[Darshan-commits] [Darshan] branch, dev-modular, updated. 44a058c21369e5e069c87a243e5b59b7e47cbd1a
Service Account git at mcs.anl.gov
Tue Nov 4 15:37:39 CST 2014
This is an automated email from the git hooks/post-receive script. It was
generated because a ref change was pushed to the repository containing
the project "".
The branch, dev-modular has been updated
       via  44a058c21369e5e069c87a243e5b59b7e47cbd1a (commit)
       via  c88a970e8fa565ca47228e25a4da2bdc104ead32 (commit)
      from  0da31a588b438cc6905b94d6923ba90d51f3f964 (commit)
Those revisions listed above that are new to this repository have
not appeared on any other notification email; so we list those
revisions in full, below.
- Log -----------------------------------------------------------------
commit 44a058c21369e5e069c87a243e5b59b7e47cbd1a
Author: Shane Snyder <ssnyder at mcs.anl.gov>
Date:   Tue Nov 4 15:37:05 2014 -0600
    Initial darshan-core shutdown logic
commit c88a970e8fa565ca47228e25a4da2bdc104ead32
Date:   Tue Nov 4 15:36:42 2014 -0600
    Remove darshan-common from build temporarily
Summary of changes:
 darshan-log-format.h                |    7 -
 darshan-runtime/Makefile.in         |    5 +-
 darshan-runtime/darshan.h           |   17 ++-
 darshan-runtime/lib/darshan-core.c  |  266 ++++++++++++++++++++++++++++++++---
 darshan-runtime/lib/darshan-posix.c |   66 +++++++++-
 5 files changed, 325 insertions(+), 36 deletions(-)
Diff of changes:
diff --git a/darshan-log-format.h b/darshan-log-format.h
index 4803094..2f59c34 100644
--- a/darshan-log-format.h
+++ b/darshan-log-format.h
@@ -44,11 +44,4 @@ struct darshan_job
     char metadata[DARSHAN_JOB_METADATA_LEN];
-/* This macro can be used to identify files that have been opened using
- * pnetcdf, hdf5, or mpi-io, but were never opened at the posix level.  As a
- * result the record will not necessarily have all of the expected fields
- * populated.
-#define CP_FILE_PARTIAL(__file)((((__file)->counters[CP_POSIX_OPENS] || (__file)->counters[CP_POSIX_FOPENS] || (__file)->counters[CP_POSIX_STATS]) ? 0 : 1))
 #endif /* __DARSHAN_LOG_FORMAT_H */
diff --git a/darshan-runtime/Makefile.in b/darshan-runtime/Makefile.in
index ac3d5e2..a882bab 100644
--- a/darshan-runtime/Makefile.in
+++ b/darshan-runtime/Makefile.in
@@ -37,9 +37,6 @@ lib::
 lib/darshan-core.o: lib/darshan-core.c darshan-core.h $(DARSHAN_LOG_FORMAT) | lib
 	$(CC) $(CFLAGS) -c $< -o $@
-lib/darshan-common.o: lib/darshan-common.c darshan.h | lib
-	$(CC) $(CFLAGS) -c $< -o $@
 #lib/darshan-mpi-io.o: lib/darshan-mpi-io.c darshan.h darshan-dynamic.h $(DARSHAN_LOG_FORMAT) | lib
 #	$(CC) $(CFLAGS) -c $< -o $@
@@ -91,7 +88,7 @@ lib/lookup8.o: lib/lookup8.c
 #%.i: %.c
 #	$(CC) -E $(CFLAGS) -c $< -o $@
-lib/libdarshan-core.a: lib/darshan-core.o lib/darshan-common.o lib/lookup3.o lib/lookup8.o lib/darshan-posix.o
+lib/libdarshan-core.a: lib/darshan-core.o lib/lookup3.o lib/lookup8.o lib/darshan-posix.o
 	ar rcs $@ $^
 #lib/libdarshan-mpi-io.a: lib/darshan-mpi-io.o lib/darshan-mpi-init-finalize.o lib/darshan-pnetcdf.o lib/darshan-hdf5.o
diff --git a/darshan-runtime/darshan.h b/darshan-runtime/darshan.h
index f7e6347..e5f2590 100644
--- a/darshan-runtime/darshan.h
+++ b/darshan-runtime/darshan.h
@@ -10,8 +10,21 @@
 #include <sys/types.h>
 #include <stdint.h>
 #include <mpi.h>
 #include "darshan-log-format.h"
+/* Environment variable to override CP_JOBID */
+#define CP_JOBID_OVERRIDE "DARSHAN_JOBID"
+/* Environment variable to override __CP_LOG_PATH */
+#define CP_LOG_PATH_OVERRIDE "DARSHAN_LOGPATH"
+#define CP_LOG_HINTS_OVERRIDE "DARSHAN_LOGHINTS"
+/* Environment variable to override __CP_MEM_ALIGNMENT */
+#define CP_MEM_ALIGNMENT_OVERRIDE "DARSHAN_MEMALIGN"
 /* TODO these go where ? */
 #define DARSHAN_MPI_CALL(func) func
@@ -36,8 +49,4 @@ void darshan_core_lookup_id(
 double darshan_core_wtime(void);
-char* darshan_clean_file_path(const char* path);
-double darshan_wtime(void);
 #endif /* __DARSHAN_H */
diff --git a/darshan-runtime/lib/darshan-core.c b/darshan-runtime/lib/darshan-core.c
index 8b273e4..5681099 100644
--- a/darshan-runtime/lib/darshan-core.c
+++ b/darshan-runtime/lib/darshan-core.c
@@ -3,18 +3,22 @@
  *      See COPYRIGHT in top-level directory.
