[Darshan-commits] [Darshan] branch, trac-150-regression, updated. darshan-2.3.1-pre1-9-g48173bc
Service Account
git at mcs.anl.gov
Tue Feb 3 19:50:05 CST 2015
This is an automated email from the git hooks/post-receive script. It was
generated because a ref change was pushed to the repository containing
the project "".
The branch, trac-150-regression has been updated
via 48173bc1eef809adb980ee0bee7bd67ef7ce2bdb (commit)
from ffc2ef63e93ea0766e9f16754c2bbba3a584a1e4 (commit)
Those revisions listed above that are new to this repository have
not appeared on any other notification email; so we list those
revisions in full, below.
- Log -----------------------------------------------------------------
commit 48173bc1eef809adb980ee0bee7bd67ef7ce2bdb
Author: Phil Carns <carns at mcs.anl.gov>
Date: Tue Feb 3 20:49:30 2015 -0500
fortran test cases
Summary of changes:
darshan-test/regression/run-all.sh | 12 ++
darshan-test/regression/test-cases/cxxpi.sh | 2 +-
.../test-cases/{mpi-io-test.sh => fperf-f77.sh} | 9 +-
.../test-cases/{mpi-io-test.sh => fperf-f90.sh} | 9 +-
darshan-test/regression/test-cases/src/fperf.f | 180 ++++++++++++++++++++
.../regression/ws/{setup-cc.sh => setup-f77.sh} | 14 +-
.../regression/ws/{setup-cc.sh => setup-f90.sh} | 14 +-
7 files changed, 215 insertions(+), 25 deletions(-)
copy darshan-test/regression/test-cases/{mpi-io-test.sh => fperf-f77.sh} (81%)
copy darshan-test/regression/test-cases/{mpi-io-test.sh => fperf-f90.sh} (81%)
create mode 100644 darshan-test/regression/test-cases/src/fperf.f
copy darshan-test/regression/ws/{setup-cc.sh => setup-f77.sh} (60%)
copy darshan-test/regression/ws/{setup-cc.sh => setup-f90.sh} (60%)
Diff of changes:
diff --git a/darshan-test/regression/run-all.sh b/darshan-test/regression/run-all.sh
index 47f159b..d2ee05a 100755
--- a/darshan-test/regression/run-all.sh
+++ b/darshan-test/regression/run-all.sh
@@ -53,6 +53,18 @@ if [ $? -ne 0 ]; then
fi
export DARSHAN_CXX
+# set up Fortran compilers for this platform
+DARSHAN_F77=`$DARSHAN_PLATFORM/setup-f77.sh`
+if [ $? -ne 0 ]; then
+ exit 1
+fi
+export DARSHAN_F77
+DARSHAN_F90=`$DARSHAN_PLATFORM/setup-f90.sh`
+ exit 1
+fi
+export DARSHAN_F90
# set up job execution wrapper for this platform
DARSHAN_RUNJOB=`$DARSHAN_PLATFORM/setup-runjob.sh`
diff --git a/darshan-test/regression/test-cases/cxxpi.sh b/darshan-test/regression/test-cases/cxxpi.sh
index cb49b7b..8151692 100755
--- a/darshan-test/regression/test-cases/cxxpi.sh
+++ b/darshan-test/regression/test-cases/cxxpi.sh
@@ -31,7 +31,7 @@ fi
# check results
# in this case we want to confirm that the open counts are zero; cxxpi does not do any IO
POSIX_OPENS=`grep CP_POSIX_OPENS $DARSHAN_TMP/${PROG}.darshan.txt |cut -f 4`
-if [ $POSIX_OPENS != "" ]; then
+if [ "$POSIX_OPENS"x != ""x ]; then
echo "Error: Found unexpected POSIX open count of $POSIX_OPENS" 1>&2
exit 1
fi
diff --git a/darshan-test/regression/test-cases/mpi-io-test.sh b/darshan-test/regression/test-cases/fperf-f77.sh
similarity index 81%
copy from darshan-test/regression/test-cases/mpi-io-test.sh
copy to darshan-test/regression/test-cases/fperf-f77.sh
index a2c7651..d056a04 100755
--- a/darshan-test/regression/test-cases/mpi-io-test.sh
+++ b/darshan-test/regression/test-cases/fperf-f77.sh
@@ -1,20 +1,20 @@
#!/bin/bash
-PROG=mpi-io-test
+PROG=fperf-f77
# set log file path; remove previous log if present
export DARSHAN_LOGFILE=$DARSHAN_TMP/${PROG}.darshan.gz
