[codes-ross-users] how to use fattree static routing
Peixin Qiao pqiao at hawk.iit.edu
Wed Mar 15 11:10:39 CDT 2017
I still cannot create the routing table. Here is what I did and the error
report:
1: I do the "empty" run to dump the topology and only get the file:
fattree.dot.0, which is in attachment
2: When I run ./simulate.py -s, I get the following result:
patching file Makefile.am
patching file scripts/scheduler-sar-interface.py
Step 1...
Step 2...
Step 3...
Step 4...
Step 5...
Step 6...
sed: can't read /home/peixin/simulation/ofed/bin/ibdiagnet: No such file or
directory
...... skipping omnet install .....
Step 9...
3. Finally I run ~/simulation/scripts/create_static_lft.sh routing_folder
dot_file, and get the following result:
peixin at peixin:~/simulation/scripts$
/home/peixin/fattree_simulation/routing_folder fattree
running createIBNet.py
Selected configuration:
  Output:  /home/peixin/fattree_simulation/routing_folder/topo.net
  Topology:  DOT
  Number of endpoints:  8
  Number of ports per endpoints:  1
  Number of switches:  4
  Number of ports per switch:  4
  Dimensions for Mesh/Torus: -1, -1, -1
  k-ary-n Tree: -1 -ary- -1
  Kautz K(b,n): K(-1; -1)
  XGFT(h,m,w): XGFT(-1; -1; -1)
  Dragonfly(a,p,h) : Dragonfly(-1, -1, -1) with -1 groups
  Cascade(a,p,h,g) : Cascade(96, 8, 10) with -1 groups
  Tofu(d1,d2,d3) : Tofu(-1, -1, -1) with -1 groups
This program also writes an dot-file to plot the graph with Graphviz.
Try:
  dot / neato /home/peixin/fattree_simulation/routing_folder/topo.dot -Tpng
running simulate.py
Run ibsim...
Run opensm...
Check routing...
Scan fabric...
Stop ibsim/opensm...
Warning: 13526 already dead
Warning: 13520 already dead
Check the connectivity of the system...
mv: cannot stat
‘/home/peixin/fattree_simulation/routing_folder/ofedout/ibdiagnet.fdbs’: No
such file or directory
running post_process_lfts.py
ERR: file /home/peixin/fattree_simulation/routing_folder/ibdiagnet.fdbs or
/home/peixin/fattree_simulation/routing_folder/opensm-subnet.lst does not
exist
Peixin
On Mon, Mar 13, 2017 at 4:39 PM, Nikhil Jain <nikhil.jain at acm.org> wrote:
> routing_folder and dot_file are keywords/parameters in the config file
> whose values were chosen by you during the topology dump run. It is
> described in the second step "2- Static Routing”.
> Nikhil Jain
> Postdoctoral Fellow, Lawrence Livermore National Laboratory
> nikhil.jain at acm.org, http://nikhil-jain.github.io/
> On Mar 13, 2017, at 14:25, Peixin Qiao <pqiao at hawk.iit.edu> wrote:
> When I run the third step as README.fattree.txt:
> # 3. Choose a routing algorithm which should be used by OpenSM
> # (possible options: updn, dnup, ftree, lash, dor, torus-2QoS, dfsssp,
> sssp)
> # export OSM_ROUTING="ftree"
> # ~/simulation/scripts/create_static_lft.sh routing_folder dot_file
> # (here routing_folder and dot_file should be same as the one used during
> the run used to dump the topology)
> # Now, the routing table stored as LFT files should be in the
> routing_folder.
> So what is the routing_folder and dot_file? Is the following correct?
> routing_folder: mkdir routing_folder
> dot_file: python simulate.py createIBNet -t XGFT -xh 3 -xm 18,18,36 -xw
> 1,18,18 -sp 36 (get 2 files: net.dot and net.txt)
> Thanks,
> Peixin
> On Mon, Mar 13, 2017 at 1:52 PM, Nikhil Jain <nikhil.jain at acm.org> wrote:
>> Did the script die or you killed it? If you killed it, after how long?
>> What size system are you generating routing for?
>> Nikhil Jain
>> On Mar 13, 2017, at 10:31, Peixin Qiao <pqiao at hawk.iit.edu> wrote:
>> Hi CODES,
>> When I run the command in README.fattree.txt, I cannot finish creating
>> static routing table. The third step cannot be finished as follows:
>> peixin at peixin:~/simulation/scripts/routing_folder$ ls
>> net.dot  net.txt
>> peixin at peixin:~/simulation/scripts/routing_folder$ cd ..
>> peixin at peixin:~/simulation/scripts$ ~/simulation/scripts/create_static_lft.sh
>> /home/peixin/simulation/scripts/routing_folder/ net
>> dot file already exists.
>>   Output:  /home/peixin/simulation/scripts/routing_folder/topo.net
>>   Topology:  XGFT
>>   Number of ports per switch:  36
>>   XGFT(h,m,w): XGFT(3; 18,18,36; 1,18,18)
>> Try:
>>   dot / neato /home/peixin/simulation/scripts/routing_folder/topo.dot
>> running simulate.py
>> Run ibsim...
>> Run opensm...
>> ^CTraceback (most recent call last):
>>   File "/home/peixin/simulation/scripts/simulate.py", line 1140, in
>> <module>
>>     app = runSim(options.network, options.routing, options.pattern)
>>   File "/home/peixin/simulation/scripts/simulate.py", line 826, in
>> __init__
>>     time.sleep(60)
>> KeyboardInterrupt
>> peixin at peixin:~/simulation/scripts$ cd routing_folder/
>> log.txt  net.dot  net.txt  ofedout  rootguids.conf  topo.dot  topo.net
>> How to create fat-tree static routing table with 36-ports switch?
>> Thanks,
>> Peixin
>> codes-ross-users mailing list
>> codes-ross-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/codes-ross-users
URL: <http://lists.mcs.anl.gov/pipermail/codes-ross-users/attachments/20170315/9096c4fa/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/codes-ross-users/attachments/20170315/9096c4fa/attachment-0001.obj>
More information about the codes-ross-users mailing list
