup temporary files, and complete
 # config.log.  We remove comments because anyway the quotes in there
@@ -1560,11 +1872,9 @@ trap 'exit_status=$?
     echo
-    cat <<\_ASBOX
+    $as_echo "## ---------------- ##
 ## Cache variables. ##
-_ASBOX
     echo
     # The following way of writing the cache mishandles newlines in values,
@@ -1573,13 +1883,13 @@ _ASBOX
     case $ac_val in #(
     *${as_nl}*)
       case $ac_var in #(
-      *_cv_*) { $as_echo "$as_me:$LINENO: WARNING: cache variable $ac_var contains a newline" >&5
+      *_cv_*) { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: cache variable $ac_var contains a newline" >&5
 $as_echo "$as_me: WARNING: cache variable $ac_var contains a newline" >&2;} ;;
       esac
       case $ac_var in #(
       _ | IFS | as_nl) ;; #(
       BASH_ARGV | BASH_SOURCE) eval $ac_var= ;; #(
-      *) $as_unset $ac_var ;;
+      *) { eval $ac_var=; unset $ac_var;} ;;
       esac ;;
     esac
   done
@@ -1598,11 +1908,9 @@ $as_echo "$as_me: WARNING: cache variable $ac_var contains a newline" >&2;} ;;
     echo
-    cat <<\_ASBOX
+    $as_echo "## ----------------- ##
 ## Output variables. ##
-_ASBOX
     echo
     for ac_var in $ac_subst_vars
     do
@@ -1615,11 +1923,9 @@ _ASBOX
     echo
     if test -n "$ac_subst_files"; then
-      cat <<\_ASBOX
+      $as_echo "## ------------------- ##
 ## File substitutions. ##
-_ASBOX
       echo
       for ac_var in $ac_subst_files
       do
@@ -1633,11 +1939,9 @@ _ASBOX
     fi
     if test -s confdefs.h; then
-      cat <<\_ASBOX
+      $as_echo "## ----------- ##
 ## confdefs.h. ##
-_ASBOX
       echo
       cat confdefs.h
       echo
@@ -1651,46 +1955,53 @@ _ASBOX
     exit $exit_status
 ' 0
 for ac_signal in 1 2 13 15; do
-  trap 'ac_signal='$ac_signal'; { (exit 1); exit 1; }' $ac_signal
+  trap 'ac_signal='$ac_signal'; as_fn_exit 1' $ac_signal
 done
 ac_signal=0
 # confdefs.h avoids OS command line length limits that DEFS can exceed.
 rm -f -r conftest* confdefs.h
+$as_echo "/* confdefs.h */" > confdefs.h
 # Predefined preprocessor variables.
 cat >>confdefs.h <<_ACEOF
 #define PACKAGE_NAME "$PACKAGE_NAME"
 _ACEOF
 #define PACKAGE_TARNAME "$PACKAGE_TARNAME"
 _ACEOF
 #define PACKAGE_VERSION "$PACKAGE_VERSION"
 _ACEOF
 #define PACKAGE_STRING "$PACKAGE_STRING"
 _ACEOF
 #define PACKAGE_BUGREPORT "$PACKAGE_BUGREPORT"
 _ACEOF
+cat >>confdefs.h <<_ACEOF
+#define PACKAGE_URL "$PACKAGE_URL"
+_ACEOF
 # Let the site file select an alternate cache file if it wants to.
 # Prefer an explicitly selected file to automatically selected ones.
 ac_site_file1=NONE
 ac_site_file2=NONE
 if test -n "$CONFIG_SITE"; then
-  ac_site_file1=$CONFIG_SITE
+  # We do not want a PATH search for config.site.
+  case $CONFIG_SITE in #((
+    -*)  ac_site_file1=./$CONFIG_SITE;;
+    */*) ac_site_file1=$CONFIG_SITE;;
+    *)   ac_site_file1=./$CONFIG_SITE;;
+  esac
 elif test "x$prefix" != xNONE; then
   ac_site_file1=$prefix/share/config.site
   ac_site_file2=$prefix/etc/config.site
@@ -1701,19 +2012,23 @@ fi
 for ac_site_file in "$ac_site_file1" "$ac_site_file2"
 do
   test "x$ac_site_file" = xNONE && continue
-  if test -r "$ac_site_file"; then
-    { $as_echo "$as_me:$LINENO: loading site script $ac_site_file" >&5
+  if test /dev/null != "$ac_site_file" && test -r "$ac_site_file"; then
+    { $as_echo "$as_me:${as_lineno-$LINENO}: loading site script $ac_site_file" >&5
 $as_echo "$as_me: loading site script $ac_site_file" >&6;}
     sed 's/^/| /' "$ac_site_file" >&5
-    . "$ac_site_file"
+    . "$ac_site_file" \
+      || { { $as_echo "$as_me:${as_lineno-$LINENO}: error: in \`$ac_pwd':" >&5
+$as_echo "$as_me: error: in \`$ac_pwd':" >&2;}
+as_fn_error $? "failed to load site script $ac_site_file
+See \`config.log' for more details" "$LINENO" 5; }
   fi
 done
 if test -r "$cache_file"; then
-  # Some versions of bash will fail to source /dev/null (special
-  # files actually), so we avoid doing that.
-  if test -f "$cache_file"; then
-    { $as_echo "$as_me:$LINENO: loading cache $cache_file" >&5
+  # Some versions of bash will fail to source /dev/null (special files
+  # actually), so we avoid doing that.  DJGPP emulates it as a regular file.
+  if test /dev/null != "$cache_file" && test -f "$cache_file"; then
+    { $as_echo "$as_me:${as_lineno-$LINENO}: loading cache $cache_file" >&5
 $as_echo "$as_me: loading cache $cache_file" >&6;}
     case $cache_file in
       [\\/]* | ?:[\\/]* ) . "$cache_file";;
@@ -1721,7 +2036,7 @@ $as_echo "$as_me: loading cache $cache_file" >&6;}
     esac
   fi
 else
-  { $as_echo "$as_me:$LINENO: creating cache $cache_file" >&5
+  { $as_echo "$as_me:${as_lineno-$LINENO}: creating cache $cache_file" >&5
 $as_echo "$as_me: creating cache $cache_file" >&6;}
   >$cache_file
 fi
@@ -1736,11 +2051,11 @@ for ac_var in $ac_precious_vars; do
   eval ac_new_val=\$ac_env_${ac_var}_value
   case $ac_old_set,$ac_new_set in
     set,)
-      { $as_echo "$as_me:$LINENO: error: \`$ac_var' was set to \`$ac_old_val' in the previous run" >&5
+      { $as_echo "$as_me:${as_lineno-$LINENO}: error: \`$ac_var' was set to \`$ac_old_val' in the previous run" >&5
 $as_echo "$as_me: error: \`$ac_var' was set to \`$ac_old_val' in the previous run" >&2;}
       ac_cache_corrupted=: ;;
     ,set)
-      { $as_echo "$as_me:$LINENO: error: \`$ac_var' was not set in the previous run" >&5
+      { $as_echo "$as_me:${as_lineno-$LINENO}: error: \`$ac_var' was not set in the previous run" >&5
 $as_echo "$as_me: error: \`$ac_var' was not set in the previous run" >&2;}
@@ -1750,17 +2065,17 @@ $as_echo "$as_me: error: \`$ac_var' was not set in the previous run" >&2;}
 	ac_old_val_w=`echo x $ac_old_val`
 	ac_new_val_w=`echo x $ac_new_val`
 	if test "$ac_old_val_w" != "$ac_new_val_w"; then
-	  { $as_echo "$as_me:$LINENO: error: \`$ac_var' has changed since the previous run:" >&5
+	  { $as_echo "$as_me:${as_lineno-$LINENO}: error: \`$ac_var' has changed since the previous run:" >&5
 $as_echo "$as_me: error: \`$ac_var' has changed since the previous run:" >&2;}
 	else
-	  { $as_echo "$as_me:$LINENO: warning: ignoring whitespace changes in \`$ac_var' since the previous run:" >&5
+	  { $as_echo "$as_me:${as_lineno-$LINENO}: warning: ignoring whitespace changes in \`$ac_var' since the previous run:" >&5
 $as_echo "$as_me: warning: ignoring whitespace changes in \`$ac_var' since the previous run:" >&2;}
 	  eval $ac_var=\$ac_old_val
 	fi
-	{ $as_echo "$as_me:$LINENO:   former value:  \`$ac_old_val'" >&5
+	{ $as_echo "$as_me:${as_lineno-$LINENO}:   former value:  \`$ac_old_val'" >&5
 $as_echo "$as_me:   former value:  \`$ac_old_val'" >&2;}
-	{ $as_echo "$as_me:$LINENO:   current value: \`$ac_new_val'" >&5
+	{ $as_echo "$as_me:${as_lineno-$LINENO}:   current value: \`$ac_new_val'" >&5
 $as_echo "$as_me:   current value: \`$ac_new_val'" >&2;}
       fi;;
   esac
@@ -1772,43 +2087,20 @@ $as_echo "$as_me:   current value: \`$ac_new_val'" >&2;}
     esac
     case " $ac_configure_args " in
       *" '$ac_arg' "*) ;; # Avoid dups.  Use of quotes ensures accuracy.
-      *) ac_configure_args="$ac_configure_args '$ac_arg'" ;;
+      *) as_fn_append ac_configure_args " '$ac_arg'" ;;
     esac
   fi
 done
 if $ac_cache_corrupted; then
-  { $as_echo "$as_me:$LINENO: error: in \`$ac_pwd':" >&5
+  { $as_echo "$as_me:${as_lineno-$LINENO}: error: in \`$ac_pwd':" >&5
-  { $as_echo "$as_me:$LINENO: error: changes in the environment can compromise the build" >&5
+  { $as_echo "$as_me:${as_lineno-$LINENO}: error: changes in the environment can compromise the build" >&5
 $as_echo "$as_me: error: changes in the environment can compromise the build" >&2;}
-  { { $as_echo "$as_me:$LINENO: error: run \`make distclean' and/or \`rm $cache_file' and start over" >&5
-$as_echo "$as_me: error: run \`make distclean' and/or \`rm $cache_file' and start over" >&2;}
+  as_fn_error $? "run \`make distclean' and/or \`rm $cache_file' and start over" "$LINENO" 5
 fi
+## Main body of script. ##
 ac_ext=c
 ac_cpp='$CPP $CPPFLAGS'
@@ -1835,9 +2127,7 @@ for ac_dir in ../maint/config "$srcdir"/../maint/config; do
   fi
 done
 if test -z "$ac_aux_dir"; then
-  { { $as_echo "$as_me:$LINENO: error: cannot find install-sh or install.sh in ../maint/config \"$srcdir\"/../maint/config" >&5
-$as_echo "$as_me: error: cannot find install-sh or install.sh in ../maint/config \"$srcdir\"/../maint/config" >&2;}
+  as_fn_error $? "cannot find install-sh, install.sh, or shtool in ../maint/config \"$srcdir\"/../maint/config" "$LINENO" 5
 fi
 # These three variables are undocumented and unsupported,
@@ -1866,10 +2156,10 @@ ac_config_headers="$ac_config_headers darshan-runtime-config.h"
 # OS/2's system install, which has a completely different semantic
 # ./install, which can be erroneously created by make from ./install.sh.
 # Reject install programs that cannot install multiple files.
-{ $as_echo "$as_me:$LINENO: checking for a BSD-compatible install" >&5
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for a BSD-compatible install" >&5
 $as_echo_n "checking for a BSD-compatible install... " >&6; }
 if test -z "$INSTALL"; then
-if test "${ac_cv_path_install+set}" = set; then
+if ${ac_cv_path_install+:} false; then :
 else
@@ -1877,11 +2167,11 @@ for as_dir in $PATH
 do
   IFS=$as_save_IFS
-  # Account for people who put trailing slashes in PATH elements.
-case $as_dir/ in
-  ./ | .// | /cC/* | \
+    # Account for people who put trailing slashes in PATH elements.
+case $as_dir/ in #((
+  ./ | .// | /[cC]/* | \
   /etc/* | /usr/sbin/* | /usr/etc/* | /sbin/* | /usr/afsws/bin/* | \
-  ?:\\/os2\\/install\\/* | ?:\\/OS2\\/INSTALL\\/* | \
+  ?:[\\/]os2[\\/]install[\\/]* | ?:[\\/]OS2[\\/]INSTALL[\\/]* | \
   /usr/ucb/* ) ;;
     # OSF1 and SCO ODT 3.0 have their own names for install.
@@ -1889,7 +2179,7 @@ case $as_dir/ in
     # by default.
     for ac_prog in ginstall scoinst install; do
       for ac_exec_ext in '' $ac_executable_extensions; do
-	if { test -f "$as_dir/$ac_prog$ac_exec_ext" && $as_test_x "$as_dir/$ac_prog$ac_exec_ext"; }; then
+	if as_fn_executable_p "$as_dir/$ac_prog$ac_exec_ext"; then
 	  if test $ac_prog = install &&
 	    grep dspmsg "$as_dir/$ac_prog$ac_exec_ext" >/dev/null 2>&1; then
 	    # AIX install.  It has an incompatible calling convention.
@@ -1918,7 +2208,7 @@ case $as_dir/ in
 esac
-done
+  done
 IFS=$as_save_IFS
 rm -rf conftest.one conftest.two conftest.dir
@@ -1934,7 +2224,7 @@ fi
     INSTALL=$ac_install_sh
   fi
 fi
-{ $as_echo "$as_me:$LINENO: result: $INSTALL" >&5
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $INSTALL" >&5
 $as_echo "$INSTALL" >&6; }
 # Use test -z because SunOS4 sh mishandles braces in ${var-val}.
@@ -1946,7 +2236,7 @@ test -z "$INSTALL_SCRIPT" && INSTALL_SCRIPT='${INSTALL}'
 test -z "$INSTALL_DATA" && INSTALL_DATA='${INSTALL} -m 644'
-{ $as_echo "$as_me:$LINENO: checking whether the mpicc compiler works" >&5
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether the mpicc compiler works" >&5
 $as_echo_n "checking whether the mpicc compiler works... " >&6; }
 ac_ext=c
@@ -1956,9 +2246,9 @@ ac_compiler_gnu=$ac_cv_c_compiler_gnu
 if test -n "$ac_tool_prefix"; then
   # Extract the first word of "${ac_tool_prefix}gcc", so it can be a program name with args.
 set dummy ${ac_tool_prefix}gcc; ac_word=$2
-{ $as_echo "$as_me:$LINENO: checking for $ac_word" >&5
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for $ac_word" >&5
 $as_echo_n "checking for $ac_word... " >&6; }
-if test "${ac_cv_prog_CC+set}" = set; then
+if ${ac_cv_prog_CC+:} false; then :
 else
   if test -n "$CC"; then
@@ -1969,24 +2259,24 @@ for as_dir in $PATH
 do
   IFS=$as_save_IFS
-  for ac_exec_ext in '' $ac_executable_extensions; do
-  if { test -f "$as_dir/$ac_word$ac_exec_ext" && $as_test_x "$as_dir/$ac_word$ac_exec_ext"; }; then
+    for ac_exec_ext in '' $ac_executable_extensions; do
+  if as_fn_executable_p "$as_dir/$ac_word$ac_exec_ext"; then
     ac_cv_prog_CC="${ac_tool_prefix}gcc"
-    $as_echo "$as_me:$LINENO: found $as_dir/$ac_word$ac_exec_ext" >&5
+    $as_echo "$as_me:${as_lineno-$LINENO}: found $as_dir/$ac_word$ac_exec_ext" >&5
     break 2
   fi
 done
-done
+  done
 IFS=$as_save_IFS
 fi
 fi
 CC=$ac_cv_prog_CC
-  { $as_echo "$as_me:$LINENO: result: $CC" >&5
+  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $CC" >&5
 $as_echo "$CC" >&6; }
 else
-  { $as_echo "$as_me:$LINENO: result: no" >&5
+  { $as_echo "$as_me:${as_lineno-$LINENO}: result: no" >&5
 $as_echo "no" >&6; }
 fi
@@ -1996,9 +2286,9 @@ if test -z "$ac_cv_prog_CC"; then
   ac_ct_CC=$CC
   # Extract the first word of "gcc", so it can be a program name with args.
 set dummy gcc; ac_word=$2
-if test "${ac_cv_prog_ac_ct_CC+set}" = set; then
+if ${ac_cv_prog_ac_ct_CC+:} false; then :
 else
   if test -n "$ac_ct_CC"; then
@@ -2009,24 +2299,24 @@ for as_dir in $PATH
 do
   IFS=$as_save_IFS
     ac_cv_prog_ac_ct_CC="gcc"
     break 2
   fi
 done
-done
+  done
 IFS=$as_save_IFS
 fi
 fi
 ac_ct_CC=$ac_cv_prog_ac_ct_CC
-  { $as_echo "$as_me:$LINENO: result: $ac_ct_CC" >&5
+  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_ct_CC" >&5
 $as_echo "$ac_ct_CC" >&6; }
 else
 fi
@@ -2035,7 +2325,7 @@ fi
   else
     case $cross_compiling:$ac_tool_warned in
 yes:)
-{ $as_echo "$as_me:$LINENO: WARNING: using cross tools not prefixed with host triplet" >&5
+{ $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: using cross tools not prefixed with host triplet" >&5
 $as_echo "$as_me: WARNING: using cross tools not prefixed with host triplet" >&2;}
 ac_tool_warned=yes ;;
