[codes-ross-users] Replay HPL's dumpi trace on CODES
Maxime Chevalier maxime.chevalier at inria.fr
Fri Jun 2 07:52:56 CDT 2017
Hi Misbah,
Thanks for your fast response. I was looking for the data type, but I don't really understand. I have figured out how to avoid "UNDEFINED DATA TYPE" errors by compiling HPL whit "HPL_NO_MPI_DATATYPE", but the output is quite the same (see trace below). I don't know if it's a step forward or backward...
Maxime
Trace :
Fri Jun 2 09:15:49 2017
ROSS Revision: 4c6a7d8eb9c784797d900edfc76725d62ec25941
tw_net_start: Found world size to be 1
ROSS Core Configuration:
Total Nodes 1
Total Processors [Nodes (1) x PE_per_Node (1)] 1
Total KPs [Nodes (1) x KPs (16)] 16
Total LPs 54
Simulation End Time 300000000000.00
LP-to-PE Mapping model defined
ROSS Event Memory Allocation:
Model events 13825
Network events 50000
Total events 63824
*** START SEQUENTIAL SIMULATION ***
*** END SIMULATION ***
LP 1 unmatched irecvs 1 unmatched sends 0 Total sends 0 receives 2 collectives 0 delays 8 wait alls 0 waits 0 send time 0.000000 wait 0.000000
LP 3 unmatched irecvs 1 unmatched sends 0 Total sends 1 receives 1 collectives 0 delays 10 wait alls 0 waits 0 send time 3.202149 wait 0.000000
LP 5 unmatched irecvs 0 unmatched sends 0 Total sends 0 receives 1 collectives 0 delays 7 wait alls 0 waits 0 send time 0.000000 wait 0.000000
LP 7 unmatched irecvs 1 unmatched sends 0 Total sends 1 receives 1 collectives 0 delays 10 wait alls 0 waits 0 send time 3.189207 wait 0.000000
: Running Time = 0.0001 seconds
TW Library Statistics:
Total Events Processed 56
Events Aborted (part of RBs) 0
Events Rolled Back 0
Event Ties Detected in PE Queues 0
Efficiency 100.00 %
Total Remote (shared mem) Events Processed 0
Percent Remote Events 0.00 %
Total Remote (network) Events Processed 0
Total Roll Backs 0
Primary Roll Backs 0
Secondary Roll Backs 0
Fossil Collect Attempts 0
Total GVT Computations 0
Net Events Processed 56
Event Rate (events/sec) 823529.4
Total Events Scheduled Past End Time 0
TW Memory Statistics:
Events Allocated 63825
Memory Allocated 62573
Memory Wasted 683
TW Data Structure sizes in bytes (sizeof):
PE struct 608
KP struct 144
LP struct 128
LP Model struct 760
LP RNGs 80
Total LP 968
Event struct 144
Event struct with Model 928
TW Clock Cycle Statistics (MAX values in secs at 1.0000 GHz):
Priority Queue (enq/deq) 0.0000
AVL Tree (insert/delete) 0.0000
LZ4 (de)compression 0.0000
Buddy system 0.0000
Event Processing 0.0000
Event Cancel 0.0000
Event Abort 0.0000
GVT 0.0000
Fossil Collect 0.0000
Primary Rollbacks 0.0000
Network Read 0.0000
Statistics Computation 0.0000
Statistics Write 0.0000
Total Time (Note: Using Running Time above for Speedup) 0.0002
TW GVT Statistics: MPI AllReduce
GVT Interval 16
GVT Real Time Interval (cycles) 0
GVT Real Time Interval (sec) 0.00000000
Batch Size 16
Forced GVT 0
Total All Reduce Calls 0
Average Reduction / GVT -nan
Total bytes sent 8 recvd 20
max runtime 0.000000 ns avg runtime 0.000000
max comm time 0.000000 avg comm time -69573.000000
max send time 3.202149 avg send time 1.597839
max recv time 45682.609151 avg recv time 11420.652288
max wait time 0.000000 avg wait time 0.000000
----- Mail original -----
> De: "Misbah Mubarak" <mmubarak at anl.gov>
> À: "Maxime Chevalier" <maxime.chevalier at inria.fr>,
> codes-ross-users at lists.mcs.anl.gov
> Envoyé: Mardi 30 Mai 2017 18:12:46
> Objet: Re: [codes-ross-users] Replay HPL's dumpi trace on CODES
> Hi Maxime,
> Thanks for your message. There seems to be a data type that is either not
> supported by DUMPI or CODES. Are you familiar with what data types are being
> used by the HPL trace? I will find out if the support for them can be added
> in the code.
> Regards,
> Misbah
> From: < codes-ross-users-bounces at lists.mcs.anl.gov > on behalf of Maxime
> Chevalier < maxime.chevalier at inria.fr >
> Date: Monday, May 29, 2017 at 3:51 AM
> To: " codes-ross-users at lists.mcs.anl.gov " <
> codes-ross-users at lists.mcs.anl.gov >
> Subject: [codes-ross-users] Replay HPL's dumpi trace on CODES
> Hi,
> I'm trying to replay HPL's DUMPI trace generated on my computer with CODES.
> Unfortunately, I get a lot of "Undefined data type" errors (see the trace
> below).
> I have already replayed AMG traces (downloaded here ) and replayed my own
> generated AMG traces. It has worked fine.
> So I'm wondering if I did something wrong, or if it's HPL fault.
> Best regards,
> Maxime
> Trace :
> > Total Nodes 1
> > Total LPs 5
> > Model events 1281
> > Total events 51280
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type
> > Undefined data type *** START SEQUENTIAL SIMULATION ***
> > LP 1 unmatched irecvs 1 unmatched sends 0 Total sends 0 receives 1
> > : Running Time = 0.0000 seconds
> > Total Events Processed 8
> > Efficiency 100.00 %
> > Total Roll Backs 0
> > Net Events Processed 8
> > Event Rate (events/sec) 307692.3
> > Events Allocated 51281
> > Memory Allocated 51168
> > Memory Wasted 720
> > PE struct 608
> > KP struct 144
> > LP struct 128
> > LP Model struct 760
> > LP RNGs 80
> > Total LP 968
> > Event struct 144
> > Buddy system 0.0000
> > Event Cancel 0.0000
> > Event Abort 0.0000
> > GVT 0.0000
> > Network Read 0.0000
> > Total Time (Note: Using Running Time above for Speedup) 0.0001
> > GVT Interval 16
> > Batch Size 16
> > Forced GVT 0
> > Total bytes sent 0 recvd 4
> > max comm time 0.000000 avg comm time -66232.000000
> > max send time 0.000000 avg send time 0.000000
> > max recv time 0.000000 avg recv time 0.000000
> > LP-IO: writing output to hpl-trace-25282-1495543803/
> > LP-IO: data files:
> > hpl-trace-25282-1495543803/mpi-replay-stats
> > hpl-trace-25282-1495543803/model-net-category-all
URL: <http://lists.mcs.anl.gov/pipermail/codes-ross-users/attachments/20170602/da3a7cf6/attachment-0001.html>
More information about the codes-ross-users mailing list
