[Darshan-commits] [Darshan] branch, dev-modular, updated. 8f85fd08a49f9c2862ae1636b3ed46f609806239
Service Account
git at mcs.anl.gov
Fri Feb 20 16:57:43 CST 2015
This is an automated email from the git hooks/post-receive script. It was
generated because a ref change was pushed to the repository containing
the project "".
The branch, dev-modular has been updated
via 8f85fd08a49f9c2862ae1636b3ed46f609806239 (commit)
from efd500f045180f703b65ec537ed312c7bb13b40e (commit)
Those revisions listed above that are new to this repository have
not appeared on any other notification email; so we list those
revisions in full, below.
- Log -----------------------------------------------------------------
commit 8f85fd08a49f9c2862ae1636b3ed46f609806239
Author: Shane Snyder <ssnyder at mcs.anl.gov>
Date: Fri Feb 20 16:56:39 2015 -0600
log compression good to go, revamped logutils
Summary of changes:
darshan-runtime/darshan-core.h | 5 +
darshan-runtime/lib/darshan-core.c | 213 ++++++++++++++++++++++--------
darshan-util/darshan-logutils.c | 254 ++++++++++++++++++++++++++++++-----
darshan-util/darshan-logutils.h | 3 +-
darshan-util/darshan-posix-parser.c | 42 ++++---
5 files changed, 412 insertions(+), 105 deletions(-)
Diff of changes:
diff --git a/darshan-runtime/darshan-core.h b/darshan-runtime/darshan-core.h
index 7d98d71..8ecddaf 100644
--- a/darshan-runtime/darshan-core.h
+++ b/darshan-runtime/darshan-core.h
@@ -15,6 +15,10 @@
/* TODO: enforce this when handing out ids */
#define DARSHAN_CORE_MAX_RECORDS 1024
+/* default compression buffer size of 2 MiB */
+/* TODO: revisit this default size if we change memory per module */
+#define DARSHAN_COMP_BUF_SIZE (2 * 1024 * 1024)
struct darshan_core_module
darshan_module_id id;
@@ -28,6 +32,7 @@ struct darshan_core_runtime
char exe[DARSHAN_EXE_LEN+1];
struct darshan_core_record_ref *rec_hash;
struct darshan_core_module* mod_array[DARSHAN_MAX_MODS];
+ char comp_buf[DARSHAN_COMP_BUF_SIZE];
double wtime_offset;
char *trailing_data;
diff --git a/darshan-runtime/lib/darshan-core.c b/darshan-runtime/lib/darshan-core.c
index 0bf770e..419291f 100644
--- a/darshan-runtime/lib/darshan-core.c
+++ b/darshan-runtime/lib/darshan-core.c
@@ -69,8 +69,10 @@ static void darshan_get_shared_record_ids(
struct darshan_core_runtime *core, darshan_record_id *shared_recs);
static int darshan_log_coll_open(
char *logfile_name, MPI_File *log_fh);
+static int darshan_compress_buffer(void **pointers, int *lengths,
+ int count, char *comp_buf, int *comp_length);
static int darshan_log_write_record_hash(
- MPI_File log_fh, struct darshan_core_record_ref *rec_hash,
+ MPI_File log_fh, struct darshan_core_runtime *core,
darshan_record_id *shared_recs, struct darshan_log_map *map);
static int darshan_log_coll_write(
MPI_File log_fh, void *buf, int count, struct darshan_log_map *map);
@@ -139,7 +141,6 @@ static void darshan_core_initialize(int *argc, char ***argv)
if(internal_timing_flag)
init_start = DARSHAN_MPI_CALL(PMPI_Wtime)();
- DARSHAN_CORE_LOCK();
/* setup darshan runtime if darshan is enabled and hasn't been initialized already */
if(!getenv("DARSHAN_DISABLE") && !darshan_core)
@@ -191,7 +192,6 @@ static void darshan_core_initialize(int *argc, char ***argv)
darshan_core->trailing_data = darshan_get_exe_and_mounts(darshan_core);
- DARSHAN_CORE_UNLOCK();
@@ -230,7 +230,7 @@ static void darshan_core_shutdown()
long offset;
struct darshan_header log_header;
MPI_File log_fh;
- MPI_Offset tmp_off;
+ MPI_Offset tmp_off = 0;
MPI_Status status;
if(getenv("DARSHAN_INTERNAL_TIMING"))
@@ -356,30 +356,37 @@ static void darshan_core_shutdown()
return;
- /* rank 0 is responsible for writing the darshan job information */
+ /* rank 0 is responsible for writing the compressed darshan job information */
if(my_rank == 0)
- unsigned char tmp_buf[DARSHAN_JOB_RECORD_SIZE];
- unsigned char *tmp_ptr;