 esac
@@ -2049,9 +2339,9 @@ if test -z "$CC"; then
     # Extract the first word of "${ac_tool_prefix}cc", so it can be a program name with args.
 set dummy ${ac_tool_prefix}cc; ac_word=$2
 else
@@ -2062,24 +2352,24 @@ for as_dir in $PATH
 do
   IFS=$as_save_IFS
     ac_cv_prog_CC="${ac_tool_prefix}cc"
     break 2
   fi
 done
-done
+  done
 IFS=$as_save_IFS
 fi
 fi
 CC=$ac_cv_prog_CC
 else
 fi
@@ -2089,9 +2379,9 @@ fi
   # Extract the first word of "cc", so it can be a program name with args.
 set dummy cc; ac_word=$2
 else
@@ -2103,18 +2393,18 @@ for as_dir in $PATH
 do
   IFS=$as_save_IFS
     if test "$as_dir/$ac_word$ac_exec_ext" = "/usr/ucb/cc"; then
        ac_prog_rejected=yes
        continue
      fi
     ac_cv_prog_CC="cc"
     break 2
   fi
 done
-done
+  done
 IFS=$as_save_IFS
 if test $ac_prog_rejected = yes; then
@@ -2133,10 +2423,10 @@ fi
 fi
 CC=$ac_cv_prog_CC
 else
 fi
@@ -2148,9 +2438,9 @@ if test -z "$CC"; then
   do
     # Extract the first word of "$ac_tool_prefix$ac_prog", so it can be a program name with args.
 set dummy $ac_tool_prefix$ac_prog; ac_word=$2
 else
@@ -2161,24 +2451,24 @@ for as_dir in $PATH
 do
   IFS=$as_save_IFS
     ac_cv_prog_CC="$ac_tool_prefix$ac_prog"
     break 2
   fi
 done
-done
+  done
 IFS=$as_save_IFS
 fi
 fi
 CC=$ac_cv_prog_CC
 else
 fi
@@ -2192,9 +2482,9 @@ if test -z "$CC"; then
 do
   # Extract the first word of "$ac_prog", so it can be a program name with args.
 set dummy $ac_prog; ac_word=$2
 else
@@ -2205,24 +2495,24 @@ for as_dir in $PATH
 do
   IFS=$as_save_IFS
     ac_cv_prog_ac_ct_CC="$ac_prog"
     break 2
   fi
 done
-done
+  done
 IFS=$as_save_IFS
 fi
 fi
 else
 fi
@@ -2235,7 +2525,7 @@ done
   else
 yes:)
 esac
@@ -2246,57 +2536,37 @@ fi
 fi
-test -z "$CC" && { { $as_echo "$as_me:$LINENO: error: in \`$ac_pwd':" >&5
+test -z "$CC" && { { $as_echo "$as_me:${as_lineno-$LINENO}: error: in \`$ac_pwd':" >&5
-{ { $as_echo "$as_me:$LINENO: error: no acceptable C compiler found in \$PATH
-See \`config.log' for more details." >&5
-$as_echo "$as_me: error: no acceptable C compiler found in \$PATH
-See \`config.log' for more details." >&2;}
-   { (exit 1); exit 1; }; }; }
+as_fn_error $? "no acceptable C compiler found in \$PATH
 # Provide some information about the compiler.
-$as_echo "$as_me:$LINENO: checking for C compiler version" >&5
+$as_echo "$as_me:${as_lineno-$LINENO}: checking for C compiler version" >&5
 set X $ac_compile
 ac_compiler=$2
-{ (ac_try="$ac_compiler --version >&5"
-case "(($ac_try" in
-  *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;;
-  *) ac_try_echo=$ac_try;;
-esac
-eval ac_try_echo="\"\$as_me:$LINENO: $ac_try_echo\""
-$as_echo "$ac_try_echo") >&5
-  (eval "$ac_compiler --version >&5") 2>&5
-  ac_status=$?
-  $as_echo "$as_me:$LINENO: \$? = $ac_status" >&5
-  (exit $ac_status); }
-{ (ac_try="$ac_compiler -v >&5"
-esac
-  (eval "$ac_compiler -v >&5") 2>&5
-  ac_status=$?
-{ (ac_try="$ac_compiler -V >&5"
+for ac_option in --version -v -V -qversion; do
+  { { ac_try="$ac_compiler $ac_option >&5"
 case "(($ac_try" in
 esac
-  (eval "$ac_compiler -V >&5") 2>&5
+  (eval "$ac_compiler $ac_option >&5") 2>conftest.err
   ac_status=$?
+    sed '10a\
+... rest of stderr output deleted ...
+         10q' conftest.err >conftest.er1
+  fi
+  rm -f conftest.er1 conftest.err
+done
-cat >conftest.$ac_ext <<_ACEOF
-/* confdefs.h.  */
-_ACEOF
-cat confdefs.h >>conftest.$ac_ext
-cat >>conftest.$ac_ext <<_ACEOF
 int
@@ -2312,8 +2582,8 @@ ac_clean_files="$ac_clean_files a.out a.out.dSYM a.exe b.out"
 # Try to create an executable without -o first, disregard a.out.
 # It will help us diagnose broken compilers, and finding out an intuition
 # of exeext.
-{ $as_echo "$as_me:$LINENO: checking for C compiler default output file name" >&5
-$as_echo_n "checking for C compiler default output file name... " >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether the C compiler works" >&5
+$as_echo_n "checking whether the C compiler works... " >&6; }
 ac_link_default=`$as_echo "$ac_link" | sed 's/ -o *conftest[^ ]*//'`
 # The possible output files:
@@ -2329,17 +2599,17 @@ do
 done
 rm -f $ac_rmfiles
-if { (ac_try="$ac_link_default"
+if { { ac_try="$ac_link_default"
 case "(($ac_try" in
 esac
   (eval "$ac_link_default") 2>&5
   ac_status=$?
-  (exit $ac_status); }; then
+  test $ac_status = 0; }; then :
   # Autoconf-2.13 could set the ac_cv_exeext variable to `no'.
 # So ignore a value of `no', otherwise this would lead to `EXEEXT = no'
 # in a Makefile.  We should not override ac_cv_exeext if it was cached,
@@ -2356,7 +2626,7 @@ do
 	# certainly right.
 	break;;
-        if test "${ac_cv_exeext+set}" = set && test "$ac_cv_exeext" != no;
+	if test "${ac_cv_exeext+set}" = set && test "$ac_cv_exeext" != no;
 	then :; else
 	   ac_cv_exeext=`expr "$ac_file" : '[^.]*\(\..*\)'`
 	fi
@@ -2375,84 +2645,41 @@ test "$ac_cv_exeext" = no && ac_cv_exeext=
 else
   ac_file=''
 fi
-{ $as_echo "$as_me:$LINENO: result: $ac_file" >&5
-$as_echo "$ac_file" >&6; }
-if test -z "$ac_file"; then
-  $as_echo "$as_me: failed program was:" >&5
+if test -z "$ac_file"; then :
+$as_echo "no" >&6; }
+$as_echo "$as_me: failed program was:" >&5
-{ { $as_echo "$as_me:$LINENO: error: in \`$ac_pwd':" >&5
+{ { $as_echo "$as_me:${as_lineno-$LINENO}: error: in \`$ac_pwd':" >&5
-{ { $as_echo "$as_me:$LINENO: error: C compiler cannot create executables
-$as_echo "$as_me: error: C compiler cannot create executables
-   { (exit 77); exit 77; }; }; }
+as_fn_error 77 "C compiler cannot create executables
+else
+  { $as_echo "$as_me:${as_lineno-$LINENO}: result: yes" >&5
+$as_echo "yes" >&6; }
 fi
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for C compiler default output file name" >&5
+$as_echo_n "checking for C compiler default output file name... " >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_file" >&5
+$as_echo "$ac_file" >&6; }
 ac_exeext=$ac_cv_exeext
-# Check that the compiler produces executables we can run.  If not, either
-# the compiler is broken, or we cross compile.
-{ $as_echo "$as_me:$LINENO: checking whether the C compiler works" >&5
-$as_echo_n "checking whether the C compiler works... " >&6; }
-# FIXME: These cross compiler hacks should be removed for Autoconf 3.0
-# If not cross compiling, check that we can run a simple program.
-if test "$cross_compiling" != yes; then
-  if { ac_try='./$ac_file'
-  { (case "(($ac_try" in
-esac
-  (eval "$ac_try") 2>&5
-  ac_status=$?
-  (exit $ac_status); }; }; then
-    cross_compiling=no
-  else
-    if test "$cross_compiling" = maybe; then
-	cross_compiling=yes
-    else
-	{ { $as_echo "$as_me:$LINENO: error: in \`$ac_pwd':" >&5
-$as_echo "$as_me: error: in \`$ac_pwd':" >&2;}
-{ { $as_echo "$as_me:$LINENO: error: cannot run C compiled programs.
-If you meant to cross compile, use \`--host'.
-$as_echo "$as_me: error: cannot run C compiled programs.
-    fi
-  fi
-fi
-{ $as_echo "$as_me:$LINENO: result: yes" >&5
-$as_echo "yes" >&6; }
 rm -f -r a.out a.out.dSYM a.exe conftest$ac_cv_exeext b.out
 ac_clean_files=$ac_clean_files_save
-{ $as_echo "$as_me:$LINENO: checking whether we are cross compiling" >&5
-$as_echo_n "checking whether we are cross compiling... " >&6; }
-{ $as_echo "$as_me:$LINENO: result: $cross_compiling" >&5
-$as_echo "$cross_compiling" >&6; }
-{ $as_echo "$as_me:$LINENO: checking for suffix of executables" >&5
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for suffix of executables" >&5
 $as_echo_n "checking for suffix of executables... " >&6; }
-if { (ac_try="$ac_link"
+if { { ac_try="$ac_link"
 case "(($ac_try" in
 esac
   ac_status=$?
   # If both `conftest.exe' and `conftest' are `present' (well, observable)
 # catch `conftest.exe'.  For instance with Cygwin, `ls conftest' will
 # work properly (i.e., refer to `conftest.exe'), while it won't with
@@ -2467,32 +2694,83 @@ for ac_file in conftest.exe conftest conftest.*; do
   esac
 done
 else
+  { { $as_echo "$as_me:${as_lineno-$LINENO}: error: in \`$ac_pwd':" >&5
-{ { $as_echo "$as_me:$LINENO: error: cannot compute suffix of executables: cannot compile and link
-$as_echo "$as_me: error: cannot compute suffix of executables: cannot compile and link
+as_fn_error $? "cannot compute suffix of executables: cannot compile and link
 fi
-rm -f conftest$ac_cv_exeext
-{ $as_echo "$as_me:$LINENO: result: $ac_cv_exeext" >&5
+rm -f conftest conftest$ac_cv_exeext
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_exeext" >&5
 $as_echo "$ac_cv_exeext" >&6; }
 rm -f conftest.$ac_ext
 EXEEXT=$ac_cv_exeext
 ac_exeext=$EXEEXT
-{ $as_echo "$as_me:$LINENO: checking for suffix of object files" >&5
+#include <stdio.h>
+int
+main ()
+FILE *f = fopen ("conftest.out", "w");
+ return ferror (f) || fclose (f) != 0;
+  return 0;
+_ACEOF
+ac_clean_files="$ac_clean_files conftest.out"
+# Check that the compiler produces executables we can run.  If not, either
+# the compiler is broken, or we cross compile.
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether we are cross compiling" >&5
+$as_echo_n "checking whether we are cross compiling... " >&6; }
+if test "$cross_compiling" != yes; then
+  { { ac_try="$ac_link"
+esac
+  ac_status=$?
+  if { ac_try='./conftest$ac_cv_exeext'
+esac
+  ac_status=$?
+    cross_compiling=no
+  else
+    if test "$cross_compiling" = maybe; then
+	cross_compiling=yes
+    else
+as_fn_error $? "cannot run C compiled programs.
+If you meant to cross compile, use \`--host'.
+    fi
+  fi
+fi
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $cross_compiling" >&5
+$as_echo "$cross_compiling" >&6; }
+rm -f conftest.$ac_ext conftest$ac_cv_exeext conftest.out
+ac_clean_files=$ac_clean_files_save
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for suffix of object files" >&5
 $as_echo_n "checking for suffix of object files... " >&6; }
-if test "${ac_cv_objext+set}" = set; then
+if ${ac_cv_objext+:} false; then :
 else
-  cat >conftest.$ac_ext <<_ACEOF
-/* confdefs.h.  */
-_ACEOF
 int
@@ -2504,17 +2782,17 @@ main ()
 _ACEOF
 rm -f conftest.o conftest.obj
-if { (ac_try="$ac_compile"
+if { { ac_try="$ac_compile"
 case "(($ac_try" in
 esac
   (eval "$ac_compile") 2>&5
   ac_status=$?
   for ac_file in conftest.o conftest.obj conftest.*; do
   test -f "$ac_file" || continue;
   case $ac_file in
@@ -2527,31 +2805,23 @@ else
-{ { $as_echo "$as_me:$LINENO: error: cannot compute suffix of object files: cannot compile
-$as_echo "$as_me: error: cannot compute suffix of object files: cannot compile
+as_fn_error $? "cannot compute suffix of object files: cannot compile
 fi
 rm -f conftest.$ac_cv_objext conftest.$ac_ext
 fi
-{ $as_echo "$as_me:$LINENO: result: $ac_cv_objext" >&5
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_objext" >&5
 $as_echo "$ac_cv_objext" >&6; }
 OBJEXT=$ac_cv_objext
 ac_objext=$OBJEXT
-{ $as_echo "$as_me:$LINENO: checking whether we are using the GNU C compiler" >&5
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether we are using the GNU C compiler" >&5
 $as_echo_n "checking whether we are using the GNU C compiler... " >&6; }
-if test "${ac_cv_c_compiler_gnu+set}" = set; then
+if ${ac_cv_c_compiler_gnu+:} false; then :
 else
-/* confdefs.h.  */
-_ACEOF
 int
@@ -2565,37 +2835,16 @@ main ()
   return 0;
 _ACEOF
-rm -f conftest.$ac_objext
-esac
-  (eval "$ac_compile") 2>conftest.er1
-  ac_status=$?
-  grep -v '^ *+' conftest.er1 >conftest.err
-  rm -f conftest.er1
-  cat conftest.err >&5
-  (exit $ac_status); } && {
-	 test -z "$ac_c_werror_flag" ||
-	 test ! -s conftest.err
-       } && test -s conftest.$ac_objext; then
   ac_compiler_gnu=yes
 else
-sed 's/^/| /' conftest.$ac_ext >&5
-	ac_compiler_gnu=no
+  ac_compiler_gnu=no
 fi
 ac_cv_c_compiler_gnu=$ac_compiler_gnu
 fi
-{ $as_echo "$as_me:$LINENO: result: $ac_cv_c_compiler_gnu" >&5
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_c_compiler_gnu" >&5
 $as_echo "$ac_cv_c_compiler_gnu" >&6; }
 if test $ac_compiler_gnu = yes; then
   GCC=yes
@@ -2604,20 +2853,16 @@ else
 fi
 ac_test_CFLAGS=${CFLAGS+set}
 ac_save_CFLAGS=$CFLAGS
-{ $as_echo "$as_me:$LINENO: checking whether $CC accepts -g" >&5
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether $CC accepts -g" >&5
 $as_echo_n "checking whether $CC accepts -g... " >&6; }
-if test "${ac_cv_prog_cc_g+set}" = set; then
+if ${ac_cv_prog_cc_g+:} false; then :
 else
   ac_save_c_werror_flag=$ac_c_werror_flag
    ac_c_werror_flag=yes
    ac_cv_prog_cc_g=no
    CFLAGS="-g"
-/* confdefs.h.  */
-_ACEOF
 int
@@ -2628,35 +2873,11 @@ main ()
   return 0;
 _ACEOF
-esac
-  ac_status=$?
   ac_cv_prog_cc_g=yes
 else
-	CFLAGS=""
-/* confdefs.h.  */
-_ACEOF
+  CFLAGS=""
 int
@@ -2667,36 +2888,12 @@ main ()
   return 0;
 _ACEOF
-esac
-  ac_status=$?
