[cgma-dev] commit/CGM: 8 new changesets
Bitbucket
commits-noreply at bitbucket.org
Mon May 5 12:33:23 CDT 2014
8 new commits in CGM:
https://bitbucket.org/fathomteam/cgm/commits/0fc28830accd/
Changeset: 0fc28830accd
Branch: None
User: dcthomp
Date: 2014-05-01 22:46:13
Summary: Fix compilation using CMake on OS X.
0. Add a new toplevel CMakeLists.txt file to build the project.
1. The new (Mavericks) libc++ uses a specialization for
`std::vector<bool>` that prevents `DLIList<X>` from re-using
`std::vector<X>::const_reference` blindly.
2. CubitCompat.h was not being generated.
3. The init project's include directories did not cover
build directories where configured headers are placed.
Affected #: 3 files
https://bitbucket.org/fathomteam/cgm/commits/848cb17d6b97/
Changeset: 848cb17d6b97
Branch: None
User: dcthomp
Summary: Start fixing CMake install rules.
Affected #: 3 files
https://bitbucket.org/fathomteam/cgm/commits/588755965351/
Changeset: 588755965351
Branch: None
User: dcthomp
Summary: Add a ReadMe in a format github likes.
Affected #: 1 file
https://bitbucket.org/fathomteam/cgm/commits/e8a3200ea8ce/
Changeset: e8a3200ea8ce
Branch: None
User: dcthomp
Summary: Get headers installed properly.
Now, with the exception of the itaps directory, header files
installed by CMake match those install by autoconf (at least
on OS X 10.9 built with OCC and CGM_FACET turned on).
Affected #: 10 files
https://bitbucket.org/fathomteam/cgm/commits/af74c96465aa/
Changeset: af74c96465aa
Branch: None
User: dcthomp
Summary: Clean up CMakeLists.
Affected #: 2 files
https://bitbucket.org/fathomteam/cgm/commits/5587ee046f6b/
Changeset: 5587ee046f6b
Branch: None
User: dcthomp
Date: 2014-05-01 22:47:52
Summary: Progress on building with CMake.
CGM now builds against some versions of OpenCascade.
It is unclear why the subdirectories are
separate projects instead of a top-level CMakeLists that
prepares "add_definitions" and "include_directories"
values for all subdirectories.
CGM also creates `cgm.make` (to mirror the autoconf
version) which is usable in some cases.
Affected #: 11 files
https://bitbucket.org/fathomteam/cgm/commits/7a3b9069334d/
Changeset: 7a3b9069334d
Branch: None
User: dcthomp
Date: 2014-05-01 22:48:36
Summary: Update ReadMe.
Affected #: 1 file
https://bitbucket.org/fathomteam/cgm/commits/af90022a1c7c/
Changeset: af90022a1c7c
Branch: master
User: janehu
Date: 2014-05-05 19:33:15
Summary: Merged in dcthomp/cgma/cmake (pull request #3)
Minimal changes to get CMake building
Affected #: 12 files
Repository URL: https://bitbucket.org/fathomteam/cgm/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
More information about the cgma-dev
