[Darshan-commits] [Darshan] branch, dev-modular, updated. 35f07b3803bd03fe2f7ec893c59b12970d700bbe
Service Account git at mcs.anl.gov
Thu Feb 19 16:01:04 CST 2015
This is an automated email from the git hooks/post-receive script. It was
generated because a ref change was pushed to the repository containing
the project "".
The branch, dev-modular has been updated
       via  35f07b3803bd03fe2f7ec893c59b12970d700bbe (commit)
       via  af20f42af9a38bf4d5258eb0bfa8ad2703158a3c (commit)
      from  601e5ef70169f6d00c271f53f2f0a8cd7fdfd86f (commit)
Those revisions listed above that are new to this repository have
not appeared on any other notification email; so we list those
revisions in full, below.
- Log -----------------------------------------------------------------
commit 35f07b3803bd03fe2f7ec893c59b12970d700bbe
Author: Shane Snyder <ssnyder at mcs.anl.gov>
Date:   Thu Feb 19 16:00:46 2015 -0600
    code cleanup / bug fixes
commit af20f42af9a38bf4d5258eb0bfa8ad2703158a3c
Date:   Wed Feb 18 11:26:19 2015 -0600
    Clean up variable names and source files
Summary of changes:
 darshan-log-format.h                            |    8 +-
 darshan-runtime/configure                       |    2 +-
 darshan-runtime/configure.in                    |    2 +-
 darshan-runtime/darshan-core.h                  |    2 +-
 darshan-runtime/darshan.h                       |    1 +
 darshan-runtime/lib/darshan-core.c              |   62 +-
 darshan-runtime/lib/darshan-hdf5-stubs.c        |   79 -
 darshan-runtime/lib/darshan-hdf5.c              |  190 --
 darshan-runtime/lib/darshan-mpi-init-finalize.c |  252 ---
 darshan-runtime/lib/darshan-mpi-io.c            | 2580 -----------------------
 darshan-runtime/lib/darshan-pnetcdf-stubs.c     |   76 -
 darshan-runtime/lib/darshan-pnetcdf.c           |  202 --
 darshan-runtime/lib/darshan-posix.c             |  129 +-
 darshan-util/darshan-logutils.c                 |   49 +-
 darshan-util/darshan-posix-parser.c             |    5 +-
 15 files changed, 128 insertions(+), 3511 deletions(-)
 delete mode 100644 darshan-runtime/lib/darshan-hdf5-stubs.c
 delete mode 100644 darshan-runtime/lib/darshan-hdf5.c
 delete mode 100644 darshan-runtime/lib/darshan-mpi-init-finalize.c
 delete mode 100644 darshan-runtime/lib/darshan-mpi-io.c
 delete mode 100644 darshan-runtime/lib/darshan-pnetcdf-stubs.c
 delete mode 100644 darshan-runtime/lib/darshan-pnetcdf.c
Diff of changes:
diff --git a/darshan-log-format.h b/darshan-log-format.h
index ccd4df9..382ab00 100644
--- a/darshan-log-format.h
+++ b/darshan-log-format.h
@@ -19,16 +19,16 @@
 #endif
 /* update this on file format changes */
-#define CP_VERSION "3.00"
+#define DARSHAN_LOG_VERSION "3.00"
 /* magic number for validating output files and checking byte order */
-#define CP_MAGIC_NR 6567223
+#define DARSHAN_MAGIC_NR 6567223
 /* size (in bytes) of job record */
-#define CP_JOB_RECORD_SIZE 4096
+#define DARSHAN_JOB_RECORD_SIZE 4096
 /* max length of exe string within job record (not counting '\0') */
-#define CP_EXE_LEN (CP_JOB_RECORD_SIZE - sizeof(struct darshan_job) - 1)
+#define DARSHAN_EXE_LEN (DARSHAN_JOB_RECORD_SIZE - sizeof(struct darshan_job) - 1)
 typedef uint64_t darshan_record_id;
diff --git a/darshan-runtime/configure b/darshan-runtime/configure
index 5071619..b5aa9d5 100755
--- a/darshan-runtime/configure
+++ b/darshan-runtime/configure
@@ -4169,7 +4169,7 @@ done
 # libc functions wrapped by darshan
 #CP_WRAPPERS="-Wl,-u,MPI_Init,-u,MPI_Wtime,-wrap,write,-wrap,open,-wrap,creat,-wrap,creat64,-wrap,open64,-wrap,close,-wrap,read,-wrap,lseek,-wrap,lseek64,-wrap,pread,-wrap,pwrite,-wrap,readv,-wrap,writev,-wrap,__xstat,-wrap,__lxstat,-wrap,__fxstat,-wrap,__xstat64,-wrap,__lxstat64,-wrap,__fxstat64,-wrap,mmap,-wrap,mmap64,-wrap,fopen,-wrap,fclose,-wrap,fread,-wrap,fwrite,-wrap,fseek,-wrap,fopen64,-wrap,pread64,-wrap,pwrite64,-wrap,fsync,-wrap,fdatasync,-wrap,ncmpi_create,-wrap,ncmpi_open,-wrap,ncmpi_close,-wrap,H5Fcreate,-wrap,H5Fopen,-wrap,H5Fclose,-wrap,aio_write,-wrap,aio_write64,-wrap,aio_read,-wrap,aio_read64,-wrap,lio_listio,-wrap,lio_listio64,-wrap,aio_return,-wrap,aio_return64"
-CP_WRAPPERS="-Wl,-u,MPI_Init,-u,MPI_Wtime,-wrap,open,-wrap,close"
+CP_WRAPPERS="-Wl,-u,MPI_Init,-u,MPI_Wtime,-wrap,open,-wrap,open64,-wrap,close"
 # We need to know the value of the $libdir and $bindir variables so that
 # we can reference the correct path in the darshan compiler wrappers.
diff --git a/darshan-runtime/configure.in b/darshan-runtime/configure.in
index 6a1d470..a69c61e 100644
--- a/darshan-runtime/configure.in
+++ b/darshan-runtime/configure.in
@@ -190,7 +190,7 @@ AC_CHECK_HEADERS(mntent.h sys/mount.h)
diff --git a/darshan-runtime/darshan-core.h b/darshan-runtime/darshan-core.h
index 8d1c0ce..7d98d71 100644
--- a/darshan-runtime/darshan-core.h
+++ b/darshan-runtime/darshan-core.h
@@ -25,7 +25,7 @@ struct darshan_core_module
 struct darshan_core_runtime
     struct darshan_job log_job;
-    char exe[CP_EXE_LEN+1];
+    char exe[DARSHAN_EXE_LEN+1];
     struct darshan_core_record_ref *rec_hash;
     struct darshan_core_module* mod_array[DARSHAN_MAX_MODS];
     double wtime_offset;
diff --git a/darshan-runtime/darshan.h b/darshan-runtime/darshan.h
index 7b57874..9a4f480 100644
--- a/darshan-runtime/darshan.h
+++ b/darshan-runtime/darshan.h
@@ -30,6 +30,7 @@
 struct darshan_module_funcs
+    void (*disable_instrumentation)(void);
     void (*get_output_data)(
         MPI_Comm mod_comm, /* communicator to use for module shutdown */
         void** buf, /* output parameter to save module buffer address */
diff --git a/darshan-runtime/lib/darshan-core.c b/darshan-runtime/lib/darshan-core.c
index 095c756..0bf770e 100644
--- a/darshan-runtime/lib/darshan-core.c
+++ b/darshan-runtime/lib/darshan-core.c
@@ -139,6 +139,7 @@ static void darshan_core_initialize(int *argc, char ***argv)
     if(internal_timing_flag)
         init_start = DARSHAN_MPI_CALL(PMPI_Wtime)();
+    DARSHAN_CORE_LOCK();
     /* setup darshan runtime if darshan is enabled and hasn't been initialized already */
     if(!getenv("DARSHAN_DISABLE") && !darshan_core)
@@ -158,11 +159,11 @@ static void darshan_core_initialize(int *argc, char ***argv)
             /* record exe and arguments */
             for(i=0; i<(*argc); i++)
-                chars_left = CP_EXE_LEN-strlen(darshan_core->exe);
+                chars_left = DARSHAN_EXE_LEN-strlen(darshan_core->exe);
                 strncat(darshan_core->exe, (*argv)[i], chars_left);
                 if(i < ((*argc)-1))
                     strncat(darshan_core->exe, " ", chars_left);
@@ -172,16 +173,16 @@ static void darshan_core_initialize(int *argc, char ***argv)
             if(argc == 0)
                 strncat(darshan_core->exe, __progname, chars_left);
                 strncat(darshan_core->exe, " <unknown args>", chars_left);
             if(chars_left == 0)
                 /* we ran out of room; mark that string was truncated */
-                truncate_offset = CP_EXE_LEN - strlen(truncate_string);
+                truncate_offset = DARSHAN_EXE_LEN - strlen(truncate_string);
                 sprintf(&darshan_core->exe[truncate_offset], "%s",
                     truncate_string);
@@ -190,6 +191,7 @@ static void darshan_core_initialize(int *argc, char ***argv)
             darshan_core->trailing_data = darshan_get_exe_and_mounts(darshan_core);
+    DARSHAN_CORE_UNLOCK();
@@ -234,17 +236,27 @@ static void darshan_core_shutdown()
     if(getenv("DARSHAN_INTERNAL_TIMING"))
         internal_timing_flag = 1;
+    /* disable darhan-core while we shutdown */
     if(!darshan_core)
         return;
-    /* disable further tracing while hanging onto the data so that we can
-     * write it out
     final_core = darshan_core;
     darshan_core = NULL;
+    /* we also need to set which modules were registerd on this process and
+     * disable tracing within those modules while we shutdown
+    for(i = 0; i < DARSHAN_MAX_MODS; i++)
+        if(final_core->mod_array[i])
+            local_mod_use[i] = 1;
+            final_core->mod_array[i]->mod_funcs.disable_instrumentation();
     start_log_time = DARSHAN_MPI_CALL(PMPI_Wtime)();
@@ -319,13 +331,6 @@ static void darshan_core_shutdown()
         final_core->log_job.end_time = last_end_time;
-    /* set which local modules were actually used */
-    for(i = 0; i < DARSHAN_MAX_MODS; i++)
-        if(final_core->mod_array[i])
-            local_mod_use[i] = 1;
     /* reduce the number of times a module was opened globally and bcast to everyone */
     DARSHAN_MPI_CALL(PMPI_Allreduce)(local_mod_use, global_mod_use_count, DARSHAN_MAX_MODS, MPI_INT, MPI_SUM, MPI_COMM_WORLD);
@@ -354,18 +359,18 @@ static void darshan_core_shutdown()
     /* rank 0 is responsible for writing the darshan job information */
     if(my_rank == 0)
-        unsigned char tmp_buf[CP_JOB_RECORD_SIZE];
+        unsigned char tmp_buf[DARSHAN_JOB_RECORD_SIZE];
         unsigned char *tmp_ptr;
         /* pack the job info and exe/mount info into a buffer for writing */
         tmp_ptr = tmp_buf;
         memcpy(tmp_ptr, &final_core->log_job, sizeof(struct darshan_job));
         tmp_ptr += sizeof(struct darshan_job);
-        memcpy(tmp_ptr, final_core->trailing_data, CP_EXE_LEN+1);
+        memcpy(tmp_ptr, final_core->trailing_data, DARSHAN_EXE_LEN+1);
         /* write the job information, making sure to prealloc space for the log header */
         all_ret = DARSHAN_MPI_CALL(PMPI_File_write_at)(log_fh, sizeof(struct darshan_header),
-                tmp_buf, CP_JOB_RECORD_SIZE, MPI_BYTE, &status);
+                tmp_buf, DARSHAN_JOB_RECORD_SIZE, MPI_BYTE, &status);
         if(all_ret != MPI_SUCCESS)
             fprintf(stderr, "darshan library warning: unable to write job data to log file %s\n",
@@ -374,7 +379,7 @@ static void darshan_core_shutdown()
         /* TODO: after compression is added, this should be fixed */
-        log_header.rec_map.off = sizeof(struct darshan_header) + CP_JOB_RECORD_SIZE;
+        log_header.rec_map.off = sizeof(struct darshan_header) + DARSHAN_JOB_RECORD_SIZE;
     /* error out if unable to write job information */
@@ -487,8 +492,8 @@ static void darshan_core_shutdown()
     if(my_rank == 0)
         /* initialize the remaining header fields */
-        strcpy(log_header.version_string, CP_VERSION);
-        log_header.magic_nr = CP_MAGIC_NR;
+        strcpy(log_header.version_string, DARSHAN_LOG_VERSION);
+        log_header.magic_nr = DARSHAN_MAGIC_NR;
         log_header.comp_type = DARSHAN_GZ_COMP;
         all_ret = DARSHAN_MPI_CALL(PMPI_File_write_at)(log_fh, 0, &log_header,
@@ -839,7 +844,7 @@ static void darshan_get_exe_and_mounts_root(struct darshan_core_runtime *core,
     /* length of exe has already been safety checked in darshan-posix.c */
     strcat(trailing_data, core->exe);
-    space_left = CP_EXE_LEN - strlen(trailing_data);
+    space_left = DARSHAN_EXE_LEN - strlen(trailing_data);
     /* we make two passes through mounted file systems; in the first pass we
      * grab any non-nfs mount points, then on the second pass we grab nfs
@@ -903,7 +908,7 @@ static char* darshan_get_exe_and_mounts(struct darshan_core_runtime *core)
     char* trailing_data;
     int space_left;
-    space_left = CP_EXE_LEN + 1;
+    space_left = DARSHAN_EXE_LEN + 1;
     trailing_data = malloc(space_left);
     if(!trailing_data)
@@ -1210,10 +1215,9 @@ void darshan_core_register_module(
     int *runtime_mem_limit)
     struct darshan_core_module* mod;
+    *runtime_mem_limit = 0;
-    *runtime_mem_limit = 0;
     if(!darshan_core || (id >= DARSHAN_MAX_MODS))
@@ -1261,16 +1265,15 @@ void darshan_core_lookup_record_id(
     darshan_record_id tmp_id;
     struct darshan_core_record_ref* ref;
-    if(!darshan_core || !name)
+    if(!darshan_core)
         return;
     /* TODO: what do you do with printable flag? */
     /* hash the input name to get a unique id for this record */
     tmp_id = darshan_hash(name, len, 0);
-    DARSHAN_CORE_LOCK();
     /* check to see if we've already stored the id->name mapping for this record */
     HASH_FIND(hlink, darshan_core->rec_hash, &tmp_id, sizeof(darshan_record_id), ref);
     if(!ref)
@@ -1287,11 +1290,8 @@ void darshan_core_lookup_record_id(
             HASH_ADD(hlink, darshan_core->rec_hash, rec.id, sizeof(darshan_record_id), ref);
-    printf("New Darshan record: %s (%"PRIu64")\n", (char *)name, tmp_id);
     *id = tmp_id;
     return;
diff --git a/darshan-runtime/lib/darshan-hdf5-stubs.c b/darshan-runtime/lib/darshan-hdf5-stubs.c
deleted file mode 100644
index a220bef..0000000
--- a/darshan-runtime/lib/darshan-hdf5-stubs.c
+++ /dev/null
@@ -1,79 +0,0 @@
- *  (C) 2009 by Argonne National Laboratory.
- *      See COPYRIGHT in top-level directory.
-/* This file contains stubs for the H5F functions intercepted by Darshan.
- * They are defined as weak symbols in order to satisfy dependencies of the
- * hdf5 wrappers in cases where hdf5 is not being used.
