[Darshan-commits] [Darshan] branch, dev-modular, updated. darshan-2.3.1-pre2-49-g72380aa
Service Account
git at mcs.anl.gov
Thu Mar 12 17:54:16 CDT 2015
This is an automated email from the git hooks/post-receive script. It was
generated because a ref change was pushed to the repository containing
the project "".
The branch, dev-modular has been updated
via 72380aad89dc2e3f215de57cbcfd880c79bbacb2 (commit)
from acc05e4a78089a657525a8e6fc96e2e643aae45b (commit)
Those revisions listed above that are new to this repository have
not appeared on any other notification email; so we list those
revisions in full, below.
- Log -----------------------------------------------------------------
commit 72380aad89dc2e3f215de57cbcfd880c79bbacb2
Author: Shane Snyder <ssnyder at mcs.anl.gov>
Date: Thu Mar 12 17:53:46 2015 -0500
more docs and added unregister functions
Summary of changes:
darshan-runtime/darshan.h | 5 +-
darshan-runtime/lib/darshan-core.c | 38 ++++-
darshan-runtime/lib/darshan-posix.c | 1 +
darshan-util/darshan-logutils.c | 48 +++---
darshan-util/darshan-posix-parser.c | 7 +
doc/darshan-modularization.txt | 303 +++++++++++++++++++++++++++++++++--
6 files changed, 360 insertions(+), 42 deletions(-)
Diff of changes:
diff --git a/darshan-runtime/darshan.h b/darshan-runtime/darshan.h
index 9347907..46ed062 100644
--- a/darshan-runtime/darshan.h
+++ b/darshan-runtime/darshan.h
@@ -63,12 +63,15 @@ void darshan_core_register_module(
struct darshan_module_funcs *funcs,
int *runtime_mem_limit);
+void darshan_core_unregister_module(
+ darshan_module_id mod_id);
void darshan_core_register_record(
void *name,
int len,
int printable_flag,
darshan_module_id mod_id,
- darshan_record_id *id);
+ darshan_record_id *rec_id);
void darshan_core_unregister_record(
darshan_record_id rec_id,
diff --git a/darshan-runtime/lib/darshan-core.c b/darshan-runtime/lib/darshan-core.c
index a72fde4..4e3eff2 100644
--- a/darshan-runtime/lib/darshan-core.c
+++ b/darshan-runtime/lib/darshan-core.c
@@ -32,7 +32,7 @@ extern char* __progname;
/* internal variable delcarations */
static struct darshan_core_runtime *darshan_core = NULL;
-static pthread_mutex_t darshan_core_mutex = PTHREAD_MUTEX_INITIALIZER;
+static pthread_mutex_t darshan_core_mutex = PTHREAD_RECURSIVE_MUTEX_INITIALIZER_NP;
static int my_rank = -1;
static int nprocs = -1;
@@ -1484,19 +1484,19 @@ static int darshan_log_coll_write(MPI_File log_fh, void *buf, int count,
- darshan_module_id id,
+ darshan_module_id mod_id,
struct darshan_core_module* mod;
*runtime_mem_limit = 0;
- if(!darshan_core || (id >= DARSHAN_MAX_MODS))
+ if(!darshan_core || (mod_id >= DARSHAN_MAX_MODS))
return;
/* see if this module is already registered */
DARSHAN_CORE_LOCK();
- if(darshan_core->mod_array[id])
+ if(darshan_core->mod_array[mod_id])
/* if module is already registered just return */
/* NOTE: we do not recalculate memory limit here, just set to 0 */
@@ -1513,11 +1513,11 @@ void darshan_core_register_module(
memset(mod, 0, sizeof(*mod));
- mod->id = id;
+ mod->id = mod_id;
mod->mod_funcs = *funcs;
/* register module with darshan */
- darshan_core->mod_array[id] = mod;
+ darshan_core->mod_array[mod_id] = mod;
/* TODO: something smarter than just 2 MiB per module */
*runtime_mem_limit = 2 * 1024 * 1024;
@@ -1527,6 +1527,31 @@ void darshan_core_register_module(
return;
+/* TODO: implement & test*/
