[cgma-dev] What versions of OCE is CGM 13.1 compatible with?
Jane Hu janejhu at gmail.com
Tue May 20 09:59:17 CDT 2014
Hi, Geoff
The OCE mentioned in Mac OSX build was from https://github.com/tpaviot/oce,
looks like 0.16-dev version.
Did you apply the patches under cgm/geom/OCC/occ_patches_6.6.0 for the
build? What are the failed tests? We are working on Linux, so may not be
able to fix for all of the failed tests, but want to get to know which ones
are failing on Mac. Thanks.
Jane
On Tue, May 20, 2014 at 1:32 AM, Geoff Oxberry <goxberry at gmail.com> wrote:
> Dear CGM devs,
> I am attempting to write a build recipe for CGM for the OS X package
> manager Homebrew. So far, I've managed to build CGM with OCE, as
> recommended by the Trac wiki, although "make check" fails. Before I delve
> too far into the weeds by attaching build logs and error messages, what
> version of OCE should I be building with?
> Cheers,
> Geoff
> Geoffrey Oxberry, Ph.D., E.I.T.
Jane Hu
Asst. Researcher
Dept. of Engineering Physics
UW @ Madison
"And we know that for those who love God, that is, for those who are called
according to his purpose, all things are working together for good."
(Romans 8:28)
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20140520/b3937966/attachment.html>
More information about the cgma-dev mailing list