-else
-	ac_c_werror_flag=$ac_save_c_werror_flag
+else
+  ac_c_werror_flag=$ac_save_c_werror_flag
 	 CFLAGS="-g"
-/* confdefs.h.  */
-_ACEOF
 int
@@ -2707,42 +2904,17 @@ main ()
   return 0;
 _ACEOF
-esac
-  ac_status=$?
   ac_cv_prog_cc_g=yes
-else
 fi
 fi
 fi
 fi
-{ $as_echo "$as_me:$LINENO: result: $ac_cv_prog_cc_g" >&5
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_prog_cc_g" >&5
 $as_echo "$ac_cv_prog_cc_g" >&6; }
 if test "$ac_test_CFLAGS" = set; then
   CFLAGS=$ac_save_CFLAGS
@@ -2759,23 +2931,18 @@ else
     CFLAGS=
   fi
 fi
-{ $as_echo "$as_me:$LINENO: checking for $CC option to accept ISO C89" >&5
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for $CC option to accept ISO C89" >&5
 $as_echo_n "checking for $CC option to accept ISO C89... " >&6; }
-if test "${ac_cv_prog_cc_c89+set}" = set; then
+if ${ac_cv_prog_cc_c89+:} false; then :
 else
   ac_cv_prog_cc_c89=no
 ac_save_CC=$CC
-/* confdefs.h.  */
-_ACEOF
 #include <stdarg.h>
 #include <stdio.h>
-#include <sys/types.h>
-#include <sys/stat.h>
+struct stat;
 /* Most of the following tests are stolen from RCS 5.7's src/conf.sh.  */
 struct buf { int x; };
 FILE * (*rcsopen) (struct buf *, struct stat *, int);
@@ -2827,32 +2994,9 @@ for ac_arg in '' -qlanglvl=extc89 -qlanglvl=ansi -std \
 	-Ae "-Aa -D_HPUX_SOURCE" "-Xc -D__EXTENSIONS__"
 do
   CC="$ac_save_CC $ac_arg"
-  rm -f conftest.$ac_objext
-esac
-  ac_status=$?
+  if ac_fn_c_try_compile "$LINENO"; then :
   ac_cv_prog_cc_c89=$ac_arg
-else
 fi
   test "x$ac_cv_prog_cc_c89" != "xno" && break
 done
@@ -2863,17 +3007,19 @@ fi
 # AC_CACHE_VAL
 case "x$ac_cv_prog_cc_c89" in
   x)
-    { $as_echo "$as_me:$LINENO: result: none needed" >&5
+    { $as_echo "$as_me:${as_lineno-$LINENO}: result: none needed" >&5
 $as_echo "none needed" >&6; } ;;
   xno)
-    { $as_echo "$as_me:$LINENO: result: unsupported" >&5
+    { $as_echo "$as_me:${as_lineno-$LINENO}: result: unsupported" >&5
 $as_echo "unsupported" >&6; } ;;
     CC="$CC $ac_cv_prog_cc_c89"
-    { $as_echo "$as_me:$LINENO: result: $ac_cv_prog_cc_c89" >&5
+    { $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_prog_cc_c89" >&5
 $as_echo "$ac_cv_prog_cc_c89" >&6; } ;;
 esac
+if test "x$ac_cv_prog_cc_c89" != xno; then :
+fi
 ac_ext=c
@@ -2882,11 +3028,7 @@ ac_link='$CC -o conftest$ac_exeext $CFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $
-/* confdefs.h.  */
-_ACEOF
 #include <mpi.h>
 int
@@ -2897,46 +3039,21 @@ int ret = MPI_Init(0, (void*)0)
   return 0;
 _ACEOF
-esac
-  ac_status=$?
-  { $as_echo "$as_me:$LINENO: result: yes" >&5
 else
-    { { $as_echo "$as_me:$LINENO: error: CC doesn't appear to be a valid MPI compiler.  See INSTALL document or try adding CC=mpicc to your configure command line." >&5
-$as_echo "$as_me: error: CC doesn't appear to be a valid MPI compiler.  See INSTALL document or try adding CC=mpicc to your configure command line." >&2;}
+    as_fn_error $? "CC doesn't appear to be a valid MPI compiler.  See INSTALL document or try adding CC=mpicc to your configure command line." "$LINENO" 5
 fi
 # Check whether --with-zlib-for-mpi was given.
-if test "${with_zlib_for_mpi+set}" = set; then
-  withval=$with_zlib_for_mpi; { { $as_echo "$as_me:$LINENO: error: with-zlib-for-mpi argument is deprecated.  Please see Darshan documentation." >&5
-$as_echo "$as_me: error: with-zlib-for-mpi argument is deprecated.  Please see Darshan documentation." >&2;}
+if test "${with_zlib_for_mpi+set}" = set; then :
+  withval=$with_zlib_for_mpi; as_fn_error $? "with-zlib-for-mpi argument is deprecated.  Please see Darshan documentation." "$LINENO" 5
 fi
@@ -2947,14 +3064,14 @@ ac_cpp='$CPP $CPPFLAGS'
 ac_compile='$CC -c $CFLAGS $CPPFLAGS conftest.$ac_ext >&5'
 ac_link='$CC -o conftest$ac_exeext $CFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
-{ $as_echo "$as_me:$LINENO: checking how to run the C preprocessor" >&5
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking how to run the C preprocessor" >&5
 $as_echo_n "checking how to run the C preprocessor... " >&6; }
 # On Suns, sometimes $CPP names a directory.
 if test -n "$CPP" && test -d "$CPP"; then
   CPP=
 fi
 if test -z "$CPP"; then
-  if test "${ac_cv_prog_CPP+set}" = set; then
+  if ${ac_cv_prog_CPP+:} false; then :
 else
       # Double quotes because CPP needs to be expanded
@@ -2969,11 +3086,7 @@ do
   # <limits.h> exists even on freestanding compilers.
   # On the NeXT, cc -E runs the code through the compiler's parser,
   # not just through cpp. "Syntax error" is here to catch this case.
-/* confdefs.h.  */
-_ACEOF
 #ifdef __STDC__
 # include <limits.h>
@@ -2982,78 +3095,34 @@ cat >>conftest.$ac_ext <<_ACEOF
 #endif
 		     Syntax error
 _ACEOF
-if { (ac_try="$ac_cpp conftest.$ac_ext"
-esac
-  (eval "$ac_cpp conftest.$ac_ext") 2>conftest.er1
-  ac_status=$?
-  (exit $ac_status); } >/dev/null && {
-	 test -z "$ac_c_preproc_warn_flag$ac_c_werror_flag" ||
-       }; then
-else
+else
   # Broken: fails on valid input.
 continue
 fi
-rm -f conftest.err conftest.$ac_ext
   # OK, works on sane cases.  Now check whether nonexistent headers
   # can be detected and how.
-/* confdefs.h.  */
-_ACEOF
 #include <ac_nonexistent.h>
 _ACEOF
-esac
-  ac_status=$?
-       }; then
   # Broken: success on invalid input.
 continue
 else
   # Passes both tests.
 ac_preproc_ok=:
 break
 fi
 done
 # Because of `break', _AC_PREPROC_IFELSE's cleaning code was skipped.
-if $ac_preproc_ok; then
+rm -f conftest.i conftest.err conftest.$ac_ext
+if $ac_preproc_ok; then :
   break
 fi
@@ -3065,7 +3134,7 @@ fi
 else
   ac_cv_prog_CPP=$CPP
 fi
-{ $as_echo "$as_me:$LINENO: result: $CPP" >&5
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $CPP" >&5
 $as_echo "$CPP" >&6; }
 ac_preproc_ok=false
 for ac_c_preproc_warn_flag in '' yes
@@ -3076,11 +3145,7 @@ do
-/* confdefs.h.  */
-_ACEOF
 #ifdef __STDC__
@@ -3089,87 +3154,40 @@ cat >>conftest.$ac_ext <<_ACEOF
 #endif
 		     Syntax error
 _ACEOF
-esac
-  ac_status=$?
-       }; then
-else
+else
 continue
 fi
-/* confdefs.h.  */
-_ACEOF
 _ACEOF
-esac
-  ac_status=$?
-       }; then
 continue
 else
 ac_preproc_ok=:
 break
 fi
 done
 else
-{ { $as_echo "$as_me:$LINENO: error: C preprocessor \"$CPP\" fails sanity check
-$as_echo "$as_me: error: C preprocessor \"$CPP\" fails sanity check
+as_fn_error $? "C preprocessor \"$CPP\" fails sanity check
 fi
 ac_ext=c
@@ -3179,9 +3197,9 @@ ac_link='$CC -o conftest$ac_exeext $CFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $
-{ $as_echo "$as_me:$LINENO: checking for grep that handles long lines and -e" >&5
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for grep that handles long lines and -e" >&5
 $as_echo_n "checking for grep that handles long lines and -e... " >&6; }
-if test "${ac_cv_path_GREP+set}" = set; then
+if ${ac_cv_path_GREP+:} false; then :
 else
   if test -z "$GREP"; then
@@ -3192,10 +3210,10 @@ for as_dir in $PATH$PATH_SEPARATOR/usr/xpg4/bin
 do
   IFS=$as_save_IFS
   test -z "$as_dir" && as_dir=.
-  for ac_prog in grep ggrep; do
+    for ac_prog in grep ggrep; do
       ac_path_GREP="$as_dir/$ac_prog$ac_exec_ext"
-      { test -f "$ac_path_GREP" && $as_test_x "$ac_path_GREP"; } || continue
+      as_fn_executable_p "$ac_path_GREP" || continue
 # Check for GNU ac_path_GREP and select it if it is found.
   # Check for GNU $ac_path_GREP
 case `"$ac_path_GREP" --version 2>&1` in
@@ -3212,7 +3230,7 @@ case `"$ac_path_GREP" --version 2>&1` in
     $as_echo 'GREP' >> "conftest.nl"
     "$ac_path_GREP" -e 'GREP$' -e '-(cannot match)-' < "conftest.nl" >"conftest.out" 2>/dev/null || break
     diff "conftest.out" "conftest.nl" >/dev/null 2>&1 || break
-    ac_count=`expr $ac_count + 1`
+    as_fn_arith $ac_count + 1 && ac_count=$as_val
     if test $ac_count -gt ${ac_path_GREP_max-0}; then
       # Best one so far, save it but keep looking for a better one
       ac_cv_path_GREP="$ac_path_GREP"
@@ -3227,26 +3245,24 @@ esac
       $ac_path_GREP_found && break 3
     done
   done
-done
+  done
 IFS=$as_save_IFS
   if test -z "$ac_cv_path_GREP"; then
-    { { $as_echo "$as_me:$LINENO: error: no acceptable grep could be found in $PATH$PATH_SEPARATOR/usr/xpg4/bin" >&5
-$as_echo "$as_me: error: no acceptable grep could be found in $PATH$PATH_SEPARATOR/usr/xpg4/bin" >&2;}
+    as_fn_error $? "no acceptable grep could be found in $PATH$PATH_SEPARATOR/usr/xpg4/bin" "$LINENO" 5
   fi
 else
   ac_cv_path_GREP=$GREP
 fi
 fi
-{ $as_echo "$as_me:$LINENO: result: $ac_cv_path_GREP" >&5
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_path_GREP" >&5
 $as_echo "$ac_cv_path_GREP" >&6; }
  GREP="$ac_cv_path_GREP"
-{ $as_echo "$as_me:$LINENO: checking for egrep" >&5
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for egrep" >&5
 $as_echo_n "checking for egrep... " >&6; }
-if test "${ac_cv_path_EGREP+set}" = set; then
+if ${ac_cv_path_EGREP+:} false; then :
 else
   if echo a | $GREP -E '(a|b)' >/dev/null 2>&1
@@ -3260,10 +3276,10 @@ for as_dir in $PATH$PATH_SEPARATOR/usr/xpg4/bin
 do
   IFS=$as_save_IFS
-  for ac_prog in egrep; do
+    for ac_prog in egrep; do
       ac_path_EGREP="$as_dir/$ac_prog$ac_exec_ext"
-      { test -f "$ac_path_EGREP" && $as_test_x "$ac_path_EGREP"; } || continue
+      as_fn_executable_p "$ac_path_EGREP" || continue
 # Check for GNU ac_path_EGREP and select it if it is found.
   # Check for GNU $ac_path_EGREP
 case `"$ac_path_EGREP" --version 2>&1` in
@@ -3280,7 +3296,7 @@ case `"$ac_path_EGREP" --version 2>&1` in
     $as_echo 'EGREP' >> "conftest.nl"
     "$ac_path_EGREP" 'EGREP$' < "conftest.nl" >"conftest.out" 2>/dev/null || break
     if test $ac_count -gt ${ac_path_EGREP_max-0}; then
       ac_cv_path_EGREP="$ac_path_EGREP"
@@ -3295,12 +3311,10 @@ esac
       $ac_path_EGREP_found && break 3
     done
   done
-done
+  done
 IFS=$as_save_IFS
   if test -z "$ac_cv_path_EGREP"; then
-    { { $as_echo "$as_me:$LINENO: error: no acceptable egrep could be found in $PATH$PATH_SEPARATOR/usr/xpg4/bin" >&5
-$as_echo "$as_me: error: no acceptable egrep could be found in $PATH$PATH_SEPARATOR/usr/xpg4/bin" >&2;}
+    as_fn_error $? "no acceptable egrep could be found in $PATH$PATH_SEPARATOR/usr/xpg4/bin" "$LINENO" 5
   fi
 else
   ac_cv_path_EGREP=$EGREP
@@ -3308,21 +3322,17 @@ fi
    fi
 fi
-{ $as_echo "$as_me:$LINENO: result: $ac_cv_path_EGREP" >&5
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_path_EGREP" >&5
 $as_echo "$ac_cv_path_EGREP" >&6; }
  EGREP="$ac_cv_path_EGREP"
-{ $as_echo "$as_me:$LINENO: checking for ANSI C header files" >&5
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for ANSI C header files" >&5
 $as_echo_n "checking for ANSI C header files... " >&6; }
-if test "${ac_cv_header_stdc+set}" = set; then
+if ${ac_cv_header_stdc+:} false; then :
 else
-/* confdefs.h.  */
-_ACEOF
 #include <stdlib.h>
 #include <stdarg.h>
@@ -3337,48 +3347,23 @@ main ()
   return 0;
 _ACEOF
-esac
-  ac_status=$?
   ac_cv_header_stdc=yes
 else
-	ac_cv_header_stdc=no
+  ac_cv_header_stdc=no
 fi
 if test $ac_cv_header_stdc = yes; then
   # SunOS 4.x string.h does not declare mem*, contrary to ANSI.
-/* confdefs.h.  */
-_ACEOF
 #include <string.h>
 _ACEOF
 if (eval "$ac_cpp conftest.$ac_ext") 2>&5 |
-  $EGREP "memchr" >/dev/null 2>&1; then
+  $EGREP "memchr" >/dev/null 2>&1; then :
 else
 fi
@@ -3388,18 +3373,14 @@ fi
   # ISC 2.0.2 stdlib.h does not declare free, contrary to ANSI.
-/* confdefs.h.  */
-_ACEOF
 #include <stdlib.h>
 _ACEOF
-  $EGREP "free" >/dev/null 2>&1; then
+  $EGREP "free" >/dev/null 2>&1; then :
 else
 fi
@@ -3409,14 +3390,10 @@ fi
   # /bin/cc in Irix-4.0.5 gets non-ANSI ctype macros unless using -ansi.
-  if test "$cross_compiling" = yes; then
+  if test "$cross_compiling" = yes; then :
 else
-/* confdefs.h.  */
-_ACEOF
 #include <ctype.h>
 #include <stdlib.h>
@@ -3443,118 +3420,33 @@ main ()
   return 0;
 _ACEOF
-rm -f conftest$ac_exeext
-esac
-  (eval "$ac_link") 2>&5
-  ac_status=$?
-  (exit $ac_status); } && { ac_try='./conftest$ac_exeext'
-esac
-  ac_status=$?
-else
-  $as_echo "$as_me: program exited with status $ac_status" >&5
-$as_echo "$as_me: failed program was:" >&5
+if ac_fn_c_try_run "$LINENO"; then :
-( exit $ac_status )
-ac_cv_header_stdc=no
+else
 fi
-rm -rf conftest.dSYM
-rm -f core *.core core.conftest.* gmon.out bb.out conftest$ac_exeext conftest.$ac_objext conftest.$ac_ext
+rm -f core *.core core.conftest.* gmon.out bb.out conftest$ac_exeext \
+  conftest.$ac_objext conftest.beam conftest.$ac_ext
 fi
 fi
 fi
-{ $as_echo "$as_me:$LINENO: result: $ac_cv_header_stdc" >&5
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_header_stdc" >&5
 $as_echo "$ac_cv_header_stdc" >&6; }
-cat >>confdefs.h <<\_ACEOF
-#define STDC_HEADERS 1
-_ACEOF
+$as_echo "#define STDC_HEADERS 1" >>confdefs.h
 fi
 # On IRIX 5.3, sys/types and inttypes.h are conflicting.
 for ac_header in sys/types.h sys/stat.h stdlib.h string.h memory.h strings.h \
 		  inttypes.h stdint.h unistd.h
-do
-as_ac_Header=`$as_echo "ac_cv_header_$ac_header" | $as_tr_sh`
-{ $as_echo "$as_me:$LINENO: checking for $ac_header" >&5
-$as_echo_n "checking for $ac_header... " >&6; }
-if { as_var=$as_ac_Header; eval "test \"\${$as_var+set}\" = set"; }; then
-  $as_echo_n "(cached) " >&6
-else
-/* confdefs.h.  */
-_ACEOF
-/* end confdefs.h.  */
-$ac_includes_default
-#include <$ac_header>
-_ACEOF
-esac
-  ac_status=$?
