[cgma-dev] Why can't I create surfaces from curves
Andrew Davis
andrew.davis at wisc.edu
Mon Jul 27 10:01:22 CDT 2015
Hi Patrick
Irrespective of whether or not I use planar, best fit, sphere, its the same
error message over and over again.
Thanks
Andy
On Sat, Jul 25, 2015 at 8:00 AM, Patrick Shriwise <shriwise at wisc.edu> wrote:
> Hey Andy,
> The error message seems to indicate it's trying to make a surface which
> isn't planar.. maybe thats a good starting point? Are there other flags to
> hand that function by chance?
> Cheers,
> Patrick
> On 07/23/2015 02:34 PM, Andrew Davis wrote:
> Hi Guys
> I have the following function that I've added to my version of iGeom,
> ITAPS_API void
> iGeom_createSurface2(iGeom_Instance instance,
> /*in*/ iBase_EntityHandle *input_curves,
> /*in*/ int num_curves,
> /*out*/ iBase_EntityHandle *geom_entity,
> int* err)
> CubitVector p1(0, 0, 5);
> RefVertex* v1 = gmt->make_RefVertex(p1);
> CubitVector p2(0, 0, -5);
> RefVertex* v2 = gmt->make_RefVertex(p2);
> CubitVector p3(0, 5, 0);
> RefVertex* v3 = gmt->make_RefVertex(p3);
> CubitVector p4(0, -5, 0);
> RefVertex* v4 = gmt->make_RefVertex(p4);
> RefEdge* e1 = gmt->make_RefEdge(ARC_CURVE_TYPE,v1,v2,&p3);
> RefEdge* e2 = gmt->make_RefEdge(ARC_CURVE_TYPE,v1,v2,&p4);
> DLIList<RefEdge*> curves;
> curves.insert(e1);
> curves.insert(e2);
> RefFace* tmp_surface = gmt->make_RefFace(PLANE_SURFACE_TYPE,
> curves,
> false);
> *geom_entity = reinterpret_cast<iBase_EntityHandle>(tmp_surface);
> RETURN ((tmp_surface ? iBase_SUCCESS : iBase_FAILURE));
> When I run this, I can sucessfully create the vertices, and create
> curves from those verts using make_RefEdge. When I try to create a surface
> from those two ref edges I get the following error.
> WARNING: In AcisGeometryEngine::make_FACE
> At this time, cannot make a FACE that isn't planar or best fit.
> ERROR: In AcisModifyEngine::make_Surface
> Cannot make Surface object.
> ERROR: Couldn't make new RefFace.
> If I save the file as acis and examine the results in Cubit, they appear
> as they should (minus the surface). I can, in Cubit, make surface then,
> sweep and do all the operations that I want to.
> Is there something that I', just misunderstanding about CGM / gmt that
> means I'm using this wrong?
> Thanks
> Andy
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20150727/db837fa4/attachment.html>
More information about the cgma-dev
