[Darshan-commits] [Darshan] branch, dev-modular, updated. darshan-2.3.1-106-g28f1940
Service Account git at mcs.anl.gov
Tue Jun 30 22:28:22 CDT 2015
This is an automated email from the git hooks/post-receive script. It was
generated because a ref change was pushed to the repository containing
the project "".
The branch, dev-modular has been updated
       via  28f19402834f8b016441741b7dd87c0b4859e9f7 (commit)
      from  faa3101fd3c8aac2d7f3b51106b3a84f96a6b6f8 (commit)
Those revisions listed above that are new to this repository have
not appeared on any other notification email; so we list those
revisions in full, below.
- Log -----------------------------------------------------------------
commit 28f19402834f8b016441741b7dd87c0b4859e9f7
Author: Shane Snyder <ssnyder at mcs.anl.gov>
Date:   Tue Jun 30 22:27:40 2015 -0500
    add aio and lio wrappers to posix module
Summary of changes:
 darshan-posix-log-format.h            |   10 +-
 darshan-runtime/darshan-posix-ld-opts |    8 +
 darshan-runtime/lib/darshan-posix.c   |  265 ++++++++++++++++++++++++++++++++-
 3 files changed, 277 insertions(+), 6 deletions(-)
Diff of changes:
diff --git a/darshan-posix-log-format.h b/darshan-posix-log-format.h
index 3041da6..b3c5f20 100644
--- a/darshan-posix-log-format.h
+++ b/darshan-posix-log-format.h
@@ -105,10 +105,12 @@ enum darshan_posix_f_indices
     /* Total I/O and meta time consumed by fastest and slowest ranks */
     POSIX_F_FASTEST_RANK_TIME,
     POSIX_F_SLOWEST_RANK_TIME,
-#if 0
-    F_VARIANCE_RANK_TIME,
-    F_VARIANCE_RANK_BYTES,
-#endif
+    /* TODO we need to be able to run more reduction operations to get
+     * time and byte variances for shared files. currently, darshan-core
+     * just runs a single reduction, which is used to reduce all other
+     * shared record fields. */
+    //F_VARIANCE_RANK_TIME,
+    //F_VARIANCE_RANK_BYTES,
     POSIX_F_NUM_INDICES,
diff --git a/darshan-runtime/darshan-posix-ld-opts b/darshan-runtime/darshan-posix-ld-opts
index 4521894..1f969ad 100644
--- a/darshan-runtime/darshan-posix-ld-opts
+++ b/darshan-runtime/darshan-posix-ld-opts
@@ -33,3 +33,11 @@
 --wrap=fdatasync
 --wrap=close
 --wrap=fclose
+--wrap=aio_read
+--wrap=aio_write
+--wrap=aio_read64
+--wrap=aio_write64
+--wrap=aio_return
+--wrap=aio_return64
+--wrap=lio_listio
+--wrap=lio_listio64
diff --git a/darshan-runtime/lib/darshan-posix.c b/darshan-runtime/lib/darshan-posix.c
index 07aa532..4d295bd 100644
--- a/darshan-runtime/lib/darshan-posix.c
+++ b/darshan-runtime/lib/darshan-posix.c
@@ -27,6 +27,8 @@
 #include <pthread.h>
 #include "uthash.h"
+#include "utlist.h"
 #include "darshan.h"
 #include "darshan-posix-log-format.h"
@@ -79,8 +81,14 @@ DARSHAN_FORWARD_DECL(fsync, int, (int fd));
 DARSHAN_FORWARD_DECL(fdatasync, int, (int fd));
 DARSHAN_FORWARD_DECL(close, int, (int fd));
 DARSHAN_FORWARD_DECL(fclose, int, (FILE *fp));
-/* TODO aio */
-/* TODO listio */
+DARSHAN_FORWARD_DECL(aio_read, int, (struct aiocb *aiocbp));
+DARSHAN_FORWARD_DECL(aio_write, int, (struct aiocb *aiocbp));
+DARSHAN_FORWARD_DECL(aio_read64, int, (struct aiocb64 *aiocbp));
+DARSHAN_FORWARD_DECL(aio_write64, int, (struct aiocb64 *aiocbp));
+DARSHAN_FORWARD_DECL(aio_return, ssize_t, (struct aiocb *aiocbp));
+DARSHAN_FORWARD_DECL(aio_return64, ssize_t, (struct aiocb64 *aiocbp));
+DARSHAN_FORWARD_DECL(lio_listio, int, (int mode, struct aiocb *const aiocb_list[], int nitems, struct sigevent *sevp));
+DARSHAN_FORWARD_DECL(lio_listio64, int, (int mode, struct aiocb64 *const aiocb_list[], int nitems, struct sigevent *sevp));
 /* maximum number of access sizes and stride sizes that darshan will track
  * per file at runtime; at log time they will be reduced into the 4 most
@@ -106,6 +114,14 @@ struct posix_access_counter
     int freq;
+/* struct to track information about aio operations in flight */
+struct posix_aio_tracker
+    double tm1;
+    void *aiocbp;
+    struct posix_aio_tracker* next;
 /* The posix_file_runtime structure maintains necessary runtime metadata
  * for the POSIX file record (darshan_posix_file structure, defined in
  * darshan-posix-log-format.h) pointed to by 'file_record'. This metadata
@@ -143,6 +159,7 @@ struct posix_file_runtime
     int access_count;
     void* stride_root;
     int stride_count;
+    struct posix_aio_tracker* aio_list;
     UT_hash_handle hlink;
@@ -214,6 +231,8 @@ static void posix_access_walker(const void* nodep, const VISIT which, const int
 static void posix_walk_file_accesses(void);
