[Darshan-commits] [Darshan] branch, dev-modular, updated. darshan-2.3.1-pre2-48-gacc05e4
Service Account git at mcs.anl.gov
Fri Mar 6 11:24:19 CST 2015
This is an automated email from the git hooks/post-receive script. It was
generated because a ref change was pushed to the repository containing
the project "".
The branch, dev-modular has been updated
       via  acc05e4a78089a657525a8e6fc96e2e643aae45b (commit)
      from  75eee95096b07874b7ad3e95be5c80eccad24d8f (commit)
Those revisions listed above that are new to this repository have
not appeared on any other notification email; so we list those
revisions in full, below.
- Log -----------------------------------------------------------------
commit acc05e4a78089a657525a8e6fc96e2e643aae45b
Author: Shane Snyder <ssnyder at mcs.anl.gov>
Date:   Fri Mar 6 11:23:56 2015 -0600
    resolve minor TODO items
Summary of changes:
 darshan-runtime/Makefile.in         |    4 -
 darshan-runtime/darshan-core.h      |   27 ++-
 darshan-runtime/darshan.h           |   21 ++-
 darshan-runtime/lib/darshan-core.c  |  308 +++++++++++++++++++++--------------
 darshan-runtime/lib/darshan-posix.c |   15 +-
 5 files changed, 223 insertions(+), 152 deletions(-)
Diff of changes:
diff --git a/darshan-runtime/Makefile.in b/darshan-runtime/Makefile.in
index 08561a2..9bb7860 100644
--- a/darshan-runtime/Makefile.in
+++ b/darshan-runtime/Makefile.in
@@ -28,14 +28,11 @@ CFLAGS = -DDARSHAN_CONFIG_H=\"darshan-runtime-config.h\" -I . -I ../ -I $(srcdir
 CFLAGS_SHARED = -DDARSHAN_CONFIG_H=\"darshan-runtime-config.h\" -I . -I$(srcdir) -I$(srcdir)/../ @CFLAGS@ @CPPFLAGS@ -D_LARGEFILE64_SOURCE -shared -fpic -DPIC -DDARSHAN_PRELOAD
-# TODO: BZ2?
 LIBS = -lz @LIBBZ2@
 lib::
 	@mkdir -p $@
-# TODO make sure the headers are right in these prereqs
 lib/darshan-core.o: lib/darshan-core.c darshan-core.h $(DARSHAN_LOG_FORMAT) | lib
 	$(CC) $(CFLAGS) -c $< -o $@
@@ -66,7 +63,6 @@ lib/lookup8.o: lib/lookup8.c
 lib/lookup8.po: lib/lookup8.c
 	$(CC) $(CFLAGS_SHARED) -c $< -o $@
-# TODO: huh?
 #%.i: %.c
 #	$(CC) -E $(CFLAGS) -c $< -o $@
diff --git a/darshan-runtime/darshan-core.h b/darshan-runtime/darshan-core.h
index 0a78eed..5667e9b 100644
--- a/darshan-runtime/darshan-core.h
+++ b/darshan-runtime/darshan-core.h
@@ -12,18 +12,20 @@
 #include "darshan.h"
-/* TODO: enforce this when handing out ids */
+/* TODO: this goes where ? -- shared libs */
+#define DARSHAN_MPI_CALL(func) func
 #define DARSHAN_CORE_MAX_RECORDS 1024
-/* default compression buffer size of 2 MiB */
 /* TODO: revisit this default size if we change memory per module */
-#define DARSHAN_COMP_BUF_SIZE (2 * 1024 * 1024)
+#define DARSHAN_CORE_COMP_BUF_SIZE (2 * 1024 * 1024)
-struct darshan_core_module
-    darshan_module_id id;
-    struct darshan_module_funcs mod_funcs;
+#define DARSHAN_CORE_MOD_SET(flags, id) (flags | (1 << id))
+#define DARSHAN_CORE_MOD_UNSET(flags, id) (flags & ~(1 << id))
+#define DARSHAN_CORE_MOD_ISSET(flags, id) (flags & (1 << id))
 /* in memory structure to keep up with job level data */
 struct darshan_core_runtime
@@ -31,12 +33,19 @@ struct darshan_core_runtime
     struct darshan_job log_job;
     char exe[DARSHAN_EXE_LEN+1];
     struct darshan_core_record_ref *rec_hash;
+    int rec_count;
     struct darshan_core_module* mod_array[DARSHAN_MAX_MODS];
-    char comp_buf[DARSHAN_COMP_BUF_SIZE];
+    char comp_buf[DARSHAN_CORE_COMP_BUF_SIZE];
     double wtime_offset;
     char *trailing_data;
+struct darshan_core_module
+    darshan_module_id id;
+    struct darshan_module_funcs mod_funcs;
     struct darshan_record rec;
diff --git a/darshan-runtime/darshan.h b/darshan-runtime/darshan.h
index f942a25..9347907 100644
--- a/darshan-runtime/darshan.h
+++ b/darshan-runtime/darshan.h
@@ -25,20 +25,21 @@
 /* Environment variable to override __CP_MEM_ALIGNMENT */
 #define CP_MEM_ALIGNMENT_OVERRIDE "DARSHAN_MEMALIGN"
+/* module developers provide the following functions to darshan-core */
