[cgma-dev] Inconsistency in getEntities for iGeom interface. Causes problems in iRel.
shriwise shriwise at wisc.edu
Tue Jul 15 10:29:56 CDT 2014
Bump.
On 07/11/2014 08:15 PM, Paul Wilson wrote:
> Rajeev,
> You are mentioned in the git logs as the inspiration for the
> copy_attrib test that Patrick mentioned.  (a few years ago)
> I wonder if you have any thoughts on what the purpose and/or
> requirements are for this capability?  You probably needed it for RGG
> based on OCC?
> Paul
> On 07/11/2014 07:21 PM, Patrick Shriwise wrote:
>> Hi all,
>> I'm currently working on the changes to iGeom that Paul previously
>> proposed. I've hit one test when built with OCC (copy_attrib) that
>> suggests that tags are expected to be copied along with an entity
>> when using iGeom functions like copyEnt or subtractEnt. Is this the
>> case? Are these specifc tags that are supposed to be copied if they
>> exist on the original entity?
>> Also to be clear this has become an issue because for volume entities
>> we now use the RefVolume to get the volume Body and make a copy of
>> that body using the GeometryModifyTool. The Body we make a copy of
>> does not have the tags associated with the RefVolume. As a result the
>> new Body and the corresponding RefVolumethat we return from the
>> function does not have the original tags.
>> These tags can be transferred to the new entity before leaving the
>> function of course, but we're looking for the proper way to handle
>> this situation. Mainly it would be good to know if there is a
>> particular tag or tags that should be copied over to new entity upon
>> it's creation.
>> Cheers,
>> Patrick
>> On 06/23/2014 03:06 PM, Paul Wilson wrote:
>>> Hi everyone,
>>> Patrick and I have discussed this and have come up with the
>>> following proposal for a revision of how iGeom_CGMA handles
>>> RefVolumes and Body's.
>>>  1. All references to iBase_REGION will refer only to entities of
>>>     type RefVolume in CGM.
>>>  2. All entities that are returned by iGeom will be RefEntities and
>>>     not CubitEntities
>>>  3. At the time of loading file, based on an option based to
>>>     iGeom_load(), all entities of type Body in CGM that contain more
>>>     than a single volume, will be converted to RefGroup's and tagged
>>>     to distinguish them from the original RefGroup's
>>> The last of these may be subject to the most conversation, but it
>>> seemed like a useful approach to use because it:
>>>   * had little to no effect on the API of iGeom
>>>   * preserves access to CGM/ACIS bodies
>>>   * is the least intrusive in the implementation of iGeom_CGMA
>>> If a user does NOT pass in the option (e.g.
>>> "CONVERT_BODY_TO_GROUP"), then no bodies will be accessible through
>>> iGeom.  If a user does pass in this option, any call to
>>> iGeom_getEntSets will return both the original RefGroups and the
>>> additional RefGroups that were generated automatically from Bodies.
>>> It will be up to the user to filter between them using the available
>>> tag.
>>> Finally, since every RefVolume in ACIS always has a Body in which it
>>> is a member, it seems best to only convert Bodies that contain >1
>>> RefVolume to avoid creating far more RefGroups than necessary.
>>> We'd like to embark on these changes soon, but welcome any comments
>>> or feedback.  I'm sure we've missed something!
>>> Paul
>>> On 06/17/2014 09:00 AM, Jane Hu wrote:
>>>> So, I will add RefVolume to the return list
>>>> of iGeom_get_adjacent_entities() as the result of the discussion.
>>>> CubitEntity only has derived classes of RefEntity
>>>> and CubitCoordinateSystem, iGeom_CGMA.cc only uses RefEntity as
>>>> instance of the object.
>>>> Jane
>>>> On Mon, Jun 16, 2014 at 11:35 AM, Jane Hu <janejhu at gmail.com
>>>> <mailto:janejhu at gmail.com>> wrote:
>>>>     See comments below...
>>>>     On Mon, Jun 16, 2014 at 10:22 AM, Paul Wilson
>>>>     <wilsonp at engr.wisc.edu <mailto:wilsonp at engr.wisc.edu>> wrote:
>>>>         Hi Jane,
>>>>         I think this needs a thorough review! Patrick and I hunted
>>>>         through iGeom_CGMA and found some inconsistencies in a few
>>>>         places.
>>>>         First, there is an inconsistency between returning pointers
>>>>         to RefEntity and pointers to CubitEntity.  This is probably
>>>>         less important, but should probably be resolved in any change.
>>>>     I see RefEntity is inherited from CubitEntity, and CubitEntity
>>>>     is a pure virtual class. So even you got pointers to
>>>>     CubitEntity, you have to instantiate it to RefEntity objects.
>>>>         Second, there are places where the geometry is queried for
>>>>         entities of dimension=3 (returning RefVolumes) and places
>>>>         where the geometry is queried for entities of
>>>>         type=iGeom_REGION (== Body).
>>>>     In this case, I can return both bodies and refvolumes, so after
>>>>     user gets the refentity list back, he can cast to see if they
>>>>     are bodies or refvolumes, and choose to keep what ever he needs.
>>>>         This means that 2 calls into the interface that should
>>>>         resolve to the same entity may not do so for both reasons.
>>>>         All of this is related to the fundamental difference
>>>>         between the iGeom types (equivalent to vertex, edge, face,
>>>>         volume) and the CGM/ACIS types (equiavlent to vertex, edge,
>>>>         face, volume, body).  I think Tim's suggestion is the best,
>>>>         but will require some substantial effort.