-  eval "$as_ac_Header=yes"
-else
-	eval "$as_ac_Header=no"
-fi
-rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext
-fi
-ac_res=`eval 'as_val=${'$as_ac_Header'}
-		 $as_echo "$as_val"'`
-	       { $as_echo "$as_me:$LINENO: result: $ac_res" >&5
-$as_echo "$ac_res" >&6; }
-as_val=`eval 'as_val=${'$as_ac_Header'}
-   if test "x$as_val" = x""yes; then
+do :
+  as_ac_Header=`$as_echo "ac_cv_header_$ac_header" | $as_tr_sh`
+ac_fn_c_check_header_compile "$LINENO" "$ac_header" "$as_ac_Header" "$ac_includes_default
+if eval test \"x\$"$as_ac_Header"\" = x"yes"; then :
 #define `$as_echo "HAVE_$ac_header" | $as_tr_cpp` 1
 _ACEOF
@@ -3568,7 +3460,7 @@ done
 # Check whether --with-zlib was given.
-if test "${with_zlib+set}" = set; then
+if test "${with_zlib+set}" = set; then :
   withval=$with_zlib; if test "$withval" != no ; then
   if test -d "$withval"
   then
@@ -3578,166 +3470,31 @@ if test "${with_zlib+set}" = set; then
     __CP_ZLIB_LINK_FLAGS="-L${ZLIB_HOME}/lib"
     __CP_ZLIB_INCLUDE_FLAGS="-I${ZLIB_HOME}/include"
   else
-    { $as_echo "$as_me:$LINENO: WARNING: Sorry, $withval does not exist, checking usual places" >&5
+    { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: Sorry, $withval does not exist, checking usual places" >&5
 $as_echo "$as_me: WARNING: Sorry, $withval does not exist, checking usual places" >&2;}
   fi
 else
-  { { $as_echo "$as_me:$LINENO: error: zlib is required" >&5
-$as_echo "$as_me: error: zlib is required" >&2;}
+  as_fn_error $? "zlib is required" "$LINENO" 5
 fi
 fi
-if test "${ac_cv_header_zlib_h+set}" = set; then
-  { $as_echo "$as_me:$LINENO: checking for zlib.h" >&5
-$as_echo_n "checking for zlib.h... " >&6; }
-fi
-{ $as_echo "$as_me:$LINENO: result: $ac_cv_header_zlib_h" >&5
-$as_echo "$ac_cv_header_zlib_h" >&6; }
-else
-  # Is the header compilable?
-{ $as_echo "$as_me:$LINENO: checking zlib.h usability" >&5
-$as_echo_n "checking zlib.h usability... " >&6; }
-/* confdefs.h.  */
-_ACEOF
-#include <zlib.h>
-_ACEOF
-esac
-  ac_status=$?
-  ac_header_compiler=yes
-else
-	ac_header_compiler=no
-fi
-{ $as_echo "$as_me:$LINENO: result: $ac_header_compiler" >&5
-$as_echo "$ac_header_compiler" >&6; }
-# Is the header present?
-{ $as_echo "$as_me:$LINENO: checking zlib.h presence" >&5
-$as_echo_n "checking zlib.h presence... " >&6; }
-/* confdefs.h.  */
-_ACEOF
-#include <zlib.h>
-_ACEOF
-esac
-  ac_status=$?
-       }; then
-  ac_header_preproc=yes
-else
-  ac_header_preproc=no
-fi
-{ $as_echo "$as_me:$LINENO: result: $ac_header_preproc" >&5
-$as_echo "$ac_header_preproc" >&6; }
-# So?  What about this header?
-case $ac_header_compiler:$ac_header_preproc:$ac_c_preproc_warn_flag in
-  yes:no: )
-    { $as_echo "$as_me:$LINENO: WARNING: zlib.h: accepted by the compiler, rejected by the preprocessor!" >&5
-$as_echo "$as_me: WARNING: zlib.h: accepted by the compiler, rejected by the preprocessor!" >&2;}
-    { $as_echo "$as_me:$LINENO: WARNING: zlib.h: proceeding with the compiler's result" >&5
-$as_echo "$as_me: WARNING: zlib.h: proceeding with the compiler's result" >&2;}
-  no:yes:* )
-    { $as_echo "$as_me:$LINENO: WARNING: zlib.h: present but cannot be compiled" >&5
-$as_echo "$as_me: WARNING: zlib.h: present but cannot be compiled" >&2;}
-    { $as_echo "$as_me:$LINENO: WARNING: zlib.h:     check for missing prerequisite headers?" >&5
-$as_echo "$as_me: WARNING: zlib.h:     check for missing prerequisite headers?" >&2;}
-    { $as_echo "$as_me:$LINENO: WARNING: zlib.h: see the Autoconf documentation" >&5
-$as_echo "$as_me: WARNING: zlib.h: see the Autoconf documentation" >&2;}
-    { $as_echo "$as_me:$LINENO: WARNING: zlib.h:     section \"Present But Cannot Be Compiled\"" >&5
-$as_echo "$as_me: WARNING: zlib.h:     section \"Present But Cannot Be Compiled\"" >&2;}
-    { $as_echo "$as_me:$LINENO: WARNING: zlib.h: proceeding with the preprocessor's result" >&5
-$as_echo "$as_me: WARNING: zlib.h: proceeding with the preprocessor's result" >&2;}
-    { $as_echo "$as_me:$LINENO: WARNING: zlib.h: in the future, the compiler will take precedence" >&5
-$as_echo "$as_me: WARNING: zlib.h: in the future, the compiler will take precedence" >&2;}
-esac
-{ $as_echo "$as_me:$LINENO: checking for zlib.h" >&5
-else
-  ac_cv_header_zlib_h=$ac_header_preproc
-fi
+ac_fn_c_check_header_mongrel "$LINENO" "zlib.h" "ac_cv_header_zlib_h" "$ac_includes_default"
+if test "x$ac_cv_header_zlib_h" = xyes; then :
-fi
-if test "x$ac_cv_header_zlib_h" = x""yes; then
 else
-  { { $as_echo "$as_me:$LINENO: error: z.h not found" >&5
-$as_echo "$as_me: error: z.h not found" >&2;}
+  as_fn_error $? "z.h not found" "$LINENO" 5
 fi
-{ $as_echo "$as_me:$LINENO: checking for inflateEnd in -lz" >&5
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for inflateEnd in -lz" >&5
 $as_echo_n "checking for inflateEnd in -lz... " >&6; }
-if test "${ac_cv_lib_z_inflateEnd+set}" = set; then
+if ${ac_cv_lib_z_inflateEnd+:} false; then :
 else
   ac_check_lib_save_LIBS=$LIBS
 LIBS="-lz  $LIBS"
-/* confdefs.h.  */
-_ACEOF
 /* Override any GCC internal prototype to avoid an error.
@@ -3755,43 +3512,18 @@ return inflateEnd ();
   return 0;
 _ACEOF
-rm -f conftest.$ac_objext conftest$ac_exeext
-esac
-  (eval "$ac_link") 2>conftest.er1
-  ac_status=$?
-       } && test -s conftest$ac_exeext && {
-	 test "$cross_compiling" = yes ||
-	 $as_test_x conftest$ac_exeext
-       }; then
+if ac_fn_c_try_link "$LINENO"; then :
   ac_cv_lib_z_inflateEnd=yes
 else
-	ac_cv_lib_z_inflateEnd=no
+  ac_cv_lib_z_inflateEnd=no
 fi
-rm -f core conftest.err conftest.$ac_objext conftest_ipa8_conftest.oo \
-      conftest$ac_exeext conftest.$ac_ext
+rm -f core conftest.err conftest.$ac_objext \
+    conftest$ac_exeext conftest.$ac_ext
 LIBS=$ac_check_lib_save_LIBS
 fi
-{ $as_echo "$as_me:$LINENO: result: $ac_cv_lib_z_inflateEnd" >&5
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_lib_z_inflateEnd" >&5
 $as_echo "$ac_cv_lib_z_inflateEnd" >&6; }
-if test "x$ac_cv_lib_z_inflateEnd" = x""yes; then
+if test "x$ac_cv_lib_z_inflateEnd" = xyes; then :
 #define HAVE_LIBZ 1
 _ACEOF
@@ -3799,21 +3531,17 @@ _ACEOF
   LIBS="-lz $LIBS"
 else
-  { { $as_echo "$as_me:$LINENO: error: libz not found" >&5
-$as_echo "$as_me: error: libz not found" >&2;}
+  as_fn_error $? "libz not found" "$LINENO" 5
 fi
 # Check whether --enable-cuserid was given.
-if test "${enable_cuserid+set}" = set; then
+if test "${enable_cuserid+set}" = set; then :
   enableval=$enable_cuserid; if test "x$enableval" = "xno" ; then
-#define DARSHAN_DISABLE_CUSERID 1
-_ACEOF
+$as_echo "#define DARSHAN_DISABLE_CUSERID 1" >>confdefs.h
 fi
@@ -3821,7 +3549,7 @@ fi
 # Check whether --enable-ld-preload was given.
-if test "${enable_ld_preload+set}" = set; then
+if test "${enable_ld_preload+set}" = set; then :
   enableval=$enable_ld_preload; if test "x$enableval" = "xno" ; then
     DISABLE_LDPRELOAD="1"
 fi
@@ -3830,12 +3558,10 @@ fi
 # Check whether --enable-group-readable-logs was given.
-if test "${enable_group_readable_logs+set}" = set; then
+if test "${enable_group_readable_logs+set}" = set; then :
   enableval=$enable_group_readable_logs; if test "x$enableval" = "xyes" ; then
-#define __CP_GROUP_READABLE_LOGS 1
-_ACEOF
+$as_echo "#define __CP_GROUP_READABLE_LOGS 1" >>confdefs.h
 fi
@@ -3843,12 +3569,10 @@ fi
 # Check whether --enable-stat-at-open was given.
-if test "${enable_stat_at_open+set}" = set; then
+if test "${enable_stat_at_open+set}" = set; then :
   enableval=$enable_stat_at_open; if test "x$enableval" = "xyes" ; then
-#define __CP_STAT_AT_OPEN 1
-_ACEOF
+$as_echo "#define __CP_STAT_AT_OPEN 1" >>confdefs.h
 fi
@@ -3857,11 +3581,9 @@ fi
 # Check whether --with-mem-align was given.
-if test "${with_mem_align+set}" = set; then
+if test "${with_mem_align+set}" = set; then :
   withval=$with_mem_align; if test x$withval = xyes; then
-        { { $as_echo "$as_me:$LINENO: error: --with-mem-align must be given a number in bytes" >&5
-$as_echo "$as_me: error: --with-mem-align must be given a number in bytes" >&2;}
+        as_fn_error $? "--with-mem-align must be given a number in bytes" "$LINENO" 5
     else
@@ -3876,11 +3598,9 @@ fi
 # Check whether --with-log-path-by-env was given.
-if test "${with_log_path_by_env+set}" = set; then
+if test "${with_log_path_by_env+set}" = set; then :
   withval=$with_log_path_by_env; if test x$withval = xyes; then
-        { { $as_echo "$as_me:$LINENO: error: --with-log-path-by-env must be given at least one variable name" >&5
-$as_echo "$as_me: error: --with-log-path-by-env must be given at least one variable name" >&2;}
+        as_fn_error $? "--with-log-path-by-env must be given at least one variable name" "$LINENO" 5
     else
@@ -3896,11 +3616,9 @@ fi
 # Check whether --with-log-hints was given.
-if test "${with_log_hints+set}" = set; then
+if test "${with_log_hints+set}" = set; then :
   withval=$with_log_hints; if test x$withval = xyes; then
-        { { $as_echo "$as_me:$LINENO: error: --with-log-hints must be given an argument" >&5
-$as_echo "$as_me: error: --with-log-hints must be given an argument" >&2;}
+        as_fn_error $? "--with-log-hints must be given an argument" "$LINENO" 5
     else
@@ -3916,11 +3634,9 @@ fi
 # Check whether --with-log-path was given.
-if test "${with_log_path+set}" = set; then
+if test "${with_log_path+set}" = set; then :
   withval=$with_log_path; if test x$withval = xyes; then
-        { { $as_echo "$as_me:$LINENO: error: --with-log-path must be given a pathname" >&5
-$as_echo "$as_me: error: --with-log-path must be given a pathname" >&2;}
+        as_fn_error $? "--with-log-path must be given a pathname" "$LINENO" 5
     else
@@ -3936,11 +3652,9 @@ fi
 # Check whether --with-jobid-env was given.
-if test "${with_jobid_env+set}" = set; then
+if test "${with_jobid_env+set}" = set; then :
   withval=$with_jobid_env; if test x$withval = xyes; then
-        { { $as_echo "$as_me:$LINENO: error: --with-jobid-env must be given a name" >&5
-$as_echo "$as_me: error: --with-jobid-env must be given a name" >&2;}
+        as_fn_error $? "--with-jobid-env must be given a name" "$LINENO" 5
     else
@@ -3955,19 +3669,13 @@ fi
 if test x$GOT_ALIGNMENT != x1; then
-    { { $as_echo "$as_me:$LINENO: error: must provide --with-mem-align=<num> argument to configure." >&5
-$as_echo "$as_me: error: must provide --with-mem-align=<num> argument to configure." >&2;}
+    as_fn_error $? "must provide --with-mem-align=<num> argument to configure." "$LINENO" 5
 fi
 if test x$GOT_LOG_PATH != x1; then
-    { { $as_echo "$as_me:$LINENO: error: must provide --with-log-path=<path> _or_ --with-log-path-by-env=<variable list> argument to configure." >&5
-$as_echo "$as_me: error: must provide --with-log-path=<path> _or_ --with-log-path-by-env=<variable list> argument to configure." >&2;}
+    as_fn_error $? "must provide --with-log-path=<path> _or_ --with-log-path-by-env=<variable list> argument to configure." "$LINENO" 5
 fi
 if test x$GOT_JOBID != x1; then
-    { { $as_echo "$as_me:$LINENO: error: must provide --with-jobid-env=<name> argument to configure." >&5
-$as_echo "$as_me: error: must provide --with-jobid-env=<name> argument to configure." >&2;}
+    as_fn_error $? "must provide --with-jobid-env=<name> argument to configure." "$LINENO" 5
 fi
 __CP_LOG_HINTS_DEFAULT="romio_no_indep_rw=true;cb_nodes=4"
 if test x$GOT_LOG_HINTS != x1; then
@@ -3980,146 +3688,12 @@ fi
 # checks to see how we can print 64 bit values on this architecture
-for ac_header in inttypes.h
-do
-  { $as_echo "$as_me:$LINENO: checking for $ac_header" >&5
-fi
-else
-{ $as_echo "$as_me:$LINENO: checking $ac_header usability" >&5
-$as_echo_n "checking $ac_header usability... " >&6; }
-/* confdefs.h.  */
-_ACEOF
-_ACEOF
-esac
-  ac_status=$?
-else
-fi
-{ $as_echo "$as_me:$LINENO: checking $ac_header presence" >&5
-$as_echo_n "checking $ac_header presence... " >&6; }
-/* confdefs.h.  */
-_ACEOF
-_ACEOF
-esac
-  ac_status=$?