- /* pack the job info and exe/mount info into a buffer for writing */
- tmp_ptr = tmp_buf;
- memcpy(tmp_ptr, &final_core->log_job, sizeof(struct darshan_job));
- tmp_ptr += sizeof(struct darshan_job);
- memcpy(tmp_ptr, final_core->trailing_data, DARSHAN_EXE_LEN+1);
- /* write the job information, making sure to prealloc space for the log header */
- all_ret = DARSHAN_MPI_CALL(PMPI_File_write_at)(log_fh, sizeof(struct darshan_header),
- tmp_buf, DARSHAN_JOB_RECORD_SIZE, MPI_BYTE, &status);
- if(all_ret != MPI_SUCCESS)
+ void *pointers[2] = {&final_core->log_job, final_core->trailing_data};
+ int lengths[2] = {sizeof(struct darshan_job), DARSHAN_EXE_LEN+1};
+ int comp_buf_sz = 0;
+ /* compress the job info and the trailing mount/exe data */
+ all_ret = darshan_compress_buffer(pointers, lengths, 2,
+ final_core->comp_buf, &comp_buf_sz);
+ if(all_ret)
- fprintf(stderr, "darshan library warning: unable to write job data to log file %s\n",
- logfile_name);
+ fprintf(stderr, "darshan library warning: unable to compress job data\n");
unlink(logfile_name);
+ else
+ /* write the job information, preallocing space for the log header */
+ all_ret = DARSHAN_MPI_CALL(PMPI_File_write_at)(
+ log_fh, sizeof(struct darshan_header), final_core->comp_buf,
+ comp_buf_sz, MPI_BYTE, &status);
+ if(all_ret != MPI_SUCCESS)
+ fprintf(stderr, "darshan library warning: unable to write job data to log file %s\n",
+ logfile_name);
+ unlink(logfile_name);
- /* TODO: after compression is added, this should be fixed */
- log_header.rec_map.off = sizeof(struct darshan_header) + DARSHAN_JOB_RECORD_SIZE;
+ /* set the beginning offset of record hash, which precedes job info just written */
+ log_header.rec_map.off = sizeof(struct darshan_header) + comp_buf_sz;
/* error out if unable to write job information */
@@ -392,8 +399,7 @@ static void darshan_core_shutdown()
/* write the record name->id hash to the log file */
- ret = darshan_log_write_record_hash(log_fh, final_core->rec_hash,
- shared_recs, &log_header.rec_map);
+ ret = darshan_log_write_record_hash(log_fh, final_core, shared_recs, &log_header.rec_map);
/* error out if unable to write record hash */
DARSHAN_MPI_CALL(PMPI_Allreduce)(&ret, &all_ret, 1, MPI_INT,
@@ -402,7 +408,7 @@ static void darshan_core_shutdown()
if(my_rank == 0)
- fprintf(stderr, "darshan library warning: unable to write record map to log file %s\n",
+ fprintf(stderr, "darshan library warning: unable to write record hash to log file %s\n",
logfile_name);
@@ -423,7 +429,8 @@ static void darshan_core_shutdown()
struct darshan_core_module* this_mod = final_core->mod_array[i];
MPI_Comm mod_comm;
void* mod_buf = NULL;
- int mod_buf_size = 0;
+ int mod_buf_sz = 0;
if(!global_mod_use_count[i])
@@ -447,19 +454,33 @@ static void darshan_core_shutdown()
if(local_mod_use[i])
/* get output buffer from module */
- this_mod->mod_funcs.get_output_data(mod_comm, &mod_buf, &mod_buf_size);
+ this_mod->mod_funcs.get_output_data(mod_comm, &mod_buf, &mod_buf_sz);
- /* set the starting offset of this module */
- if(tmp_off == 0)
- tmp_off = log_header.rec_map.off + log_header.rec_map.len;
+ /* compress the module buffer */
+ ret = darshan_compress_buffer((void**)&mod_buf, &mod_buf_sz, 1,
+ if(ret == 0)
+ /* set the starting offset of this module */
+ if(tmp_off == 0)
+ tmp_off = log_header.rec_map.off + log_header.rec_map.len;
- log_header.mod_map[i].off = tmp_off;
+ log_header.mod_map[i].off = tmp_off;
- /* write module data buffer to the darshan log file */
- ret = darshan_log_coll_write(log_fh, mod_buf, mod_buf_size, &log_header.mod_map[i]);
+ /* write (compressed) module data buffer to the darshan log file */
+ ret = darshan_log_coll_write(log_fh, final_core->comp_buf, comp_buf_sz,
+ &log_header.mod_map[i]);
+ else
+ /* error in compression, participate in collective write to avoid
+ * deadlock, but preserve return value to terminate darshan_shutdown.