-#include "darshan-runtime-config.h"
-#include <stdio.h>
-#include <pthread.h>
-#include <string.h>
-#include "mpi.h"
-#include "darshan.h"
-/* hope this doesn't change any time soon */
-typedef int hid_t;
-typedef int herr_t;
-hid_t H5Fcreate(const char *filename, unsigned flags,
-    hid_t create_plist, hid_t access_plist) __attribute__((weak));
-    int rank;
-    MPI_Comm_rank(MPI_COMM_WORLD, &rank);
-    if(rank == 0)
-        fprintf(stderr, "WARNING: Darshan H5Fcreate() stub called; this is probably the result of a link-time problem.\n");
-    return(-1);
-hid_t H5Fopen(const char *filename, unsigned flags,
-    hid_t access_plist) __attribute__((weak));
-    int rank;
-    if(rank == 0)
-        fprintf(stderr, "WARNING: Darshan H5Fopen() stub called; this is probably the result of a link-time problem.\n");
-    return(-1);
-herr_t H5Fclose(hid_t file_id) __attribute__((weak));
-    int rank;
-    if(rank == 0)
-        fprintf(stderr, "WARNING: Darshan H5Fclose() stub called; this is probably the result of a link-time problem.\n");
-    return(-1);
- * Local variables:
- *  c-indent-level: 4
- *  c-basic-offset: 4
- * End:
- * vim: ts=8 sts=4 sw=4 expandtab
diff --git a/darshan-runtime/lib/darshan-hdf5.c b/darshan-runtime/lib/darshan-hdf5.c
index 979ab67..0000000
--- a/darshan-runtime/lib/darshan-hdf5.c
+++ /dev/null
@@ -1,190 +0,0 @@
-#include <stdio.h>
-#include "mpi.h"
-typedef int hid_t;
-#ifdef DARSHAN_PRELOAD
-#define __USE_GNU
-#include <dlfcn.h>
-#include <stdlib.h>
-#define DARSHAN_FORWARD_DECL(name,ret,args) \
-  ret (*__real_ ## name)args = NULL;
-#define DARSHAN_DECL(__name) __name
-#define MAP_OR_FAIL(func) \
-    if (!(__real_ ## func)) \
-        __real_ ## func = dlsym(RTLD_NEXT, #func); \
-        if(!(__real_ ## func)) { \
-            fprintf(stderr, "Darshan failed to map symbol: %s\n", #func); \
-            exit(1); \
-#else
-  extern ret __real_ ## name args;
-#define DARSHAN_DECL(__name) __wrap_ ## __name
-#endif
-DARSHAN_FORWARD_DECL(H5Fcreate, hid_t, (const char *filename, unsigned flags, hid_t create_plist, hid_t access_plist));
-DARSHAN_FORWARD_DECL(H5Fopen, hid_t, (const char *filename, unsigned flags, hid_t access_plist));
-DARSHAN_FORWARD_DECL(H5Fclose, herr_t, (hid_t file_id));
-static struct darshan_file_runtime* darshan_file_by_hid(int hid);
-static void darshan_file_close_hid(int hid);
-static struct darshan_file_runtime* darshan_file_by_name_sethid(const char* name, int hid);
-hid_t DARSHAN_DECL(H5Fcreate)(const char *filename, unsigned flags,
-    int ret;
-    struct darshan_file_runtime* file;
-    char* tmp;
-    double tm1;
-    MAP_OR_FAIL(H5Fcreate);
-    tm1 = darshan_wtime();
-    ret = __real_H5Fcreate(filename, flags, create_plist, access_plist);
-    if(ret >= 0)
-        CP_LOCK();
-        /* use ROMIO approach to strip prefix if present */
-        /* strip off prefix if there is one, but only skip prefixes
-         * if they are greater than length one to allow for windows
-         * drive specifications (e.g. c:\...)
-        tmp = strchr(filename, ':');
-        if (tmp > filename + 1) {
-            filename = tmp + 1;
-        file = darshan_file_by_name_sethid(filename, ret);
-        if(file)
-            if(CP_F_VALUE(file, CP_F_OPEN_TIMESTAMP) == 0)
-                CP_F_SET(file, CP_F_OPEN_TIMESTAMP,
-                tm1);
-            CP_INC(file, CP_HDF5_OPENS, 1);
-        CP_UNLOCK();
-    return(ret);
-hid_t DARSHAN_DECL(H5Fopen)(const char *filename, unsigned flags,
-    int ret;
-    char* tmp;
-    double tm1;
-    MAP_OR_FAIL(H5Fopen);
-    ret = __real_H5Fopen(filename, flags, access_plist);
-    if(ret >= 0)
-        CP_LOCK();
-        if(file)
-                tm1);
-        CP_UNLOCK();
-    return(ret);
-herr_t DARSHAN_DECL(H5Fclose)(hid_t file_id)
-    int ret;
-    MAP_OR_FAIL(H5Fclose);
-    ret = __real_H5Fclose(file_id);
-    CP_LOCK();
-    file = darshan_file_by_hid(file_id);
-    if(file)
-        CP_F_SET(file, CP_F_CLOSE_TIMESTAMP, PMPI_Wtime());
-        darshan_file_close_hid(file_id);
-    CP_UNLOCK();
-    return(ret);
-    struct darshan_file_runtime* tmp_file;
-    tmp_file = darshan_file_by_name_sethandle(name, &hid, sizeof(hid), DARSHAN_HID);
-    return(tmp_file);
-    darshan_file_closehandle(&hid, sizeof(hid), DARSHAN_HID);
-    return;
-    tmp_file = darshan_file_by_handle(&hid, sizeof(hid), DARSHAN_HID);
-    return(tmp_file);
- * End:
diff --git a/darshan-runtime/lib/darshan-mpi-init-finalize.c b/darshan-runtime/lib/darshan-mpi-init-finalize.c
index c1d3e9d..0000000
--- a/darshan-runtime/lib/darshan-mpi-init-finalize.c
+++ /dev/null
@@ -1,252 +0,0 @@
- *  (C) 2012 by Argonne National Laboratory.
-#define _XOPEN_SOURCE 500
-#define _GNU_SOURCE /* for RTLD_NEXT */
-#include <stdio.h>
-#include "mpi.h"
-#include "darshan-dynamic.h"
-#include <dlfcn.h>
-    if (!(__real_ ## func)) { \
-DARSHAN_FORWARD_DECL(PMPI_File_close, int, (MPI_File *fh));
-DARSHAN_FORWARD_DECL(PMPI_File_set_size, int, (MPI_File fh, MPI_Offset size));
-DARSHAN_FORWARD_DECL(PMPI_File_iread_at, int, (MPI_File fh, MPI_Offset offset, void *buf, int count, MPI_Datatype datatype, __D_MPI_REQUEST *request));
-DARSHAN_FORWARD_DECL(PMPI_File_iread, int, (MPI_File fh, void  *buf, int  count, MPI_Datatype  datatype, __D_MPI_REQUEST  *request));
-DARSHAN_FORWARD_DECL(PMPI_File_iread_shared, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype, __D_MPI_REQUEST *request));
-#ifdef HAVE_MPIIO_CONST
-DARSHAN_FORWARD_DECL(PMPI_File_iwrite_at, int, (MPI_File fh, MPI_Offset offset, const void *buf, int count, MPI_Datatype datatype, __D_MPI_REQUEST *request));
-#else
-DARSHAN_FORWARD_DECL(PMPI_File_iwrite_at, int, (MPI_File fh, MPI_Offset offset, void *buf, int count, MPI_Datatype datatype, __D_MPI_REQUEST *request));
-#endif
-DARSHAN_FORWARD_DECL(PMPI_File_iwrite, int, (MPI_File fh, const void *buf, int count, MPI_Datatype datatype, __D_MPI_REQUEST *request));
-#else
-DARSHAN_FORWARD_DECL(PMPI_File_iwrite, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype, __D_MPI_REQUEST *request));
-#endif
-DARSHAN_FORWARD_DECL(PMPI_File_iwrite_shared, int, (MPI_File fh, const void *buf, int count, MPI_Datatype datatype, __D_MPI_REQUEST *request));
-#else
-DARSHAN_FORWARD_DECL(PMPI_File_iwrite_shared, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype, __D_MPI_REQUEST *request));
-#endif
-DARSHAN_FORWARD_DECL(PMPI_File_open, int, (MPI_Comm comm, const char *filename, int amode, MPI_Info info, MPI_File *fh));
-#else
-DARSHAN_FORWARD_DECL(PMPI_File_open, int, (MPI_Comm comm, char *filename, int amode, MPI_Info info, MPI_File *fh));
-#endif
-DARSHAN_FORWARD_DECL(PMPI_File_read_all_begin, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype));
-DARSHAN_FORWARD_DECL(PMPI_File_read_all, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
-DARSHAN_FORWARD_DECL(PMPI_File_read_at_all, int, (MPI_File fh, MPI_Offset offset, void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
-DARSHAN_FORWARD_DECL(PMPI_File_read_at_all_begin, int, (MPI_File fh, MPI_Offset offset, void *buf, int count, MPI_Datatype datatype));
-DARSHAN_FORWARD_DECL(PMPI_File_read_at, int, (MPI_File fh, MPI_Offset offset, void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
-DARSHAN_FORWARD_DECL(PMPI_File_read, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
-DARSHAN_FORWARD_DECL(PMPI_File_read_ordered_begin, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype));
-DARSHAN_FORWARD_DECL(PMPI_File_read_ordered, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
-DARSHAN_FORWARD_DECL(PMPI_File_read_shared, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
-DARSHAN_FORWARD_DECL(PMPI_File_set_view, int, (MPI_File fh, MPI_Offset disp, MPI_Datatype etype, MPI_Datatype filetype, const char *datarep, MPI_Info info));
-#else
-DARSHAN_FORWARD_DECL(PMPI_File_set_view, int, (MPI_File fh, MPI_Offset disp, MPI_Datatype etype, MPI_Datatype filetype, char *datarep, MPI_Info info));
-#endif
-DARSHAN_FORWARD_DECL(PMPI_File_sync, int, (MPI_File fh));
-DARSHAN_FORWARD_DECL(PMPI_File_write_all_begin, int, (MPI_File fh, const void *buf, int count, MPI_Datatype datatype));
-#else
-DARSHAN_FORWARD_DECL(PMPI_File_write_all_begin, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype));
-#endif
-DARSHAN_FORWARD_DECL(PMPI_File_write_all, int, (MPI_File fh, const void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
-#else
-DARSHAN_FORWARD_DECL(PMPI_File_write_all, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
-#endif
-DARSHAN_FORWARD_DECL(PMPI_File_write_at_all_begin, int, (MPI_File fh, MPI_Offset offset, const void *buf, int count, MPI_Datatype datatype));
-#else
-DARSHAN_FORWARD_DECL(PMPI_File_write_at_all_begin, int, (MPI_File fh, MPI_Offset offset, void *buf, int count, MPI_Datatype datatype));
-#endif
-DARSHAN_FORWARD_DECL(PMPI_File_write_at_all, int, (MPI_File fh, MPI_Offset offset, const void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
-#else
-DARSHAN_FORWARD_DECL(PMPI_File_write_at_all, int, (MPI_File fh, MPI_Offset offset, void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
-#endif
-DARSHAN_FORWARD_DECL(PMPI_File_write_at, int, (MPI_File fh, MPI_Offset offset, const void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
-#else
-DARSHAN_FORWARD_DECL(PMPI_File_write_at, int, (MPI_File fh, MPI_Offset offset, void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
-#endif
-DARSHAN_FORWARD_DECL(PMPI_File_write, int, (MPI_File fh, const void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
-#else
-DARSHAN_FORWARD_DECL(PMPI_File_write, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
-#endif
-DARSHAN_FORWARD_DECL(PMPI_File_write_ordered_begin, int, (MPI_File fh, const void *buf, int count, MPI_Datatype datatype));
-#else
-DARSHAN_FORWARD_DECL(PMPI_File_write_ordered_begin, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype));
-#endif
-DARSHAN_FORWARD_DECL(PMPI_File_write_ordered, int, (MPI_File fh, const void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
-#else
-DARSHAN_FORWARD_DECL(PMPI_File_write_ordered, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
-#endif
-DARSHAN_FORWARD_DECL(PMPI_File_write_shared, int, (MPI_File fh, const void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
-#else
-DARSHAN_FORWARD_DECL(PMPI_File_write_shared, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
-#endif
-DARSHAN_FORWARD_DECL(PMPI_Finalize, int, ());
-DARSHAN_FORWARD_DECL(PMPI_Init, int, (int *argc, char ***argv));
-DARSHAN_FORWARD_DECL(PMPI_Init_thread, int, (int *argc, char ***argv, int required, int *provided));
-DARSHAN_FORWARD_DECL(PMPI_Wtime, double, ());
-DARSHAN_FORWARD_DECL(PMPI_Allreduce, int, (void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype, MPI_Op op, MPI_Comm comm));
-DARSHAN_FORWARD_DECL(PMPI_Bcast, int, (void *buffer, int count, MPI_Datatype datatype, int root, MPI_Comm comm));
-DARSHAN_FORWARD_DECL(PMPI_Comm_rank, int, (MPI_Comm comm, int *rank));
-DARSHAN_FORWARD_DECL(PMPI_Comm_size, int, (MPI_Comm comm, int *size));
-DARSHAN_FORWARD_DECL(PMPI_Scan, int, (void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype, MPI_Op op, MPI_Comm comm));
-DARSHAN_FORWARD_DECL(PMPI_Type_commit, int, (MPI_Datatype *datatype));
-DARSHAN_FORWARD_DECL(PMPI_Type_contiguous, int, (int count, MPI_Datatype oldtype, MPI_Datatype *newtype));
-DARSHAN_FORWARD_DECL(PMPI_Type_extent, int, (MPI_Datatype datatype, MPI_Aint *extent));
-DARSHAN_FORWARD_DECL(PMPI_Type_free, int, (MPI_Datatype *datatype));
-DARSHAN_FORWARD_DECL(PMPI_Type_hindexed, int, (int count, int *array_of_blocklengths, MPI_Aint *array_of_displacements, MPI_Datatype oldtype, MPI_Datatype *newtype));
-DARSHAN_FORWARD_DECL(PMPI_Op_create, int, (MPI_User_function *function, int commute, MPI_Op *op));
-DARSHAN_FORWARD_DECL(PMPI_Op_free, int, (MPI_Op *op));
-DARSHAN_FORWARD_DECL(PMPI_Reduce, int, (void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype, MPI_Op op, int root, MPI_Comm comm));
-DARSHAN_FORWARD_DECL(PMPI_Type_get_envelope, int, (MPI_Datatype datatype, int *num_integers, int *num_addresses, int *num_datatypes, int *combiner));
-DARSHAN_FORWARD_DECL(PMPI_Type_size, int, (MPI_Datatype datatype, int *size));
-void resolve_mpi_symbols (void)
-     * Overloaded functions
-    MAP_OR_FAIL(PMPI_File_close);
-    MAP_OR_FAIL(PMPI_File_set_size);
-    MAP_OR_FAIL(PMPI_File_iread_at);
-    MAP_OR_FAIL(PMPI_File_iread);
-    MAP_OR_FAIL(PMPI_File_iread_shared);
-    MAP_OR_FAIL(PMPI_File_iwrite_at);
-    MAP_OR_FAIL(PMPI_File_iwrite);
-    MAP_OR_FAIL(PMPI_File_iwrite_shared);
-    MAP_OR_FAIL(PMPI_File_open);
-    MAP_OR_FAIL(PMPI_File_read_all_begin);
-    MAP_OR_FAIL(PMPI_File_read_all);
-    MAP_OR_FAIL(PMPI_File_read_at_all_begin);
-    MAP_OR_FAIL(PMPI_File_read_at_all);
-    MAP_OR_FAIL(PMPI_File_read_at);
-    MAP_OR_FAIL(PMPI_File_read);
-    MAP_OR_FAIL(PMPI_File_read_ordered_begin);
-    MAP_OR_FAIL(PMPI_File_read_ordered);
-    MAP_OR_FAIL(PMPI_File_read_shared);
-    MAP_OR_FAIL(PMPI_File_set_view);
-    MAP_OR_FAIL(PMPI_File_sync);
-    MAP_OR_FAIL(PMPI_File_write_all_begin);
-    MAP_OR_FAIL(PMPI_File_write_all);
-    MAP_OR_FAIL(PMPI_File_write_at_all_begin);
-    MAP_OR_FAIL(PMPI_File_write_at_all);
-    MAP_OR_FAIL(PMPI_File_write_at);
-    MAP_OR_FAIL(PMPI_File_write);
-    MAP_OR_FAIL(PMPI_File_write_ordered_begin);
-    MAP_OR_FAIL(PMPI_File_write_ordered);
-    MAP_OR_FAIL(PMPI_File_write_shared);
-    MAP_OR_FAIL(PMPI_Finalize);
-    MAP_OR_FAIL(PMPI_Init);
-    MAP_OR_FAIL(PMPI_Init_thread);
-     * These function are not intercepted but are used
-     * by darshan itself.