+#define _XOPEN_SOURCE 500
 #include "darshan-runtime-config.h"
-#include <stdlib.h>
 #include <stdio.h>
-#include <string.h>
 #ifdef HAVE_MNTENT_H
 #include <mntent.h>
 #endif
+#include <stdlib.h>
+#include <string.h>
+#include <time.h>
+#include <limits.h>
+#include <pthread.h>
 #include <sys/stat.h>
 #include <sys/vfs.h>
-#include <pthread.h>
 #include <mpi.h>
@@ -25,6 +29,7 @@ extern char* __progname_full;
 static void darshan_core_initialize(int *argc, char ***argv);
 static void darshan_core_shutdown(void);
+static void darshan_core_cleanup(struct darshan_core_job_runtime* job);
 /* internal variables */
 static struct darshan_core_job_runtime *darshan_core_job = NULL;
@@ -33,14 +38,14 @@ static pthread_mutex_t darshan_mutex = PTHREAD_MUTEX_INITIALIZER;
 #define DARSHAN_LOCK() pthread_mutex_lock(&darshan_mutex)
 #define DARSHAN_UNLOCK() pthread_mutex_unlock(&darshan_mutex)
-#define DARSHAN_MOD_REGISTER(__mod) \
-    LL_PREPEND(darshan_core_job->mod_list_head, __mod)
-#define DARSHAN_MOD_SEARCH(__mod, __tmp) \
-    LL_SEARCH(darshan_core_job->mod_list_head, __mod, __tmp, mod_cmp)
-#define DARSHAN_MOD_ITER(__mod, __tmp) \
-    LL_FOREACH_SAFE(darshan_core_job->mod_list_head, __mod, __tmp)
-#define DARSHAN_MOD_DELETE(__mod) \
-   LL_DELETE(darshan_core_job->mod_list_head, __mod)
+#define DARSHAN_MOD_REGISTER(__mod, __job) \
+    LL_PREPEND(__job->mod_list_head, __mod)
+#define DARSHAN_MOD_SEARCH(__mod, __tmp, __job) \
+    LL_SEARCH(__job->mod_list_head, __mod, __tmp, mod_cmp)
+#define DARSHAN_MOD_ITER(__mod, __tmp, __job) \
+    LL_FOREACH_SAFE(__job->mod_list_head, __mod, __tmp)
+#define DARSHAN_MOD_DELETE(__mod, __job) \
+   LL_DELETE(__job->mod_list_head, __mod)
 /* intercept MPI initialize and finalize to initialize darshan */
 int MPI_Init(int *argc, char ***argv)
@@ -176,22 +181,242 @@ static void darshan_core_initialize(int *argc, char ***argv)
 static void darshan_core_shutdown()
+    int rank;
+    char *logfile_name;
+    struct darshan_core_job_runtime* final_job;
     struct darshan_core_module *mod, *tmp;
     int internal_timing_flag = 0;
+    int jobid;
+    char* jobid_str;
+    char* envjobid;
+    char* logpath;
+    int ret;
+    uint64_t hlevel;
+    char hname[HOST_NAME_MAX];
+    uint64_t logmod;
+    char* logpath_override = NULL;
+#ifdef __CP_LOG_ENV
+    char env_check[256];
+    char* env_tok;
+#endif
     if(getenv("DARSHAN_INTERNAL_TIMING"))
         internal_timing_flag = 1;
+    DARSHAN_LOCK();
+    if(!darshan_core_job)
+        DARSHAN_UNLOCK();
+        return;
+    /* disable further tracing while hanging onto the data so that we can
+     * write it out
+    final_job = darshan_core_job;
+    darshan_core_job = NULL;
+    DARSHAN_UNLOCK();
+    logfile_name = malloc(PATH_MAX);
+    if(!logfile_name)
+        darshan_core_cleanup(final_job);
+        return;
+    DARSHAN_MPI_CALL(PMPI_Comm_rank)(MPI_COMM_WORLD, &rank);
+    /* construct log file name */
+    if(rank == 0)
+        char cuser[L_cuserid] = {0};
+        struct tm* my_tm;
+        time_t start_time_tmp;
+        /* Use CP_JOBID_OVERRIDE for the env var or CP_JOBID */
+        envjobid = getenv(CP_JOBID_OVERRIDE);
+        if (!envjobid)
+            envjobid = CP_JOBID;
+        /* Use CP_LOG_PATH_OVERRIDE for the value or __CP_LOG_PATH */
+        logpath = getenv(CP_LOG_PATH_OVERRIDE);
+        if (!logpath)
+#ifdef __CP_LOG_PATH
+            logpath = __CP_LOG_PATH;
+#endif
+        /* find a job id */
+        jobid_str = getenv(envjobid);
+        if(jobid_str)
+            /* in cobalt we can find it in env var */
+            ret = sscanf(jobid_str, "%d", &jobid);
+        if(!jobid_str || ret != 1)
+            /* use pid as fall back */
+            jobid = getpid();
+        /* break out time into something human readable */
