[cgma-dev] Build failed in Jenkins: cgm_par #969
jenkins-ci at mcs.anl.gov jenkins-ci at mcs.anl.gov
Sun Nov 15 00:05:14 CST 2015
See <https://jenkins-ci.mcs.anl.gov/job/cgm_par/969/changes>
Changes:
[iulian] test edge orient was not reporting correctly
[wuda] Updated CGM version to 14.9
[wuda] Added a small test case to export a body (cylinder) to an ACIS SAT file.
[wuda] These header files are exactly the same in CGMA14.0 and CGMSandia14.0, so we can safely replace them with CGMSandia14.9 versions.
[wuda] These header files are different in CGMA14.0 and CGMSandia14.0, so we should manually merge them with CGMSandia14.9 versions.
[wuda] Added some new header files from CGMSandia14.9
[wuda] Fixed all build errors caused by updated header files.
[wuda] A workaround (register attribute 43 as a dummy one) for make check to pass.
[wuda] MOAB with this version of CGM needs some new header files installed.
[wuda] Disable specific warnings: anonymous variadic macros were introduced in C99 [-Wvariadic-macros]
[wuda] itaps test executables are not linking on cubit 14.9 (this is only in shared mode, fixed by Iulian Grindeanu).
[wuda] For the time being, register dummy attribute type 43 for OCC-based CGM as well.
[wuda] DLIListSorter prevents classes using DLIList from being sorted by pointer. However, in OCCCurve::get_interior_extrema(), DLIList<CubitVector*> point_list needs to be sorted. Comment out DLIListSorter in DLIList::sort() for the time being.
[wuda] These source files are exactly the same in CGMA14.0 and CGMSandia14.0, so we can safely replace them with CGMSandia14.9 versions.
[wuda] These source files are different in CGMA14.0 and CGMSandia14.0, so we should manually merge them with CGMSandia14.9 versions.
[wuda] Fix build errors from some .hpp and .cpp files under geom/OCC/
[wuda] Added some new header files and source files from CGMSandia14.9. Some of them are actually not new: FacetProjectTool.*pp and PST_Data.*pp are moved from geom/virtual to geom/facet. CCbuitFile.cpp is exactly the same as the original CubitFile.cpp (Note: GMSandia14.9 has totally rewritten CubitFile.cpp for another new class).
[wuda] Deleted some files that are no longer in CGMSandia14.9
[wuda] Updated some Makefiles for deleted and added files.
[wuda] Fixed an error in geom/facet/Makefile.am
[wuda] Fix build errors from test/modify.cpp
[wuda] Fix more build errors from OCC unit tests.
[wuda] Manually merge a few more files to have both CGMA14.0 and CGMSandia14.9 changes.
[wuda] BasicTopologyEntity has a static_cast from CGMSandia14.9 changing that back to dynamic_cast.
[wuda] Adding step file for make distcheck to work
[wuda] Remove from CMakeLists.txt files that are not there.
[wuda] cmake build fixes
[wuda] remove missing files from CMakeLists.txt
[wuda] Change WIN32 to _WIN32 for some files copied from CGMSandia14.9
[iulian] missing file from installation
[iulian] prepare for cgm 15.0 release
[iulian] version 15.0
[iulian] add to distribution mesh files
[wuda] Fix some compiler warnings during make and make check.
[wuda] Fix some errors during make distcheck.
[wuda] Fix some compiler warnings from two CGM header files when building MOAB: declaration of ‘end’ shadows a member of 'this', unused parameter 'face', unused parameter 'loop_list'.
[...truncated 369 lines...]
mv -f .deps/TestUtilities.Tpo .deps/TestUtilities.Plo
/bin/sh ../libtool  --tag=CXX   --mode=link /homes/fathom/3rdparty/mpich2/mpich2-1.5/gcc/bin/mpicxx  -Wall -pipe -pedantic -Wno-variadic-macros -O2 -DNDEBUG   -o libcgm_test.la  TestUtilities.lo  -lm
libtool: link: rm -fr  .libs/libcgm_test.a .libs/libcgm_test.la
libtool: link: ar cru .libs/libcgm_test.a  TestUtilities.o
libtool: link: ranlib .libs/libcgm_test.a
libtool: link: ( cd ".libs" && rm -f "libcgm_test.la" && ln -s "../libcgm_test.la" "libcgm_test.la" )
make[2]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/cgm_par/ws/test'>
make[1]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/cgm_par/ws/'>
+ make check
Making check in compat
make[1]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/cgm_par/ws/compat'>
make[1]: Nothing to be done for `check'.
