[Darshan-commits] [Darshan] branch, master, updated. darshan-2.3.1-pre1-27-ga583249
Service Account git at mcs.anl.gov
Sun Feb 8 09:36:44 CST 2015
This is an automated email from the git hooks/post-receive script. It was
generated because a ref change was pushed to the repository containing
the project "".
The branch, master has been updated
       via  a5832499de7e0091db8d01f59c946c3a119dfd23 (commit)
      from  547fa7af4c5993f4a89eb46412d7d7c52de4fc32 (commit)
Those revisions listed above that are new to this repository have
not appeared on any other notification email; so we list those
revisions in full, below.
- Log -----------------------------------------------------------------
commit a5832499de7e0091db8d01f59c946c3a119dfd23
Author: Phil Carns <carns at mcs.anl.gov>
Date:   Sun Feb 8 10:36:34 2015 -0500
    bump to pre2 version number
Summary of changes:
 darshan-runtime/configure    |   20 ++++++++++----------
 darshan-runtime/configure.in |    2 +-
 darshan-util/configure       |   20 ++++++++++----------
 darshan-util/configure.in    |    2 +-
 4 files changed, 22 insertions(+), 22 deletions(-)
Diff of changes:
diff --git a/darshan-runtime/configure b/darshan-runtime/configure
index d11b220..6873376 100755
--- a/darshan-runtime/configure
+++ b/darshan-runtime/configure
@@ -1,6 +1,6 @@
 #! /bin/sh
 # Guess values for system-dependent variables and create Makefiles.
-# Generated by GNU Autoconf 2.69 for darshan-runtime 2.3.1-pre1.
+# Generated by GNU Autoconf 2.69 for darshan-runtime 2.3.1-pre2.
 # Copyright (C) 1992-1996, 1998-2012 Free Software Foundation, Inc.
@@ -577,8 +577,8 @@ MAKEFLAGS=
 # Identity of this package.
 PACKAGE_NAME='darshan-runtime'
 PACKAGE_TARNAME='darshan-runtime'
-PACKAGE_VERSION='2.3.1-pre1'
-PACKAGE_STRING='darshan-runtime 2.3.1-pre1'
+PACKAGE_VERSION='2.3.1-pre2'
+PACKAGE_STRING='darshan-runtime 2.3.1-pre2'
 PACKAGE_BUGREPORT=''
 PACKAGE_URL=''
@@ -1244,7 +1244,7 @@ if test "$ac_init_help" = "long"; then
   # Omit some internal or obsolete options to make the list less imposing.
   # This message is too long to be a string in the A/UX 3.1 sh.
   cat <<_ACEOF
-\`configure' configures darshan-runtime 2.3.1-pre1 to adapt to many kinds of systems.
+\`configure' configures darshan-runtime 2.3.1-pre2 to adapt to many kinds of systems.
 Usage: $0 [OPTION]... [VAR=VALUE]...
@@ -1305,7 +1305,7 @@ fi
 if test -n "$ac_init_help"; then
   case $ac_init_help in
-     short | recursive ) echo "Configuration of darshan-runtime 2.3.1-pre1:";;
+     short | recursive ) echo "Configuration of darshan-runtime 2.3.1-pre2:";;
    esac
   cat <<\_ACEOF
@@ -1409,7 +1409,7 @@ fi
 test -n "$ac_init_help" && exit $ac_status
 if $ac_init_version; then
   cat <<\_ACEOF
-darshan-runtime configure 2.3.1-pre1
+darshan-runtime configure 2.3.1-pre2
 generated by GNU Autoconf 2.69
 Copyright (C) 2012 Free Software Foundation, Inc.
@@ -1761,7 +1761,7 @@ cat >config.log <<_ACEOF
 This file contains any messages produced by compilers while
 running configure, to aid debugging if configure makes a mistake.
-It was created by darshan-runtime $as_me 2.3.1-pre1, which was
+It was created by darshan-runtime $as_me 2.3.1-pre2, which was
 generated by GNU Autoconf 2.69.  Invocation command line was
   $ $0 $@
@@ -4264,7 +4264,7 @@ $as_echo "no" >&6; }
     MPICH_LIB_OLD=0
 fi
-DARSHAN_VERSION="2.3.1-pre1"
+DARSHAN_VERSION="2.3.1-pre2"
