[Darshan-commits] [Darshan] branch, dev-modular, updated. darshan-2.3.1-151-g8892647
Service Account git at mcs.anl.gov
Fri Aug 21 15:09:07 CDT 2015
This is an automated email from the git hooks/post-receive script. It was
generated because a ref change was pushed to the repository containing
the project "".
The branch, dev-modular has been updated
       via  88926470e0528fda0b182f247c0052c84276e3c0 (commit)
       via  814b126671a39bcad4a3df69fc1273518f633168 (commit)
       via  e5bfa490dd6dd2d1318a352a20c34ca219951cf0 (commit)
       via  a94832b33200c1dfbcbbc05a8be71a7219e30446 (commit)
      from  a850ea7453abc28a3e46e554cd48ab49739ea156 (commit)
Those revisions listed above that are new to this repository have
not appeared on any other notification email; so we list those
revisions in full, below.
- Log -----------------------------------------------------------------
commit 88926470e0528fda0b182f247c0052c84276e3c0
Author: Shane Snyder <ssnyder at mcs.anl.gov>
Date:   Fri Aug 21 15:08:24 2015 -0500
    fully implemented darshan-parser w/ all options
commit 814b126671a39bcad4a3df69fc1273518f633168
Date:   Thu Aug 20 12:41:12 2015 -0500
    add macro to detect partial posix file recs
commit e5bfa490dd6dd2d1318a352a20c34ca219951cf0
Date:   Wed Aug 19 15:22:51 2015 -0500
    slight api change for retrieving mod records
commit a94832b33200c1dfbcbbc05a8be71a7219e30446
Date:   Wed Aug 19 13:33:10 2015 -0500
    byte swap bug fix for reading the record hash
Summary of changes:
 darshan-posix-log-format.h              |    7 +
 darshan-runtime/lib/darshan-posix.c     |   16 +-
 darshan-util/darshan-hdf5-logutils.c    |   10 +-
 darshan-util/darshan-logutils.c         |    3 +-
 darshan-util/darshan-logutils.h         |    4 +-
 darshan-util/darshan-mpiio-logutils.c   |   10 +-
 darshan-util/darshan-parser.c           | 1347 ++++++++++++++++++++++++++++++-
 darshan-util/darshan-pnetcdf-logutils.c |   10 +-
 darshan-util/darshan-posix-logutils.c   |   10 +-
 9 files changed, 1372 insertions(+), 45 deletions(-)
Diff of changes:
diff --git a/darshan-posix-log-format.h b/darshan-posix-log-format.h
index 237e478..6ef9ac5 100644
--- a/darshan-posix-log-format.h
+++ b/darshan-posix-log-format.h
@@ -176,4 +176,11 @@ struct darshan_posix_file
     double fcounters[POSIX_F_NUM_INDICES];
+/* This macro can be used to identify files that have been opened using
+ * pnetcdf, hdf5, or mpi-io, but were never opened at the posix level.  As a
+ * result the record will not necessarily have all of the expected fields
+ * populated.
+#define POSIX_FILE_PARTIAL(__file)((((__file)->counters[POSIX_OPENS] || (__file)->counters[POSIX_FOPENS] || (__file)->counters[POSIX_STATS]) ? 0 : 1))
 #endif /* __DARSHAN_POSIX_LOG_FORMAT_H */
diff --git a/darshan-runtime/lib/darshan-posix.c b/darshan-runtime/lib/darshan-posix.c
index c6c1ec7..a4ec6ea 100644
--- a/darshan-runtime/lib/darshan-posix.c
+++ b/darshan-runtime/lib/darshan-posix.c
@@ -1719,7 +1719,10 @@ static void posix_record_reduction_op(void* infile_v, void* inoutfile_v,
             tmp_file.counters[j] = infile->counters[j] + inoutfile->counters[j];
-        tmp_file.counters[POSIX_MODE] = infile->counters[POSIX_MODE];
+        if(POSIX_FILE_PARTIAL(infile))
+            tmp_file.counters[POSIX_MODE] = inoutfile->counters[POSIX_MODE];
+        else
+            tmp_file.counters[POSIX_MODE] = infile->counters[POSIX_MODE];
         /* sum */
         for(j=POSIX_BYTES_READ; j<=POSIX_BYTES_WRITTEN; j++)
@@ -1742,8 +1745,10 @@ static void posix_record_reduction_op(void* infile_v, void* inoutfile_v,
-        tmp_file.counters[POSIX_MEM_ALIGNMENT] = infile->counters[POSIX_MEM_ALIGNMENT];
-        tmp_file.counters[POSIX_FILE_ALIGNMENT] = infile->counters[POSIX_FILE_ALIGNMENT];
+            tmp_file.counters[POSIX_MEM_ALIGNMENT] = inoutfile->counters[POSIX_MEM_ALIGNMENT];
+        else
+            tmp_file.counters[POSIX_MEM_ALIGNMENT] = infile->counters[POSIX_MEM_ALIGNMENT];
         /* sum */
         for(j=POSIX_FILE_NOT_ALIGNED; j<=POSIX_FILE_NOT_ALIGNED; j++)
@@ -1751,6 +1756,11 @@ static void posix_record_reduction_op(void* infile_v, void* inoutfile_v,
+        if(POSIX_PARTIAL_FILE(infile))
+            tmp_file.counters[POSIX_FILE_ALIGNMENT] = inoutfile->counters[POSIX_FILE_ALIGNMENT];
+        else
+            tmp_file.counters[POSIX_FILE_ALIGNMENT] = infile->counters[POSIX_FILE_ALIGNMENT];
         /* skip POSIX_MAX_*_TIME_SIZE; handled in floating point section */
         for(j=POSIX_SIZE_READ_0_100; j<=POSIX_SIZE_WRITE_1G_PLUS; j++)
diff --git a/darshan-util/darshan-hdf5-logutils.c b/darshan-util/darshan-hdf5-logutils.c
index 80ef43b..e4d6368 100644
--- a/darshan-util/darshan-hdf5-logutils.c
+++ b/darshan-util/darshan-hdf5-logutils.c
@@ -30,8 +30,8 @@ char *hdf5_f_counter_names[] = {
 #undef X
-static int darshan_log_get_hdf5_file(darshan_fd fd, void** hdf5_buf_p,
-    int* bytes_left, void** file_rec, darshan_record_id* rec_id);
+static int darshan_log_get_hdf5_file(void** hdf5_buf_p, int* bytes_left,
+    void** file_rec, darshan_record_id* rec_id, int byte_swap_flag);
 static void darshan_log_print_hdf5_file(void *file_rec,
     char *file_name, char *mnt_pt, char *fs_type);
@@ -41,8 +41,8 @@ struct darshan_mod_logutil_funcs hdf5_logutils =
     .log_print_record = &darshan_log_print_hdf5_file,
     int i;
     struct darshan_hdf5_file *file = (struct darshan_hdf5_file *)
@@ -51,7 +51,7 @@ static int darshan_log_get_hdf5_file(darshan_fd fd, void** hdf5_buf_p,
     if(*bytes_left < sizeof(struct darshan_hdf5_file))
         return(-1);
-    if(fd->swap_flag)
+    if(byte_swap_flag)
         /* swap bytes if necessary */
         DARSHAN_BSWAP64(&file->f_id);
diff --git a/darshan-util/darshan-logutils.c b/darshan-util/darshan-logutils.c