make[1]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/cgm_par/ws/compat'>
Making check in util
make[1]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/cgm_par/ws/util'>
make[1]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/cgm_par/ws/util'>
Making check in geom
make[1]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/cgm_par/ws/geom'>
Making check in .
make[2]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/cgm_par/ws/geom'>
make[2]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/cgm_par/ws/geom'>
Making check in Cholla
make[2]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/cgm_par/ws/geom/Cholla'>
make[2]: Nothing to be done for `check'.
make[2]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/cgm_par/ws/geom/Cholla'>
Making check in facetbool
make[2]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/cgm_par/ws/geom/facetbool'>
make[2]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/cgm_par/ws/geom/facetbool'>
make[2]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/cgm_par/ws/geom/facet'>
make[2]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/cgm_par/ws/geom/facet'>
Making check in virtual
make[2]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/cgm_par/ws/geom/virtual'>
make[2]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/cgm_par/ws/geom/virtual'>
Making check in parallel
make[2]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/cgm_par/ws/geom/parallel'>
make[2]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/cgm_par/ws/geom/parallel'>
make[1]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/cgm_par/ws/geom'>
Making check in init
make[1]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/cgm_par/ws/init'>
make[1]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/cgm_par/ws/init'>
Making check in .
make[1]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/cgm_par/ws/'>
Making check in itaps
make[1]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/cgm_par/ws/itaps'>
make  check-recursive
make[2]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/cgm_par/ws/itaps'>
Making check in .
make[3]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/cgm_par/ws/itaps'>
make  chaman test_edge_orient  testgeom
make[4]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/cgm_par/ws/itaps'>
/homes/fathom/3rdparty/mpich2/mpich2-1.5/gcc/bin/mpicxx -DHAVE_CONFIG_H -I. -I.. -I../geom/parallel -I../geom  -DLITTLE_ENDIAN=BYTE_ORDER   -DTEMPLATE_DEFS_INCLUDED -DHAVE_ACIS  -DSRCDIR=. -I../util -I../util -I../geom -I../init -I../init -I../geom/parallel -DUSE_MPI    -Wall -pipe -pedantic -Wno-variadic-macros -O2 -DNDEBUG -MT chaman.o -MD -MP -MF .deps/chaman.Tpo -c -o chaman.o chaman.cc
mv -f .deps/chaman.Tpo .deps/chaman.Po
/bin/sh ../libtool  --tag=CXX   --mode=link /homes/fathom/3rdparty/mpich2/mpich2-1.5/gcc/bin/mpicxx  -Wall -pipe -pedantic -Wno-variadic-macros -O2 -DNDEBUG -Wl,-rpath,/homes/fathom/3rdparty/cubit/Cubit64/cubit-14.0/bin -L/homes/fathom/3rdparty/cubit/Cubit64/cubit-14.0/bin  -o chaman chaman.o libiGeom.la ../libcgm.la -lcubit_util  -lm
libtool: link: /homes/fathom/3rdparty/mpich2/mpich2-1.5/gcc/bin/mpicxx -Wall -pipe -pedantic -Wno-variadic-macros -O2 -DNDEBUG -Wl,-rpath -Wl,/homes/fathom/3rdparty/cubit/Cubit64/cubit-14.0/bin -o chaman chaman.o  -L/homes/fathom/3rdparty/cubit/Cubit64/cubit-14.0/bin ./.libs/libiGeom.a -L./src/mpl -L./src/openpa/src ../.libs/libcgm.a /homes/fathom/3rdparty/mpich2/mpich2-1.5/gcc/lib/libmpichcxx.so /homes/fathom/3rdparty/mpich2/mpich2-1.5/gcc/lib/libmpich.so -lrt /homes/fathom/3rdparty/mpich2/mpich2-1.5/gcc/lib/libopa.so -lpthread /homes/fathom/3rdparty/mpich2/mpich2-1.5/gcc/lib/libmpl.so -lcubiti19 -lcubit_geom -lcubit_util -lm -Wl,-rpath -Wl,/homes/fathom/3rdparty/mpich2/mpich2-1.5/gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/mpich2/mpich2-1.5/gcc/lib
./.libs/libiGeom.a(iGeom_CGMA.o): In function `igeom_copyent_':
iGeom_CGMA.cc:(.text+0xb9cf): undefined reference to `GeometryModifyTool::copy_body(Body*, std::map<RefEntity*, RefEntity*, std::less<RefEntity*>, std::allocator<std::pair<RefEntity* const, RefEntity*> > >*)'