-    MAP_OR_FAIL(PMPI_Wtime);
-    MAP_OR_FAIL(PMPI_Allreduce);
-    MAP_OR_FAIL(PMPI_Bcast);
-    MAP_OR_FAIL(PMPI_Comm_rank);
-    MAP_OR_FAIL(PMPI_Comm_size);
-    MAP_OR_FAIL(PMPI_Scan);
-    MAP_OR_FAIL(PMPI_Type_commit);
-    MAP_OR_FAIL(PMPI_Type_contiguous);
-    MAP_OR_FAIL(PMPI_Type_extent);
-    MAP_OR_FAIL(PMPI_Type_free);
-    MAP_OR_FAIL(PMPI_Type_size);
-    MAP_OR_FAIL(PMPI_Type_hindexed);
-    MAP_OR_FAIL(PMPI_Op_create);
-    MAP_OR_FAIL(PMPI_Op_free);
-    MAP_OR_FAIL(PMPI_Reduce);
-    MAP_OR_FAIL(PMPI_Type_get_envelope);
-    return;
-#endif
-int MPI_Init(int *argc, char ***argv)
-    int ret;
-    resolve_mpi_symbols();
-#endif
-    ret = DARSHAN_MPI_CALL(PMPI_Init)(argc, argv);
-    if(ret != MPI_SUCCESS)
-        return(ret);
-    darshan_mpi_initialize(argc, argv);
-    return(ret);
-int MPI_Init_thread (int *argc, char ***argv, int required, int *provided)
-    int ret;
-#endif
-    ret = DARSHAN_MPI_CALL(PMPI_Init_thread)(argc, argv, required, provided);
-    if (ret != MPI_SUCCESS)
-        return(ret);
-    return(ret);
-int MPI_Finalize(void)
-    int ret;
-    if(getenv("DARSHAN_INTERNAL_TIMING"))
-        darshan_shutdown(1);
-    else
-        darshan_shutdown(0);
-    ret = DARSHAN_MPI_CALL(PMPI_Finalize)();
-    return(ret);
diff --git a/darshan-runtime/lib/darshan-mpi-io.c b/darshan-runtime/lib/darshan-mpi-io.c
index 7f880f5..0000000
--- a/darshan-runtime/lib/darshan-mpi-io.c
+++ /dev/null
@@ -1,2580 +0,0 @@
-#define _GNU_SOURCE /* for tdestroy() */
-#include <stdio.h>
-#ifdef HAVE_MNTENT_H
-#include <mntent.h>
-#endif
-#include <time.h>
-#include <limits.h>
-#include <unistd.h>
-#include <sys/types.h>
-#include <sys/stat.h>
-#include <sys/vfs.h>
-#include <zlib.h>
-#include <assert.h>
-#include <search.h>
-#include "mpi.h"
-extern char* __progname;
-/* maximum number of memory segments each process will write to the log */
-#define CP_MAX_MEM_SEGMENTS 8
-/* Some old versions of MPI don't provide all of these COMBINER definitions.
- * If any are missing then we define them to an arbitrary value just to
- * prevent compile errors in DATATYPE_INC().
-#ifndef MPI_COMBINER_NAMED
-    #define MPI_COMBINER_NAMED CP_COMBINER_NAMED
-#endif
-#ifndef MPI_COMBINER_DUP
-    #define MPI_COMBINER_DUP CP_COMBINER_DUP
-#endif
-#ifndef MPI_COMBINER_CONTIGUOUS
-    #define MPI_COMBINER_CONTIGUOUS CP_COMBINER_CONTIGUOUS
-#endif
-#ifndef MPI_COMBINER_VECTOR
-    #define MPI_COMBINER_VECTOR CP_COMBINER_VECTOR
-#endif
-#ifndef MPI_COMBINER_HVECTOR_INTEGER
-    #define MPI_COMBINER_HVECTOR_INTEGER CP_COMBINER_HVECTOR_INTEGER
-#endif
-    #define MPI_COMBINER_HVECTOR CP_COMBINER_HVECTOR
-#endif
-#ifndef MPI_COMBINER_INDEXED
-    #define MPI_COMBINER_INDEXED CP_COMBINER_INDEXED
-#endif
-#ifndef MPI_COMBINER_HINDEXED_INTEGER
-    #define MPI_COMBINER_HINDEXED_INTEGER CP_COMBINER_HINDEXED_INTEGER
-#endif
-    #define MPI_COMBINER_HINDEXED CP_COMBINER_HINDEXED
-#endif
-#ifndef MPI_COMBINER_INDEXED_BLOCK
-    #define MPI_COMBINER_INDEXED_BLOCK CP_COMBINER_INDEXED_BLOCK
-#endif
-#ifndef MPI_COMBINER_STRUCT_INTEGER
-    #define MPI_COMBINER_STRUCT_INTEGER CP_COMBINER_STRUCT_INTEGER
-#endif
-    #define MPI_COMBINER_STRUCT CP_COMBINER_STRUCT
-#endif
-#ifndef MPI_COMBINER_SUBARRAY
-    #define MPI_COMBINER_SUBARRAY CP_COMBINER_SUBARRAY
-#endif
-#ifndef MPI_COMBINER_DARRAY
-    #define MPI_COMBINER_DARRAY CP_COMBINER_DARRAY
-#endif
-#ifndef MPI_COMBINER_F90_REAL
-    #define MPI_COMBINER_F90_REAL CP_COMBINER_F90_REAL
-#endif
-#ifndef MPI_COMBINER_F90_COMPLEX
-    #define MPI_COMBINER_F90_COMPLEX CP_COMBINER_F90_COMPLEX
-#endif
-#ifndef MPI_COMBINER_F90_INTEGER
-    #define MPI_COMBINER_F90_INTEGER CP_COMBINER_F90_INTEGER
-#endif
-#ifndef MPI_COMBINER_RESIZED
-    #define MPI_COMBINER_RESIZED CP_COMBINER_RESIZED
-#endif
-#define CP_DATATYPE_INC(__file, __datatype) do {\
-    int num_integers, num_addresses, num_datatypes, combiner, ret; \
-    ret = DARSHAN_MPI_CALL(PMPI_Type_get_envelope)(__datatype, &num_integers, \
-        &num_addresses, &num_datatypes, &combiner); \
-    if(ret == MPI_SUCCESS) { \
-        switch(combiner) { \
-            case MPI_COMBINER_NAMED:\
-                CP_INC(__file,CP_COMBINER_NAMED,1); break; \
-            case MPI_COMBINER_DUP:\
-                CP_INC(__file,CP_COMBINER_DUP,1); break; \
-            case MPI_COMBINER_CONTIGUOUS:\
-                CP_INC(__file,CP_COMBINER_CONTIGUOUS,1); break; \
-            case MPI_COMBINER_VECTOR:\
-                CP_INC(__file,CP_COMBINER_VECTOR,1); break; \
-            case MPI_COMBINER_HVECTOR_INTEGER:\
-                CP_INC(__file,CP_COMBINER_HVECTOR_INTEGER,1); break; \
-            case MPI_COMBINER_HVECTOR:\
-                CP_INC(__file,CP_COMBINER_HVECTOR,1); break; \
-            case MPI_COMBINER_INDEXED:\
-                CP_INC(__file,CP_COMBINER_INDEXED,1); break; \
-            case MPI_COMBINER_HINDEXED_INTEGER:\
-                CP_INC(__file,CP_COMBINER_HINDEXED_INTEGER,1); break; \
-            case MPI_COMBINER_HINDEXED:\
-                CP_INC(__file,CP_COMBINER_HINDEXED,1); break; \
-            case MPI_COMBINER_INDEXED_BLOCK:\
-                CP_INC(__file,CP_COMBINER_INDEXED_BLOCK,1); break; \
-            case MPI_COMBINER_STRUCT_INTEGER:\
-                CP_INC(__file,CP_COMBINER_STRUCT_INTEGER,1); break; \
-            case MPI_COMBINER_STRUCT:\
-                CP_INC(__file,CP_COMBINER_STRUCT,1); break; \
-            case MPI_COMBINER_SUBARRAY:\
-                CP_INC(__file,CP_COMBINER_SUBARRAY,1); break; \
-            case MPI_COMBINER_DARRAY:\
-                CP_INC(__file,CP_COMBINER_DARRAY,1); break; \
-            case MPI_COMBINER_F90_REAL:\
-                CP_INC(__file,CP_COMBINER_F90_REAL,1); break; \
-            case MPI_COMBINER_F90_COMPLEX:\
-                CP_INC(__file,CP_COMBINER_F90_COMPLEX,1); break; \
-            case MPI_COMBINER_F90_INTEGER:\
-                CP_INC(__file,CP_COMBINER_F90_INTEGER,1); break; \
-            case MPI_COMBINER_RESIZED:\
-                CP_INC(__file,CP_COMBINER_RESIZED,1); break; \
-} while(0)
-#define CP_RECORD_MPI_WRITE(__ret, __fh, __count, __datatype, __counter, __tm1, __tm2) do { \
-    struct darshan_file_runtime* file; \
-    int size = 0; \
-    MPI_Aint extent = 0; \
-    if(__ret != MPI_SUCCESS) break; \
-    file = darshan_file_by_fh(__fh); \
-    if(!file) break; \
-    DARSHAN_MPI_CALL(PMPI_Type_size)(__datatype, &size);  \
-    size = size * __count; \
-    DARSHAN_MPI_CALL(PMPI_Type_extent)(__datatype, &extent); \
-    CP_BUCKET_INC(file, CP_SIZE_WRITE_AGG_0_100, size); \
-    CP_BUCKET_INC(file, CP_EXTENT_WRITE_0_100, extent); \
-    CP_INC(file, __counter, 1); \
-    CP_DATATYPE_INC(file, __datatype); \
-    CP_F_INC_NO_OVERLAP(file, __tm1, __tm2, file->last_mpi_write_end, CP_F_MPI_WRITE_TIME); \
-    if(CP_F_VALUE(file, CP_F_WRITE_START_TIMESTAMP) == 0) \
-        CP_F_SET(file, CP_F_WRITE_START_TIMESTAMP, __tm1); \
-    CP_F_SET(file, CP_F_WRITE_END_TIMESTAMP, __tm2); \
-} while(0)
-#define CP_RECORD_MPI_READ(__ret, __fh, __count, __datatype, __counter, __tm1, __tm2) do { \
-    int size = 0; \
-    CP_BUCKET_INC(file, CP_SIZE_READ_AGG_0_100, size); \
-    CP_BUCKET_INC(file, CP_EXTENT_READ_0_100, extent); \
-    CP_F_INC_NO_OVERLAP(file, __tm1, __tm2, file->last_mpi_read_end, CP_F_MPI_READ_TIME); \
-    if(CP_F_VALUE(file, CP_F_READ_START_TIMESTAMP) == 0) \
-        CP_F_SET(file, CP_F_READ_START_TIMESTAMP, __tm1); \
-    CP_F_SET(file, CP_F_READ_END_TIMESTAMP, __tm2); \
-} while(0)
-static void cp_normalize_timestamps(struct darshan_job_runtime* final_job);
-static void cp_log_construct_indices(struct darshan_job_runtime* final_job,
-    int rank, int* inout_count, int* lengths, void** pointers, char*
-    trailing_data);
-static int cp_log_write(struct darshan_job_runtime* final_job, int rank,
-    char* logfile_name, int count, int* lengths, void** pointers, double start_log_time);
-static void cp_log_record_hints_and_ver(struct darshan_job_runtime* final_job, int rank);
-static int cp_log_reduction(struct darshan_job_runtime* final_job, int rank,
-    char* logfile_name, MPI_Offset* next_offset);
-static void darshan_file_reduce(void* infile_v,
-    void* inoutfile_v, int *len,
-    MPI_Datatype *datatype);
-static int cp_log_compress(struct darshan_job_runtime* final_job,
-    int rank, int* inout_count, int* lengths, void** pointers);
-static int file_compare(const void* a, const void* b);
-static int darshan_file_variance(
-    struct darshan_file *infile_array,
-    struct darshan_file *outfile_array,
-    int count, int rank);
-static void pairwise_variance_reduce (
-    void *invec, void *inoutvec, int *len, MPI_Datatype *dt);
-#if 0
-static void debug_mounts(const char* mtab_file, const char* out_file);
-#endif
-static struct darshan_file_runtime* darshan_file_by_fh(MPI_File fh);
-static void darshan_file_close_fh(MPI_File fh);
-static struct darshan_file_runtime* darshan_file_by_name_setfh(const char* name, MPI_File fh);
-#define CP_MAX_MNTS 64
-#define CP_MAX_MNT_PATH 256
-#define CP_MAX_MNT_TYPE 32
-struct mnt_data
-    int64_t hash;
-    int64_t block_size;
-    char path[CP_MAX_MNT_PATH];
-    char type[CP_MAX_MNT_TYPE];
-static struct mnt_data mnt_data_array[CP_MAX_MNTS];
-static int mnt_data_count = 0;
-struct variance_dt
-    double n;
-    double T;
-    double S;
-void darshan_mpi_initialize(int *argc, char ***argv)
-    int nprocs;
-    int rank;
-    int timing_flag = 0;
-    double init_start, init_time, init_max;
-    DARSHAN_MPI_CALL(PMPI_Comm_size)(MPI_COMM_WORLD, &nprocs);
-    DARSHAN_MPI_CALL(PMPI_Comm_rank)(MPI_COMM_WORLD, &rank);
-        timing_flag = 1;
-    if(timing_flag)
-        init_start = DARSHAN_MPI_CALL(PMPI_Wtime)();
-    if(argc && argv)
-        darshan_initialize(*argc, *argv, nprocs, rank);
-    else
-        /* we don't see argc and argv here in fortran */
-        darshan_initialize(0, NULL, nprocs, rank);
-    if(timing_flag)
-        init_time = DARSHAN_MPI_CALL(PMPI_Wtime)() - init_start;
-        DARSHAN_MPI_CALL(PMPI_Reduce)(&init_time, &init_max, 1,
-            MPI_DOUBLE, MPI_MAX, 0, MPI_COMM_WORLD);
-        if(rank == 0)
-            printf("#darshan:<op>\t<nprocs>\t<time>\n");
-            printf("darshan:init\t%d\t%f\n", nprocs, init_max);
-    return;
-void darshan_shutdown(int timing_flag)
-    int rank;
-    char* logfile_name;
-    struct darshan_job_runtime* final_job;
-    double start_log_time = 0;
-    int all_ret = 0;
-    int local_ret = 0;
-    MPI_Offset next_offset = 0;
-    char* jobid_str;
-    char* envjobid;
-    char* logpath;
-    int jobid;
-    int index_count = 0;
-    int lengths[CP_MAX_MEM_SEGMENTS];
-    void* pointers[CP_MAX_MEM_SEGMENTS];
-    int ret;
-    double red1=0, red2=0, gz1=0, gz2=0, write1=0, write2=0, tm_end=0;
-    double bcst=0;
-    int nprocs;
-    time_t start_time_tmp = 0;
-    uint64_t logmod;
-    char hname[HOST_NAME_MAX];
-    char* logpath_override = NULL;
-#ifdef __CP_LOG_ENV
-    char env_check[256];
-    char* env_tok;
-#endif
-    uint64_t hlevel;
-    int64_t first_start_time;
-    int64_t last_end_time;
-    CP_LOCK();
-    if(!darshan_global_job)
-        CP_UNLOCK();
-        return;
-     * write it out
-    final_job = darshan_global_job;
-    darshan_global_job = NULL;
-    CP_UNLOCK();
-    start_log_time = DARSHAN_MPI_CALL(PMPI_Wtime)();
-    /* figure out which access sizes to log */
-    darshan_walk_file_accesses(final_job);
-    /* if the records have been condensed, then zero out fields that are no
-     * longer valid for safety
-    if(final_job->flags & CP_FLAG_CONDENSED && final_job->file_count)
-        CP_SET(&final_job->file_runtime_array[0], CP_MODE, 0);
-        CP_SET(&final_job->file_runtime_array[0], CP_CONSEC_READS, 0);
-        CP_SET(&final_job->file_runtime_array[0], CP_CONSEC_WRITES, 0);
-        CP_SET(&final_job->file_runtime_array[0], CP_SEQ_READS, 0);
-        CP_SET(&final_job->file_runtime_array[0], CP_SEQ_WRITES, 0);
-        CP_SET(&final_job->file_runtime_array[0], CP_STRIDE1_STRIDE, 0);
-        CP_SET(&final_job->file_runtime_array[0], CP_STRIDE2_STRIDE, 0);
-        CP_SET(&final_job->file_runtime_array[0], CP_STRIDE3_STRIDE, 0);
-        CP_SET(&final_job->file_runtime_array[0], CP_STRIDE4_STRIDE, 0);
-        CP_SET(&final_job->file_runtime_array[0], CP_STRIDE1_COUNT, 0);
-        CP_SET(&final_job->file_runtime_array[0], CP_STRIDE2_COUNT, 0);
-        CP_SET(&final_job->file_runtime_array[0], CP_STRIDE3_COUNT, 0);
-        CP_SET(&final_job->file_runtime_array[0], CP_STRIDE4_COUNT, 0);
-        CP_SET(&final_job->file_runtime_array[0], CP_ACCESS1_ACCESS, 0);
-        CP_SET(&final_job->file_runtime_array[0], CP_ACCESS2_ACCESS, 0);
-        CP_SET(&final_job->file_runtime_array[0], CP_ACCESS3_ACCESS, 0);
-        CP_SET(&final_job->file_runtime_array[0], CP_ACCESS4_ACCESS, 0);
-        CP_SET(&final_job->file_runtime_array[0], CP_ACCESS1_COUNT, 0);
-        CP_SET(&final_job->file_runtime_array[0], CP_ACCESS2_COUNT, 0);
-        CP_SET(&final_job->file_runtime_array[0], CP_ACCESS3_COUNT, 0);
-        CP_SET(&final_job->file_runtime_array[0], CP_ACCESS4_COUNT, 0);
-        CP_F_SET(&final_job->file_runtime_array[0], CP_F_OPEN_TIMESTAMP, 0);
-        CP_F_SET(&final_job->file_runtime_array[0], CP_F_CLOSE_TIMESTAMP, 0);
-        CP_F_SET(&final_job->file_runtime_array[0], CP_F_READ_START_TIMESTAMP, 0);
-        CP_F_SET(&final_job->file_runtime_array[0], CP_F_READ_END_TIMESTAMP, 0);
-        CP_F_SET(&final_job->file_runtime_array[0], CP_F_WRITE_START_TIMESTAMP, 0);
-        CP_F_SET(&final_job->file_runtime_array[0], CP_F_WRITE_END_TIMESTAMP, 0);
-    logfile_name = malloc(PATH_MAX);
-    if(!logfile_name)
-        darshan_finalize(final_job);
-        return;
-    /* construct log file name */
-    if(rank == 0)
-        char cuser[L_cuserid] = {0};
-        struct tm* my_tm;
-        /* Use CP_JOBID_OVERRIDE for the env var or CP_JOBID */
-        envjobid = getenv(CP_JOBID_OVERRIDE);
-        if (!envjobid)
-            envjobid = CP_JOBID;
-        /* Use CP_LOG_PATH_OVERRIDE for the value or __CP_LOG_PATH */
-        logpath = getenv(CP_LOG_PATH_OVERRIDE);
-        if (!logpath)
-#ifdef __CP_LOG_PATH
-            logpath = __CP_LOG_PATH;
-#endif
-        /* find a job id */
-        jobid_str = getenv(envjobid);
-        if(jobid_str)
-            /* in cobalt we can find it in env var */
-            ret = sscanf(jobid_str, "%d", &jobid);
-        if(!jobid_str || ret != 1)
-            /* use pid as fall back */
-            jobid = getpid();
-        /* break out time into something human readable */
-        start_time_tmp += final_job->log_job.start_time;
-        my_tm = localtime(&start_time_tmp);
-        /* get the username for this job.  In order we will try each of the
-         * following until one of them succeeds:
-         * - cuserid()
-         * - getenv("LOGNAME")
-         * - snprintf(..., geteuid());
-         * Note that we do not use getpwuid() because it generally will not
-         * work in statically compiled binaries.