@@ -4783,7 +4783,7 @@ cat >>$CONFIG_STATUS <<\_ACEOF || ac_write_fail=1
 # report actual input values of CONFIG_FILES etc. instead of their
 # values after options handling.
 ac_log="
-This file was extended by darshan-runtime $as_me 2.3.1-pre1, which was
+This file was extended by darshan-runtime $as_me 2.3.1-pre2, which was
   CONFIG_FILES    = $CONFIG_FILES
@@ -4845,7 +4845,7 @@ _ACEOF
 cat >>$CONFIG_STATUS <<_ACEOF || ac_write_fail=1
 ac_cs_config="`$as_echo "$ac_configure_args" | sed 's/^ //; s/[\\""\`\$]/\\\\&/g'`"
 ac_cs_version="\\
-darshan-runtime config.status 2.3.1-pre1
+darshan-runtime config.status 2.3.1-pre2
 configured by $0, generated by GNU Autoconf 2.69,
   with options \\"\$ac_cs_config\\"
diff --git a/darshan-runtime/configure.in b/darshan-runtime/configure.in
index 30352ac..a1e40f4 100644
--- a/darshan-runtime/configure.in
+++ b/darshan-runtime/configure.in
@@ -5,7 +5,7 @@ dnl Process this file with autoconf to produce a configure script.
 dnl You may need to use autoheader as well if changing any DEFINEs
 dnl sanity checks, output header, location of scripts used here
-AC_INIT([darshan-runtime], [2.3.1-pre1])
+AC_INIT([darshan-runtime], [2.3.1-pre2])
 AC_CONFIG_SRCDIR([darshan.h])
 AC_CONFIG_AUX_DIR(../maint/config)
 AC_CONFIG_HEADER(darshan-runtime-config.h)
diff --git a/darshan-util/configure b/darshan-util/configure
index ba26b81..33b64ec 100755
--- a/darshan-util/configure
+++ b/darshan-util/configure
@@ -1,6 +1,6 @@
 #! /bin/sh
-# Generated by GNU Autoconf 2.69 for darshan-util 2.3.1-pre1.
+# Generated by GNU Autoconf 2.69 for darshan-util 2.3.1-pre2.
 PACKAGE_NAME='darshan-util'
 PACKAGE_TARNAME='darshan-util'
-PACKAGE_STRING='darshan-util 2.3.1-pre1'
+PACKAGE_STRING='darshan-util 2.3.1-pre2'
 PACKAGE_URL=''
@@ -1236,7 +1236,7 @@ if test "$ac_init_help" = "long"; then
   cat <<_ACEOF
-\`configure' configures darshan-util 2.3.1-pre1 to adapt to many kinds of systems.
+\`configure' configures darshan-util 2.3.1-pre2 to adapt to many kinds of systems.
@@ -1297,7 +1297,7 @@ fi
-     short | recursive ) echo "Configuration of darshan-util 2.3.1-pre1:";;
+     short | recursive ) echo "Configuration of darshan-util 2.3.1-pre2:";;
    esac
   cat <<\_ACEOF
@@ -1393,7 +1393,7 @@ fi
   cat <<\_ACEOF
-darshan-util configure 2.3.1-pre1
+darshan-util configure 2.3.1-pre2
@@ -1758,7 +1758,7 @@ cat >config.log <<_ACEOF
-It was created by darshan-util $as_me 2.3.1-pre1, which was
+It was created by darshan-util $as_me 2.3.1-pre2, which was
   $ $0 $@
@@ -4105,7 +4105,7 @@ fi
 done
-DARSHAN_UTIL_VERSION="2.3.1-pre1"
+DARSHAN_UTIL_VERSION="2.3.1-pre2"
@@ -4621,7 +4621,7 @@ cat >>$CONFIG_STATUS <<\_ACEOF || ac_write_fail=1
 ac_log="
-This file was extended by darshan-util $as_me 2.3.1-pre1, which was
+This file was extended by darshan-util $as_me 2.3.1-pre2, which was
@@ -4683,7 +4683,7 @@ _ACEOF
 ac_cs_version="\\
-darshan-util config.status 2.3.1-pre1
+darshan-util config.status 2.3.1-pre2
diff --git a/darshan-util/configure.in b/darshan-util/configure.in
index 6d0de63..42a18d1 100644
--- a/darshan-util/configure.in
+++ b/darshan-util/configure.in
-AC_INIT([darshan-util], [2.3.1-pre1])
+AC_INIT([darshan-util], [2.3.1-pre2])
 AC_CONFIG_SRCDIR([darshan-logutils.h])
 AC_CONFIG_HEADER(darshan-util-config.h)
hooks/post-receive
More information about the Darshan-commits mailing list