+ struct darshan_core_record_ref *ref, *tmp;
+ if(!darshan_core)
+ return;
+ DARSHAN_CORE_LOCK();
+ /* iterate all records and disassociate this module from them */
+ HASH_ITER(hlink, darshan_core->rec_hash, ref, tmp)
+ darshan_core_unregister_record(ref->rec.id, mod_id);
+ free(darshan_core->mod_array[mod_id]);
+ darshan_core->mod_array[mod_id] = NULL;
+ DARSHAN_CORE_UNLOCK();
+ return;
void *name,
int len,
@@ -1579,6 +1604,7 @@ void darshan_core_register_record(
return;
+/* TODO: test */
diff --git a/darshan-runtime/lib/darshan-posix.c b/darshan-runtime/lib/darshan-posix.c
index 3222b71..0a5ae13 100644
--- a/darshan-runtime/lib/darshan-posix.c
+++ b/darshan-runtime/lib/darshan-posix.c
@@ -103,6 +103,7 @@ static pthread_mutex_t posix_runtime_mutex = PTHREAD_RECURSIVE_MUTEX_INITIALIZER
static int instrumentation_disabled = 0;
+/* TODO: I'm sure these should be applied on all modules */
/* these are paths that we will not trace */
static char* exclusions[] = {
"/etc/",
diff --git a/darshan-util/darshan-logutils.c b/darshan-util/darshan-logutils.c
index 0f9661f..4118a9d 100644
--- a/darshan-util/darshan-logutils.c
+++ b/darshan-util/darshan-logutils.c
@@ -362,7 +362,6 @@ int darshan_log_gethash(darshan_fd fd, struct darshan_record_ref **hash)
free(comp_buf);
- /* TODO: check for duplicate entries? */
buf_ptr = hash_buf;
while(buf_ptr < (hash_buf + hash_buf_sz))
@@ -377,18 +376,6 @@ int darshan_log_gethash(darshan_fd fd, struct darshan_record_ref **hash)
path_ptr = (char *)buf_ptr;
buf_ptr += *path_len_ptr;
- ref = malloc(sizeof(*ref));
- if(!ref)
- return(-1);
- ref->rec.name = malloc(*path_len_ptr + 1);
- if(!ref->rec.name)
- free(ref);
- return(-1);
if(fd->swap_flag)
/* we need to sort out endianness issues before deserializing */
@@ -396,13 +383,29 @@ int darshan_log_gethash(darshan_fd fd, struct darshan_record_ref **hash)
DARSHAN_BSWAP32(path_len_ptr);
- /* set the fields for this record */
- ref->rec.id = *rec_id_ptr;
- memcpy(ref->rec.name, path_ptr, *path_len_ptr);
- ref->rec.name[*path_len_ptr] = '\0';
+ HASH_FIND(hlink, *hash, rec_id_ptr, sizeof(darshan_record_id), ref);
+ if(!ref)
+ ref = malloc(sizeof(*ref));
+ if(!ref)
+ return(-1);
+ ref->rec.name = malloc(*path_len_ptr + 1);
+ if(!ref->rec.name)
+ free(ref);
+ return(-1);
+ /* set the fields for this record */
+ ref->rec.id = *rec_id_ptr;
+ memcpy(ref->rec.name, path_ptr, *path_len_ptr);
+ ref->rec.name[*path_len_ptr] = '\0';
- /* add this record to the hash */
- HASH_ADD(hlink, *hash, rec.id, sizeof(darshan_record_id), ref);
+ /* add this record to the hash */
+ HASH_ADD(hlink, *hash, rec.id, sizeof(darshan_record_id), ref);
return(0);
@@ -476,15 +479,13 @@ int darshan_log_getmod(darshan_fd fd, darshan_module_id mod_id,
*mod_buf = tmp_buf;
*mod_buf_sz = tmp_buf_sz;
- /* TODO: bswaps */
return(0);
-#if 0
/* TODO: hardcoded for posix -- what can we do generally?
* different function for each module and a way to map to this function?
+/* TODO: we need bswaps here, too */
int darshan_log_getfile(darshan_fd fd, struct darshan_posix_file *file)
char *comp_buf;
@@ -544,7 +545,6 @@ int darshan_log_getfile(darshan_fd fd, struct darshan_posix_file *file)
fprintf(stderr, "Error: %s\n", err_string);
return(-1);
-#endif
/* darshan_log_close()
@@ -563,7 +563,7 @@ void darshan_log_close(darshan_fd fd)
free(fd);
/* return 0 on successful seek to offset, -1 on failure.