index e61447c..411f2ad 100644
--- a/darshan-util/darshan-logutils.c
+++ b/darshan-util/darshan-logutils.c
@@ -619,7 +619,6 @@ int darshan_log_gethash(darshan_fd fd, struct darshan_record_ref **hash)
         path_len_ptr = (uint32_t *)buf_ptr;
         buf_ptr += sizeof(uint32_t);
         path_ptr = (char *)buf_ptr;
-        buf_ptr += *path_len_ptr;
         if(fd->swap_flag)
@@ -653,6 +652,8 @@ int darshan_log_gethash(darshan_fd fd, struct darshan_record_ref **hash)
             /* add this record to the hash */
             HASH_ADD(hlink, *hash, rec.id, sizeof(darshan_record_id), ref);
+        buf_ptr += *path_len_ptr;
     free(hash_buf);
diff --git a/darshan-util/darshan-logutils.h b/darshan-util/darshan-logutils.h
index f6b5d9f..544dba9 100644
--- a/darshan-util/darshan-logutils.h
+++ b/darshan-util/darshan-logutils.h
@@ -46,11 +46,11 @@ struct darshan_record_ref
     int (*log_get_record)(
-        darshan_fd fd,
         void** mod_buf_p,
         int* mod_bytes_left,
         void** file_rec,
-        darshan_record_id* rec_id
+        darshan_record_id* rec_id,
+        int byte_swap_flag
     void (*log_print_record)(
         void *file_rec,
diff --git a/darshan-util/darshan-mpiio-logutils.c b/darshan-util/darshan-mpiio-logutils.c
index d78f470..f6c30e6 100644
--- a/darshan-util/darshan-mpiio-logutils.c
+++ b/darshan-util/darshan-mpiio-logutils.c
@@ -30,8 +30,8 @@ char *mpiio_f_counter_names[] = {
 #undef X
-static int darshan_log_get_mpiio_file(darshan_fd fd, void** mpiio_buf_p,
+static int darshan_log_get_mpiio_file(void** mpiio_buf_p, int* bytes_left,
 static void darshan_log_print_mpiio_file(void *file_rec,
@@ -41,8 +41,8 @@ struct darshan_mod_logutil_funcs mpiio_logutils =
     .log_print_record = &darshan_log_print_mpiio_file,
     int i;
     struct darshan_mpiio_file *file = (struct darshan_mpiio_file *)
@@ -51,7 +51,7 @@ static int darshan_log_get_mpiio_file(darshan_fd fd, void** mpiio_buf_p,
     if(*bytes_left < sizeof(struct darshan_mpiio_file))
         return(-1);
-    if(fd->swap_flag)
diff --git a/darshan-util/darshan-parser.c b/darshan-util/darshan-parser.c
index ba4aa79..a16575a 100644
--- a/darshan-util/darshan-parser.c
+++ b/darshan-util/darshan-parser.c
@@ -20,9 +20,181 @@
 #include "darshan-logutils.h"
+ * Options
+#define OPTION_BASE  (1 << 0)  /* darshan log fields */
+#define OPTION_TOTAL (1 << 1)  /* aggregated fields */
+#define OPTION_PERF  (1 << 2)  /* derived performance */
+#define OPTION_FILE  (1 << 3)  /* file count totals */
+#define OPTION_FILE_LIST  (1 << 4)  /* per-file summaries */
+#define OPTION_FILE_LIST_DETAILED  (1 << 6)  /* per-file summaries with extra detail */
+#define OPTION_ALL (\
+  OPTION_BASE|\
+  OPTION_TOTAL|\
+  OPTION_PERF|\
+  OPTION_FILE|\
+  OPTION_FILE_LIST|\
+  OPTION_FILE_LIST_DETAILED)
+#define FILETYPE_SHARED (1 << 0)
+#define FILETYPE_UNIQUE (1 << 1)
+#define FILETYPE_PARTSHARED (1 << 2)
+#define max(a,b) (((a) > (b)) ? (a) : (b))
+ * Datatypes
+typedef struct hash_entry_s
+    UT_hash_handle hlink;
+    darshan_record_id rec_id;
+    int64_t type;
+    int64_t procs;
+    void *rec_dat;
+    double cumul_time;
+    double slowest_time;
+} hash_entry_t;
+typedef struct file_data_s
+    int64_t total;
+    int64_t total_size;
+    int64_t total_max;
+    int64_t read_only;
+    int64_t read_only_size;
+    int64_t read_only_max;
+    int64_t write_only;
+    int64_t write_only_size;
+    int64_t write_only_max;
+    int64_t read_write;
+    int64_t read_write_size;
+    int64_t read_write_max;
+    int64_t unique;
+    int64_t unique_size;
+    int64_t unique_max;
+    int64_t shared;
+    int64_t shared_size;
+    int64_t shared_max;
+} file_data_t;
+typedef struct perf_data_s
+    int64_t total_bytes;
+    double slowest_rank_time;
+    double slowest_rank_meta_time;
+    int slowest_rank_rank;
+    double shared_time_by_cumul;
+    double shared_time_by_open;
+    double shared_time_by_open_lastio;
+    double shared_time_by_slowest;
+    double shared_meta_time;
+    double agg_perf_by_cumul;
+    double agg_perf_by_open;
+    double agg_perf_by_open_lastio;
+    double agg_perf_by_slowest;
+    double *rank_cumul_io_time;
+    double *rank_cumul_md_time;
+} perf_data_t;
+ * Prototypes
+void posix_accum_file(struct darshan_posix_file *pfile, hash_entry_t *hfile, int64_t nprocs);
+void posix_accum_perf(struct darshan_posix_file *pfile, perf_data_t *pdata);
+void posix_calc_file(hash_entry_t *file_hash, file_data_t *fdata);
+void posix_print_total_file(struct darshan_posix_file *pfile);
+void posix_file_list(hash_entry_t *file_hash, struct darshan_record_ref *rec_hash, int detail_flag);
+void mpiio_accum_file(struct darshan_mpiio_file *mfile, hash_entry_t *hfile, int64_t nprocs);
+void mpiio_accum_perf(struct darshan_mpiio_file *mfile, perf_data_t *pdata);
+void mpiio_calc_file(hash_entry_t *file_hash, file_data_t *fdata);
+void mpiio_print_total_file(struct darshan_mpiio_file *mfile);
+void mpiio_file_list(hash_entry_t *file_hash, struct darshan_record_ref *rec_hash, int detail_flag);
+void calc_perf(perf_data_t *pdata, int64_t nprocs);
+int usage (char *exename)
+    fprintf(stderr, "Usage: %s [options] <filename>\n", exename);
+    fprintf(stderr, "    --all   : all sub-options are enabled\n");
+    fprintf(stderr, "    --base  : darshan log field data [default]\n");
+    fprintf(stderr, "    --file  : total file counts\n");
+    fprintf(stderr, "    --file-list  : per-file summaries\n");
+    fprintf(stderr, "    --file-list-detailed  : per-file summaries with additional detail\n");
+    fprintf(stderr, "    --perf  : derived perf data\n");
+    fprintf(stderr, "    --total : aggregated darshan field data\n");
+    exit(1);
+int parse_args (int argc, char **argv, char **filename)