     /* disable futher instrumentation within a module */
     void (*disable_instrumentation)(void);
-    /* TODO: */
+    /* perform any necessary steps prior to reducing */
     void (*prepare_for_reduction)(
-        darshan_record_id *shared_recs,
+        darshan_record_id *shared_recs, /* input list of shared records */
         int *shared_rec_count, /* in/out shared record count */
-        void **send_buf,
-        void **recv_buf,
-        int *rec_size
+        void **send_buf, /* send buffer for shared file reduction */
+        void **recv_buf, /* recv buffer for shared file reduction (root only) */
+        int *rec_size /* size of records being stored for this module */
-    /* TODO: */
-    void (*reduce_record)(
+    /* reduce records which are shared globally across this module */
+    void (*reduce_records)(
         void* infile_v,
         void* inoutfile_v,
         int *len,
@@ -62,13 +63,17 @@ void darshan_core_register_module(
     struct darshan_module_funcs *funcs,
     int *runtime_mem_limit);
-void darshan_core_lookup_record_id(
+void darshan_core_register_record(
     void *name,
     int len,
     int printable_flag,
     darshan_module_id mod_id,
     darshan_record_id *id);
+void darshan_core_unregister_record(
+    darshan_record_id rec_id,
+    darshan_module_id mod_id);
 double darshan_core_wtime(void);
diff --git a/darshan-runtime/lib/darshan-core.c b/darshan-runtime/lib/darshan-core.c
index 12381b2..a72fde4 100644
--- a/darshan-runtime/lib/darshan-core.c
+++ b/darshan-runtime/lib/darshan-core.c
@@ -30,14 +30,15 @@
 /* TODO is __progname_full needed here */
 extern char* __progname;
-#define DARSHAN_MPI_CALL(func) func
 /* internal variable delcarations */
 static struct darshan_core_runtime *darshan_core = NULL;
 static pthread_mutex_t darshan_core_mutex = PTHREAD_MUTEX_INITIALIZER;
 static int my_rank = -1;
 static int nprocs = -1;
+#define DARSHAN_CORE_LOCK() pthread_mutex_lock(&darshan_core_mutex)
+#define DARSHAN_CORE_UNLOCK() pthread_mutex_unlock(&darshan_core_mutex)
 /* FS mount information */
 #define DARSHAN_MAX_MNTS 64
 #define DARSHAN_MAX_MNT_PATH 256
@@ -79,9 +80,6 @@ static int darshan_log_write_record_hash(
 static int darshan_log_coll_write(
     MPI_File log_fh, void *buf, int count, struct darshan_log_map *map);
-#define DARSHAN_CORE_LOCK() pthread_mutex_lock(&darshan_core_mutex)
-#define DARSHAN_CORE_UNLOCK() pthread_mutex_unlock(&darshan_core_mutex)
 /* intercept MPI initialize and finalize to manage darshan core runtime */
 int MPI_Init(int *argc, char ***argv)
@@ -397,6 +395,7 @@ static void darshan_core_shutdown()
                 fprintf(stderr, "darshan library warning: unable to write job data to log file %s\n",
                         logfile_name);
                 unlink(logfile_name);
             /* set the beginning offset of record hash, which precedes job info just written */
@@ -438,7 +437,6 @@ static void darshan_core_shutdown()
     if(internal_timing_flag)
         rec2 = DARSHAN_MPI_CALL(PMPI_Wtime)();
-    /* TODO: would be nice to factor this out somehow ... a lot to look at */
     /* loop over globally used darshan modules and:
      *      - perform shared file reductions, if possible
      *      - get final output buffer
@@ -484,7 +482,7 @@ static void darshan_core_shutdown()
                 HASH_FIND(hlink, final_core->rec_hash, &shared_recs[j],
                     sizeof(darshan_record_id), ref);
                 assert(ref);
-                if(ref->global_mod_flags & (1 << i)) /* TODO: MACRO? */
+                if(DARSHAN_CORE_MOD_ISSET(ref->global_mod_flags, i))
                     mod_shared_recs[shared_rec_count++] = shared_recs[j];
@@ -505,7 +503,7 @@ static void darshan_core_shutdown()
                     DARSHAN_MPI_CALL(PMPI_Type_commit)(&red_type);
                     /* register a reduction operator for this module */
