[cgma-dev] r6153 - cgm/tags/12.2.1
janehu at mcs.anl.gov
Wed Mar 12 11:22:59 CDT 2014
Author: janehu
Date: 2014-03-12 11:22:59 -0500 (Wed, 12 Mar 2014)
New Revision: 6153
Added:
cgm/tags/12.2.1/README.DOWNLOAD
Removed:
cgm/tags/12.2.1/CMakeLists.txt
cgm/tags/12.2.1/KNOWN_ISSUES
cgm/tags/12.2.1/LICENSE.CGM
cgm/tags/12.2.1/Makefile.am
cgm/tags/12.2.1/README.CGM
cgm/tags/12.2.1/README.CONFIGURE
cgm/tags/12.2.1/README.OCC
cgm/tags/12.2.1/README.OpenCascade
cgm/tags/12.2.1/cgm.make.in
cgm/tags/12.2.1/cgm_apps/
cgm/tags/12.2.1/cgm_version.h
cgm/tags/12.2.1/compat/
cgm/tags/12.2.1/configure.ac
cgm/tags/12.2.1/geom/
cgm/tags/12.2.1/init/
cgm/tags/12.2.1/itaps/
cgm/tags/12.2.1/m4/
cgm/tags/12.2.1/test/
cgm/tags/12.2.1/util/
Log:
Removed all source files. Added info to direct interested user to use bitbucket.
Deleted: cgm/tags/12.2.1/CMakeLists.txt
--- cgm/tags/12.2.1/CMakeLists.txt 2014-03-12 16:21:17 UTC (rev 6152)
+++ cgm/tags/12.2.1/CMakeLists.txt 2014-03-12 16:22:59 UTC (rev 6153)
@@ -1,5 +0,0 @@
-# do util and geom and test subdirs
-SUBDIRS( util geom test init )
Deleted: cgm/tags/12.2.1/KNOWN_ISSUES
--- cgm/tags/12.2.1/KNOWN_ISSUES 2014-03-12 16:21:17 UTC (rev 6152)
+++ cgm/tags/12.2.1/KNOWN_ISSUES 2014-03-12 16:22:59 UTC (rev 6153)
@@ -1,27 +0,0 @@
-This is a list of the known issues with CGM on OCC.For more details please see
-the online ticket system at the MOAB website:
- https://trac.mcs.anl.gov/projects/ITAPS/wiki
-ID Severity Summary/Details
-175 critical imprint special cases fail with crash.
-176 minor CGM memory leak
-178 major Unite function doesn't unite smoothly connected surfaces.
-179 major mcnp2cad test suite lat1-7 not working, needs debugging.
-180 major There are lots new functions or added functions to exsisting
- functions requirements to port OCC to cubit12.
-181 minor Lack of good cases for testing purpose.
-182 minor Dirty geometry/imported geometry is not tested for read/repair yet
-183 minor Don't have proper tool to visualize the TopoDS_Shapes, debugging
- process is long preparing for graphics to understand the issue
-185 major mcnp2cad/tests/INP-torus test case fails on imprinting 2 spline
- surfaces.
Deleted: cgm/tags/12.2.1/LICENSE.CGM
--- cgm/tags/12.2.1/LICENSE.CGM 2014-03-12 16:21:17 UTC (rev 6152)
+++ cgm/tags/12.2.1/LICENSE.CGM 2014-03-12 16:22:59 UTC (rev 6153)
@@ -1,21 +0,0 @@
-CGM, the Common Geometry Module, is a code library which provides
-geometry functionality used for mesh generation and other applications.
More information about the cgma-dev
