[cgma-dev] Inconsistency in getEntities for iGeom interface. Causes problems in iRel.
Paul Wilson wilsonp at engr.wisc.edu
Wed Jul 16 09:16:44 CDT 2014
Patrick,
I think there is a global ID tag (or something similar) that should
probably NOT be overwritten.  I am not sure of others...
Paul
On 07/16/2014 09:15 AM, Patrick Shriwise wrote:
> Are there any default tags that are automatically generated upon
> creating a new entity in cgm? If so, should those be overwritten by
> the tags from the original entity we are copying?
> Patrick
> On 07/16/2014 02:35 AM, Rajeev Jain wrote:
>> I think all of the tags should get copied, but there might be use
>> cases (in-future, I can't think of a case now) where making things
>> more general and allowing a user option for selective or complete
>> copying of tags might prove useful.
>> Rajeev
>> *From:* Paul Wilson <wilsonp at engr.wisc.edu>
>> *To:* "Jain, Rajeev" <jain at mcs.anl.gov>; shriwise
>> <shriwise at wisc.edu>; CGMA Development <cgma-dev at mcs.anl.gov>
>> *Sent:* Wednesday, July 16, 2014 12:09 AM
>> *Subject:* Re: [cgma-dev] Inconsistency in getEntities for iGeom
>> Hi Rajeev,
>> Thanks for the response.  I guess it's still not clear what the
>> expected behavior should be when copying an entity in iGeom.  Should
>> it copy some/none/all of the tags to the new entity?  Is there a
>> standard for what gets copied?
>> Paul
>> On 07/15/2014 08:26 PM, Rajeev Jain wrote:
>>> Sorry, I missed this email.
>>> Yes, you are right. It is for OCC based meshing. The test names
>>> volumes/surfs etc and then tries to retrieve them.
>>> You can ignore the test case as we started working on developing
>>> other missing pieces for OCC geometry based meshing in MeshKit. When
>>> entities are copied the names can be copied with some an additional
>>> letter word under some convention.
>>> Ex. CUBIT uses vol 1 named as mysteel when copied the new vol 2 is
>>> called mysteel at a etc.
>>> Rajeev
>>> *From:* shriwise <shriwise at wisc.edu> <mailto:shriwise at wisc.edu>
>>> *To:* Paul Wilson <wilsonp at engr.wisc.edu>
>>> <mailto:wilsonp at engr.wisc.edu>; "Jain, Rajeev" <jain at mcs.anl.gov>
>>> <mailto:jain at mcs.anl.gov>; CGMA Development <cgma-dev at mcs.anl.gov>
>>> <mailto:cgma-dev at mcs.anl.gov>
>>> *Sent:* Tuesday, July 15, 2014 10:29 AM
>>> Bump.
>>> On 07/11/2014 08:15 PM, Paul Wilson wrote:
>>>> Rajeev,
>>>> You are mentioned in the git logs as the inspiration for the
>>>> copy_attrib test that Patrick mentioned.  (a few years ago)
>>>> I wonder if you have any thoughts on what the purpose and/or
>>>> requirements are for this capability?  You probably needed it for
>>>> RGG based on OCC?
>>>> Paul
>>>> On 07/11/2014 07:21 PM, Patrick Shriwise wrote:
>>>>> Hi all,
>>>>> I'm currently working on the changes to iGeom that Paul previously
>>>>> proposed. I've hit one test when built with OCC (copy_attrib) that
>>>>> suggests that tags are expected to be copied along with an entity
>>>>> when using iGeom functions like copyEnt or subtractEnt. Is this
>>>>> the case? Are these specifc tags that are supposed to be copied if
>>>>> they exist on the original entity?
>>>>> Also to be clear this has become an issue because for volume
>>>>> entities we now use the RefVolume to get the volume Body and make
>>>>> a copy of that body using the GeometryModifyTool. The Body we make
>>>>> a copy of does not have the tags associated with the RefVolume. As
>>>>> a result the new Body and the corresponding RefVolumethat we
>>>>> return from the function does not have the original tags.
