[cgma-dev] Build failed in Jenkins: cgm32bit #349
    jenkins-ci at mcs.anl.gov
    Thu Mar 13 00:04:46 CDT 2014
See <https://jenkins-ci.mcs.anl.gov/job/cgm32bit/349/>
[...truncated 246 lines...]
CubitCompat.cpp: In function 'CubitStatus CubitCompat_export_solid_model(DLIList<RefEntity*>&, const char*, const char*, int&, const CubitString&, const char*)':
CubitCompat.cpp:81:14: warning: unused variable 'print_results' [-Wunused-variable]
CubitCompat.cpp:82:14: warning: unused variable 'merge_globally' [-Wunused-variable]
CubitCompat.cpp:83:14: warning: unused variable 'no_assembly_level_features' [-Wunused-variable]
mv -f .deps/CubitCompat.Tpo .deps/CubitCompat.Plo
/bin/sh ../libtool  --tag=CXX   --mode=link /homes/fathom/lib32/mpich2-1.5_gcc/bin/mpicxx  -Wall -pipe -pedantic -O2 -DNDEBUG   -o libcubit_geom.la  CubitCompat.lo  -lm
libtool: link: ar cru .libs/libcubit_geom.a  CubitCompat.o
libtool: link: ranlib .libs/libcubit_geom.a
libtool: link: ( cd ".libs" && rm -f "libcubit_geom.la" && ln -s "../libcubit_geom.la" "libcubit_geom.la" )
make[4]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/cgm32bit/ws/geom'>
Making all in Cholla
make[4]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/cgm32bit/ws/geom/Cholla'>
make[4]: Nothing to be done for `all'.
make[4]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/cgm32bit/ws/geom/Cholla'>
Making all in facetbool
make[4]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/cgm32bit/ws/geom/facetbool'>
make[4]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/cgm32bit/ws/geom/facetbool'>
Making all in facet
make[4]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/cgm32bit/ws/geom/facet'>
make[4]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/cgm32bit/ws/geom/facet'>
Making all in virtual
make[4]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/cgm32bit/ws/geom/virtual'>
make[4]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/cgm32bit/ws/geom/virtual'>
Making all in parallel
make[4]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/cgm32bit/ws/geom/parallel'>
(CDPATH="${ZSH_VERSION+.}:" && cd ../.. && /bin/sh <https://jenkins-ci.mcs.anl.gov/job/cgm32bit/ws/missing> --run autoheader)
rm -f stamp-h2
touch CGMmpi_config.h.in
cd ../.. && /bin/sh ./config.status geom/parallel/CGMmpi_config.h
config.status: creating geom/parallel/CGMmpi_config.h
config.status: geom/parallel/CGMmpi_config.h is unchanged
make  all-am
make[5]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/cgm32bit/ws/geom/parallel'>
/bin/sh ../../libtool  --tag=CXX   --mode=compile /homes/fathom/lib32/mpich2-1.5_gcc/bin/mpicxx -DHAVE_CONFIG_H -I. -I../.. -I../../geom -I../../itaps  -DLITTLE_ENDIAN=BYTE_ORDER   -DTEMPLATE_DEFS_INCLUDED -I../../util -I../../geom -I../../geom/ACIS -Ino/include   -DUSE_MPI   -Wall -pipe -pedantic -O2 -DNDEBUG -MT CGMProcConfig.lo -MD -MP -MF .deps/CGMProcConfig.Tpo -c -o CGMProcConfig.lo CGMProcConfig.cpp
libtool: compile:  /homes/fathom/lib32/mpich2-1.5_gcc/bin/mpicxx -DHAVE_CONFIG_H -I. -I../.. -I../../geom -I../../itaps -DLITTLE_ENDIAN=BYTE_ORDER -DTEMPLATE_DEFS_INCLUDED -I../../util -I../../geom -I../../geom/ACIS -Ino/include -DUSE_MPI -Wall -pipe -pedantic -O2 -DNDEBUG -MT CGMProcConfig.lo -MD -MP -MF .deps/CGMProcConfig.Tpo -c CGMProcConfig.cpp -o CGMProcConfig.o
