[Darshan-commits] [Darshan] branch, dev-modular, updated. darshan-2.3.1-153-g89a97a0
Service Account
git at mcs.anl.gov
Mon Aug 24 12:50:15 CDT 2015
This is an automated email from the git hooks/post-receive script. It was
generated because a ref change was pushed to the repository containing
the project "".
The branch, dev-modular has been updated
via 89a97a0f4de39f7ee149308af537390d5db0a8dc (commit)
from 8eb2f98d7ad53bfede836909ff9ba3956b2351a1 (commit)
Those revisions listed above that are new to this repository have
not appeared on any other notification email; so we list those
revisions in full, below.
- Log -----------------------------------------------------------------
commit 89a97a0f4de39f7ee149308af537390d5db0a8dc
Author: Shane Snyder <ssnyder at mcs.anl.gov>
Date: Mon Aug 24 12:49:46 2015 -0500
darshan parser bug fixes
Summary of changes:
darshan-util/darshan-parser.c | 25 +++++++++++++++++--------
1 files changed, 17 insertions(+), 8 deletions(-)
Diff of changes:
diff --git a/darshan-util/darshan-parser.c b/darshan-util/darshan-parser.c
index a16575a..266033a 100644
--- a/darshan-util/darshan-parser.c
+++ b/darshan-util/darshan-parser.c
@@ -394,6 +394,12 @@ int main(int argc, char **argv)
printf("# %s module data\n", darshan_module_names[i]);
printf("# *******************************************************\n");
+ if(mask & OPTION_BASE)
+ /* TODO: does each module print header of what each counter means??? */
+ DARSHAN_PRINT_HEADER();
/* this module has data to be parsed and printed */
mod_bytes_left = mod_buf_sz;
mod_buf_p = mod_buf;
@@ -436,9 +442,6 @@ int main(int argc, char **argv)
- /* TODO: does each module print header of what each counter means??? */
- DARSHAN_PRINT_HEADER();
/* print the corresponding module data for this record */
mod_logutils[i]->log_print_record(rec_p, ref->rec.name,
mnt_pt, fs_type);
@@ -448,7 +451,7 @@ int main(int argc, char **argv)
* if the parser is executed with more than the base option
if(i != DARSHAN_POSIX_MOD && i != DARSHAN_MPIIO_MOD)
- break;
+ continue;
HASH_FIND(hlink, file_hash, &rec_id, sizeof(darshan_record_id), hfile);
if(!hfile)
@@ -483,6 +486,12 @@ int main(int argc, char **argv)
+ /* we calculate more detailed stats for POSIX and MPI-IO modules,
+ * if the parser is executed with more than the base option
+ if(i != DARSHAN_POSIX_MOD && i != DARSHAN_MPIIO_MOD)
+ continue;
/* Total Calc */
if(mask & OPTION_TOTAL)
@@ -686,9 +695,9 @@ void posix_accum_file(struct darshan_posix_file *pfile,
hfile->rec_dat = malloc(sizeof(struct darshan_posix_file));
assert(hfile->rec_dat);
- tmp = (struct darshan_posix_file*)hfile->rec_dat;
- memset(tmp, 0, sizeof(struct darshan_posix_file));
+ memset(hfile->rec_dat, 0, sizeof(struct darshan_posix_file));
+ tmp = (struct darshan_posix_file*)hfile->rec_dat;
for(i = 0; i < POSIX_NUM_INDICES; i++)
@@ -890,9 +899,9 @@ void mpiio_accum_file(struct darshan_mpiio_file *mfile,
hfile->rec_dat = malloc(sizeof(struct darshan_mpiio_file));
- tmp = (struct darshan_mpiio_file*)hfile->rec_dat;
- memset(tmp, 0, sizeof(struct darshan_mpiio_file));
+ memset(hfile->rec_dat, 0, sizeof(struct darshan_mpiio_file));
+ tmp = (struct darshan_mpiio_file*)hfile->rec_dat;
for(i = 0; i < MPIIO_NUM_INDICES; i++)
hooks/post-receive
More information about the Darshan-commits
