[Darshan-commits] [Darshan] branch, master, updated. 9edc0d7106241592423c26693314a7e7f619b23a
Service Account
git at mcs.anl.gov
Fri Oct 24 16:18:05 CDT 2014
This is an automated email from the git hooks/post-receive script. It was
generated because a ref change was pushed to the repository containing
the project "".
The branch, master has been updated
via 9edc0d7106241592423c26693314a7e7f619b23a (commit)
via a61bba43ac6368d4192739419c2b49a40e10f77c (commit)
via 58889f88ddfb049dc72441a2c640be805b3832dc (commit)
from ff60981bc60776e2cb572a66f30f3e36d0f6c426 (commit)
Those revisions listed above that are new to this repository have
not appeared on any other notification email; so we list those
revisions in full, below.
- Log -----------------------------------------------------------------
commit 9edc0d7106241592423c26693314a7e7f619b23a
Author: Phil Carns <carns at mcs.anl.gov>
Date: Fri Oct 24 17:17:57 2014 -0400
attribution in Changelog
commit a61bba43ac6368d4192739419c2b49a40e10f77c
Date: Fri Oct 24 17:16:51 2014 -0400
update Changelog for zlib autoconf fix
commit 58889f88ddfb049dc72441a2c640be805b3832dc
Date: Fri Oct 24 17:16:18 2014 -0400
simplify zlib m4 check
- zlib is mandatory now
Summary of changes:
ChangeLog | 3 +
darshan-runtime/configure | 206 +++++++++++++-------------------------------
darshan-util/configure | 206 +++++++++++++-------------------------------
maint/config/check_zlib.m4 | 74 ++--------------
4 files changed, 129 insertions(+), 360 deletions(-)
Diff of changes:
diff --git a/ChangeLog b/ChangeLog
index da767e9..505cce7 100644
--- a/ChangeLog
+++ b/ChangeLog
@@ -5,6 +5,7 @@ Darshan Release Change Log
darshan-2.3.1-pre1
* Add wrappers for mkstemp(), mkostemp(), mkstemps(), and mkostemps()
+ (reported by Tom Peterka)
* Change OPEN_TIMESTAMP field to report timestamp right before open() is
invoked rather than after timestamp after open is completed.
NOTE: updated log format version to 2.06 to reflect this change.
@@ -12,6 +13,8 @@ darshan-2.3.1-pre1
(respectively) across all ranks
* Fix bug in write volume data reported in file system table in
darshan-job-summary.pl (reported by Matthieu Dorier)
+* Clean up autoconf test for zlib and make zlib mandatory (reported by Kalyana
+ Chadalavada)
darshan-2.3.0
diff --git a/darshan-runtime/configure b/darshan-runtime/configure
index 3b2e305..26f0244 100755
--- a/darshan-runtime/configure
+++ b/darshan-runtime/configure
@@ -1460,52 +1460,6 @@ fi
} # ac_fn_c_try_compile
-# ac_fn_c_try_link LINENO
-# Try to link conftest.$ac_ext, and return whether this succeeded.
-ac_fn_c_try_link ()
- as_lineno=${as_lineno-"$1"} as_lineno_stack=as_lineno_stack=$as_lineno_stack
- rm -f conftest.$ac_objext conftest$ac_exeext
- if { { ac_try="$ac_link"
-case "(($ac_try" in
- *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;;
- *) ac_try_echo=$ac_try;;
-esac
-eval ac_try_echo="\"\$as_me:${as_lineno-$LINENO}: $ac_try_echo\""
-$as_echo "$ac_try_echo"; } >&5
- (eval "$ac_link") 2>conftest.err
- ac_status=$?
- if test -s conftest.err; then
- grep -v '^ *+' conftest.err >conftest.er1
- cat conftest.er1 >&5
- mv -f conftest.er1 conftest.err
- fi
- $as_echo "$as_me:${as_lineno-$LINENO}: \$? = $ac_status" >&5
- test $ac_status = 0; } && {
- test -z "$ac_c_werror_flag" ||
- test ! -s conftest.err
- } && test -s conftest$ac_exeext && {
- test "$cross_compiling" = yes ||
- test -x conftest$ac_exeext
- }; then :
- ac_retval=0
-else
- $as_echo "$as_me: failed program was:" >&5
-sed 's/^/| /' conftest.$ac_ext >&5
- ac_retval=1
-fi
- # Delete the IPA/IPO (Inter Procedural Analysis/Optimization) information
- # created by the PGI compiler (conftest_ipa8_conftest.oo), as it would
- # interfere with the next link command; also delete a directory that is
- # left behind by Apple's compiler. We do this before executing the actions.
