[codes-ross-users] "No free event buffers" error
Jian Peng
jpeng10 at hawk.iit.edu
Wed Apr 5 16:14:05 CDT 2017
Great, thanks!
On Wed, Apr 5, 2017 at 2:48 PM, Nikhil Jain <nikhil.jain at acm.org> wrote:
> Another way to control ROSS’s excessive memory consumption is the
> max-opt-lookahead option:
> https://github.com/carothersc/ROSS/commit/53b7fcabcb9b8c015b1f17e3ce1a94
> 298b06920d
> I use it often and this helps avoid running out of memory.
> Nikhil Jain
> Postdoctoral Fellow, Lawrence Livermore National Laboratory
> nikhil.jain at acm.org, http://nikhil-jain.github.io/
> On Apr 5, 2017, at 13:34, Jian Peng <jpeng10 at hawk.iit.edu> wrote:
> Thanks for the explanation! I'll try it out.
> On Wed, Apr 5, 2017 at 11:18 AM, Mubarak, Misbah <mmubarak at anl.gov> wrote:
>> Hi Jian,
>> The ROSS simulations start up with a certain number of events statically
>> allocated per PE (The message-size parameter in the CODES config files tell
>> ROSS how big an event is in bytes). At some point during the simulation, if
>> the events being processed by a PE exceed the number of events that were
>> allocated at the simulation start up, this error is thrown and the
>> simulation terminates.
>> To handle this issue, you could do a —extramem that you already tried.
>> This will allocate an extra number of events per PE. You could try
>> increasing extramem till the point where the event memory is sufficient.
>> However, when this error pops up, it is usually better to double check the
>> model behavior I.e. If the model is issuing a reasonable number of events,
>> it isn't running into an infinite loop of event generation or if the
>> workload is reasonable (it could be that the workload is injecting a very
>> large number of events in a short amount of time).
>> Also, if you are running in optimistic mode and you are getting too many
>> rollbacks, that could be another reason of the event memory running out. So
>> it will help to run the simulation in sequential mode first and see if the
>> error is still there.
>> Regards,
>> Misbah
>> From: <codes-ross-users-bounces at lists.mcs.anl.gov> on behalf of Jian
>> Date: Wednesday, April 5, 2017 at 12:48 PM
>> To: "codes-ross-users at lists.mcs.anl.gov" <codes-ross-users at lists.mcs.an
>> l.gov>
>> Subject: [codes-ross-users] "No free event buffers" error
>> Hi,
>> I get a "No free event buffers.Try increasing via g_tw_events_per_pe
>> or --extramem" error in tw_event_new when running some not too large scale
>> simulation, say 12840 LPs. I add option "--extramem=8192" and it doesn't
>> help. And there is still 90GB of memory left.
>> So, any general suggestion of avoiding this error? Thanks.
> codes-ross-users mailing list
> https://lists.mcs.anl.gov/mailman/listinfo/codes-ross-users
URL: <http://lists.mcs.anl.gov/pipermail/codes-ross-users/attachments/20170405/7f3313e4/attachment.html>
More information about the codes-ross-users
