[Darshan-commits] [Darshan] branch, trac-150-regression, updated. darshan-2.3.1-pre1-5-g34b666a
Service Account
git at mcs.anl.gov
Thu Jan 29 13:57:55 CST 2015
This is an automated email from the git hooks/post-receive script. It was
generated because a ref change was pushed to the repository containing
the project "".
The branch, trac-150-regression has been updated
via 34b666ac054982410282b84b454c0a538c9150ae (commit)
from edfe5fab24434c220f2f0ef32d192d7954e434fa (commit)
Those revisions listed above that are new to this repository have
not appeared on any other notification email; so we list those
revisions in full, below.
- Log -----------------------------------------------------------------
commit 34b666ac054982410282b84b454c0a538c9150ae
Author: Phil Carns <carns at mcs.anl.gov>
Date: Thu Jan 29 14:57:42 2015 -0500
stub in subdirs for platforms and test cases
Summary of changes:
darshan-test/regression/run-all.sh | 28 +-
darshan-test/regression/test-cases/mpi-io-test.sh | 9 +
.../regression/test-cases/src/mpi-io-test.c | 443 ++++++++++++++++++++
darshan-test/regression/ws/setup-cc.sh | 26 ++
4 files changed, 500 insertions(+), 6 deletions(-)
create mode 100755 darshan-test/regression/test-cases/mpi-io-test.sh
create mode 100644 darshan-test/regression/test-cases/src/mpi-io-test.c
create mode 100755 darshan-test/regression/ws/setup-cc.sh
Diff of changes:
diff --git a/darshan-test/regression/run-all.sh b/darshan-test/regression/run-all.sh
index 89c988f..09b1f49 100755
--- a/darshan-test/regression/run-all.sh
+++ b/darshan-test/regression/run-all.sh
@@ -1,8 +1,8 @@
#!/bin/bash
if [ "$#" -ne 3 ]; then
- echo "Usage: run-all.sh <darshan_install_path> <tmp_path> <platform>"
- echo "Example: ./run-all.sh ~/darshan-install /tmp/test ws"
+ echo "Usage: run-all.sh <darshan_install_path> <tmp_path> <platform>" 1>&2
+ echo "Example: ./run-all.sh ~/darshan-install /tmp/test ws" 1>&2
exit 1
fi
@@ -13,7 +13,7 @@ export DARSHAN_PLATFORM=$3
# check darshan path
if [ ! -x $DARSHAN_PATH/bin/darshan-parser ]; then
- echo "Error: $DARSHAN_PATH doesn't contain a valid Darshan install."
+ echo "Error: $DARSHAN_PATH doesn't contain a valid Darshan install." 1>&2
exit 1
fi
@@ -23,18 +23,34 @@ if [ ! -d $DARSHAN_TMP ]; then
fi
- echo "Error: unable to find or create $DARSHAN_TMP"
+ echo "Error: unable to find or create $DARSHAN_TMP" 1>&2
exit 1
fi
if [ ! -w $DARSHAN_TMP ]; then
- echo "Error: unable to write to $DARSHAN_TMP"
+ echo "Error: unable to write to $DARSHAN_TMP" 1>&2
exit 1
fi
# make sure that we have sub-scripts for the specified platform
if [ ! -d $DARSHAN_PLATFORM ]; then
- echo "Error: unable to find scripts for platform $DARSHAN_PLATFORM"
+ echo "Error: unable to find scripts for platform $DARSHAN_PLATFORM" 1>&2
exit 1
fi
+# set up c compiler for this platform
+DARSHAN_CC=`$DARSHAN_PLATFORM/setup-cc.sh`
+if [ $? != 0 ]; then
+ exit 1
+fi
+export DARSHAN_CC
+for i in `ls test-cases/*.sh`; do
+ $i
+ if [ $? != 0 ]; then
+ echo "Error: failed to execute test case $i"
+ exit 1
+ fi
+done
exit 0
diff --git a/darshan-test/regression/test-cases/mpi-io-test.sh b/darshan-test/regression/test-cases/mpi-io-test.sh
new file mode 100755
index 0000000..13792f8
--- /dev/null
+++ b/darshan-test/regression/test-cases/mpi-io-test.sh
@@ -0,0 +1,9 @@
+#!/bin/bash
+$DARSHAN_CC test-cases/src/mpi-io-test.c -o $DARSHAN_TMP/mpi-io-test
+ echo "Error: failed to compile mpi-io-test" 1>&2
+ exit 1
+fi
+exit 0
diff --git a/darshan-test/regression/test-cases/src/mpi-io-test.c b/darshan-test/regression/test-cases/src/mpi-io-test.c
new file mode 100644
index 0000000..152c24b
--- /dev/null
+++ b/darshan-test/regression/test-cases/src/mpi-io-test.c
@@ -0,0 +1,443 @@
+ * (C) 1995-2001 Clemson University and Argonne National Laboratory.
