[codes-ross-users] Questions about CODES
Mubarak, Misbah
mmubarak at anl.gov
Fri Nov 10 17:23:07 CST 2017
Hi Junji,
>From what you have described, the core modeling part can be implemented
with a simple logic. You can add the state of the cores in your server LP.
For example, add a next_available_time variable for each of those cores in
the server LP state which would be initially set to be current simulation
time with tw_now(lp) but will get updated with the time needed by the core
to process an event. We do something similar for network links (one
example is in src/networks/torus.c, look for next_link_available_time).
You would also need some form of event queue in case an event has arrived
but there is no core available. In that case when a core becomes
available, you can fetch an event from that waiting queue. To implement a
queue, either qlist or a linked list can be used (Functions for qlist are
available in codes/quiclist.h)
We currently don't have a memory model in CODES but if you need a simple
set of operations with the memory, perhaps those can be implemented as
well.
Misbah
On 11/9/17, 3:20 AM, "Junji Kobayashi" <kbys at hpcs.cs.tsukuba.ac.jp> wrote:
>Hi Misbah,
>Thanks for your help.
>I'm looking at 4 cores cpu and 24GB memory.
>I would like to simulate following operations,
>a server receive a event -> to processing the event, a cpu core is
>required ->
>-> if all cores processing events, the server wait until processing is
>completed.
>-> if a core is available, the server processing the event
>If CODES can simulate these operations, how to implement using CODES ?
>Best Regards.
>Junji Kobayashi
>University of Tsukuba
>Junji Kobayashi
>email:(kbys at hpcs.cs.tsukuba.ac.jp)
>> Hi Junji,
>> Currently, CODES does not simulate cpu or memory resources but if you
>>know
>> the specific pieces that you want, I can help get you started with the
>> implementation. What memory/cpu resources are you looking at?
>> Thanks,
>> Misbah
>> On 11/6/17, 8:10 PM, "codes-ross-users on behalf of Junji Kobayashi"
>> <codes-ross-users-bounces at lists.mcs.anl.gov on behalf of
>>>Hi there,
>>>I would like to simulate cpu or memory resources in servers.
>>>Does CODES supports these simulations?
>>>If CODES supports these simulations, how to implement using CODES?
>>>Best Regards.
>>>Junji Kobayashi
>>>Junji Kobayashi
>>>_______________________________________________
>>>codes-ross-users mailing list
>>>codes-ross-users at lists.mcs.anl.gov
>>>https://lists.mcs.anl.gov/mailman/listinfo/codes-ross-users
More information about the codes-ross-users
