[codes-ross-users] Correlation between latency and number of hops on torus network?
Ross, Robert B. rross at mcs.anl.gov
Thu Jul 23 13:59:12 CDT 2015
How big a message are you sending? -- Rob
On Jul 23, 2015, at 1:46 PM, Daniel Parker <dkparker at uchicago.edu> wrote:
> Hello,
> First I wanted to thank Jonathan and Misbah for their help on my last question. I was successful in setting up networks where arbitrary numbers of nodes are active or inactive.
> Now that I am able to do so, however, I have made a strange observation. It seems to me that there is not a correlation between the number of hops that a message must make over a torus network and that message's latency. To determine this, I created a simple model where one sender and one receiver node are randomly chosen within a 3D 10x10x10 torus network. I take latency measurements for 10 pings from the sender to the receiver and back, then average the values. I repeated this trial 500 times and aggregated the data into these graphs:
> http://imgur.com/a/7rqRw
> The first graph shows a cdf of latencies of the different trials, with each data point color-coded corresponding to the number of hops between the sender and receiver for that trial. Blue indicates few hops while red indicates more. The second shows the distribution of hop counts observed over the 500 trials, with number of hops on the x axis and frequency on the y axis. As you can see, the latency seems constant despite distance between the nodes in question, which does not make sense to me. Do any of you know why this would be? Is there something about the torus implementation that I'm misunderstanding?
> I can upload my code if necessary.
> Thanks for your help,
> Dan Parker
> codes-ross-users mailing list
> codes-ross-users at lists.mcs.anl.gov
> https://lists.mcs.anl.gov/mailman/listinfo/codes-ross-users
More information about the codes-ross-users mailing list
