[Darshan-commits] [Git][darshan/darshan][dev-modular] back out commit for fixing races -- not needed
Shane Snyder
xgitlab at cels.anl.gov
Thu Dec 17 17:07:32 CST 2015
Shane Snyder pushed to branch dev-modular at darshan / darshan
Commits:
7d455c98 by Shane Snyder at 2015-12-17T17:07:03Z
6 changed files:
- darshan-runtime/lib/darshan-bgq.c
- darshan-runtime/lib/darshan-hdf5.c
- darshan-runtime/lib/darshan-mpiio.c
- darshan-runtime/lib/darshan-null.c
- darshan-runtime/lib/darshan-pnetcdf.c
- darshan-runtime/lib/darshan-posix.c
Changes:
--- a/darshan-runtime/lib/darshan-bgq.c
+++ b/darshan-runtime/lib/darshan-bgq.c
@@ -223,8 +223,6 @@ static void bgq_get_output_data(
int result;
uint64_t *ion_ids;
- BGQ_LOCK();
if (my_rank == 0)
DARSHAN_MPI_CALL(PMPI_Comm_size)(mod_comm, &nprocs);
@@ -272,21 +270,18 @@ static void bgq_get_output_data(
*size = 0;
- BGQ_UNLOCK();
return;
/* Shutdown the BGQ module by freeing up all data structures. */
static void bgq_shutdown()
- BGQ_LOCK();
if (bgq_runtime)
free(bgq_runtime);
bgq_runtime = NULL;
- BGQ_UNLOCK();
return;
--- a/darshan-runtime/lib/darshan-hdf5.c
+++ b/darshan-runtime/lib/darshan-hdf5.c
@@ -484,8 +484,6 @@ static void hdf5_get_output_data(
assert(hdf5_runtime);
- HDF5_LOCK();
/* if there are globally shared files, do a shared file reduction */
/* NOTE: the shared file reduction is also skipped if the
* DARSHAN_DISABLE_SHARED_REDUCTION environment variable is set.
@@ -519,7 +517,6 @@ static void hdf5_get_output_data(
red_recv_buf = malloc(shared_rec_count * sizeof(struct darshan_hdf5_file));
if(!red_recv_buf)
- HDF5_UNLOCK();
return;
@@ -558,7 +555,6 @@ static void hdf5_get_output_data(
*hdf5_buf = (void *)(hdf5_runtime->file_record_array);
*hdf5_buf_sz = hdf5_runtime->file_array_ndx * sizeof(struct darshan_hdf5_file);
- HDF5_UNLOCK();
return;
@@ -568,7 +564,6 @@ static void hdf5_shutdown()
- HDF5_LOCK();
HASH_ITER(hlink, hdf5_runtime->hid_hash, ref, tmp)
HASH_DELETE(hlink, hdf5_runtime->hid_hash, ref);
@@ -582,7 +577,6 @@ static void hdf5_shutdown()
free(hdf5_runtime);
hdf5_runtime = NULL;
- HDF5_UNLOCK();
return;
--- a/darshan-runtime/lib/darshan-mpiio.c
+++ b/darshan-runtime/lib/darshan-mpiio.c
@@ -1320,8 +1320,6 @@ static void mpiio_get_output_data(
assert(mpiio_runtime);
- MPIIO_LOCK();
/* go through and set the 4 most common access sizes for MPI-IO */
for(i = 0; i < mpiio_runtime->file_array_ndx; i++)
@@ -1391,7 +1389,6 @@ static void mpiio_get_output_data(
red_recv_buf = malloc(shared_rec_count * sizeof(struct darshan_mpiio_file));
if(!red_recv_buf)
- MPIIO_UNLOCK();
return;
@@ -1434,7 +1431,6 @@ static void mpiio_get_output_data(
*mpiio_buf = (void *)(mpiio_runtime->file_record_array);
*mpiio_buf_sz = mpiio_runtime->file_array_ndx * sizeof(struct darshan_mpiio_file);
- MPIIO_UNLOCK();
return;
@@ -1444,7 +1440,6 @@ static void mpiio_shutdown()
- MPIIO_LOCK();
HASH_ITER(hlink, mpiio_runtime->fh_hash, ref, tmp)
HASH_DELETE(hlink, mpiio_runtime->fh_hash, ref);
@@ -1458,7 +1453,6 @@ static void mpiio_shutdown()
