[Darshan-commits] [Darshan] branch, dev-modular, updated. darshan-2.3.1-100-g5ecf401
Service Account
git at mcs.anl.gov
Wed Apr 8 16:00:52 CDT 2015
This is an automated email from the git hooks/post-receive script. It was
generated because a ref change was pushed to the repository containing
the project "".
The branch, dev-modular has been updated
via 5ecf4013b55c356441590ce97e4ef29cf03d3a1f (commit)
from 233f1607498e8197f127a5b2712f1593e752ae28 (commit)
Those revisions listed above that are new to this repository have
not appeared on any other notification email; so we list those
revisions in full, below.
- Log -----------------------------------------------------------------
commit 5ecf4013b55c356441590ce97e4ef29cf03d3a1f
Author: Shane Snyder <ssnyder at mcs.anl.gov>
Date: Wed Apr 8 15:59:58 2015 -0500
more docs + "NULL" example module implementation
Summary of changes:
darshan-log-format.h | 9 +-
darshan-mpiio-log-format.h | 5 +-
darshan-null-log-format.h | 47 ++++
darshan-runtime/Makefile.in | 18 +-
darshan-runtime/darshan.h | 46 ++--
darshan-runtime/lib/darshan-core.c | 9 +-
darshan-runtime/lib/darshan-mpiio.c | 12 +-
darshan-runtime/lib/darshan-null.c | 382 +++++++++++++++++++++++++++
darshan-runtime/lib/darshan-posix.c | 20 +-
darshan-runtime/utlist.h | 490 +++++++++++++++++++++++++++++++++++
doc/darshan-modularization.txt | 7 +-
11 files changed, 994 insertions(+), 51 deletions(-)
create mode 100644 darshan-null-log-format.h
create mode 100644 darshan-runtime/lib/darshan-null.c
create mode 100644 darshan-runtime/utlist.h
Diff of changes:
diff --git a/darshan-log-format.h b/darshan-log-format.h
index 7c49cbb..8886700 100644
--- a/darshan-log-format.h
+++ b/darshan-log-format.h
@@ -1,6 +1,7 @@
- * (C) 2009 by Argonne National Laboratory.
- * See COPYRIGHT in top-level directory.
+ * Copyright (C) 2015 University of Chicago.
+ * See COPYRIGHT notice in top-level directory.
#ifndef __DARSHAN_LOG_FORMAT_H
@@ -39,7 +40,8 @@ typedef uint64_t darshan_record_id;
#define DARSHAN_MAX_MODS 16
typedef enum
- DARSHAN_POSIX_MOD = 0,
+ DARSHAN_NULL_MOD = 0,
+ DARSHAN_POSIX_MOD,
DARSHAN_MPIIO_MOD,
DARSHAN_HDF5_MOD,
DARSHAN_PNETCDF_MOD,
@@ -47,6 +49,7 @@ typedef enum
static char * const darshan_module_names[] =
+ "NULL",
"POSIX",
"MPI-IO",
"HDF5",
diff --git a/darshan-mpiio-log-format.h b/darshan-mpiio-log-format.h
index 48a10f0..857133d 100644
--- a/darshan-mpiio-log-format.h
+++ b/darshan-mpiio-log-format.h
@@ -1,6 +1,7 @@
- * (C) 2015 by Argonne National Laboratory.
#ifndef __DARSHAN_MPIIO_LOG_FORMAT_H
diff --git a/darshan-null-log-format.h b/darshan-null-log-format.h
new file mode 100644
index 0000000..152dd1a
--- /dev/null
+++ b/darshan-null-log-format.h
@@ -0,0 +1,47 @@
+#ifndef __DARSHAN_NULL_LOG_FORMAT_H
+#define __DARSHAN_NULL_LOG_FORMAT_H
+#include "darshan-log-format.h"
+/* integer counters for the "NULL" example module */
+enum darshan_null_indices
+ NULL_BARS, /* count of number of 'bar' function calls */
+ NULL_BAR_DAT, /* arbitrary data value set by last call to 'bar' */
+ NULL_NUM_INDICES,
+/* floating point counters for the "NULL" example module */
+enum darshan_null_f_indices
+ NULL_F_BAR_TIMESTAMP, /* timestamp of the first call to function 'bar' */
+ NULL_F_BAR_DURATION, /* timer indicating duration of last call to 'bar' */
+ NULL_F_NUM_INDICES,
+/* the darshan_null_record structure encompasses the high-level data/counters
+ * which would actually be logged to file by Darshan for the "NULL" example
+ * module. This example implementation logs the following data for each
+ * record:
+ * - a corresponding Darshan record identifier
+ * - the rank of the process responsible for the record
+ * - integer I/O counters (operation counts, I/O sizes, etc.)
+ * - floating point I/O counters (timestamps, cumulative timers, etc.)
