[Darshan-commits] [Darshan] branch, dev-modular, updated. 42a4b3b084b0aebf1a1a4b37d4b9b4270fd39967
Service Account
git at mcs.anl.gov
Tue Feb 17 15:14:56 CST 2015
This is an automated email from the git hooks/post-receive script. It was
generated because a ref change was pushed to the repository containing
the project "".
The branch, dev-modular has been updated
via 42a4b3b084b0aebf1a1a4b37d4b9b4270fd39967 (commit)
from 756b640d97a13630c0e30e6b84b82e975e78d369 (commit)
Those revisions listed above that are new to this repository have
not appeared on any other notification email; so we list those
revisions in full, below.
- Log -----------------------------------------------------------------
commit 42a4b3b084b0aebf1a1a4b37d4b9b4270fd39967
Author: Shane Snyder <snyder at miralac1.fst.alcf.anl.gov>
Date: Tue Feb 17 21:13:30 2015 +0000
darshan runtime makefile cleanup
Summary of changes:
darshan-runtime/Makefile.in | 51 +++----------------------------------
darshan-runtime/darshan-config.in | 8 +++---
2 files changed, 8 insertions(+), 51 deletions(-)
Diff of changes:
diff --git a/darshan-runtime/Makefile.in b/darshan-runtime/Makefile.in
index 4343e1d..97d656b 100644
--- a/darshan-runtime/Makefile.in
+++ b/darshan-runtime/Makefile.in
@@ -1,5 +1,4 @@
all: lib/libdarshan.a
-#all: lib/libdarshan-posix.a lib/libdarshan-mpi-io.a lib/libdarshan-stubs.a
DESTDIR =
srcdir = @srcdir@
@@ -19,9 +18,9 @@ DISABLE_LDPRELOAD = @DISABLE_LDPRELOAD@
DARSHAN_LOG_FORMAT = $(srcdir)/../darshan-log-format.h
DARSHAN_VERSION = @DARSHAN_VERSION@
-#ifndef DISABLE_LDPRELOAD
-#all: lib/libdarshan.so
-#endif
+ifndef DISABLE_LDPRELOAD
+all: lib/libdarshan.so
+endif
VPATH = $(srcdir)
@@ -40,36 +39,6 @@ lib/darshan-core.o: lib/darshan-core.c darshan-core.h $(DARSHAN_LOG_FORMAT) | li
lib/darshan-common.o: lib/darshan-common.c darshan.h $(DARSHAN_LOG_FORMAT) | lib
$(CC) $(CFLAGS) -c $< -o $@
-#lib/darshan-mpi-io.o: lib/darshan-mpi-io.c darshan.h darshan-dynamic.h $(DARSHAN_LOG_FORMAT) | lib
-# $(CC) $(CFLAGS) -c $< -o $@
-#lib/darshan-mpi-io.po: lib/darshan-mpi-io.c darshan.h darshan-dynamic.h $(DARSHAN_LOG_FORMAT) | lib
-# $(CC) $(CFLAGS_SHARED) -c $< -o $@
-#lib/darshan-mpi-init-finalize.o: lib/darshan-mpi-init-finalize.c darshan.h darshan-dynamic.h $(DARSHAN_LOG_FORMAT) | lib
-#lib/darshan-mpi-init-finalize.po: lib/darshan-mpi-init-finalize.c darshan.h darshan-dynamic.h $(DARSHAN_LOG_FORMAT) | lib
-#lib/darshan-pnetcdf-stubs.o: lib/darshan-pnetcdf-stubs.c darshan.h $(DARSHAN_LOG_FORMAT) | lib
-#lib/darshan-pnetcdf.o: lib/darshan-pnetcdf.c darshan.h $(DARSHAN_LOG_FORMAT) | lib
-#lib/darshan-pnetcdf.po: lib/darshan-pnetcdf.c darshan.h $(DARSHAN_LOG_FORMAT) | lib
-#lib/darshan-hdf5.o: lib/darshan-hdf5.c darshan.h $(DARSHAN_LOG_FORMAT) | lib
-#lib/darshan-hdf5-stubs.o: lib/darshan-hdf5-stubs.c darshan.h $(DARSHAN_LOG_FORMAT) | lib