+ * See COPYING in top-level directory.
+/* mpi-io-test.c
+ * This is derived from code given to me by Rajeev Thakur. Dunno where
+ * it originated.
+ * It's purpose is to produce aggregate bandwidth numbers for varying
+ * block sizes, number of processors, an number of iterations.
+ * This is strictly an MPI program - it is used to test the MPI I/O
+ * functionality implemented by Romio.
+ * Compiling is usually easiest with something like:
+ * mpicc -Wall -Wstrict-prototypes mpi-io-test.c -o mpi-io-test
+ * NOTE: This code assumes that all command line arguments make it out to all
+ * the processes that make up the parallel job, which isn't always the case.
+ * So if it doesn't work on some platform, that might be why.
+#include <stdio.h>
+#include <stdlib.h>
+#include <fcntl.h>
+#include <unistd.h>
+#include <string.h>
+#include <sys/time.h>
+#include <mpi.h>
+#include <errno.h>
+#include <getopt.h>
+/* DEFAULT VALUES FOR OPTIONS */
+static int64_t opt_block = 16*1024*1024;
+static int opt_iter = 1;
+static int opt_coll = 0;
+static int opt_correct = 0;
+static int opt_sync = 0;
+static int opt_single = 0;
+static int opt_verbose = 0;
+static int opt_rdonly = 0;
+static int opt_wronly = 0;
+static char opt_file[256] = "test.out";
+static char opt_pvfs2tab[256] = "notset";
+static int opt_pvfstab_set = 0;
+/* function prototypes */
+static int parse_args(int argc, char **argv);
+static void usage(void);
+static void handle_error(int errcode, char *str);
+/* global vars */
+static int mynod = 0;
+static int nprocs = 1;
+int main(int argc, char **argv)
+ char *buf, *tmp=NULL, *check;
+ int i, j, v, err, sync_err=0, my_correct = 1, correct, myerrno;
+ double stim, etim;
+ double write_tim = 0;
+ double read_tim = 0;
+ double read_bw, write_bw;
+ double max_read_tim, max_write_tim;
+ double min_read_tim, min_write_tim;
+ double ave_read_tim, ave_write_tim;
+ double sum_read_tim, sum_write_tim;
+ double sq_write_tim, sq_read_tim;
+ double sumsq_write_tim, sumsq_read_tim;
+ double var_read_tim, var_write_tim;
+ int64_t iter_jump = 0;
+ int64_t seek_position = 0;
+ MPI_File fh;
+ MPI_Status status;
+ MPI_Comm comm;
+ int nchars=0;
+ int namelen;
+ char processor_name[MPI_MAX_PROCESSOR_NAME];
+ /* startup MPI and determine the rank of this process */
+ MPI_Init(&argc,&argv);
+ MPI_Comm_size(MPI_COMM_WORLD, &nprocs);
+ MPI_Comm_rank(MPI_COMM_WORLD, &mynod);
+ MPI_Get_processor_name(processor_name, &namelen);
+ /* parse the command line arguments */
+ parse_args(argc, argv);
+ if (opt_verbose) fprintf(stdout,"Process %d of %d is on %s\n",
+ mynod, nprocs, processor_name);
+ if (mynod == 0) printf("# Using mpi-io calls.\n");
+ //sleep(15);
+ /* kindof a weird hack- if the location of the pvfstab file was
+ * specified on the command line, then spit out this location into
+ * the appropriate environment variable: */
+ if (opt_pvfstab_set) {
+ if ((setenv("PVFS2TAB_FILE", opt_pvfs2tab, 1)) < 0) {