-#ifndef DARSHAN_DISABLE_CUSERID
-        cuserid(cuser);
-#endif
-        /* if cuserid() didn't work, then check the environment */
-        if (strcmp(cuser, "") == 0)
-            char* logname_string;
-            logname_string = getenv("LOGNAME");
-            if(logname_string)
-                strncpy(cuser, logname_string, (L_cuserid-1));
-        /* if cuserid() and environment both fail, then fall back to uid */
-            uid_t uid = geteuid();
-            snprintf(cuser, sizeof(cuser), "%u", uid);
-        /* generate a random number to help differentiate the log */
-        hlevel=DARSHAN_MPI_CALL(PMPI_Wtime)() * 1000000;
-        (void) gethostname(hname, sizeof(hname));
-        logmod = darshan_hash((void*)hname,strlen(hname),hlevel);
-        /* see if darshan was configured using the --with-logpath-by-env
-         * argument, which allows the user to specify an absolute path to
-         * place logs via an env variable.
-        /* just silently skip if the environment variable list is too big */
-        if(strlen(__CP_LOG_ENV) < 256)
-            /* copy env variable list to a temporary buffer */
-            strcpy(env_check, __CP_LOG_ENV);
-            /* tokenize the comma-separated list */
-            env_tok = strtok(env_check, ",");
-            if(env_tok)
-                do
-                    /* check each env variable in order */
-                    logpath_override = getenv(env_tok);
-                    if(logpath_override)
-                        /* stop as soon as we find a match */
-                        break;
-                }while((env_tok = strtok(NULL, ",")));
-#endif
-            ret = snprintf(logfile_name, PATH_MAX,
-                "%s/%s_%s_id%d_%d-%d-%d-%" PRIu64 ".darshan_partial",
-                logpath_override,
-                cuser, __progname, jobid,
-                (my_tm->tm_mon+1),
-                my_tm->tm_mday,
-                (my_tm->tm_hour*60*60 + my_tm->tm_min*60 + my_tm->tm_sec),
-                logmod);
-            if(ret == (PATH_MAX-1))
-                /* file name was too big; squish it down */
-                snprintf(logfile_name, PATH_MAX,
-                    "%s/id%d.darshan_partial",
-                    logpath_override, jobid);
-        else if(logpath)
-                "%s/%d/%d/%d/%s_%s_id%d_%d-%d-%d-%" PRIu64 ".darshan_partial",
-                logpath, (my_tm->tm_year+1900),
-                (my_tm->tm_mon+1), my_tm->tm_mday,
-                my_tm->tm_mday,
-                logmod);
-                    logpath, jobid);
-        else
-            logfile_name[0] = '\0';
-        /* add jobid */
-        final_job->log_job.jobid = (int64_t)jobid;
-    /* broadcast log file name */
-    bcst=DARSHAN_MPI_CALL(PMPI_Wtime)();
-    DARSHAN_MPI_CALL(PMPI_Bcast)(logfile_name, PATH_MAX, MPI_CHAR, 0,
-        MPI_COMM_WORLD);
-    if(strlen(logfile_name) == 0)
-        /* failed to generate log file name */
-	return;
-    final_job->log_job.end_time = time(NULL);
-    /* reduce to report first start time and last end time across all ranks
-     * at rank 0
-    DARSHAN_MPI_CALL(PMPI_Reduce)(&final_job->log_job.start_time, &first_start_time, 1, MPI_LONG_LONG, MPI_MIN, 0, MPI_COMM_WORLD);
-    DARSHAN_MPI_CALL(PMPI_Reduce)(&final_job->log_job.end_time, &last_end_time, 1, MPI_LONG_LONG, MPI_MAX, 0, MPI_COMM_WORLD);
-    if(rank == 0)
-        final_job->log_job.start_time = first_start_time;
-        final_job->log_job.end_time = last_end_time;
-    /* reduce records for shared files */
-    if(timing_flag)
-        red1 = DARSHAN_MPI_CALL(PMPI_Wtime)();
-    if(getenv("DARSHAN_DISABLE_SHARED_REDUCTION"))
-        local_ret = 0;
-    else
-        local_ret = cp_log_reduction(final_job, rank, logfile_name,
-            &next_offset);
-    if(timing_flag)
-        red2 = DARSHAN_MPI_CALL(PMPI_Wtime)();
-    DARSHAN_MPI_CALL(PMPI_Allreduce)(&local_ret, &all_ret, 1, MPI_INT, MPI_LOR,
-        MPI_COMM_WORLD);
-    /* adjust timestamps in any remaining records */
-    cp_normalize_timestamps(final_job);
-    /* if we are using any hints to write the log file, then record those
-     * hints in the log file header
-    cp_log_record_hints_and_ver(final_job, rank);
-    if(all_ret == 0)
-        /* collect data to write from local process */
-        cp_log_construct_indices(final_job, rank, &index_count, lengths,
-            pointers, final_job->trailing_data);
-    if(all_ret == 0)
-        /* compress data */
-        if(timing_flag)
-            gz1 = DARSHAN_MPI_CALL(PMPI_Wtime)();
-        local_ret = cp_log_compress(final_job, rank, &index_count,
-            lengths, pointers);
-        if(timing_flag)
-            gz2 = DARSHAN_MPI_CALL(PMPI_Wtime)();
-            MPI_INT, MPI_LOR, MPI_COMM_WORLD);
-    if(all_ret == 0)
-        /* actually write out log file */
-        if(timing_flag)
-            write1 = DARSHAN_MPI_CALL(PMPI_Wtime)();
-        local_ret = cp_log_write(final_job, rank, logfile_name,
-            index_count, lengths, pointers, start_log_time);
-        if(timing_flag)
-            write2 = DARSHAN_MPI_CALL(PMPI_Wtime)();
-    if(rank == 0)
-        if(all_ret != 0)
-            fprintf(stderr, "darshan library warning: unable to write log file %s\n", logfile_name);
-            /* if any process failed to write log, then delete the whole
-             * file so we don't leave corrupted results
-            unlink(logfile_name);
-        else
-            /* rename from *.darshan_partial to *-<logwritetime>.darshan.gz,
-             * which indicates that this log file is complete and ready for
-             * analysis
-            char* mod_index;
-            double end_log_time;
-            char* new_logfile_name;
-            new_logfile_name = malloc(PATH_MAX);
-            if(new_logfile_name)
-                new_logfile_name[0] = '\0';
-                end_log_time = DARSHAN_MPI_CALL(PMPI_Wtime)();
-                strcat(new_logfile_name, logfile_name);
-                mod_index = strstr(new_logfile_name, ".darshan_partial");
-                sprintf(mod_index, "_%d.darshan.gz", (int)(end_log_time-start_log_time+1));
-                rename(logfile_name, new_logfile_name);
-                /* set permissions on log file */
-#ifdef __CP_GROUP_READABLE_LOGS
-                chmod(new_logfile_name, (S_IRUSR|S_IRGRP));
-#else
-                chmod(new_logfile_name, (S_IRUSR));
-#endif
-                free(new_logfile_name);
-    if(final_job->trailing_data)
-        free(final_job->trailing_data);
-    mnt_data_count = 0;
-    free(logfile_name);
-    if(timing_flag)
-        double red_tm, red_slowest;
-        double gz_tm, gz_slowest;
-        double write_tm, write_slowest;
-        double all_tm, all_slowest;
-        double bcst_tm, bcst_slowest;
-        tm_end = DARSHAN_MPI_CALL(PMPI_Wtime)();
-        bcst_tm= red1-bcst;
-        red_tm = red2-red1;
-        gz_tm = gz2-gz1;
-        write_tm = write2-write1;
-        all_tm = tm_end-start_log_time;
-        DARSHAN_MPI_CALL(PMPI_Reduce)(&red_tm, &red_slowest, 1,
-        DARSHAN_MPI_CALL(PMPI_Reduce)(&gz_tm, &gz_slowest, 1,
-        DARSHAN_MPI_CALL(PMPI_Reduce)(&write_tm, &write_slowest, 1,
-        DARSHAN_MPI_CALL(PMPI_Reduce)(&all_tm, &all_slowest, 1,
-        DARSHAN_MPI_CALL(PMPI_Reduce)(&bcst_tm, &bcst_slowest, 1,
-        if(rank == 0)
-            printf("darshan:bcst\t%d\t%f\n", nprocs, bcst_slowest);
-            printf("darshan:reduce\t%d\t%f\n", nprocs, red_slowest);
-            printf("darshan:gzip\t%d\t%f\n", nprocs, gz_slowest);
-            printf("darshan:write\t%d\t%f\n", nprocs, write_slowest);
-            printf("darshan:bcast+reduce+gzip+write\t%d\t%f\n", nprocs, all_slowest);
-    return;
-int MPI_File_open(MPI_Comm comm, const char *filename, int amode, MPI_Info info, MPI_File *fh)
-#else
-int MPI_File_open(MPI_Comm comm, char *filename, int amode, MPI_Info info, MPI_File *fh)
-#endif
-    int ret;
-    char* tmp;
-    int comm_size;
-    double tm1, tm2;
-    ret = DARSHAN_MPI_CALL(PMPI_File_open)(comm, filename, amode, info, fh);
-    tm2 = darshan_wtime();
-        CP_LOCK();
-        file = darshan_file_by_name_setfh(filename, (*fh));
-        if(file)
-            CP_SET(file, CP_MODE, amode);
-            CP_F_INC_NO_OVERLAP(file, tm1, tm2, file->last_mpi_meta_end, CP_F_MPI_META_TIME);
-                tm1);
-            DARSHAN_MPI_CALL(PMPI_Comm_size)(comm, &comm_size);
-            if(comm_size == 1)
-                CP_INC(file, CP_INDEP_OPENS, 1);
-            else
-                CP_INC(file, CP_COLL_OPENS, 1);
-            if(info != MPI_INFO_NULL)
-                CP_INC(file, CP_HINTS, 1);
-        CP_UNLOCK();
-    return(ret);
-int MPI_File_close(MPI_File *fh)
-    MPI_File tmp_fh = *fh;
-    double tm1, tm2;
-    int ret;
-    ret = DARSHAN_MPI_CALL(PMPI_File_close)(fh);
-    CP_LOCK();
-    file = darshan_file_by_fh(tmp_fh);
-    if(file)
-        CP_F_SET(file, CP_F_CLOSE_TIMESTAMP, DARSHAN_MPI_CALL(PMPI_Wtime)());
-        darshan_file_close_fh(tmp_fh);
-    CP_UNLOCK();
-    return(ret);
-int MPI_File_sync(MPI_File fh)
-    int ret;
-    double tm1, tm2;
-    ret = DARSHAN_MPI_CALL(PMPI_File_sync)(fh);
-        CP_LOCK();
-        file = darshan_file_by_fh(fh);
-        if(file)
-            CP_F_INC_NO_OVERLAP(file, tm1, tm2, file->last_mpi_write_end, CP_F_MPI_WRITE_TIME);
-            CP_INC(file, CP_SYNCS, 1);
-        CP_UNLOCK();
-    return(ret);
-int MPI_File_set_view(MPI_File fh, MPI_Offset disp, MPI_Datatype etype,
-    MPI_Datatype filetype, const char *datarep, MPI_Info info)
-#else
-    MPI_Datatype filetype, char *datarep, MPI_Info info)
-#endif
-    int ret;
-    double tm1, tm2;
-    ret = DARSHAN_MPI_CALL(PMPI_File_set_view)(fh, disp, etype,
-        filetype, datarep, info);
-        CP_LOCK();
-        if(file)
-            CP_INC(file, CP_VIEWS, 1);
-            CP_DATATYPE_INC(file, filetype);
-        CP_UNLOCK();
-    return(ret);
-int MPI_File_read(MPI_File fh, void *buf, int count,
-    MPI_Datatype datatype, MPI_Status *status)
-    int ret;
-    double tm1, tm2;
-    ret = DARSHAN_MPI_CALL(PMPI_File_read)(fh, buf, count, datatype, status);
-    CP_LOCK();
-    CP_RECORD_MPI_READ(ret, fh, count, datatype, CP_INDEP_READS, tm1, tm2);
-    CP_UNLOCK();
-    return(ret);
-int MPI_File_read_at(MPI_File fh, MPI_Offset offset, void *buf,
-    int count, MPI_Datatype datatype, MPI_Status *status)
-    int ret;
-    double tm1, tm2;
-    ret = DARSHAN_MPI_CALL(PMPI_File_read_at)(fh, offset, buf,
-        count, datatype, status);
-    CP_LOCK();
-    CP_UNLOCK();
-    return(ret);
-int MPI_File_read_at_all(MPI_File fh, MPI_Offset offset, void * buf,
-    int count, MPI_Datatype datatype, MPI_Status * status)
-    int ret;
-    double tm1, tm2;
-    ret = DARSHAN_MPI_CALL(PMPI_File_read_at_all)(fh, offset, buf,
-    CP_LOCK();
-    CP_RECORD_MPI_READ(ret, fh, count, datatype, CP_COLL_READS, tm1, tm2);
-    CP_UNLOCK();
-    return(ret);
-int MPI_File_read_all(MPI_File fh, void * buf, int count, MPI_Datatype datatype, MPI_Status *status)