./.libs/libiGeom.a(iGeom_CGMA.o): In function `igeom_sectionent_':
iGeom_CGMA.cc:(.text+0x124ad): undefined reference to `GeometryModifyTool::copy_body(Body*, std::map<RefEntity*, RefEntity*, std::less<RefEntity*>, std::allocator<std::pair<RefEntity* const, RefEntity*> > >*)'
./.libs/libiGeom.a(iGeom_CGMA.o): In function `igeom_uniteents_':
iGeom_CGMA.cc:(.text+0x12af0): undefined reference to `GeometryModifyTool::copy_body(Body*, std::map<RefEntity*, RefEntity*, std::less<RefEntity*>, std::allocator<std::pair<RefEntity* const, RefEntity*> > >*)'
./.libs/libiGeom.a(iGeom_CGMA.o): In function `igeom_intersectents_':
iGeom_CGMA.cc:(.text+0x13027): undefined reference to `GeometryModifyTool::copy_body(Body*, std::map<RefEntity*, RefEntity*, std::less<RefEntity*>, std::allocator<std::pair<RefEntity* const, RefEntity*> > >*)'
iGeom_CGMA.cc:(.text+0x1306a): undefined reference to `GeometryModifyTool::copy_body(Body*, std::map<RefEntity*, RefEntity*, std::less<RefEntity*>, std::allocator<std::pair<RefEntity* const, RefEntity*> > >*)'
./.libs/libiGeom.a(iGeom_CGMA.o):iGeom_CGMA.cc:(.text+0x133d6): more undefined references to `GeometryModifyTool::copy_body(Body*, std::map<RefEntity*, RefEntity*, std::less<RefEntity*>, std::allocator<std::pair<RefEntity* const, RefEntity*> > >*)' follow
./.libs/libiGeom.a(iGeom_CGMA.o): In function `igeom_moveent_':
iGeom_CGMA.cc:(.text+0x13d5a): undefined reference to `GeometryQueryTool::translate(DLIList<Body*>&, CubitVector const&, DLIList<Body*>*, bool, bool)'
iGeom_CGMA.cc:(.text+0x13ede): undefined reference to `GeometryQueryTool::translate(DLIList<Body*>&, CubitVector const&, DLIList<Body*>*, bool, bool)'
iGeom_CGMA.cc:(.text+0x13fea): undefined reference to `GeometryQueryTool::translate(DLIList<BasicTopologyEntity*>&, CubitVector const&, DLIList<BasicTopologyEntity*>*, bool, bool)'
./.libs/libiGeom.a(iGeom_CGMA.o): In function `igeom_reflectent_':
iGeom_CGMA.cc:(.text+0x141ee): undefined reference to `GeometryQueryTool::reflect(DLIList<Body*>&, CubitVector const&, CubitVector const&, DLIList<Body*>*, bool)'
iGeom_CGMA.cc:(.text+0x14310): undefined reference to `GeometryQueryTool::reflect(DLIList<BasicTopologyEntity*>&, CubitVector const&, CubitVector const&, DLIList<BasicTopologyEntity*>*, bool, bool)'
./.libs/libiGeom.a(iGeom_CGMA.o): In function `igeom_rotateent_':
iGeom_CGMA.cc:(.text+0x145dc): undefined reference to `GeometryQueryTool::rotate(DLIList<Body*>&, CubitVector const&, double, DLIList<Body*>*, bool, bool)'
iGeom_CGMA.cc:(.text+0x146f6): undefined reference to `GeometryQueryTool::rotate(DLIList<BasicTopologyEntity*>&, CubitVector const&, double, DLIList<BasicTopologyEntity*>*, bool, bool)'
./.libs/libiGeom.a(iGeom_CGMA.o): In function `_GLOBAL__sub_I_iGeom_entity_type_names':
iGeom_CGMA.cc:(.text.startup+0x28): undefined reference to `CubitColor::CubitColor()'
iGeom_CGMA.cc:(.text.startup+0x3e): undefined reference to `CubitColor::CubitColor(unsigned char, unsigned char, unsigned char, unsigned char)'
iGeom_CGMA.cc:(.text.startup+0x5d): undefined reference to `CubitColor::CubitColor(unsigned char, unsigned char, unsigned char, unsigned char)'
iGeom_CGMA.cc:(.text.startup+0x79): undefined reference to `CubitColor::CubitColor(unsigned char, unsigned char, unsigned char, unsigned char)'
iGeom_CGMA.cc:(.text.startup+0x92): undefined reference to `CubitColor::CubitColor(unsigned char, unsigned char, unsigned char, unsigned char)'
iGeom_CGMA.cc:(.text.startup+0xab): undefined reference to `CubitColor::CubitColor(unsigned char, unsigned char, unsigned char, unsigned char)'
./.libs/libiGeom.a(iGeom_CGMA.o):iGeom_CGMA.cc:(.text.startup+0xc7): more undefined references to `CubitColor::CubitColor(unsigned char, unsigned char, unsigned char, unsigned char)' follow
./.libs/libiGeom.a(InitCGMA.o): In function `InitCGMA::initialize_cgma(char const*)':
InitCGMA.cpp:(.text+0xfc): undefined reference to `CubitString::format(char const*, ...)'