diff --git a/darshan-util/darshan-posix-parser.c b/darshan-util/darshan-posix-parser.c
index 394d0e3..334f341 100644
--- a/darshan-util/darshan-posix-parser.c
+++ b/darshan-util/darshan-posix-parser.c
@@ -168,11 +168,18 @@ int main(int argc, char **argv)
return(0);
+ /* TODO: move this functionality somewhere else so it can be reused */
/* loop over the POSIX file records and print out counters */
for(i = 0; i < (posix_mod_buf_sz / sizeof(struct darshan_posix_file)); i++)
struct darshan_posix_file next_rec = posix_mod_buf[i];
+ DARSHAN_BSWAP64(&(next_rec.f_id));
+ DARSHAN_BSWAP64(&(next_rec.rank));
+ DARSHAN_BSWAP64(&(next_rec.counters[CP_POSIX_OPENS]));
+ DARSHAN_BSWAP64(&(next_rec.fcounters[CP_F_OPEN_TIMESTAMP]));
+ DARSHAN_BSWAP64(&(next_rec.fcounters[CP_F_CLOSE_TIMESTAMP]));
/* get the pathname for this record */
HASH_FIND(hlink, rec_hash, &next_rec.f_id, sizeof(darshan_record_id), ref);
assert(ref);
diff --git a/doc/darshan-modularization.txt b/doc/darshan-modularization.txt
index cebfe33..019b9f4 100644
--- a/doc/darshan-modularization.txt
+++ b/doc/darshan-modularization.txt
@@ -42,9 +42,9 @@ http://www.mcs.anl.gov/research/projects/darshan/docs/darshan-util.html[darshan-
necessary steps for building these repositories should not have changed in the new version of
Darshan.
-== Architectural overview
+== Darshan dev-modular overview
-The Darshan source tree is composed of two primary components:
+The Darshan source tree is organized into two primary components:
* *darshan-runtime*: Darshan runtime environment necessary for instrumenting MPI
applications and generating I/O characterization logs.
@@ -55,22 +55,303 @@ I/O characterization log.
The following subsections provide an overview of each of these components with specific
attention to how new instrumentation modules may be integrated into Darshan.
-=== darshan-runtime
+=== Darshan-runtime
-At a high level, the darshan-runtime library is responsible for instrumenting MPI applications
-and generating a log file containing the resulting I/O characterization.
+The primary responsibilities of the darshan-runtime component are:
-The I/O behavior an application is primarily instrumented by intercepting function calls of
-interest and recording relevant data.
+* intercepting I/O functions of interest from a target application;
-// TODO: how does dynamic vs static executable affect a module developer?
+* extracting statistics, timing information, and other data characterizing the application's I/O workload;
+* compressing I/O characterization data and corresponding metadata;
+* logging the compressed I/O characterization to file for future evaluation
-=== darshan-util
+The first two responsibilities are the burden of the instrumentation module developer, while the last
+two are handled automatically by Darshan.
-Text.
+==== Instrumentation modules
+The wrapper functions used to intercept I/O function calls of interest are central to the design of
+any Darshan instrumentation module. These wrappers are used to extract pertinent I/O data from
+the function call and persist this data in some state structure maintained by the module. The wrappers
+are inserted at compile time for statically linked executables (e.g., using the linkers `--wrap`
+mechanism) and at runtime for dynamically linked executables (using LD_PRELOAD).
+*NOTE*: Modules should not perform any I/O or communication within wrapper functions. Darshan records
+I/O data independently on each application process, then merges the data from all processes when the
+job is shutting down. This defers expensive I/O and communication operations to the shutdown process,
+limiting Darshan's impact on application I/O performance.
+When the instrumented application terminates and Darshan begins its shutdown procedure, it requires
+a way to interface with any active modules that have data to contribute to the output I/O characterization.
+Darshan requires that module developers implement the following functions to allow the Darshan runtime
+environment to coordinate with modules while shutting down:
+[source,c]
+struct darshan_module_funcs
+ void (*disable_instrumentation)(void);
+ void (*prepare_for_reduction)(
+ darshan_record_id *shared_recs,
+ int *shared_rec_count,
+ void **send_buf,
+ void **recv_buf,
+ int *rec_size
+ void (*reduce_records)(
+ void* a,
+ void* b,
+ int *len,
+ MPI_Datatype *datatype
+ void (*get_output_data)(
+ void** buf,
+ int* size
+ void (*shutdown)(void);
+`disable_instrumentation()`
+This function informs the module that Darshan is about to begin shutting down. It should disable
+all wrappers and stop updating internal data structures to ensure data consistency and avoid
+other race conditions.
