[codes-ross-users] Cmake fails with reason "include could not find load file:GetGitRevisionDescription"
Sughosh Divanji sdivanji at hawk.iit.edu
Fri Jan 30 17:35:08 CST 2015
Thanks for the quick response. Now everything is compiling.
ᐧ
On Fri, Jan 30, 2015 at 4:22 PM, Justin M. LaPre <jlapre at gmail.com> wrote:
>  It was just a mis-typed variable name.  It has been corrected and
> everything should compile now.
> Justin M. LaPre
> Sent with Sparrow <http://www.sparrowmailapp.com/?sig>
> On Friday, January 30, 2015 at 5:04 PM, Sughosh Divanji wrote:
> Hi Elsa,
> Thanks a lot for your help. I tried the installation as suggested by you.
> Now cmake is failing with the following error,
> sughosh at sughosh-Lenovo-G50-45:~/Desktop/IITC/CS597/ross-build/ROSS-build$
> cmake ~/Desktop/IITC/CS597/ROSS/
> -- Configuring done
> -- Generating done
> -- Build files have been written to:
> /home/sughosh/Desktop/IITC/CS597/ross-build/ROSS-build
> make
> Scanning dependencies of target ROSS
> [  4%] Building C object core/CMakeFiles/ROSS.dir/queue/splay.c.o
> [  8%] Building C object core/CMakeFiles/ROSS.dir/ross-random.c.o
> [ 13%] Building C object core/CMakeFiles/ROSS.dir/rand-clcg4.c.o
> [ 17%] Building C object core/CMakeFiles/ROSS.dir/clock/amd64.c.o
> [ 21%] Building C object core/CMakeFiles/ROSS.dir/gvt/mpi_allreduce.c.o
> [ 26%] Building C object core/CMakeFiles/ROSS.dir/network-mpi.c.o
> [ 30%] Building C object core/CMakeFiles/ROSS.dir/hash-quadratic.c.o
> /home/sughosh/Desktop/IITC/CS597/ROSS/core/hash-quadratic.c: In function
> ‘tw_hash_create’:
> /home/sughosh/Desktop/IITC/CS597/ROSS/core/hash-quadratic.c:36:3: error:
> ‘g_avl_node_count’ undeclared (first use in this function)
>    g_avl_node_count = 1 << g_tw_avl_node_count;
> /home/sughosh/Desktop/IITC/CS597/ROSS/core/hash-quadratic.c:36:3: note:
> each undeclared identifier is reported only once for each function it
> appears in
> make[2]: *** [core/CMakeFiles/ROSS.dir/hash-quadratic.c.o] Error 1
> make[1]: *** [core/CMakeFiles/ROSS.dir/all] Error 2
> make: *** [all] Error 2
> Please suggest how to fix this error.
> Thanks,
> Sughosh
> On Thu, Jan 29, 2015 at 10:34 PM, Elsa Gonsiorowski <gonsie at rpi.edu>
> wrote:
> Once you download the ROSS repo run these two commands:
> git submodule init
> git submodule update
> Then clear out your build directory and try CMake again.
> Please let me know if that doesn't work!
> Elsa Gonsiorowski
> On 2015/01/29, at 18:57, Sughosh Divanji <sdivanji at hawk.iit.edu> wrote:
> Hi all,
> I am trying to install ROSS and I am following the instructions on "
> https://github.com/carothersc/ROSS/wiki/Installation".
> git clone is successful. But cmake fails with following reason:
> CMake Error at core/CMakeLists.txt:67 (INCLUDE):
> CMake Error at core/CMakeLists.txt:68 (GET_GIT_HEAD_REVISION):
>   Unknown CMake command "GET_GIT_HEAD_REVISION".
> -- Configuring incomplete, errors occurred!
> At first I tried compiling without DROSS_BUILD_MODELS option because the
> recent changes are yet to be re-integrated in code base. And also, I am
> getting the same error with DROSS_BUILD_MODELS option as well.
> Please let me know how to fix this.
> Thanks,
> Sughosh
> codes-ross-users mailing list
> codes-ross-users at lists.mcs.anl.gov
> https://lists.mcs.anl.gov/mailman/listinfo/codes-ross-users
URL: <http://lists.mcs.anl.gov/pipermail/codes-ross-users/attachments/20150130/aa867e73/attachment-0001.html>
More information about the codes-ross-users mailing list