-       }; then
-else
-fi
-  yes:no: )
-    { $as_echo "$as_me:$LINENO: WARNING: $ac_header: accepted by the compiler, rejected by the preprocessor!" >&5
-$as_echo "$as_me: WARNING: $ac_header: accepted by the compiler, rejected by the preprocessor!" >&2;}
-    { $as_echo "$as_me:$LINENO: WARNING: $ac_header: proceeding with the compiler's result" >&5
-$as_echo "$as_me: WARNING: $ac_header: proceeding with the compiler's result" >&2;}
-  no:yes:* )
-    { $as_echo "$as_me:$LINENO: WARNING: $ac_header: present but cannot be compiled" >&5
-$as_echo "$as_me: WARNING: $ac_header: present but cannot be compiled" >&2;}
-    { $as_echo "$as_me:$LINENO: WARNING: $ac_header:     check for missing prerequisite headers?" >&5
-$as_echo "$as_me: WARNING: $ac_header:     check for missing prerequisite headers?" >&2;}
-    { $as_echo "$as_me:$LINENO: WARNING: $ac_header: see the Autoconf documentation" >&5
-$as_echo "$as_me: WARNING: $ac_header: see the Autoconf documentation" >&2;}
-    { $as_echo "$as_me:$LINENO: WARNING: $ac_header:     section \"Present But Cannot Be Compiled\"" >&5
-$as_echo "$as_me: WARNING: $ac_header:     section \"Present But Cannot Be Compiled\"" >&2;}
-    { $as_echo "$as_me:$LINENO: WARNING: $ac_header: proceeding with the preprocessor's result" >&5
-$as_echo "$as_me: WARNING: $ac_header: proceeding with the preprocessor's result" >&2;}
-    { $as_echo "$as_me:$LINENO: WARNING: $ac_header: in the future, the compiler will take precedence" >&5
-$as_echo "$as_me: WARNING: $ac_header: in the future, the compiler will take precedence" >&2;}
-esac
-else
-  eval "$as_ac_Header=\$ac_header_preproc"
-fi
-fi
+  for ac_header in inttypes.h
+do :
+  ac_fn_c_check_header_mongrel "$LINENO" "inttypes.h" "ac_cv_header_inttypes_h" "$ac_includes_default"
+if test "x$ac_cv_header_inttypes_h" = xyes; then :
-#define `$as_echo "HAVE_$ac_header" | $as_tr_cpp` 1
+#define HAVE_INTTYPES_H 1
 _ACEOF
 fi
@@ -4127,17 +3701,13 @@ fi
 done
   if test $ac_cv_header_inttypes_h = yes; then
-    { $as_echo "$as_me:$LINENO: checking whether the inttypes.h PRIxNN macros are broken" >&5
+    { $as_echo "$as_me:${as_lineno-$LINENO}: checking whether the inttypes.h PRIxNN macros are broken" >&5
 $as_echo_n "checking whether the inttypes.h PRIxNN macros are broken... " >&6; }
-if test "${gt_cv_inttypes_pri_broken+set}" = set; then
+if ${gt_cv_inttypes_pri_broken+:} false; then :
 else
-/* confdefs.h.  */
-_ACEOF
 #include <inttypes.h>
 #ifdef PRId32
@@ -4152,36 +3722,15 @@ main ()
   return 0;
 _ACEOF
-esac
-  ac_status=$?
   gt_cv_inttypes_pri_broken=no
 else
-	gt_cv_inttypes_pri_broken=yes
+  gt_cv_inttypes_pri_broken=yes
 fi
 fi
-{ $as_echo "$as_me:$LINENO: result: $gt_cv_inttypes_pri_broken" >&5
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $gt_cv_inttypes_pri_broken" >&5
 $as_echo "$gt_cv_inttypes_pri_broken" >&6; }
   fi
   if test "$gt_cv_inttypes_pri_broken" = yes; then
@@ -4197,175 +3746,32 @@ _ACEOF
 if test x$PRI_MACROS_BROKEN == xyes; then
-    { { $as_echo "$as_me:$LINENO: error: PRI_xx macros are broken" >&5
-$as_echo "$as_me: error: PRI_xx macros are broken" >&2;}
-else
-do
-fi
-else
-/* confdefs.h.  */
-_ACEOF
-_ACEOF
-esac
-  ac_status=$?
-else
-fi
-/* confdefs.h.  */
-_ACEOF
-_ACEOF
-esac
-  ac_status=$?
-       }; then
+    as_fn_error $? "PRI_xx macros are broken" "$LINENO" 5
 else
-fi
-  yes:no: )
-  no:yes:* )
-esac
-else
-fi
-fi
+do :
 _ACEOF
 else
-  { { $as_echo "$as_me:$LINENO: error: Couldn't find inttypes.h" >&5
-$as_echo "$as_me: error: Couldn't find inttypes.h" >&2;}
+  as_fn_error $? "Couldn't find inttypes.h" "$LINENO" 5
 fi
 done
 fi
- { $as_echo "$as_me:$LINENO: checking whether byte ordering is bigendian" >&5
+ { $as_echo "$as_me:${as_lineno-$LINENO}: checking whether byte ordering is bigendian" >&5
 $as_echo_n "checking whether byte ordering is bigendian... " >&6; }
-if test "${ac_cv_c_bigendian+set}" = set; then
+if ${ac_cv_c_bigendian+:} false; then :
 else
   ac_cv_c_bigendian=unknown
     # See if we're dealing with a universal compiler.
-/* confdefs.h.  */
-_ACEOF
 #ifndef __APPLE_CC__
 	       not a universal capable compiler
@@ -4373,46 +3779,34 @@ cat >>conftest.$ac_ext <<_ACEOF
 	     typedef int dummy;
 _ACEOF
-esac
-  ac_status=$?
 	# Check for potential -arch flags.  It is not universal unless
-	# there are some -arch flags.  Note that *ppc* also matches
-	# ppc64.  This check is also rather less than ideal.
-	case "${CC} ${CFLAGS} ${CPPFLAGS} ${LDFLAGS}" in  #(
-	  *-arch*ppc*|*-arch*i386*|*-arch*x86_64*) ac_cv_c_bigendian=universal;;
-	esac
-else
+	# there are at least two -arch flags with different values.
+	ac_arch=
+	ac_prev=
+	for ac_word in $CC $CFLAGS $CPPFLAGS $LDFLAGS; do
+	 if test -n "$ac_prev"; then
+	   case $ac_word in
+	     i?86 | x86_64 | ppc | ppc64)
+	       if test -z "$ac_arch" || test "$ac_arch" = "$ac_word"; then
+		 ac_arch=$ac_word
+	       else
+		 ac_cv_c_bigendian=universal
+		 break
+	       fi
+	   esac
+	   ac_prev=
+	 elif test "x$ac_word" = "x-arch"; then
+	   ac_prev=arch
+	 fi
+       done
 fi
     if test $ac_cv_c_bigendian = unknown; then
       # See if sys/param.h defines the BYTE_ORDER macro.
-/* confdefs.h.  */
-_ACEOF
 	     #include <sys/param.h>
@@ -4430,30 +3824,9 @@ main ()
   return 0;
 _ACEOF
-esac
-  ac_status=$?
   # It does; now see whether it defined to BIG_ENDIAN or not.
-/* confdefs.h.  */
-_ACEOF
@@ -4469,49 +3842,18 @@ main ()
   return 0;
 _ACEOF
-esac
-  ac_status=$?
+if ac_fn_c_try_compile "$LINENO"; then :
   ac_cv_c_bigendian=yes
 else
-	ac_cv_c_bigendian=no
+  ac_cv_c_bigendian=no
 fi
-else
 fi
     fi
       # See if <limits.h> defines _LITTLE_ENDIAN or _BIG_ENDIAN (e.g., Solaris).
-/* confdefs.h.  */
-_ACEOF
 #include <limits.h>
@@ -4526,30 +3868,9 @@ main ()
   return 0;
 _ACEOF
-esac
-  ac_status=$?
   # It does; now see whether it defined to _BIG_ENDIAN or not.
-/* confdefs.h.  */
-_ACEOF
 #include <limits.h>
@@ -4564,51 +3885,20 @@ main ()
   return 0;
 _ACEOF
-esac
-  ac_status=$?
 else
 fi
-else
 fi
     fi
       # Compile a test program.
   # Try to guess by grepping values from an object file.
-/* confdefs.h.  */
-_ACEOF
 short int ascii_mm[] =
 		  { 0x4249, 0x4765, 0x6E44, 0x6961, 0x6E53, 0x7953, 0 };
@@ -4634,24 +3924,7 @@ return use_ascii (foo) == use_ebcdic (foo);
   return 0;
 _ACEOF
-esac
-  ac_status=$?
   if grep BIGenDianSyS conftest.$ac_objext >/dev/null; then
 	    fi
@@ -4663,20 +3936,10 @@ $as_echo "$ac_try_echo") >&5
 	      fi
 	    fi
-else
 fi
 else
-/* confdefs.h.  */
-_ACEOF
 int
@@ -4696,79 +3959,41 @@ main ()
   return 0;
 _ACEOF
-esac
-  ac_status=$?
-esac
-  ac_status=$?
 else
-ac_cv_c_bigendian=yes
+  ac_cv_c_bigendian=yes
 fi
 fi
     fi
 fi
-{ $as_echo "$as_me:$LINENO: result: $ac_cv_c_bigendian" >&5
+{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_c_bigendian" >&5
 $as_echo "$ac_cv_c_bigendian" >&6; }
  case $ac_cv_c_bigendian in #(
    yes)
-     cat >>confdefs.h <<\_ACEOF
-#define WORDS_BIGENDIAN 1
-_ACEOF
+     $as_echo "#define WORDS_BIGENDIAN 1" >>confdefs.h
    no)
    universal)
-#define AC_APPLE_UNIVERSAL_BUILD 1
-_ACEOF
+$as_echo "#define AC_APPLE_UNIVERSAL_BUILD 1" >>confdefs.h
-     { { $as_echo "$as_me:$LINENO: error: unknown endianness
- presetting ac_cv_c_bigendian=no (or yes) will help" >&5
-$as_echo "$as_me: error: unknown endianness
- presetting ac_cv_c_bigendian=no (or yes) will help" >&2;}
-   { (exit 1); exit 1; }; } ;;
+     as_fn_error $? "unknown endianness
+ presetting ac_cv_c_bigendian=no (or yes) will help" "$LINENO" 5 ;;
  esac
 old_cflags="$CFLAGS"
 CFLAGS="$CFLAGS -D_FILE_OFFSET_BITS=64 -D_LARGEFILE64_SOURCE"
-{ $as_echo "$as_me:$LINENO: checking for struct aiocb64" >&5
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for struct aiocb64" >&5
 $as_echo_n "checking for struct aiocb64... " >&6; }
-/* confdefs.h.  */
-_ACEOF
+cat confdefs.h - <<_ACEOF >conftest.$ac_ext
     #include <aio.h>
@@ -4781,52 +4006,25 @@ main ()
   return 0;
 _ACEOF
-esac
-  ac_status=$?
-#define HAVE_AIOCB64 1
-_ACEOF
+$as_echo "#define HAVE_AIOCB64 1" >>confdefs.h
 else
 fi
 CFLAGS="$old_cflags"
-{ $as_echo "$as_me:$LINENO: checking for off64_t" >&5
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for off64_t" >&5
 $as_echo_n "checking for off64_t... " >&6; }
-/* confdefs.h.  */
-_ACEOF
     #include <stdio.h>
@@ -4853,182 +4051,25 @@ main ()
   return 0;
 _ACEOF
-esac
-  ac_status=$?
-#define HAVE_OFF64_T 1
-_ACEOF
+$as_echo "#define HAVE_OFF64_T 1" >>confdefs.h
 else
 fi
 for ac_header in mntent.h sys/mount.h
-do
-fi
-else
-/* confdefs.h.  */
-_ACEOF
-_ACEOF
-esac
-  ac_status=$?
-else
-fi
-/* confdefs.h.  */
-_ACEOF
-_ACEOF
-esac
-  ac_status=$?
-       }; then
-else
-fi
-  yes:no: )
-  no:yes:* )
-esac
-else
-fi
-fi
+do :
+ac_fn_c_check_header_mongrel "$LINENO" "$ac_header" "$as_ac_Header" "$ac_includes_default"
 _ACEOF
@@ -5063,13 +4104,9 @@ prefix=$savePrefix
 exec_prefix=$saveExecprefix
 # determine if the MPI library includes MPI-IO functions or not
-{ $as_echo "$as_me:$LINENO: checking for MPI-IO support in MPI" >&5
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for MPI-IO support in MPI" >&5
 $as_echo_n "checking for MPI-IO support in MPI... " >&6; }
-/* confdefs.h.  */
-_ACEOF
 #include <mpi.h>
 int
@@ -5087,53 +4124,22 @@ main ()
   return 0;
 _ACEOF
-esac
-  ac_status=$?
-       }; then
 else
-	{ { $as_echo "$as_me:$LINENO: error: Darshan requires a version of MPI with MPI-IO support" >&5
-$as_echo "$as_me: error: Darshan requires a version of MPI with MPI-IO support" >&2;}
+  as_fn_error $? "Darshan requires a version of MPI with MPI-IO support" "$LINENO" 5
 fi
 # At some point MPI-IO converted most API functions to be const correct.  We
 # need to test for this to determine how to define MPI-IO wrappers in
 # Darshan.  First we try compiling without cost qualifiers.
-{ $as_echo "$as_me:$LINENO: checking for MPI-IO prototypes without const qualifier" >&5
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for MPI-IO prototypes without const qualifier" >&5
 $as_echo_n "checking for MPI-IO prototypes without const qualifier... " >&6; }
-/* confdefs.h.  */
-_ACEOF
     #include <mpi.h>
@@ -5149,42 +4155,18 @@ main ()
   return 0;
 _ACEOF
-esac
-  ac_status=$?
 else
     # unable to compile without const qualifiers.  Let's try again with
     # const qualifiers.
-    { $as_echo "$as_me:$LINENO: checking for MPI-IO prototypes with const qualifier" >&5
+    { $as_echo "$as_me:${as_lineno-$LINENO}: checking for MPI-IO prototypes with const qualifier" >&5
 $as_echo_n "checking for MPI-IO prototypes with const qualifier... " >&6; }
-/* confdefs.h.  */
-_ACEOF
+    cat confdefs.h - <<_ACEOF >conftest.$ac_ext
         #include <mpi.h>
@@ -5200,42 +4182,16 @@ main ()
   return 0;
 _ACEOF
-esac
-  ac_status=$?
-#define HAVE_MPIIO_CONST 1
-_ACEOF
-else
+$as_echo "#define HAVE_MPIIO_CONST 1" >>confdefs.h
 fi
 fi
 # determine if mpicc can create shared libraries that use MPI functions
@@ -5243,13 +4199,9 @@ old_cflags="$CFLAGS"
 CFLAGS="$CFLAGS -shared -fpic -DPIC"
 old_libs="$LIBS"
 LIBS="$LIBS -ldl"
-{ $as_echo "$as_me:$LINENO: checking for shared libraries in MPI" >&5
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for shared libraries in MPI" >&5
 $as_echo_n "checking for shared libraries in MPI... " >&6; }
-/* confdefs.h.  */
-_ACEOF
 #include <mpi.h>
 int
@@ -5263,44 +4215,19 @@ main ()
   return 0;
 _ACEOF
-esac
-  ac_status=$?
-       }; then
 else
-    { $as_echo "$as_me:$LINENO: WARNING: mpicc doesn't support shared objects; disabling LD_PRELOAD library" >&5
+    { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: mpicc doesn't support shared objects; disabling LD_PRELOAD library" >&5
 $as_echo "$as_me: WARNING: mpicc doesn't support shared objects; disabling LD_PRELOAD library" >&2;}
 fi
 LIBS="$old_libs"
@@ -5309,134 +4236,35 @@ LIBS="$old_libs"
 # for MPI 1.x implementations that did not use generalized requests yet in
 # MPI-IO.  Later MPI implementations might typedef MPIO_Request to MPI_Request
 # so there is no  harm in using the former if it is available there.
-{ $as_echo "$as_me:$LINENO: checking for MPIO_Request" >&5
-$as_echo_n "checking for MPIO_Request... " >&6; }
-if test "${ac_cv_type_MPIO_Request+set}" = set; then
-else
-  ac_cv_type_MPIO_Request=no
-/* confdefs.h.  */
-_ACEOF
-#include <mpi.h>
-int
-main ()
-if (sizeof (MPIO_Request))
-       return 0;
-  return 0;
-_ACEOF
-esac
-  ac_status=$?
-/* confdefs.h.  */
-_ACEOF
-#include <mpi.h>
-int
-main ()
-if (sizeof ((MPIO_Request)))
-	  return 0;
-  return 0;
-_ACEOF
-esac
-  ac_status=$?
-else
-	ac_cv_type_MPIO_Request=yes
-fi
-else
-fi
+ac_fn_c_check_type "$LINENO" "MPIO_Request" "ac_cv_type_MPIO_Request" "#include <mpi.h>
+if test "x$ac_cv_type_MPIO_Request" = xyes; then :
-fi
-{ $as_echo "$as_me:$LINENO: result: $ac_cv_type_MPIO_Request" >&5
-$as_echo "$ac_cv_type_MPIO_Request" >&6; }
-if test "x$ac_cv_type_MPIO_Request" = x""yes; then
-#define __D_MPI_REQUEST MPIO_Request
-_ACEOF
+$as_echo "#define __D_MPI_REQUEST MPIO_Request" >>confdefs.h
 else
-#define __D_MPI_REQUEST MPI_Request
-_ACEOF
+$as_echo "#define __D_MPI_REQUEST MPI_Request" >>confdefs.h
 fi
 # attempt to detect librarly naming convention in mpi compiler script
-{ $as_echo "$as_me:$LINENO: checking for old (pre-3.1.1) style MPICH library naming convention" >&5
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for old (pre-3.1.1) style MPICH library naming convention" >&5
 $as_echo_n "checking for old (pre-3.1.1) style MPICH library naming convention... " >&6; }
-if $CC -show foo.c -o foo |grep lmpich >& /dev/null; then
+if $CC -show foo.c -o foo |grep lmpich >& /dev/null; then :
     MPICH_LIB_OLD=1
 else
     MPICH_LIB_OLD=0
 fi
-DARSHAN_VERSION="2.3.1-pre2"
+DARSHAN_VERSION="2.3.1"
@@ -5475,13 +4303,13 @@ _ACEOF
     case $ac_val in #(
     *${as_nl}*)
       case $ac_var in #(
-      *_cv_*) { $as_echo "$as_me:$LINENO: WARNING: cache variable $ac_var contains a newline" >&5
+      *_cv_*) { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: cache variable $ac_var contains a newline" >&5
 $as_echo "$as_me: WARNING: cache variable $ac_var contains a newline" >&2;} ;;
       esac
       case $ac_var in #(
       _ | IFS | as_nl) ;; #(
       BASH_ARGV | BASH_SOURCE) eval $ac_var= ;; #(
-      *) $as_unset $ac_var ;;
+      *) { eval $ac_var=; unset $ac_var;} ;;
       esac ;;
     esac
   done
@@ -5489,8 +4317,8 @@ $as_echo "$as_me: WARNING: cache variable $ac_var contains a newline" >&2;} ;;
   (set) 2>&1 |
     case $as_nl`(ac_space=' '; set) 2>&1` in #(
     *${as_nl}ac_space=\ *)
-      # `set' does not quote correctly, so add quotes (double-quote
-      # substitution turns \\\\ into \\, and sed turns \\ into \).