free(mpiio_runtime);
mpiio_runtime = NULL;
- MPIIO_UNLOCK();
return;
--- a/darshan-runtime/lib/darshan-null.c
+++ b/darshan-runtime/lib/darshan-null.c
@@ -349,8 +349,6 @@ static void null_get_output_data(
assert(null_runtime);
- NULL_LOCK();
/* NOTE: this function can be used to run collective operations prior to
* shutting down the module, as implied by the MPI communicator passed in
* as the first agrument. Typically, module developers will want to run a
@@ -368,7 +366,6 @@ static void null_get_output_data(
*null_buf = (void *)(null_runtime->record_array);
*null_buf_sz = null_runtime->rec_array_ndx * sizeof(struct darshan_null_record);
- NULL_UNLOCK();
return;
@@ -377,7 +374,6 @@ static void null_shutdown()
- NULL_LOCK();
HASH_CLEAR(hlink, null_runtime->record_hash); /* these hash entries are freed all at once below */
free(null_runtime->runtime_record_array);
@@ -385,7 +381,6 @@ static void null_shutdown()
free(null_runtime);
null_runtime = NULL;
- NULL_UNLOCK();
return;
--- a/darshan-runtime/lib/darshan-pnetcdf.c
+++ b/darshan-runtime/lib/darshan-pnetcdf.c
@@ -496,8 +496,6 @@ static void pnetcdf_get_output_data(
assert(pnetcdf_runtime);
- PNETCDF_LOCK();
@@ -531,7 +529,6 @@ static void pnetcdf_get_output_data(
red_recv_buf = malloc(shared_rec_count * sizeof(struct darshan_pnetcdf_file));
if(!red_recv_buf)
- PNETCDF_UNLOCK();
return;
@@ -570,7 +567,6 @@ static void pnetcdf_get_output_data(
*pnetcdf_buf = (void *)(pnetcdf_runtime->file_record_array);
*pnetcdf_buf_sz = pnetcdf_runtime->file_array_ndx * sizeof(struct darshan_pnetcdf_file);
- PNETCDF_UNLOCK();
return;
@@ -580,7 +576,6 @@ static void pnetcdf_shutdown()
- PNETCDF_LOCK();
HASH_ITER(hlink, pnetcdf_runtime->ncid_hash, ref, tmp)
HASH_DELETE(hlink, pnetcdf_runtime->ncid_hash, ref);
@@ -594,7 +589,6 @@ static void pnetcdf_shutdown()
free(pnetcdf_runtime);
pnetcdf_runtime = NULL;
- PNETCDF_UNLOCK();
return;
--- a/darshan-runtime/lib/darshan-posix.c
+++ b/darshan-runtime/lib/darshan-posix.c
@@ -2051,8 +2051,6 @@ static void posix_get_output_data(
assert(posix_runtime);
- POSIX_LOCK();
/* go through file access data for each record and set the 4 most common
* stride/access size counters.
@@ -2129,7 +2127,6 @@ static void posix_get_output_data(
if(!red_recv_buf)
return;
- POSIX_UNLOCK();
@@ -2171,7 +2168,6 @@ static void posix_get_output_data(
*posix_buf = (void *)(posix_runtime->file_record_array);
*posix_buf_sz = posix_runtime->file_array_ndx * sizeof(struct darshan_posix_file);
- POSIX_UNLOCK();
return;
@@ -2181,7 +2177,6 @@ static void posix_shutdown()
- POSIX_LOCK();
HASH_ITER(hlink, posix_runtime->fd_hash, ref, tmp)
HASH_DELETE(hlink, posix_runtime->fd_hash, ref);
@@ -2195,7 +2190,6 @@ static void posix_shutdown()
free(posix_runtime);
posix_runtime = NULL;
- POSIX_UNLOCK();
return;
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/commit/7d455c98345f27688d46b139907ffa8f53ec0f6d
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20151217/3eb6c584/attachment.html>
More information about the Darshan-commits