+ (void)darshan_log_coll_write(log_fh, NULL, 0, &log_header.mod_map[i]);
- /* error out if unable to write this module's data */
+ /* error out if the compression or collective write failed */
MPI_LOR, MPI_COMM_WORLD);
if(all_ret != 0)
@@ -1050,10 +1071,81 @@ static int darshan_log_coll_open(char *logfile_name, MPI_File *log_fh)
return(0);
+static int darshan_compress_buffer(void **pointers, int *lengths, int count,
+ char *comp_buf, int *comp_length)
+ int ret = 0;
+ int i;
+ int total_target = 0;
+ z_stream tmp_stream;
+ memset(&tmp_stream, 0, sizeof(tmp_stream));
+ tmp_stream.zalloc = Z_NULL;
+ tmp_stream.zfree = Z_NULL;
+ tmp_stream.opaque = Z_NULL;
+ /* initialize the zlib compression parameters */
+ /* TODO: check these parameters? */
+// ret = deflateInit2(&tmp_stream, Z_DEFAULT_COMPRESSION, Z_DEFLATED,
+// 31, 8, Z_DEFAULT_STRATEGY);
+ ret = deflateInit(&tmp_stream, Z_DEFAULT_COMPRESSION);
+ if(ret != Z_OK)
+ return(-1);
+ tmp_stream.next_out = comp_buf;
+ tmp_stream.avail_out = DARSHAN_COMP_BUF_SIZE;
+ /* loop over the input pointers */
+ for(i = 0; i < count; i++)
+ total_target += lengths[i];
+ tmp_stream.next_in = pointers[i];
+ tmp_stream.avail_in = lengths[i];
+ /* while we have not finished consuming all of the data available to
+ * this point in the loop
+ while(tmp_stream.total_in < total_target)
+ if(tmp_stream.avail_out == 0)
+ /* We ran out of buffer space for compression. In theory,
+ * we could start using some of the file_array buffer space
+ * without having to malloc again. In practice, this case
+ * is going to be practically impossible to hit.