+struct darshan_null_record
+ darshan_record_id f_id;
+ int64_t rank;
+ int64_t counters[NULL_NUM_INDICES];
+ double fcounters[NULL_F_NUM_INDICES];
+#endif /* __DARSHAN_NULL_LOG_FORMAT_H */
diff --git a/darshan-runtime/Makefile.in b/darshan-runtime/Makefile.in
index 791cac6..be3485b 100644
--- a/darshan-runtime/Makefile.in
+++ b/darshan-runtime/Makefile.in
@@ -1,4 +1,4 @@
-all: lib/libdarshan.a
+all: lib/libdarshan.a lib/darshan-null.o
DESTDIR =
srcdir = @srcdir@
@@ -19,7 +19,7 @@ DARSHAN_LOG_FORMAT = $(srcdir)/../darshan-log-format.h
DARSHAN_VERSION = @DARSHAN_VERSION@
ifndef DISABLE_LDPRELOAD
-all: lib/libdarshan.so
+all: lib/libdarshan.so lib/darshan-null.po
endif
VPATH = $(srcdir)
@@ -51,16 +51,22 @@ lib/darshan-common.o: lib/darshan-common.c darshan.h $(DARSHAN_LOG_FORMAT) | lib
lib/darshan-common.po: lib/darshan-common.c darshan.h $(DARSHAN_LOG_FORMAT) | lib
$(CC) $(CFLAGS_SHARED) -c $< -o $@
-lib/darshan-posix.o: lib/darshan-posix.c darshan.h $(DARSHAN_LOG_FORMAT) | lib
+lib/darshan-null.o: lib/darshan-null.c darshan.h $(DARSHAN_LOG_FORMAT) $(srcdir)/../darshan-null-log-format.h | lib
$(CC) $(CFLAGS) -c $< -o $@
-lib/darshan-posix.po: lib/darshan-posix.c darshan.h $(DARSHAN_LOG_FORMAT) | lib
+lib/darshan-null.po: lib/darshan-null.c darshan.h $(DARSHAN_LOG_FORMAT) $(srcdir)/../darshan-null-log-format.h | lib
-lib/darshan-mpiio.o: lib/darshan-mpiio.c darshan.h $(DARSHAN_LOG_FORMAT) | lib
+lib/darshan-posix.o: lib/darshan-posix.c darshan.h $(DARSHAN_LOG_FORMAT) $(srcdir)/../darshan-posix-log-format.h | lib
-lib/darshan-mpiio.po: lib/darshan-mpiio.c darshan.h $(DARSHAN_LOG_FORMAT) | lib
+lib/darshan-posix.po: lib/darshan-posix.c darshan.h $(DARSHAN_LOG_FORMAT) $(srcdir)/../darshan-posix-log-format.h | lib
+ $(CC) $(CFLAGS_SHARED) -c $< -o $@
+lib/darshan-mpiio.o: lib/darshan-mpiio.c darshan.h $(DARSHAN_LOG_FORMAT) $(srcdir)/../darshan-mpiio-log-format.h | lib
+ $(CC) $(CFLAGS) -c $< -o $@
+lib/darshan-mpiio.po: lib/darshan-mpiio.c darshan.h $(DARSHAN_LOG_FORMAT) $(srcdir)/../darshan-mpiio-log-format.h | lib
lib/lookup3.o: lib/lookup3.c
diff --git a/darshan-runtime/darshan.h b/darshan-runtime/darshan.h
index b9c7066..6016d24 100644
--- a/darshan-runtime/darshan.h
+++ b/darshan-runtime/darshan.h
@@ -34,38 +34,43 @@
#include <dlfcn.h>
#include <stdlib.h>
-#define DARSHAN_FORWARD_DECL(name,ret,args) \
- ret (*__real_ ## name)args = NULL
+#define DARSHAN_FORWARD_DECL(__func,__ret,__args) \
+ __ret (*__real_ ## __func)__args = NULL
-#define DARSHAN_DECL(__name) __name
+#define DARSHAN_DECL(__func) __func
-#define DARSHAN_MPI_CALL(func) __real_ ## func
+#define DARSHAN_MPI_CALL(__func) __real_ ## __func
-#define MAP_OR_FAIL(func) \
- if (!(__real_ ## func)) \
+#define MAP_OR_FAIL(__func) \
+ if (!(__real_ ## __func)) \
- __real_ ## func = dlsym(RTLD_NEXT, #func); \
- if(!(__real_ ## func)) { \
- fprintf(stderr, "Darshan failed to map symbol: %s\n", #func); \
+ __real_ ## __func = dlsym(RTLD_NEXT, #__func); \
+ if(!(__real_ ## __func)) { \
+ fprintf(stderr, "Darshan failed to map symbol: %s\n", #__func); \
exit(1); \
#else
- extern ret __real_ ## name args;
+#define DARSHAN_FORWARD_DECL(__name,__ret,__args) \
+ extern __ret __real_ ## __name __args;
#define DARSHAN_DECL(__name) __wrap_ ## __name
-#define DARSHAN_MPI_CALL(func) func
+#define DARSHAN_MPI_CALL(__func) __func
#endif
-/* macros for manipulating module's counter variables */
-/* NOTE: */
+/* macros for manipulating a module's counter variables */
+/* NOTE: These macros assume a module's record stores integer
+ * and floating point counters in arrays, named counters and
+ * fcounters, respectively. __rec_p is the a pointer to the
+ * data record, __counter is the counter in question, and
+ * __value is the corresponding data value.
#define DARSHAN_COUNTER_SET(__rec_p, __counter, __value) do{ \
(__rec_p)->counters[__counter] = __value; \
} while(0)
@@ -102,6 +107,11 @@
} while(0)
+/* NOTE: This macro is for storing histogram counters with 10
+ * distinct buckets. For an example of how it is used, consult
+ * the POSIX module implementation, which stores histograms of
+ * access sizes for POSIX I/O functions.
#define DARSHAN_BUCKET_INC(__rec_p, __counter_base, __value) do {\
if(__value < 101) \
(__rec_p)->counters[__counter_base] += 1; \
@@ -128,10 +138,10 @@
/* module developers provide the following functions to darshan-core */
struct darshan_module_funcs
- /* disable futher instrumentation within a module */
- void (*disable_instrumentation)(void);
+ /* perform any necessary pre-shutdown steps */
+ void (*begin_shutdown)(void);
/* perform any necessary steps prior to reducing */
- void (*prepare_for_reduction)(
+ void (*setup_reduction)(
darshan_record_id *shared_recs, /* input list of shared records */
int *shared_rec_count, /* in/out shared record count */
void **send_buf, /* send buffer for shared file reduction */
diff --git a/darshan-runtime/lib/darshan-core.c b/darshan-runtime/lib/darshan-core.c
index 55006bc..aee8c6f 100644
--- a/darshan-runtime/lib/darshan-core.c
+++ b/darshan-runtime/lib/darshan-core.c
@@ -258,14 +258,15 @@ void darshan_core_shutdown()
darshan_core = NULL;
/* we also need to set which modules were registered on this process and
- * disable tracing within those modules while we shutdown
+ * call into those modules and give them a chance to perform any necessary
+ * pre-shutdown steps.
