[cgma-dev] Facet/Cholla engine
David Thompson
david.thompson at kitware.com
Mon Jan 13 22:03:13 CST 2014
Hi all,
I have a question about the facet engine in CGM. Are multiple faceted surfaces per body supported? I see crashes if I call
DLIList <CubitPoint*> plist;
DLIList<CubitFacet*> tflist;
DLIList<CubitQuadFacet*> qflist;
DLIList<Surface*> slist;
FacetModifyEngine::instance()->build_facet_surface(
qflist, tflist, plist, -1, 0, false, false, slist);
where tflist and qflist do not use every point in plist (because another call to build_facet_surface() will use those points later).
If I create a separate plist for each call to build_facet_surface(), it does not crash... but will coincident points be recognized as identical and merged -- or will the geometry need some kind of stitching?
David
More information about the cgma-dev