+ deflateEnd(&tmp_stream);
+ return(-1);
+ /* compress data */
+ ret = deflate(&tmp_stream, Z_NO_FLUSH);
+ if(ret != Z_OK)
+ return(-1);
+ /* flush compression and end */
+ ret = deflate(&tmp_stream, Z_FINISH);
+ if(ret != Z_STREAM_END)
+ return(-1);
+ *comp_length = tmp_stream.total_out;
+ return(0);
/* NOTE: the map written to file may contain duplicate id->name entries if a
* record is opened by multiple ranks, but not all ranks
-static int darshan_log_write_record_hash(MPI_File log_fh, struct darshan_core_record_ref *rec_hash,
+static int darshan_log_write_record_hash(MPI_File log_fh, struct darshan_core_runtime *core,
int i;
@@ -1062,20 +1154,20 @@ static int darshan_log_write_record_hash(MPI_File log_fh, struct darshan_core_re
uint32_t name_len;
size_t record_sz;
size_t hash_buf_sz = 0;
- unsigned char *hash_buf;
- unsigned char *hash_buf_off;
+ char *hash_buf;
+ char *hash_buf_off;
MPI_Status status;
- /* non-root ranks (rank > 0) remove shared records from their map --
+ /* non-root ranks (rank > 0) remove shared records from their hash --
* these records will be written by rank 0
if(my_rank > 0)
for(i=0; (i<DARSHAN_CORE_MAX_RECORDS && shared_recs[i]); i++)
- HASH_FIND(hlink, rec_hash, &shared_recs[i], sizeof(darshan_record_id), ref);
+ HASH_FIND(hlink, core->rec_hash, &shared_recs[i], sizeof(darshan_record_id), ref);
assert(ref); /* this id had better be in the hash ... */
- HASH_DELETE(hlink, rec_hash, ref);
+ HASH_DELETE(hlink, core->rec_hash, ref);
if(ref->rec.name) free(ref->rec.name);
free(ref);
@@ -1090,19 +1182,19 @@ static int darshan_log_write_record_hash(MPI_File log_fh, struct darshan_core_re
return(-1);
- /* serialize the record map into a buffer for writing */
+ /* serialize the record hash into a buffer for writing */
hash_buf_off = hash_buf;
- HASH_ITER(hlink, rec_hash, ref, tmp)
+ HASH_ITER(hlink, core->rec_hash, ref, tmp)
name_len = strlen(ref->rec.name);
record_sz = sizeof(darshan_record_id) + sizeof(int) + name_len;
/* make sure there is room in the buffer for this record */
if((hash_buf_off + record_sz) > (hash_buf + hash_buf_sz))
- unsigned char *tmp_buf;
+ char *tmp_buf;
size_t old_buf_sz;
- /* if no room, reallocate the map buffer at twice the current size */
+ /* if no room, reallocate the hash buffer at twice the current size */
old_buf_sz = hash_buf_off - hash_buf;
hash_buf_sz *= 2;
tmp_buf = malloc(hash_buf_sz);
@@ -1118,8 +1210,8 @@ static int darshan_log_write_record_hash(MPI_File log_fh, struct darshan_core_re
hash_buf_off = hash_buf + old_buf_sz;
- /* now serialize the record into the map buffer.
- * NOTE: darshan record map serialization method:
+ /* now serialize the record into the hash buffer.
+ * NOTE: darshan record hash serialization method:
* ... darshan_record_id | (uint32_t) path_len | path ...
*((darshan_record_id *)hash_buf_off) = ref->rec.id;
@@ -1130,11 +1222,27 @@ static int darshan_log_write_record_hash(MPI_File log_fh, struct darshan_core_re
hash_buf_off += name_len;
- /* collectively write out the record map to the darshan log */
+ /* collectively write out the record hash to the darshan log */
if(hash_buf_off > hash_buf)
- /* we have records to contribute to the collective write of the record map */
- ret = darshan_log_coll_write(log_fh, hash_buf, (hash_buf_off-hash_buf), map);
+ int hash_buf_sz = hash_buf_off - hash_buf;
+ /* compress the record hash buffer */
+ ret = darshan_compress_buffer((void **)&hash_buf, &hash_buf_sz, 1,
+ core->comp_buf, &comp_buf_sz);
+ if(ret < 0)
+ /* participate in collective write to avoid deadlock, but preserve
+ * the compression error to pass back to the caller.