In file included from CGMmpi.h:11:0,
                 from CGMProcConfig.hpp:5,
                 from CGMProcConfig.cpp:1:
/homes/fathom/lib32/mpich2-1.5_gcc/include/mpi.h:523:1: warning: ISO C++ 1998 does not support 'long long' [-Wlong-long]
mv -f .deps/CGMProcConfig.Tpo .deps/CGMProcConfig.Plo
/bin/sh ../../libtool  --tag=CXX   --mode=compile /homes/fathom/lib32/mpich2-1.5_gcc/bin/mpicxx -DHAVE_CONFIG_H -I. -I../.. -I../../geom -I../../itaps  -DLITTLE_ENDIAN=BYTE_ORDER   -DTEMPLATE_DEFS_INCLUDED -I../../util -I../../geom -I../../geom/ACIS -Ino/include   -DUSE_MPI   -Wall -pipe -pedantic -O2 -DNDEBUG -MT CGMParallelComm.lo -MD -MP -MF .deps/CGMParallelComm.Tpo -c -o CGMParallelComm.lo CGMParallelComm.cpp
libtool: compile:  /homes/fathom/lib32/mpich2-1.5_gcc/bin/mpicxx -DHAVE_CONFIG_H -I. -I../.. -I../../geom -I../../itaps -DLITTLE_ENDIAN=BYTE_ORDER -DTEMPLATE_DEFS_INCLUDED -I../../util -I../../geom -I../../geom/ACIS -Ino/include -DUSE_MPI -Wall -pipe -pedantic -O2 -DNDEBUG -MT CGMParallelComm.lo -MD -MP -MF .deps/CGMParallelComm.Tpo -c CGMParallelComm.cpp -o CGMParallelComm.o
                 from CGMParallelComm.hpp:13,
                 from CGMParallelComm.cpp:1:
CGMParallelComm.cpp: In member function 'CubitStatus CGMParallelComm::broadcast_entities(unsigned int, DLIList<RefEntity*>&)':
CGMParallelComm.cpp:154:5: warning: format not a string literal and no format arguments [-Wformat-security]
CGMParallelComm.cpp:157:5: warning: format not a string literal and no format arguments [-Wformat-security]
CGMParallelComm.cpp:160:5: warning: format not a string literal and no format arguments [-Wformat-security]
CGMParallelComm.cpp:164:3: warning: format not a string literal and no format arguments [-Wformat-security]
CGMParallelComm.cpp:168:5: warning: format not a string literal and no format arguments [-Wformat-security]
CGMParallelComm.cpp: In member function 'CubitStatus CGMParallelComm::scatter_entities(unsigned int, DLIList<RefEntity*>&)':
CGMParallelComm.cpp:209:23: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
CGMParallelComm.cpp:218:24: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
CGMParallelComm.cpp:225:7: warning: format not a string literal and no format arguments [-Wformat-security]
CGMParallelComm.cpp:261:5: warning: format not a string literal and no format arguments [-Wformat-security]
CGMParallelComm.cpp: In member function 'CubitStatus CGMParallelComm::append_to_buffer(DLIList<RefEntity*>&, int)':
CGMParallelComm.cpp:333:3: warning: format not a string literal and no format arguments [-Wformat-security]
CGMParallelComm.cpp: In static member function 'static CGMParallelComm* CGMParallelComm::get_pcomm(const MPI_Comm*)':
CGMParallelComm.cpp:110:32: warning: 'pcomm_id' is used uninitialized in this function [-Wuninitialized]
mv -f .deps/CGMParallelComm.Tpo .deps/CGMParallelComm.Plo