+    int index;
+    int mask;
+    static struct option long_opts[] =
+        {"all",   0, NULL, OPTION_ALL},
+        {"base",  0, NULL, OPTION_BASE},
+        {"file",  0, NULL, OPTION_FILE},
+        {"file-list",  0, NULL, OPTION_FILE_LIST},
+        {"file-list-detailed",  0, NULL, OPTION_FILE_LIST_DETAILED},
+        {"perf",  0, NULL, OPTION_PERF},
+        {"total", 0, NULL, OPTION_TOTAL},
+        {"help",  0, NULL, 0},
+        {0, 0, 0, 0}
+    mask = 0;
+    while(1)
+        int c = getopt_long(argc, argv, "", long_opts, &index);
+        if (c == -1) break;
+        switch(c)
+            case OPTION_ALL:
+            case OPTION_BASE:
+            case OPTION_FILE:
+            case OPTION_FILE_LIST:
+            case OPTION_FILE_LIST_DETAILED:
+            case OPTION_PERF:
+            case OPTION_TOTAL:
+                mask |= c;
+                break;
+            case 0:
+            case '?':
+            default:
+                usage(argv[0]);
+                break;
+    if (optind < argc)
+        *filename = argv[optind];
+    else
+        usage(argv[0]);
+    /* default mask value if none specified */
+    if (mask == 0)
+        mask = OPTION_BASE;
+    return mask;
 int main(int argc, char **argv)
     int ret;
+    int mask;
     int i, j;
     char *filename;
     char tmp_string[4096] = {0};
@@ -30,7 +202,7 @@ int main(int argc, char **argv)
     struct darshan_header header;
     struct darshan_job job;
     struct darshan_record_ref *rec_hash = NULL;
-    struct darshan_record_ref *ref, *tmp;
+    struct darshan_record_ref *ref, *tmp_ref;
     int mount_count;
     char** mnt_pts;
     char** fs_types;
@@ -42,9 +214,18 @@ int main(int argc, char **argv)
     char *mod_buf;
     int mod_buf_sz;
-    /* TODO: argument parsing */
-    assert(argc == 2);
-    filename = argv[1];
+    hash_entry_t *file_hash = NULL;
+    hash_entry_t *curr = NULL;
+    hash_entry_t *tmp_file = NULL;
+    hash_entry_t total;
+    file_data_t fdata;
+    perf_data_t pdata;
+    memset(&total, 0, sizeof(total));
+    memset(&fdata, 0, sizeof(fdata));
+    memset(&pdata, 0, sizeof(pdata));
+    mask = parse_args(argc, argv, &filename);
     fd = darshan_log_open(filename);
     if(!fd)
@@ -160,8 +341,18 @@ int main(int argc, char **argv)
     if(!mod_buf)
         return(-1);
-    DARSHAN_PRINT_HEADER();
-    /* TODO: does each module print header of what each counter means??? */
+    pdata.rank_cumul_io_time = malloc(sizeof(double)*job.nprocs);
+    pdata.rank_cumul_md_time = malloc(sizeof(double)*job.nprocs);
+    if (!pdata.rank_cumul_io_time || !pdata.rank_cumul_md_time)
+        darshan_log_close(fd);
+        return(-1);
+    else
+        memset(pdata.rank_cumul_io_time, 0, sizeof(double)*job.nprocs);
+        memset(pdata.rank_cumul_md_time, 0, sizeof(double)*job.nprocs);
     for(i=0; i<DARSHAN_MAX_MODS; i++)
@@ -169,9 +360,11 @@ int main(int argc, char **argv)
         void *mod_buf_p;
         void *rec_p = NULL;
+        void *save_io, *save_md;
-        memset(mod_buf, 0, DARSHAN_DEF_COMP_BUF_SZ);
+        /* reset data structures for each module */
         mod_buf_sz = DARSHAN_DEF_COMP_BUF_SZ;
+        memset(mod_buf, 0, DARSHAN_DEF_COMP_BUF_SZ);
         /* check each module for any data */
         ret = darshan_log_getmod(fd, i, mod_buf, &mod_buf_sz);
@@ -179,7 +372,6 @@ int main(int argc, char **argv)
             fprintf(stderr, "Error: failed to get module %s data\n",
                 darshan_module_names[i]);
-            fflush(stderr);
             return(-1);
@@ -198,23 +390,27 @@ int main(int argc, char **argv)
             continue;
+        printf("\n# *******************************************************\n");
+        printf("# %s module data\n", darshan_module_names[i]);
+        printf("# *******************************************************\n");
         /* this module has data to be parsed and printed */
-        mod_buf_p = mod_buf;
         mod_bytes_left = mod_buf_sz;
+        mod_buf_p = mod_buf;
         /* loop over each of this module's records and print them */
         while (mod_bytes_left > 0)
             char *mnt_pt = NULL;
             char *fs_type = NULL;
+            hash_entry_t *hfile = NULL;
-            ret = mod_logutils[i]->log_get_record(fd, &mod_buf_p, &mod_bytes_left,
-                &rec_p, &rec_id);
+            ret = mod_logutils[i]->log_get_record(&mod_buf_p, &mod_bytes_left,
+                &rec_p, &rec_id, fd->swap_flag);
             if(ret < 0)
                 fprintf(stderr, "Error: failed to parse module %s data record\n",
-                fflush(stderr);
                 return(-1);
@@ -238,18 +434,189 @@ int main(int argc, char **argv)
             if(!fs_type)
                 fs_type = "UNKNOWN";
-            /* print the corresponding module data for this record */
-            mod_logutils[i]->log_print_record(rec_p, ref->rec.name,
-                mnt_pt, fs_type);
+            if(mask & OPTION_BASE)
+                /* TODO: does each module print header of what each counter means??? */
+                DARSHAN_PRINT_HEADER();
+                /* print the corresponding module data for this record */
+                mod_logutils[i]->log_print_record(rec_p, ref->rec.name,
+                    mnt_pt, fs_type);
+            /* we calculate more detailed stats for POSIX and MPI-IO modules,
+             * if the parser is executed with more than the base option
+            if(i != DARSHAN_POSIX_MOD && i != DARSHAN_MPIIO_MOD)
+                break;
+            HASH_FIND(hlink, file_hash, &rec_id, sizeof(darshan_record_id), hfile);
+            if(!hfile)
+                hfile = malloc(sizeof(*hfile));
+                if(!hfile)