InitCGMA.cpp:(.text+0x10e): undefined reference to `CubitMessage::print_error(CubitString const&)'
InitCGMA.cpp:(.text+0x3c9): undefined reference to `CubitString::format(char const*, ...)'
InitCGMA.cpp:(.text+0x3db): undefined reference to `CubitMessage::print_error(CubitString const&)'
./.libs/libiGeom.a(InitCGMA.o): In function `_GLOBAL__sub_I__Z22CAAssemblyData_creatorP9RefEntityRK17CubitSimpleAttrib':
InitCGMA.cpp:(.text.startup+0xa): undefined reference to `CubitColor::CubitColor()'
InitCGMA.cpp:(.text.startup+0x20): undefined reference to `CubitColor::CubitColor(unsigned char, unsigned char, unsigned char, unsigned char)'
InitCGMA.cpp:(.text.startup+0x3f): undefined reference to `CubitColor::CubitColor(unsigned char, unsigned char, unsigned char, unsigned char)'
InitCGMA.cpp:(.text.startup+0x5b): undefined reference to `CubitColor::CubitColor(unsigned char, unsigned char, unsigned char, unsigned char)'
InitCGMA.cpp:(.text.startup+0x74): undefined reference to `CubitColor::CubitColor(unsigned char, unsigned char, unsigned char, unsigned char)'
InitCGMA.cpp:(.text.startup+0x8d): undefined reference to `CubitColor::CubitColor(unsigned char, unsigned char, unsigned char, unsigned char)'
./.libs/libiGeom.a(InitCGMA.o):InitCGMA.cpp:(.text.startup+0xa9): more undefined references to `CubitColor::CubitColor(unsigned char, unsigned char, unsigned char, unsigned char)' follow
./.libs/libiGeom.a(CGMParallelComm.o): In function `CGMParallelComm::broadcast_entities(unsigned int, DLIList<RefEntity*>&)':
CGMParallelComm.cpp:(.text+0x319): undefined reference to `CubitString::format(char const*, ...)'
CGMParallelComm.cpp:(.text+0x32b): undefined reference to `CubitMessage::print_error(CubitString const&)'
CGMParallelComm.cpp:(.text+0x3d4): undefined reference to `CubitString::format(char const*, ...)'
CGMParallelComm.cpp:(.text+0x3e6): undefined reference to `CubitMessage::print_error(CubitString const&)'
CGMParallelComm.cpp:(.text+0x497): undefined reference to `CubitString::format(char const*, ...)'
CGMParallelComm.cpp:(.text+0x4a9): undefined reference to `CubitMessage::print_error(CubitString const&)'
CGMParallelComm.cpp:(.text+0x562): undefined reference to `CubitString::format(char const*, ...)'
CGMParallelComm.cpp:(.text+0x574): undefined reference to `CubitMessage::print_error(CubitString const&)'
./.libs/libiGeom.a(CGMParallelComm.o): In function `CGMParallelComm::append_to_buffer(DLIList<RefEntity*>&, int)':
CGMParallelComm.cpp:(.text+0x701): undefined reference to `CubitString::format(char const*, ...)'