for(i = 0; i < DARSHAN_MAX_MODS; i++)
if(final_core->mod_array[i])
local_mod_use[i] = 1;
- final_core->mod_array[i]->mod_funcs.disable_instrumentation();
+ final_core->mod_array[i]->mod_funcs.begin_shutdown();
DARSHAN_CORE_UNLOCK();
@@ -492,10 +493,10 @@ void darshan_core_shutdown()
/* if there are globally shared files, do a shared file reduction */
- if(shared_rec_count && this_mod->mod_funcs.prepare_for_reduction &&
+ if(shared_rec_count && this_mod->mod_funcs.setup_reduction &&
this_mod->mod_funcs.record_reduction_op)
- this_mod->mod_funcs.prepare_for_reduction(mod_shared_recs, &shared_rec_count,
+ this_mod->mod_funcs.setup_reduction(mod_shared_recs, &shared_rec_count,
&red_send_buf, &red_recv_buf, &rec_sz);
if(shared_rec_count)
diff --git a/darshan-runtime/lib/darshan-mpiio.c b/darshan-runtime/lib/darshan-mpiio.c
index 67f30a5..2d3a82d 100644
--- a/darshan-runtime/lib/darshan-mpiio.c
+++ b/darshan-runtime/lib/darshan-mpiio.c
@@ -114,7 +114,7 @@ static int my_rank = -1;
#define MPIIO_UNLOCK() pthread_mutex_unlock(&mpiio_runtime_mutex)
static void mpiio_runtime_initialize(void);
-static void mpiio_disable_instrumentation(void);
+static void mpiio_begin_shutdown(void);
static void mpiio_shutdown(void);
static void mpiio_get_output_data(
void **buffer,
@@ -123,7 +123,7 @@ static struct mpiio_file_runtime* mpiio_file_by_name_setfh(const char* name, MPI
static struct mpiio_file_runtime* mpiio_file_by_name(const char *name);
static void mpiio_record_reduction_op(void* infile_v, void* inoutfile_v,
int *len, MPI_Datatype *datatype);
-static void mpiio_prepare_for_reduction(darshan_record_id *shared_recs,
+static void mpiio_setup_reduction(darshan_record_id *shared_recs,
int *shared_rec_count, void **send_buf, void **recv_buf, int *rec_size);
static int mpiio_file_compare(const void* a, const void* b);
@@ -192,8 +192,8 @@ static void mpiio_runtime_initialize()
int mem_limit;
struct darshan_module_funcs mpiio_mod_fns =
- .disable_instrumentation = &mpiio_disable_instrumentation,
- .prepare_for_reduction = &mpiio_prepare_for_reduction,
+ .begin_shutdown = &mpiio_begin_shutdown,
+ .setup_reduction = &mpiio_setup_reduction,
.record_reduction_op = &mpiio_record_reduction_op,
.get_output_data = &mpiio_get_output_data,
.shutdown = &mpiio_shutdown
@@ -245,7 +245,7 @@ static void mpiio_runtime_initialize()
return;
-static void mpiio_disable_instrumentation()
+static void mpiio_begin_shutdown()
assert(mpiio_runtime);
@@ -444,7 +444,7 @@ static void mpiio_record_reduction_op(
return;
void **send_buf,
diff --git a/darshan-runtime/lib/darshan-null.c b/darshan-runtime/lib/darshan-null.c
index 0000000..0a864e2
--- /dev/null
+++ b/darshan-runtime/lib/darshan-null.c
@@ -0,0 +1,382 @@
+#define _XOPEN_SOURCE 500
+#define _GNU_SOURCE
+#include "darshan-runtime-config.h"
+#include <stdio.h>
+#include <unistd.h>
+#include <stdlib.h>
+#include <pthread.h>
+#include <assert.h>
+#include "uthash.h"
+#include "darshan.h"
+#include "darshan-null-log-format.h"
+/* The "NULL" module is an example instrumentation module implementation provided
+ * with Darshan, primarily to indicate how arbitrary modules may be integrated
+ * into Darshan. In particular, this module demonstrates how to develop wrapper
+ * functions for intercepting functions of interest, how to best manage necessary
+ * runtime data structures, and how to coordinate with the darshan-core component,
+ * among other things. This module is not linked with the darshan-runtime library;
+ * it is intended mainly to serve as a basic stubbed out module implementation
+ * that may be reused and expanded on by developers adding new instrumentation modules.
+/* TODO: this probably shouldn't be here -- LD_PRELOADing POSIX wrappers will cause MPI linker dependency */
+#ifdef DARSHAN_PRELOAD
+extern double (*__real_PMPI_Comm_rank)(MPI_Comm comm, int *rank);
+#endif
+/* The DARSHAN_FORWARD_DECL macro (defined in darshan.h) is used to provide forward
+ * declarations for wrapped funcions, regardless if Darshan is used with statically
+ * or dynamically linked executables.
+DARSHAN_FORWARD_DECL(foo, int, (const char *name, int arg1, int arg2));
+/* The null_record_runtime structure maintains necessary runtime metadata
+ * for a "NULL" module data record (darshan_null_record structure, defined
+ * in darshan-null-log-format.h). This metadata assists with the instrumenting
+ * of specific statistics in the file record.
+ * RATIONALE: In general, a module may need to track some stateful, volatile
+ * information regarding specific I/O statistics to aid in the instrumentation
+ * process. However, this information should not be stored in the darshan_null_record
+ * struct because we don't want it to appear in the final darshan log file.