/bin/sh ../../libtool  --tag=CXX   --mode=compile /homes/fathom/lib32/mpich2-1.5_gcc/bin/mpicxx -DHAVE_CONFIG_H -I. -I../.. -I../../geom -I../../itaps  -DLITTLE_ENDIAN=BYTE_ORDER   -DTEMPLATE_DEFS_INCLUDED -I../../util -I../../geom -I../../geom/ACIS -Ino/include   -DUSE_MPI   -Wall -pipe -pedantic -O2 -DNDEBUG -MT CGMFileOptions.lo -MD -MP -MF .deps/CGMFileOptions.Tpo -c -o CGMFileOptions.lo CGMFileOptions.cpp
libtool: compile:  /homes/fathom/lib32/mpich2-1.5_gcc/bin/mpicxx -DHAVE_CONFIG_H -I. -I../.. -I../../geom -I../../itaps -DLITTLE_ENDIAN=BYTE_ORDER -DTEMPLATE_DEFS_INCLUDED -I../../util -I../../geom -I../../geom/ACIS -Ino/include -DUSE_MPI -Wall -pipe -pedantic -O2 -DNDEBUG -MT CGMFileOptions.lo -MD -MP -MF .deps/CGMFileOptions.Tpo -c CGMFileOptions.cpp -o CGMFileOptions.o
mv -f .deps/CGMFileOptions.Tpo .deps/CGMFileOptions.Plo
/bin/sh ../../libtool  --tag=CXX   --mode=compile /homes/fathom/lib32/mpich2-1.5_gcc/bin/mpicxx -DHAVE_CONFIG_H -I. -I../.. -I../../geom -I../../itaps  -DLITTLE_ENDIAN=BYTE_ORDER   -DTEMPLATE_DEFS_INCLUDED -I../../util -I../../geom -I../../geom/ACIS -Ino/include   -DUSE_MPI   -Wall -pipe -pedantic -O2 -DNDEBUG -MT CABodies.lo -MD -MP -MF .deps/CABodies.Tpo -c -o CABodies.lo CABodies.cpp
libtool: compile:  /homes/fathom/lib32/mpich2-1.5_gcc/bin/mpicxx -DHAVE_CONFIG_H -I. -I../.. -I../../geom -I../../itaps -DLITTLE_ENDIAN=BYTE_ORDER -DTEMPLATE_DEFS_INCLUDED -I../../util -I../../geom -I../../geom/ACIS -Ino/include -DUSE_MPI -Wall -pipe -pedantic -O2 -DNDEBUG -MT CABodies.lo -MD -MP -MF .deps/CABodies.Tpo -c CABodies.cpp -o CABodies.o
CABodies.cpp: In constructor 'CABodies::CABodies(RefEntity*, CubitSimpleAttrib*)':
CABodies.cpp:54:40: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
CABodies.cpp:62:42: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
mv -f .deps/CABodies.Tpo .deps/CABodies.Plo
/bin/sh ../../libtool  --tag=CXX   --mode=compile /homes/fathom/lib32/mpich2-1.5_gcc/bin/mpicxx -DHAVE_CONFIG_H -I. -I../.. -I../../geom -I../../itaps  -DLITTLE_ENDIAN=BYTE_ORDER   -DTEMPLATE_DEFS_INCLUDED -I../../util -I../../geom -I../../geom/ACIS -Ino/include   -DUSE_MPI   -Wall -pipe -pedantic -O2 -DNDEBUG -MT TDParallel.lo -MD -MP -MF .deps/TDParallel.Tpo -c -o TDParallel.lo TDParallel.cpp
libtool: compile:  /homes/fathom/lib32/mpich2-1.5_gcc/bin/mpicxx -DHAVE_CONFIG_H -I. -I../.. -I../../geom -I../../itaps -DLITTLE_ENDIAN=BYTE_ORDER -DTEMPLATE_DEFS_INCLUDED -I../../util -I../../geom -I../../geom/ACIS -Ino/include -DUSE_MPI -Wall -pipe -pedantic -O2 -DNDEBUG -MT TDParallel.lo -MD -MP -MF .deps/TDParallel.Tpo -c TDParallel.cpp -o TDParallel.o
TDParallel.cpp: In constructor 'TDParallel::TDParallel(ToolDataUser*, DLIList<int>*, DLIList<int>*, DLIList<int>*, int, int)':
TDParallel.cpp:22:15: warning: variable 'status' set but not used [-Wunused-but-set-variable]
mv -f .deps/TDParallel.Tpo .deps/TDParallel.Plo
/bin/sh ../../libtool  --tag=CXX   --mode=compile /homes/fathom/lib32/mpich2-1.5_gcc/bin/mpicxx -DHAVE_CONFIG_H -I. -I../.. -I../../geom -I../../itaps  -DLITTLE_ENDIAN=BYTE_ORDER   -DTEMPLATE_DEFS_INCLUDED -I../../util -I../../geom -I../../geom/ACIS -Ino/include   -DUSE_MPI   -Wall -pipe -pedantic -O2 -DNDEBUG -MT CGMReadParallel.lo -MD -MP -MF .deps/CGMReadParallel.Tpo -c -o CGMReadParallel.lo CGMReadParallel.cpp