+                    return(-1);
+                /* init */
+                memset(hfile, 0, sizeof(*hfile));
+                hfile->rec_id = rec_id;
+                hfile->type = 0;
+                hfile->procs = 0;
+                hfile->rec_dat = NULL;
+                hfile->cumul_time = 0.0;
+                hfile->slowest_time = 0.0;
+                HASH_ADD(hlink, file_hash, rec_id, sizeof(darshan_record_id), hfile);
+            if(i == DARSHAN_POSIX_MOD)
+                posix_accum_file((struct darshan_posix_file*)rec_p, &total, job.nprocs);
+                posix_accum_file((struct darshan_posix_file*)rec_p, hfile, job.nprocs);
+                posix_accum_perf((struct darshan_posix_file*)rec_p, &pdata);
+            else if(i == DARSHAN_MPIIO_MOD)
+                mpiio_accum_file((struct darshan_mpiio_file*)rec_p, &total, job.nprocs);
+                mpiio_accum_file((struct darshan_mpiio_file*)rec_p, hfile, job.nprocs);
+                mpiio_accum_perf((struct darshan_mpiio_file*)rec_p, &pdata);
+        /* Total Calc */
+        if(mask & OPTION_TOTAL)
+                posix_print_total_file((struct darshan_posix_file*)total.rec_dat);
+                mpiio_print_total_file((struct darshan_mpiio_file*)total.rec_dat);
+        /* File Calc */
+        if(mask & OPTION_FILE)
+                posix_calc_file(file_hash, &fdata);
+                mpiio_calc_file(file_hash, &fdata);
+            printf("\n# files\n");
+            printf("# -----\n");
+            printf("# total: %" PRId64 " %" PRId64 " %" PRId64 "\n",
+                   fdata.total,
+                   fdata.total_size,
+                   fdata.total_max);
+            printf("# read_only: %" PRId64 " %" PRId64 " %" PRId64 "\n",
+                   fdata.read_only,
+                   fdata.read_only_size,
+                   fdata.read_only_max);
+            printf("# write_only: %" PRId64 " %" PRId64 " %" PRId64 "\n",
+                   fdata.write_only,
+                   fdata.write_only_size,
+                   fdata.write_only_max);
+            printf("# read_write: %" PRId64 " %" PRId64 " %" PRId64 "\n",
+                   fdata.read_write,
+                   fdata.read_write_size,
+                   fdata.read_write_max);
+            printf("# unique: %" PRId64 " %" PRId64 " %" PRId64 "\n",
+                   fdata.unique,
+                   fdata.unique_size,
+                   fdata.unique_max);
+            printf("# shared: %" PRId64 " %" PRId64 " %" PRId64 "\n",
+                   fdata.shared,
+                   fdata.shared_size,
+                   fdata.shared_max);
+        /* Perf Calc */
+        if(mask & OPTION_PERF)
+            calc_perf(&pdata, job.nprocs);
+            printf("\n# performance\n");
+            printf("# -----------\n");
+            printf("# total_bytes: %" PRId64 "\n", pdata.total_bytes);
+            printf("#\n");
+            printf("# I/O timing for unique files (seconds):\n");
+            printf("# ...........................\n");
+            printf("# unique files: slowest_rank_io_time: %lf\n", pdata.slowest_rank_time);
+            printf("# unique files: slowest_rank_meta_time: %lf\n", pdata.slowest_rank_meta_time);
+            printf("# unique files: slowest rank: %d\n", pdata.slowest_rank_rank);
+            printf("#\n");
+            printf("# I/O timing for shared files (seconds):\n");
+            printf("# (multiple estimates shown; time_by_slowest is generally the most accurate)\n");
+            printf("# shared files: time_by_cumul_io_only: %lf\n", pdata.shared_time_by_cumul);
+            printf("# shared files: time_by_cumul_meta_only: %lf\n", pdata.shared_meta_time);
+            printf("# shared files: time_by_open: %lf\n", pdata.shared_time_by_open);
+            printf("# shared files: time_by_open_lastio: %lf\n", pdata.shared_time_by_open_lastio);
+            printf("# shared files: time_by_slowest: %lf\n", pdata.shared_time_by_slowest);
+            printf("#\n");
+            printf("# Aggregate performance, including both shared and unique files (MiB/s):\n");
+            printf("# (multiple estimates shown; agg_perf_by_slowest is generally the most accurate)\n");
+            printf("# agg_perf_by_cumul: %lf\n", pdata.agg_perf_by_cumul);
+            printf("# agg_perf_by_open: %lf\n", pdata.agg_perf_by_open);
+            printf("# agg_perf_by_open_lastio: %lf\n", pdata.agg_perf_by_open_lastio);
+            printf("# agg_perf_by_slowest: %lf\n", pdata.agg_perf_by_slowest);
+        if((mask & OPTION_FILE_LIST) || (mask & OPTION_FILE_LIST_DETAILED))
+                if(mask & OPTION_FILE_LIST_DETAILED)
+                    posix_file_list(file_hash, rec_hash, 1);
+                else
+                    posix_file_list(file_hash, rec_hash, 0);
+                    mpiio_file_list(file_hash, rec_hash, 1);
+                else
+                    mpiio_file_list(file_hash, rec_hash, 0);
+        /* reset data structures for next module */
+        if(total.rec_dat) free(total.rec_dat);
+        save_io = pdata.rank_cumul_io_time;
+        save_md = pdata.rank_cumul_md_time;
+        memset(save_io, 0, sizeof(double)*job.nprocs);
+        memset(save_md, 0, sizeof(double)*job.nprocs);
+        pdata.rank_cumul_io_time = save_io;
+        pdata.rank_cumul_md_time = save_md;
+        HASH_ITER(hlink, file_hash, curr, tmp_file)
+            HASH_DELETE(hlink, file_hash, curr);
+            if(curr->rec_dat) free(curr->rec_dat);
+            free(curr);
     if(empty_mods == DARSHAN_MAX_MODS)
-        printf("# no module data available.\n");
+        printf("\n# no module data available.\n");
     free(mod_buf);
+    free(pdata.rank_cumul_io_time);
+    free(pdata.rank_cumul_md_time);
