[codes-ross-users] Too many rollback events
Nikhil Jain
nikhil.jain at acm.org
Mon Jun 5 11:13:20 CDT 2017
I don’t think 10 microsecond is a large lookahead; How big a system are you trying to simulate (as in the network size)? If the system is small, it may be hard to reduce the rollbacks as the #core increase.
Other things that can be tried:
1. nkp option = number of KPs; but default ROSS uses 16, but you can set it to (#total LPs)/(#cores) - i.e. make each LP has its own KP, which will prevent false rollbacks
2. gvt/batch size = you can try a small gvt frequency (like 4/8) and batch size (4/8).
Nikhil Jain
Postdoctoral Fellow, Lawrence Livermore National Laboratory
nikhil.jain at acm.org, http://nikhil-jain.github.io/
> On Jun 5, 2017, at 11:57, Jian Peng <jpeng10 at hawk.iit.edu> wrote:
> Hi,
> My simulation is having too many events rolled back, like 70%. It's still relatively small scale, 16 cores on 4 nodes, using optimistic scheduler. The result is attached.
> Any general idea of reducing number of rollback events? I used the max-opt-lookahead option and set it to 10000. Is it still a large number?
> Thanks!
> <rollback_result_1.png><rollback_result_2.png>_______________________________________________
> codes-ross-users mailing list
> codes-ross-users at lists.mcs.anl.gov
> https://lists.mcs.anl.gov/mailman/listinfo/codes-ross-users
URL: <http://lists.mcs.anl.gov/pipermail/codes-ross-users/attachments/20170605/7e88e7b6/attachment.html>
More information about the codes-ross-users