+ * We therefore associate a null_record_runtime structure with each darshan_null_record
+ * structure in order to track this information.
+ * NOTE: The null_record_runtime struct contains a pointer to a darshan_null_record
+ * struct (see the *record_p member) rather than simply embedding an entire
+ * darshan_null_record struct. This is done so that all of the darshan_null_record
+ * structs can be kept contiguous in memory as a single array to simplify
+ * reduction, compression, and storage.
+struct null_record_runtime
+ /* Darshan record for the "NULL" example module */
+ struct darshan_null_record* record_p;
+ /* ... other runtime data ... */
+ /* hash table link for this record */
+ /* NOTE: it is entirely up to the module developer how to persist module
+ * records in memory as the instrumented application runs. These records
+ * could just as easily be stored in an array or linked list. That said,
+ * the data structure selection should be mindful of the resulting memory
+ * footprint and search time complexity to attempt minimize Darshan overheads.
+ * hash table and linked list implementations are available in uthash.h and
+ * utlist.h, respectively.
+ UT_hash_handle hlink;
+/* The null_runtime structure simply encapsulates global data structures needed
+ * by the module for instrumenting functions of interest and providing the output
+ * I/O data for this module to the darshan-core component at shutdown time.
+struct null_runtime
+ /* runtime_record_array is the array of runtime records for the "NULL" module. */
+ struct null_record_runtime* runtime_record_array;
+ /* record_array is the array of high-level Darshan records for the "NULL" module,
+ * each corresponding to the the runtime record structure stored at the same array
+ * index in runtime_record_array.
+ struct darshan_null_record* record_array;
+ /* file_array_size is the maximum amount of records that can be stored in
+ * record_array (and consequentially, runtime_record_array).
+ int rec_array_size;
+ /* file_array_ndx is the current index into both runtime_record_array and
+ * record_array.
+ int rec_array_ndx;
+ /* record_hash is a pointer to a hash table of null_record_runtime structures
+ * currently maintained by the "NULL" module.
+ struct null_record_runtime* record_hash;
+/* null_runtime is the global data structure encapsulating "NULL" module state */
+static struct null_runtime *null_runtime = NULL;
+/* The null_runtime_mutex is a lock used when updating the null_runtime global
+ * structure (or any other global data structures). This is necessary to avoid race
+ * conditions as multiple threads execute function wrappers and update module state.
+ * NOTE: Recursive mutexes are used in case functions wrapped by this module call
+ * other wrapped functions that would result in deadlock, otherwise. This mechanism
+ * may not be necessary for all instrumentation modules.
+static pthread_mutex_t null_runtime_mutex = PTHREAD_RECURSIVE_MUTEX_INITIALIZER_NP;
+/* the instrumentation_disabled flag is used to toggle wrapper functions on/off */
+static int instrumentation_disabled = 0;
+/* my_rank indicates the MPI rank of this process */
+static int my_rank = -1;
+/* internal helper functions for the "NULL" module */
+static void null_runtime_initialize(void);
+static struct null_record_runtime* null_record_by_name(const char *name);
+/* forward declaration for module functions needed to interface with darshan-core */
+static void null_begin_shutdown(void);
+static void null_get_output_data(void **buffer, int *size);
+static void null_shutdown(void);
+/* macros for obtaining/releasing the "NULL" module lock */
+#define NULL_LOCK() pthread_mutex_lock(&null_runtime_mutex)
+#define NULL_UNLOCK() pthread_mutex_unlock(&null_runtime_mutex)
+/* macro for instrumenting the "NULL" module's foo function */
+/* NOTE: this macro makes use of the DARSHAN_COUNTER_* macros defined
+ * and documented in darshan.h.
+#define NULL_RECORD_FOO(__ret, __name, __dat, __tm1, __tm2) do{ \
+ struct null_record_runtime* rec; \
+ double elapsed = __tm2 - __tm1; \
+ /* if foo returns error (return code < 0), don't instrument anything */ \
+ if(__ret < 0) break; \
+ /* use '__name' to lookup a corresponding "NULL" record */ \
+ rec = null_record_by_name(__name); \
+ if(!rec) break; \
+ /* increment counter indicating number of calls to 'bar' */ \
+ DARSHAN_COUNTER_INC(rec->record_p, NULL_BARS, 1); \
+ /* store data value for most recent call to 'bar' */ \
+ DARSHAN_COUNTER_SET(rec->record_p, NULL_BAR_DAT, __dat); \
+ /* store timestamp of most recent call to 'bar' */ \
+ DARSHAN_COUNTER_F_SET(rec->record_p, NULL_F_BAR_TIMESTAMP, __tm1); \
+ /* store duration of most recent call to 'bar' */ \
+ DARSHAN_COUNTER_F_SET(rec->record_p, NULL_F_BAR_DURATION, elapsed); \
+} while(0)
+ * Wrappers for "NULL" module functions of interest *
+/* The DARSHAN_DECL macro provides the appropriate wrapper function names,
+ * depending on whether the Darshan library is statically or dynamically linked.
+int DARSHAN_DECL(foo)(const char* name, int arg1, int arg2)
+ ssize_t ret;
+ double tm1, tm2;
+ /* The MAP_OR_FAIL macro attempts to obtain the address of the actual
+ * underlying foo function call (__real_foo), in the case of LD_PRELOADing
+ * the Darshan library. For statically linked executables, this macro is
+ * just a NOP.
+ MAP_OR_FAIL(foo);
+ /* In general, Darshan wrappers begin by calling the real version of the
+ * given wrapper function. Timers are used to record the duration of this
+ * operation. */
+ tm1 = darshan_core_wtime();
+ ret = __real_foo(name, arg1, arg2);
+ tm2 = darshan_core_wtime();
+ NULL_LOCK();
+ /* Before attempting to instrument I/O statistics for function foo, make
+ * sure the "NULL" module runtime environment has been initialized.