- rm -rf conftest.dSYM conftest_ipa8_conftest.oo
- eval $as_lineno_stack; ${as_lineno_stack:+:} unset as_lineno
- as_fn_set_status $ac_retval
-} # ac_fn_c_try_link
# ac_fn_c_try_cpp LINENO
# Try to preprocess conftest.$ac_ext, and return whether this succeeded.
@@ -1703,6 +1657,52 @@ $as_echo "$ac_res" >&6; }
} # ac_fn_c_check_header_compile
+# ac_fn_c_try_link LINENO
+# Try to link conftest.$ac_ext, and return whether this succeeded.
+ac_fn_c_try_link ()
+ as_lineno=${as_lineno-"$1"} as_lineno_stack=as_lineno_stack=$as_lineno_stack
+ rm -f conftest.$ac_objext conftest$ac_exeext
+ if { { ac_try="$ac_link"
+case "(($ac_try" in
+ *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;;
+ *) ac_try_echo=$ac_try;;
+esac
+eval ac_try_echo="\"\$as_me:${as_lineno-$LINENO}: $ac_try_echo\""
+$as_echo "$ac_try_echo"; } >&5
+ (eval "$ac_link") 2>conftest.err
+ ac_status=$?
+ if test -s conftest.err; then
+ grep -v '^ *+' conftest.err >conftest.er1
+ cat conftest.er1 >&5
+ mv -f conftest.er1 conftest.err
+ fi
+ $as_echo "$as_me:${as_lineno-$LINENO}: \$? = $ac_status" >&5
+ test $ac_status = 0; } && {
+ test -z "$ac_c_werror_flag" ||
+ test ! -s conftest.err
+ } && test -s conftest$ac_exeext && {
+ test "$cross_compiling" = yes ||
+ test -x conftest$ac_exeext
+ }; then :
+ ac_retval=0
+else
+ $as_echo "$as_me: failed program was:" >&5
+sed 's/^/| /' conftest.$ac_ext >&5
+ ac_retval=1
+fi
+ # Delete the IPA/IPO (Inter Procedural Analysis/Optimization) information
+ # created by the PGI compiler (conftest_ipa8_conftest.oo), as it would
+ # interfere with the next link command; also delete a directory that is
+ # left behind by Apple's compiler. We do this before executing the actions.