-#lib/darshan-hdf5.po: lib/darshan-hdf5.c darshan.h $(DARSHAN_LOG_FORMAT) | lib
lib/darshan-posix.o: lib/darshan-posix.c darshan.h $(DARSHAN_LOG_FORMAT) | lib
@@ -94,24 +63,12 @@ lib/lookup8.o: lib/lookup8.c
lib/libdarshan.a: lib/darshan-posix.o lib/darshan-core.o lib/darshan-common.o lib/lookup3.o lib/lookup8.o
ar rcs $@ $^
-#lib/libdarshan-mpi-io.a: lib/darshan-mpi-io.o lib/darshan-mpi-init-finalize.o lib/darshan-pnetcdf.o lib/darshan-hdf5.o
-# ar rcs $@ $^
-#lib/libdarshan-stubs.a: lib/darshan-pnetcdf-stubs.o lib/darshan-hdf5-stubs.o
-# ar rcs $@ $^
-#lib/libdarshan-posix.a: lib/darshan-posix.o lib/lookup3.o lib/lookup8.o
-# ar rcs $@ $^
#lib/libdarshan.so: lib/darshan-mpi-io.po lib/darshan-mpi-init-finalize.po lib/darshan-pnetcdf.po lib/darshan-hdf5.po lib/darshan-posix.po lib/lookup3.po lib/lookup8.po
# $(CC) $(CFLAGS_SHARED) $(LDFLAGS) -o $@ $^ -lpthread -lrt -lz -ldl
install:: all
install -d $(libdir)
install -m 755 lib/libdarshan.a $(libdir)
-# install -m 755 lib/libdarshan-posix.a $(libdir)
-# install -m 755 lib/libdarshan-mpi-io.a $(libdir)
-# install -m 755 lib/libdarshan-stubs.a $(libdir)
# install -m 755 lib/libdarshan.so $(libdir)
#endif
@@ -120,7 +77,7 @@ install:: all
install -m 755 darshan-gen-cc.pl $(bindir)
# install -m 755 darshan-gen-cxx.pl $(bindir)
# install -m 755 darshan-gen-fortran.pl $(bindir)
-# install -m 755 darshan-config $(bindir)
+ install -m 755 darshan-config $(bindir)
# install -d $(datarootdir)/craype-1.x/modulefiles/darshan
# install -m 755 share/craype-1.x/darshan-module $(datarootdir)/craype-1.x/modulefiles/darshan/$(DARSHAN_VERSION)
# install -d $(datarootdir)/craype-2.x/modulefiles/darshan
diff --git a/darshan-runtime/darshan-config.in b/darshan-runtime/darshan-config.in
index 0227b45..c000993 100755
--- a/darshan-runtime/darshan-config.in
+++ b/darshan-runtime/darshan-config.in
@@ -10,10 +10,10 @@ DARSHAN_LD_FLAGS="@LDFLAGS@"
# final one is necessary to give the linker a change to resolve indirect
# dependencies on PnetCDF and HDF5 symbols (if the app used a library which
# in turn used one of those HLLs).
-PRE_LD_FLAGS="-L$DARSHAN_LIB_PATH $DARSHAN_LD_FLAGS -ldarshan-core -lz $CP_WRAPPERS"
-POST_LD_FLAGS="-L$DARSHAN_LIB_PATH -ldarshan-core -lz -lrt -lpthread"
-#PRE_LD_FLAGS="-L$DARSHAN_LIB_PATH $DARSHAN_LD_FLAGS -ldarshan-mpi-io -lz $CP_WRAPPERS"
-#POST_LD_FLAGS="-L$DARSHAN_LIB_PATH -ldarshan-posix -ldarshan-mpi-io -lz -lrt -lpthread"
+# TODO: extra -lmpi in POST_LD_FLAGS -- link ordering issue
+PRE_LD_FLAGS="-L$DARSHAN_LIB_PATH $DARSHAN_LD_FLAGS -ldarshan -lz $CP_WRAPPERS"
+POST_LD_FLAGS="-L$DARSHAN_LIB_PATH -ldarshan -lmpi -lz -lrt -lpthread"
usage="\
Usage: darshan-config [--pre-ld-flags] [--post-ld-flags]"
hooks/post-receive
More information about the Darshan-commits