>>>>> These tags can be transferred to the new entity before leaving the
>>>>> function of course, but we're looking for the proper way to handle
>>>>> this situation. Mainly it would be good to know if there is a
>>>>> particular tag or tags that should be copied over to new entity
>>>>> upon it's creation.
>>>>> Cheers,
>>>>> Patrick
>>>>> On 06/23/2014 03:06 PM, Paul Wilson wrote:
>>>>>> Hi everyone,
>>>>>> Patrick and I have discussed this and have come up with the
>>>>>> following proposal for a revision of how iGeom_CGMA handles
>>>>>> RefVolumes and Body's.
>>>>>>  1. All references to iBase_REGION will refer only to entities of
>>>>>>     type RefVolume in CGM.
>>>>>>  2. All entities that are returned by iGeom will be RefEntities
>>>>>>     and not CubitEntities
>>>>>>  3. At the time of loading file, based on an option based to
>>>>>>     iGeom_load(), all entities of type Body in CGM that contain
>>>>>>     more than a single volume, will be converted to RefGroup's
>>>>>>     and tagged to distinguish them from the original RefGroup's
>>>>>> The last of these may be subject to the most conversation, but it
>>>>>> seemed like a useful approach to use because it:
>>>>>>   * had little to no effect on the API of iGeom
>>>>>>   * preserves access to CGM/ACIS bodies
>>>>>>   * is the least intrusive in the implementation of iGeom_CGMA
>>>>>> If a user does NOT pass in the option (e.g.
>>>>>> "CONVERT_BODY_TO_GROUP"), then no bodies will be accessible
>>>>>> through iGeom. If a user does pass in this option, any call to
>>>>>> iGeom_getEntSets will return both the original RefGroups and the
>>>>>> additional RefGroups that were generated automatically from
>>>>>> Bodies. It will be up to the user to filter between them using
>>>>>> the available tag.
>>>>>> Finally, since every RefVolume in ACIS always has a Body in which
>>>>>> it is a member, it seems best to only convert Bodies that contain
>>>>>> >1 RefVolume to avoid creating far more RefGroups than necessary.
>>>>>> We'd like to embark on these changes soon, but welcome any
>>>>>> comments or feedback.  I'm sure we've missed something!
>>>>>> Paul
>>>>>> On 06/17/2014 09:00 AM, Jane Hu wrote:
>>>>>>> So, I will add RefVolume to the return list
>>>>>>> of iGeom_get_adjacent_entities() as the result of the discussion.
>>>>>>> CubitEntity only has derived classes of RefEntity
>>>>>>> and CubitCoordinateSystem, iGeom_CGMA.cc only uses RefEntity as
>>>>>>> instance of the object.
>>>>>>> Jane
>>>>>>> On Mon, Jun 16, 2014 at 11:35 AM, Jane Hu <janejhu at gmail.com
>>>>>>> <mailto:janejhu at gmail.com>> wrote:
>>>>>>>     See comments below...
>>>>>>>     On Mon, Jun 16, 2014 at 10:22 AM, Paul Wilson
>>>>>>>     <wilsonp at engr.wisc.edu <mailto:wilsonp at engr.wisc.edu>> wrote:
>>>>>>>         Hi Jane,
>>>>>>>         I think this needs a thorough review! Patrick and I
>>>>>>>         hunted through iGeom_CGMA and found some inconsistencies
>>>>>>>         in a few places.
>>>>>>>         First, there is an inconsistency between returning
>>>>>>>         pointers to RefEntity and pointers to CubitEntity. This
>>>>>>>         is probably less important, but should probably be
>>>>>>>         resolved in any change.
>>>>>>>     I see RefEntity is inherited from CubitEntity, and
>>>>>>>     CubitEntity is a pure virtual class. So even you
>>>>>>>     got pointers to CubitEntity, you have to instantiate it to
>>>>>>>     RefEntity objects.