+ (void)darshan_log_coll_write(log_fh, NULL, 0, map);
+ else
+ /* we have records to contribute to the write of the record hash */
+ ret = darshan_log_coll_write(log_fh, core->comp_buf, comp_buf_sz, map);
else
@@ -1217,14 +1325,11 @@ void darshan_core_register_module(
struct darshan_core_module* mod;
*runtime_mem_limit = 0;
if(!darshan_core || (id >= DARSHAN_MAX_MODS))
return;
/* see if this module is already registered */
+ DARSHAN_CORE_LOCK();
if(darshan_core->mod_array[id])
/* if module is already registered just return */
@@ -1273,8 +1378,8 @@ void darshan_core_lookup_record_id(
/* hash the input name to get a unique id for this record */
tmp_id = darshan_hash(name, len, 0);
/* check to see if we've already stored the id->name mapping for this record */
HASH_FIND(hlink, darshan_core->rec_hash, &tmp_id, sizeof(darshan_record_id), ref);
if(!ref)
diff --git a/darshan-util/darshan-logutils.c b/darshan-util/darshan-logutils.c
index 7fe7632..a801157 100644
--- a/darshan-util/darshan-logutils.c
+++ b/darshan-util/darshan-logutils.c
@@ -23,6 +23,9 @@
#include "darshan-logutils.h"
+/* default to a compression buffer size of 4 MiB */
+#define DARSHAN_DEF_DECOMP_BUF_SZ (4*1024*1024)
struct darshan_fd_s
int pf;
@@ -38,7 +41,8 @@ struct darshan_fd_s
static int darshan_log_seek(darshan_fd fd, off_t offset);
static int darshan_log_read(darshan_fd fd, void *buf, int len);
static int darshan_log_write(darshan_fd fd, void *buf, int len);
+static int darshan_decompress_buffer(char *comp_buf, int comp_buf_sz,
+ char *decomp_buf, int *inout_decomp_buf_sz);
/* darshan_log_open()
@@ -150,24 +154,45 @@ int darshan_log_getheader(darshan_fd fd, struct darshan_header *header)
int darshan_log_getjob(darshan_fd fd, struct darshan_job *job)
+ char *comp_buf;
char job_buf[DARSHAN_JOB_RECORD_SIZE] = {0};
+ int job_buf_sz = DARSHAN_JOB_RECORD_SIZE;
int ret;
+ /* allocate a buffer to store the (compressed) darshan job info */
+ comp_buf = malloc(fd->job_map.len);
+ if(!comp_buf)
+ return(-1);
ret = darshan_log_seek(fd, fd->job_map.off);
if(ret < 0)
fprintf(stderr, "Error: unable to seek in darshan log file.\n");
+ free(comp_buf);
return(ret);
/* read the job data from the log file */
- ret = darshan_log_read(fd, job_buf, fd->job_map.len);
+ ret = darshan_log_read(fd, comp_buf, fd->job_map.len);
if(ret < fd->job_map.len)
fprintf(stderr, "Error: invalid darshan log file (failed to read job data).\n");
+ free(comp_buf);
return(-1);
+ /* decompress the job data */
+ ret = darshan_decompress_buffer(comp_buf, fd->job_map.len,
+ job_buf, &job_buf_sz);
+ if(ret < 0)
+ fprintf(stderr, "Error: unable to decompress darshan job data.\n");
+ free(comp_buf);
+ return(-1);
+ assert(job_buf_sz == DARSHAN_JOB_RECORD_SIZE);
+ free(comp_buf);
memcpy(job, job_buf, sizeof(*job));
if(fd->swap_flag)
@@ -181,7 +206,8 @@ int darshan_log_getjob(darshan_fd fd, struct darshan_job *job)
/* save trailing job data, so exe and mount information can be retrieved later */
- fd->exe_mnt_data = malloc(DARSHAN_EXE_LEN+1);
+ if(!fd->exe_mnt_data)
+ fd->exe_mnt_data = malloc(DARSHAN_EXE_LEN+1);
return(-1);
memcpy(fd->exe_mnt_data, &job_buf[sizeof(*job)], DARSHAN_EXE_LEN+1);
@@ -193,9 +219,17 @@ int darshan_log_getexe(darshan_fd fd, char *buf)
char *newline;
- /* TODO: try reading log job one more time to set this buffer up */
+ /* if the exe/mount info has not been saved yet, read in the job
+ * header to get this data.