CGMParallelComm.cpp:(.text+0x713): undefined reference to `CubitMessage::print_error(CubitString const&)'
./.libs/libiGeom.a(CGMParallelComm.o): In function `CGMParallelComm::scatter_entities(unsigned int, DLIList<RefEntity*>&)':
CGMParallelComm.cpp:(.text+0x1089): undefined reference to `CubitString::format(char const*, ...)'
CGMParallelComm.cpp:(.text+0x109e): undefined reference to `CubitMessage::print_error(CubitString const&)'
CGMParallelComm.cpp:(.text+0x110d): undefined reference to `CubitString::format(char const*, ...)'
CGMParallelComm.cpp:(.text+0x111f): undefined reference to `CubitMessage::print_error(CubitString const&)'
./.libs/libiGeom.a(CGMParallelComm.o): In function `_GLOBAL__sub_I__ZN15CGMParallelCommC2Ei':
CGMParallelComm.cpp:(.text.startup+0xa): undefined reference to `CubitColor::CubitColor()'
CGMParallelComm.cpp:(.text.startup+0x20): undefined reference to `CubitColor::CubitColor(unsigned char, unsigned char, unsigned char, unsigned char)'
CGMParallelComm.cpp:(.text.startup+0x3f): undefined reference to `CubitColor::CubitColor(unsigned char, unsigned char, unsigned char, unsigned char)'
CGMParallelComm.cpp:(.text.startup+0x5b): undefined reference to `CubitColor::CubitColor(unsigned char, unsigned char, unsigned char, unsigned char)'
CGMParallelComm.cpp:(.text.startup+0x74): undefined reference to `CubitColor::CubitColor(unsigned char, unsigned char, unsigned char, unsigned char)'
CGMParallelComm.cpp:(.text.startup+0x8d): undefined reference to `CubitColor::CubitColor(unsigned char, unsigned char, unsigned char, unsigned char)'
./.libs/libiGeom.a(CGMParallelComm.o):CGMParallelComm.cpp:(.text.startup+0xa9): more undefined references to `CubitColor::CubitColor(unsigned char, unsigned char, unsigned char, unsigned char)' follow
./.libs/libiGeom.a(CGMReadParallel.o): In function `CGMReadParallel::read_entities(char const*)':
CGMReadParallel.cpp:(.text+0x12b): undefined reference to `CubitString::format(char const*, ...)'
CGMReadParallel.cpp:(.text+0x140): undefined reference to `CubitMessage::print_error(CubitString const&)'
CGMReadParallel.cpp:(.text+0x1fa): undefined reference to `CubitString::format(char const*, ...)'
CGMReadParallel.cpp:(.text+0x20f): undefined reference to `CubitMessage::print_error(CubitString const&)'
CGMReadParallel.cpp:(.text+0x337): undefined reference to `CubitString::format(char const*, ...)'
CGMReadParallel.cpp:(.text+0x34c): undefined reference to `CubitMessage::print_error(CubitString const&)'
./.libs/libiGeom.a(CGMReadParallel.o): In function `CGMReadParallel::check_partition_info()':
CGMReadParallel.cpp:(.text+0x62f): undefined reference to `CubitString::format(char const*, ...)'
CGMReadParallel.cpp:(.text+0x641): undefined reference to `CubitMessage::print_error(CubitString const&)'
CGMReadParallel.cpp:(.text+0x887): undefined reference to `CubitString::format(char const*, ...)'
CGMReadParallel.cpp:(.text+0x89c): undefined reference to `CubitMessage::print_error(CubitString const&)'
./.libs/libiGeom.a(CGMReadParallel.o): In function `CGMReadParallel::balance_round_robin()':
CGMReadParallel.cpp:(.text+0x15c3): undefined reference to `CubitString::format(char const*, ...)'
CGMReadParallel.cpp:(.text+0x15d8): undefined reference to `CubitMessage::print_error(CubitString const&)'
CGMReadParallel.cpp:(.text+0x1982): undefined reference to `CubitString::format(char const*, ...)'
CGMReadParallel.cpp:(.text+0x1997): undefined reference to `CubitMessage::print_error(CubitString const&)'
./.libs/libiGeom.a(CGMReadParallel.o): In function `CGMReadParallel::delete_nonlocal_entities(int, std::basic_string<char, std::char_traits<char>, std::allocator<char> >&, std::vector<int, std::allocator<int> >&)':
CGMReadParallel.cpp:(.text+0x2a6d): undefined reference to `CubitString::format(char const*, ...)'