+ perror("setenv");
+ goto die_jar_jar_die;
+ /* this is how much of the file data is covered on each iteration of
+ * the test. used to help determine the seek offset on each
+ * iteration */
+ iter_jump = nprocs * opt_block;
+ /* setup a buffer of data to write */
+ if (!(tmp = malloc((size_t) opt_block + 256))) {
+ perror("malloc");
+ buf = tmp + 128 - (((long)tmp) % 128); /* align buffer */
+ /* open the file for writing */
+ if (opt_coll) {
+ comm = MPI_COMM_WORLD;
+ else {
+ comm = MPI_COMM_SELF;
+ err = MPI_File_open(comm, opt_file,
+ MPI_MODE_CREATE | MPI_MODE_RDWR, MPI_INFO_NULL, &fh);
+ if (err != MPI_SUCCESS) {
+ handle_error(err, "MPI_File_open");
+ nchars = (int) (opt_block/sizeof(char));
+ if (!opt_rdonly) {
+ /* now repeat the seek and write operations the number of times
+ * specified on the command line */
+ for (j=0; j < opt_iter; j++) {
+ /* reading and writing to the same block is cheating, but sometimes
+ * we want to measure cached performance of file servers */
+ if (opt_single == 1)
+ seek_position = 0;
+ else
+ /* seek to an appropriate position depending on the iteration
+ * and rank of the current process */
+ seek_position = (j*iter_jump)+(mynod*opt_block);
+ MPI_File_seek(fh, seek_position, MPI_SEEK_SET);
+ if (opt_correct) /* fill in buffer for iteration */ {
+ for (i=0, v=mynod+j, check=buf; i<opt_block; i++, v++, check++)
+ *check = (char) v;
+ /* discover the starting time of the operation */
+ MPI_Barrier(MPI_COMM_WORLD);
+ stim = MPI_Wtime();
+ /* write out the data */
+ if (opt_coll) {
+ err = MPI_File_write_all(fh, buf, nchars, MPI_CHAR, &status);
+ else {
+ err = MPI_File_write(fh, buf, nchars, MPI_CHAR, &status);
+ if(err){
+ fprintf(stderr, "node %d, write error: %s\n", mynod,
+ strerror(errno));
+ if (opt_sync) sync_err = MPI_File_sync(fh);
+ if (sync_err) {
+ fprintf(stderr, "node %d, sync error: %s\n", mynod,
+ strerror(errno));
+ /* discover the ending time of the operation */
+ etim = MPI_Wtime();
+ write_tim += (etim - stim);
+ /* we are done with this "write" iteration */
+ } /* ! opt_rdonly */
+ err = MPI_File_close(&fh);
+ if(err){
+ fprintf(stderr, "node %d, close error after write\n", mynod);
+ /* wait for everyone to synchronize at this point */
+ /* reopen the file to read the data back out */
+ if (err < 0) {
+ fprintf(stderr, "node %d, open error: %s\n", mynod, strerror(errno));
+ if (!opt_wronly) {
+ /* we are going to repeat the read operation the number of iterations
+ * specified */
+ if (opt_single == 1) {
+ else {
+ /* discover the start time */
+ /* read in the file data */
+ if (opt_coll) {
+ err = MPI_File_read_all(fh, buf, nchars, MPI_CHAR, &status);
+ else {
+ err = MPI_File_read(fh, buf, nchars, MPI_CHAR, &status);
+ myerrno = errno;
+ /* discover the end time */
+ read_tim += (etim - stim);
+ if (err < 0) {
+ fprintf(stderr, "node %d, read error, loc = %lld: %s\n",
+ mynod, (long long) mynod*opt_block, strerror(myerrno));