- return(-1);
+ struct darshan_job job;
+ (void)darshan_log_getjob(fd, &job);
+ return(-1);
newline = strchr(fd->exe_mnt_data, '\n');
@@ -219,11 +253,18 @@ int darshan_log_getmounts(darshan_fd fd, char*** mnt_pts,
char *pos;
int array_index = 0;
- return(-1);
+ return(-1);
- /* count entries */
*count = 0;
pos = fd->exe_mnt_data;
while((pos = strchr(pos, '\n')) != NULL)
@@ -278,37 +319,51 @@ int darshan_log_getmounts(darshan_fd fd, char*** mnt_pts,
int darshan_log_gethash(darshan_fd fd, struct darshan_record_ref **hash)
- unsigned char *buf_ptr;
+ char *comp_buf;
+ char hash_buf[DARSHAN_DEF_DECOMP_BUF_SZ] = {0};
+ int hash_buf_sz = DARSHAN_DEF_DECOMP_BUF_SZ;
+ char *buf_ptr;
darshan_record_id *rec_id_ptr;
uint32_t *path_len_ptr;
char *path_ptr;
struct darshan_record_ref *ref;
int ret;
+ /* allocate a buffer to store the (compressed, serialized) darshan record hash */
+ comp_buf = malloc(fd->rec_map.len);
+ if(!comp_buf)
+ return(-1);
ret = darshan_log_seek(fd, fd->rec_map.off);
if(ret < 0)
+ free(comp_buf);
return(ret);
- /* allocate a buffer to store the (serialized) darshan record hash */
- hash_buf = malloc(fd->rec_map.len);
- if(!hash_buf)
- return(-1);
- /* read the record map from the log file */
- ret = darshan_log_read(fd, hash_buf, fd->rec_map.len);
+ /* read the record hash from the log file */
+ ret = darshan_log_read(fd, comp_buf, fd->rec_map.len);
if(ret < fd->rec_map.len)
fprintf(stderr, "Error: invalid darshan log file (failed to read record hash).\n");
- free(hash_buf);
+ free(comp_buf);
return(-1);
+ /* decompress the record hash buffer */
+ ret = darshan_decompress_buffer(comp_buf, fd->rec_map.len,
+ hash_buf, &hash_buf_sz);
+ if(ret < 0)
+ free(comp_buf);
+ return(-1);
+ free(comp_buf);
buf_ptr = hash_buf;
- while(buf_ptr < (hash_buf + fd->rec_map.len))
+ while(buf_ptr < (hash_buf + hash_buf_sz))
/* get pointers for each field of this darshan record */
/* NOTE: darshan record hash serialization method:
@@ -324,13 +379,11 @@ int darshan_log_gethash(darshan_fd fd, struct darshan_record_ref **hash)
ref = malloc(sizeof(*ref));
if(!ref)
- free(hash_buf);
return(-1);
ref->rec.name = malloc(*path_len_ptr + 1);
if(!ref->rec.name)
- free(hash_buf);
free(ref);
return(-1);
@@ -351,16 +404,88 @@ int darshan_log_gethash(darshan_fd fd, struct darshan_record_ref **hash)
HASH_ADD(hlink, *hash, rec.id, sizeof(darshan_record_id), ref);
- free(hash_buf);
+ return(0);
+int darshan_log_getmod(darshan_fd fd, int mod_id, void **mod_buf,
+ int *mod_buf_sz)
+ char *comp_buf;
+ char *tmp_buf;
+ int tmp_buf_sz;
+ int ret;
+ *mod_buf = NULL;
+ *mod_buf_sz = 0;
+ if(mod_id < 0 || mod_id >= DARSHAN_MAX_MODS)
+ fprintf(stderr, "Error: invalid Darshan module id.\n");
+ return(-1);
+ if(fd->mod_map[mod_id].len == 0)
+ /* this module has no data in the log */
+ return(0);
+ comp_buf = malloc(fd->mod_map[mod_id].len);
+ if(!comp_buf)
+ return(-1);
+ ret = darshan_log_seek(fd, fd->mod_map[mod_id].off);
+ if(ret < 0)
+ fprintf(stderr, "Error: unable to seek in darshan log file.\n");
+ free(comp_buf);
+ return(ret);
+ /* read the given module's (compressed) data from the log file */
+ ret = darshan_log_read(fd, comp_buf, fd->mod_map[mod_id].len);
+ if(ret < fd->mod_map[mod_id].len)
+ fprintf(stderr, "Error: invalid darshan log file (failed to read module %s data).\n",
+ darshan_module_names[mod_id]);
+ free(comp_buf);
+ return(-1);
+ tmp_buf_sz = DARSHAN_DEF_DECOMP_BUF_SZ;
+ tmp_buf = malloc(DARSHAN_DEF_DECOMP_BUF_SZ);
+ if(!tmp_buf)
+ free(comp_buf);
+ return(-1);
+ /* decompress this module's data */
+ ret = darshan_decompress_buffer(comp_buf, fd->mod_map[mod_id].len, tmp_buf,
+ &tmp_buf_sz);
+ if(ret < 0)
+ fprintf(stderr, "Error: unable to decompress module %s data.\n",
+ free(tmp_buf);
+ return(-1);
+ free(comp_buf);
+ /* pass back the final decompressed data pointer */
+ *mod_buf = tmp_buf;
+ *mod_buf_sz = tmp_buf_sz;
return(0);
+#if 0
/* TODO: hardcoded for posix -- what can we do generally?
