[cgma-dev] copying iGeom entities in occ...
shriwise shriwise at wisc.edu
Tue Aug 19 11:11:04 CDT 2014
Who is our contact for Cubit? Should I ask them directly?
(Sending this a head of time so I don't forget. Paul might have a good
idea on this...)
Patrick
On 08/19/2014 10:57 AM, Tim Tautges wrote:
> Maybe so.  Would help to get a word from cubit people on this...
> - tim
> On 08/19/2014 09:56 AM, shriwise wrote:
>> Agreed, but the function seems to be set up for this scenario as its
>> only behaviour without consideration for a pure
>> copy operation.
>> Patrick
>> On 08/15/2014 05:23 PM, Tim Tautges wrote:
>>> One case I can think of where this happens is in preparation for
>>> certain boolean operations (e.g. subtract with option
>>> to keep the original), you don't want the attributes on the body
>>> being subtracted from the other.
>>> - tim
>>> On 08/06/2014 02:10 PM, Paul Wilson wrote:
>>>> Hi Patrick,
>>>> On 08/06/2014 09:08 AM, Patrick Shriwise wrote:
>>>>> As for the topic at hand, my naive opinion is that attributes on
>>>>> the original should never be removed and transferring
>>>>> these attributes should be optional in both cases. I can't think
>>>>> of a scenario in which you would expect data do be
>>>>> deleted from the original upon copying it. It sounds like this may
>>>>> be the case, but its buried pretty deep? Is that
>>>>> right, Paul?
>>>> I agree.  There must be something more complex happening that we
>>>> don't see/understand.  It seems strange to ever delete
>>>> the attributes from the original entity when making a copy.
>>>> Paul
Patrick C. Shriwise
Research Assistant
University of Wisconsin - Madison
Engineering Research Building - Rm. 428
1500 Engineering Drive
Madison, WI 53706
(608) 446-8173
More information about the cgma-dev mailing list