+        start_time_tmp = final_job->log_job.start_time;
+        my_tm = localtime(&start_time_tmp);
+        /* get the username for this job.  In order we will try each of the
+         * following until one of them succeeds:
+         * - cuserid()
+         * - getenv("LOGNAME")
+         * - snprintf(..., geteuid());
+         * Note that we do not use getpwuid() because it generally will not
+         * work in statically compiled binaries.
+#ifndef DARSHAN_DISABLE_CUSERID
+        cuserid(cuser);
+#endif
+        /* if cuserid() didn't work, then check the environment */
+        if (strcmp(cuser, "") == 0)
+            char* logname_string;
+            logname_string = getenv("LOGNAME");
+            if(logname_string)
+                strncpy(cuser, logname_string, (L_cuserid-1));
+        /* if cuserid() and environment both fail, then fall back to uid */
+            uid_t uid = geteuid();
+            snprintf(cuser, sizeof(cuser), "%u", uid);
+        /* generate a random number to help differentiate the log */
+        hlevel=DARSHAN_MPI_CALL(PMPI_Wtime)() * 1000000;
+        (void) gethostname(hname, sizeof(hname));
+        logmod = darshan_hash((void*)hname,strlen(hname),hlevel);
+        /* see if darshan was configured using the --with-logpath-by-env
+         * argument, which allows the user to specify an absolute path to
+         * place logs via an env variable.
+        /* just silently skip if the environment variable list is too big */
+        if(strlen(__CP_LOG_ENV) < 256)
+            /* copy env variable list to a temporary buffer */
+            strcpy(env_check, __CP_LOG_ENV);
+            /* tokenize the comma-separated list */
+            env_tok = strtok(env_check, ",");
+            if(env_tok)
+                do
+                    /* check each env variable in order */
+                    logpath_override = getenv(env_tok);
+                    if(logpath_override)
+                        /* stop as soon as we find a match */
+                        break;
+                }while((env_tok = strtok(NULL, ",")));
+#endif
+            ret = snprintf(logfile_name, PATH_MAX,
+                "%s/%s_%s_id%d_%d-%d-%d-%" PRIu64 ".darshan_partial",
+                logpath_override,
+                cuser, __progname, jobid,
+                (my_tm->tm_mon+1),
+                my_tm->tm_mday,
+                (my_tm->tm_hour*60*60 + my_tm->tm_min*60 + my_tm->tm_sec),
+                logmod);
+            if(ret == (PATH_MAX-1))
+                /* file name was too big; squish it down */
+                snprintf(logfile_name, PATH_MAX,
+                    "%s/id%d.darshan_partial",
+                    logpath_override, jobid);
+        else if(logpath)
+                "%s/%d/%d/%d/%s_%s_id%d_%d-%d-%d-%" PRIu64 ".darshan_partial",
+                logpath, (my_tm->tm_year+1900),
+                (my_tm->tm_mon+1), my_tm->tm_mday,
+                my_tm->tm_mday,
+                logmod);
+                    logpath, jobid);
+        else
+            logfile_name[0] = '\0';
+        /* add jobid */
+        final_job->log_job.jobid = (int64_t)jobid;
+    /* broadcast log file name */
+    DARSHAN_MPI_CALL(PMPI_Bcast)(logfile_name, PATH_MAX, MPI_CHAR, 0,
+        MPI_COMM_WORLD);
+    if(strlen(logfile_name) == 0)
+        /* failed to generate log file name */
+        return;
+    final_job->log_job.end_time = time(NULL);
     /* TODO: coordinate shutdown accross all registered modules */
-    DARSHAN_MOD_ITER(mod, tmp)
+    free(logfile_name);
+    if (internal_timing_flag)
-        printf("Shutting down %s module\n", mod->name);
+        /* TODO: what do we want to time in new darshan version? */
+    return;
-        DARSHAN_MOD_DELETE(mod);
+    struct darshan_core_module *mod, *tmp;