+ rm -rf conftest.dSYM conftest_ipa8_conftest.oo
+ eval $as_lineno_stack; ${as_lineno_stack:+:} unset as_lineno
+ as_fn_set_status $ac_retval
+} # ac_fn_c_try_link
# ac_fn_c_check_type LINENO TYPE VAR INCLUDES
# Tests whether TYPE exists after having included INCLUDES, setting cache
@@ -3455,109 +3455,38 @@ fi
done
-# Handle user hints
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking if zlib is wanted" >&5
-$as_echo_n "checking if zlib is wanted... " >&6; }
# Check whether --with-zlib was given.
if test "${with_zlib+set}" = set; then :
withval=$with_zlib; if test "$withval" != no ; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: yes" >&5
-$as_echo "yes" >&6; }
if test -d "$withval"
then
ZLIB_HOME="$withval"
+ LDFLAGS="$LDFLAGS -L${ZLIB_HOME}/lib"
+ CPPFLAGS="$CPPFLAGS -I${ZLIB_HOME}/include"
+ __CP_ZLIB_LINK_FLAGS="-L${ZLIB_HOME}/lib"
+ __CP_ZLIB_INCLUDE_FLAGS="-I${ZLIB_HOME}/include"
else
{ $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: Sorry, $withval does not exist, checking usual places" >&5
$as_echo "$as_me: WARNING: Sorry, $withval does not exist, checking usual places" >&2;}
fi
else
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: no" >&5
-$as_echo "no" >&6; }
+ as_fn_error $? "zlib is required" "$LINENO" 5
fi
fi
-# Locate zlib, if wanted
-if test -n "${ZLIB_HOME}"
-then
- ZLIB_OLD_LDFLAGS=$LDFLAGS
- ZLIB_OLD_CPPFLAGS=$LDFLAGS
- LDFLAGS="$LDFLAGS -L${ZLIB_HOME}/lib"
- CPPFLAGS="$CPPFLAGS -I${ZLIB_HOME}/include"
- ac_ext=c
-ac_cpp='$CPP $CPPFLAGS'
-ac_compile='$CC -c $CFLAGS $CPPFLAGS conftest.$ac_ext >&5'
-ac_link='$CC -o conftest$ac_exeext $CFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
-ac_compiler_gnu=$ac_cv_c_compiler_gnu
- { $as_echo "$as_me:${as_lineno-$LINENO}: checking for inflateEnd in -lz" >&5
-$as_echo_n "checking for inflateEnd in -lz... " >&6; }
-if ${ac_cv_lib_z_inflateEnd+:} false; then :
- $as_echo_n "(cached) " >&6
-else
- ac_check_lib_save_LIBS=$LIBS
-LIBS="-lz $LIBS"
-cat confdefs.h - <<_ACEOF >conftest.$ac_ext
-/* end confdefs.h. */
-/* Override any GCC internal prototype to avoid an error.
- Use char because int might match the return type of a GCC
- builtin and then its argument prototype would still apply. */
-#ifdef __cplusplus
-extern "C"
-#endif
-char inflateEnd ();
-int
-main ()
-return inflateEnd ();
- return 0;
-_ACEOF
-if ac_fn_c_try_link "$LINENO"; then :
- ac_cv_lib_z_inflateEnd=yes
-else
- ac_cv_lib_z_inflateEnd=no
-fi
-rm -f core conftest.err conftest.$ac_objext \
- conftest$ac_exeext conftest.$ac_ext
-LIBS=$ac_check_lib_save_LIBS
-fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_lib_z_inflateEnd" >&5
-$as_echo "$ac_cv_lib_z_inflateEnd" >&6; }
-if test "x$ac_cv_lib_z_inflateEnd" = xyes; then :
- zlib_cv_libz=yes
-else
- zlib_cv_libz=no
-fi
- ac_fn_c_check_header_mongrel "$LINENO" "zlib.h" "ac_cv_header_zlib_h" "$ac_includes_default"
+ac_fn_c_check_header_mongrel "$LINENO" "zlib.h" "ac_cv_header_zlib_h" "$ac_includes_default"
if test "x$ac_cv_header_zlib_h" = xyes; then :
- zlib_cv_zlib_h=yes
else
- zlib_cv_zlib_h=no
+ as_fn_error $? "z.h not found" "$LINENO" 5
fi
- ac_ext=c
- if test "$zlib_cv_libz" = "yes" -a "$zlib_cv_zlib_h" = "yes"
- then
- # If both library and header were found, use them
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for inflateEnd in -lz" >&5
@@ -3600,27 +3529,10 @@ _ACEOF
LIBS="-lz $LIBS"
+else
+ as_fn_error $? "libz not found" "$LINENO" 5
fi
- { $as_echo "$as_me:${as_lineno-$LINENO}: checking zlib in ${ZLIB_HOME}" >&5
-$as_echo_n "checking zlib in ${ZLIB_HOME}... " >&6; }
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: ok" >&5
-$as_echo "ok" >&6; }
- __CP_ZLIB_LINK_FLAGS="-L${ZLIB_HOME}/lib"
- __CP_ZLIB_INCLUDE_FLAGS="-I${ZLIB_HOME}/include"
- else
- # If either header or library was not found, revert and bomb
- LDFLAGS="$ZLIB_OLD_LDFLAGS"
- CPPFLAGS="$ZLIB_OLD_CPPFLAGS"
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: failed" >&5
-$as_echo "failed" >&6; }
- as_fn_error $? "either specify a valid zlib installation with --with-zlib=DIR or disable zlib usage with --without-zlib" "$LINENO" 5
- fi
-fi
diff --git a/darshan-util/configure b/darshan-util/configure
index 121df8b..ba26b81 100755
--- a/darshan-util/configure
+++ b/darshan-util/configure
@@ -1445,52 +1445,6 @@ fi
-esac
- ac_status=$?