+      # `set' does not quote correctly, so add quotes: double-quote
+      # substitution turns \\\\ into \\, and sed turns \\ into \.
       sed -n \
 	"s/'/'\\\\''/g;
 	  s/^\\([_$as_cr_alnum]*_cv_[_$as_cr_alnum]*\\)=\\(.*\\)/\\1='\\2'/p"
@@ -5512,12 +4340,23 @@ $as_echo "$as_me: WARNING: cache variable $ac_var contains a newline" >&2;} ;;
      :end' >>confcache
 if diff "$cache_file" confcache >/dev/null 2>&1; then :; else
   if test -w "$cache_file"; then
-    test "x$cache_file" != "x/dev/null" &&
-      { $as_echo "$as_me:$LINENO: updating cache $cache_file" >&5
+    if test "x$cache_file" != "x/dev/null"; then
+      { $as_echo "$as_me:${as_lineno-$LINENO}: updating cache $cache_file" >&5
 $as_echo "$as_me: updating cache $cache_file" >&6;}
-    cat confcache >$cache_file
+      if test ! -f "$cache_file" || test -h "$cache_file"; then
+	cat confcache >"$cache_file"
+      else
+        case $cache_file in #(
+	  mv -f confcache "$cache_file"$$ &&
+	  mv -f "$cache_file"$$ "$cache_file" ;; #(
+	  mv -f confcache "$cache_file" ;;
+	esac
+      fi
+    fi
   else
-    { $as_echo "$as_me:$LINENO: not updating unwritable cache $cache_file" >&5
+    { $as_echo "$as_me:${as_lineno-$LINENO}: not updating unwritable cache $cache_file" >&5
 $as_echo "$as_me: not updating unwritable cache $cache_file" >&6;}
   fi
 fi
@@ -5531,14 +4370,15 @@ DEFS=-DHAVE_CONFIG_H
 ac_libobjs=
 ac_ltlibobjs=
+U=
 for ac_i in : $LIBOBJS; do test "x$ac_i" = x: && continue
   # 1. Remove the extension, and $U if already installed.
   ac_script='s/\$U\././;s/\.o$//;s/\.obj$//'
   ac_i=`$as_echo "$ac_i" | sed "$ac_script"`
   # 2. Prepend LIBOBJDIR.  When used with automake>=1.10 LIBOBJDIR
   #    will be set to the directory where LIBOBJS objects are built.
-  ac_libobjs="$ac_libobjs \${LIBOBJDIR}$ac_i\$U.$ac_objext"
-  ac_ltlibobjs="$ac_ltlibobjs \${LIBOBJDIR}$ac_i"'$U.lo'
+  as_fn_append ac_libobjs " \${LIBOBJDIR}$ac_i\$U.$ac_objext"
+  as_fn_append ac_ltlibobjs " \${LIBOBJDIR}$ac_i"'$U.lo'
 done
 LIBOBJS=$ac_libobjs
@@ -5547,13 +4387,14 @@ LTLIBOBJS=$ac_ltlibobjs
-: ${CONFIG_STATUS=./config.status}
+: "${CONFIG_STATUS=./config.status}"
 ac_write_fail=0
 ac_clean_files_save=$ac_clean_files
 ac_clean_files="$ac_clean_files $CONFIG_STATUS"
-{ $as_echo "$as_me:$LINENO: creating $CONFIG_STATUS" >&5
+{ $as_echo "$as_me:${as_lineno-$LINENO}: creating $CONFIG_STATUS" >&5
 $as_echo "$as_me: creating $CONFIG_STATUS" >&6;}
-cat >$CONFIG_STATUS <<_ACEOF || ac_write_fail=1
+as_write_fail=0
+cat >$CONFIG_STATUS <<_ASEOF || as_write_fail=1
 #! $SHELL
 # Generated by $as_me.
 # Run this file to recreate the current configuration.
@@ -5563,17 +4404,18 @@ cat >$CONFIG_STATUS <<_ACEOF || ac_write_fail=1
 debug=false
 ac_cs_recheck=false
 ac_cs_silent=false
-SHELL=\${CONFIG_SHELL-$SHELL}
-_ACEOF
-cat >>$CONFIG_STATUS <<\_ACEOF || ac_write_fail=1
-## M4sh Initialization.  ##
+SHELL=\${CONFIG_SHELL-$SHELL}
+export SHELL
+_ASEOF
+cat >>$CONFIG_STATUS <<\_ASEOF || as_write_fail=1
+## M4sh Initialization. ##
 # Be more Bourne compatible
 DUALCASE=1; export DUALCASE # for MKS sh
-if test -n "${ZSH_VERSION+set}" && (emulate sh) >/dev/null 2>&1; then
+if test -n "${ZSH_VERSION+set}" && (emulate sh) >/dev/null 2>&1; then :
   emulate sh
   NULLCMD=:
   # Pre-4.2 versions of Zsh do word splitting on ${1+"$@"}, which
@@ -5581,23 +4423,15 @@ if test -n "${ZSH_VERSION+set}" && (emulate sh) >/dev/null 2>&1; then
   alias -g '${1+"$@"}'='"$@"'
   setopt NO_GLOB_SUBST
 else
-  case `(set -o) 2>/dev/null` in
-  *posix*) set -o posix ;;
+  case `(set -o) 2>/dev/null` in #(
+  *posix*) :
+    set -o posix ;; #(
 esac
 fi
-# PATH needs CR
-# Avoid depending upon Character Ranges.
-as_cr_letters='abcdefghijklmnopqrstuvwxyz'
-as_cr_LETTERS='ABCDEFGHIJKLMNOPQRSTUVWXYZ'
-as_cr_Letters=$as_cr_letters$as_cr_LETTERS
-as_cr_digits='0123456789'
-as_cr_alnum=$as_cr_Letters$as_cr_digits
 as_nl='
 export as_nl
@@ -5605,7 +4439,13 @@ export as_nl
 as_echo='\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\'
 as_echo=$as_echo$as_echo$as_echo$as_echo$as_echo
 as_echo=$as_echo$as_echo$as_echo$as_echo$as_echo$as_echo
-if (test "X`printf %s $as_echo`" = "X$as_echo") 2>/dev/null; then
+# Prefer a ksh shell builtin over an external printf program on Solaris,
+# but without wasting forks for bash or zsh.
+if test -z "$BASH_VERSION$ZSH_VERSION" \
+    && (test "X`print -r -- $as_echo`" = "X$as_echo") 2>/dev/null; then
+  as_echo='print -r --'
+  as_echo_n='print -rn --'
+elif (test "X`printf %s $as_echo`" = "X$as_echo") 2>/dev/null; then
   as_echo='printf %s\n'
   as_echo_n='printf %s'
 else
@@ -5616,7 +4456,7 @@ else
     as_echo_body='eval expr "X$1" : "X\\(.*\\)"'
     as_echo_n_body='eval
       arg=$1;
-      case $arg in
+      case $arg in #(
       *"$as_nl"*)
 	expr "X$arg" : "X\\(.*\\)$as_nl";
 	arg=`expr "X$arg" : ".*$as_nl\\(.*\\)"`;;
@@ -5639,13 +4479,6 @@ if test "${PATH_SEPARATOR+set}" != set; then
 fi
-# Support unset when possible.
-if ( (MAIL=60; unset MAIL) || exit) >/dev/null 2>&1; then
-  as_unset=unset
-else
-  as_unset=false
-fi
 # IFS
 # We need space, tab and new line, in precisely that order.  Quoting is
@@ -5655,15 +4488,16 @@ fi
 IFS=" ""	$as_nl"
 # Find who we are.  Look in the path if we contain no directory separator.
-case $0 in
+as_myself=
+case $0 in #((
   *[\\/]* ) as_myself=$0 ;;
   *) as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
 for as_dir in $PATH
 do
   IFS=$as_save_IFS
-  test -r "$as_dir/$0" && as_myself=$as_dir/$0 && break
-done
+    test -r "$as_dir/$0" && as_myself=$as_dir/$0 && break
+  done
 IFS=$as_save_IFS
@@ -5675,12 +4509,16 @@ if test "x$as_myself" = x; then
 fi
 if test ! -f "$as_myself"; then
   $as_echo "$as_myself: error: cannot find myself; rerun with an absolute file name" >&2
+  exit 1
 fi
-# Work around bugs in pre-3.0 UWIN ksh.
-for as_var in ENV MAIL MAILPATH
-do ($as_unset $as_var) >/dev/null 2>&1 && $as_unset $as_var
+# Unset variables that we do not need and which cause bugs (e.g. in
+# pre-3.0 UWIN ksh).  But do not cause bugs in bash 2.01; the "|| exit 1"
+# suppresses any "Segmentation fault" message there.  '((' could
+# trigger a bug in pdksh 5.2.14.
+for as_var in BASH_ENV ENV MAIL MAILPATH
+do eval test x\${$as_var+set} = xset \
+  && ( (unset $as_var) || exit 1) >/dev/null 2>&1 && unset $as_var || :
 done
 PS1='$ '
 PS2='> '
@@ -5692,7 +4530,89 @@ export LC_ALL
 LANGUAGE=C
 export LANGUAGE
-# Required to use basename.
+# CDPATH.
+(unset CDPATH) >/dev/null 2>&1 && unset CDPATH
+# as_fn_error STATUS ERROR [LINENO LOG_FD]
+# Output "`basename $0`: error: ERROR" to stderr. If LINENO and LOG_FD are
+# provided, also output the error to LOG_FD, referencing LINENO. Then exit the
+# script with STATUS, using 1 if that was 0.
+as_fn_error ()
+  as_status=$1; test $as_status -eq 0 && as_status=1
+  if test "$4"; then
+    as_lineno=${as_lineno-"$3"} as_lineno_stack=as_lineno_stack=$as_lineno_stack
+    $as_echo "$as_me:${as_lineno-$LINENO}: error: $2" >&$4
+  fi
+  $as_echo "$as_me: error: $2" >&2
+  as_fn_exit $as_status
+} # as_fn_error
+# as_fn_set_status STATUS
+# Set $? to STATUS, without forking.
+as_fn_set_status ()
+  return $1
+} # as_fn_set_status
+# as_fn_exit STATUS
+# Exit the shell with STATUS, even in a "trap 0" or "set -e" context.
+as_fn_exit ()
+  set +e
+  as_fn_set_status $1
+  exit $1
+} # as_fn_exit
+# as_fn_unset VAR
+# Portably unset VAR.
+as_fn_unset ()
+  { eval $1=; unset $1;}
+as_unset=as_fn_unset
+# as_fn_append VAR VALUE
+# Append the text in VALUE to the end of the definition contained in VAR. Take
+# advantage of any shell optimizations that allow amortized linear growth over
+# repeated appends, instead of the typical quadratic growth present in naive
+# implementations.
+if (eval "as_var=1; as_var+=2; test x\$as_var = x12") 2>/dev/null; then :
+  eval 'as_fn_append ()
+    eval $1+=\$2
+else
+  as_fn_append ()
+    eval $1=\$$1\$2
+fi # as_fn_append
+# as_fn_arith ARG...
+# Perform arithmetic evaluation on the ARGs, and store the result in the
+# global $as_val. Take advantage of shells that can avoid forks. The arguments
+# must be portable across $(()) and expr.
+if (eval "test \$(( 1 + 1 )) = 2") 2>/dev/null; then :
+  eval 'as_fn_arith ()
+    as_val=$(( $* ))
+else
+  as_fn_arith ()
+    as_val=`expr "$@" || test $? -eq 1`
+fi # as_fn_arith
 if expr a : '\(a\)' >/dev/null 2>&1 &&
    test "X`expr 00001 : '.*\(...\)'`" = X001; then
   as_expr=expr
@@ -5706,8 +4626,12 @@ else
   as_basename=false
 fi
+if (as_dir=`dirname -- /` && test "X$as_dir" = X/) >/dev/null 2>&1; then
+  as_dirname=dirname
+else
+  as_dirname=false
+fi
-# Name of the executable.
 as_me=`$as_basename -- "$0" ||
 $as_expr X/"$0" : '.*/\([^/][^/]*\)/*$' \| \
 	 X"$0" : 'X\(//\)$' \| \
@@ -5727,76 +4651,25 @@ $as_echo X/"$0" |
 	  s/.*/./; q'`
-# CDPATH.
-$as_unset CDPATH
-  as_lineno_1=$LINENO
-  as_lineno_2=$LINENO
-  test "x$as_lineno_1" != "x$as_lineno_2" &&
-  test "x`expr $as_lineno_1 + 1`" = "x$as_lineno_2" || {
-  # Create $as_me.lineno as a copy of $as_myself, but with $LINENO
-  # uniformly replaced by the line number.  The first 'sed' inserts a
-  # line-number line after each line using $LINENO; the second 'sed'
-  # does the real work.  The second script uses 'N' to pair each
-  # line-number line with the line containing $LINENO, and appends
-  # trailing '-' during substitution so that $LINENO is not a special
-  # case at line end.
-  # (Raja R Harinath suggested sed '=', and Paul Eggert wrote the
-  # scripts with optimization help from Paolo Bonzini.  Blame Lee
-  # E. McMahon (1931-1989) for sed's syntax.  :-)
-  sed -n '
-    p
-    /[$]LINENO/=
-  ' <$as_myself |
-    sed '
-      s/[$]LINENO.*/&-/
-      t lineno
-      b
-      :lineno
-      N
-      :loop
-      s/[$]LINENO\([^'$as_cr_alnum'_].*\n\)\(.*\)/\2\1\2/
-      t loop
-      s/-\n.*//
-    ' >$as_me.lineno &&
-  chmod +x "$as_me.lineno" ||
-    { $as_echo "$as_me: error: cannot create $as_me.lineno; rerun with a POSIX shell" >&2
-  # Don't try to exec as it changes $[0], causing all sort of problems
-  # (the dirname of $[0] is not the place where we might find the
-  # original and so on.  Autoconf is especially sensitive to this).
-  . "./$as_me.lineno"
-  # Exit status is that of the last command.
-  exit
-if (as_dir=`dirname -- /` && test "X$as_dir" = X/) >/dev/null 2>&1; then
-  as_dirname=dirname
-else
-  as_dirname=false
-fi
+# Avoid depending upon Character Ranges.
+as_cr_letters='abcdefghijklmnopqrstuvwxyz'
+as_cr_LETTERS='ABCDEFGHIJKLMNOPQRSTUVWXYZ'
+as_cr_Letters=$as_cr_letters$as_cr_LETTERS
+as_cr_digits='0123456789'
+as_cr_alnum=$as_cr_Letters$as_cr_digits
 ECHO_C= ECHO_N= ECHO_T=
-case `echo -n x` in
+case `echo -n x` in #(((((
 -n*)
-  case `echo 'x\c'` in
+  case `echo 'xy\c'` in
   *c*) ECHO_T='	';;	# ECHO_T is single tab character.
-  *)   ECHO_C='\c';;
+  xy)  ECHO_C='\c';;
+  *)   echo `echo ksh88 bug on AIX 6.1` > /dev/null
+       ECHO_T='	';;
   esac;;
   ECHO_N='-n';;
 esac
-if expr a : '\(a\)' >/dev/null 2>&1 &&
-   test "X`expr 00001 : '.*\(...\)'`" = X001; then
-  as_expr=expr
-else
-  as_expr=false
-fi
 rm -f conf$$ conf$$.exe conf$$.file
 if test -d conf$$.dir; then
@@ -5811,49 +4684,85 @@ if (echo >conf$$.file) 2>/dev/null; then
     # ... but there are two gotchas:
     # 1) On MSYS, both `ln -s file dir' and `ln file dir' fail.
     # 2) DJGPP < 2.04 has no symlinks; `ln -s' creates a wrapper executable.
-    # In both cases, we have to default to `cp -p'.
+    # In both cases, we have to default to `cp -pR'.
     ln -s conf$$.file conf$$.dir 2>/dev/null && test ! -f conf$$.exe ||
-      as_ln_s='cp -p'
+      as_ln_s='cp -pR'
   elif ln conf$$.file conf$$ 2>/dev/null; then
     as_ln_s=ln
   else
-    as_ln_s='cp -p'
+    as_ln_s='cp -pR'
   fi
 else
-  as_ln_s='cp -p'
+  as_ln_s='cp -pR'
 fi
 rm -f conf$$ conf$$.exe conf$$.dir/conf$$.file conf$$.file
 rmdir conf$$.dir 2>/dev/null
+# as_fn_mkdir_p
+# Create "$as_dir" as a directory, including parents if necessary.