CGMReadParallel.cpp:(.text+0x2a82): undefined reference to `CubitMessage::print_error(CubitString const&)'
./.libs/libiGeom.a(CGMReadParallel.o): In function `CGMReadParallel::load_file(char const*, int, std::basic_string<char, std::char_traits<char>, std::allocator<char> >&, std::vector<int, std::allocator<int> >&, std::vector<int, std::allocator<int> >&, CGMFileOptions const&, char const*, int const*, int, int, bool)':
CGMReadParallel.cpp:(.text+0x3005): undefined reference to `CubitString::format(char const*, ...)'
CGMReadParallel.cpp:(.text+0x301a): undefined reference to `CubitMessage::print_error(CubitString const&)'
CGMReadParallel.cpp:(.text+0x3063): undefined reference to `CubitString::format(char const*, ...)'
CGMReadParallel.cpp:(.text+0x3075): undefined reference to `CubitMessage::print_error(CubitString const&)'
CGMReadParallel.cpp:(.text+0x30d2): undefined reference to `CubitString::format(char const*, ...)'
CGMReadParallel.cpp:(.text+0x30e4): undefined reference to `CubitMessage::print_error(CubitString const&)'
CGMReadParallel.cpp:(.text+0x3124): undefined reference to `CubitString::format(char const*, ...)'
CGMReadParallel.cpp:(.text+0x3136): undefined reference to `CubitMessage::print_error(CubitString const&)'
CGMReadParallel.cpp:(.text+0x3173): undefined reference to `CubitString::format(char const*, ...)'
CGMReadParallel.cpp:(.text+0x3185): undefined reference to `CubitMessage::print_error(CubitString const&)'
CGMReadParallel.cpp:(.text+0x31a7): undefined reference to `CubitString::format(char const*, ...)'
CGMReadParallel.cpp:(.text+0x31b9): undefined reference to `CubitMessage::print_error(CubitString const&)'
./.libs/libiGeom.a(CGMReadParallel.o): In function `CGMReadParallel::load_file(char const*, char const*, char const*, int const*, int)':
CGMReadParallel.cpp:(.text+0x3458): undefined reference to `CubitString::format(char const*, ...)'
CGMReadParallel.cpp:(.text+0x346d): undefined reference to `CubitMessage::print_error(CubitString const&)'
CGMReadParallel.cpp:(.text+0x3504): undefined reference to `CubitString::format(char const*, ...)'
CGMReadParallel.cpp:(.text+0x3519): undefined reference to `CubitMessage::print_error(CubitString const&)'
CGMReadParallel.cpp:(.text+0x3557): undefined reference to `CubitString::format(char const*, ...)'
CGMReadParallel.cpp:(.text+0x356c): undefined reference to `CubitMessage::print_error(CubitString const&)'
CGMReadParallel.cpp:(.text+0x38b0): undefined reference to `CubitString::format(char const*, ...)'
CGMReadParallel.cpp:(.text+0x38c5): undefined reference to `CubitMessage::print_error(CubitString const&)'
CGMReadParallel.cpp:(.text+0x3918): undefined reference to `CubitString::format(char const*, ...)'
CGMReadParallel.cpp:(.text+0x392d): undefined reference to `CubitMessage::print_error(CubitString const&)'
./.libs/libiGeom.a(CGMReadParallel.o): In function `_GLOBAL__sub_I_CGMParallelActionsNames':
CGMReadParallel.cpp:(.text.startup+0xa): undefined reference to `CubitColor::CubitColor()'
CGMReadParallel.cpp:(.text.startup+0x20): undefined reference to `CubitColor::CubitColor(unsigned char, unsigned char, unsigned char, unsigned char)'
CGMReadParallel.cpp:(.text.startup+0x3f): undefined reference to `CubitColor::CubitColor(unsigned char, unsigned char, unsigned char, unsigned char)'
CGMReadParallel.cpp:(.text.startup+0x5b): undefined reference to `CubitColor::CubitColor(unsigned char, unsigned char, unsigned char, unsigned char)'
CGMReadParallel.cpp:(.text.startup+0x74): undefined reference to `CubitColor::CubitColor(unsigned char, unsigned char, unsigned char, unsigned char)'
CGMReadParallel.cpp:(.text.startup+0x8d): undefined reference to `CubitColor::CubitColor(unsigned char, unsigned char, unsigned char, unsigned char)'
./.libs/libiGeom.a(CGMReadParallel.o):CGMReadParallel.cpp:(.text.startup+0xa9): more undefined references to `CubitColor::CubitColor(unsigned char, unsigned char, unsigned char, unsigned char)' follow
./.libs/libiGeom.a(TDParallel.o): In function `TDParallel::TDParallel(ToolDataUser*, DLIList<int>*, DLIList<int>*, DLIList<int>*, int, int)':
TDParallel.cpp:(.text+0xc18): undefined reference to `CubitString::format(char const*, ...)'