+ * NOTE: this runtime environment is initialized only once -- if the
+ * appropriate structures have already been initialized, this function simply
+ * returns.
+ null_runtime_initialize();
+ /* Call macro for instrumenting data for foo function calls. */
+ NULL_RECORD_FOO(ret, name, arg1+arg2, tm1, tm2);
+ NULL_UNLOCK();
+ return(ret);
+ * Internal functions for manipulating POSIX module state *
+/* Initialize internal POSIX module data structures and register with darshan-core. */
+static void null_runtime_initialize()
+ /* struct of function pointers for interfacing with darshan-core */
+ struct darshan_module_funcs null_mod_fns =
+ .begin_shutdown = &null_begin_shutdown,
+ .setup_reduction = NULL, /* "NULL" module does not do reductions */
+ .record_reduction_op = NULL, /* "NULL" module does not do reductions */
+ .get_output_data = &null_get_output_data,
+ .shutdown = &null_shutdown
+ int mem_limit; /* max. memory this module can consume, dictated by darshan-core */
+ /* don't do anything if already initialized or instrumenation is disabled */
+ if(null_runtime || instrumentation_disabled)
+ return;
+ /* register the "NULL" module with the darshan-core component */
+ darshan_core_register_module(
+ DARSHAN_NULL_MOD, /* Darshan module identifier, defined in darshan-log-format.h */
+ &null_mod_fns,
+ &mem_limit,
+ NULL);
+ /* return if no memory assigned by darshan-core */
+ if(mem_limit == 0)
+ return;
+ /* initialize module's global state */
+ null_runtime = malloc(sizeof(*null_runtime));
+ if(!null_runtime)
+ return;
+ memset(null_runtime, 0, sizeof(*null_runtime));
+ /* Set the maximum number of data records this module may track, as indicated
+ * by mem_limit (set by darshan-core).
+ * NOTE: We interpret the maximum memory limit to be related to the maximum
+ * amount of data which may be written to log by a single process for a given
+ * module. We therefore use this maximum memory limit to determine how many
+ * darshan_null_record structures we can track per process.
+ null_runtime->rec_array_size = mem_limit / sizeof(struct darshan_null_record);
+ null_runtime->rec_array_ndx = 0;
+ /* allocate both record arrays (runtime and high-level records) */
+ null_runtime->runtime_record_array = malloc(null_runtime->rec_array_size *
+ sizeof(struct null_record_runtime));
+ null_runtime->record_array = malloc(null_runtime->rec_array_size *
+ sizeof(struct darshan_null_record));
+ if(!null_runtime->runtime_record_array || !null_runtime->record_array)
+ null_runtime->rec_array_size = 0;
+ return;
+ memset(null_runtime->runtime_record_array, 0, null_runtime->rec_array_size *
+ memset(null_runtime->record_array, 0, null_runtime->rec_array_size *
+ /* TODO: we should move this out of here.. perhaps register_module returns rank? */
+ DARSHAN_MPI_CALL(PMPI_Comm_rank)(MPI_COMM_WORLD, &my_rank);
+ return;
+/* Search for and return a "NULL" module record corresponding to name parameter. */
+ struct null_record_runtime *rec = NULL;
+ darshan_record_id rec_id;
+ /* Don't search for a record if the "NULL" module is not initialized or
+ * if instrumentation has been toggled off.
+ if(!null_runtime || instrumentation_disabled)
+ return(NULL);
+ /* get a unique record identifier for this record from darshan-core */
+ darshan_core_register_record(
+ (void*)name,
+ strlen(name),
+ 1,
+ DARSHAN_NULL_MOD,
+ &rec_id,
+ NULL);
+ /* search the hash table for this file record, and return if found */
+ HASH_FIND(hlink, null_runtime->record_hash, &rec_id, sizeof(darshan_record_id), rec);
+ if(rec)
+ return(rec);
+ if(null_runtime->rec_array_ndx < null_runtime->rec_array_size);
+ /* no existing record, assign a new one from the global array */
+ rec = &(null_runtime->runtime_record_array[null_runtime->rec_array_ndx]);
+ rec->record_p = &(null_runtime->record_array[null_runtime->rec_array_ndx]);
+ /* set the darshan record id and corresponding process rank for this record */
+ rec->record_p->f_id = rec_id;
+ rec->record_p->rank = my_rank;
+ /* add new record to file hash table */
+ HASH_ADD(hlink, null_runtime->record_hash, record_p->f_id, sizeof(darshan_record_id), rec);
+ null_runtime->rec_array_ndx++;
+ return(rec);
+ * Functions exported by the "NULL" module for coordinating with darshan-core *
+/* Perform any necessary steps prior to shutting down for the "NULL" module. */
+static void null_begin_shutdown()
+ assert(null_runtime);
+ NULL_LOCK();
+ /* In general, we want to disable all wrappers while Darshan shuts down.
+ * This is to avoid race conditions and ensure data consistency, as
+ * executing wrappers could potentially modify module state while Darshan
+ * is in the process of shutting down.
+ instrumentation_disabled = 1;
+ /* ... any other code which needs to be executed before beginning shutdown process ... */
+ NULL_UNLOCK();
+ return;
+/* Pass output data for the "NULL" module back to darshan-core to log to file. */
+ void **buffer,
+ int *size)
+ /* Just set the output buffer to point at the array of the "NULL" module's
+ * I/O records, and set the output size according to the number of records
+ * currently being tracked.