+as_fn_mkdir_p ()
+  case $as_dir in #(
+  -*) as_dir=./$as_dir;;
+  esac
+  test -d "$as_dir" || eval $as_mkdir_p || {
+    as_dirs=
+    while :; do
+      *\'*) as_qdir=`$as_echo "$as_dir" | sed "s/'/'\\\\\\\\''/g"`;; #'(
+      *) as_qdir=$as_dir;;
+      esac
+      as_dirs="'$as_qdir' $as_dirs"
+      as_dir=`$as_dirname -- "$as_dir" ||
+$as_expr X"$as_dir" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \
+	 X"$as_dir" : 'X\(//\)[^/]' \| \
+	 X"$as_dir" : 'X\(//\)$' \| \
+	 X"$as_dir" : 'X\(/\)' \| . 2>/dev/null ||
+$as_echo X"$as_dir" |
+    sed '/^X\(.*[^/]\)\/\/*[^/][^/]*\/*$/{
+	    s//\1/
+	    q
+	  /^X\(\/\/\)[^/].*/{
+	    s//\1/
+	    q
+	  /^X\(\/\/\)$/{
+	    s//\1/
+	    q
+	  /^X\(\/\).*/{
+	    s//\1/
+	    q
+	  s/.*/./; q'`
+      test -d "$as_dir" && break
+    done
+    test -z "$as_dirs" || eval "mkdir $as_dirs"
+  } || test -d "$as_dir" || as_fn_error $? "cannot create directory $as_dir"
+} # as_fn_mkdir_p
 if mkdir -p . 2>/dev/null; then
-  as_mkdir_p=:
+  as_mkdir_p='mkdir -p "$as_dir"'
 else
   test -d ./-p && rmdir ./-p
   as_mkdir_p=false
 fi
-if test -x / >/dev/null 2>&1; then
-  as_test_x='test -x'
-else
-  if ls -dL / >/dev/null 2>&1; then
-    as_ls_L_option=L
-  else
-    as_ls_L_option=
-  fi
-  as_test_x='
-    eval sh -c '\''
-      if test -d "$1"; then
-	test -d "$1/.";
-      else
-	case $1 in
-	-*)set "./$1";;
-	esac;
-	case `ls -ld'$as_ls_L_option' "$1" 2>/dev/null` in
-	???[sx]*):;;*)false;;esac;fi
-    '\'' sh
-fi
-as_executable_p=$as_test_x
+# as_fn_executable_p FILE
+# Test if FILE is an executable regular file.
+as_fn_executable_p ()
+  test -f "$1" && test -x "$1"
+} # as_fn_executable_p
+as_test_x='test -x'
+as_executable_p=as_fn_executable_p
 # Sed expression to map a string onto a valid CPP name.
 as_tr_cpp="eval sed 'y%*$as_cr_letters%P$as_cr_LETTERS%;s%[^_$as_cr_alnum]%_%g'"
@@ -5863,13 +4772,19 @@ as_tr_sh="eval sed 'y%*+%pp%;s%[^_$as_cr_alnum]%_%g'"
 exec 6>&1
+## Main body of $CONFIG_STATUS script. ##
+_ASEOF
+test $as_write_fail = 0 && chmod +x $CONFIG_STATUS || ac_write_fail=1
-# Save the log message, to keep $[0] and so on meaningful, and to
+cat >>$CONFIG_STATUS <<\_ACEOF || ac_write_fail=1
+# Save the log message, to keep $0 and so on meaningful, and to
 # report actual input values of CONFIG_FILES etc. instead of their
 # values after options handling.
 ac_log="
-This file was extended by darshan-runtime $as_me 2.3.1-pre2, which was
-generated by GNU Autoconf 2.63.  Invocation command line was
+This file was extended by darshan-runtime $as_me 2.3.1, which was
+generated by GNU Autoconf 2.69.  Invocation command line was
   CONFIG_FILES    = $CONFIG_FILES
   CONFIG_HEADERS  = $CONFIG_HEADERS
@@ -5900,13 +4815,15 @@ _ACEOF
 ac_cs_usage="\
-\`$as_me' instantiates files from templates according to the
-current configuration.
+\`$as_me' instantiates files and other configuration actions
+from templates according to the current configuration.  Unless the files
+and actions are specified as TAGs, all are instantiated by default.
-Usage: $0 [OPTION]... [FILE]...
+Usage: $0 [OPTION]... [TAG]...
   -h, --help       print this help, then exit
   -V, --version    print version number and configuration settings, then exit
+      --config     print configuration, then exit
   -q, --quiet, --silent
                    do not print progress messages
   -d, --debug      don't remove temporary files
@@ -5922,16 +4839,17 @@ $config_files
 Configuration headers:
 $config_headers
-Report bugs to <bug-autoconf at gnu.org>."
+Report bugs to the package provider."
 _ACEOF
 cat >>$CONFIG_STATUS <<_ACEOF || ac_write_fail=1
+ac_cs_config="`$as_echo "$ac_configure_args" | sed 's/^ //; s/[\\""\`\$]/\\\\&/g'`"
 ac_cs_version="\\
-darshan-runtime config.status 2.3.1-pre2
-configured by $0, generated by GNU Autoconf 2.63,
-  with options \\"`$as_echo "$ac_configure_args" | sed 's/^ //; s/[\\""\`\$]/\\\\&/g'`\\"
+darshan-runtime config.status 2.3.1
+configured by $0, generated by GNU Autoconf 2.69,
+  with options \\"\$ac_cs_config\\"
-Copyright (C) 2008 Free Software Foundation, Inc.
+Copyright (C) 2012 Free Software Foundation, Inc.
 This config.status script is free software; the Free Software Foundation
 gives unlimited permission to copy, distribute and modify it."
@@ -5947,11 +4865,16 @@ ac_need_defaults=:
 while test $# != 0
 do
   case $1 in
     ac_option=`expr "X$1" : 'X\([^=]*\)='`
     ac_optarg=`expr "X$1" : 'X[^=]*=\(.*\)'`
     ac_shift=:
+    ac_option=`expr "X$1" : 'X\([^=]*\)='`
+    ac_optarg=
+    ac_shift=:
     ac_option=$1
     ac_optarg=$2
@@ -5965,27 +4888,29 @@ do
     ac_cs_recheck=: ;;
   --version | --versio | --versi | --vers | --ver | --ve | --v | -V )
     $as_echo "$ac_cs_version"; exit ;;
+  --config | --confi | --conf | --con | --co | --c )
+    $as_echo "$ac_cs_config"; exit ;;
   --debug | --debu | --deb | --de | --d | -d )
     debug=: ;;
   --file | --fil | --fi | --f )
     $ac_shift
     case $ac_optarg in
     *\'*) ac_optarg=`$as_echo "$ac_optarg" | sed "s/'/'\\\\\\\\''/g"` ;;
+    '') as_fn_error $? "missing file argument" ;;
     esac
-    CONFIG_FILES="$CONFIG_FILES '$ac_optarg'"
+    as_fn_append CONFIG_FILES " '$ac_optarg'"
     ac_need_defaults=false;;
   --header | --heade | --head | --hea )
     $ac_shift
     case $ac_optarg in
     esac
-    CONFIG_HEADERS="$CONFIG_HEADERS '$ac_optarg'"
+    as_fn_append CONFIG_HEADERS " '$ac_optarg'"
   --he | --h)
     # Conflict between --help and --header
-    { $as_echo "$as_me: error: ambiguous option: $1
-Try \`$0 --help' for more information." >&2
-   { (exit 1); exit 1; }; };;
+    as_fn_error $? "ambiguous option: \`$1'
+Try \`$0 --help' for more information.";;
   --help | --hel | -h )
     $as_echo "$ac_cs_usage"; exit ;;
   -q | -quiet | --quiet | --quie | --qui | --qu | --q \
@@ -5993,11 +4918,10 @@ Try \`$0 --help' for more information." >&2
     ac_cs_silent=: ;;
   # This is an error.
-  -*) { $as_echo "$as_me: error: unrecognized option: $1
+  -*) as_fn_error $? "unrecognized option: \`$1'
+Try \`$0 --help' for more information." ;;
-  *) ac_config_targets="$ac_config_targets $1"
+  *) as_fn_append ac_config_targets " $1"
      ac_need_defaults=false ;;
   esac
@@ -6014,7 +4938,7 @@ fi
 _ACEOF
 if \$ac_cs_recheck; then
-  set X '$SHELL' '$0' $ac_configure_args \$ac_configure_extra_args --no-create --no-recursion
+  set X $SHELL '$0' $ac_configure_args \$ac_configure_extra_args --no-create --no-recursion
   shift
   \$as_echo "running CONFIG_SHELL=$SHELL \$*" >&6
   CONFIG_SHELL='$SHELL'
@@ -6060,9 +4984,7 @@ do
     "share/mpi-profile/darshan-bg-cxx.conf") CONFIG_FILES="$CONFIG_FILES share/mpi-profile/darshan-bg-cxx.conf" ;;
     "share/mpi-profile/darshan-bg-f.conf") CONFIG_FILES="$CONFIG_FILES share/mpi-profile/darshan-bg-f.conf" ;;
-  *) { { $as_echo "$as_me:$LINENO: error: invalid argument: $ac_config_target" >&5
-$as_echo "$as_me: error: invalid argument: $ac_config_target" >&2;}
+  *) as_fn_error $? "invalid argument: \`$ac_config_target'" "$LINENO" 5;;
   esac
 done
@@ -6084,26 +5006,24 @@ fi
 # after its creation but before its name has been assigned to `$tmp'.
 $debug ||
-  tmp=
+  tmp= ac_tmp=
   trap 'exit_status=$?
-  { test -z "$tmp" || test ! -d "$tmp" || rm -fr "$tmp"; } && exit $exit_status
+  : "${ac_tmp:=$tmp}"
+  { test ! -d "$ac_tmp" || rm -fr "$ac_tmp"; } && exit $exit_status
 ' 0
-  trap '{ (exit 1); exit 1; }' 1 2 13 15
+  trap 'as_fn_exit 1' 1 2 13 15
 # Create a (secure) tmp directory for tmp files.
   tmp=`(umask 077 && mktemp -d "./confXXXXXX") 2>/dev/null` &&
-  test -n "$tmp" && test -d "$tmp"
+  test -d "$tmp"
   tmp=./conf$$-$RANDOM
   (umask 077 && mkdir "$tmp")
-   $as_echo "$as_me: cannot create a temporary directory in ." >&2
+} || as_fn_error $? "cannot create a temporary directory in ." "$LINENO" 5
+ac_tmp=$tmp
 # Set up the scripts for CONFIG_FILES section.
 # No need to generate them if there are no CONFIG_FILES.
@@ -6111,7 +5031,13 @@ $debug ||
 if test -n "$CONFIG_FILES"; then
-ac_cr='
+ac_cr=`echo X | tr X '\015'`
+# On cygwin, bash can eat \r inside `` if the user requested igncr.
+# But we know of no other shell where ac_cr would be empty at this
+# point, so we can use a bashism as a fallback.
+if test "x$ac_cr" = x; then
+  eval ac_cr=\$\'\\r\'
+fi
 ac_cs_awk_cr=`$AWK 'BEGIN { print "a\rb" }' </dev/null 2>/dev/null`
 if test "$ac_cs_awk_cr" = "a${ac_cr}b"; then
   ac_cs_awk_cr='\\r'
@@ -6119,7 +5045,7 @@ else
   ac_cs_awk_cr=$ac_cr
 fi
-echo 'BEGIN {' >"$tmp/subs1.awk" &&
+echo 'BEGIN {' >"$ac_tmp/subs1.awk" &&
 _ACEOF
@@ -6128,24 +5054,18 @@ _ACEOF
   echo "$ac_subst_vars" | sed 's/.*/&!$&$ac_delim/' &&
   echo "_ACEOF"
 } >conf$$subs.sh ||
-  { { $as_echo "$as_me:$LINENO: error: could not make $CONFIG_STATUS" >&5
-$as_echo "$as_me: error: could not make $CONFIG_STATUS" >&2;}
-ac_delim_num=`echo "$ac_subst_vars" | grep -c '$'`
+  as_fn_error $? "could not make $CONFIG_STATUS" "$LINENO" 5
+ac_delim_num=`echo "$ac_subst_vars" | grep -c '^'`
 ac_delim='%!_!# '
 for ac_last_try in false false false false false :; do
   . ./conf$$subs.sh ||
   ac_delim_n=`sed -n "s/.*$ac_delim\$/X/p" conf$$subs.awk | grep -c X`
   if test $ac_delim_n = $ac_delim_num; then
     break
   elif $ac_last_try; then
   else
     ac_delim="$ac_delim!$ac_delim _$ac_delim!! "
   fi
@@ -6153,7 +5073,7 @@ done
 rm -f conf$$subs.sh
-cat >>"\$tmp/subs1.awk" <<\\_ACAWK &&
+cat >>"\$ac_tmp/subs1.awk" <<\\_ACAWK &&
 _ACEOF
 sed -n '
 h
@@ -6167,7 +5087,7 @@ s/'"$ac_delim"'$//
 t delim
 :nl
 h
-s/\(.\{148\}\).*/\1/
+s/\(.\{148\}\)..*/\1/
 t more1
 s/["\\]/\\&/g; s/^/"/; s/$/\\n"\\/
 p
@@ -6181,7 +5101,7 @@ s/.\{148\}//
 t nl
 :delim
 h
 t more2
 s/["\\]/\\&/g; s/^/"/; s/$/"/
 p
@@ -6201,7 +5121,7 @@ t delim
 rm -f conf$$subs.awk
 _ACAWK
-cat >>"\$tmp/subs1.awk" <<_ACAWK &&
+cat >>"\$ac_tmp/subs1.awk" <<_ACAWK &&
   for (key in S) S_is_set[key] = 1
   FS = ""
@@ -6233,23 +5153,29 @@ if sed "s/$ac_cr//" < /dev/null > /dev/null 2>&1; then
   sed "s/$ac_cr\$//; s/$ac_cr/$ac_cs_awk_cr/g"
 else
   cat
-fi < "$tmp/subs1.awk" > "$tmp/subs.awk" \
-  || { { $as_echo "$as_me:$LINENO: error: could not setup config files machinery" >&5
-$as_echo "$as_me: error: could not setup config files machinery" >&2;}
+fi < "$ac_tmp/subs1.awk" > "$ac_tmp/subs.awk" \
+  || as_fn_error $? "could not setup config files machinery" "$LINENO" 5
 _ACEOF
-# VPATH may cause trouble with some makes, so we remove $(srcdir),
-# ${srcdir} and @srcdir@ from VPATH if srcdir is ".", strip leading and
+# VPATH may cause trouble with some makes, so we remove sole $(srcdir),
+# ${srcdir} and @srcdir@ entries from VPATH if srcdir is ".", strip leading and
 # trailing colons and then remove the whole line if VPATH becomes empty
 # (actually we leave an empty line to preserve line numbers).
 if test "x$srcdir" = x.; then
-  ac_vpsub='/^[	 ]*VPATH[	 ]*=/{
-s/:*\$(srcdir):*/:/
-s/:*\${srcdir}:*/:/
-s/:*@srcdir@:*/:/
-s/^\([^=]*=[	 ]*\):*/\1/
+  ac_vpsub='/^[	 ]*VPATH[	 ]*=[	 ]*/{
+h
+s///
+s/^/:/
+s/[	 ]*$/:/
+s/:\$(srcdir):/:/g
+s/:\${srcdir}:/:/g
+s/:@srcdir@:/:/g
+s/^:*//
 s/:*$//
+x
+s/\(=[	 ]*\).*/\1/
+G
+s/\n//
 s/^[^=]*=[	 ]*$//
 fi
@@ -6261,7 +5187,7 @@ fi # test -n "$CONFIG_FILES"
