[cgma-dev] Cubit 14
Tim Tautges (ANL)
tautges at mcs.anl.gov
Wed Jan 29 14:42:07 CST 2014
Jane's off this week on personal leave, so we probably won't hear from her until next week.
But, keep in mind that a) ReadCGM is part of MOAB, so that's in the mix too, and b) we can check for that file in the
configure process and set a cpp variable accordingly.
- tim
On 01/29/2014 09:49 AM, Grindeanu, Iulian R. wrote:
> Jane ? maybe there should be a better way of managing versions/branches/releases/tags?
> I can't answer any of those questions Andy and David have. I know that there is a plan to move cgm on bitbucket, but the releases/branches/tags will all be ported as they are now.
> Iulian
> _
> ______________________________________
> From: Andrew Davis [davisa at engr.wisc.edu]
> Sent: Wednesday, January 29, 2014 9:27 AM
> To: Grindeanu, Iulian R.; Paul Wilson; cgma-dev at mcs.anl.gov
> Subject: Re: [cgma-dev] Cubit 14
> Hi Iulian
> cgmurl I can see, I doubt I have ever used it, why is there more than
> one for cubit12.2?
> Also I was using 13.1 from branches (no cgm_version.h) , not 13.1.1
> from tags (which has cgm_version.h)
> Out of curiosity, should there not be a 13.1.1 on branches? Perhaps now
> that 13.1 is out of date you could replace it with
> 13.1.1? Same for 12.2-merge?
> Andy
> On 01/29/2014 09:19 AM, Grindeanu, Iulian R. wrote:
>> buildbot uses these:
>> cgmurl = 'https://svn.mcs.anl.gov/repos/ITAPS/cgm/branches/merge-cubit12.2' for cubit 12.2
>> cgmurlt1311 = 'https://svn.mcs.anl.gov/repos/ITAPS/cgm/tags/13.1.1' for cubit 13.1
>> cgmurltrunk = 'https://svn.mcs.anl.gov/repos/ITAPS/cgm/trunk' for Cubit14.0
>> What versions are you using?
>> What is not compiling for you?
>> Iulian
>> ________________________________________
>> From: Paul Wilson [wilsonp at engr.wisc.edu]
>> Sent: Wednesday, January 29, 2014 9:15 AM
>> To: Andrew Davis; Grindeanu, Iulian R.; cgma-dev at mcs.anl.gov
>> Hi Andy,
>> Can you remind me of the specific symptom? Is it the existence of the
>> version file that needs to be backported (perhaps not), or is it the use
>> of the version info to change the behavior that needs to be backported
>> (perhaps)?
>> Paul
>> On 01/29/2014 09:10 AM, Andrew Davis wrote:
>>> Hi Julian
>>> The SVN
>>> Andy
>>> On 01/29/2014 09:07 AM, Grindeanu, Iulian R. wrote:
>>>> I think that current branches (mergecubit12.2, trunk, ) all have that
>>>> file; at least buildbot is not complaining.
>>>> Are you using a release tar file or svn repo?
>>>> From: cgma-dev-bounces at mcs.anl.gov [cgma-dev-bounces at mcs.anl.gov] on
>>>> behalf of Andrew Davis [davisa at engr.wisc.edu]
>>>> Sent: Wednesday, January 29, 2014 9:05 AM
>>>> To: cgma-dev at mcs.anl.gov
>>>> Subject: [cgma-dev] Cubit 14
>>>> This is question kind of linked to both CGM and MOAB
>>>> Jane fixed readCGM.cpp in MOAB, however this fix only works for CGM,
>>>> since it relies on cgm_version.h, which was included in CGM14.0,
>>>> however, when we compile with any version previous we do not have this
>>>> header file availble to us. Would it be possible to back port the
>>>> cgm_version.h file back into previous CGM releases?
>>>> Thanks
>>>> Andy
>> Paul Wilson ~ UW-Madison ~ 608-263-0807 ~ cal: http://bit.ly/pphw-cal
>> Professor, Engineering Physics. ~ http://cnerg.engr.wisc.edu
>> Faculty Director, Advanced Computing Infrastructure
steadfast, because he trusts in you." Isaiah 26:3
Tim Tautges Argonne National Laboratory
(tautges at mcs.anl.gov) (telecommuting from UW-Madison)
phone (gvoice): (608) 354-1459 1500 Engineering Dr.
fax: (608) 263-4499 Madison, WI 53706
More information about the cgma-dev