-                    DARSHAN_MPI_CALL(PMPI_Op_create)(this_mod->mod_funcs.reduce_record,
+                    DARSHAN_MPI_CALL(PMPI_Op_create)(this_mod->mod_funcs.reduce_records,
                         1, &red_op);
                     /* reduce shared file records for this module */
@@ -613,29 +611,39 @@ static void darshan_core_shutdown()
      * to *-<logwritetime>.darshan.gz, which indicates that this log file is
      * complete and ready for analysis
-    /* TODO: support user given logfile path/name */
     if(my_rank == 0)
-        char* tmp_index;
-        double end_log_time;
-        char* new_logfile_name;
-        new_logfile_name = malloc(PATH_MAX);
-        if(new_logfile_name)
+        if(getenv("DARSHAN_LOGFILE"))
-            new_logfile_name[0] = '\0';
-            end_log_time = DARSHAN_MPI_CALL(PMPI_Wtime)();
-            strcat(new_logfile_name, logfile_name);
-            tmp_index = strstr(new_logfile_name, ".darshan_partial");
-            sprintf(tmp_index, "_%d.darshan.gz", (int)(end_log_time-start_log_time+1));
-            rename(logfile_name, new_logfile_name);
-            /* set permissions on log file */
 #ifdef __CP_GROUP_READABLE_LOGS
-            chmod(new_logfile_name, (S_IRUSR|S_IRGRP));
+            chmod(logfile_name, (S_IRUSR|S_IRGRP));
 #else
-            chmod(new_logfile_name, (S_IRUSR));
+            chmod(logfile_name, (S_IRUSR));
 #endif
-            free(new_logfile_name);
+        else
+            char* tmp_index;
+            double end_log_time;
+            char* new_logfile_name;
+            new_logfile_name = malloc(PATH_MAX);
+            if(new_logfile_name)
+                new_logfile_name[0] = '\0';
+                end_log_time = DARSHAN_MPI_CALL(PMPI_Wtime)();
+                strcat(new_logfile_name, logfile_name);
+                tmp_index = strstr(new_logfile_name, ".darshan_partial");
+                sprintf(tmp_index, "_%d.darshan.gz", (int)(end_log_time-start_log_time+1));
+                rename(logfile_name, new_logfile_name);
+                /* set permissions on log file */
+#ifdef __CP_GROUP_READABLE_LOGS
+                chmod(new_logfile_name, (S_IRUSR|S_IRGRP));
+#else
+                chmod(new_logfile_name, (S_IRUSR));
+#endif
+                free(new_logfile_name);
@@ -727,6 +735,7 @@ static void darshan_core_cleanup(struct darshan_core_runtime* core)
 /* construct the darshan log file name */
 static void darshan_get_logfile_name(char* logfile_name, int jobid, struct tm* start_tm)
+    char* user_logfile_name;
     char* logpath;
     char* logname_string;
     char* logpath_override = NULL;
@@ -740,120 +749,139 @@ static void darshan_get_logfile_name(char* logfile_name, int jobid, struct tm* s
     char cuser[L_cuserid] = {0};
     int ret;
-    /* Use CP_LOG_PATH_OVERRIDE for the value or __CP_LOG_PATH */
-    logpath = getenv(CP_LOG_PATH_OVERRIDE);
-    if(!logpath)
+    /* first, check if user specifies a complete logpath to use */
+    user_logfile_name = getenv("DARSHAN_LOGFILE");
+    if(user_logfile_name)
+        if(strlen(user_logfile_name) >= (PATH_MAX-1))
+            fprintf(stderr, "darshan library warning: user log file name too long.\n");
+            logfile_name[0] = '\0';
+        else
+            strcpy(logfile_name, user_logfile_name);
+    else
+        /* otherwise, generate the log path automatically */
+        /* Use CP_LOG_PATH_OVERRIDE for the value or __CP_LOG_PATH */
+        logpath = getenv(CP_LOG_PATH_OVERRIDE);
+        if(!logpath)
 #ifdef __CP_LOG_PATH
-        logpath = __CP_LOG_PATH;
+            logpath = __CP_LOG_PATH;
 #endif
-    /* get the username for this job.  In order we will try each of the
-     * following until one of them succeeds:
-     * - cuserid()
-     * - getenv("LOGNAME")
-     * - snprintf(..., geteuid());
-     * Note that we do not use getpwuid() because it generally will not
-     * work in statically compiled binaries.