+    DARSHAN_MOD_ITER(mod, tmp, job)
+        DARSHAN_MOD_DELETE(mod, job);
         free(mod);
-    free(darshan_core_job);
+    free(job);
     return;
@@ -211,15 +436,18 @@ void darshan_core_register_module(
     struct darshan_core_module tmp;
     struct darshan_core_module* mod;
+    DARSHAN_LOCK();
     *runtime_mem_limit = 0;
+        DARSHAN_UNLOCK();
         return;
-    DARSHAN_LOCK();
     /* see if this module is already registered */
     strncpy(tmp.name, name, DARSHAN_MOD_NAME_LEN);
-    DARSHAN_MOD_SEARCH(mod, &tmp);
+    DARSHAN_MOD_SEARCH(mod, &tmp, darshan_core_job);
     if(mod)
         /* if module is already registered, update module_funcs and return */
@@ -241,7 +469,7 @@ void darshan_core_register_module(
     strncpy(mod->name, name, DARSHAN_MOD_NAME_LEN);
     mod->mod_funcs = *funcs;
-    DARSHAN_MOD_REGISTER(mod);
+    DARSHAN_MOD_REGISTER(mod, darshan_core_job);
     /* TODO: something smarter than just 2 MiB per module */
     *runtime_mem_limit = 2 * 1024 * 1024;
diff --git a/darshan-runtime/lib/darshan-posix.c b/darshan-runtime/lib/darshan-posix.c
index 9c8bbb8..a3bee83 100644
--- a/darshan-runtime/lib/darshan-posix.c
+++ b/darshan-runtime/lib/darshan-posix.c
@@ -188,7 +188,7 @@ struct posix_runtime
 static struct posix_runtime *posix_runtime = NULL;
 static pthread_mutex_t posix_runtime_mutex = PTHREAD_RECURSIVE_MUTEX_INITIALIZER_NP;
-static int my_rank = -1;
+static int my_rank = -1; /* TODO */
 static int darshan_mem_alignment = 1;
 /* these are paths that we will not trace */
@@ -215,6 +215,7 @@ static void posix_runtime_finalize(void);
 static struct posix_runtime_file* posix_file_by_name(const char *name);
 static struct posix_runtime_file* posix_file_by_name_setfd(const char* name, int fd);
 static void posix_file_close_fd(int fd);
+static char* darshan_clean_file_path(const char* path);
 static void posix_prepare_for_shutdown(void);
 static void posix_get_output_data(void **buffer, int size);
@@ -395,7 +396,7 @@ static void posix_runtime_initialize()
     #if (__CP_MEM_ALIGNMENT < 1)
         #error Darshan must be configured with a positive value for --with-mem-align
     #endif
-    alignstr = getenv("DARSHAN_MEMALIGN");
+    alignstr = getenv(CP_MEM_ALIGNMENT_OVERRIDE);
     if(alignstr)
         ret = sscanf(alignstr, "%d", &tmpval);
@@ -528,6 +529,67 @@ static void posix_file_close_fd(int fd)
     return;
+/* Allocate a new string that contains a cleaned-up version of the path
+ * passed in as an argument.  Converts relative paths to absolute paths and
+ * filters out some potential noise in the path string.
+    char* newpath = NULL;
+    char* cwd = NULL;
+    char* filter = NULL;
+    if(!path || strlen(path) < 1)
+        return(NULL);
+    if(path[0] == '/')
+        /* it is already an absolute path */
+        newpath = malloc(strlen(path)+1);
+        if(newpath)
+            strcpy(newpath, path);
+    else
+        /* handle relative path */
+        cwd = malloc(PATH_MAX);
+        if(cwd)
+            if(getcwd(cwd, PATH_MAX))
+                newpath = malloc(strlen(path) + strlen(cwd) + 2);
+                if(newpath)
+                    sprintf(newpath, "%s/%s", cwd, path);
+            free(cwd);
+    if(!newpath)
+        return(NULL);
+    /* filter out any double slashes */
+    while((filter = strstr(newpath, "//")))
+        /* shift down one character */
+        memmove(filter, &filter[1], (strlen(&filter[1]) + 1));
+    /* filter out any /./ instances */
+    while((filter = strstr(newpath, "/./")))
+        /* shift down two characters */
+        memmove(filter, &filter[2], (strlen(&filter[2]) + 1));
+    /* return result */
+    return(newpath);
 static void posix_prepare_for_shutdown()
hooks/post-receive
More information about the Darshan-commits mailing list