+ /* if the user wanted to check correctness, compare the write
+ * buffer to the read buffer */
+ if (opt_correct) {
+ int badct = 0;
+ i < opt_block && badct < 10;
+ i++, v++, check++)
+ if (*check != (char) v) {
+ my_correct = 0;
+ if (badct < 10) {
+ badct++;
+ fprintf(stderr, "buf[%d] = %d, should be %d\n",
+ i, *check, (char) v);
+ MPI_Allreduce(&my_correct, &correct, 1, MPI_INT, MPI_MIN,
+ MPI_COMM_WORLD);
+ if (badct == 10) fprintf(stderr, "...\n");
+ /* we are done with this read iteration */
+ } /* !opt_wronly */
+ /* close the file */
+ if (err) {
+ /* compute the read and write times */
+ MPI_Allreduce(&read_tim, &max_read_tim, 1, MPI_DOUBLE, MPI_MAX,
+ MPI_COMM_WORLD);
+ MPI_Allreduce(&read_tim, &min_read_tim, 1, MPI_DOUBLE, MPI_MIN,
+ MPI_COMM_WORLD);
+ MPI_Allreduce(&read_tim, &sum_read_tim, 1, MPI_DOUBLE, MPI_SUM,
+ MPI_COMM_WORLD);
+ /* calculate our part of the summation used for variance */
+ sq_read_tim = read_tim - (sum_read_tim / nprocs);
+ sq_read_tim = sq_read_tim * sq_read_tim;
+ MPI_Allreduce(&sq_read_tim, &sumsq_read_tim, 1, MPI_DOUBLE,
+ MPI_SUM, MPI_COMM_WORLD);
+ MPI_Allreduce(&write_tim, &max_write_tim, 1, MPI_DOUBLE, MPI_MAX,
+ MPI_COMM_WORLD);
+ MPI_Allreduce(&write_tim, &min_write_tim, 1, MPI_DOUBLE, MPI_MIN,
+ MPI_COMM_WORLD);
+ MPI_Allreduce(&write_tim, &sum_write_tim, 1, MPI_DOUBLE, MPI_SUM,
+ MPI_COMM_WORLD);
+ sq_write_tim = write_tim - (sum_write_tim / nprocs );
+ sq_write_tim = sq_write_tim * sq_write_tim;
+ MPI_Allreduce(&sq_write_tim, &sumsq_write_tim, 1, MPI_DOUBLE,
+ /* calculate the average from the sum */
+ ave_read_tim = sum_read_tim / nprocs;
+ ave_write_tim = sum_write_tim / nprocs;
+ /* and finally compute variance */
+ if (nprocs > 1) {
+ var_read_tim = sumsq_read_tim / (nprocs-1);
+ var_write_tim = sumsq_write_tim / (nprocs-1);
+ else {
+ var_read_tim = 0;
+ var_write_tim = 0;
+ /* print out the results on one node */
+ if (mynod == 0) {
+ read_bw = (opt_block*nprocs*opt_iter)/(max_read_tim*1.0e6);
+ write_bw = (opt_block*nprocs*opt_iter)/(max_write_tim*1.0e6);
+ printf("nr_procs = %d, nr_iter = %d, blk_sz = %lld, coll = %d\n",
+ nprocs, opt_iter, (long long) opt_block, opt_coll);
+ printf("# total_size = %lld\n",
+ (long long) opt_block*nprocs*opt_iter);
+ printf("# Write: min_t = %f, max_t = %f, mean_t = %f, var_t = %f\n",
+ min_write_tim, max_write_tim, ave_write_tim, var_write_tim);
+ printf("# Read: min_t = %f, max_t = %f, mean_t = %f, var_t = %f\n",
+ min_read_tim, max_read_tim, ave_read_tim, var_read_tim);
+ printf("Write bandwidth = %f Mbytes/sec\n", write_bw);
+ printf("Read bandwidth = %f Mbytes/sec\n", read_bw);
+ printf("Correctness test %s.\n", correct ? "passed" : "failed");
+die_jar_jar_die:
+ free(tmp);
+ MPI_Finalize();
+ return(0);
+ int c;
+ while ((c = getopt(argc, argv, "b:i:f:p:CcyShvrw")) != EOF) {
+ switch (c) {
+ case 'b': /* block size */
+ opt_block = atoi(optarg);
+ break;