+        /* get the username for this job.  In order we will try each of the
+         * following until one of them succeeds:
+         * - cuserid()
+         * - getenv("LOGNAME")
+         * - snprintf(..., geteuid());
+         * Note that we do not use getpwuid() because it generally will not
+         * work in statically compiled binaries.
 #ifndef DARSHAN_DISABLE_CUSERID
-    cuserid(cuser);
+        cuserid(cuser);
 #endif
-    /* if cuserid() didn't work, then check the environment */
-    if(strcmp(cuser, "") == 0)
-        logname_string = getenv("LOGNAME");
-        if(logname_string)
+        /* if cuserid() didn't work, then check the environment */
+        if(strcmp(cuser, "") == 0)
-            strncpy(cuser, logname_string, (L_cuserid-1));
+            logname_string = getenv("LOGNAME");
+            if(logname_string)
+                strncpy(cuser, logname_string, (L_cuserid-1));
-    /* if cuserid() and environment both fail, then fall back to uid */
-        uid_t uid = geteuid();
-        snprintf(cuser, sizeof(cuser), "%u", uid);
+        /* if cuserid() and environment both fail, then fall back to uid */
+            uid_t uid = geteuid();
+            snprintf(cuser, sizeof(cuser), "%u", uid);
-    /* generate a random number to help differentiate the log */
-    hlevel=DARSHAN_MPI_CALL(PMPI_Wtime)() * 1000000;
-    (void)gethostname(hname, sizeof(hname));
-    logmod = darshan_hash((void*)hname,strlen(hname),hlevel);
+        /* generate a random number to help differentiate the log */
+        hlevel=DARSHAN_MPI_CALL(PMPI_Wtime)() * 1000000;
+        (void)gethostname(hname, sizeof(hname));
+        logmod = darshan_hash((void*)hname,strlen(hname),hlevel);
-    /* see if darshan was configured using the --with-logpath-by-env
-     * argument, which allows the user to specify an absolute path to
-     * place logs via an env variable.
+        /* see if darshan was configured using the --with-logpath-by-env
+         * argument, which allows the user to specify an absolute path to
+         * place logs via an env variable.