* different function for each module and a way to map to this function?
int darshan_log_getfile(darshan_fd fd, struct darshan_posix_file *file)
+ char *comp_buf;
int ret;
const char* err_string;
int i;
@@ -416,6 +541,7 @@ int darshan_log_getfile(darshan_fd fd, struct darshan_posix_file *file)
fprintf(stderr, "Error: %s\n", err_string);
return(-1);
+#endif
/* darshan_log_close()
@@ -436,6 +562,25 @@ void darshan_log_close(darshan_fd fd)
+/* return 0 on successful seek to offset, -1 on failure.
+static int darshan_log_seek(darshan_fd fd, off_t offset)
+ off_t ret_off;
+ if(fd->pos == offset)
+ return(0);
+ ret_off = lseek(fd->pf, offset, SEEK_SET);
+ if(ret_off == offset)
+ fd->pos = offset;
+ return(0);
+ return(-1);
/* return amount written on success, -1 on failure.
static int darshan_log_write(darshan_fd fd, void* buf, int len)
@@ -470,21 +615,64 @@ static int darshan_log_read(darshan_fd fd, void* buf, int len)
return(-1);
-/* return 0 on successful seek to offset, -1 on failure.
-static int darshan_log_seek(darshan_fd fd, off_t offset)
+/* TODO bz2 compression support */
- off_t ret_off;
+ int ret;
+ /* initialize the zlib decompression parameters */
+ //ret = inflateInit2(&tmp_stream, 31);
+ ret = inflateInit(&tmp_stream);
+ if(ret != Z_OK)
+ return(-1);
- if(fd->pos == offset)
- return(0);
+ tmp_stream.next_in = comp_buf;
+ tmp_stream.avail_in = comp_buf_sz;
+ tmp_stream.next_out = decomp_buf;
+ tmp_stream.avail_out = *inout_decomp_buf_sz;
- ret_off = lseek(fd->pf, offset, SEEK_SET);
- if(ret_off == offset)
+ /* while we have not finished consuming all of the compressed input data */
+ while(tmp_stream.total_in < comp_buf_sz)
- fd->pos = offset;
- return(0);
+ * we could just alloc more space, but probably just easier
+ * to bump up the default size of the output buffer.
+ inflateEnd(&tmp_stream);
+ return(-1);
+ /* decompress data */
+ ret = inflate(&tmp_stream, Z_NO_FLUSH);
+ return(-1);
- return(-1);
+ *inout_decomp_buf_sz = tmp_stream.total_out;
+ return(0);
+ * Local variables:
+ * c-indent-level: 4
+ * c-basic-offset: 4
+ * End:
+ * vim: ts=8 sts=4 sw=4 expandtab
diff --git a/darshan-util/darshan-logutils.h b/darshan-util/darshan-logutils.h
index fbaa0ac..d1d2ee3 100644
--- a/darshan-util/darshan-logutils.h
+++ b/darshan-util/darshan-logutils.h
@@ -22,10 +22,11 @@ darshan_fd darshan_log_open(const char *name, const char* mode);
int darshan_log_getheader(darshan_fd file, struct darshan_header *header);
int darshan_log_getjob(darshan_fd file, struct darshan_job *job);
int darshan_log_gethash(darshan_fd file, struct darshan_record_ref **hash);
-int darshan_log_getfile(darshan_fd fd, struct darshan_posix_file *file);
int darshan_log_getexe(darshan_fd fd, char *buf);
char*** fs_types, int* count);
+ int *mod_buf_sz);
void darshan_log_close(darshan_fd file);
/* convenience macros for printing out counters */
diff --git a/darshan-util/darshan-posix-parser.c b/darshan-util/darshan-posix-parser.c
index c4a453e..394d0e3 100644
--- a/darshan-util/darshan-posix-parser.c
+++ b/darshan-util/darshan-posix-parser.c
@@ -32,11 +32,12 @@ int main(int argc, char **argv)
int mount_count;
char** mnt_pts;