+`prepare_for_reduction()`
+Since Darshan aggregates shared data records (i.e., records which all application processes
+accessed) into a single record, module developers must provide mechanisms for performing a reduction
+on these records.
+This function is used to prepare a module for performing a reduction operation. In general, this
+just involves providing the input buffers to the reduction, and (on rank 0 only) providing output
+buffer space to store the result of the reduction.
+* _shared_recs_ is a set of Darshan record identifiers which are associated with this module.
+These are the records which need to be reduced into single shared data records.
+* _shared_rec_count_ is a pointer to an integer storing the number of shared records will
+be reduced by this module. When the function is called this variable points to the number
+of shared records detected by Darshan, but the module can decide not to reduce any number
+of these records. Upon completion of the function, this variable should point to the number
+of shared records to perform reductions on (i.e., the size of the input and output buffers).
+* _send_buf_ is a pointer to the address of the send buffer used for performing the reduction
+operation. Upon completion, this variable should point to a buffer containing *_shared_rec_count_
+records that will be reduced.
+* _recv_buf_ is a pointer to the address of the receive bufffer used for performing the reduction
+records that will be reduced. This variable is only valid on the root process (rank 0). This
+buffer address needs to be stored with module state, as it will be needed when retrieiving
+the final output buffers from this module.
+* _rec_size_ is just the size of the record structure being reduced for this module.
+`reduce_records()`
+This is the function which performs the actual shared record reduction operation. The prototype
+of this function matches that of the user function provided to the MPI_Op_create function. Refer
+to the http://www.mpich.org/static/docs/v3.1/www3/MPI_Op_create.html[documentation] for further
+details.
+`get_output_data()`
+This function is responsible for passing back a single buffer storing all data this module is
+contributing to the output I/O characterization. On rank 0, this may involve copying the results
+of the shared record reduction into the output buffer.
+* _buf_ is a pointer to the address of the buffer this module is contributing to the I/O
+characterization.
+* _size_ is the size of this module's output buffer.
+`shutdown()`
+This function is a signal from Darshan that it is safe to shutdown. It should clean up and free
+all internal data structures.
+==== darshan-core
+Within darshan-runtime, the darshan-core component manages the initialization and shutdown of the
+Darshan environment, provides instrumentation module developers an interface for registering modules
+with Darshan, and manages the compressing and the writing of the resultant I/O charracterization.
+Each of the functions defined by this interface are explained in detail below.
+[source,c]
+void darshan_core_register_module(
+ struct darshan_module_funcs *funcs,
+ int *runtime_mem_limit);
+The `darshan_core_register_module` function registers Darshan instrumentation modules with the
+darshan-core runtime environment. This function needs to be called at least once for any module
+that will contribute data to Darshan's final I/O characterization.
+* _mod_id_ is a unique identifier for the given module, which is defined in the Darshan log
+format header file (darshan-log-format.h).
+* _funcs_ is the structure of function pointers (as described above) that a module developer must
+provide to interface with the darshan-core runtime.
+* _runtime_mem_limit_ is a pointer to an integer which will store the amount of memory Darshan
+allows this module to use at runtime. Currently, darshan-core will hardcode this value to 2 MiB,
+but in the future this may be changed to optimize Darshan's memory footprint. Note that Darshan
+does not allocate any memory for modules, it just informs a module how much memory it can use.
+[source,c]
+The `darshan_core_unregister_module` function disassociates the given module from the
+darshan-core runtime. Consequentially, Darshan does not interface with the given module at
+shutdown time and will not log any I/O data from the module. This function should only be used
+if a module registers itself with darshan-core but later decides it does not want to contribute
+any I/O data.
+* _mod_id_ is the unique identifer for the module being unregistered.
+[source,c]
+void darshan_core_register_record(
+ void *name,
+ int len,
+ int printable_flag,
+The `darshan_core_register_record` function registers some data record with the darshan-core
+runtime. This record could reference a POSIX file or perhaps an object identifier for an
+object storage system, for instance. A unique identifier for the given record name is
+generated by Darshan, which should then be used by the module for referencing the corresponding
+record. This allows multiple modules to refer to a specific data record in a consistent manner
+and also provides a mechanism for mapping these records back to important metadata stored by
+darshan-core. It is safe (and likely necessary) to call this function many times for the same
+record -- darshan-core will just set the corresponding record identifier if the record has
+been previously registered.
+* _name_ is just the name of the data record, which could be a file path, object ID, etc.
+* _len_ is the size of the input record name. For string record names, this would just be the
+string length, but for nonprintable record names (e.g., an integer object identifier), this
+is the size of the record name type.