 #ifdef __CP_LOG_ENV
-    /* just silently skip if the environment variable list is too big */
-    if(strlen(__CP_LOG_ENV) < 256)
-        /* copy env variable list to a temporary buffer */
-        strcpy(env_check, __CP_LOG_ENV);
-        /* tokenize the comma-separated list */
-        env_tok = strtok(env_check, ",");
-        if(env_tok)
+        /* just silently skip if the environment variable list is too big */
+        if(strlen(__CP_LOG_ENV) < 256)
-            do
+            /* copy env variable list to a temporary buffer */
+            strcpy(env_check, __CP_LOG_ENV);
+            /* tokenize the comma-separated list */
+            env_tok = strtok(env_check, ",");
+            if(env_tok)
-                /* check each env variable in order */
-                logpath_override = getenv(env_tok);
-                if(logpath_override)
+                do
-                    /* stop as soon as we find a match */
-                    break;
-            }while((env_tok = strtok(NULL, ",")));
+                    /* check each env variable in order */
+                    logpath_override = getenv(env_tok);
+                    if(logpath_override)
+                        /* stop as soon as we find a match */
+                        break;
+                }while((env_tok = strtok(NULL, ",")));
 #endif
-        ret = snprintf(logfile_name, PATH_MAX,
-            "%s/%s_%s_id%d_%d-%d-%d-%" PRIu64 ".darshan_partial",
-            logpath_override,
-            cuser, __progname, jobid,
-            (start_tm->tm_mon+1),
-            start_tm->tm_mday,
-            (start_tm->tm_hour*60*60 + start_tm->tm_min*60 + start_tm->tm_sec),
-            logmod);
-        if(ret == (PATH_MAX-1))
-            /* file name was too big; squish it down */
-            snprintf(logfile_name, PATH_MAX,
-                "%s/id%d.darshan_partial",
-                logpath_override, jobid);
+            ret = snprintf(logfile_name, PATH_MAX,
+                "%s/%s_%s_id%d_%d-%d-%d-%" PRIu64 ".darshan_partial",
+                logpath_override,
+                cuser, __progname, jobid,
+                (start_tm->tm_mon+1),
+                start_tm->tm_mday,
+                (start_tm->tm_hour*60*60 + start_tm->tm_min*60 + start_tm->tm_sec),
+                logmod);
+            if(ret == (PATH_MAX-1))
+                /* file name was too big; squish it down */
+                snprintf(logfile_name, PATH_MAX,
+                    "%s/id%d.darshan_partial",
+                    logpath_override, jobid);
-    else if(logpath)
-            "%s/%d/%d/%d/%s_%s_id%d_%d-%d-%d-%" PRIu64 ".darshan_partial",
-            logpath, (start_tm->tm_year+1900),
-            (start_tm->tm_mon+1), start_tm->tm_mday,
-            logmod);
+        else if(logpath)
-                logpath, jobid);
+                "%s/%d/%d/%d/%s_%s_id%d_%d-%d-%d-%" PRIu64 ".darshan_partial",
+                logpath, (start_tm->tm_year+1900),
+                (start_tm->tm_mon+1), start_tm->tm_mday,
+                logmod);
+                    logpath, jobid);
+        else
-    else
-        logfile_name[0] = '\0';
     return;
@@ -1198,7 +1226,7 @@ static int darshan_log_coll_open(char *logfile_name, MPI_File *log_fh)
     /* open the darshan log file for writing */
     ret = DARSHAN_MPI_CALL(PMPI_File_open)(MPI_COMM_WORLD, logfile_name,
         MPI_MODE_CREATE | MPI_MODE_WRONLY | MPI_MODE_EXCL, info, log_fh);
-    if(ret < 0)
+    if(ret != MPI_SUCCESS)
         return(-1);
     MPI_Info_free(&info);
@@ -1244,7 +1272,7 @@ static int darshan_compress_buffer(void **pointers, int *lengths, int count,
     tmp_stream.next_out = comp_buf;
-    tmp_stream.avail_out = DARSHAN_COMP_BUF_SIZE;
+    tmp_stream.avail_out = DARSHAN_CORE_COMP_BUF_SIZE;
     /* loop over the input pointers */
     for(i = 0; i < count; i++)
@@ -1425,7 +1453,7 @@ static int darshan_log_coll_write(MPI_File log_fh, void *buf, int count,
     /* perform the collective write */
     ret = DARSHAN_MPI_CALL(PMPI_File_write_at_all)(log_fh, my_off, buf,
         count, MPI_BYTE, &status);
-    if(ret < 0)
         return(-1);
     /* send the ending offset from rank (n-1) to rank 0 */
@@ -1499,8 +1527,7 @@ void darshan_core_register_module(
     return;
-/* TODO: RENAME */
     void *name,
     int len,
     int printable_flag,