+ *buffer = (void *)(null_runtime->record_array);
+ *size = null_runtime->rec_array_ndx * sizeof(struct darshan_null_record);
+ return;
+/* Shutdown the "NULL" module by freeing up all data structures. */
+static void null_shutdown()
+ HASH_CLEAR(hlink, null_runtime->record_hash); /* these hash entries are freed all at once below */
+ free(null_runtime->runtime_record_array);
+ free(null_runtime->record_array);
+ free(null_runtime);
+ null_runtime = NULL;
+ return;
+ * Local variables:
+ * c-indent-level: 4
+ * c-basic-offset: 4
+ * End:
+ * vim: ts=8 sts=4 sw=4 expandtab
diff --git a/darshan-runtime/lib/darshan-posix.c b/darshan-runtime/lib/darshan-posix.c
index a647f0e..c66a118 100644
--- a/darshan-runtime/lib/darshan-posix.c
+++ b/darshan-runtime/lib/darshan-posix.c
@@ -215,9 +215,9 @@ static void posix_walk_file_accesses(void);
static int posix_access_compare(const void* a_p, const void* b_p);
static int posix_file_compare(const void* a, const void* b);
-static void posix_disable_instrumentation(void);
-static void posix_prepare_for_reduction(darshan_record_id *shared_recs,
- int *shared_rec_count, void **send_buf, void **recv_buf, int *rec_size);
+static void posix_begin_shutdown(void);
+static void posix_setup_reduction(darshan_record_id *shared_recs, int *shared_rec_count,
+ void **send_buf, void **recv_buf, int *rec_size);
static void posix_record_reduction_op(void* infile_v, void* inoutfile_v,
static void posix_get_output_data(void **buffer, int *size);
@@ -1295,8 +1295,8 @@ static void posix_runtime_initialize()
int mem_limit;
struct darshan_module_funcs posix_mod_fns =
- .disable_instrumentation = &posix_disable_instrumentation,
- .prepare_for_reduction = &posix_prepare_for_reduction,
+ .begin_shutdown = &posix_begin_shutdown,
+ .setup_reduction = &posix_setup_reduction,
.record_reduction_op = &posix_record_reduction_op,
.get_output_data = &posix_get_output_data,
.shutdown = &posix_shutdown
@@ -1627,21 +1627,25 @@ static int posix_file_compare(const void* a_p, const void* b_p)
* Functions exported by this module for coordinating with darshan-core *
-static void posix_disable_instrumentation()
+static void posix_begin_shutdown()
assert(posix_runtime);
POSIX_LOCK();
+ /* go through file access data for each record and set the 4 most common
+ * stride/access size counters.
posix_walk_file_accesses();
+ /* disable further instrumentation while Darshan shuts down */
POSIX_UNLOCK();
return;
void **send_buf,
@@ -1980,6 +1984,8 @@ static void posix_shutdown()
struct posix_file_runtime_ref *ref, *tmp;
+ assert(posix_runtime);
HASH_ITER(hlink, posix_runtime->fd_hash, ref, tmp)
HASH_DELETE(hlink, posix_runtime->fd_hash, ref);
diff --git a/darshan-runtime/utlist.h b/darshan-runtime/utlist.h
index 0000000..35fc9db
--- /dev/null
+++ b/darshan-runtime/utlist.h
@@ -0,0 +1,490 @@
+Copyright (c) 2007-2010, Troy D. Hanson http://uthash.sourceforge.net
+All rights reserved.
+Redistribution and use in source and binary forms, with or without
+modification, are permitted provided that the following conditions are met:
+ * Redistributions of source code must retain the above copyright
+ notice, this list of conditions and the following disclaimer.
+THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS
+IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
+TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
+PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER
+OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
+EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
+PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR
+PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF
+LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING
+NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
+SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
+#ifndef UTLIST_H
+#define UTLIST_H
+#define UTLIST_VERSION 1.9.1
+ * This file contains macros to manipulate singly and doubly-linked lists.
+ * 1. LL_ macros: singly-linked lists.
+ * 2. DL_ macros: doubly-linked lists.
+ * 3. CDL_ macros: circular doubly-linked lists.
+ * To use singly-linked lists, your structure must have a "next" pointer.
+ * To use doubly-linked lists, your structure must "prev" and "next" pointers.
+ * Either way, the pointer to the head of the list must be initialized to NULL.
+ * ----------------.EXAMPLE -------------------------
+ * struct item {
+ * int id;
+ * struct item *prev, *next;
+ * struct item *list = NULL:
+ * int main() {
+ * struct item *item;
+ * ... allocate and populate item ...
+ * DL_APPEND(list, item);
+ * For doubly-linked lists, the append and delete macros are O(1)
+ * For singly-linked lists, append and delete are O(n) but prepend is O(1)
+ * The sort macro is O(n log(n)) for all types of single/double/circular lists.
+/* These macros use decltype or the earlier __typeof GNU extension.