-    int ret;
-    double tm1, tm2;
-    ret = DARSHAN_MPI_CALL(PMPI_File_read_all)(fh, buf, count,
-        datatype, status);
-    CP_LOCK();
-    CP_UNLOCK();
-    return(ret);
-int MPI_File_read_shared(MPI_File fh, void * buf, int count, MPI_Datatype datatype, MPI_Status *status)
-    int ret;
-    double tm1, tm2;
-    ret = DARSHAN_MPI_CALL(PMPI_File_read_shared)(fh, buf, count,
-    CP_LOCK();
-    CP_UNLOCK();
-    return(ret);
-int MPI_File_read_ordered(MPI_File fh, void * buf, int count,
-    MPI_Datatype datatype, MPI_Status * status)
-    int ret;
-    double tm1, tm2;
-    ret = DARSHAN_MPI_CALL(PMPI_File_read_ordered)(fh, buf, count,
-    CP_LOCK();
-    CP_UNLOCK();
-    return(ret);
-int MPI_File_read_at_all_begin(MPI_File fh, MPI_Offset offset, void * buf,
-    int count, MPI_Datatype datatype)
-    int ret;
-    double tm1, tm2;
-    ret = DARSHAN_MPI_CALL(PMPI_File_read_at_all_begin)(fh, offset, buf,
-        count, datatype);
-    CP_LOCK();
-    CP_RECORD_MPI_READ(ret, fh, count, datatype, CP_SPLIT_READS, tm1, tm2);
-    CP_UNLOCK();
-    return(ret);
-int MPI_File_read_all_begin(MPI_File fh, void * buf, int count, MPI_Datatype datatype)
-    int ret;
-    double tm1, tm2;
-    ret = DARSHAN_MPI_CALL(PMPI_File_read_all_begin)(fh, buf, count, datatype);
-    CP_LOCK();
-    CP_UNLOCK();
-    return(ret);
-int MPI_File_read_ordered_begin(MPI_File fh, void * buf, int count, MPI_Datatype datatype)
-    int ret;
-    double tm1, tm2;
-    ret = DARSHAN_MPI_CALL(PMPI_File_read_ordered_begin)(fh, buf, count,
-        datatype);
-    CP_LOCK();
-    CP_UNLOCK();
-    return(ret);
-int MPI_File_iread_at(MPI_File fh, MPI_Offset offset, void * buf,
-    int count, MPI_Datatype datatype, __D_MPI_REQUEST *request)
-    int ret;
-    double tm1, tm2;
-    ret = DARSHAN_MPI_CALL(PMPI_File_iread_at)(fh, offset, buf, count,
-        datatype, request);
-    CP_LOCK();
-    CP_RECORD_MPI_READ(ret, fh, count, datatype, CP_NB_READS, tm1, tm2);
-    CP_UNLOCK();
-    return(ret);
-int MPI_File_iread(MPI_File fh, void * buf, int count, MPI_Datatype datatype, __D_MPI_REQUEST * request)
-    int ret;
-    double tm1, tm2;
-    ret = DARSHAN_MPI_CALL(PMPI_File_iread)(fh, buf, count, datatype, request);
-    CP_LOCK();
-    CP_UNLOCK();
-    return(ret);
-int MPI_File_iread_shared(MPI_File fh, void * buf, int count,
-    MPI_Datatype datatype, __D_MPI_REQUEST * request)
-    int ret;
-    double tm1, tm2;
-    ret = DARSHAN_MPI_CALL(PMPI_File_iread_shared)(fh, buf, count,
-    CP_LOCK();
-    CP_UNLOCK();
-    return(ret);
-int MPI_File_write(MPI_File fh, const void *buf, int count,
-#else
-int MPI_File_write(MPI_File fh, void *buf, int count,
-#endif
-    int ret;
-    double tm1, tm2;
-    ret = DARSHAN_MPI_CALL(PMPI_File_write)(fh, buf, count, datatype, status);
-    CP_LOCK();
-    CP_RECORD_MPI_WRITE(ret, fh, count, datatype, CP_INDEP_WRITES, tm1, tm2);
-    CP_UNLOCK();
-    return(ret);
-int MPI_File_write_at(MPI_File fh, MPI_Offset offset, const void *buf,
-#else
-int MPI_File_write_at(MPI_File fh, MPI_Offset offset, void *buf,
-#endif
-    int ret;
-    double tm1, tm2;
-    ret = DARSHAN_MPI_CALL(PMPI_File_write_at)(fh, offset, buf,
-    CP_LOCK();
-    CP_UNLOCK();
-    return(ret);
-int MPI_File_write_at_all(MPI_File fh, MPI_Offset offset, const void * buf,
-#else
-int MPI_File_write_at_all(MPI_File fh, MPI_Offset offset, void * buf,
-#endif
-    int ret;
-    double tm1, tm2;
-    ret = DARSHAN_MPI_CALL(PMPI_File_write_at_all)(fh, offset, buf,
-    CP_LOCK();
-    CP_RECORD_MPI_WRITE(ret, fh, count, datatype, CP_COLL_WRITES, tm1, tm2);
-    CP_UNLOCK();
-    return(ret);
-int MPI_File_write_all(MPI_File fh, const void * buf, int count, MPI_Datatype datatype, MPI_Status *status)
-#else
-int MPI_File_write_all(MPI_File fh, void * buf, int count, MPI_Datatype datatype, MPI_Status *status)
-#endif
-    int ret;
-    double tm1, tm2;
-    ret = DARSHAN_MPI_CALL(PMPI_File_write_all)(fh, buf, count,
-    CP_LOCK();
-    CP_UNLOCK();
-    return(ret);
-int MPI_File_write_shared(MPI_File fh, const void * buf, int count, MPI_Datatype datatype, MPI_Status *status)
-#else
-int MPI_File_write_shared(MPI_File fh, void * buf, int count, MPI_Datatype datatype, MPI_Status *status)
-#endif
-    int ret;
-    double tm1, tm2;
-    ret = DARSHAN_MPI_CALL(PMPI_File_write_shared)(fh, buf, count,
-    CP_LOCK();
-    CP_UNLOCK();
-    return(ret);
-int MPI_File_write_ordered(MPI_File fh, const void * buf, int count,
-#else
-int MPI_File_write_ordered(MPI_File fh, void * buf, int count,
-#endif
-    int ret;
-    double tm1, tm2;
-    ret = DARSHAN_MPI_CALL(PMPI_File_write_ordered)(fh, buf, count,
-    CP_LOCK();
-    CP_UNLOCK();
-    return(ret);
-int MPI_File_write_at_all_begin(MPI_File fh, MPI_Offset offset, const void * buf,
-#else
-int MPI_File_write_at_all_begin(MPI_File fh, MPI_Offset offset, void * buf,
-#endif
-    int ret;
-    double tm1, tm2;
-    ret = DARSHAN_MPI_CALL(PMPI_File_write_at_all_begin)(fh, offset,
-        buf, count, datatype);
-    CP_LOCK();
-    CP_RECORD_MPI_WRITE(ret, fh, count, datatype, CP_SPLIT_WRITES, tm1, tm2);
-    CP_UNLOCK();
-    return(ret);
-int MPI_File_write_all_begin(MPI_File fh, const void * buf, int count, MPI_Datatype datatype)
-#else
-int MPI_File_write_all_begin(MPI_File fh, void * buf, int count, MPI_Datatype datatype)
-#endif
-    int ret;
-    double tm1, tm2;
-    ret = DARSHAN_MPI_CALL(PMPI_File_write_all_begin)(fh, buf, count, datatype);
-    CP_LOCK();
-    CP_UNLOCK();
-    return(ret);
-int MPI_File_write_ordered_begin(MPI_File fh, const void * buf, int count, MPI_Datatype datatype)
-#else
-int MPI_File_write_ordered_begin(MPI_File fh, void * buf, int count, MPI_Datatype datatype)
-#endif
-    int ret;
-    double tm1, tm2;
-    ret = DARSHAN_MPI_CALL(PMPI_File_write_ordered_begin)(fh, buf, count,
-        datatype);
-    CP_LOCK();
-    CP_UNLOCK();
-    return(ret);
-int MPI_File_iwrite_at(MPI_File fh, MPI_Offset offset, const void * buf,
-#else
-int MPI_File_iwrite_at(MPI_File fh, MPI_Offset offset, void * buf,
-#endif
-    int ret;
-    double tm1, tm2;
-    ret = DARSHAN_MPI_CALL(PMPI_File_iwrite_at)(fh, offset, buf,
-        count, datatype, request);
-    CP_LOCK();
-    CP_RECORD_MPI_WRITE(ret, fh, count, datatype, CP_NB_WRITES, tm1, tm2);
-    CP_UNLOCK();
-    return(ret);
-int MPI_File_iwrite(MPI_File fh, const void * buf, int count, MPI_Datatype datatype, __D_MPI_REQUEST * request)
-#else
-int MPI_File_iwrite(MPI_File fh, void * buf, int count, MPI_Datatype datatype, __D_MPI_REQUEST * request)
-#endif
-    int ret;
-    double tm1, tm2;
-    ret = DARSHAN_MPI_CALL(PMPI_File_iwrite)(fh, buf, count, datatype, request);
-    CP_LOCK();
-    CP_UNLOCK();
-    return(ret);
-int MPI_File_iwrite_shared(MPI_File fh, const void * buf, int count,
-#else
-int MPI_File_iwrite_shared(MPI_File fh, void * buf, int count,
-#endif
-    int ret;
-    double tm1, tm2;
-    ret = DARSHAN_MPI_CALL(PMPI_File_iwrite_shared)(fh, buf, count,
-    CP_LOCK();
-    CP_UNLOCK();
-    return(ret);
-/* cp_log_reduction()
- * Identify shared files and reduce them to one log entry
- * returns 0 on success, -1 on failure
-    /* TODO: these need to be allocated differently now, too big */
-    uint64_t hash_array[CP_MAX_FILES] = {0};
-    int mask_array[CP_MAX_FILES] = {0};
-    int all_mask_array[CP_MAX_FILES] = {0};
-    int ret;
-    int i;
-    int j;
-    MPI_Op reduce_op;
-    MPI_Datatype rtype;
-    struct darshan_file* tmp_array = NULL;
-    int shared_count = 0;
-    double mpi_time, posix_time;
-    /* register a reduction operation */
-    ret = DARSHAN_MPI_CALL(PMPI_Op_create)(darshan_file_reduce, 1, &reduce_op);
-    if(ret != 0)
-        return(-1);
-    /* construct a datatype for a file record.  This is serving no purpose
-     * except to make sure we can do a reduction on proper boundaries
-    DARSHAN_MPI_CALL(PMPI_Type_contiguous)(sizeof(struct darshan_file),
-        MPI_BYTE, &rtype);
-    DARSHAN_MPI_CALL(PMPI_Type_commit)(&rtype);
-    /* gather list of files that root process has opened */
-    if(rank == 0)
-        for(i=0; i<final_job->file_count; i++)
-            hash_array[i] = final_job->file_array[i].hash;
-    /* broadcast list of files to all other processes */
-    ret = DARSHAN_MPI_CALL(PMPI_Bcast)(hash_array,
-        (CP_MAX_FILES * sizeof(uint64_t)),
-        MPI_BYTE, 0, MPI_COMM_WORLD);
-    if(ret != 0)
-        DARSHAN_MPI_CALL(PMPI_Op_free)(&reduce_op);
-        DARSHAN_MPI_CALL(PMPI_Type_free)(&rtype);
-        return(-1);
-    /* everyone looks to see if they have also opened that same file */
-    for(i=0; (i<CP_MAX_FILES && hash_array[i] != 0); i++)
-        for(j=0; j<final_job->file_count; j++)
-            if(hash_array[i] && final_job->file_array[j].hash == hash_array[i])
-                /* we opened that file too */
-                mask_array[i] = 1;
-                break;
-    /* now allreduce so that everyone agrees on which files are shared */
-    ret = DARSHAN_MPI_CALL(PMPI_Allreduce)(mask_array, all_mask_array,
-        CP_MAX_FILES, MPI_INT, MPI_LAND, MPI_COMM_WORLD);
-    if(ret != 0)
-        return(-1);
-    /* walk through mask array counting entries and marking corresponding
-     * files with a rank of -1
-    for(i=0; i<CP_MAX_FILES; i++)
-        if(all_mask_array[i])
-            shared_count++;
-                if(final_job->file_array[j].hash == hash_array[i])
-                    posix_time =
-                      final_job->file_array[j].fcounters[CP_F_POSIX_META_TIME] +
-                      final_job->file_array[j].fcounters[CP_F_POSIX_READ_TIME] +
-                      final_job->file_array[j].fcounters[CP_F_POSIX_WRITE_TIME];
-                    mpi_time =
-                      final_job->file_array[j].fcounters[CP_F_MPI_META_TIME] +
-                      final_job->file_array[j].fcounters[CP_F_MPI_READ_TIME] +
-                      final_job->file_array[j].fcounters[CP_F_MPI_WRITE_TIME];
-                     * Initialize fastest/slowest info prior
-                     * to the reduction.
-                    final_job->file_array[j].counters[CP_FASTEST_RANK] =
-                      final_job->file_array[j].rank;
-                    final_job->file_array[j].counters[CP_FASTEST_RANK_BYTES] =
-                      final_job->file_array[j].counters[CP_BYTES_READ] +
-                      final_job->file_array[j].counters[CP_BYTES_WRITTEN];
-                    /* use MPI timing if this file was accessed with MPI */
-                    if(mpi_time > 0)
-                        final_job->file_array[j].fcounters[CP_F_FASTEST_RANK_TIME] =
-                        mpi_time;
-                    else
-                        posix_time;
-                    /* Until reduction occurs, we assume that this rank is
-                     * both the fastest and slowest.  It is up to the
-                     * reduction operator to find the true min and max if it
-                     * is a shared file.