     /* free record hash data */
-    HASH_ITER(hlink, rec_hash, ref, tmp)
+    HASH_ITER(hlink, rec_hash, ref, tmp_ref)
         HASH_DELETE(hlink, rec_hash, ref);
         free(ref->rec.name);
@@ -268,7 +635,949 @@ int main(int argc, char **argv)
         free(fs_types);
-    darshan_log_close(fd);
     return(0);
+                      hash_entry_t *hfile,
+                      int64_t nprocs)
+    int i, j;
+    int set;
+    int min_ndx;
+    int64_t min;
+    struct darshan_posix_file* tmp;
+    hfile->procs += 1;
+    if(pfile->rank == -1)
+        hfile->slowest_time = pfile->fcounters[POSIX_F_SLOWEST_RANK_TIME];
+    else
+        hfile->slowest_time = max(hfile->slowest_time,
+            (pfile->fcounters[POSIX_F_META_TIME] +
+            pfile->fcounters[POSIX_F_READ_TIME] +
+            pfile->fcounters[POSIX_F_WRITE_TIME]));
+        hfile->procs = nprocs;
+        hfile->type |= FILETYPE_SHARED;
+    else if(hfile->procs > 1)
+        hfile->type &= (~FILETYPE_UNIQUE);
+        hfile->type |= FILETYPE_PARTSHARED;
+    else
+        hfile->type |= FILETYPE_UNIQUE;
+    hfile->cumul_time += pfile->fcounters[POSIX_F_META_TIME] +
+                         pfile->fcounters[POSIX_F_WRITE_TIME];
+    if(hfile->rec_dat == NULL)
+        hfile->rec_dat = malloc(sizeof(struct darshan_posix_file));
+        assert(hfile->rec_dat);
+        tmp = (struct darshan_posix_file*)hfile->rec_dat;
+        memset(tmp, 0, sizeof(struct darshan_posix_file));
+    for(i = 0; i < POSIX_NUM_INDICES; i++)
+        switch(i)
+        case POSIX_MODE:
+        case POSIX_MEM_ALIGNMENT:
+        case POSIX_FILE_ALIGNMENT:
+            if(POSIX_FILE_PARTIAL(tmp))
+                tmp->counters[i] = pfile->counters[i];
+            break;
+        case POSIX_MAX_BYTE_READ:
+        case POSIX_MAX_BYTE_WRITTEN:
+            if (tmp->counters[i] < pfile->counters[i])
+            break;
+        case POSIX_STRIDE1_STRIDE:
+        case POSIX_STRIDE2_STRIDE:
+        case POSIX_STRIDE3_STRIDE:
+        case POSIX_STRIDE4_STRIDE:
+        case POSIX_ACCESS1_ACCESS:
+        case POSIX_ACCESS2_ACCESS:
+        case POSIX_ACCESS3_ACCESS:
+        case POSIX_ACCESS4_ACCESS:
+            * do nothing here because these will be stored
+            * when the _COUNT is accessed.
+           break;
+        case POSIX_STRIDE1_COUNT:
+        case POSIX_STRIDE2_COUNT:
+        case POSIX_STRIDE3_COUNT:
+        case POSIX_STRIDE4_COUNT:
+            set = 0;
+            min_ndx = POSIX_STRIDE1_COUNT;
+            min = tmp->counters[min_ndx];
+            for(j = POSIX_STRIDE1_COUNT; j <= POSIX_STRIDE4_COUNT; j++)
+                if(tmp->counters[j-4] == pfile->counters[i-4])
+                    tmp->counters[j] += pfile->counters[i];
+                    set = 1;
+                    break;
+                if(tmp->counters[j] < min)
+                    min_ndx = j;
+                    min = tmp->counters[j];
+            if(!set && (pfile->counters[i] > min))
+                tmp->counters[min_ndx] = pfile->counters[i];
+                tmp->counters[min_ndx-4] = pfile->counters[i-4];
+            break;
+        case POSIX_ACCESS1_COUNT:
+        case POSIX_ACCESS2_COUNT:
+        case POSIX_ACCESS3_COUNT:
+        case POSIX_ACCESS4_COUNT:
+            set = 0;
+            min_ndx = POSIX_ACCESS1_COUNT;
+            for(j = POSIX_ACCESS1_COUNT; j <= POSIX_ACCESS4_COUNT; j++)
+                    set = 1;
+                    break;
+                    min_ndx = j;
+                tmp->counters[i-4] = pfile->counters[i-4];
+            break;
+        case POSIX_FASTEST_RANK:
+        case POSIX_SLOWEST_RANK:
+        case POSIX_FASTEST_RANK_BYTES:
+        case POSIX_SLOWEST_RANK_BYTES:
+            tmp->counters[i] = 0;
+            break;
+        case POSIX_MAX_READ_TIME_SIZE:
+        case POSIX_MAX_WRITE_TIME_SIZE:
+            break;
+        default:
+            tmp->counters[i] += pfile->counters[i];
+            break;
+    for(i = 0; i < POSIX_F_NUM_INDICES; i++)
+        switch(i)
+            case POSIX_F_OPEN_TIMESTAMP:
+            case POSIX_F_READ_START_TIMESTAMP:
+            case POSIX_F_WRITE_START_TIMESTAMP:
+                if(tmp->fcounters[i] == 0 ||
+                    tmp->fcounters[i] > pfile->fcounters[i])
+                    tmp->fcounters[i] = pfile->fcounters[i];
+                break;
+            case POSIX_F_READ_END_TIMESTAMP:
+            case POSIX_F_WRITE_END_TIMESTAMP:
+            case POSIX_F_CLOSE_TIMESTAMP:
+                    tmp->fcounters[i] < pfile->fcounters[i])
+                break;
+            case POSIX_F_FASTEST_RANK_TIME:
+            case POSIX_F_SLOWEST_RANK_TIME:
+            case POSIX_F_VARIANCE_RANK_TIME:
+            case POSIX_F_VARIANCE_RANK_BYTES:
+                tmp->fcounters[i] = 0;
+                break;
+            case POSIX_F_MAX_READ_TIME:
+                if(tmp->fcounters[i] < pfile->fcounters[i])
+                    tmp->counters[POSIX_MAX_READ_TIME_SIZE] =
+                        pfile->counters[POSIX_MAX_READ_TIME_SIZE];
+                break;
+            case POSIX_F_MAX_WRITE_TIME:
+                    tmp->counters[POSIX_MAX_WRITE_TIME_SIZE] =
+                        pfile->counters[POSIX_MAX_WRITE_TIME_SIZE];
+                break;
+            default:
+                tmp->fcounters[i] += pfile->fcounters[i];
+                break;
+    return;
+                      int64_t nprocs)
+    int i, j;
+    int set;
+    int min_ndx;
+    int64_t min;
+    struct darshan_mpiio_file* tmp;
+    if(mfile->rank == -1)
+        hfile->slowest_time = mfile->fcounters[MPIIO_F_SLOWEST_RANK_TIME];
+    else
+            (mfile->fcounters[MPIIO_F_META_TIME] +
+            mfile->fcounters[MPIIO_F_READ_TIME] +