libtool: compile:  /homes/fathom/lib32/mpich2-1.5_gcc/bin/mpicxx -DHAVE_CONFIG_H -I. -I../.. -I../../geom -I../../itaps -DLITTLE_ENDIAN=BYTE_ORDER -DTEMPLATE_DEFS_INCLUDED -I../../util -I../../geom -I../../geom/ACIS -Ino/include -DUSE_MPI -Wall -pipe -pedantic -O2 -DNDEBUG -MT CGMReadParallel.lo -MD -MP -MF .deps/CGMReadParallel.Tpo -c CGMReadParallel.cpp -o CGMReadParallel.o
                 from CGMReadParallel.hpp:7,
                 from CGMReadParallel.cpp:22:
CGMReadParallel.cpp: In member function 'CubitStatus CGMReadParallel::load_file(const char*, const char*, const char*, const int*, int)':
CGMReadParallel.cpp:85:7: warning: variable 'geom_dim' set but not used [-Wunused-but-set-variable]
mv -f .deps/CGMReadParallel.Tpo .deps/CGMReadParallel.Plo
/bin/sh ../../libtool  --tag=CXX   --mode=link /homes/fathom/lib32/mpich2-1.5_gcc/bin/mpicxx  -Wall -pipe -pedantic -O2 -DNDEBUG   -o libcubit_parallel.la  CGMProcConfig.lo CGMParallelComm.lo CGMFileOptions.lo CABodies.lo TDParallel.lo CGMReadParallel.lo  -lm
libtool: link: ar cru .libs/libcubit_parallel.a  CGMProcConfig.o CGMParallelComm.o CGMFileOptions.o CABodies.o TDParallel.o CGMReadParallel.o
libtool: link: ranlib .libs/libcubit_parallel.a
libtool: link: ( cd ".libs" && rm -f "libcubit_parallel.la" && ln -s "../libcubit_parallel.la" "libcubit_parallel.la" )
make[5]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/cgm32bit/ws/geom/parallel'>
make[4]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/cgm32bit/ws/geom/parallel'>
make[3]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/cgm32bit/ws/geom'>
make[2]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/cgm32bit/ws/geom'>
Making all in init
make[2]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/cgm32bit/ws/init'>
/bin/sh ../libtool  --tag=CXX   --mode=compile /homes/fathom/lib32/mpich2-1.5_gcc/bin/mpicxx -DHAVE_CONFIG_H -I. -I.. -I../geom/parallel -I../geom -I../itaps  -DLITTLE_ENDIAN=BYTE_ORDER   -DTEMPLATE_DEFS_INCLUDED -DHAVE_ACIS  -DCUBIT_CGM -DACIS_TWEAK_TOOL_CAT -I../geom -I../util -I../geom/ACIS -I../geom/OCC -I../geom/virtual -I../geom/facet -I../geom/cholla -I.    -Wall -pipe -pedantic -O2 -DNDEBUG -MT InitCGMA.lo -MD -MP -MF .deps/InitCGMA.Tpo -c -o InitCGMA.lo InitCGMA.cpp
libtool: compile:  /homes/fathom/lib32/mpich2-1.5_gcc/bin/mpicxx -DHAVE_CONFIG_H -I. -I.. -I../geom/parallel -I../geom -I../itaps -DLITTLE_ENDIAN=BYTE_ORDER -DTEMPLATE_DEFS_INCLUDED -DHAVE_ACIS -DCUBIT_CGM -DACIS_TWEAK_TOOL_CAT -I../geom -I../util -I../geom/ACIS -I../geom/OCC -I../geom/virtual -I../geom/facet -I../geom/cholla -I. -Wall -pipe -pedantic -O2 -DNDEBUG -MT InitCGMA.lo -MD -MP -MF .deps/InitCGMA.Tpo -c InitCGMA.cpp -o InitCGMA.o
mv -f .deps/InitCGMA.Tpo .deps/InitCGMA.Plo
/bin/sh ../libtool  --tag=CXX   --mode=link /homes/fathom/lib32/mpich2-1.5_gcc/bin/mpicxx  -Wall -pipe -pedantic -O2 -DNDEBUG   -o libcgma_init.la  InitCGMA.lo  -lm
libtool: link: ar cru .libs/libcgma_init.a  InitCGMA.o
libtool: link: ranlib .libs/libcgma_init.a
libtool: link: ( cd ".libs" && rm -f "libcgma_init.la" && ln -s "../libcgma_init.la" "libcgma_init.la" )
make[2]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/cgm32bit/ws/init'>
Making all in .
