[codes-ross-users] Help needed in running codes.
Sughosh Divanji
sdivanji at hawk.iit.edu
Mon Mar 2 21:46:44 CST 2015
Hi Jonathan,
Thanks for your help. We are able to run sample programs for codes-base.
But, I am not able to find any example program for codes-net. Could you
point me to a sample program for codes-net and how to run it.
Sughosh
ᐧ
On Fri, Feb 27, 2015 at 2:25 PM, Jenkins, Jonathan P. <jenkins at mcs.anl.gov>
wrote:
> Ah OK. So in general, it's recommended to either stick with releases
> (e.g., "git checkout v0.3.0" for codes-base, codes-net) with the ROSS hash
> listed in the INSTALL document, or work from the master branches in all
> three. Both projects are being actively developed, so changes in behavior
> between a snapshot and non-snapshot version can result in things like the
> RNG error you experienced earlier.
> John
> From: Raghav Kapoor <rkapoor7 at hawk.iit.edu>
> Date: Friday, February 27, 2015 at 2:15 PM
> To: John Jenkins <jenkins at mcs.anl.gov>
> Cc: Ke Wang <kwang22 at hawk.iit.edu>, "codes-ross-users at lists.mcs.anl.gov" <
> codes-ross-users at lists.mcs.anl.gov>, Sughosh Divanji <
> sdivanji at hawk.iit.edu>
> Subject: Re: [codes-ross-users] Help needed in running codes.
> Hi Jonathan,
> For codes-base and codes-net, I used git
> repos:
> git clone git://git.mcs.anl.gov/radix/codes-base
> git clone git://git.mcs.anl.gov/radix/codes-net
> For ross, first i cloned the ROSS git repo, git clone
> http://github.com/carothersc/ROSS.git
> then i did git checkout c04babe
> Should I use the latest ROSS version for it to work correctly?
> Regards,
> Raghav
> ᐧ
> On Fri, Feb 27, 2015 at 2:04 PM, Jenkins, Jonathan P. <jenkins at mcs.anl.gov
> > wrote:
>> Hi Raghav,
>> This looks like a mismatch in ROSS and CODES versions - random number
>> generation went through a few changes on both ends in the last months. Are
>> you using a newer revision of CODES with an older revision of ROSS? What
>> are the commit hashes of codes-base and codes-net (or are you using the
>> 0.3.0 release tarballs)?
>> I'm afraid there aren't any video tutorials – the GETTING_STARTED doc,
>> the best practices LaTeX doc, and the example program are the best we have
>> currently.
>> John
>> Date: Friday, February 27, 2015 at 1:51 PM
>> <codes-ross-users at lists.mcs.anl.gov>, Sughosh Divanji <
>> Hi Jonathon,
>> Thanks for reply. I have built the
>> example in doc/example directory.
>> However when i run it, i get the following:
>> *raghav at raghav-Lenovo-G505s:~/DIC_PROJECT/codesross1/codes-base/doc/example$
>> ./example --codes-config=./example.conf*
>> *./example --codes-config=./example.conf *
>> *Fri Feb 27 13:48:37 2015*
>> *ROSS Revision: c04babe513a0c570ce64db9b5dd939324b118311*
>> *tw_net_start: Found world size to be 1 *
>> *node: 0: error:
>> /home/raghav/DIC_PROJECT/codesross1/ROSS/ross/rand-clcg4.c:289: RNG max
>> streams exceeded: 2 > 1*
>> *application called MPI_Abort(MPI_COMM_WORLD, 1) - process 0*
>> I tried with mpirun as well.
>> mpirun -np 1 ./example --codes-config=./example.conf
>> Fri Feb 27 13:49:37 2015
>> node: 0: error:
>> = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
>> = EXIT CODE: 1
>> = CLEANING UP REMAINING PROCESSES
>> = YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
>> I think there is some issue while running.
>> Can you explain how to run it.
>> Also is there any video tutorial on ROSS or codes through which we can
>> understand these two frameworks better?
