[Darshan-commits] [Darshan] branch, dev-modular, updated. darshan-2.3.1-94-gcc000cb
Service Account git at mcs.anl.gov
Mon Apr 6 16:27:00 CDT 2015
This is an automated email from the git hooks/post-receive script. It was
generated because a ref change was pushed to the repository containing
the project "".
The branch, dev-modular has been updated
       via  cc000cb3d4f478a614c4115c193fc10ff0e83b59 (commit)
      from  f18d0c3f6b375e058d404f686f4f76324c6f805a (commit)
Those revisions listed above that are new to this repository have
not appeared on any other notification email; so we list those
revisions in full, below.
- Log -----------------------------------------------------------------
commit cc000cb3d4f478a614c4115c193fc10ff0e83b59
Author: Phil Carns <carns at mcs.anl.gov>
Date:   Mon Apr 6 17:26:53 2015 -0400
    stub in reduction op for mpiio
Summary of changes:
 darshan-runtime/lib/darshan-mpiio.c |   54 ++++++++++++++++++++++++++++++++++-
 1 files changed, 53 insertions(+), 1 deletions(-)
Diff of changes:
diff --git a/darshan-runtime/lib/darshan-mpiio.c b/darshan-runtime/lib/darshan-mpiio.c
index 7dd4b74..98eb024 100644
--- a/darshan-runtime/lib/darshan-mpiio.c
+++ b/darshan-runtime/lib/darshan-mpiio.c
@@ -121,6 +121,8 @@ static void mpiio_get_output_data(
     int *size);
 static struct mpiio_file_runtime* mpiio_file_by_name_setfh(const char* name, MPI_File *fh);
 static struct mpiio_file_runtime* mpiio_file_by_name(const char *name);
+static void mpiio_record_reduction_op(void* infile_v, void* inoutfile_v,
+    int *len, MPI_Datatype *datatype);
 #ifdef HAVE_MPIIO_CONST
 int MPI_File_open(MPI_Comm comm, const char *filename, int amode, MPI_Info info, MPI_File *fh)
@@ -189,7 +191,7 @@ static void mpiio_runtime_initialize()
         .disable_instrumentation = &mpiio_disable_instrumentation,
         .prepare_for_reduction = NULL,
-        .record_reduction_op = NULL,
+        .record_reduction_op = &mpiio_record_reduction_op,
         .get_output_data = &mpiio_get_output_data,
         .shutdown = &mpiio_shutdown
@@ -378,6 +380,56 @@ static struct mpiio_file_runtime* mpiio_file_by_name_setfh(const char* name, MPI
     return(file);
+    void* infile_v,
+    void* inoutfile_v,
+    int *len,
+    MPI_Datatype *datatype)
+    struct darshan_mpiio_file tmp_file;
+    struct darshan_mpiio_file *infile = infile_v;
+    struct darshan_mpiio_file *inoutfile = inoutfile_v;
+    int i, j;
+    assert(mpiio_runtime);
+    for(i=0; i<*len; i++)
+        memset(&tmp_file, 0, sizeof(struct darshan_mpiio_file));
+        tmp_file.f_id = infile->f_id;
+        tmp_file.rank = -1;
+        /* sum */
+        for(j=DARSHAN_MPIIO_INDEP_OPENS; j<=DARSHAN_MPIIO_HINTS; j++)
+            tmp_file.counters[j] = infile->counters[j] + inoutfile->counters[j];
+        /* sum (floating point) */
+        for(j=DARSHAN_MPIIO_F_META_TIME; j<=DARSHAN_MPIIO_F_META_TIME; j++)
+            tmp_file.fcounters[j] = infile->fcounters[j] + inoutfile->fcounters[j];
+        /* min non-zero (if available) value */
+        for(j=DARSHAN_MPIIO_F_OPEN_TIMESTAMP; j<=DARSHAN_MPIIO_F_OPEN_TIMESTAMP; j++)
+            if(infile->fcounters[j] > inoutfile->fcounters[j] && inoutfile->fcounters[j] > 0)
+                tmp_file.fcounters[j] = inoutfile->fcounters[j];
+            else
+                tmp_file.fcounters[j] = infile->fcounters[j];
+        /* update pointers */
+        *inoutfile = tmp_file;
+        inoutfile++;
+        infile++;
+    return;
  * Local variables:
  *  c-indent-level: 4
hooks/post-receive
More information about the Darshan-commits mailing list