make[2]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/cgm32bit/ws/'>
/bin/sh ./libtool  --tag=CC   --mode=link /homes/fathom/lib32/mpich2-1.5_gcc/bin/mpicc  -g -O2 -Wall -pipe -pedantic   -o libcgm.la -rpath /homes/fathom/lib32/jenkins/cgm/lib  init/libcgma_init.la geom/libcubit_geom.la geom/parallel/libcubit_parallel.la -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin -lcubiti19 -lcubit_geom -lcubit_util /homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin/libcubiti19.so -lm
libtool: link: (cd .libs/libcgm.lax/libcgma_init.a && ar x "<https://jenkins-ci.mcs.anl.gov/job/cgm32bit/ws/init/.libs/libcgma_init.a")>
libtool: link: (cd .libs/libcgm.lax/libcubit_geom.a && ar x "<https://jenkins-ci.mcs.anl.gov/job/cgm32bit/ws/geom/.libs/libcubit_geom.a")>
libtool: link: (cd .libs/libcgm.lax/libcubit_parallel.a && ar x "<https://jenkins-ci.mcs.anl.gov/job/cgm32bit/ws/geom/parallel/.libs/libcubit_parallel.a")>
libtool: link: ar cru .libs/libcgm.a   .libs/libcgm.lax/libcgma_init.a/InitCGMA.o  .libs/libcgm.lax/libcubit_geom.a/CubitCompat.o  .libs/libcgm.lax/libcubit_parallel.a/CABodies.o .libs/libcgm.lax/libcubit_parallel.a/CGMFileOptions.o .libs/libcgm.lax/libcubit_parallel.a/CGMParallelComm.o .libs/libcgm.lax/libcubit_parallel.a/CGMProcConfig.o .libs/libcgm.lax/libcubit_parallel.a/CGMReadParallel.o .libs/libcgm.lax/libcubit_parallel.a/TDParallel.o
libtool: link: ranlib .libs/libcgm.a
libtool: link: rm -fr .libs/libcgm.lax
libtool: link: ( cd ".libs" && rm -f "libcgm.la" && ln -s "../libcgm.la" "libcgm.la" )
make[2]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/cgm32bit/ws/'>
Making all in itaps
make[2]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/cgm32bit/ws/itaps'>
(CDPATH="${ZSH_VERSION+.}:" && cd .. && /bin/sh <https://jenkins-ci.mcs.anl.gov/job/cgm32bit/ws/missing> --run autoheader)
rm -f stamp-h4
touch iBase_FCDefs.h.in
cd .. && /bin/sh ./config.status itaps/iBase_FCDefs.h
config.status: creating itaps/iBase_FCDefs.h
config.status: itaps/iBase_FCDefs.h is unchanged
make  all-recursive
make[3]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/cgm32bit/ws/itaps'>
Making all in .
make[4]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/cgm32bit/ws/itaps'>
/bin/sh ../libtool  --tag=CXX   --mode=compile /homes/fathom/lib32/mpich2-1.5_gcc/bin/mpicxx -DHAVE_CONFIG_H -I. -I.. -I../geom/parallel -I../geom  -DLITTLE_ENDIAN=BYTE_ORDER   -DTEMPLATE_DEFS_INCLUDED -DHAVE_ACIS  -DSRCDIR=. -I../util -I../geom -I../init -I../geom/parallel -DUSE_MPI    -Wall -pipe -pedantic -O2 -DNDEBUG -MT CATag.lo -MD -MP -MF .deps/CATag.Tpo -c -o CATag.lo CATag.cpp
libtool: compile:  /homes/fathom/lib32/mpich2-1.5_gcc/bin/mpicxx -DHAVE_CONFIG_H -I. -I.. -I../geom/parallel -I../geom -DLITTLE_ENDIAN=BYTE_ORDER -DTEMPLATE_DEFS_INCLUDED -DHAVE_ACIS -DSRCDIR=. -I../util -I../geom -I../init -I../geom/parallel -DUSE_MPI -Wall -pipe -pedantic -O2 -DNDEBUG -MT CATag.lo -MD -MP -MF .deps/CATag.Tpo -c CATag.cpp -o CATag.o
CATag.cpp: In member function 'iBase_ErrorType CGMTagManager::set_csa_tag(RefEntity*, long int, CubitSimpleAttrib*)':
CATag.cpp:231:31: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
CATag.cpp:241:31: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
CATag.cpp: In member function 'std::vector<RefGroup*>* CGMTagManager::pc_list(RefEntity*, int, bool)':