 static int posix_access_compare(const void* a_p, const void* b_p);
 static int posix_file_compare(const void* a, const void* b);
+static void posix_aio_tracker_add(int fd, void *aiocbp);
+static struct posix_aio_tracker* posix_aio_tracker_del(int fd, void *aiocbp);
 static void posix_begin_shutdown(void);
 static void posix_setup_reduction(darshan_record_id *shared_recs, int *shared_rec_count,
@@ -1285,6 +1304,200 @@ int DARSHAN_DECL(fclose)(FILE *fp)
     return(ret);
+int DARSHAN_DECL(aio_read)(struct aiocb *aiocbp)
+    int ret;
+    MAP_OR_FAIL(aio_read);
+    ret = __real_aio_read(aiocbp);
+    if(ret == 0)
+        POSIX_LOCK();
+        posix_runtime_initialize();
+        posix_aio_tracker_add(aiocbp->aio_fildes, aiocbp);
+        POSIX_UNLOCK();
+    return(ret);
+int DARSHAN_DECL(aio_write)(struct aiocb *aiocbp)
+    int ret;
+    MAP_OR_FAIL(aio_write);
+    ret = __real_aio_write(aiocbp);
+    if(ret == 0)
+        POSIX_LOCK();
+        POSIX_UNLOCK();
+    return(ret);
+int DARSHAN_DECL(aio_read64)(struct aiocb64 *aiocbp)
+    int ret;
+    MAP_OR_FAIL(aio_read64);
+    ret = __real_aio_read64(aiocbp);
+    if(ret == 0)
+        POSIX_LOCK();
+        POSIX_UNLOCK();
+    return(ret);
+int DARSHAN_DECL(aio_write64)(struct aiocb64 *aiocbp)
+    int ret;
+    MAP_OR_FAIL(aio_write64);
+    ret = __real_aio_write64(aiocbp);
+    if(ret == 0)
+        POSIX_LOCK();
+        POSIX_UNLOCK();
+    return(ret);
+ssize_t DARSHAN_DECL(aio_return)(struct aiocb *aiocbp)
+    int ret;
+    double tm2;
+    struct posix_aio_tracker *tmp;
+    int aligned_flag = 0;
+    MAP_OR_FAIL(aio_return);
+    ret = __real_aio_return(aiocbp);
+    tm2 = darshan_core_wtime();
+    POSIX_LOCK();
+    tmp = posix_aio_tracker_del(aiocbp->aio_fildes, aiocbp);
+    if (tmp)
+        if((unsigned long)aiocbp->aio_buf % darshan_mem_alignment == 0)
+            aligned_flag = 1;
+        if(aiocbp->aio_lio_opcode == LIO_WRITE)
+            POSIX_RECORD_WRITE(ret, aiocbp->aio_fildes,
+                1, aiocbp->aio_offset, aligned_flag, 0,
+                tmp->tm1, tm2);
+        else if(aiocbp->aio_lio_opcode == LIO_READ)
+            POSIX_RECORD_READ(ret, aiocbp->aio_fildes,
+                tmp->tm1, tm2);
+        free(tmp);
+    POSIX_UNLOCK();
+    return(ret);
+ssize_t DARSHAN_DECL(aio_return64)(struct aiocb64 *aiocbp)
+    int ret;
+    double tm2;
+    MAP_OR_FAIL(aio_return64);
+    ret = __real_aio_return64(aiocbp);
+    POSIX_LOCK();
+    if (tmp)
+            aligned_flag = 1;
+                tmp->tm1, tm2);
+                tmp->tm1, tm2);
+        free(tmp);
+    POSIX_UNLOCK();
+    return(ret);
+int DARSHAN_DECL(lio_listio)(int mode, struct aiocb *const aiocb_list[],
+    int nitems, struct sigevent *sevp)
+    int ret;
+    int i;
+    MAP_OR_FAIL(lio_listio);
+    ret = __real_lio_listio(mode, aiocb_list, nitems, sevp);
+    if(ret == 0)
+        POSIX_LOCK();
+        for(i = 0; i < nitems; i++)
+            posix_aio_tracker_add(aiocb_list[i]->aio_fildes, aiocb_list[i]);
+        POSIX_UNLOCK();
+    return(ret);
+int DARSHAN_DECL(lio_listio64)(int mode, struct aiocb64 *const aiocb_list[],
+    int ret;
+    int i;
+    MAP_OR_FAIL(lio_listio64);
+    ret = __real_lio_listio64(mode, aiocb_list, nitems, sevp);
+    if(ret == 0)
+        POSIX_LOCK();
+        POSIX_UNLOCK();
+    return(ret);
  * Internal functions for manipulating POSIX module state *
@@ -1623,6 +1836,54 @@ static int posix_file_compare(const void* a_p, const void* b_p)
     return 0;
+/* adds a tracker for the given aio operation */
+    struct posix_aio_tracker* tracker;
+    struct posix_file_runtime* file;
+    file = posix_file_by_fd(fd);
+    if (file)
+        tracker = malloc(sizeof(*tracker));
+        if (tracker)
+            tracker->tm1 = darshan_core_wtime();
+            tracker->aiocbp = aiocbp;
+            LL_PREPEND(file->aio_list, tracker);
+    return;
+/* finds the tracker structure for a given aio operation, removes it from
+ * the linked list for the darshan_file structure, and returns a pointer.
+ * returns NULL if aio operation not found
+    struct posix_aio_tracker *tracker = NULL, *iter, *tmp;
+    if (file)
+        LL_FOREACH_SAFE(file->aio_list, iter, tmp)
+            if (iter->aiocbp == aiocbp)
+                LL_DELETE(file->aio_list, iter);
+                tracker = iter;
+                break;
+    return(tracker);
  * Functions exported by this module for coordinating with darshan-core *
hooks/post-receive
More information about the Darshan-commits mailing list