- fi
- }; then :
- ac_retval=0
-else
- ac_retval=1
-fi
@@ -1688,6 +1642,52 @@ $as_echo "$ac_res" >&6; }
+esac
+ ac_status=$?
+ fi
+ }; then :
+ ac_retval=0
+else
+ ac_retval=1
+fi
# ac_fn_c_check_func LINENO FUNC VAR
# Tests whether FUNC exists, setting the cache variable VAR accordingly
@@ -3420,109 +3420,38 @@ fi
done
then
else
fi
else
fi
fi
-then
- ac_ext=c
-else
-LIBS="-lz $LIBS"
-#ifdef __cplusplus
-extern "C"
-#endif
-int
-main ()
- return 0;
-_ACEOF
-else
-fi
-fi
- zlib_cv_libz=yes
-else
- zlib_cv_libz=no
-fi
else
- zlib_cv_zlib_h=no
fi
- ac_ext=c
- then
@@ -3565,27 +3494,10 @@ _ACEOF
LIBS="-lz $LIBS"
+else
fi
- else
- fi
-fi
diff --git a/maint/config/check_zlib.m4 b/maint/config/check_zlib.m4
index dc39c2d..ba74736 100644
--- a/maint/config/check_zlib.m4
+++ b/maint/config/check_zlib.m4
@@ -1,84 +1,26 @@
-dnl @synopsis CHECK_ZLIB()
-dnl
-dnl This macro searches for an installed zlib library. If nothing was
-dnl specified when calling configure, it searches first in /usr/local
-dnl and then in /usr. If the --with-zlib=DIR is specified, it will try
-dnl to find it in DIR/include/zlib.h and DIR/lib/libz.a. If
-dnl --without-zlib is specified, the library is not searched at all.
-dnl
-dnl If either the header file (zlib.h) or the library (libz) is not
-dnl found, the configuration exits on error, asking for a valid zlib
-dnl installation directory or --without-zlib.
-dnl
-dnl The macro defines the symbol HAVE_LIBZ if the library is found. You
-dnl should use autoheader to include a definition for this symbol in a
-dnl config.h file. Sample usage in a C/C++ source is as follows:
-dnl
-dnl #ifdef HAVE_LIBZ
-dnl #include <zlib.h>
-dnl #endif /* HAVE_LIBZ */
-dnl
-dnl @category InstalledPackages
-dnl @author Loic Dachary <loic at senga.org>
-dnl @version 2004-09-20
-dnl @license GPLWithACException
AC_DEFUN([CHECK_ZLIB],
-[AC_MSG_CHECKING(if zlib is wanted)
AC_ARG_WITH(zlib,
[ --with-zlib=DIR root directory path of zlib installation [defaults to
/usr/local or /usr if not found in /usr/local]
--without-zlib to disable zlib usage completely],
[if test "$withval" != no ; then
- AC_MSG_RESULT(yes)
then
else
AC_MSG_WARN([Sorry, $withval does not exist, checking usual places])
fi
else
- AC_MSG_RESULT(no)
+ AC_MSG_ERROR(zlib is required)
fi])
-then
- AC_LANG_SAVE
- AC_LANG_C
- AC_CHECK_LIB(z, inflateEnd, [zlib_cv_libz=yes], [zlib_cv_libz=no])
- AC_CHECK_HEADER(zlib.h, [zlib_cv_zlib_h=yes], [zlib_cv_zlib_h=no])
- AC_LANG_RESTORE
- then
- AC_CHECK_LIB(z, inflateEnd)
- AC_MSG_CHECKING(zlib in ${ZLIB_HOME})
- AC_MSG_RESULT(ok)
- else
- AC_MSG_RESULT(failed)
- AC_MSG_ERROR(either specify a valid zlib installation with --with-zlib=DIR or disable zlib usage with --without-zlib)
- fi
-fi
+AC_CHECK_HEADER(zlib.h, [],[AC_MSG_ERROR(z.h not found)])
+AC_CHECK_LIB(z, inflateEnd, [],[AC_MSG_ERROR(libz not found)])
hooks/post-receive
More information about the Darshan-commits