CATag.cpp:687:19: warning: variable 'result' set but not used [-Wunused-but-set-variable]
CATag.cpp: In member function 'void CGMTagManager::pc_list(RefEntity*, std::vector<RefGroup*>*&, std::vector<RefGroup*>*&, bool)':
CATag.cpp:713:19: warning: variable 'result' set but not used [-Wunused-but-set-variable]
mv -f .deps/CATag.Tpo .deps/CATag.Plo
/bin/sh ../libtool  --tag=CXX   --mode=compile /homes/fathom/lib32/mpich2-1.5_gcc/bin/mpicxx -DHAVE_CONFIG_H -I. -I.. -I../geom/parallel -I../geom  -DLITTLE_ENDIAN=BYTE_ORDER   -DTEMPLATE_DEFS_INCLUDED -DHAVE_ACIS  -DSRCDIR=. -I../util -I../geom -I../init -I../geom/parallel -DUSE_MPI    -Wall -pipe -pedantic -O2 -DNDEBUG -MT iGeom_CGMA.lo -MD -MP -MF .deps/iGeom_CGMA.Tpo -c -o iGeom_CGMA.lo iGeom_CGMA.cc
libtool: compile:  /homes/fathom/lib32/mpich2-1.5_gcc/bin/mpicxx -DHAVE_CONFIG_H -I. -I.. -I../geom/parallel -I../geom -DLITTLE_ENDIAN=BYTE_ORDER -DTEMPLATE_DEFS_INCLUDED -DHAVE_ACIS -DSRCDIR=. -I../util -I../geom -I../init -I../geom/parallel -DUSE_MPI -Wall -pipe -pedantic -O2 -DNDEBUG -MT iGeom_CGMA.lo -MD -MP -MF .deps/iGeom_CGMA.Tpo -c iGeom_CGMA.cc -o iGeom_CGMA.o
In file included from ../geom/parallel/CGMmpi.h:11:0,
                 from ../geom/parallel/CGMProcConfig.hpp:5,
                 from ../geom/parallel/CGMParallelComm.hpp:13,
                 from ../geom/parallel/CGMReadParallel.hpp:7,
                 from iGeom_CGMA.cc:107:
iGeom_CGMA.cc: In function 'CubitStatus iGeom_get_graphics(RefFace*, DLIList<CubitVector*>&, DLIList<int>&, double, double, double)':
iGeom_CGMA.cc:328:1: warning: no return statement in function returning non-void [-Wreturn-type]
iGeom_CGMA.cc: In function 'CubitStatus iGeom_get_graphics(RefEdge*, DLIList<CubitVector*>&, DLIList<int>&, double, double)':
iGeom_CGMA.cc:350:1: warning: no return statement in function returning non-void [-Wreturn-type]
iGeom_CGMA.cc: At global scope:
iGeom_CGMA.cc:6992:1: warning: 'bool iBase_intersect_ray_box(const CubitBox&, const CubitVector&, const CubitVector&)' defined but not used [-Wunused-function]
iGeom_CGMA.cc:307:20: warning: 'CubitStatus iGeom_get_graphics(RefFace*, DLIList<CubitVector*>&, DLIList<int>&, double, double, double)' defined but not used [-Wunused-function]
iGeom_CGMA.cc:330:20: warning: 'CubitStatus iGeom_get_graphics(RefEdge*, DLIList<CubitVector*>&, DLIList<int>&, double, double)' defined but not used [-Wunused-function]
mv -f .deps/iGeom_CGMA.Tpo .deps/iGeom_CGMA.Plo
/bin/sh ../libtool  --tag=CXX   --mode=compile /homes/fathom/lib32/mpich2-1.5_gcc/bin/mpicxx -DHAVE_CONFIG_H -I. -I.. -I../geom/parallel -I../geom  -DLITTLE_ENDIAN=BYTE_ORDER   -DTEMPLATE_DEFS_INCLUDED -DHAVE_ACIS  -DSRCDIR=. -I../util -I../geom -I../init -I../geom/parallel -DUSE_MPI    -Wall -pipe -pedantic -O2 -DNDEBUG -MT iGeomError.lo -MD -MP -MF .deps/iGeomError.Tpo -c -o iGeomError.lo iGeomError.cc
libtool: compile:  /homes/fathom/lib32/mpich2-1.5_gcc/bin/mpicxx -DHAVE_CONFIG_H -I. -I.. -I../geom/parallel -I../geom -DLITTLE_ENDIAN=BYTE_ORDER -DTEMPLATE_DEFS_INCLUDED -DHAVE_ACIS -DSRCDIR=. -I../util -I../geom -I../init -I../geom/parallel -DUSE_MPI -Wall -pipe -pedantic -O2 -DNDEBUG -MT iGeomError.lo -MD -MP -MF .deps/iGeomError.Tpo -c iGeomError.cc -o iGeomError.o
mv -f .deps/iGeomError.Tpo .deps/iGeomError.Plo