>>>>>>>         Second, there are places where the geometry is queried
>>>>>>>         for entities of dimension=3 (returning RefVolumes) and
>>>>>>>         places where the geometry is queried for entities of
>>>>>>>         type=iGeom_REGION (== Body).
>>>>>>>     In this case, I can return both bodies and refvolumes, so
>>>>>>>     after user gets the refentity list back, he can cast to see
>>>>>>>     if they are bodies or refvolumes, and choose to keep what
>>>>>>>     ever he needs.
>>>>>>>         This means that 2 calls into the interface that should
>>>>>>>         resolve to the same entity may not do so for both reasons.
>>>>>>>         All of this is related to the fundamental difference
>>>>>>>         between the iGeom types (equivalent to vertex, edge,
>>>>>>>         face, volume) and the CGM/ACIS types (equiavlent to
>>>>>>>         vertex, edge, face, volume, body).  I think Tim's
>>>>>>>         suggestion is the best, but will require some
>>>>>>>         substantial effort.
>>>>>>>         Paul
>>>>>>>         On 06/16/2014 10:14 AM, Jane Hu wrote:
>>>>>>>>         I see in iGeom_CGMA.cc file,
>>>>>>>>         function iGeom_get_adjacent_entities, if asks for 3-D
>>>>>>>>         refentities, it returns body list. In CGM, bodies are
>>>>>>>>         not necessary to be 3-D entities, it may contain single
>>>>>>>>         surface or shell. Should we change the return to be
>>>>>>>>         only refvolumes which are 3-D entities (I prefer this,
>>>>>>>>         makes more sense)? Or I can return both bodies and
>>>>>>>>         refvolumes in the returned refentity list. Depending on
>>>>>>>>         your user case, I can return one of the two choices.
>>>>>>>>         Jane
>>>>>>>>         On Mon, Jun 16, 2014 at 9:32 AM, Jane Hu
>>>>>>>>         <janejhu at gmail.com <mailto:janejhu at gmail.com>> wrote:
>>>>>>>>             Yes, it returns a list of refVolume's which are
>>>>>>>>             RefEntities.
>>>>>>>>             Jane
>>>>>>>>             On Sun, Jun 15, 2014 at 11:55 PM, Patrick Shriwise
>>>>>>>>             <shriwise at wisc.edu <mailto:shriwise at wisc.edu>> wrote:
>>>>>>>>                 Hi Jane,
>>>>>>>>                 Will the ref_volumes() method return RefEntities?
>>>>>>>>                 Patrick
>>>>>>>>                 On Jun 15, 2014, at 3:56 PM, Jane Hu
>>>>>>>>                 wrote:
>>>>>>>>>                 Look at line 6454, if you have body's pointer,
>>>>>>>>>                 directly call ref_volumes() will work. It's
>>>>>>>>>                 not an iGeom interface function, but you can
>>>>>>>>>                 access it in iGeom.
>>>>>>>>>                 Good luck!
>>>>>>>>>                 Jane
>>>>>>>>>                 On Sat, Jun 14, 2014 at 8:55 AM, Patrick
>>>>>>>>>                 Shriwise <shriwise at wisc.edu
>>>>>>>>>                     Hi Jane,
>>>>>>>>>                     I looked around for this but didn't see
>>>>>>>>>                     it, is there a specific line/function you
>>>>>>>>>                     were thinking of? Good to know the
>>>>>>>>>                     ref_volume information is so easy to get
>>>>>>>>>                     to, but it doesn't seem that its part of
>>>>>>>>>                     the iGeom interface. The issue being that
>>>>>>>>>                     there's no way to access a body's volumes
>>>>>>>>>                     via iGeom.
>>>>>>>>>                     Cheers,
>>>>>>>>>                     Patrick
>>>>>>>>>                     On 06/13/2014 11:26 PM, Jane Hu wrote:
>>>>>>>>>>                          Is there a way to get volumes within
>>>>>>>>>>                         bodies via iGeom?