@@ -1508,7 +1535,7 @@ void darshan_core_lookup_record_id(
     darshan_record_id *rec_id)
     darshan_record_id tmp_rec_id;
-    struct darshan_core_record_ref* ref;
+    struct darshan_core_record_ref *ref;
     if(!darshan_core)
         return;
@@ -1523,7 +1550,15 @@ void darshan_core_lookup_record_id(
     HASH_FIND(hlink, darshan_core->rec_hash, &tmp_rec_id, sizeof(darshan_record_id), ref);
     if(!ref)
-        /* if not, add this record to the hash */
+        /* record not found -- add it to the hash if we aren't already tracking the
+         * maximum number of records
+        if(darshan_core->rec_count >= DARSHAN_CORE_MAX_RECORDS)
+            DARSHAN_CORE_UNLOCK();
+            return;
         ref = malloc(sizeof(struct darshan_core_record_ref));
         if(ref)
@@ -1534,16 +1569,41 @@ void darshan_core_lookup_record_id(
                 strcpy(ref->rec.name, name);
             HASH_ADD(hlink, darshan_core->rec_hash, rec.id, sizeof(darshan_record_id), ref);
+            darshan_core->rec_count++;
-    /* TODO: we need a function to disassociate a module with a record id, probably */
-    ref->mod_flags |= (1 << mod_id); /* TODO: MACRO? */
+    ref->mod_flags = DARSHAN_CORE_MOD_SET(ref->mod_flags, mod_id);
     *rec_id = tmp_rec_id;
     return;
+    if(!darshan_core)
+        return;
+    DARSHAN_CORE_LOCK();
+    HASH_FIND(hlink, darshan_core->rec_hash, &rec_id, sizeof(darshan_record_id), ref);
+    assert(ref);
+    /* disassociate this module from the given record id */
+    ref->mod_flags = DARSHAN_CORE_MOD_UNSET(ref->mod_flags, mod_id);
+    if(!(ref->mod_flags))
+        /* if no other modules are associated with this rec, delete it */
+        HASH_DELETE(hlink, darshan_core->rec_hash, ref);
+    return;
 double darshan_core_wtime()
     if(!darshan_core)
diff --git a/darshan-runtime/lib/darshan-posix.c b/darshan-runtime/lib/darshan-posix.c
index 5da3534..3222b71 100644
--- a/darshan-runtime/lib/darshan-posix.c
+++ b/darshan-runtime/lib/darshan-posix.c
@@ -127,7 +127,7 @@ static void posix_file_close_fd(int fd);
 static void posix_disable_instrumentation(void);
 static void posix_prepare_for_reduction(darshan_record_id *shared_recs,
     int *shared_rec_count, void **send_buf, void **recv_buf, int *rec_size);
-static void posix_reduce_record(void* infile_v, void* inoutfile_v,
+static void posix_reduce_records(void* infile_v, void* inoutfile_v,
     int *len, MPI_Datatype *datatype);
 static void posix_get_output_data(void **buffer, int *size);
 static void posix_shutdown(void);
@@ -306,7 +306,7 @@ static void posix_runtime_initialize()
         .disable_instrumentation = &posix_disable_instrumentation,
         .prepare_for_reduction = &posix_prepare_for_reduction,
-        .reduce_record = &posix_reduce_record,
+        .reduce_records = &posix_reduce_records,
         .get_output_data = &posix_get_output_data,
         .shutdown = &posix_shutdown
@@ -350,7 +350,8 @@ static void posix_runtime_initialize()
     memset(posix_runtime->file_record_array, 0, posix_runtime->file_array_size *
            sizeof(struct darshan_posix_file));
-    DARSHAN_MPI_CALL(PMPI_Comm_rank)(MPI_COMM_WORLD, &my_rank); /* TODO: can we move this out of here? */
+    /* TODO: can we move this out of here? perhaps register_module returns rank? */
+    DARSHAN_MPI_CALL(PMPI_Comm_rank)(MPI_COMM_WORLD, &my_rank);
     return;
@@ -369,7 +370,7 @@ static struct posix_runtime_file* posix_file_by_name(const char *name)
         newname = (char*)name;
     /* get a unique id for this file from darshan core */
-    darshan_core_lookup_record_id(
+    darshan_core_register_record(
         (void*)newname,
         strlen(newname),
         1,
@@ -548,7 +549,7 @@ static void posix_prepare_for_reduction(
     *rec_size = sizeof(struct darshan_posix_file);
-    /* TODO: HACK-Y -- how can we do this in a cleaner way?? */
+    /* TODO: cleaner way to do this? */
     if(my_rank == 0)
         posix_runtime->red_buf = *recv_buf;
     posix_runtime->shared_rec_count = *shared_rec_count;
@@ -556,7 +557,7 @@ static void posix_prepare_for_reduction(
     return;
     void* infile_v,
     void* inoutfile_v,
     int *len,
@@ -605,7 +606,7 @@ static void posix_get_output_data(
     assert(posix_runtime);
     /* clean up reduction state */
     if(my_rank == 0)
hooks/post-receive
More information about the Darshan-commits mailing list