-                    final_job->file_array[j].counters[CP_SLOWEST_RANK] =
-                        final_job->file_array[j].counters[CP_FASTEST_RANK];
-                    final_job->file_array[j].counters[CP_SLOWEST_RANK_BYTES] =
-                        final_job->file_array[j].counters[CP_FASTEST_RANK_BYTES];
-                    final_job->file_array[j].fcounters[CP_F_SLOWEST_RANK_TIME] =
-                        final_job->file_array[j].fcounters[CP_F_FASTEST_RANK_TIME];
-                    final_job->file_array[j].rank = -1;
-                    break;
-    if(shared_count)
-        if(rank == 0)
-            /* root proc needs to allocate memory to store reduction */
-            tmp_array = malloc(shared_count*sizeof(struct darshan_file));
-            if(!tmp_array)
-                /* TODO: think more about how to handle errors like this */
-                return(-1);
-        /* sort the array of files descending by rank so that we get all of the
-         * shared files (marked by rank -1) in a contiguous portion at end
-         * of the array
-        qsort(final_job->file_array, final_job->file_count,
-            sizeof(struct darshan_file), file_compare);
-        ret = DARSHAN_MPI_CALL(PMPI_Reduce)(
-            &final_job->file_array[final_job->file_count-shared_count],
-            tmp_array, shared_count, rtype, reduce_op, 0, MPI_COMM_WORLD);
-        if(ret != 0)
-            return(-1);
-        ret = darshan_file_variance(
-            tmp_array, shared_count, rank);
-        if (ret)
-            return(-1);
-        if(rank == 0)
-            /* root replaces local files with shared ones */
-            memcpy(&final_job->file_array[final_job->file_count-shared_count],
-                tmp_array, shared_count*sizeof(struct darshan_file));
-            free(tmp_array);
-            tmp_array = NULL;
-        else
-            /* everyone else simply discards those file records */
-            final_job->file_count -= shared_count;
-    return(0);
-/* TODO: should we use more of the CP macros here? */
-    struct darshan_file tmp_file;
-    struct darshan_file* infile = infile_v;
-    struct darshan_file* inoutfile = inoutfile_v;
-    struct darshan_file_runtime tmp_runtime;
-    int i;
-    int j;
-    int k;
-    for(i=0; i<*len; i++)
-        memset(&tmp_file, 0, sizeof(tmp_file));
-        tmp_file.hash = infile->hash;
-        tmp_file.rank = -1; /* indicates shared across all procs */
-        /* sum */
-        for(j=CP_INDEP_OPENS; j<=CP_VIEWS; j++)
-            tmp_file.counters[j] = infile->counters[j] +
-                inoutfile->counters[j];
-        /* pick one, favoring complete records if available */
-        if(CP_FILE_PARTIAL(infile))
-            tmp_file.counters[CP_MODE] = inoutfile->counters[CP_MODE];
-        else
-            tmp_file.counters[CP_MODE] = infile->counters[CP_MODE];
-        /* sum */
-        for(j=CP_BYTES_READ; j<=CP_BYTES_WRITTEN; j++)
-        /* max */
-        for(j=CP_MAX_BYTE_READ; j<=CP_MAX_BYTE_WRITTEN; j++)
-            tmp_file.counters[j] = (
-                (infile->counters[j] > inoutfile->counters[j]) ?
-                infile->counters[j] :
-                inoutfile->counters[j]);
-        /* sum */
-        for(j=CP_CONSEC_READS; j<=CP_MEM_NOT_ALIGNED; j++)
-            tmp_file.counters[CP_MEM_ALIGNMENT] = inoutfile->counters[CP_MEM_ALIGNMENT];
-        else
-            tmp_file.counters[CP_MEM_ALIGNMENT] = infile->counters[CP_MEM_ALIGNMENT];
-        /* sum */
-        for(j=CP_FILE_NOT_ALIGNED; j<=CP_FILE_NOT_ALIGNED; j++)
-            tmp_file.counters[CP_FILE_ALIGNMENT] = inoutfile->counters[CP_FILE_ALIGNMENT];
-        else
-            tmp_file.counters[CP_FILE_ALIGNMENT] = infile->counters[CP_FILE_ALIGNMENT];
-        /* skip CP_MAX_*_TIME_SIZE; handled in floating point section */
-        /* sum */
-        for(j=CP_SIZE_READ_0_100; j<=CP_EXTENT_WRITE_1G_PLUS; j++)
-        /* pick the 4 most common strides out of the 8 we have to chose from */
-        /* first collapse any duplicates */
-        for(j=CP_STRIDE1_STRIDE; j<=CP_STRIDE4_STRIDE; j++)
-            for(k=CP_STRIDE1_STRIDE; k<=CP_STRIDE4_STRIDE; k++)
-                if(infile->counters[j] == inoutfile->counters[k])
-                    infile->counters[j+4] += inoutfile->counters[k+4];
-                    inoutfile->counters[k] = 0;
-                    inoutfile->counters[k+4] = 0;
-        /* placeholder so we can re-use macros */
-        tmp_runtime.log_file = &tmp_file;
-        /* first set */
-            CP_COUNTER_INC(&tmp_runtime, infile->counters[j],
-                infile->counters[j+4], 1, CP_STRIDE1_STRIDE, CP_STRIDE1_COUNT);
-        /* second set */
-            CP_COUNTER_INC(&tmp_runtime, inoutfile->counters[j],
-                inoutfile->counters[j+4], 1, CP_STRIDE1_STRIDE, CP_STRIDE1_COUNT);
-        /* TODO: subroutine so we don't duplicate so much */
-        /* same for access counts */
-        for(j=CP_ACCESS1_ACCESS; j<=CP_ACCESS4_ACCESS; j++)
-            for(k=CP_ACCESS1_ACCESS; k<=CP_ACCESS4_ACCESS; k++)
-        /* first set */
-                infile->counters[j+4], 1, CP_ACCESS1_ACCESS, CP_ACCESS1_COUNT);
-        /* second set */
-                inoutfile->counters[j+4], 1, CP_ACCESS1_ACCESS, CP_ACCESS1_COUNT);
-        /* min non-zero (if available) value */
-        for(j=CP_F_OPEN_TIMESTAMP; j<=CP_F_WRITE_START_TIMESTAMP; j++)
-            if(infile->fcounters[j] > inoutfile->fcounters[j] && inoutfile->fcounters[j] > 0)
-                tmp_file.fcounters[j] = inoutfile->fcounters[j];
-            else
-                tmp_file.fcounters[j] = infile->fcounters[j];
-        /* max */
-        for(j=CP_F_CLOSE_TIMESTAMP; j<=CP_F_WRITE_END_TIMESTAMP; j++)
-            if(infile->fcounters[j] > inoutfile->fcounters[j])
-            else
-        /* sum */
-        for(j=CP_F_POSIX_READ_TIME; j<=CP_F_MPI_WRITE_TIME; j++)
-            tmp_file.fcounters[j] = infile->fcounters[j] +
-                inoutfile->fcounters[j];
-        /* max (special case) */
-        if(infile->fcounters[CP_F_MAX_WRITE_TIME] >
-            inoutfile->fcounters[CP_F_MAX_WRITE_TIME])
-            tmp_file.fcounters[CP_F_MAX_WRITE_TIME] =
-                infile->fcounters[CP_F_MAX_WRITE_TIME];
-            tmp_file.counters[CP_MAX_WRITE_TIME_SIZE] =
-                infile->counters[CP_MAX_WRITE_TIME_SIZE];
-        else
-                inoutfile->fcounters[CP_F_MAX_WRITE_TIME];
-                inoutfile->counters[CP_MAX_WRITE_TIME_SIZE];
-        if(infile->fcounters[CP_F_MAX_READ_TIME] >
-            inoutfile->fcounters[CP_F_MAX_READ_TIME])
-            tmp_file.fcounters[CP_F_MAX_READ_TIME] =
-                infile->fcounters[CP_F_MAX_READ_TIME];
-            tmp_file.counters[CP_MAX_READ_TIME_SIZE] =
-                infile->counters[CP_MAX_READ_TIME_SIZE];
-        else
-                inoutfile->fcounters[CP_F_MAX_READ_TIME];
-                inoutfile->counters[CP_MAX_READ_TIME_SIZE];
-        /* min (zeroes are ok here; some procs don't do I/O) */
-        if(infile->fcounters[CP_F_FASTEST_RANK_TIME] <
-           inoutfile->fcounters[CP_F_FASTEST_RANK_TIME])
-            tmp_file.counters[CP_FASTEST_RANK] =
-                infile->counters[CP_FASTEST_RANK];
-            tmp_file.counters[CP_FASTEST_RANK_BYTES] =
-                infile->counters[CP_FASTEST_RANK_BYTES];
-            tmp_file.fcounters[CP_F_FASTEST_RANK_TIME] =
-                infile->fcounters[CP_F_FASTEST_RANK_TIME];
-        else
-                inoutfile->counters[CP_FASTEST_RANK];
-                inoutfile->counters[CP_FASTEST_RANK_BYTES];
-                inoutfile->fcounters[CP_F_FASTEST_RANK_TIME];
-        /* max */
-        if(infile->fcounters[CP_F_SLOWEST_RANK_TIME] >
-           inoutfile->fcounters[CP_F_SLOWEST_RANK_TIME])
-            tmp_file.counters[CP_SLOWEST_RANK] =
-                infile->counters[CP_SLOWEST_RANK];
-            tmp_file.counters[CP_SLOWEST_RANK_BYTES] =
-                infile->counters[CP_SLOWEST_RANK_BYTES];
-            tmp_file.fcounters[CP_F_SLOWEST_RANK_TIME] =
-                infile->fcounters[CP_F_SLOWEST_RANK_TIME];
-        else
-                inoutfile->counters[CP_SLOWEST_RANK];
-                inoutfile->counters[CP_SLOWEST_RANK_BYTES];
-                inoutfile->fcounters[CP_F_SLOWEST_RANK_TIME];
-        /* pick one device id and file size, favoring complete records if
-         * available
-            tmp_file.counters[CP_DEVICE] = inoutfile->counters[CP_DEVICE];
-            tmp_file.counters[CP_SIZE_AT_OPEN] = inoutfile->counters[CP_SIZE_AT_OPEN];
-        else
-            tmp_file.counters[CP_DEVICE] = infile->counters[CP_DEVICE];
-            tmp_file.counters[CP_SIZE_AT_OPEN] = infile->counters[CP_SIZE_AT_OPEN];
-        /* pick one name suffix (every file record should have this, whether
-         * it is a partial record or not
-        strcpy(tmp_file.name_suffix, infile->name_suffix);
-        *inoutfile = tmp_file;
-        inoutfile++;
-        infile++;
-    return;
-/* cp_log_construct_indices()
- * create memory datatypes to describe the log data to write out
-    trailing_data)
-    *inout_count = 0;
-    if(rank == 0)
-        /* root process is responsible for writing header */
-        lengths[*inout_count] = sizeof(final_job->log_job);
-        pointers[*inout_count] = &final_job->log_job;
-        (*inout_count)++;
-        /* also string containing exe command line */
-        lengths[*inout_count] = CP_EXE_LEN + 1;
-        pointers[*inout_count] = trailing_data;
-        (*inout_count)++;
-    /* everyone adds their own file records, if present */
-    if(final_job->file_count > 0)
-        lengths[*inout_count] = final_job->file_count*CP_FILE_RECORD_SIZE;
-        pointers[*inout_count] = final_job->file_array;
-        (*inout_count)++;
-    return;
-/* cp_log_write()
- * actually write log information to disk
-    int ret;
-    MPI_File fh;
-    MPI_Status status;
-    MPI_Datatype mtype;
-    int my_total = 0;
-    long my_total_long;
-    long offset;
-    int i;
-    MPI_Aint displacements[CP_MAX_MEM_SEGMENTS];
-    void* buf;
-    int failed_write = 0;
-    char* hints;
-    char* key;
-    char* value;
-    char* tok_str;
-    char* orig_tok_str;
-    char* saveptr = NULL;
-    MPI_Info info;
-    /* skip building a datatype if we don't have anything to write */
-    if(count > 0)
-        /* construct data type to describe everything we are writing */
-        /* NOTE: there may be a bug in MPI-IO when using MPI_BOTTOM with an
-         * hindexed data type.  We will instead use the first pointer as a base
-         * and adjust the displacements relative to it.
-        buf = pointers[0];
-        for(i=0; i<count; i++)
-            /* use this transform to be compiler safe */
-            uintptr_t ptr  = (uintptr_t) pointers[i];
-            uintptr_t base = (uintptr_t) buf;
-            displacements[i] = (MPI_Aint)(ptr - base);
-        DARSHAN_MPI_CALL(PMPI_Type_hindexed)(count, lengths, displacements,
-            MPI_BYTE, &mtype);
-        DARSHAN_MPI_CALL(PMPI_Type_commit)(&mtype);
-    MPI_Info_create(&info);
-    /* check environment variable to see if the default MPI file hints have
-     * been overridden
-    hints = getenv(CP_LOG_HINTS_OVERRIDE);
-    if(!hints)
-        hints = __CP_LOG_HINTS;
-    if(hints && strlen(hints) > 0)
-        tok_str = strdup(hints);
-        if(tok_str)
-            orig_tok_str = tok_str;
-            do
-                /* split string on semicolon */
-                key = strtok_r(tok_str, ";", &saveptr);
-                if(key)
-                    tok_str = NULL;
-                    /* look for = sign splitting key/value pairs */
-                    value = index(key, '=');
-                    if(value)
-                        /* break key and value into separate null terminated strings */
-                        value[0] = '\0';
-                        value++;
-                        if(strlen(key) > 0)
-                            MPI_Info_set(info, key, value);
-            }while(key != NULL);
-            free(orig_tok_str);
-    ret = DARSHAN_MPI_CALL(PMPI_File_open)(MPI_COMM_WORLD, logfile_name,
-        MPI_MODE_CREATE | MPI_MODE_WRONLY | MPI_MODE_EXCL, info, &fh);
-    MPI_Info_free(&info);
-        if(rank == 0)
-            int msg_len;
-            char msg[MPI_MAX_ERROR_STRING] = {0};
-            MPI_Error_string(ret, msg, &msg_len);
-            fprintf(stderr, "darshan library warning: unable to open log file %s: %s\n", logfile_name, msg);
-        if(count > 0)
-            DARSHAN_MPI_CALL(PMPI_Type_free)(&mtype);
-        return(-1);
-    /* figure out where everyone is writing */
-    if(count > 0)
-        DARSHAN_MPI_CALL(PMPI_Type_size)(mtype, &my_total);
-    else
-        my_total = 0;
-    my_total_long = my_total;
-    DARSHAN_MPI_CALL(PMPI_Scan)(&my_total_long, &offset, 1,
-        MPI_LONG, MPI_SUM, MPI_COMM_WORLD);
-    /* scan is inclusive; subtract local size back out */
-    offset -= my_total_long;
-    if(count > 0)
-        /* collectively write out file records from all processes */
-            1, mtype, &status);
-            failed_write = 1;
-    else
-        /* nothing to write, but we need to participate in the
-         * collectivee anyway
-        ret = DARSHAN_MPI_CALL(PMPI_File_write_at_all)(fh, offset, NULL,
-            0, MPI_BYTE, &status);
-            failed_write = 1;
-    DARSHAN_MPI_CALL(PMPI_File_close)(&fh);
-    if(count > 0)
-    if(failed_write)
-        return(-1);
-    return(0);
-/* cp_log_compress()
- * gzip memory buffers to write to log file.  Modifies the count, lengths,
- * and pointers to reference new buffer (or buffers)
- * returns 0 on success, -1 on error
-/* TODO: pick settings for compression (memory, level, etc.) */
-    int ret = 0;
-    z_stream tmp_stream;
-    int total_target = 0;
-    int i;
-    int no_data_flag = 1;
-    /* do we actually have anything to write? */
-    for(i=0; i<*inout_count; i++)
-        if(lengths[i])
-            no_data_flag = 0;
-            break;
-    if(no_data_flag)
-        /* nothing to compress */
-        *inout_count = 0;
-        return(0);
-    memset(&tmp_stream, 0, sizeof(tmp_stream));
-    tmp_stream.zalloc = Z_NULL;
-    tmp_stream.zfree = Z_NULL;
-    tmp_stream.opaque = Z_NULL;
-    ret = deflateInit2(&tmp_stream, Z_DEFAULT_COMPRESSION, Z_DEFLATED,
-        31, 8, Z_DEFAULT_STRATEGY);
-    if(ret != Z_OK)
-        return(-1);
-    tmp_stream.next_out = (void*)final_job->comp_buf;
-    tmp_stream.avail_out = CP_COMP_BUF_SIZE;
-    /* loop through all pointers to be compressed */
-        total_target += lengths[i];
-        tmp_stream.next_in = pointers[i];
-        tmp_stream.avail_in = lengths[i];
-        /* while we have not finished consuming all of the data available to
-         * this point in the loop
-        while(tmp_stream.total_in < total_target)
-            if(tmp_stream.avail_out == 0)
-                /* We ran out of buffer space for compression.  In theory,
-                 * we could start using some of the file_array buffer space
-                 * without having to malloc again.  In practice, this case
-                 * is going to be practically impossible to hit.
