[cgma-dev] Build failed in Jenkins: cgm32bit #340
jenkins-ci at mcs.anl.gov jenkins-ci at mcs.anl.gov
Wed Mar 5 00:02:02 CST 2014
See <https://jenkins-ci.mcs.anl.gov/job/cgm32bit/340/>
Started by timer
[EnvInject] - Loading node environment variables.
Building remotely on octagon.mcs.anl.gov in workspace <https://jenkins-ci.mcs.anl.gov/job/cgm32bit/ws/>
Updating https://svn.mcs.anl.gov/repos/ITAPS/cgm/branches/cgm12.2 at revision '2014-03-05T00:01:53.514 -0600'
ERROR: Failed to update https://svn.mcs.anl.gov/repos/ITAPS/cgm/branches/cgm12.2
org.tmatesoft.svn.core.SVNException: svn: E175002: OPTIONS /repos/ITAPS/cgm/branches/cgm12.2 failed
	at org.tmatesoft.svn.core.internal.io.dav.http.HTTPConnection.request(HTTPConnection.java:379)
	at org.tmatesoft.svn.core.internal.io.dav.http.HTTPConnection.request(HTTPConnection.java:364)
	at org.tmatesoft.svn.core.internal.io.dav.http.HTTPConnection.request(HTTPConnection.java:352)
	at org.tmatesoft.svn.core.internal.io.dav.DAVConnection.performHttpRequest(DAVConnection.java:708)
	at org.tmatesoft.svn.core.internal.io.dav.DAVConnection.exchangeCapabilities(DAVConnection.java:628)
	at org.tmatesoft.svn.core.internal.io.dav.DAVConnection.open(DAVConnection.java:103)
	at org.tmatesoft.svn.core.internal.io.dav.DAVRepository.openConnection(DAVRepository.java:1018)
	at org.tmatesoft.svn.core.internal.io.dav.DAVRepository.getRepositoryUUID(DAVRepository.java:148)
	at org.tmatesoft.svn.core.internal.wc16.SVNBasicDelegate.createRepository(SVNBasicDelegate.java:339)
	at org.tmatesoft.svn.core.internal.wc16.SVNBasicDelegate.createRepository(SVNBasicDelegate.java:328)
	at org.tmatesoft.svn.core.internal.wc16.SVNUpdateClient16.update(SVNUpdateClient16.java:482)
	at org.tmatesoft.svn.core.internal.wc16.SVNUpdateClient16.doUpdate(SVNUpdateClient16.java:364)
	at org.tmatesoft.svn.core.internal.wc16.SVNUpdateClient16.doUpdate(SVNUpdateClient16.java:274)
	at org.tmatesoft.svn.core.internal.wc2.old.SvnOldUpdate.run(SvnOldUpdate.java:27)
	at org.tmatesoft.svn.core.internal.wc2.old.SvnOldUpdate.run(SvnOldUpdate.java:11)
	at org.tmatesoft.svn.core.internal.wc2.SvnOperationRunner.run(SvnOperationRunner.java:20)
	at org.tmatesoft.svn.core.wc2.SvnOperationFactory.run(SvnOperationFactory.java:1235)
	at org.tmatesoft.svn.core.wc2.SvnOperation.run(SvnOperation.java:291)
	at org.tmatesoft.svn.core.wc.SVNUpdateClient.doUpdate(SVNUpdateClient.java:311)
	at org.tmatesoft.svn.core.wc.SVNUpdateClient.doUpdate(SVNUpdateClient.java:291)
	at org.tmatesoft.svn.core.wc.SVNUpdateClient.doUpdate(SVNUpdateClient.java:387)
	at hudson.scm.subversion.UpdateUpdater$TaskImpl.perform(UpdateUpdater.java:143)
	at hudson.scm.subversion.WorkspaceUpdater$UpdateTask.delegateTo(WorkspaceUpdater.java:153)
	at hudson.scm.SubversionSCM$CheckOutTask.perform(SubversionSCM.java:903)
	at hudson.scm.SubversionSCM$CheckOutTask.invoke(SubversionSCM.java:884)
	at hudson.scm.SubversionSCM$CheckOutTask.invoke(SubversionSCM.java:867)
	at hudson.FilePath$FileCallableWrapper.call(FilePath.java:2348)
	at hudson.remoting.UserRequest.perform(UserRequest.java:118)
	at hudson.remoting.UserRequest.perform(UserRequest.java:48)
	at hudson.remoting.Request$2.run(Request.java:326)
