[cgma-dev] Inconsistency in getEntities for iGeom interface. Causes problems in iRel.
Jane Hu janejhu at gmail.com
Mon Jun 16 10:14:58 CDT 2014
I see in iGeom_CGMA.cc file, function iGeom_get_adjacent_entities, if asks
for 3-D refentities, it returns body list. In CGM, bodies are not necessary
to be 3-D entities, it may contain single surface or shell. Should we
change the return to be only refvolumes which are 3-D entities (I prefer
this, makes more sense)? Or I can return both bodies and refvolumes in the
returned refentity list. Depending on your user case, I can return one of
the two choices.
Jane
On Mon, Jun 16, 2014 at 9:32 AM, Jane Hu <janejhu at gmail.com> wrote:
> Yes, it returns a list of refVolume's which are RefEntities.
> Jane
> On Sun, Jun 15, 2014 at 11:55 PM, Patrick Shriwise <shriwise at wisc.edu>
> wrote:
>> Hi Jane,
>> Will the ref_volumes() method return RefEntities?
>> Patrick
>> On Jun 15, 2014, at 3:56 PM, Jane Hu <janejhu at gmail.com> wrote:
>> Look at line 6454, if you have body's pointer, directly call
>> ref_volumes() will work. It's not an iGeom interface function, but you can
>> access it in iGeom.
>> Good luck!
>> Jane
>> On Sat, Jun 14, 2014 at 8:55 AM, Patrick Shriwise <shriwise at wisc.edu>
>> wrote:
>>>  Hi Jane,
>>> I looked around for this but didn't see it, is there a specific
>>> line/function you were thinking of? Good to know the ref_volume information
>>> is so easy to get to, but it doesn't seem that its part of the iGeom
>>> interface. The issue being that there's no way to access a body's volumes
>>> via iGeom.
>>> Cheers,
>>> Patrick
>>> On 06/13/2014 11:26 PM, Jane Hu wrote:
>>>>  Is there a way to get volumes within bodies via iGeom?
>>>  See example in  iGeom_CGMA.cc, body->ref_volumes(volumes).
>>>  Jane
>>>> Patrick C. Shriwise
>>>> Research Assistant
>>>> University of Wisconsin - Madison
>>>> Engineering Research Building - Rm. 428
>>>> 1500 Engineering Drive
>>>> Madison, WI 53706(608) 446-8173
>>> Jane Hu
>>> Asst. Researcher
>>> Dept. of Engineering Physics
>>> UW @ Madison
>>> "And we know that for those who love God, that is, for those who are
>>> called according to his purpose, all things are working together for good."
>>> (Romans 8:28)
>> Jane Hu
>> Asst. Researcher
>> UW @ Madison
>> (Romans 8:28)
> Jane Hu
> Asst. Researcher
> UW @ Madison
> (Romans 8:28)
Jane Hu
Asst. Researcher
UW @ Madison
"And we know that for those who love God, that is, for those who are called
(Romans 8:28)
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20140616/3db8bcdd/attachment-0001.html>
More information about the cgma-dev mailing list