rm -f ${DARSHAN_LOGFILE}
# compile
-$DARSHAN_CC test-cases/src/${PROG}.c -o $DARSHAN_TMP/${PROG}
+$DARSHAN_F77 test-cases/src/fperf.f -o $DARSHAN_TMP/${PROG}
echo "Error: failed to compile ${PROG}" 1>&2
exit 1
fi
# execute
-$DARSHAN_RUNJOB $DARSHAN_TMP/${PROG} -f $DARSHAN_TMP/${PROG}.tmp.dat
+$DARSHAN_RUNJOB $DARSHAN_TMP/${PROG} -fname $DARSHAN_TMP/${PROG}.tmp.dat
echo "Error: failed to execute ${PROG}" 1>&2
exit 1
@@ -29,7 +29,7 @@ fi
# check results
# in this case we want to confirm that both the MPI and POSIX open counters were triggered
-MPI_OPENS=`grep CP_INDEP_OPENS $DARSHAN_TMP/${PROG}.darshan.txt |cut -f 4`
+MPI_OPENS=`grep CP_COLL_OPENS $DARSHAN_TMP/${PROG}.darshan.txt |cut -f 4`
if [ ! $MPI_OPENS -gt 0 ]; then
echo "Error: MPI open count of $MPI_OPENS is incorrect" 1>&2
exit 1
@@ -40,5 +40,4 @@ if [ ! $POSIX_OPENS -gt 0 ]; then
exit 1
fi
exit 0
diff --git a/darshan-test/regression/test-cases/mpi-io-test.sh b/darshan-test/regression/test-cases/fperf-f90.sh
copy to darshan-test/regression/test-cases/fperf-f90.sh
index a2c7651..af6a1b7 100755
+++ b/darshan-test/regression/test-cases/fperf-f90.sh
@@ -1,20 +1,20 @@
#!/bin/bash
-PROG=mpi-io-test
+PROG=fperf-f90
# compile
+$DARSHAN_F90 test-cases/src/fperf.f -o $DARSHAN_TMP/${PROG}
exit 1
fi
# execute
exit 1
# check results
exit 1
exit 1
fi
exit 0
diff --git a/darshan-test/regression/test-cases/src/fperf.f b/darshan-test/regression/test-cases/src/fperf.f
new file mode 100644
index 0000000..a3fdfa2
--- /dev/null
+++ b/darshan-test/regression/test-cases/src/fperf.f
@@ -0,0 +1,180 @@
+! -*- Mode: Fortran; -*-
+! (C) 2001 by Argonne National Laboratory.
+! See COPYRIGHT in top-level directory.
+ program main
+ implicit none
+ include 'mpif.h'
+! Fortran equivalent of perf.c
+ integer SIZE
+ parameter (SIZE=1048576*4)
+! read/write size per node in bytes
+ integer buf(SIZE/4), j, mynod, nprocs, ntimes, flag, foo
+ double precision stim, read_tim, write_tim, new_read_tim
+ double precision new_write_tim, min_read_tim, min_write_tim
+ double precision read_bw, write_bw
+ integer fh, status(MPI_STATUS_SIZE), ierr, argc, iargc, i
+ character*1024 str ! used to store the filename
+ integer*8 offset
+ ntimes = 5
+ min_read_tim = 10000000.0D0
+ min_write_tim = 10000000.0D0
+ call MPI_INIT(ierr)
+ call MPI_COMM_SIZE(MPI_COMM_WORLD, nprocs, foo, ierr)
+ call MPI_COMM_RANK(MPI_COMM_WORLD, mynod, ierr)
+! process 0 takes the file name as a command-line argument and
+! broadcasts it to other processes
+ if (mynod .eq. 0) then
+ argc = iargc()
+ i = 0
+ call getarg(i,str)
+ do while ((i .lt. argc) .and. (str .ne. '-fname'))
+ i = i + 1
+ end do
+ if (i .ge. argc) then
+ print *
+ print *, '*# Usage: fperf -fname filename'
+ print *
+ call MPI_ABORT(MPI_COMM_WORLD, 1, ierr)
+ end if
+ i = i + 1
+ call MPI_BCAST(str, 1024, MPI_CHARACTER, 0, &
+ & MPI_COMM_WORLD, ierr)
+ print *, 'Access size per process = ', SIZE, ' bytes', &
+ & ', ntimes = ', ntimes
+ else
+ end if
+ offset = mynod*SIZE
+ do j=1, ntimes
+ call MPI_FILE_OPEN(MPI_COMM_WORLD, str, &
+ & MPI_MODE_CREATE+MPI_MODE_RDWR, MPI_INFO_NULL, fh, ierr)
+ call MPI_FILE_SEEK(fh, offset, MPI_SEEK_SET, ierr)
+ call MPI_BARRIER(MPI_COMM_WORLD, ierr)
+ stim = MPI_WTIME()
+ call MPI_FILE_WRITE(fh, buf, SIZE, MPI_BYTE, status, ierr)
+ write_tim = MPI_WTIME() - stim
+ call MPI_FILE_CLOSE(fh, ierr)