	at hudson.remoting.InterceptingExecutorService$1.call(InterceptingExecutorService.java:72)
	at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:334)
	at java.util.concurrent.FutureTask.run(FutureTask.java:166)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1146)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
	at java.lang.Thread.run(Thread.java:701)
Caused by: svn: E175002: OPTIONS /repos/ITAPS/cgm/branches/cgm12.2 failed
	at org.tmatesoft.svn.core.SVNErrorMessage.create(SVNErrorMessage.java:208)
	at org.tmatesoft.svn.core.SVNErrorMessage.create(SVNErrorMessage.java:154)
	at org.tmatesoft.svn.core.SVNErrorMessage.create(SVNErrorMessage.java:97)
	... 36 more
Caused by: org.tmatesoft.svn.core.SVNException: svn: E175002: OPTIONS request failed on '/repos/ITAPS/cgm/branches/cgm12.2'
svn: E175011: Repository moved temporarily; please relocate
	at org.tmatesoft.svn.core.internal.wc.SVNErrorManager.error(SVNErrorManager.java:64)
	at org.tmatesoft.svn.core.internal.wc.SVNErrorManager.error(SVNErrorManager.java:51)
	at org.tmatesoft.svn.core.internal.io.dav.http.HTTPConnection._request(HTTPConnection.java:754)
	at org.tmatesoft.svn.core.internal.io.dav.http.HTTPConnection.request(HTTPConnection.java:373)
	... 35 more
Caused by: svn: E175002: OPTIONS request failed on '/repos/ITAPS/cgm/branches/cgm12.2'
	at org.tmatesoft.svn.core.internal.io.dav.http.HTTPConnection._request(HTTPConnection.java:752)
	... 36 more
Caused by: svn: E175011: Repository moved temporarily; please relocate
	at org.tmatesoft.svn.core.internal.io.dav.http.HTTPRequest.createDefaultErrorMessage(HTTPRequest.java:442)
	at org.tmatesoft.svn.core.internal.io.dav.http.HTTPRequest.dispatch(HTTPRequest.java:189)
	at org.tmatesoft.svn.core.internal.io.dav.http.HTTPConnection._request(HTTPConnection.java:460)
	... 36 more
ERROR: Subversion update failed
hudson.util.IOException2: remote file operation failed: <https://jenkins-ci.mcs.anl.gov/job/cgm32bit/ws/> at hudson.remoting.Channel at 79c21f58:octagon.mcs.anl.gov
	at hudson.FilePath.act(FilePath.java:861)
	at hudson.FilePath.act(FilePath.java:838)
	at hudson.scm.SubversionSCM.checkout(SubversionSCM.java:843)
	at hudson.scm.SubversionSCM.checkout(SubversionSCM.java:781)
	at hudson.model.AbstractProject.checkout(AbstractProject.java:1342)
	at hudson.model.AbstractBuild$AbstractBuildExecution.defaultCheckout(AbstractBuild.java:683)
	at jenkins.scm.SCMCheckoutStrategy.checkout(SCMCheckoutStrategy.java:88)
	at hudson.model.AbstractBuild$AbstractBuildExecution.run(AbstractBuild.java:588)
	at hudson.model.Run.execute(Run.java:1567)
	at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:46)
	at hudson.model.ResourceController.execute(ResourceController.java:88)
	at hudson.model.Executor.run(Executor.java:237)
Caused by: java.io.IOException
	at hudson.scm.subversion.UpdateUpdater$TaskImpl.perform(UpdateUpdater.java:184)
Caused by: hudson.scm.subversion.UpdaterException: failed to perform svn update
	... 15 more
Caused by: org.tmatesoft.svn.core.SVNException: svn: E175002: OPTIONS /repos/ITAPS/cgm/branches/cgm12.2 failed
	... 14 more
	... 36 more
	... 35 more
	... 36 more
	... 36 more
More information about the cgma-dev mailing list