+            mfile->fcounters[MPIIO_F_WRITE_TIME]));
+    else
+    hfile->cumul_time += mfile->fcounters[MPIIO_F_META_TIME] +
+                         mfile->fcounters[MPIIO_F_WRITE_TIME];
+        hfile->rec_dat = malloc(sizeof(struct darshan_mpiio_file));
+        tmp = (struct darshan_mpiio_file*)hfile->rec_dat;
+        memset(tmp, 0, sizeof(struct darshan_mpiio_file));
+    for(i = 0; i < MPIIO_NUM_INDICES; i++)
+        switch(i)
+        case MPIIO_MODE:
+            tmp->counters[i] = mfile->counters[i];
+            break;
+        case MPIIO_ACCESS1_ACCESS:
+        case MPIIO_ACCESS2_ACCESS:
+        case MPIIO_ACCESS3_ACCESS:
+        case MPIIO_ACCESS4_ACCESS:
+            break;
+        case MPIIO_ACCESS1_COUNT:
+        case MPIIO_ACCESS2_COUNT:
+        case MPIIO_ACCESS3_COUNT:
+        case MPIIO_ACCESS4_COUNT:
+            set = 0;
+            min_ndx = MPIIO_ACCESS1_COUNT;
+            for(j = MPIIO_ACCESS1_COUNT; j <= MPIIO_ACCESS4_COUNT; j++)
+                if(tmp->counters[j-4] == mfile->counters[i-4])
+                    tmp->counters[j] += mfile->counters[i];
+                    set = 1;
+                    break;
+                    min_ndx = j;
+            if(!set && (mfile->counters[i] > min))
+                tmp->counters[i-4] = mfile->counters[i-4];
+            break;
+        case MPIIO_FASTEST_RANK:
+        case MPIIO_SLOWEST_RANK:
+        case MPIIO_FASTEST_RANK_BYTES:
+        case MPIIO_SLOWEST_RANK_BYTES:
+            break;
+        case MPIIO_MAX_READ_TIME_SIZE:
+        case MPIIO_MAX_WRITE_TIME_SIZE:
+            break;
+        default:
+            tmp->counters[i] += mfile->counters[i];
+            break;
+    for(i = 0; i < MPIIO_F_NUM_INDICES; i++)
+        switch(i)
+            case MPIIO_F_OPEN_TIMESTAMP:
+            case MPIIO_F_READ_START_TIMESTAMP:
+            case MPIIO_F_WRITE_START_TIMESTAMP:
+                    tmp->fcounters[i] > mfile->fcounters[i])
+                    tmp->fcounters[i] = mfile->fcounters[i];
+                break;
+            case MPIIO_F_READ_END_TIMESTAMP:
+            case MPIIO_F_WRITE_END_TIMESTAMP:
+            case MPIIO_F_CLOSE_TIMESTAMP:
+                    tmp->fcounters[i] < mfile->fcounters[i])
+                break;
+            case MPIIO_F_FASTEST_RANK_TIME:
+            case MPIIO_F_SLOWEST_RANK_TIME:
+            case MPIIO_F_VARIANCE_RANK_TIME:
+            case MPIIO_F_VARIANCE_RANK_BYTES:
+                break;
+            case MPIIO_F_MAX_READ_TIME:
+                if(tmp->fcounters[i] < mfile->fcounters[i])
+                    tmp->counters[MPIIO_MAX_READ_TIME_SIZE] =
+                        mfile->counters[MPIIO_MAX_READ_TIME_SIZE];
+                break;
+            case MPIIO_F_MAX_WRITE_TIME:
+                    tmp->counters[MPIIO_MAX_WRITE_TIME_SIZE] =
+                        mfile->counters[MPIIO_MAX_WRITE_TIME_SIZE];
+                break;
+            default:
+                tmp->fcounters[i] += mfile->fcounters[i];
+                break;
+    return;
+                      perf_data_t *pdata)
+    pdata->total_bytes += pfile->counters[POSIX_BYTES_READ] +
+                          pfile->counters[POSIX_BYTES_WRITTEN];
+     * Calculation of Shared File Time
+     *   Four Methods!!!!
+     *     by_cumul: sum time counters and divide by nprocs
+     *               (inaccurate if lots of variance between procs)
+     *     by_open: difference between timestamp of open and close
+     *              (inaccurate if file is left open without i/o happening)
+     *     by_open_lastio: difference between timestamp of open and the
+     *                     timestamp of last i/o
+     *                     (similar to above but fixes case where file is left
+     *                      open after io is complete)
+     *     by_slowest: use slowest rank time from log data
+     *                 (most accurate but requires newer log version)
+        /* by_open */
+        if(pfile->fcounters[POSIX_F_CLOSE_TIMESTAMP] >
+            pfile->fcounters[POSIX_F_OPEN_TIMESTAMP])
+            pdata->shared_time_by_open +=
+                pfile->fcounters[POSIX_F_CLOSE_TIMESTAMP] -
+                pfile->fcounters[POSIX_F_OPEN_TIMESTAMP];
+        /* by_open_lastio */
+        if(pfile->fcounters[POSIX_F_READ_END_TIMESTAMP] >
+            pfile->fcounters[POSIX_F_WRITE_END_TIMESTAMP])
+            /* be careful: file may have been opened but not read or written */
+            if(pfile->fcounters[POSIX_F_READ_END_TIMESTAMP] > pfile->fcounters[POSIX_F_OPEN_TIMESTAMP])
+                pdata->shared_time_by_open_lastio +=
+                    pfile->fcounters[POSIX_F_READ_END_TIMESTAMP] -
+        else
+            if(pfile->fcounters[POSIX_F_WRITE_END_TIMESTAMP] > pfile->fcounters[POSIX_F_OPEN_TIMESTAMP])
+                    pfile->fcounters[POSIX_F_WRITE_END_TIMESTAMP] -
+        pdata->shared_time_by_cumul +=
+            pfile->fcounters[POSIX_F_META_TIME] +
+        pdata->shared_meta_time += pfile->fcounters[POSIX_F_META_TIME];
+        /* by_slowest */
+        pdata->shared_time_by_slowest +=
+            pfile->fcounters[POSIX_F_SLOWEST_RANK_TIME];
+     * Calculation of Unique File Time
+     *   record the data for each file and sum it
+    else
+        pdata->rank_cumul_io_time[pfile->rank] +=
+            pfile->fcounters[POSIX_F_WRITE_TIME]);
+        pdata->rank_cumul_md_time[pfile->rank] += pfile->fcounters[POSIX_F_META_TIME];
+    return;
+    pdata->total_bytes += mfile->counters[MPIIO_BYTES_READ] +
+                          mfile->counters[MPIIO_BYTES_WRITTEN];
+        /* by_open */
+        if(mfile->fcounters[MPIIO_F_CLOSE_TIMESTAMP] >
+            mfile->fcounters[MPIIO_F_OPEN_TIMESTAMP])