+ case 'i': /* iterations */
+ opt_iter = atoi(optarg);
+ break;
+ case 'f': /* filename */
+ strncpy(opt_file, optarg, 255);
+ break;
+ case 'p': /* pvfstab file */
+ strncpy(opt_pvfs2tab, optarg, 255);
+ opt_pvfstab_set = 1;
+ break;
+ case 'c': /* correctness */
+ opt_correct = 1;
+ break;
+ case 'C': /* collective I/O */
+ opt_coll = 1;
+ break;
+ case 'y': /* sYnc */
+ opt_sync = 1;
+ break;
+ case 'S': /* Single region */
+ opt_single = 1;
+ break;
+ case 'v': /* verbose */
+ opt_verbose = 1;
+ break;
+ case 'r': /* read-only */
+ opt_rdonly = 1;
+ break;
+ case 'w': /* write-only */
+ opt_wronly = 1;
+ break;
+ case 'h':
+ if (mynod == 0)
+ usage();
+ exit(0);
+ case '?': /* unknown */
+ if (mynod == 0)
+ usage();
+ exit(1);
+ default:
+ break;
+ return(0);
+ printf("Usage: mpi-io-test [<OPTIONS>...]\n");
+ printf("\n<OPTIONS> is one of\n");
+ printf(" -b block size (in bytes) [default: 16777216]\n");
+ printf(" -c verify correctness of file data [default: off]\n");
+ printf(" -C perform operations Collectively [default: off]\n");
+ printf(" -i iterations [default: 1]\n");
+ printf(" -f filename [default: /foo/test.out]\n");
+ printf(" -p path to pvfs2tab file to use [default: notset]\n");
+ printf(" -S all process write to same Single region of file [default: off]\n");
+ printf(" -r read-only. do no writes. file must already exist\n");
+ printf(" -w write-only. do no reads.\n");
+ printf(" -v be more verbose\n");
+ printf(" -y sYnc the file after each write [default: off]\n");
+ printf(" -h print this help\n");
+ char msg[MPI_MAX_ERROR_STRING];
+ int resultlen;
+ MPI_Error_string(errcode, msg, &resultlen);
+ fprintf(stderr, "%s: %s\n", str, msg);
+ MPI_Abort(MPI_COMM_WORLD, 1);
+ * Local variables:
+ * c-indent-level: 3
+ * c-basic-offset: 3
+ * tab-width: 3
+ * vim: ts=3
+ * End:
diff --git a/darshan-test/regression/ws/setup-cc.sh b/darshan-test/regression/ws/setup-cc.sh
index 0000000..2d40d77
--- /dev/null
+++ b/darshan-test/regression/ws/setup-cc.sh
@@ -0,0 +1,26 @@
+#!/bin/bash
+# General notes
+# Script to set up the C compiler to use for subsequent test cases. This
+# script may load optional modules (as in a Cray PE), set LD_PRELOAD
+# variables (as in a dynamically linked environment), or generate mpicc
+# wrappers (as in a statically linked environment).
+# The script should produce a single string to stdout, which is the command
+# line to use for invoking the C compiler
+# Notes specific to this platform (ws)
+# This particular version of the setup-cc script assumes that mpicc is
+# present in the path already, and that the C compiler to use for
+# subsequent tests should be generated from this using darshan-gen-cc.pl.
+$DARSHAN_PATH/bin/darshan-gen-cc.pl `which mpicc` --output $DARSHAN_TMP/mpicc
+ echo "Error: failed to generate c compiler." 1>&2
+ exit 1
+fi
+echo $DARSHAN_TMP/mpicc
+exit 0
hooks/post-receive
More information about the Darshan-commits