/bin/sh ../libtool  --tag=CXX   --mode=link /homes/fathom/lib32/mpich2-1.5_gcc/bin/mpicxx  -Wall -pipe -pedantic -O2 -DNDEBUG -R/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin  -o libiGeom.la -rpath /homes/fathom/lib32/jenkins/cgm/lib CATag.lo iGeom_CGMA.lo iGeomError.lo  -lcubiti19 -lcubit_util ../init/libcgma_init.la -lcubit_geom ../geom/parallel/libcubit_parallel.la -lm
libtool: link: (cd .libs/libiGeom.lax/libcgma_init.a && ar x "<https://jenkins-ci.mcs.anl.gov/job/cgm32bit/ws/itaps/../init/.libs/libcgma_init.a")>
libtool: link: (cd .libs/libiGeom.lax/libcubit_parallel.a && ar x "<https://jenkins-ci.mcs.anl.gov/job/cgm32bit/ws/itaps/../geom/parallel/.libs/libcubit_parallel.a")>
libtool: link: ar cru .libs/libiGeom.a  CATag.o iGeom_CGMA.o iGeomError.o  .libs/libiGeom.lax/libcgma_init.a/InitCGMA.o  .libs/libiGeom.lax/libcubit_parallel.a/CABodies.o .libs/libiGeom.lax/libcubit_parallel.a/CGMFileOptions.o .libs/libiGeom.lax/libcubit_parallel.a/CGMParallelComm.o .libs/libiGeom.lax/libcubit_parallel.a/CGMProcConfig.o .libs/libiGeom.lax/libcubit_parallel.a/CGMReadParallel.o .libs/libiGeom.lax/libcubit_parallel.a/TDParallel.o
libtool: link: ranlib .libs/libiGeom.a
libtool: link: rm -fr .libs/libiGeom.lax
libtool: link: ( cd ".libs" && rm -f "libiGeom.la" && ln -s "../libiGeom.la" "libiGeom.la" )
make[4]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/cgm32bit/ws/itaps'>
make[3]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/cgm32bit/ws/itaps'>
make[2]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/cgm32bit/ws/itaps'>
Making all in test
make[2]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/cgm32bit/ws/test'>
/bin/sh ../libtool  --tag=CXX   --mode=compile /homes/fathom/lib32/mpich2-1.5_gcc/bin/mpicxx -DHAVE_CONFIG_H -I. -I.. -I../geom/parallel -I../geom -I../itaps  -DLITTLE_ENDIAN=BYTE_ORDER   -DTEMPLATE_DEFS_INCLUDED -DHAVE_ACIS  -DCUBIT_CGM -DACIS_TWEAK_TOOL_CAT -DSRCDIR=. -I../geom -I../util -I../init -I../geom/ACIS -I../geom/virtual -I../geom/facet -I../geom/Cholla -I../geom/OCC -I.    -Wall -pipe -pedantic -O2 -DNDEBUG -MT TestUtilities.lo -MD -MP -MF .deps/TestUtilities.Tpo -c -o TestUtilities.lo TestUtilities.cpp
libtool: compile:  /homes/fathom/lib32/mpich2-1.5_gcc/bin/mpicxx -DHAVE_CONFIG_H -I. -I.. -I../geom/parallel -I../geom -I../itaps -DLITTLE_ENDIAN=BYTE_ORDER -DTEMPLATE_DEFS_INCLUDED -DHAVE_ACIS -DCUBIT_CGM -DACIS_TWEAK_TOOL_CAT -DSRCDIR=. -I../geom -I../util -I../init -I../geom/ACIS -I../geom/virtual -I../geom/facet -I../geom/Cholla -I../geom/OCC -I. -Wall -pipe -pedantic -O2 -DNDEBUG -MT TestUtilities.lo -MD -MP -MF .deps/TestUtilities.Tpo -c TestUtilities.cpp -o TestUtilities.o
mv -f .deps/TestUtilities.Tpo .deps/TestUtilities.Plo
/bin/sh ../libtool  --tag=CXX   --mode=link /homes/fathom/lib32/mpich2-1.5_gcc/bin/mpicxx  -Wall -pipe -pedantic -O2 -DNDEBUG   -o libcgm_test.la  TestUtilities.lo  -lm
libtool: link: ar cru .libs/libcgm_test.a  TestUtilities.o
libtool: link: ranlib .libs/libcgm_test.a
libtool: link: ( cd ".libs" && rm -f "libcgm_test.la" && ln -s "../libcgm_test.la" "libcgm_test.la" )
make[2]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/cgm32bit/ws/test'>
make[1]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/cgm32bit/ws/'>
+ make check
Making check in compat
make[1]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/cgm32bit/ws/compat'>
make[1]: Nothing to be done for `check'.