 # No need to generate them if there are no CONFIG_HEADERS.
 # This happens for instance with `./config.status Makefile'.
 if test -n "$CONFIG_HEADERS"; then
-cat >"$tmp/defines.awk" <<\_ACAWK ||
+cat >"$ac_tmp/defines.awk" <<\_ACAWK ||
 BEGIN {
 _ACEOF
@@ -6273,13 +5199,11 @@ _ACEOF
 # handling of long lines.
 ac_delim='%!_!# '
 for ac_last_try in false false :; do
-  ac_t=`sed -n "/$ac_delim/p" confdefs.h`
-  if test -z "$ac_t"; then
+  ac_tt=`sed -n "/$ac_delim/p" confdefs.h`
+  if test -z "$ac_tt"; then
     break
-    { { $as_echo "$as_me:$LINENO: error: could not make $CONFIG_HEADERS" >&5
-$as_echo "$as_me: error: could not make $CONFIG_HEADERS" >&2;}
+    as_fn_error $? "could not make $CONFIG_HEADERS" "$LINENO" 5
   else
   fi
@@ -6364,9 +5288,7 @@ cat >>$CONFIG_STATUS <<_ACEOF || ac_write_fail=1
 _ACAWK
 _ACEOF
-  { { $as_echo "$as_me:$LINENO: error: could not setup config headers machinery" >&5
-$as_echo "$as_me: error: could not setup config headers machinery" >&2;}
+  as_fn_error $? "could not setup config headers machinery" "$LINENO" 5
 fi # test -n "$CONFIG_HEADERS"
@@ -6379,9 +5301,7 @@ do
   esac
   case $ac_mode$ac_tag in
   :[FHL]*:*);;
-  :L* | :C*:*) { { $as_echo "$as_me:$LINENO: error: invalid tag $ac_tag" >&5
-$as_echo "$as_me: error: invalid tag $ac_tag" >&2;}
+  :L* | :C*:*) as_fn_error $? "invalid tag \`$ac_tag'" "$LINENO" 5;;
   :[FH]-) ac_tag=-:-;;
   :[FH]*) ac_tag=$ac_tag:$ac_tag.in;;
   esac
@@ -6400,7 +5320,7 @@ $as_echo "$as_me: error: invalid tag $ac_tag" >&2;}
     for ac_f
     do
       case $ac_f in
-      -) ac_f="$tmp/stdin";;
+      -) ac_f="$ac_tmp/stdin";;
       *) # Look for the file first in the build tree, then in the source tree
 	 # (if the path is not absolute).  The absolute path cannot be DOS-style,
 	 # because $ac_f cannot contain `:'.
@@ -6409,12 +5329,10 @@ $as_echo "$as_me: error: invalid tag $ac_tag" >&2;}
 	   [\\/$]*) false;;
 	   *) test -f "$srcdir/$ac_f" && ac_f="$srcdir/$ac_f";;
 	   esac ||
-	   { { $as_echo "$as_me:$LINENO: error: cannot find input file: $ac_f" >&5
-$as_echo "$as_me: error: cannot find input file: $ac_f" >&2;}
+	   as_fn_error 1 "cannot find input file: \`$ac_f'" "$LINENO" 5;;
       esac
       case $ac_f in *\'*) ac_f=`$as_echo "$ac_f" | sed "s/'/'\\\\\\\\''/g"`;; esac
-      ac_file_inputs="$ac_file_inputs '$ac_f'"
+      as_fn_append ac_file_inputs " '$ac_f'"
     done
     # Let's still pretend it is `configure' which instantiates (i.e., don't
@@ -6425,7 +5343,7 @@ $as_echo "$as_me: error: cannot find input file: $ac_f" >&2;}
 	`' by configure.'
     if test x"$ac_file" != x-; then
       configure_input="$ac_file.  $configure_input"
-      { $as_echo "$as_me:$LINENO: creating $ac_file" >&5
+      { $as_echo "$as_me:${as_lineno-$LINENO}: creating $ac_file" >&5
 $as_echo "$as_me: creating $ac_file" >&6;}
     fi
     # Neutralize special characters interpreted by sed in replacement strings.
@@ -6437,10 +5355,8 @@ $as_echo "$as_me: creating $ac_file" >&6;}
     esac
     case $ac_tag in
-    *:-:* | *:-) cat >"$tmp/stdin" \
-      || { { $as_echo "$as_me:$LINENO: error: could not create $ac_file" >&5
-$as_echo "$as_me: error: could not create $ac_file" >&2;}
+    *:-:* | *:-) cat >"$ac_tmp/stdin" \
+      || as_fn_error $? "could not create $ac_file" "$LINENO" 5 ;;
     esac
   esac
@@ -6468,47 +5384,7 @@ $as_echo X"$ac_file" |
 	    q
 	  s/.*/./; q'`
-  { as_dir="$ac_dir"
-  case $as_dir in #(
-  -*) as_dir=./$as_dir;;
-  esac
-  test -d "$as_dir" || { $as_mkdir_p && mkdir -p "$as_dir"; } || {
-    as_dirs=
-    while :; do
-      *\'*) as_qdir=`$as_echo "$as_dir" | sed "s/'/'\\\\\\\\''/g"`;; #'(
-      *) as_qdir=$as_dir;;
-      esac
-      as_dirs="'$as_qdir' $as_dirs"
-      as_dir=`$as_dirname -- "$as_dir" ||
-$as_expr X"$as_dir" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \
-	 X"$as_dir" : 'X\(//\)[^/]' \| \
-	 X"$as_dir" : 'X\(//\)$' \| \
-	 X"$as_dir" : 'X\(/\)' \| . 2>/dev/null ||
-$as_echo X"$as_dir" |
-    sed '/^X\(.*[^/]\)\/\/*[^/][^/]*\/*$/{
-	    s//\1/
-	    q
-	  /^X\(\/\/\)[^/].*/{
-	    s//\1/
-	    q
-	  /^X\(\/\/\)$/{
-	    s//\1/
-	    q
-	  /^X\(\/\).*/{
-	    s//\1/
-	    q
-	  s/.*/./; q'`
-      test -d "$as_dir" && break
-    done
-    test -z "$as_dirs" || eval "mkdir $as_dirs"
-  } || test -d "$as_dir" || { { $as_echo "$as_me:$LINENO: error: cannot create directory $as_dir" >&5
-$as_echo "$as_me: error: cannot create directory $as_dir" >&2;}
-   { (exit 1); exit 1; }; }; }
+  as_dir="$ac_dir"; as_fn_mkdir_p
   ac_builddir=.
 case "$ac_dir" in
@@ -6560,7 +5436,6 @@ cat >>$CONFIG_STATUS <<\_ACEOF || ac_write_fail=1
 # If the template does not know about datarootdir, expand it.
 # FIXME: This hack should be removed a few years after 2.60.
 ac_datarootdir_hack=; ac_datarootdir_seen=
 ac_sed_dataroot='
 /datarootdir/ {
   p
@@ -6570,12 +5445,11 @@ ac_sed_dataroot='
 /@docdir@/p
 /@infodir@/p
 /@localedir@/p
-/@mandir@/p
+/@mandir@/p'
 case `eval "sed -n \"\$ac_sed_dataroot\" $ac_file_inputs"` in
 *datarootdir*) ac_datarootdir_seen=yes;;
 *@datadir@*|*@docdir@*|*@infodir@*|*@localedir@*|*@mandir@*)
-  { $as_echo "$as_me:$LINENO: WARNING: $ac_file_inputs seems to ignore the --datarootdir setting" >&5
+  { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: $ac_file_inputs seems to ignore the --datarootdir setting" >&5
 $as_echo "$as_me: WARNING: $ac_file_inputs seems to ignore the --datarootdir setting" >&2;}
 _ACEOF
@@ -6585,7 +5459,7 @@ cat >>$CONFIG_STATUS <<_ACEOF || ac_write_fail=1
   s&@infodir@&$infodir&g
   s&@localedir@&$localedir&g
   s&@mandir@&$mandir&g
-    s&\\\${datarootdir}&$datarootdir&g' ;;
+  s&\\\${datarootdir}&$datarootdir&g' ;;
 esac
 _ACEOF
@@ -6612,27 +5486,24 @@ s&@abs_top_builddir@&$ac_abs_top_builddir&;t t
 s&@INSTALL@&$ac_INSTALL&;t t
 $ac_datarootdir_hack
-eval sed \"\$ac_sed_extra\" "$ac_file_inputs" | $AWK -f "$tmp/subs.awk" >$tmp/out \
+eval sed \"\$ac_sed_extra\" "$ac_file_inputs" | $AWK -f "$ac_tmp/subs.awk" \
+  >$ac_tmp/out || as_fn_error $? "could not create $ac_file" "$LINENO" 5
 test -z "$ac_datarootdir_hack$ac_datarootdir_seen" &&
-  { ac_out=`sed -n '/\${datarootdir}/p' "$tmp/out"`; test -n "$ac_out"; } &&
-  { ac_out=`sed -n '/^[	 ]*datarootdir[	 ]*:*=/p' "$tmp/out"`; test -z "$ac_out"; } &&
-  { $as_echo "$as_me:$LINENO: WARNING: $ac_file contains a reference to the variable \`datarootdir'
-which seems to be undefined.  Please make sure it is defined." >&5
+  { ac_out=`sed -n '/\${datarootdir}/p' "$ac_tmp/out"`; test -n "$ac_out"; } &&
+  { ac_out=`sed -n '/^[	 ]*datarootdir[	 ]*:*=/p' \
+      "$ac_tmp/out"`; test -z "$ac_out"; } &&
+  { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: $ac_file contains a reference to the variable \`datarootdir'
+which seems to be undefined.  Please make sure it is defined" >&5
 $as_echo "$as_me: WARNING: $ac_file contains a reference to the variable \`datarootdir'
-which seems to be undefined.  Please make sure it is defined." >&2;}
+which seems to be undefined.  Please make sure it is defined" >&2;}
-  rm -f "$tmp/stdin"
+  rm -f "$ac_tmp/stdin"
   case $ac_file in
-  -) cat "$tmp/out" && rm -f "$tmp/out";;
-  *) rm -f "$ac_file" && mv "$tmp/out" "$ac_file";;
+  -) cat "$ac_tmp/out" && rm -f "$ac_tmp/out";;
+  *) rm -f "$ac_file" && mv "$ac_tmp/out" "$ac_file";;
   esac \
   :H)
@@ -6641,27 +5512,21 @@ $as_echo "$as_me: error: could not create $ac_file" >&2;}
       $as_echo "/* $configure_input  */" \
-      && eval '$AWK -f "$tmp/defines.awk"' "$ac_file_inputs"
-    } >"$tmp/config.h" \
-    if diff "$ac_file" "$tmp/config.h" >/dev/null 2>&1; then
-      { $as_echo "$as_me:$LINENO: $ac_file is unchanged" >&5
+      && eval '$AWK -f "$ac_tmp/defines.awk"' "$ac_file_inputs"
+    } >"$ac_tmp/config.h" \
+    if diff "$ac_file" "$ac_tmp/config.h" >/dev/null 2>&1; then
+      { $as_echo "$as_me:${as_lineno-$LINENO}: $ac_file is unchanged" >&5
 $as_echo "$as_me: $ac_file is unchanged" >&6;}
     else
       rm -f "$ac_file"
-      mv "$tmp/config.h" "$ac_file" \
+      mv "$ac_tmp/config.h" "$ac_file" \
     fi
   else
-      && eval '$AWK -f "$tmp/defines.awk"' "$ac_file_inputs" \
-      || { { $as_echo "$as_me:$LINENO: error: could not create -" >&5
-$as_echo "$as_me: error: could not create -" >&2;}
+      && eval '$AWK -f "$ac_tmp/defines.awk"' "$ac_file_inputs" \
+      || as_fn_error $? "could not create -" "$LINENO" 5
   fi
@@ -6671,15 +5536,12 @@ $as_echo "$as_me: error: could not create -" >&2;}
 done # for ac_tag
-{ (exit 0); exit 0; }
+as_fn_exit 0
 _ACEOF
-chmod +x $CONFIG_STATUS
 ac_clean_files=$ac_clean_files_save
 test $ac_write_fail = 0 ||
-  { { $as_echo "$as_me:$LINENO: error: write failure creating $CONFIG_STATUS" >&5
-$as_echo "$as_me: error: write failure creating $CONFIG_STATUS" >&2;}
+  as_fn_error $? "write failure creating $CONFIG_STATUS" "$LINENO" 5
 # configure is writing to config.log, and then calls config.status.
@@ -6700,10 +5562,10 @@ if test "$no_create" != yes; then
   exec 5>>config.log
   # Use ||, not &&, to avoid exiting from the if with $? = 1, which
   # would make configure fail if this is the last instruction.
-  $ac_cs_success || { (exit 1); exit 1; }
+  $ac_cs_success || as_fn_exit 1
 fi
 if test -n "$ac_unrecognized_opts" && test "$enable_option_checking" != no; then
-  { $as_echo "$as_me:$LINENO: WARNING: unrecognized options: $ac_unrecognized_opts" >&5
+  { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: unrecognized options: $ac_unrecognized_opts" >&5
 $as_echo "$as_me: WARNING: unrecognized options: $ac_unrecognized_opts" >&2;}
 fi
diff --git a/darshan-runtime/configure.in b/darshan-runtime/configure.in
index 74dc1d9..8bdc52e 100644
--- a/darshan-runtime/configure.in
+++ b/darshan-runtime/configure.in
@@ -5,7 +5,7 @@ dnl Process this file with autoconf to produce a configure script.
 dnl You may need to use autoheader as well if changing any DEFINEs
 dnl sanity checks, output header, location of scripts used here
-AC_INIT([darshan-runtime], [2.3.1-pre2])
+AC_INIT([darshan-runtime], [2.3.1])
 AC_CONFIG_SRCDIR([darshan.h])
 AC_CONFIG_AUX_DIR(../maint/config)
 AC_CONFIG_HEADER(darshan-runtime-config.h)
diff --git a/darshan-runtime/darshan-runtime-config.h.in b/darshan-runtime/darshan-runtime-config.h.in
index 5d4b842..c7ec650 100644
--- a/darshan-runtime/darshan-runtime-config.h.in
+++ b/darshan-runtime/darshan-runtime-config.h.in
@@ -66,6 +66,9 @@
 /* Define to the one symbol short name of this package. */
 #undef PACKAGE_TARNAME
+/* Define to the home page for this package. */
+#undef PACKAGE_URL
 /* Define to the version of this package. */
 #undef PACKAGE_VERSION
diff --git a/darshan-util/configure b/darshan-util/configure
index 33b64ec..6b143a1 100755
--- a/darshan-util/configure
+++ b/darshan-util/configure
@@ -1,6 +1,6 @@
 #! /bin/sh
 # Guess values for system-dependent variables and create Makefiles.
-# Generated by GNU Autoconf 2.69 for darshan-util 2.3.1-pre2.
+# Generated by GNU Autoconf 2.69 for darshan-util 2.3.1.
 # Copyright (C) 1992-1996, 1998-2012 Free Software Foundation, Inc.
@@ -577,8 +577,8 @@ MAKEFLAGS=
 # Identity of this package.
 PACKAGE_NAME='darshan-util'
 PACKAGE_TARNAME='darshan-util'
-PACKAGE_VERSION='2.3.1-pre2'
-PACKAGE_STRING='darshan-util 2.3.1-pre2'
+PACKAGE_VERSION='2.3.1'
+PACKAGE_STRING='darshan-util 2.3.1'
 PACKAGE_BUGREPORT=''
 PACKAGE_URL=''
@@ -1236,7 +1236,7 @@ if test "$ac_init_help" = "long"; then
   # Omit some internal or obsolete options to make the list less imposing.
   # This message is too long to be a string in the A/UX 3.1 sh.
   cat <<_ACEOF
-\`configure' configures darshan-util 2.3.1-pre2 to adapt to many kinds of systems.
+\`configure' configures darshan-util 2.3.1 to adapt to many kinds of systems.
 Usage: $0 [OPTION]... [VAR=VALUE]...
@@ -1297,7 +1297,7 @@ fi
 if test -n "$ac_init_help"; then
   case $ac_init_help in
-     short | recursive ) echo "Configuration of darshan-util 2.3.1-pre2:";;
+     short | recursive ) echo "Configuration of darshan-util 2.3.1:";;
    esac
   cat <<\_ACEOF
@@ -1393,7 +1393,7 @@ fi
 test -n "$ac_init_help" && exit $ac_status
 if $ac_init_version; then
   cat <<\_ACEOF
-darshan-util configure 2.3.1-pre2
+darshan-util configure 2.3.1
@@ -1758,7 +1758,7 @@ cat >config.log <<_ACEOF
 This file contains any messages produced by compilers while
 running configure, to aid debugging if configure makes a mistake.
-It was created by darshan-util $as_me 2.3.1-pre2, which was
+It was created by darshan-util $as_me 2.3.1, which was
   $ $0 $@
@@ -4105,7 +4105,7 @@ fi
 done
-DARSHAN_UTIL_VERSION="2.3.1-pre2"
+DARSHAN_UTIL_VERSION="2.3.1"
@@ -4621,7 +4621,7 @@ cat >>$CONFIG_STATUS <<\_ACEOF || ac_write_fail=1
 ac_log="
-This file was extended by darshan-util $as_me 2.3.1-pre2, which was
+This file was extended by darshan-util $as_me 2.3.1, which was
@@ -4683,7 +4683,7 @@ _ACEOF
 ac_cs_version="\\
-darshan-util config.status 2.3.1-pre2
+darshan-util config.status 2.3.1
diff --git a/darshan-util/configure.in b/darshan-util/configure.in
index 42a18d1..3246f63 100644
--- a/darshan-util/configure.in
+++ b/darshan-util/configure.in
-AC_INIT([darshan-util], [2.3.1-pre2])
+AC_INIT([darshan-util], [2.3.1])
 AC_CONFIG_SRCDIR([darshan-logutils.h])
 AC_CONFIG_HEADER(darshan-util-config.h)
hooks/post-receive
More information about the Darshan-commits mailing list