+                mfile->fcounters[MPIIO_F_CLOSE_TIMESTAMP] -
+                mfile->fcounters[MPIIO_F_OPEN_TIMESTAMP];
+        if(mfile->fcounters[MPIIO_F_READ_END_TIMESTAMP] >
+            mfile->fcounters[MPIIO_F_WRITE_END_TIMESTAMP])
+            if(mfile->fcounters[MPIIO_F_READ_END_TIMESTAMP] > mfile->fcounters[MPIIO_F_OPEN_TIMESTAMP])
+                    mfile->fcounters[MPIIO_F_READ_END_TIMESTAMP] -
+        else
+            if(mfile->fcounters[MPIIO_F_WRITE_END_TIMESTAMP] > mfile->fcounters[MPIIO_F_OPEN_TIMESTAMP])
+                    mfile->fcounters[MPIIO_F_WRITE_END_TIMESTAMP] -
+            mfile->fcounters[MPIIO_F_META_TIME] +
+        pdata->shared_meta_time += mfile->fcounters[MPIIO_F_META_TIME];
+        /* by_slowest */
+            mfile->fcounters[MPIIO_F_SLOWEST_RANK_TIME];
+    else
+        pdata->rank_cumul_io_time[mfile->rank] +=
+            mfile->fcounters[MPIIO_F_WRITE_TIME]);
+        pdata->rank_cumul_md_time[mfile->rank] += mfile->fcounters[MPIIO_F_META_TIME];
+    return;
+                     file_data_t *fdata)
+    hash_entry_t *tmp = NULL;
+    struct darshan_posix_file *file_rec;
+    memset(fdata, 0, sizeof(*fdata));
+    HASH_ITER(hlink, file_hash, curr, tmp)
+        int64_t bytes;
+        int64_t r;
+        int64_t w;
+        file_rec = (struct darshan_posix_file*)curr->rec_dat;
+        assert(file_rec);
+        bytes = file_rec->counters[POSIX_BYTES_READ] +
+                file_rec->counters[POSIX_BYTES_WRITTEN];
+        r = (file_rec->counters[POSIX_READS]+
+             file_rec->counters[POSIX_FREADS]);
+        w = (file_rec->counters[POSIX_WRITES]+
+             file_rec->counters[POSIX_FWRITES]);
+        fdata->total += 1;
+        fdata->total_size += bytes;
+        fdata->total_max = max(fdata->total_max, bytes);
+        if (r && !w)
+            fdata->read_only += 1;
+            fdata->read_only_size += bytes;
+            fdata->read_only_max = max(fdata->read_only_max, bytes);
+        if (!r && w)
+            fdata->write_only += 1;
+            fdata->write_only_size += bytes;
+            fdata->write_only_max = max(fdata->write_only_max, bytes);
+        if (r && w)
+            fdata->read_write += 1;
+            fdata->read_write_size += bytes;
+            fdata->read_write_max = max(fdata->read_write_max, bytes);
+        if ((curr->type & (FILETYPE_SHARED|FILETYPE_PARTSHARED)))
+            fdata->shared += 1;
+            fdata->shared_size += bytes;
+            fdata->shared_max = max(fdata->shared_max, bytes);
+        if ((curr->type & (FILETYPE_UNIQUE)))
+            fdata->unique += 1;
+            fdata->unique_size += bytes;
+            fdata->unique_max = max(fdata->unique_max, bytes);
+    return;
+    struct darshan_mpiio_file *file_rec;
+        int64_t bytes;
+        int64_t r;
+        int64_t w;
+        file_rec = (struct darshan_mpiio_file*)curr->rec_dat;
+        assert(file_rec);
+        bytes = file_rec->counters[MPIIO_BYTES_READ] +
+                file_rec->counters[MPIIO_BYTES_WRITTEN];
+        r = (file_rec->counters[MPIIO_INDEP_READS]+
+             file_rec->counters[MPIIO_COLL_READS] +
+             file_rec->counters[MPIIO_SPLIT_READS] +
+             file_rec->counters[MPIIO_NB_READS]);
+        w = (file_rec->counters[MPIIO_INDEP_WRITES]+
+             file_rec->counters[MPIIO_COLL_WRITES] +
+             file_rec->counters[MPIIO_SPLIT_WRITES] +
+             file_rec->counters[MPIIO_NB_WRITES]);
+        if (r && !w)
+        if (!r && w)
+        if (r && w)
+    return;
+               int64_t nprocs)
+    int64_t i;
+    pdata->shared_time_by_cumul =
+        pdata->shared_time_by_cumul / (double)nprocs;
+    pdata->shared_meta_time = pdata->shared_meta_time / (double)nprocs;
+    for (i=0; i<nprocs; i++)
+        if (pdata->rank_cumul_io_time[i] > pdata->slowest_rank_time)
+            pdata->slowest_rank_time = pdata->rank_cumul_io_time[i];
+            pdata->slowest_rank_meta_time = pdata->rank_cumul_md_time[i];
+            pdata->slowest_rank_rank = i;
+    if (pdata->slowest_rank_time + pdata->shared_time_by_cumul)
+    pdata->agg_perf_by_cumul = ((double)pdata->total_bytes / 1048576.0) /
+                                  (pdata->slowest_rank_time +
+                                   pdata->shared_time_by_cumul);
+    if (pdata->slowest_rank_time + pdata->shared_time_by_open)
+    pdata->agg_perf_by_open  = ((double)pdata->total_bytes / 1048576.0) /
+                                    pdata->shared_time_by_open);
+    if (pdata->slowest_rank_time + pdata->shared_time_by_open_lastio)
+    pdata->agg_perf_by_open_lastio = ((double)pdata->total_bytes / 1048576.0) /
+                                      pdata->shared_time_by_open_lastio);
+    if (pdata->slowest_rank_time + pdata->shared_time_by_slowest)
+    pdata->agg_perf_by_slowest = ((double)pdata->total_bytes / 1048576.0) /
+                                      pdata->slowest_rank_meta_time +
+                                      pdata->shared_time_by_slowest);
+    return;
+    int i;
+    printf("\n");
+        printf("total_%s: %"PRId64"\n",
+            posix_counter_names[i], pfile->counters[i]);
+        printf("total_%s: %lf\n",
+            posix_f_counter_names[i], pfile->fcounters[i]);
+    return;
+    int i;
+    printf("\n");
+            mpiio_counter_names[i], mfile->counters[i]);
+            mpiio_f_counter_names[i], mfile->fcounters[i]);
+    return;
+                     struct darshan_record_ref *rec_hash,
+                     int detail_flag)
+    struct darshan_posix_file *file_rec = NULL;
+    struct darshan_record_ref *ref = NULL;
+    int i;
+    /* list of columns:
+     * normal mode
+     * - file id
+     * - file name
+     * - nprocs
+     * - slowest I/O time