TDParallel.cpp:(.text+0xc2a): undefined reference to `CubitMessage::print_error(CubitString const&)'
./.libs/libiGeom.a(TDParallel.o): In function `_GLOBAL__sub_I__ZN10TDParallelC2EP12ToolDataUserP7DLIListIiES4_S4_ii':
TDParallel.cpp:(.text.startup+0xa): undefined reference to `CubitColor::CubitColor()'
TDParallel.cpp:(.text.startup+0x20): undefined reference to `CubitColor::CubitColor(unsigned char, unsigned char, unsigned char, unsigned char)'
TDParallel.cpp:(.text.startup+0x3f): undefined reference to `CubitColor::CubitColor(unsigned char, unsigned char, unsigned char, unsigned char)'
TDParallel.cpp:(.text.startup+0x5b): undefined reference to `CubitColor::CubitColor(unsigned char, unsigned char, unsigned char, unsigned char)'
TDParallel.cpp:(.text.startup+0x74): undefined reference to `CubitColor::CubitColor(unsigned char, unsigned char, unsigned char, unsigned char)'
TDParallel.cpp:(.text.startup+0x8d): undefined reference to `CubitColor::CubitColor(unsigned char, unsigned char, unsigned char, unsigned char)'
./.libs/libiGeom.a(TDParallel.o):TDParallel.cpp:(.text.startup+0xa9): more undefined references to `CubitColor::CubitColor(unsigned char, unsigned char, unsigned char, unsigned char)' follow
./.libs/libiGeom.a(CATag.o): In function `CGMTagManager::pc_list(RefEntity*, std::vector<RefGroup*, std::allocator<RefGroup*> >*&, std::vector<RefGroup*, std::allocator<RefGroup*> >*&, bool)':
CATag.cpp:(.text+0x2e6d): undefined reference to `CubitString::format(char const*, ...)'
CATag.cpp:(.text+0x2e7f): undefined reference to `CubitMessage::print_error(CubitString const&)'
CATag.cpp:(.text+0x2f07): undefined reference to `CubitString::format(char const*, ...)'
CATag.cpp:(.text+0x2f19): undefined reference to `CubitMessage::print_error(CubitString const&)'
./.libs/libiGeom.a(CATag.o): In function `CGMTagManager::pc_list(RefEntity*, int, bool)':
CATag.cpp:(.text+0x30ed): undefined reference to `CubitString::format(char const*, ...)'
CATag.cpp:(.text+0x30ff): undefined reference to `CubitMessage::print_error(CubitString const&)'
CATag.cpp:(.text+0x3121): undefined reference to `CubitString::format(char const*, ...)'
CATag.cpp:(.text+0x3133): undefined reference to `CubitMessage::print_error(CubitString const&)'
./.libs/libiGeom.a(CATag.o): In function `_GLOBAL__sub_I__ZN13CGMTagManager10CATag_NAMEE':
CATag.cpp:(.text.startup+0x29): undefined reference to `CubitColor::CubitColor()'
CATag.cpp:(.text.startup+0x3f): undefined reference to `CubitColor::CubitColor(unsigned char, unsigned char, unsigned char, unsigned char)'
CATag.cpp:(.text.startup+0x5e): undefined reference to `CubitColor::CubitColor(unsigned char, unsigned char, unsigned char, unsigned char)'
CATag.cpp:(.text.startup+0x7a): undefined reference to `CubitColor::CubitColor(unsigned char, unsigned char, unsigned char, unsigned char)'
CATag.cpp:(.text.startup+0x93): undefined reference to `CubitColor::CubitColor(unsigned char, unsigned char, unsigned char, unsigned char)'
CATag.cpp:(.text.startup+0xac): undefined reference to `CubitColor::CubitColor(unsigned char, unsigned char, unsigned char, unsigned char)'
./.libs/libiGeom.a(CATag.o):CATag.cpp:(.text.startup+0xc8): more undefined references to `CubitColor::CubitColor(unsigned char, unsigned char, unsigned char, unsigned char)' follow
./.libs/libiGeom.a(CABodies.o): In function `CABodies::actuate()':
CABodies.cpp:(.text+0x15e): undefined reference to `CubitString::format(char const*, ...)'