+ call MPI_FILE_READ(fh, buf, SIZE, MPI_BYTE, status, ierr)
+ read_tim = MPI_WTIME() - stim
+ call MPI_ALLREDUCE(write_tim, new_write_tim, 1, &
+ & MPI_DOUBLE_PRECISION, MPI_MAX, MPI_COMM_WORLD, ierr)
+ call MPI_ALLREDUCE(read_tim, new_read_tim, 1, &
+ if (new_read_tim .lt. min_read_tim) then
+ min_read_tim = new_read_tim
+ end if
+ if (new_write_tim .lt. min_write_tim) then
+ min_write_tim = new_write_tim
+ end if
+ end do
+ read_bw = (SIZE*nprocs*1.0D0)/(min_read_tim*1000000.0D0)
+ write_bw = (SIZE*nprocs*1.0D0)/(min_write_tim*1000000.0D0)
+ print *, 'Write bandwidth without file sync = ', &
+ & write_bw, ' Mbytes/sec'
+ print *, 'Read bandwidth without prior file sync = ', &
+ & read_bw, ' Mbytes/sec'
+ end if
+ flag = 0
+ do j=1, ntimes
+ call MPI_FILE_SYNC(fh, ierr)
+ if (ierr .eq. MPI_ERR_UNKNOWN) then
+ flag = 1
+ end if
+ end if
+ end if
+ end do
+ if (flag .eq. 1) then
+ print *, 'MPI_FILE_SYNC returns error.'
+ else
+ print *, 'Write bandwidth including file sync = ', &
+ print *, 'Read bandwidth after file sync = ', &
+ end if
+ end if
+ call MPI_FINALIZE(ierr)
+ stop
+ end
diff --git a/darshan-test/regression/ws/setup-cc.sh b/darshan-test/regression/ws/setup-f77.sh
similarity index 60%
copy from darshan-test/regression/ws/setup-cc.sh
copy to darshan-test/regression/ws/setup-f77.sh
index 37bb231..d370105 100755
--- a/darshan-test/regression/ws/setup-cc.sh
+++ b/darshan-test/regression/ws/setup-f77.sh
@@ -2,25 +2,25 @@
# General notes
-# Script to set up the C compiler to use for subsequent test cases. This
+# Script to set up the F77 compiler to use for subsequent test cases. This
# script may load optional modules (as in a Cray PE), set LD_PRELOAD
# variables (as in a dynamically linked environment), or generate mpicc
# wrappers (as in a statically linked environment).
# The script should produce a single string to stdout, which is the command
-# line to use for invoking the C compiler
+# line to use for invoking the F77 compiler
# Notes specific to this platform (ws)
# This particular version of the setup-cc script assumes that mpicc is
-# present in the path already, and that the C compiler to use for
-# subsequent tests should be generated from this using darshan-gen-cc.pl.
+# present in the path already, and that the F77 compiler to use for
+# subsequent tests should be generated from this using darshan-gen-fortran.pl.
-$DARSHAN_PATH/bin/darshan-gen-cc.pl `which mpicc` --output $DARSHAN_TMP/mpicc
+$DARSHAN_PATH/bin/darshan-gen-fortran.pl `which mpif77` --output $DARSHAN_TMP/mpif77
- echo "Error: failed to generate c compiler." 1>&2
+ echo "Error: failed to generate f77 compiler." 1>&2
exit 1
fi
-echo $DARSHAN_TMP/mpicc
+echo $DARSHAN_TMP/mpif77
exit 0
diff --git a/darshan-test/regression/ws/setup-cc.sh b/darshan-test/regression/ws/setup-f90.sh
copy to darshan-test/regression/ws/setup-f90.sh
index 37bb231..1d5192c 100755
+++ b/darshan-test/regression/ws/setup-f90.sh
@@ -2,25 +2,25 @@
# General notes
+# Script to set up the F90 compiler to use for subsequent test cases. This
+# line to use for invoking the F90 compiler
+# present in the path already, and that the F90 compiler to use for
+$DARSHAN_PATH/bin/darshan-gen-fortran.pl `which mpif90` --output $DARSHAN_TMP/mpif90
+ echo "Error: failed to generate f90 compiler." 1>&2
exit 1
fi
+echo $DARSHAN_TMP/mpif90
exit 0
hooks/post-receive
More information about the Darshan-commits
