[cgma-dev] What versions of OCE is CGM 13.1 compatible with?
Geoff Oxberry goxberry at gmail.com
Sat May 24 18:56:33 CDT 2014
Jane,
The patches applied successfully. OCE 0.15 and CGM 13.1 built successfully,
but CGM fails tests in "make check". Here's a gist of the configure log and
test logs: https://gist.github.com/goxberry/152faed6fb782781ee4a
The test that fails seems to be "copy_attrib".
Geoff
On Thu, May 22, 2014 at 10:23 AM, Jane Hu <janejhu at gmail.com> wrote:
> Hi, Geoff
> I attached the three patch files here, can you try to see if they work
> well on 0.15 oce?
> Jane
> On Thu, May 22, 2014 at 12:56 AM, Geoff Oxberry <goxberry at gmail.com>wrote:
>> Apologies for not sending the previous reply to the CGMA-dev list.
>> The patch under cgm/geom/OCC/occ_patches_6.6.0 failed to apply to source
>> files in OCE 0.15. A log can be found at
>> https://gist.github.com/goxberry/c31139a3c5c49adb1cad; the Homebrew
>> formula I am writing for OCE can be found at
>> https://github.com/goxberry/homebrew-itaps/blob/oce-0.15/oce.rb.
>> A similar formula is under way for CGM.
>> Cheers,
>> Geoff
>> On Wed, May 21, 2014 at 7:57 AM, Rajeev Jain <jain at mcs.anl.gov> wrote:
>>> Yes. 0.15 works.
>>> Rajeev
>>>  *From:* Jane Hu <janejhu at gmail.com>
>>> *To:* Geoff Oxberry <goxberry at gmail.com>
>>> *Cc:* Vijay M <vijay.m at gmail.com>; "Jain, Rajeev" <jain at mcs.anl.gov>
>>> *Sent:* Wednesday, May 21, 2014 9:48 AM
>>> *Subject:* Re: [cgma-dev] What versions of OCE is CGM 13.1 compatible
>>> with?
>>>  Geoff,
>>>  I don't have a Mac machine, and wouldn't tell if it works on 0.15, did
>>> you try it yet?
>>>  The patches has been requested to opencascase.org 's develop's forum
>>> for quite long time, but didn't get in as we are not their customer. They
>>> haven't been submitted to upstream yet for OCE. We have to test them on
>>> linux for OCE before submit. But I know some of the testcases will fail on
>>> linux w/o the patches.
>>>  Best,
>>>  Jane
>>> On Wed, May 21, 2014 at 1:06 AM, Geoff Oxberry <goxberry at gmail.com>wrote:
>>> Jane,
>>>  I take it by 0.16-dev, you mean the master branch of
>>> https://github.com/tpaviot/oce? Will it build with version 0.15?
>>>  I did not apply the patches. I will do that to test the build, but it
>>> will mean that I cannot include the build recipe in
>>> https://github.com/Homebrew/homebrew-science, so CGM will not be in a
>>> mainstream package manager for OS X. I'll have to set up a separate repo
>>> called a "tap", and fork other build recipes in the process (at least MOAB,
>>> gmsh).
>>>  Have these OCC/OCE patches been submitted upstream? If not, is there
>>> any plan to? Merging them upstream would make it easier to get build
>>> recipes for CGM, Lasso, and MeshKit into homebrew/science. It would also
>>> avoid a lot of unnecessary duplication and spread the maintenance burden
>>> for packaging over more people. (homebrew/science has 239 contributors; I
>>> am just one person.)
>>>  Thanks,
>>>  Geoff
>>> On Tue, May 20, 2014 at 7:59 AM, Jane Hu <janejhu at gmail.com> wrote:
>>> Hi, Geoff
>>>  The OCE mentioned in Mac OSX build was from
>>> https://github.com/tpaviot/oce, looks like 0.16-dev version.
>>>  Did you apply the patches under cgm/geom/OCC/occ_patches_6.6.0 for the
>>> build? What are the failed tests? We are working on Linux, so may not be
>>> able to fix for all of the failed tests, but want to get to know which ones
>>> are failing on Mac. Thanks.
>>>  Jane
>>> On Tue, May 20, 2014 at 1:32 AM, Geoff Oxberry <goxberry at gmail.com>wrote:
>>>  Dear CGM devs,
>>>  I am attempting to write a build recipe for CGM for the OS X package
>>> manager Homebrew. So far, I've managed to build CGM with OCE, as
>>> recommended by the Trac wiki, although "make check" fails. Before I delve
>>> too far into the weeds by attaching build logs and error messages, what
>>> version of OCE should I be building with?
>>>  Cheers,
>>>  Geoff
>>> Geoffrey Oxberry, Ph.D., E.I.T.
>>> Jane Hu
>>> Asst. Researcher
>>> Dept. of Engineering Physics
>>> UW @ Madison
>>> "And we know that for those who love God, that is, for those who are
>>> called according to his purpose, all things are working together for good."
>>> (Romans 8:28)
>>> Jane Hu
>>> Asst. Researcher
>>> UW @ Madison
>>> (Romans 8:28)
> Jane Hu
> Asst. Researcher
> UW @ Madison
> (Romans 8:28)
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20140524/0f9f9965/attachment.html>
More information about the cgma-dev mailing list