CABodies.cpp:(.text+0x170): undefined reference to `CubitMessage::print_error(CubitString const&)'
CABodies.cpp:(.text+0x1d2): undefined reference to `CubitString::format(char const*, ...)'
CABodies.cpp:(.text+0x1e4): undefined reference to `CubitMessage::print_debug(CubitString const&)'
CABodies.cpp:(.text+0x2e5): undefined reference to `CubitString::format(char const*, ...)'
CABodies.cpp:(.text+0x2f7): undefined reference to `CubitMessage::print_error(CubitString const&)'
CABodies.cpp:(.text+0x430): undefined reference to `CubitString::format(char const*, ...)'
CABodies.cpp:(.text+0x442): undefined reference to `CubitMessage::print_error(CubitString const&)'
CABodies.cpp:(.text+0x530): undefined reference to `CubitString::format(char const*, ...)'
CABodies.cpp:(.text+0x542): undefined reference to `CubitMessage::print_error(CubitString const&)'
CABodies.cpp:(.text+0x597): undefined reference to `CubitString::format(char const*, ...)'
CABodies.cpp:(.text+0x5a9): undefined reference to `CubitMessage::print_error(CubitString const&)'
./.libs/libiGeom.a(CABodies.o): In function `CABodies::CABodies(RefEntity*)':
CABodies.cpp:(.text+0x996): undefined reference to `CubitString::format(char const*, ...)'
CABodies.cpp:(.text+0x9a6): undefined reference to `CubitMessage::print_debug(CubitString const&)'
./.libs/libiGeom.a(CABodies.o): In function `CABodies::CABodies(RefEntity*, CubitSimpleAttrib*)':
CABodies.cpp:(.text+0x14ac): undefined reference to `CubitString::format(char const*, ...)'
CABodies.cpp:(.text+0x14be): undefined reference to `CubitMessage::print_debug(CubitString const&)'
./.libs/libiGeom.a(CABodies.o): In function `CABodies::update()':
CABodies.cpp:(.text+0x1b30): undefined reference to `CubitString::format(char const*, ...)'
CABodies.cpp:(.text+0x1b40): undefined reference to `CubitMessage::print_debug(CubitString const&)'
./.libs/libiGeom.a(CABodies.o): In function `_GLOBAL__sub_I__Z16CABodies_creatorP9RefEntityRK17CubitSimpleAttrib':
CABodies.cpp:(.text.startup+0xa): undefined reference to `CubitColor::CubitColor()'
CABodies.cpp:(.text.startup+0x20): undefined reference to `CubitColor::CubitColor(unsigned char, unsigned char, unsigned char, unsigned char)'
CABodies.cpp:(.text.startup+0x3f): undefined reference to `CubitColor::CubitColor(unsigned char, unsigned char, unsigned char, unsigned char)'
CABodies.cpp:(.text.startup+0x5b): undefined reference to `CubitColor::CubitColor(unsigned char, unsigned char, unsigned char, unsigned char)'
CABodies.cpp:(.text.startup+0x74): undefined reference to `CubitColor::CubitColor(unsigned char, unsigned char, unsigned char, unsigned char)'
CABodies.cpp:(.text.startup+0x8d): undefined reference to `CubitColor::CubitColor(unsigned char, unsigned char, unsigned char, unsigned char)'
./.libs/libiGeom.a(CABodies.o):CABodies.cpp:(.text.startup+0xa9): more undefined references to `CubitColor::CubitColor(unsigned char, unsigned char, unsigned char, unsigned char)' follow
collect2: ld returned 1 exit status
make[4]: *** [chaman] Error 1
make[4]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/cgm_par/ws/itaps'>
make[3]: *** [check-am] Error 2
make[3]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/cgm_par/ws/itaps'>
make[2]: *** [check-recursive] Error 1
make[2]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/cgm_par/ws/itaps'>
make[1]: *** [check] Error 2
make[1]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/cgm_par/ws/itaps'>
make: *** [check-recursive] Error 1
Build step 'Execute shell' marked build as failure
More information about the cgma-dev mailing list
