[Darshan-commits] [Darshan] branch, dev-modular, updated. darshan-2.3.1-79-g8a1f77e
Service Account git at mcs.anl.gov
Wed Apr 1 11:41:10 CDT 2015
This is an automated email from the git hooks/post-receive script. It was
generated because a ref change was pushed to the repository containing
the project "".
The branch, dev-modular has been updated
       via  8a1f77e3eb293eabe336194b279ee96c7130db6c (commit)
      from  905e0ac4cccc3cee2bf5324b572799ce64a9c8ec (commit)
Those revisions listed above that are new to this repository have
not appeared on any other notification email; so we list those
revisions in full, below.
- Log -----------------------------------------------------------------
commit 8a1f77e3eb293eabe336194b279ee96c7130db6c
Author: Phil Carns <carns at mcs.anl.gov>
Date:   Wed Apr 1 11:40:58 2015 -0500
    carry over file ref comments to mpiio mod
Summary of changes:
 darshan-runtime/lib/darshan-mpiio.c |   50 +++++++++++++++++++++++++++++++++++
 1 files changed, 50 insertions(+), 0 deletions(-)
Diff of changes:
diff --git a/darshan-runtime/lib/darshan-mpiio.c b/darshan-runtime/lib/darshan-mpiio.c
index 76a1bb1..5548fb5 100644
--- a/darshan-runtime/lib/darshan-mpiio.c
+++ b/darshan-runtime/lib/darshan-mpiio.c
@@ -28,12 +28,62 @@
 #include "darshan.h"
 #include "darshan-mpiio-log-format.h"
+/* The mpiio_file_runtime structure maintains necessary runtime metadata
+ * for the MPIIO file record (darshan_mpiio_file structure, defined in
+ * darshan-mpiio-log-format.h) pointed to by 'file_record'. This metadata
+ * assists with the instrumenting of specific statistics in the file record.
+ * 'hlink' is a hash table link structure used to add/remove this record
+ * from the hash table of MPIIO file records for this process.
+ * RATIONALE: the MPIIO module needs to track some stateful, volatile
+ * information about each open file (like the current file offset, most recent
+ * access time, etc.) to aid in instrumentation, but this information can't be
+ * stored in the darshan_mpiio_file struct because we don't want it to appear in
+ * the final darshan log file.  We therefore associate a mpiio_file_runtime
+ * struct with each darshan_mpiio_file struct in order to track this information.
+ * NOTE: There is a one-to-one mapping of mpiio_file_runtime structs to
+ * darshan_mpiio_file structs.
+ * NOTE: The mpiio_file_runtime struct contains a pointer to a darshan_mpiio_file
+ * struct (see the *file_record member) rather than simply embedding an entire
+ * darshan_mpiio_file struct.  This is done so that all of the darshan_mpiio_file
+ * structs can be kept contiguous in memory as a single array to simplify
+ * reduction, compression, and storage.
 struct mpiio_runtime_file
     struct darshan_mpiio_file* file_record;
+    /* TODO: any stateful (but not intended for persistent storage in the log)
+     * information about MPI-IO access.  If we don't have any then this struct
+     * could be eliminated.
     UT_hash_handle hlink;
+/* The mpiio_file_runtime_ref structure is used to associate a MPIIO
+ * file handle with an already existing MPIIO file record. This is
+ * necessary as many MPIIO I/O functions take only a file handle as input,
+ * but MPIIO file records are indexed by their full file paths (i.e., darshan
+ * record identifiers for MPIIO files are created by hashing the file path).
+ * In other words, this structure is necessary as it allows us to look up a
+ * file record either by a pathname (mpiio_file_runtime) or by MPIIO file
+ * descriptor (mpiio_file_runtime_ref), depending on which parameters are
+ * available. This structure includes another hash table link, since separate
+ * hashes are maintained for mpiio_file_runtime structures and mpiio_file_runtime_ref
+ * structures.
+ * RATIONALE: In theory the file handle information could be included in the
+ * mpiio_file_runtime struct rather than in a separate structure here.  The
+ * reason we don't do that is to handle the potential for an MPI implementation
+ * to produce a new file handle instance each time MPI_File_open() is called on a
+ * file.  Thus there might be multiple file handles referring to the same
+ * underlying record.
+ * NOTE: there are potentially multiple mpiio_file_runtime_ref structures
+ * referring to a single mpiio_file_runtime structure.  Most of the time there is
+ * only one, however.
 struct mpiio_runtime_file_ref
     struct mpiio_runtime_file* file;
hooks/post-receive
More information about the Darshan-commits mailing list