+ As decltype is only available in newer compilers (VS2010 or gcc 4.3+
+ when compiling c++ code), this code uses whatever method is needed
+ or, for VS2008 where neither is available, uses casting workarounds. */
+#ifdef _MSC_VER /* MS compiler */
+#if _MSC_VER >= 1600 && __cplusplus /* VS2010 and newer in C++ mode */
+#define LDECLTYPE(x) decltype(x)
+#else /* VS2008 or older (or VS2010 in C mode) */
+#define NO_DECLTYPE
+#define LDECLTYPE(x) char*
+#endif
+#else /* GNU, Sun and other compilers */
+#define LDECLTYPE(x) __typeof(x)
+#endif
+/* for VS2008 we use some workarounds to get around the lack of decltype,
+ * namely, we always reassign our tmp variable to the list head if we need
+ * to dereference its prev/next pointers, and save/restore the real head.*/
+#ifdef NO_DECLTYPE
+#define _SV(elt,list) _tmp = (char*)(list); {char **_alias = (char**)&(list); *_alias = (elt); }
+#define _NEXT(elt,list) ((char*)((list)->next))
+#define _NEXTASGN(elt,list,to) { char **_alias = (char**)&((list)->next); *_alias=(char*)(to); }
+#define _PREV(elt,list) ((char*)((list)->prev))
+#define _PREVASGN(elt,list,to) { char **_alias = (char**)&((list)->prev); *_alias=(char*)(to); }
+#define _RS(list) { char **_alias = (char**)&(list); *_alias=_tmp; }
+#define _CASTASGN(a,b) { char **_alias = (char**)&(a); *_alias=(char*)(b); }
+#else
+#define _NEXT(elt,list) ((elt)->next)
+#define _NEXTASGN(elt,list,to) ((elt)->next)=(to)
+#define _PREV(elt,list) ((elt)->prev)
+#define _PREVASGN(elt,list,to) ((elt)->prev)=(to)
+#define _RS(list)
+#define _CASTASGN(a,b) (a)=(b)
+#endif
+ * The sort macro is an adaptation of Simon Tatham's O(n log(n)) mergesort *
+ * Unwieldy variable names used here to avoid shadowing passed-in variables. *
+#define LL_SORT(list, cmp) \
+do { \
+ LDECLTYPE(list) _ls_p; \
+ LDECLTYPE(list) _ls_q; \
+ LDECLTYPE(list) _ls_e; \
+ LDECLTYPE(list) _ls_tail; \
+ LDECLTYPE(list) _ls_oldhead; \
+ LDECLTYPE(list) _tmp; \
+ int _ls_insize, _ls_nmerges, _ls_psize, _ls_qsize, _ls_i, _ls_looping; \
+ if (list) { \
+ _ls_insize = 1; \
+ _ls_looping = 1; \
+ while (_ls_looping) { \
+ _CASTASGN(_ls_p,list); \
+ _CASTASGN(_ls_oldhead,list); \
+ list = NULL; \
+ _ls_tail = NULL; \
+ _ls_nmerges = 0; \
+ while (_ls_p) { \
+ _ls_nmerges++; \
+ _ls_q = _ls_p; \
+ _ls_psize = 0; \
+ for (_ls_i = 0; _ls_i < _ls_insize; _ls_i++) { \
+ _ls_psize++; \
+ _SV(_ls_q,list); _ls_q = _NEXT(_ls_q,list); _RS(list); \
+ if (!_ls_q) break; \
+ _ls_qsize = _ls_insize; \
+ while (_ls_psize > 0 || (_ls_qsize > 0 && _ls_q)) { \
+ if (_ls_psize == 0) { \
+ _ls_e = _ls_q; _SV(_ls_q,list); _ls_q = _NEXT(_ls_q,list); _RS(list); _ls_qsize--; \
+ } else if (_ls_qsize == 0 || !_ls_q) { \
+ _ls_e = _ls_p; _SV(_ls_p,list); _ls_p = _NEXT(_ls_p,list); _RS(list); _ls_psize--; \
+ } else if (cmp(_ls_p,_ls_q) <= 0) { \
+ } else { \
+ if (_ls_tail) { \
+ _SV(_ls_tail,list); _NEXTASGN(_ls_tail,list,_ls_e); _RS(list); \
+ } else { \
+ _CASTASGN(list,_ls_e); \
+ _ls_tail = _ls_e; \
+ _ls_p = _ls_q; \
+ _SV(_ls_tail,list); _NEXTASGN(_ls_tail,list,NULL); _RS(list); \
+ if (_ls_nmerges <= 1) { \
+ _ls_looping=0; \
+ _ls_insize *= 2; \
+ } else _tmp=NULL; /* quiet gcc unused variable warning */ \
+} while (0)
+#define DL_SORT(list, cmp) \
+do { \
+ if (list) { \
+ _ls_insize = 1; \
+ list = NULL; \
+ while (_ls_p) { \
+ _ls_nmerges++; \
+ _ls_q = _ls_p; \
+ _ls_psize = 0; \
+ _ls_psize++; \
+ } else { \
+ if (_ls_tail) { \
+ } else { \
+ _SV(_ls_e,list); _PREVASGN(_ls_e,list,_ls_tail); _RS(list); \
+ _ls_p = _ls_q; \
+ _CASTASGN(list->prev, _ls_tail); \
+ _ls_looping=0; \
+} while (0)
+#define CDL_SORT(list, cmp) \
+do { \
+ LDECLTYPE(list) _tmp2; \
+ if (list) { \
+ _ls_insize = 1; \
+ list = NULL; \
+ while (_ls_p) { \
+ _ls_nmerges++; \
+ _ls_q = _ls_p; \
+ _ls_psize = 0; \
+ _ls_psize++; \
+ _SV(_ls_q,list); \
+ if (_NEXT(_ls_q,list) == _ls_oldhead) { \
+ _ls_q = NULL; \
+ } else { \
+ _ls_q = _NEXT(_ls_q,list); \
+ _RS(list); \
+ if (_ls_q == _ls_oldhead) { _ls_q = NULL; } \
+ if (_ls_p == _ls_oldhead) { _ls_p = NULL; } \
+ } else { \
+ if (_ls_tail) { \
+ } else { \
+ _ls_p = _ls_q; \
+ _CASTASGN(list->prev,_ls_tail); \
+ _CASTASGN(_tmp2,list); \
+ _SV(_ls_tail,list); _NEXTASGN(_ls_tail,list,_tmp2); _RS(list); \
+ _ls_looping=0; \
+} while (0)
+ * singly linked list macros (non-circular) *
+#define LL_PREPEND(head,add) \
+do { \
+ (add)->next = head; \
+ head = add; \
+} while (0)
+#define LL_APPEND(head,add) \
+do { \
+ LDECLTYPE(head) _tmp; \
+ (add)->next=NULL; \
+ if (head) { \
+ _tmp = head; \
+ while (_tmp->next) { _tmp = _tmp->next; } \
+ _tmp->next=(add); \
+ } else { \
+ (head)=(add); \
+} while (0)