>> Thanks,
>> Raghav
>> ᐧ
>> On Fri, Feb 27, 2015 at 11:05 AM, Jenkins, Jonathan P. <
>> jenkins at mcs.anl.gov> wrote:
>>> FYI, the CC fix was just put into ROSS (thanks Elsa!), so if you wish
>>> to build with recent versions of ROSS/CODES, you can. The master branch of
>>> the CODES repositories are currently undergoing some changes, though,
>>> particularly with respect to the workload components.
>>> John
>>> From: <Jenkins>, John Jenkins <jenkins at mcs.anl.gov>
>>> Date: Friday, February 27, 2015 at 10:28 AM
>>> To: Raghav Kapoor <rkapoor7 at hawk.iit.edu>
>>> Hi Raghav,
>>> A recent revision of ROSS seems to have broken the ross-config script
>>> (I've filed the bug with the ROSS folks). I would suggest for the time
>>> being either a) change CC to mpicc in the Makefile, or b) build the
>>> released version of CODES (0.3.0) as well as the ROSS revision listed in
>>> the codes-base INSTALL document. Assuming you have done a) for the moment…
>>> Please make sure that you are setting the CODESBASE, CODESNET, and
>>> ROSS environment variables correctly. They should be pointing to the
>>> directory you specified as your install prefix (./configure
>>> --prefix=/path/to/install for codes-base, codes-net, cmake
>>> -DCMAKE_INSTALL_PREFIX=/path/to/install for ROSS). I have verified correct
>>> behavior in both the current revisions of codes/ROSS with the CC fix, as
>>> well as in the release and ROSS revision c04babe. No changes to the headers
>>> need to be made.
>>> Additionally, the undefined references you are getting are a result of
>>> the lack of the application of -lcodes-base and -lcodes–net in your
>>> compilation command (these are set in the Makefile via LDLIBS).
>>> John
>>> Date: Friday, February 27, 2015 at 9:45 AM
>>> Cc: "codes-ross-users at lists.mcs.anl.gov" <
>>> codes-ross-users at lists.mcs.anl.gov>, Ke Wang <kwang22 at hawk.iit.edu>,
>>> Sughosh Divanji <sdivanji at hawk.iit.edu>
>>> Hi Jonathon,
>>> First, I would like to bring to your attention
>>> that Makefile to compile example.c is not correct. There is no compiler
>>> specified like gcc or mpicc.
>>> Even after giving the correct dependencies and include files and
>>> compiler, if i run this command,
>>> :~/DIC_PROJECT/codesross/codes-base/doc/example$
>>> *mpicc -I/home/raghavDIC_PROJECT/codesross/codes-base/install/include
>>> -I/home/raghavDIC_PROJECT/codesross/codes-net/install/include/codes
>>> -L/home/raghav/DIC_PROJECT/codesross/ROSS/install/lib
>>> -L/home/raghavDIC_PROJECT/codesross/codes-base/install/lib
>>> -L/home/raghavDIC_PROJECT/codesross/codes-net/install/lib example.c
>>> -lROSS -lm
>>> -L/home/raghav/DIC_PROJECT/codesross/codes-net/install/lib/codes-net
>>> -L/home/raghav/DIC_PROJECT/codesross/codes-base/install/codes-base -o
>>> example*
>>> 1. I had to change in many .h files to set the correct path etc.
>>> Second after using the above command, I get lot of undefined
>>> references like
>>> /tmp/ccle6WVw.o: In function `get_next_server':
>>> /home/raghav/DIC_PROJECT/codesross/codes-base/doc/example/example.c:403:
>>> undefined reference to `codes_mapping_get_lp_info'
>>> /home/raghav/DIC_PROJECT/codesross/codes-base/doc/example/example.c:408:
>>> undefined reference to `codes_mapping_get_group_reps'
>>> /home/raghav/DIC_PROJECT/codesross/codes-base/doc/example/example.c:411:
>>> undefined reference to `codes_mapping_get_lp_id'
>>> /tmp/ccle6WVw.o: In function `handle_ack_rev_event':
>>> The include files are there as i have specified in the above command.
