[cgma-dev] Facet/Cholla engine
David Thompson
david.thompson at kitware.com
Sat Jan 18 08:23:28 CST 2014
Hi Jane,
> I'll put this into our bug system and hopefully find chances to fix it either myself or by others.
I've attached a version of the tetrahedron code that demonstrates split_surface and feature_angle do nothing that you can include in the bug report.
> Sorry for the inconvenience.
Thanks for looking into things. We are also looking at using MOAB to represent models composed of multiple faceted surfaces -- so it is not a really high priority, but it would help me with the CGM work I am doing even if we use MOAB for faceted models.
David
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20140118/5ea74b39/attachment.obj>
More information about the cgma-dev
