[codes-ross-users] CODES install error
Mubarak, Misbah mmubarak at anl.gov
Wed Jan 25 09:52:21 CST 2017
Hi Peixin,
Thanks for reporting the issue. I think the error you are seeing is because some of the tests are using DUMPI traces, the compute times for which can get corrupted (currently, we only focus on communication in our simulations, not the compute times). So I have updated the test programs to disregard the compute times.
Now this error does not show up on our test machines so it would be great if you could test and report back in case the problem persists.
Misbah
From: <codes-ross-users-bounces at lists.mcs.anl.gov<mailto:codes-ross-users-bounces at lists.mcs.anl.gov>> on behalf of Peixin Qiao <pqiao at hawk.iit.edu<mailto:pqiao at hawk.iit.edu>>
Date: Tuesday, January 24, 2017 at 5:43 PM
To: "codes-ross-users at lists.mcs.anl.gov<mailto:codes-ross-users at lists.mcs.anl.gov>" <codes-ross-users at lists.mcs.anl.gov<mailto:codes-ross-users at lists.mcs.anl.gov>>
Subject: [codes-ross-users] CODES install error
Hi CODES researchers,
When I install and make test CODES on our server, it report some errors, which is shown in attachment: test-suite.log.
Best Regards,
Peixin
URL: <http://lists.mcs.anl.gov/pipermail/codes-ross-users/attachments/20170125/2db1be7b/attachment.html>
More information about the codes-ross-users mailing list
