[cgma-dev] r6157 - cgm/tags/cubit10.2
janehu at mcs.anl.gov janehu at mcs.anl.gov
Wed Mar 12 11:29:12 CDT 2014
Author: janehu
Date: 2014-03-12 11:29:12 -0500 (Wed, 12 Mar 2014)
New Revision: 6157
Added:
   cgm/tags/cubit10.2/README.DOWNLOAD
Removed:
   cgm/tags/cubit10.2/CMakeLists.txt
   cgm/tags/cubit10.2/KNOWN_ISSUES
   cgm/tags/cubit10.2/LICENSE.CGM
   cgm/tags/cubit10.2/Makefile.am
   cgm/tags/cubit10.2/README.CGM
   cgm/tags/cubit10.2/README.CONFIGURE
   cgm/tags/cubit10.2/README.OCC
   cgm/tags/cubit10.2/README.OpenCascade
   cgm/tags/cubit10.2/cgm.make.in
   cgm/tags/cubit10.2/cgm_apps/
   cgm/tags/cubit10.2/compat/
   cgm/tags/cubit10.2/configure.ac
   cgm/tags/cubit10.2/geom/
   cgm/tags/cubit10.2/init/
   cgm/tags/cubit10.2/itaps/
   cgm/tags/cubit10.2/m4/
   cgm/tags/cubit10.2/test/
   cgm/tags/cubit10.2/util/
Log:
Removed all source files. Added info to direct interested user to use bitbucket.
Deleted: cgm/tags/cubit10.2/CMakeLists.txt
--- cgm/tags/cubit10.2/CMakeLists.txt	2014-03-12 16:27:50 UTC (rev 6156)
+++ cgm/tags/cubit10.2/CMakeLists.txt	2014-03-12 16:29:12 UTC (rev 6157)
@@ -1,5 +0,0 @@
-# do util and geom and test subdirs
-SUBDIRS( util geom test init )
Deleted: cgm/tags/cubit10.2/KNOWN_ISSUES
--- cgm/tags/cubit10.2/KNOWN_ISSUES	2014-03-12 16:27:50 UTC (rev 6156)
+++ cgm/tags/cubit10.2/KNOWN_ISSUES	2014-03-12 16:29:12 UTC (rev 6157)
@@ -1,27 +0,0 @@
-This is a list of the known issues with CGM on OCC.For more details please see
-the online ticket system at the MOAB website:
-    https://trac.mcs.anl.gov/projects/ITAPS/wiki
-ID   Severity  Summary/Details
-175 critical  imprint special cases fail with crash.
-176 minor     CGM memory leak
-178 major     Unite function doesn't unite smoothly connected surfaces.
-179 major     mcnp2cad test suite lat1-7 not working, needs debugging.
-180 major     There are lots new functions or added functions to exsisting
-              functions requirements to port OCC to cubit12.
-181 minor     Lack of good cases for testing purpose.
-182 minor     Dirty geometry/imported geometry is not tested for read/repair yet
-183 minor     Don't have proper tool to visualize the TopoDS_Shapes, debugging
-           process is long preparing for graphics to understand the issue
-185 major     mcnp2cad/tests/INP-torus test case fails on imprinting 2 spline
-              surfaces.
Deleted: cgm/tags/cubit10.2/LICENSE.CGM
--- cgm/tags/cubit10.2/LICENSE.CGM	2014-03-12 16:27:50 UTC (rev 6156)
+++ cgm/tags/cubit10.2/LICENSE.CGM	2014-03-12 16:29:12 UTC (rev 6157)
@@ -1,21 +0,0 @@
-CGM, the Common Geometry Module, is a code library which provides
-geometry functionality used for mesh generation and other applications.
More information about the cgma-dev mailing list