-                deflateEnd(&tmp_stream);
-                return(-1);
-            ret = deflate(&tmp_stream, Z_NO_FLUSH);
-            if(ret != Z_OK)
-                return(-1);
-    /* flush compression and end */
-    ret = deflate(&tmp_stream, Z_FINISH);
-    if(ret != Z_STREAM_END)
-        return(-1);
-    /* substitute our new buffer */
-    pointers[0] = final_job->comp_buf;
-    lengths[0] = tmp_stream.total_out;
-    *inout_count = 1;
-    return(0);
-static struct darshan_file_runtime* walker_file = NULL;
-static int walker_validx;
-static int walker_cntidx;
-static void cp_access_walker(const void* nodep, const VISIT which, const int depth)
-    struct cp_access_counter* counter;
-    switch (which)
-        case postorder:
-        case leaf:
-            counter = *(struct cp_access_counter**)nodep;
-#if 0
-            printf("   type %d size: %" PRId64 ", freq: %d\n", walker_validx, counter->size, counter->freq);
-#endif
-            CP_COUNTER_INC(walker_file, counter->size, counter->freq, 1, walker_validx, walker_cntidx);
-        default:
-            break;
-    return;
-/* darshan_walk_file_accesses()
- * goes through runtime collections of accesses sizes and chooses the 4 most
- * common for logging
-void darshan_walk_file_accesses(struct darshan_job_runtime* final_job)
-    int i;
-        #if 0
-        printf("file: %d\n", i);
-        #endif
-        /* walk trees for both access sizes and stride sizes to pick 4 most
-         * common of each
-        /* NOTE: setting global variables here for cp_access_walker() */
-        walker_file = &final_job->file_runtime_array[i];
-        walker_validx = CP_ACCESS1_ACCESS;
-        walker_cntidx = CP_ACCESS1_COUNT;
-        twalk(walker_file->access_root,
-            cp_access_walker);
-        tdestroy(walker_file->access_root, free);
-        walker_validx = CP_STRIDE1_STRIDE;
-        walker_cntidx = CP_STRIDE1_COUNT;
-        twalk(walker_file->stride_root,
-        tdestroy(walker_file->stride_root, free);
-    return;
-    const struct darshan_file* f_a = a;
-    const struct darshan_file* f_b = b;
-    if(f_a->rank < f_b->rank)
-        return 1;
-    if(f_a->rank > f_b->rank)
-        return -1;
-    return 0;
-static int mnt_data_cmp(const void* a, const void* b)
-    const struct mnt_data *d_a = (const struct mnt_data*)a;
-    const struct mnt_data *d_b = (const struct mnt_data*)b;
-    if(strlen(d_a->path) > strlen(d_b->path))
-        return(-1);
-    else if(strlen(d_a->path) < strlen(d_b->path))
-        return(1);
-    else
-        return(0);
-/* adds an entry to table of mounted file systems */
-static void add_entry(char* trailing_data, int* space_left, struct mntent *entry)
-    int ret;
-    char tmp_mnt[256];
-    struct statfs statfsbuf;
-    strncpy(mnt_data_array[mnt_data_count].path, entry->mnt_dir,
-        CP_MAX_MNT_PATH-1);
-    strncpy(mnt_data_array[mnt_data_count].type, entry->mnt_type,
-        CP_MAX_MNT_TYPE-1);
-    mnt_data_array[mnt_data_count].hash =
-        darshan_hash((void*)mnt_data_array[mnt_data_count].path,
-        strlen(mnt_data_array[mnt_data_count].path), 0);
-    /* NOTE: we now try to detect the preferred block size for each file
-     * system using fstatfs().  On Lustre we assume a size of 1 MiB
-     * because fstatfs() reports 4 KiB.
-#ifndef LL_SUPER_MAGIC
-#define LL_SUPER_MAGIC 0x0BD00BD0
-#endif
-    ret = statfs(entry->mnt_dir, &statfsbuf);
-    if(ret == 0 && statfsbuf.f_type != LL_SUPER_MAGIC)
-        mnt_data_array[mnt_data_count].block_size = statfsbuf.f_bsize;
-    else if(ret == 0 && statfsbuf.f_type == LL_SUPER_MAGIC)
-        mnt_data_array[mnt_data_count].block_size = 1024*1024;
-    else
-        mnt_data_array[mnt_data_count].block_size = 4096;
-    /* store mount information for use in header of darshan log */
-    ret = snprintf(tmp_mnt, 256, "\n%" PRId64 "\t%s\t%s",
-        mnt_data_array[mnt_data_count].hash,
-        entry->mnt_type, entry->mnt_dir);
-    if(ret < 256 && strlen(tmp_mnt) <= (*space_left))
-        strcat(trailing_data, tmp_mnt);
-        (*space_left) -= strlen(tmp_mnt);
-    mnt_data_count++;
-    return;
-/* darshan_get_exe_and_mounts_root()
- * collects command line and list of mounted file systems into a string that
- * will be stored with the job header
-static void darshan_get_exe_and_mounts_root(struct darshan_job_runtime* final_job, char* trailing_data, int space_left)
-    FILE* tab;
-    struct mntent *entry;
-    char* exclude;
-    int tmp_index = 0;
-    int skip = 0;
-    /* skip these fs types */
-    static char* fs_exclusions[] = {
-        "tmpfs",
-        "proc",
-        "sysfs",
-        "devpts",
-        "binfmt_misc",
-        "fusectl",
-        "debugfs",
-        "securityfs",
-        "nfsd",
-        "none",
-        "rpc_pipefs",
-	"hugetlbfs",
-	"cgroup",
-        NULL
-    /* length of exe has already been safety checked in darshan-posix.c */
-    strcat(trailing_data, final_job->exe);
-    space_left = CP_EXE_LEN - strlen(trailing_data);
-    /* we make two passes through mounted file systems; in the first pass we
-     * grab any non-nfs mount points, then on the second pass we grab nfs
-     * mount points
-    tab = setmntent("/etc/mtab", "r");
-    if(!tab)
-        return;
-    /* loop through list of mounted file systems */
-    while(mnt_data_count<CP_MAX_MNTS && (entry = getmntent(tab)) != NULL)
-        /* filter out excluded fs types */
-        tmp_index = 0;
-        skip = 0;
-        while((exclude = fs_exclusions[tmp_index]))
-            if(!(strcmp(exclude, entry->mnt_type)))
-                skip =1;
-                break;
-            tmp_index++;
-        if(skip || (strcmp(entry->mnt_type, "nfs") == 0))
-            continue;
-        add_entry(trailing_data, &space_left, entry);
-    endmntent(tab);
-    if(!tab)
-        return;
-        if(strcmp(entry->mnt_type, "nfs") != 0)
-            continue;
-    endmntent(tab);
-    /* Sort mount points in order of longest path to shortest path.  This is
-     * necessary so that if we try to match file paths to mount points later
-     * we don't match on "/" every time.
-    qsort(mnt_data_array, mnt_data_count, sizeof(mnt_data_array[0]), mnt_data_cmp);
-    return;
-/* darshan_get_exe_and_mounts()
-char* darshan_get_exe_and_mounts(struct darshan_job_runtime* final_job)
-    char* trailing_data;
-    int space_left;
-    int rank;
-    space_left = CP_EXE_LEN + 1;
-    trailing_data = malloc(space_left);
-    if(!trailing_data)
-        return(NULL);
-    memset(trailing_data, 0, space_left);
-    if(rank == 0)
-        darshan_get_exe_and_mounts_root(final_job, trailing_data, space_left);
-    /* broadcast trailing data to all nodes */
-    DARSHAN_MPI_CALL(PMPI_Bcast)(trailing_data, space_left, MPI_CHAR, 0,
-        MPI_COMM_WORLD);
-    /* broadcast mount count to all nodes */
-    DARSHAN_MPI_CALL(PMPI_Bcast)(&mnt_data_count, 1, MPI_INT, 0,
-        MPI_COMM_WORLD);
-    /* broadcast mount data to all nodes */
-    DARSHAN_MPI_CALL(PMPI_Bcast)(mnt_data_array,
-        mnt_data_count*sizeof(mnt_data_array[0]), MPI_BYTE, 0, MPI_COMM_WORLD);
-    return(trailing_data);
- * Computes population variance of bytes moved and total time
- * for each rank on a shared file.
-    MPI_Op pw_var_op = MPI_OP_NULL;
-    MPI_Datatype var_dt = MPI_BYTE;
-    int ret;
-    int i;
-    struct variance_dt* var_array = NULL;
-    struct variance_dt* varres_array = NULL;
-    ret = DARSHAN_MPI_CALL(PMPI_Op_create)(pairwise_variance_reduce, 1,
-        &pw_var_op);
-        goto error_handler;
-    ret = DARSHAN_MPI_CALL(PMPI_Type_contiguous)(sizeof(struct variance_dt),
-        MPI_BYTE, &var_dt);
-    ret = DARSHAN_MPI_CALL(PMPI_Type_commit)(&var_dt);
-    var_array = malloc(count*sizeof(struct variance_dt));
-    if(!var_array)
-    if (rank == 0)
-        varres_array = malloc(count*sizeof(struct variance_dt));
-        if(!varres_array)
-     * total time
-        var_array[i].n = 1;
-        var_array[i].S = 0;
-        var_array[i].T = infile_array[i].fcounters[CP_F_POSIX_META_TIME] +
-                         infile_array[i].fcounters[CP_F_POSIX_READ_TIME] +
-                         infile_array[i].fcounters[CP_F_POSIX_WRITE_TIME];
-             var_array, varres_array, count, var_dt, pw_var_op,
-             0, MPI_COMM_WORLD);
-    if (rank == 0)
-            outfile_array[i].fcounters[CP_F_VARIANCE_RANK_TIME] =
-                (varres_array[i].S / varres_array[i].n);
-     * total bytes
-        var_array[i].T = (double)
-                         infile_array[i].counters[CP_BYTES_READ] +
-                         infile_array[i].counters[CP_BYTES_WRITTEN];
-    if (rank == 0)
-            outfile_array[i].fcounters[CP_F_VARIANCE_RANK_BYTES] =
-    ret = 0;
-error_handler:
-    if (var_dt != MPI_BYTE) DARSHAN_MPI_CALL(PMPI_Type_free)(&var_dt);
-    if (pw_var_op != MPI_OP_NULL) DARSHAN_MPI_CALL(PMPI_Op_free)(&pw_var_op);
-    if (var_array) free(var_array);
-    if (varres_array) free(varres_array);
-    return ret;
-    int i;
-    struct variance_dt *X = invec;
-    struct variance_dt *Y = inoutvec;
-    struct variance_dt  Z;
-    for (i=0; i<*len; i++,X++,Y++)
-        Z.n = X->n + Y->n;
-        Z.T = X->T + Y->T;
-        Z.S = X->S + Y->S + (X->n/(Y->n*Z.n)) *
-           ((Y->n/X->n)*X->T - Y->T) * ((Y->n/X->n)*X->T - Y->T);
-        *Y = Z;
-    return;
-/* record any hints used to write the darshan log in the log header */
-    char* hints;
-    char* header_hints;
-    int meta_remain = 0;
-    char* m;
-    /* only need to do this on first process */
-    if(rank > 0)
-        return;
-     * been overridden
-    if(!hints)
-    if(!hints || strlen(hints) < 1)
-        return;
-    header_hints = strdup(hints);
-    if(!header_hints)
-        return;
-    meta_remain = DARSHAN_JOB_METADATA_LEN -
-        strlen(final_job->log_job.metadata) - 1;
-    if(meta_remain >= (strlen(PACKAGE_VERSION) + 9))
-        sprintf(final_job->log_job.metadata, "lib_ver=%s\n", PACKAGE_VERSION);
-        meta_remain -= (strlen(PACKAGE_VERSION) + 9);
-    if(meta_remain >= (3 + strlen(header_hints)))
-        m = final_job->log_job.metadata + strlen(final_job->log_job.metadata);
-        /* We have room to store the hints in the metadata portion of
-         * the job header.  We just prepend an h= to the hints list.  The
-         * metadata parser will ignore = characters that appear in the value
-         * portion of the metadata key/value pair.
-        sprintf(m, "h=%s\n", header_hints);
-    free(header_hints);
-    return;
-#if 0
-    FILE* tab;
-    int ret;
-    struct stat statbuf;
-    FILE* out;
-    out = fopen(out_file, "w");
-    if(!out)
-        perror("darshan: fopen");
-        return;
-    tab = setmntent(mtab_file, "r");
-    if(!tab)
-        perror("darshan: setmnt");
-        return;
-    while((entry = getmntent(tab)) != NULL)
-        ret = stat(entry->mnt_dir, &statbuf);
-        if(ret == 0)
-            int64_t tmp_st_dev = statbuf.st_dev;
-            fprintf(out, "%" PRId64 "\t%s\t%s\n", tmp_st_dev,
-        else
-            perror("darshan: stat");
-    return;
-#endif
-    struct darshan_file_runtime* tmp_file;
-    tmp_file = darshan_file_by_name_sethandle(name, &fh, sizeof(fh), DARSHAN_FH);
-    return(tmp_file);
-    darshan_file_closehandle(&fh, sizeof(fh), DARSHAN_FH);
-    return;
-    tmp_file = darshan_file_by_handle(&fh, sizeof(fh), DARSHAN_FH);
-    return(tmp_file);
-/* find the device id and block size for the specified file, based on
- * data from the mount entries.
-void darshan_mnt_id_from_path(const char* path, int64_t* device_id, int64_t* block_size)
-    int i;
-    *device_id = -1;
-    *block_size = -1;
-    for(i=0; i<mnt_data_count; i++)
-        if(!(strncmp(mnt_data_array[i].path, path, strlen(mnt_data_array[i].path))))
-            *device_id = mnt_data_array[i].hash;
-            *block_size = mnt_data_array[i].block_size;
-            return;
-    return;
-/* iterates through counters and adjusts timestamps to be relative to
- * MPI_Init()
-    int i;
-    int j;
-        for(j=CP_F_OPEN_TIMESTAMP; j<=CP_F_WRITE_END_TIMESTAMP; j++)
-            if(final_job->file_array[i].fcounters[j] > final_job->wtime_offset)
-                final_job->file_array[i].fcounters[j] -= final_job->wtime_offset;
-    return;
- * Local variables:
- *  c-indent-level: 4
- *  c-basic-offset: 4
- * End:
- * vim: ts=8 sts=4 sw=4 expandtab
diff --git a/darshan-runtime/lib/darshan-pnetcdf-stubs.c b/darshan-runtime/lib/darshan-pnetcdf-stubs.c
deleted file mode 100644
index c34bd5e..0000000
--- a/darshan-runtime/lib/darshan-pnetcdf-stubs.c
+++ /dev/null
@@ -1,76 +0,0 @@
- *  (C) 2009 by Argonne National Laboratory.
- *      See COPYRIGHT in top-level directory.
-/* This file contains stubs for the ncmpi functions intercepted by Darshan.
- * They are defined as weak symbols in order to satisfy dependencies of the
- * pnetcdf wrappers in cases where pnetcdf is not being used.