+     * - average cumulative I/O time
+     * detailed mode
+     * - first open
+     * - first read
+     * - first write
+     * - last read
+     * - last write
+     * - last close
+     * - POSIX opens
+     * - r histogram
+     * - w histogram
+    if(detail_flag)
+        printf("\n# Per-file summary of I/O activity (detailed).\n");
+    else
+        printf("\n# Per-file summary of I/O activity.\n");
+    printf("# <record_id>: darshan record id for this file\n");
+    printf("# <file_name>: file name\n");
+    printf("# <nprocs>: number of processes that opened the file\n");
+    printf("# <slowest>: (estimated) time in seconds consumed in IO by slowest process\n");
+    printf("# <avg>: average time in seconds consumed in IO per process\n");
+    if(detail_flag)
+        printf("# <start_{open/read/write}>: start timestamp of first open, read, or write\n");
+        printf("# <end_{read/write/close}>: end timestamp of last read, write, or close\n");
+        printf("# <posix_opens>: POSIX open calls\n");
+        printf("# <POSIX_SIZE_READ_*>: POSIX read size histogram\n");
+        printf("# <POSIX_SIZE_WRITE_*>: POSIX write size histogram\n");
+    printf("\n# <file_id>\t<file_name>\t<nprocs>\t<slowest>\t<avg>");
+    if(detail_flag)
+        printf("\t<start_open>\t<start_read>\t<start_write>");
+        printf("\t<end_read>\t<end_write>\t<end_close>\t<posix_opens>");
+        for(i=POSIX_SIZE_READ_0_100; i<= POSIX_SIZE_WRITE_1G_PLUS; i++)
+            printf("\t<%s>", posix_counter_names[i]);
+    printf("\n");
+        assert(file_rec);
+        HASH_FIND(hlink, rec_hash, &(curr->rec_id), sizeof(darshan_record_id), ref);
+        assert(ref);
+        printf("%" PRIu64 "\t%s\t%" PRId64 "\t%f\t%f",
+            curr->rec_id,
+            ref->rec.name,
+            curr->procs,
+            curr->slowest_time,
+            curr->cumul_time/(double)curr->procs);
+        if(detail_flag)
+            for(i=POSIX_F_OPEN_TIMESTAMP; i<=POSIX_F_CLOSE_TIMESTAMP; i++)
+                printf("\t%f", file_rec->fcounters[i]);
+            printf("\t%" PRId64, file_rec->counters[POSIX_OPENS]);
+                printf("\t%" PRId64, file_rec->counters[i]);
+        printf("\n");
+    return;
+                     int detail_flag)
+    struct darshan_mpiio_file *file_rec = NULL;
+    int i;
+     * normal mode
+     * - file id
+     * - file name
+     * - nprocs
+     * detailed mode
+     * - first open
+     * - first read
+     * - first write
+     * - last read
+     * - last write
+     * - last close
+     * - MPI indep opens
+     * - MPI coll opens
+     * - r histogram
+     * - w histogram
+    if(detail_flag)
+    else
+    if(detail_flag)
+        printf("# <mpi_indep_opens>: independent MPI_File_open calls\n");
+        printf("# <mpi_coll_opens>: collective MPI_File_open calls\n");
+        printf("# <MPIIO_SIZE_READ_AGG_*>: MPI-IO aggregate read size histogram\n");
+        printf("# <MPIIO_SIZE_WRITE_AGG_*>: MPI-IO aggregate write size histogram\n");
+    if(detail_flag)
+        printf("\t<end_read>\t<end_write>\t<end_close>");
+        printf("\t<mpi_indep_opens>\t<mpi_coll_opens>");
+        for(i=MPIIO_SIZE_READ_AGG_0_100; i<= MPIIO_SIZE_WRITE_AGG_1G_PLUS; i++)
+            printf("\t<%s>", mpiio_counter_names[i]);
+    printf("\n");
+        assert(file_rec);
+        assert(ref);
+            curr->rec_id,
+            ref->rec.name,
+            curr->procs,
+        if(detail_flag)
+            for(i=MPIIO_F_OPEN_TIMESTAMP; i<=MPIIO_F_CLOSE_TIMESTAMP; i++)
+            printf("\t%" PRId64 "\t%" PRId64, file_rec->counters[MPIIO_INDEP_OPENS],
+                file_rec->counters[MPIIO_COLL_OPENS]);
+        printf("\n");
+    return;
+ * Local variables:
+ *  c-indent-level: 4
+ *  c-basic-offset: 4
+ * End:
+ * vim: ts=8 sts=4 sw=4 expandtab
diff --git a/darshan-util/darshan-pnetcdf-logutils.c b/darshan-util/darshan-pnetcdf-logutils.c
index 98f85c0..d37d21f 100644
--- a/darshan-util/darshan-pnetcdf-logutils.c
+++ b/darshan-util/darshan-pnetcdf-logutils.c
@@ -30,8 +30,8 @@ char *pnetcdf_f_counter_names[] = {
 #undef X
-static int darshan_log_get_pnetcdf_file(darshan_fd fd, void** pnetcdf_buf_p,
+static int darshan_log_get_pnetcdf_file(void** pnetcdf_buf_p, int* bytes_left,
 static void darshan_log_print_pnetcdf_file(void *file_rec,
@@ -41,8 +41,8 @@ struct darshan_mod_logutil_funcs pnetcdf_logutils =
     .log_print_record = &darshan_log_print_pnetcdf_file,
     int i;
     struct darshan_pnetcdf_file *file = (struct darshan_pnetcdf_file *)
@@ -51,7 +51,7 @@ static int darshan_log_get_pnetcdf_file(darshan_fd fd, void** pnetcdf_buf_p,
     if(*bytes_left < sizeof(struct darshan_pnetcdf_file))
         return(-1);
-    if(fd->swap_flag)
diff --git a/darshan-util/darshan-posix-logutils.c b/darshan-util/darshan-posix-logutils.c
index d3640d9..5a02610 100644
--- a/darshan-util/darshan-posix-logutils.c
+++ b/darshan-util/darshan-posix-logutils.c
@@ -30,8 +30,8 @@ char *posix_f_counter_names[] = {
 #undef X
-static int darshan_log_get_posix_file(darshan_fd fd, void** psx_buf_p,
+static int darshan_log_get_posix_file(void** psx_buf_p, int* bytes_left,
 static void darshan_log_print_posix_file(void *file_rec,
@@ -41,8 +41,8 @@ struct darshan_mod_logutil_funcs posix_logutils =
     .log_print_record = &darshan_log_print_posix_file,
-    int* bytes_left, void **file_rec, darshan_record_id* rec_id)
     int i;
     struct darshan_posix_file *file = (struct darshan_posix_file *)
@@ -51,7 +51,7 @@ static int darshan_log_get_posix_file(darshan_fd fd, void** psx_buf_p,
     if(*bytes_left < sizeof(struct darshan_posix_file))
         return(-1);
-    if(fd->swap_flag)
hooks/post-receive
More information about the Darshan-commits mailing list