make[1]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/cgm32bit/ws/compat'>
Making check in util
make[1]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/cgm32bit/ws/util'>
make[1]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/cgm32bit/ws/util'>
Making check in geom
make[1]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/cgm32bit/ws/geom'>
Making check in .
make[2]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/cgm32bit/ws/geom'>
Making check in Cholla
make[2]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/cgm32bit/ws/geom/Cholla'>
make[2]: Nothing to be done for `check'.
make[2]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/cgm32bit/ws/geom/Cholla'>
Making check in facetbool
make[2]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/cgm32bit/ws/geom/facetbool'>
make[2]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/cgm32bit/ws/geom/facetbool'>
make[2]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/cgm32bit/ws/geom/facet'>
make[2]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/cgm32bit/ws/geom/facet'>
Making check in virtual
make[2]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/cgm32bit/ws/geom/virtual'>
make[2]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/cgm32bit/ws/geom/virtual'>
Making check in parallel
make[2]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/cgm32bit/ws/geom/parallel'>
make[2]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/cgm32bit/ws/geom/parallel'>
make[1]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/cgm32bit/ws/geom'>
Making check in init
make[1]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/cgm32bit/ws/init'>
make[1]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/cgm32bit/ws/init'>
Making check in .
make[1]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/cgm32bit/ws/'>
Making check in itaps
make[1]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/cgm32bit/ws/itaps'>
make  check-recursive
Making check in .
make  chaman test_edge_orient  testgeom  partest
/homes/fathom/lib32/mpich2-1.5_gcc/bin/mpicxx -DHAVE_CONFIG_H -I. -I.. -I../geom/parallel -I../geom  -DLITTLE_ENDIAN=BYTE_ORDER   -DTEMPLATE_DEFS_INCLUDED -DHAVE_ACIS  -DSRCDIR=. -I../util -I../geom -I../init -I../geom/parallel -DUSE_MPI    -Wall -pipe -pedantic -O2 -DNDEBUG -MT chaman.o -MD -MP -MF .deps/chaman.Tpo -c -o chaman.o chaman.cc
mv -f .deps/chaman.Tpo .deps/chaman.Po
/bin/sh ../libtool  --tag=CXX   --mode=link /homes/fathom/lib32/mpich2-1.5_gcc/bin/mpicxx  -Wall -pipe -pedantic -O2 -DNDEBUG -R/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin  -o chaman chaman.o libiGeom.la ../libcgm.la  -lm
libtool: link: /homes/fathom/lib32/mpich2-1.5_gcc/bin/mpicxx -Wall -pipe -pedantic -O2 -DNDEBUG -o chaman chaman.o  -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin ./.libs/libiGeom.a -L./src/mpl -L./src/openpa/src ../.libs/libcgm.a /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpichcxx.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpich.so -lrt /homes/fathom/lib32/mpich2-1.5_gcc/lib/libopa.so -lpthread /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpl.so -lcubiti19 -lcubit_geom -lcubit_util -lm -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin
/usr/bin/ld: cannot find -lcubit_geom
/usr/bin/ld: cannot find -lcubit_util
collect2: ld returned 1 exit status
make[4]: *** [chaman] Error 1
make[3]: *** [check-am] Error 2
make[2]: *** [check-recursive] Error 1
make[1]: *** [check] Error 2
make[1]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/cgm32bit/ws/itaps'>
make: *** [check-recursive] Error 1
Build step 'Execute shell' marked build as failure
More information about the cgma-dev