-#include "darshan-runtime-config.h"
-#include <stdio.h>
-#include <pthread.h>
-#include <string.h>
-#include "mpi.h"
-#include "darshan.h"
-int ncmpi_create(MPI_Comm comm, const char *path,
-    int cmode, MPI_Info info, int *ncidp) __attribute__((weak));
-    int rank;
-    MPI_Comm_rank(MPI_COMM_WORLD, &rank);
-    if(rank == 0)
-        fprintf(stderr, "WARNING: Darshan ncmpi_create() stub called; this is probably the result of a link-time problem.\n");
-    return(-1);
-int ncmpi_open(MPI_Comm comm, const char *path,
-    int omode, MPI_Info info, int *ncidp) __attribute__((weak));
-    int rank;
-    if(rank == 0)
-        fprintf(stderr, "WARNING: Darshan ncmpi_open() stub called; this is probably the result of a link-time problem.\n");
-    return(-1);
-int ncmpi_close(int ncid) __attribute__((weak));
-    int rank;
-    if(rank == 0)
-        fprintf(stderr, "WARNING: Darshan ncmpi_close() stub called; this is probably the result of a link-time problem.\n");
-    return(-1);
- * End:
diff --git a/darshan-runtime/lib/darshan-pnetcdf.c b/darshan-runtime/lib/darshan-pnetcdf.c
index cfad272..0000000
--- a/darshan-runtime/lib/darshan-pnetcdf.c
+++ /dev/null
@@ -1,202 +0,0 @@
-#include <stdio.h>
-#include "mpi.h"
-#ifdef DARSHAN_PRELOAD
-#define __USE_GNU
-#include <dlfcn.h>
-#include <stdlib.h>
-#define DARSHAN_FORWARD_DECL(name,ret,args) \
-  ret (*__real_ ## name)args = NULL;
-#define DARSHAN_DECL(__name) __name
-#define MAP_OR_FAIL(func) \
-    if (!(__real_ ## func)) \
-        __real_ ## func = dlsym(RTLD_NEXT, #func); \
-        if(!(__real_ ## func)) { \
-            fprintf(stderr, "Darshan failed to map symbol: %s\n", #func); \
-            exit(1); \
-#else
-  extern ret __real_ ## name args;
-#define DARSHAN_DECL(__name) __wrap_ ## __name
-#endif
-DARSHAN_FORWARD_DECL(ncmpi_create, int, (MPI_Comm comm, const char *path, int cmode, MPI_Info info, int *ncidp));
-DARSHAN_FORWARD_DECL(ncmpi_open, int, (MPI_Comm comm, const char *path, int omode, MPI_Info info, int *ncidp));
-DARSHAN_FORWARD_DECL(ncmpi_close, int, (int ncid));
-static struct darshan_file_runtime* darshan_file_by_ncid(int ncid);
-static void darshan_file_close_ncid(int ncid);
-static struct darshan_file_runtime* darshan_file_by_name_setncid(const char* name, int ncid);
-int DARSHAN_DECL(ncmpi_create)(MPI_Comm comm, const char *path,
-    int ret;
-    char* tmp;
-    int comm_size;
-    double tm1;
-    MAP_OR_FAIL(ncmpi_create);
-    tm1 = darshan_wtime();
-    ret = __real_ncmpi_create(comm, path, cmode, info, ncidp);
-    if(ret == 0)
-        CP_LOCK();
-        /* use ROMIO approach to strip prefix if present */
-        /* strip off prefix if there is one, but only skip prefixes
-         * if they are greater than length one to allow for windows
-         * drive specifications (e.g. c:\...)
-        tmp = strchr(path, ':');
-        if (tmp > path + 1) {
-            path = tmp + 1;
-        file = darshan_file_by_name_setncid(path, (*ncidp));
-        if(file)
-            if(CP_F_VALUE(file, CP_F_OPEN_TIMESTAMP) == 0)
-                CP_F_SET(file, CP_F_OPEN_TIMESTAMP,
-                tm1);
-            PMPI_Comm_size(comm, &comm_size);
-                CP_INC(file, CP_INDEP_NC_OPENS, 1);
-            else
-                CP_INC(file, CP_COLL_NC_OPENS, 1);
-        CP_UNLOCK();
-    return(ret);
-int DARSHAN_DECL(ncmpi_open)(MPI_Comm comm, const char *path,
-    int ret;
-    char* tmp;
-    int comm_size;
-    double tm1;
-    MAP_OR_FAIL(ncmpi_open);
-    ret = __real_ncmpi_open(comm, path, omode, info, ncidp);
-    if(ret == 0)
-        CP_LOCK();
-            path = tmp + 1;
-        if(file)
-                tm1);
-            else
-        CP_UNLOCK();
-    return(ret);
-int DARSHAN_DECL(ncmpi_close)(int ncid)
-    int ret;
-    MAP_OR_FAIL(ncmpi_close);
-    ret = __real_ncmpi_close(ncid);
-    CP_LOCK();
-    file = darshan_file_by_ncid(ncid);
-    if(file)
-        CP_F_SET(file, CP_F_CLOSE_TIMESTAMP, PMPI_Wtime());
-        darshan_file_close_ncid(ncid);
-    CP_UNLOCK();
-    return(ret);
-    tmp_file = darshan_file_by_name_sethandle(name, &ncid, sizeof(ncid), DARSHAN_NCID);
-    return(tmp_file);
-    darshan_file_closehandle(&ncid, sizeof(ncid), DARSHAN_NCID);
-    return;
-    tmp_file = darshan_file_by_handle(&ncid, sizeof(ncid), DARSHAN_NCID);
-    return(tmp_file);
- * End:
diff --git a/darshan-runtime/lib/darshan-posix.c b/darshan-runtime/lib/darshan-posix.c
index f3dec65..73278fa 100644
--- a/darshan-runtime/lib/darshan-posix.c
+++ b/darshan-runtime/lib/darshan-posix.c
@@ -70,6 +70,7 @@ struct posix_runtime
 static struct posix_runtime *posix_runtime = NULL;
 static pthread_mutex_t posix_runtime_mutex = PTHREAD_RECURSIVE_MUTEX_INITIALIZER_NP;
+static int instrumentation_disabled = 0;
 static int my_rank = -1;
 /* these are paths that we will not trace */
@@ -88,14 +89,17 @@ NULL
 DARSHAN_FORWARD_DECL(open, int, (const char *path, int flags, ...));
+DARSHAN_FORWARD_DECL(open64, int, (const char *path, int flags, ...));
 DARSHAN_FORWARD_DECL(close, int, (int fd));
 static void posix_runtime_initialize(void);
 static struct posix_runtime_file* posix_file_by_name(const char *name);
 static struct posix_runtime_file* posix_file_by_name_setfd(const char* name, int fd);
+static struct posix_runtime_file* posix_file_by_fd(int fd);
 static void posix_file_close_fd(int fd);
+static void posix_disable_instrumentation(void);
 static void posix_get_output_data(MPI_Comm comm, void **buffer, int *size);
 static void posix_shutdown(void);
@@ -200,10 +204,44 @@ int DARSHAN_DECL(open)(const char *path, int flags, ...)
     return(ret);
+int DARSHAN_DECL(open64)(const char *path, int flags, ...)
+    int mode = 0;
+    int ret;
+    double tm1, tm2;
+    MAP_OR_FAIL(open);
+    if(flags & O_CREAT)
+        va_list arg;
+        va_start(arg, flags);
+        mode = va_arg(arg, int);
+        va_end(arg);
+        tm1 = darshan_core_wtime();
+        ret = __real_open64(path, flags, mode);
+        tm2 = darshan_core_wtime();
+    else
+        ret = __real_open64(path, flags);
+    POSIX_LOCK();
+    posix_runtime_initialize();
+    POSIX_RECORD_OPEN(ret, path, mode, 0, tm1, tm2);
+    POSIX_UNLOCK();
+    return(ret);
 int DARSHAN_DECL(close)(int fd)
-    int tmp_fd = fd;
+    struct posix_runtime_file* file;
     double tm1, tm2;
     int ret;
@@ -216,8 +254,12 @@ int DARSHAN_DECL(close)(int fd)
     POSIX_LOCK();
-    posix_file_close_fd(tmp_fd);
+    file = posix_file_by_fd(fd);
+    if(file)
+        POSIX_F_SET(file, CP_F_CLOSE_TIMESTAMP, darshan_core_wtime());
+        posix_file_close_fd(fd);
     POSIX_UNLOCK();
     return(ret);
@@ -233,11 +275,13 @@ static void posix_runtime_initialize()
     int mem_limit;
     struct darshan_module_funcs posix_mod_fns =
+        .disable_instrumentation = &posix_disable_instrumentation,
         .get_output_data = &posix_get_output_data,
         .shutdown = &posix_shutdown
-    if(posix_runtime)
+    /* don't do anything if already initialized or instrumenation is disabled */
+    if(posix_runtime || instrumentation_disabled)
         return;
     /* register the posix module with darshan core */
@@ -275,34 +319,7 @@ static void posix_runtime_initialize()
     memset(posix_runtime->file_record_array, 0, posix_runtime->file_array_size *
            sizeof(struct darshan_posix_file));
-    DARSHAN_MPI_CALL(PMPI_Comm_rank)(MPI_COMM_WORLD, &my_rank);
-#if 0
-    /* set the memory alignment according to config or environment variables */
-    #if (__CP_MEM_ALIGNMENT < 1)
-        #error Darshan must be configured with a positive value for --with-mem-align
-    #endif
-    alignstr = getenv(CP_MEM_ALIGNMENT_OVERRIDE);
-    if(alignstr)
-        ret = sscanf(alignstr, "%d", &tmpval);
-        /* silently ignore if the env variable is set poorly */
-        if(ret == 1 && tmpval > 0)
-            darshan_mem_alignment = tmpval;
-    else
-        darshan_mem_alignment = __CP_MEM_ALIGNMENT;
-    /* avoid floating point errors on faulty input */
-    if(darshan_mem_alignment < 1)
-        darshan_mem_alignment = 1;
-#endif
+    DARSHAN_MPI_CALL(PMPI_Comm_rank)(MPI_COMM_WORLD, &my_rank); /* TODO: can we move this out of here? */
     return;
@@ -313,7 +330,7 @@ static struct posix_runtime_file* posix_file_by_name(const char *name)
     char *newname = NULL;
     darshan_record_id file_id;
-    if(!posix_runtime)
+    if(!posix_runtime || instrumentation_disabled)
         return(NULL);
     newname = darshan_clean_file_path(name);
@@ -359,7 +376,7 @@ static struct posix_runtime_file* posix_file_by_name_setfd(const char* name, int
     struct posix_runtime_file_ref* ref;
         return(NULL);
     /* find file record by name first */
@@ -386,19 +403,34 @@ static struct posix_runtime_file* posix_file_by_name_setfd(const char* name, int
     if(!ref)
         return(NULL);
     memset(ref, 0, sizeof(*ref));
     ref->file = file;
     ref->fd = fd;
     HASH_ADD(hlink, posix_runtime->fd_hash, fd, sizeof(int), ref);
     return(file);
+    struct posix_runtime_file_ref* ref;
+        return(NULL);
+    /* search hash table for existing file ref for this fd */
+    HASH_FIND(hlink, posix_runtime->fd_hash, &fd, sizeof(int), ref);
+    if(ref)
+        return(ref->file);
+    return(NULL);
         return;
     /* search hash table for this fd */
@@ -415,21 +447,18 @@ static void posix_file_close_fd(int fd)
-static void posix_get_output_data(MPI_Comm comm, void **buffer, int *size)
+static void posix_disable_instrumentation()
-    int comm_cmp;
-    DARSHAN_MPI_CALL(PMPI_Comm_compare)(MPI_COMM_WORLD, comm, &comm_cmp);
+    POSIX_LOCK();
+    instrumentation_disabled = 1;
+    POSIX_UNLOCK();
-    /* only do shared file reductions if this communicator includes _everyone_ */
-    if((comm_cmp == MPI_IDENT) || (comm_cmp == MPI_CONGRUENT))
-        /* don't reduce shared files if that feature is disabled, either */
-        if(!getenv("DARSHAN_DISABLE_SHARED_REDUCTION"))
-            /* TODO reduction code */
+    return;
+static void posix_get_output_data(MPI_Comm comm, void **buffer, int *size)
+    /* TODO: shared file reduction */
     *buffer = (void *)(posix_runtime->file_record_array);
     *size = posix_runtime->file_array_ndx * sizeof(struct darshan_posix_file);
diff --git a/darshan-util/darshan-logutils.c b/darshan-util/darshan-logutils.c
index 8ecfd30..7fe7632 100644
--- a/darshan-util/darshan-logutils.c
+++ b/darshan-util/darshan-logutils.c
@@ -103,7 +103,7 @@ int darshan_log_getheader(darshan_fd fd, struct darshan_header *header)
     /* save the version string */
     strncpy(fd->version, header->version_string, 8);
-    if(header->magic_nr == CP_MAGIC_NR)
+    if(header->magic_nr == DARSHAN_MAGIC_NR)
         /* no byte swapping needed, this file is in host format already */
         fd->swap_flag = 0;
@@ -112,7 +112,7 @@ int darshan_log_getheader(darshan_fd fd, struct darshan_header *header)
         /* try byte swapping */
         DARSHAN_BSWAP64(&header->magic_nr);
             fd->swap_flag = 1;
@@ -150,7 +150,7 @@ int darshan_log_getheader(darshan_fd fd, struct darshan_header *header)
 int darshan_log_getjob(darshan_fd fd, struct darshan_job *job)
-    char job_buf[CP_JOB_RECORD_SIZE] = {0};
+    char job_buf[DARSHAN_JOB_RECORD_SIZE] = {0};
     int ret;
     ret = darshan_log_seek(fd, fd->job_map.off);
@@ -181,49 +181,14 @@ int darshan_log_getjob(darshan_fd fd, struct darshan_job *job)
     /* save trailing job data, so exe and mount information can be retrieved later */
-    fd->exe_mnt_data = malloc(CP_EXE_LEN+1);
+    fd->exe_mnt_data = malloc(DARSHAN_EXE_LEN+1);
     if(!fd->exe_mnt_data)
         return(-1);
-    memcpy(fd->exe_mnt_data, &job_buf[sizeof(*job)], CP_EXE_LEN+1);
+    memcpy(fd->exe_mnt_data, &job_buf[sizeof(*job)], DARSHAN_EXE_LEN+1);
     return(0);
-#if 0
-#ifdef HAVE_STRNDUP
-    metadata = strndup(job->metadata, sizeof(job->metadata));
-#else
-    metadata = strdup(job->metadata);
-#endif
-    char *kv;
-    char *key;
-    char *value;
-    char *save;
-    for(kv=strtok_r(metadata, "\n", &save);
-        kv != NULL;
-        kv=strtok_r(NULL, "\n", &save))
-        /* NOTE: we intentionally only split on the first = character.
-         * There may be additional = characters in the value portion
-         * (for example, when storing mpi-io hints).
-        strcpy(buffer, kv);
-        key = buffer;
-        value = index(buffer, '=');
-        if(!value)
-            continue;
-        /* convert = to a null terminator to split key and value */
-        value[0] = '\0';
-        value++;
-        if (strcmp(key, "prev_ver") == 0)
-            strncpy(job->version_string, value, sizeof(job->version_string));
-    free(metadata);
-#endif
 int darshan_log_getexe(darshan_fd fd, char *buf)
     char *newline;
@@ -285,9 +250,9 @@ int darshan_log_getmounts(darshan_fd fd, char*** mnt_pts,
     while((pos = strrchr(fd->exe_mnt_data, '\n')) != NULL)
         /* overestimate string lengths */
-        (*mnt_pts)[array_index] = malloc(CP_EXE_LEN);
+        (*mnt_pts)[array_index] = malloc(DARSHAN_EXE_LEN);
         assert((*mnt_pts)[array_index]);
-        (*fs_types)[array_index] = malloc(CP_EXE_LEN);
+        (*fs_types)[array_index] = malloc(DARSHAN_EXE_LEN);
         assert((*fs_types)[array_index]);
         ret = sscanf(++pos, "%s\t%s", (*fs_types)[array_index],
diff --git a/darshan-util/darshan-posix-parser.c b/darshan-util/darshan-posix-parser.c
index 6aaba19..c4a453e 100644
--- a/darshan-util/darshan-posix-parser.c
+++ b/darshan-util/darshan-posix-parser.c
@@ -169,8 +169,9 @@ int main(int argc, char **argv)
         printf("\tRecord %d: id=%"PRIu64" (path=%s, rank=%"PRId64")\n",
             i, next_rec.f_id, ref->rec.name, next_rec.rank);
-        printf("\t\tPOSIX_OPENS:\t%"PRIu64"\n\t\tF_OPEN_TIMESTAMP:\t%lf\n",
-            next_rec.counters[CP_POSIX_OPENS], next_rec.fcounters[CP_F_OPEN_TIMESTAMP]);
+        printf("\t\tPOSIX_OPENS:\t%"PRIu64"\n\t\tF_OPEN_TIMESTAMP:\t%lf\n\t\tF_CLOSE_TIMESTAMP:\t%lf\n",
+            next_rec.counters[CP_POSIX_OPENS], next_rec.fcounters[CP_F_OPEN_TIMESTAMP],
+            next_rec.fcounters[CP_F_CLOSE_TIMESTAMP]);
         i++;
     } while((ret = darshan_log_getfile(file, &next_rec)) == 1);
hooks/post-receive
More information about the Darshan-commits mailing list
