[cgma-dev] cgma-dev Digest, Vol 81, Issue 3
Andrew Davis
andrewdavis.davis at gmail.com
Tue Aug 25 12:06:35 CDT 2015
Hi Evan
My assumption would be that it was converted via Cubit from the equivalent
*.sat file.
Looking at git blame its from Hong-Jun Kim (stp), the sat is from Iulian.
However, the stp is older than the sat by about a year
Andy
On Tue, Aug 25, 2015 at 12:00 PM, <cgma-dev-request at mcs.anl.gov> wrote:
> Send cgma-dev mailing list submissions to
> cgma-dev at mcs.anl.gov
> To subscribe or unsubscribe via the World Wide Web, visit
> https://lists.mcs.anl.gov/mailman/listinfo/cgma-dev
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> cgma-dev-owner at mcs.anl.gov
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of cgma-dev digest..."
> Today's Topics:
> 1. CGM brick orientation test (Vander Zee, Evan B.)
> Message: 1
> Date: Tue, 25 Aug 2015 16:54:28 +0000
> From: "Vander Zee, Evan B." <vanderzee at anl.gov>
> To: "Jain, Rajeev" <jain at mcs.anl.gov>
> Cc: "cgma-dev at mcs.anl.gov" <cgma-dev at mcs.anl.gov>
> Subject: [cgma-dev] CGM brick orientation test
> Message-ID: <553D5F34658FB846ACEA00D6140EAC6897ADB09F at PAYTON.anl.gov>
> Content-Type: text/plain; charset="us-ascii"
> Do you know the source of the file itaps/brick_2.stp in the CGM
> repository? It looks to me like the edges in the file have improper edge
> orientations.
> I have some local changes to CGM that, I thought, fix the face-to-volume
> sense bug. I am testing the changes in various ways and learning more
> about OCC and CGM. This version of itaps/brick_2.stp has been used by the
> test_edge_orient test in the itaps directory. I disabled the test
> previously in my edgeFaceSense branch when I fixed an edge-to-face
> orientation problem. I am working on rewriting the test now so that it
> properly tests the face-to-volume sense and the edge-to-face sense for both
> OCC and ACIS.
> I have the face-to-volume part of the test working fine for OCC now, but
> my revised edge orientation part of the test is failing. This part of the
> test tests edge orientation after reading the itaps/brick_2.stp file. When
> I create a 2 x 2 x 2 brick using iGeom_createBrick rather than reading the
> brick from file, my revised edge orientation part of the test passes. If I
> save that brick to a file, then I can also read the file I've saved, and
> the edge orientation part of the test passes.
> I looked at the brick_2.stp file and my human-readable interpretation is
> that the edge orientations are encoded incorrectly. I think I could
> correct it by hand within the file by changing the orientation of some of
> the oriented edges at entities 106 through 144. I want to know whether
> it's okay to do that or the STEP file came from some source outside of CGM
> that we need to be able to support. The brick that CGM writes out after
> iGeom_createBrick is represented quite differently from the way the one in
> itaps/brick_2.stp is represented.
> It would help me if I could get a reference for the geometric STEP
> entities. I have pieced together a few things through Internet searches,
> but I have not been able to find good reference documentation for the parts
> of STEP that are used by CGM. Do you know of any?
> -Evan
> End of cgma-dev Digest, Vol 81, Issue 3
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20150825/c2a233d6/attachment.html>
More information about the cgma-dev