>>>>>>>>>>                     See example in  iGeom_CGMA.cc,
>>>>>>>>>>                     body->ref_volumes(volumes).
>>>>>>>>>>                     Jane
>>>>>>>>>>                         Patrick C. Shriwise
>>>>>>>>>>                         Research Assistant
>>>>>>>>>>                         University of Wisconsin - Madison
>>>>>>>>>>                         Engineering Research Building - Rm. 428
>>>>>>>>>>                         1500 Engineering Drive
>>>>>>>>>>                         Madison, WI 53706
>>>>>>>>>>                         (608) 446-8173
>>>>>>>>>>                     Jane Hu
>>>>>>>>>>                     Asst. Researcher
>>>>>>>>>>                     Dept. of Engineering Physics
>>>>>>>>>>                     UW @ Madison
>>>>>>>>>>                     "And we know that for those who love God,
>>>>>>>>>>                     that is, for those who are called
>>>>>>>>>>                     according to his purpose, all things are
>>>>>>>>>>                     working together for good." (Romans 8:28)
>>>>>>>>>                 Jane Hu
>>>>>>>>>                 Asst. Researcher
>>>>>>>>>                 UW @ Madison
>>>>>>>>>                 "And we know that for those who love God, that
>>>>>>>>>                 is, for those who are called according to his
>>>>>>>>>                 purpose, all things are working together for
>>>>>>>>             Jane Hu
>>>>>>>>             Asst. Researcher
>>>>>>>>             UW @ Madison
>>>>>>>>             "And we know that for those who love God, that is,
>>>>>>>>             for those who are called according to his purpose,
>>>>>>>>             all things are working together for good." (Romans
>>>>>>>>             8:28)
>>>>>>>>         Jane Hu
>>>>>>>>         Asst. Researcher
>>>>>>>>         UW @ Madison
>>>>>>>>         "And we know that for those who love God, that is, for
>>>>>>>>         those who are called according to his purpose, all
>>>>>>>>         things are working together for good." (Romans 8:28)
>>>>>>>         Paul Wilson ~ UW-Madison ~608-263-0807  ~ cal:http://bit.ly/pphw-cal
>>>>>>>         Professor, Engineering Physics. ~http://cnerg.engr.wisc.edu  <http://cnerg.engr.wisc.edu/>
>>>>>>>         Faculty Director, Advanced Computing Infrastructure
>>>>>>>     Jane Hu
>>>>>>>     Asst. Researcher
>>>>>>>     UW @ Madison
>>>>>>>     "And we know that for those who love God, that is, for those
>>>>>>>     who are called according to his purpose, all things are
>>>>>>> Jane Hu
>>>>>>> Asst. Researcher
>>>>>>> UW @ Madison
>>>>>>> "And we know that for those who love God, that is, for those who
>>>>>>> are called according to his purpose, all things are working
>>>>>> Paul Wilson ~ UW-Madison ~ 608-263-0807 ~ cal:http://bit.ly/pphw-cal
>>>>> Patrick C. Shriwise
>>>>> Research Assistant
>>>>> Madison, WI 53706
>>>>> (608) 446-8173
>>> Patrick C. Shriwise
>>> Research Assistant
>>> Madison, WI 53706
>>> (608) 446-8173
> Patrick C. Shriwise
> Research Assistant
> Madison, WI 53706
> (608) 446-8173
Paul Wilson ~ UW-Madison ~ 608-263-0807 ~ cal: http://bit.ly/pphw-cal
Professor, Engineering Physics. ~ http://cnerg.engr.wisc.edu
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20140716/949c53a0/attachment-0001.html>
Type: application/pkcs7-signature
Desc: S/MIME Cryptographic Signature
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20140716/949c53a0/attachment-0001.bin>
More information about the cgma-dev mailing list