>>>>         Paul
>>>>         On 06/16/2014 10:14 AM, Jane Hu wrote:
>>>>>         I see in iGeom_CGMA.cc file,
>>>>>         function iGeom_get_adjacent_entities, if asks for 3-D
>>>>>         refentities, it returns body list. In CGM, bodies are not
>>>>>         necessary to be 3-D entities, it may contain single
>>>>>         surface or shell. Should we change the return to be only
>>>>>         refvolumes which are 3-D entities (I prefer this, makes
>>>>>         more sense)? Or I can return both bodies and refvolumes in
>>>>>         the returned refentity list. Depending on your user case,
>>>>>         I can return one of the two choices.
>>>>>         Jane
>>>>>         On Mon, Jun 16, 2014 at 9:32 AM, Jane Hu
>>>>>         <janejhu at gmail.com <mailto:janejhu at gmail.com>> wrote:
>>>>>             Yes, it returns a list of refVolume's which are
>>>>>             RefEntities.
>>>>>             Jane
>>>>>             On Sun, Jun 15, 2014 at 11:55 PM, Patrick Shriwise
>>>>>             <shriwise at wisc.edu <mailto:shriwise at wisc.edu>> wrote:
>>>>>                 Hi Jane,
>>>>>                 Will the ref_volumes() method return RefEntities?
>>>>>                 Patrick
>>>>>                 On Jun 15, 2014, at 3:56 PM, Jane Hu
>>>>>>                 Look at line 6454, if you have body's pointer,
>>>>>>                 directly call ref_volumes() will work. It's not
>>>>>>                 an iGeom interface function, but you can access
>>>>>>                 it in iGeom.
>>>>>>                 Good luck!
>>>>>>                 Jane
>>>>>>                 On Sat, Jun 14, 2014 at 8:55 AM, Patrick Shriwise
>>>>>>                     Hi Jane,
>>>>>>                     I looked around for this but didn't see it,
>>>>>>                     is there a specific line/function you were
>>>>>>                     thinking of? Good to know the ref_volume
>>>>>>                     information is so easy to get to, but it
>>>>>>                     doesn't seem that its part of the iGeom
>>>>>>                     interface. The issue being that there's no
>>>>>>                     way to access a body's volumes via iGeom.
>>>>>>                     Cheers,
>>>>>>                     Patrick
>>>>>>                     On 06/13/2014 11:26 PM, Jane Hu wrote:
>>>>>>>                          Is there a way to get volumes within
>>>>>>>                         bodies via iGeom?
>>>>>>>                     See example in  iGeom_CGMA.cc,
>>>>>>>                     body->ref_volumes(volumes).
>>>>>>>                     Jane
>>>>>>>                         Patrick C. Shriwise
>>>>>>>                         Research Assistant
>>>>>>>                         University of Wisconsin - Madison
>>>>>>>                         Engineering Research Building - Rm. 428
>>>>>>>                         1500 Engineering Drive
>>>>>>>                         Madison, WI 53706
>>>>>>>                         (608) 446-8173  <tel:%28608%29%20446-8173>
>>>>>>>                     Jane Hu
>>>>>>>                     Asst. Researcher
>>>>>>>                     Dept. of Engineering Physics
>>>>>>>                     UW @ Madison
>>>>>>>                     "And we know that for those who love God,
>>>>>>>                     that is, for those who are called according
>>>>>>>                     to his purpose, all things are working
>>>>>>>                     together for good." (Romans 8:28)
>>>>>>                 Jane Hu
>>>>>>                 Asst. Researcher
>>>>>>                 UW @ Madison
>>>>>>                 "And we know that for those who love God, that
>>>>>>                 is, for those who are called according to his
>>>>>>                 purpose, all things are working together for
>>>>>             Jane Hu
>>>>>             Asst. Researcher
>>>>>             UW @ Madison
>>>>>             "And we know that for those who love God, that is, for
>>>>>             those who are called according to his purpose, all
>>>>>             things are working together for good." (Romans 8:28)
>>>>>         Jane Hu
>>>>>         Asst. Researcher
>>>>>         UW @ Madison
>>>>>         those who are called according to his purpose, all things
>>>>         Paul Wilson ~ UW-Madison ~608-263-0807  <tel:608-263-0807>  ~ cal:http://bit.ly/pphw-cal
>>>>         Professor, Engineering Physics. ~http://cnerg.engr.wisc.edu
>>>>         Faculty Director, Advanced Computing Infrastructure
>>>>     Jane Hu
>>>>     Asst. Researcher
>>>>     UW @ Madison
>>>>     "And we know that for those who love God, that is, for those
>>>>     who are called according to his purpose, all things are working
>>>> Jane Hu
>>>> Asst. Researcher
>>>> UW @ Madison
>>>> "And we know that for those who love God, that is, for those who
>>> Paul Wilson ~ UW-Madison ~ 608-263-0807 ~ cal:http://bit.ly/pphw-cal
>> Patrick C. Shriwise
>> Research Assistant
>> Madison, WI 53706
>> (608) 446-8173
Patrick C. Shriwise
Research Assistant
Madison, WI 53706
(608) 446-8173
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20140715/4b94fce0/attachment-0001.html>
More information about the cgma-dev mailing list