+#define LL_DELETE(head,del) \
+do { \
+ if ((head) == (del)) { \
+ (head)=(head)->next; \
+ } else { \
+ _tmp = head; \
+ while (_tmp->next && (_tmp->next != (del))) { \
+ _tmp = _tmp->next; \
+ if (_tmp->next) { \
+ _tmp->next = ((del)->next); \
+} while (0)
+/* Here are VS2008 replacements for LL_APPEND and LL_DELETE */
+#define LL_APPEND_VS2008(head,add) \
+do { \
+ if (head) { \
+ (add)->next = head; /* use add->next as a temp variable */ \
+ while ((add)->next->next) { (add)->next = (add)->next->next; } \
+ (add)->next->next=(add); \
+ } else { \
+ (head)=(add); \
+} while (0)
+#define LL_DELETE_VS2008(head,del) \
+do { \
+ } else { \
+ char *_tmp = (char*)(head); \
+ while (head->next && (head->next != (del))) { \
+ head = head->next; \
+ if (head->next) { \
+ head->next = ((del)->next); \
+ char **_head_alias = (char**)&(head); \
+ *_head_alias = _tmp; \
+} while (0)
+#ifdef NO_DECLTYPE
+#undef LL_APPEND
+#define LL_APPEND LL_APPEND_VS2008
+#undef LL_DELETE
+#define LL_DELETE LL_DELETE_VS2008
+#endif
+/* end VS2008 replacements */
+#define LL_FOREACH(head,el) \
+ for(el=head;el;el=el->next)
+#define LL_FOREACH_SAFE(head,el,tmp) \
+ for((el)=(head);(el) && (tmp = (el)->next, 1); (el) = tmp)
+#define LL_SEARCH_SCALAR(head,out,field,val) \
+do { \
+ LL_FOREACH(head,out) { \
+ if ((out)->field == (val)) break; \
+} while(0)
+#define LL_SEARCH(head,out,elt,cmp) \
+do { \
+ if ((cmp(out,elt))==0) break; \
+} while(0)
+ * doubly linked list macros (non-circular) *
+#define DL_PREPEND(head,add) \
+do { \
+ if (head) { \
+ (add)->prev = (head)->prev; \
+ (head)->prev = (add); \
+ } else { \
+ (add)->prev = (add); \
+ (head) = (add); \
+} while (0)
+#define DL_APPEND(head,add) \
+do { \
+ if (head) { \
+ (head)->prev->next = (add); \
+ (add)->next = NULL; \
+ } else { \
+ (head)=(add); \
+ (head)->prev = (head); \
+ (head)->next = NULL; \
+} while (0);
+#define DL_DELETE(head,del) \
+do { \
+ if ((del)->prev == (del)) { \
+ (head)=NULL; \
+ } else if ((del)==(head)) { \
+ (del)->next->prev = (del)->prev; \
+ (head) = (del)->next; \
+ } else { \
+ (del)->prev->next = (del)->next; \
+ if ((del)->next) { \
+ } else { \
+ (head)->prev = (del)->prev; \
+} while (0);
+#define DL_FOREACH(head,el) \
+/* this version is safe for deleting the elements during iteration */
+#define DL_FOREACH_SAFE(head,el,tmp) \
+/* these are identical to their singly-linked list counterparts */
+#define DL_SEARCH_SCALAR LL_SEARCH_SCALAR
+#define DL_SEARCH LL_SEARCH
+ * circular doubly linked list macros *
+#define CDL_PREPEND(head,add) \
+do { \
+ if (head) { \
+ (add)->next = (head); \
+ (add)->prev->next = (add); \
+ } else { \
+ (add)->next = (add); \
+(head)=(add); \
+} while (0)
+#define CDL_DELETE(head,del) \
+do { \
+ if ( ((head)==(del)) && ((head)->next == (head))) { \
+ (head) = 0L; \
+ } else { \
+ if ((del) == (head)) (head)=(del)->next; \
+} while (0);
+#define CDL_FOREACH(head,el) \
+ for(el=head;el;el=(el->next==head ? 0L : el->next))
+#define CDL_FOREACH_SAFE(head,el,tmp1,tmp2) \
+ for((el)=(head), ((tmp1)=(head)?((head)->prev):NULL); \
+ (el) && ((tmp2)=(el)->next, 1); \
+ ((el) = (((el)==(tmp1)) ? 0L : (tmp2))))
+#define CDL_SEARCH_SCALAR(head,out,field,val) \
+do { \
+ CDL_FOREACH(head,out) { \
+} while(0)
+#define CDL_SEARCH(head,out,elt,cmp) \
+do { \
+} while(0)
+#endif /* UTLIST_H */
diff --git a/doc/darshan-modularization.txt b/doc/darshan-modularization.txt
index 40a70f6..693e55a 100644
--- a/doc/darshan-modularization.txt
+++ b/doc/darshan-modularization.txt
@@ -6,11 +6,6 @@ Darshan modularization branch development notes
Darshan is a lightweight toolkit for characterizing the I/O performance of instrumented
HPC applications.
-Darshan was originally designed to gather I/O data from a static set of sources.
-Adding instrumentation for additional sources of I/O data was only possible through
-manual modification of the Darshan log file format, which consequentially breaks
-any other utilities reliant on that format.
Starting with version 3.0.0, the Darshan runtime environment and log file format have
been redesigned such that new "instrumentation modules" can be added without breaking
existing tools. Developers are given a framework to implement arbitrary instrumentation
@@ -52,6 +47,8 @@ applications and generating I/O characterization logs.
* *darshan-util*: Darshan utilities for analyzing the contents of a given Darshan
I/O characterization log.
The following subsections provide an overview of each of these components with specific
attention to how new instrumentation modules may be integrated into Darshan.
hooks/post-receive
More information about the Darshan-commits
