[Darshan-commits] [Darshan] branch, dev-modular, updated. darshan-2.3.1-140-gbaa3f7b
Service Account
git at mcs.anl.gov
Thu Aug 13 16:54:24 CDT 2015
This is an automated email from the git hooks/post-receive script. It was
generated because a ref change was pushed to the repository containing
the project "".
The branch, dev-modular has been updated
via baa3f7bca57ca182c15462528f6de0a4776f8906 (commit)
from 718c949783d8f39699000b2002e884a9f2d2ac35 (commit)
Those revisions listed above that are new to this repository have
not appeared on any other notification email; so we list those
revisions in full, below.
- Log -----------------------------------------------------------------
commit baa3f7bca57ca182c15462528f6de0a4776f8906
Author: Shane Snyder <ssnyder at mcs.anl.gov>
Date: Thu Aug 13 16:53:45 2015 -0500
update regression tests to reflect recent updates
Summary of changes:
darshan-test/regression/run-all.sh | 2 +-
darshan-test/regression/test-cases/cxxpi.sh | 9 ++-------
darshan-test/regression/test-cases/fperf-f77.sh | 18 +++++-------------
darshan-test/regression/test-cases/fperf-f90.sh | 18 +++++-------------
darshan-test/regression/test-cases/mpi-io-test.sh | 16 +++++-----------
5 files changed, 18 insertions(+), 45 deletions(-)
Diff of changes:
diff --git a/darshan-test/regression/run-all.sh b/darshan-test/regression/run-all.sh
index 97607cc..cb03fcc 100755
--- a/darshan-test/regression/run-all.sh
+++ b/darshan-test/regression/run-all.sh
@@ -17,7 +17,7 @@ DARSHAN_TESTDIR=$( cd "$( dirname "${BASH_SOURCE[0]}" )" && pwd )
export DARSHAN_TESTDIR
# check darshan path
-if [ ! -x $DARSHAN_PATH/bin/darshan-posix-parser ]; then
+if [ ! -x $DARSHAN_PATH/bin/darshan-parser ]; then
echo "Error: $DARSHAN_PATH doesn't contain a valid Darshan install." 1>&2
exit 1
fi
diff --git a/darshan-test/regression/test-cases/cxxpi.sh b/darshan-test/regression/test-cases/cxxpi.sh
index eda00eb..e7d7f47 100755
--- a/darshan-test/regression/test-cases/cxxpi.sh
+++ b/darshan-test/regression/test-cases/cxxpi.sh
@@ -21,7 +21,7 @@ if [ $? -ne 0 ]; then
fi
# parse log
-$DARSHAN_PATH/bin/darshan-posix-parser $DARSHAN_LOGFILE > $DARSHAN_TMP/${PROG}.darshan.txt
+$DARSHAN_PATH/bin/darshan-parser $DARSHAN_LOGFILE > $DARSHAN_TMP/${PROG}.darshan.txt
echo "Error: failed to parse ${DARSHAN_LOGFILE}" 1>&2
exit 1
@@ -29,12 +29,7 @@ fi
# check results
# in this case we want to confirm that the open counts are zero; cxxpi does not do any IO
-#POSIX_OPENS=`grep CP_POSIX_OPENS $DARSHAN_TMP/${PROG}.darshan.txt |cut -f 4`
-#if [ "$POSIX_OPENS"x != ""x ]; then
-# echo "Error: Found unexpected POSIX open count of $POSIX_OPENS" 1>&2
-# exit 1
-#fi
-POSIX_OPENS=`grep POSIX_OPENS $DARSHAN_TMP/${PROG}.darshan.txt |cut -d : -f 2 |xargs`
+POSIX_OPENS=`grep POSIX_OPENS $DARSHAN_TMP/${PROG}.darshan.txt |cut -f 5`
exit 1
diff --git a/darshan-test/regression/test-cases/fperf-f77.sh b/darshan-test/regression/test-cases/fperf-f77.sh
index 7159572..6a73390 100755
--- a/darshan-test/regression/test-cases/fperf-f77.sh
+++ b/darshan-test/regression/test-cases/fperf-f77.sh
@@ -21,31 +21,23 @@ if [ $? -ne 0 ]; then
fi
# parse log
-if [ $? -ne 0 ]; then
- echo "Error: failed to parse ${DARSHAN_LOGFILE}" 1>&2
- exit 1
-fi
-$DARSHAN_PATH/bin/darshan-mpiio-parser $DARSHAN_LOGFILE > $DARSHAN_TMP/${PROG}-mpiio.darshan.txt
exit 1
fi
# check results
# in this case we want to confirm that both the MPI and POSIX open counters were triggered
-if [ ! $POSIX_OPENS -gt 0 ]; then
+if [ ! "$POSIX_OPENS" -gt 0 ]; then
echo "Error: POSIX open count of $POSIX_OPENS is incorrect" 1>&2
exit 1
fi
-MPI_OPENS=`grep COLL_OPENS $DARSHAN_TMP/${PROG}-mpiio.darshan.txt |cut -d : -f 2 |xargs`
-if [ ! $MPI_OPENS -gt 0 ]; then
+MPI_OPENS=`grep COLL_OPENS $DARSHAN_TMP/${PROG}.darshan.txt |cut -f 5`
+if [ ! "$MPI_OPENS" -gt 0 ]; then
echo "Error: MPI open count of $MPI_OPENS is incorrect" 1>&2
exit 1
fi
exit 0
diff --git a/darshan-test/regression/test-cases/fperf-f90.sh b/darshan-test/regression/test-cases/fperf-f90.sh
index 0bdf420..fc166b6 100755
--- a/darshan-test/regression/test-cases/fperf-f90.sh
+++ b/darshan-test/regression/test-cases/fperf-f90.sh
fi
# parse log
- exit 1
-fi
exit 1
fi
# check results
exit 1
fi
exit 1
fi
exit 0
diff --git a/darshan-test/regression/test-cases/mpi-io-test.sh b/darshan-test/regression/test-cases/mpi-io-test.sh
index 63d04b0..52dd387 100755
--- a/darshan-test/regression/test-cases/mpi-io-test.sh
+++ b/darshan-test/regression/test-cases/mpi-io-test.sh
@@ -21,12 +21,7 @@ if [ $? -ne 0 ]; then
fi
# parse log
- exit 1
-fi
exit 1
@@ -34,16 +29,15 @@ fi
# check results
exit 1
fi
-MPI_OPENS=`grep INDEP_OPENS $DARSHAN_TMP/${PROG}-mpiio.darshan.txt |cut -d : -f 2 |xargs`
+MPI_OPENS=`grep INDEP_OPENS $DARSHAN_TMP/${PROG}.darshan.txt |cut -f 5`
exit 1
fi
exit 0
hooks/post-receive
More information about the Darshan-commits