>>> Not sure what is going wrong.
>>> Can you help.
>>> Regards,
>>> Raghav
>>> ᐧ
>>> On Thu, Feb 26, 2015 at 8:37 PM, Sughosh Divanji <sdivanji at hawk.iit.edu>
>>> wrote:
>>>> Hi Jonathan,
>>>> Thanks for the info. I have setup CODESBASE,CODESNET and ROSS
>>>> environment variables and tried to run example.c. However, compiling is
>>>> failing because of the following reason.
>>>> sughosh at sughosh-Lenovo-G50-45:~/Desktop/IITC/CS597/codes-base/doc/example$
>>>> make
>>>> make: /home/sughosh/Desktop/IITC/CS597/ROSS/bin/ross-config: Command
>>>> not found
>>>> not found
>>>> not found
>>>> not found
>>>> I/home/sughosh/Desktop/IITC/CS597/codes-base/include
>>>> -I/home/sughosh/Desktop/IITC/CS597/codes-net/include/codes
>>>> -L/home/sughosh/Desktop/IITC/CS597/codes-base/lib
>>>> -L/home/sughosh/Desktop/IITC/CS597/codes-net/lib example.c -lcodes-net
>>>> -lcodes-base -o example
>>>> make: I/home/sughosh/Desktop/IITC/CS597/codes-base/include: Command not
>>>> found
>>>> make: [example] Error 127 (ignored)
>>>> bin directory is not prsent in my ROSS installation and the same with
>>>> other errors as well.
>>>> I tried compiling codes-base 0.3.0 but it was failing at src/util/codes_mapping.c:483:51
>>>> as I have indicated in my earlier mail. So, I downloaded the source code
>>>> from the git link mentioned in Developer Access page,
>>>> http://git.mcs.anl.gov/radix/codes-base and
>>>> git.mcs.anl.gov/radix/codes-net and was able to compile codes-base and
>>>> codes-net succesfully. For ROSS I have downloaded source code from
>>>> https://github.com/carothersc/ROSS.
>>>> Thanks,
>>>> Sughosh
>>>> ᐧ
>>>> On Thu, Feb 26, 2015 at 8:51 AM, Jenkins, Jonathan P. <
>>>>> Hi Sughosh,
>>>>> Instructions to build CODES (codes-base and codes-net repositories)
>>>>> can be found in their respective INSTALL documents. An example program,
>>>>> requiring codes-base and codes-net, can be found in codes-base/doc/example.
>>>>> To build it, you need to specify the paths to the codes installs via the
>>>>> CODESBASE, CODESNET, and ROSS environment variables. Details of the program
>>>>> as well as the CODES components utilized by the program can be found in the
>>>>> GETTING_STARTED document.
>>>>> Additionally, what version / revision of ROSS/CODES are you using?
>>>>> We're in the midst of some changes on the master branches, so it's probably
>>>>> safer to start with the 0.3.0 releases with the ROSS revision specified in
>>>>> the INSTALL document.
>>>>> John
>>>>> From: Sughosh Divanji <sdivanji at hawk.iit.edu>
>>>>> Date: Wednesday, February 25, 2015 at 7:26 PM
>>>>> To: "codes-ross-users at lists.mcs.anl.gov" <
>>>>> codes-ross-users at lists.mcs.anl.gov>, Raghav Kapoor <
>>>>> rkapoor7 at hawk.iit.edu>, Ke Wang <kwang22 at hawk.iit.edu>
>>>>> Subject: [codes-ross-users] Help needed in running codes.
>>>>> Hi,
>>>>> I am trying to use codes for my project and I am new to codes. I
>>>>> have installed codes. Can you provide me a sample hello-world program and
>>>>> instructions on how to run it. I haven't been able to find documentation on
>>>>> how to run the programs and also make files seem to be broken.
>>>>> Thanks,
>>>>> Sughosh
URL: <http://lists.mcs.anl.gov/pipermail/codes-ross-users/attachments/20150302/3a3cf431/attachment-0001.html>
More information about the codes-ross-users