char** fs_types;
- struct darshan_posix_file next_rec;
time_t tmp_time = 0;
char *token;
char *save;
char buffer[DARSHAN_JOB_METADATA_LEN];
+ struct darshan_posix_file *posix_mod_buf;
+ int posix_mod_buf_sz = 0;
assert(argc == 2);
filename = argv[1];
@@ -80,8 +81,8 @@ int main(int argc, char **argv)
/* print job summary */
printf("# darshan log version: %s\n", header.version_string);
- printf("# size of POSIX file statistics: %zu bytes\n", sizeof(next_rec));
- printf("# size of job statistics: %zu bytes\n", sizeof(job));
+ printf("# size of POSIX file statistics: %zu bytes\n", sizeof(struct darshan_posix_file));
+ printf("# size of job statistics: %zu bytes\n", sizeof(struct darshan_job));
printf("# exe: %s\n", tmp_string);
printf("# uid: %" PRId64 "\n", job.uid);
printf("# jobid: %" PRId64 "\n", job.jobid);
@@ -132,6 +133,13 @@ int main(int argc, char **argv)
printf("# mount entry:\t%s\t%s\n", mnt_pts[i], fs_types[i]);
+ uint64_t job_size = header.rec_map.off - sizeof(struct darshan_header);
+ printf("\nDarshan log file module sizes:\n");
+ printf("\tHEADER size = %"PRIu64"\n\tJOB size = %"PRIu64"\n\tREC_HASH size = %"PRIu64"\n",
+ sizeof(struct darshan_header), job_size, header.rec_map.len);
+ printf("\t%s MODULE size = %"PRIu64"\n", darshan_module_names[DARSHAN_POSIX_MOD],
+ header.mod_map[DARSHAN_POSIX_MOD].len);
/* read hash of darshan records */
ret = darshan_log_gethash(file, &rec_hash);
if(ret < 0)
@@ -141,15 +149,18 @@ int main(int argc, char **argv)
return(-1);
- /* try to retrieve first record (may not exist) */
- ret = darshan_log_getfile(file, &next_rec);
- if(ret < 0)
+ printf("\n*** FILE RECORD DATA ***\n");
+ /* get the log data for the POSIX module */
+ ret = darshan_log_getmod(file, DARSHAN_POSIX_MOD, (void**)&posix_mod_buf, &posix_mod_buf_sz);
+ if(ret < 0 || posix_mod_buf_sz % sizeof(struct darshan_posix_file))
- fprintf(stderr, "Error: failed to parse log file.\n");
- fflush(stderr);
+ fprintf(stderr, "darshan_log_getmod() failed to read POSIX module data.\n");
+ darshan_log_close(file);
return(-1);
- if(ret == 0)
+ if(posix_mod_buf_sz == 0)
/* it looks like the app didn't open any files */
printf("# no files opened.\n");
@@ -157,11 +168,10 @@ int main(int argc, char **argv)
return(0);
- /* iterate the posix file records stored in the darshan log */
- printf("\n*** FILE RECORD DATA ***\n");
- i = 0;
- do{
- struct darshan_record_ref *ref;
+ /* loop over the POSIX file records and print out counters */
+ for(i = 0; i < (posix_mod_buf_sz / sizeof(struct darshan_posix_file)); i++)
+ struct darshan_posix_file next_rec = posix_mod_buf[i];
/* get the pathname for this record */
HASH_FIND(hlink, rec_hash, &next_rec.f_id, sizeof(darshan_record_id), ref);
@@ -172,9 +182,7 @@ int main(int argc, char **argv)
printf("\t\tPOSIX_OPENS:\t%"PRIu64"\n\t\tF_OPEN_TIMESTAMP:\t%lf\n\t\tF_CLOSE_TIMESTAMP:\t%lf\n",
next_rec.counters[CP_POSIX_OPENS], next_rec.fcounters[CP_F_OPEN_TIMESTAMP],
next_rec.fcounters[CP_F_CLOSE_TIMESTAMP]);
- i++;
- } while((ret = darshan_log_getfile(file, &next_rec)) == 1);
/* free mount info */
for(i=0; i<mount_count; i++)
hooks/post-receive
More information about the Darshan-commits