-== Adding new modules
+* _printable_flag_ indicates whether the input record name is a printable ASCII string.
+* _mod_id_ is the identifier for the module attempting to register this record.
+* _rec_id_ is a pointer to a variable which will store the unique record identifier generated
+by Darshan.
+[source,c]
+void darshan_core_unregister_record(
+ darshan_record_id rec_id,
+The `darshan_core_unregister_record` functoin disassociates the given module identifier from the
+given record identifier. If no other modules are associated with the given record identifier, then
+Darshan removes all internal references to the record. This function should only be used if a
+module registers a record with darshan-core, but later decides not to store the record internally.
+* _rec_id_ is the record identifier we want to unregister.
+* _mod_id_ is the module identifier that is unregistering _rec_id_.
+[source,c]
+double darshan_core_wtime(void);
+The `darshan_core_wtime` function simply returns a floating point number of seconds since
+Darshan was initialized. This functionality can be used to time the duration of application
+I/O calls or to store timestamps of when functions of interest were called.
+==== darshan-common
+darshan-common is a utility component of darshan-runtime, providing module developers with
+general functions that are likely to be reused across multiple modules. These functions are
+distinct from darshan-core functions since they do not require access to internal Darshan
+state.
+[source,c]
+char* darshan_clean_file_path(
+ const char* path);
+The `darshan_clean_file_path` function just cleans up the input path string, converting
+relative paths to absolute paths and suppressing any potential noise within the string.
+* _path_ is the input path string to be cleaned up.
+As more modules are contributed, it is likely that more functionality can be refactored out
+of module implementations and maintained in darshan-common, facilitating code reuse and
+simplifying maintenance.
+=== Darshan-util
Text.
+== Adding new instrumentation modules
+In this section we outline each step necessary to adding a module to Darshan.
+=== Log format headers
+The following modifications to Darshan log format headers are required for defining
+the module's record structure:
+* Add module identifier to darshan_module_id enum and add module string name to the
+darshan_module_name array in `darshan-log-format.h`.
+* Add a top-level header that defines a data record structure for the module. An exemplar
+log header for the POSIX instrumentation module is given in `darshan-posix-log-format.h`.
+==== Build modifications
+The following modifications to the darshan-runtime build system are necessary to integrate
+new instrumentation modules:
+* Necessary linker flags for wrapping this module's functions need to be added to the definition
+of `CP_WRAPPERS` in `darshan-config.in`.
+* Targets must be added to `Makefile.in` to build static and shared objects for the module's
+source files, which will be stored in the `lib/` directory. The prerequisites to building
+static and dynamic versions of `lib-darshan` must be updated to include these objects, as well.
+It is necessary to rerun the `prepare` script and reconfigure darshan-runtime for these changes
+to take effect.
+==== Instrumentation module implementation
+An exemplar instrumentation module for POSIX I/O functions is given in `lib/darshan-posix.c` as
+reference. In addtion to the development notes from above and the reference POSIX module, we
+provide the following notes to assist module developers:
+* Modules only need to include the `darshan.h` header to interface with darshan-core.
+* Lacking a way to bootstrap themselves, modules will have to include some logic in their
+wrappers to initialize necessary module state if initialization has not already occurred.
+ - Part of this initialization process should be registering the module with darshan-core,
+ since this informs the module how much memory it may allocate.
+* The file record identifier given when registering a record with darshan-core can be used
+to store the record structure in a hash table or some other structure.
+ - The `darshan_core_register_record` function is really more like a lookup function. It
+ may be called multiple times for the same record -- if the record already exists, the function
+ simply returns its record ID.
+ - It may be necessary to maintain a separate hash table for other handles which the module
+ may use to refer to a given record. For instance, the POSIX module may need to look up a
+ file record based on a given file descriptor, rather than a path name.
+=== Darshan-util
+Text
+== Other resources
+* http://www.mcs.anl.gov/research/projects/darshan/[Darshan website]
+* http://www.mcs.anl.gov/research/projects/darshan/docs/darshan-runtime.html[darshan-runtime documentation]
+* http://www.mcs.anl.gov/research/projects/darshan/docs/darshan-util.html[darshan-util documentation]
+* https://lists.mcs.anl.gov/mailman/listinfo/darshan-users[Darshan-users mailing list]
+* https://trac.mcs.anl.gov/projects/darshan/report[Darshan trac page]
hooks/post-receive
More information about the Darshan-commits
