[cgma-dev] CGM 13.1 and PyTAPS
    Iulian Grindeanu
    iulian at mcs.anl.gov
    Mon Dec 16 12:04:01 CST 2013
Hello,
I was giving a wrong example for what we need to accomplish.
More exactly, the signature of scale and reflect functions are different in igeom.h between version 1.4.0 and 1.4.1
Because of that, the python bindings look different (pytaps)
The test though, should test differently, in
<pytaps>/test/igeom/creation.py
def testScale(self):
ent = self.geom.createBrick(2, 2, 2)
self.geom.scaleEnt(ent, [1,2,3])
lo, hi = self.geom.getEntBoundBox(ent)
self.assertArray(lo, [-1,-2,-3])
self.assertArray(hi, [ 1, 2, 3])
instead of calling
self.geom.scaleEnt(ent, [1, 2, 3])
we should call it with
self.geom.scaleEnt(ent,[0,0,0], [1, 2, 3]) for newer version of igeom
how can we differentiate in the test itself? Is there something that can be "exported" like a version number?
In <pytaps>iGeom.c, in pytaps, we differentiate between versions, we can do it, because this is c code:
#if IBASE_VERSION_GE(1,4,1)
static PyObject *
iGeomObj_scaleEnt(iGeom_Object *self,PyObject *args,PyObject *kw)
static char *kwlist[] = {"entity","point","scale",0};
int err;
iBaseEntity_Object *entity;
PyObject *in_vec,*vec, *in_point, *point;
if(!PyArg_ParseTupleAndKeywords(args,kw,"O!OO",kwlist,&iBaseEntity_Type,
&entity,&in_point,&in_vec))
return NULL;
vec = PyArray_ToVectors(in_vec,NPY_DOUBLE,1,3,0);
if(vec == NULL)
return NULL;
point = PyArray_ToVectors(in_point,NPY_DOUBLE,1,3,0);
if(point == NULL)
return NULL;
double *coords = PyArray_DATA(vec);
double *pt_coords = PyArray_DATA(point);
iGeom_scaleEnt(self->handle,entity->handle,pt_coords[0], pt_coords[1], pt_coords[2],
coords[0],coords[1],coords[2],
&err);
Py_DECREF(vec);
Py_DECREF(point);
if(checkError(self->handle,err))
return NULL;
Py_RETURN_NONE;
#else
static PyObject *
static char *kwlist[] = {"entity","scale",0};
int err;
PyObject *in_vec,*vec;
if(!PyArg_ParseTupleAndKeywords(args,kw,"O!O",kwlist,&iBaseEntity_Type,
&entity,&in_vec))
return NULL;
if(vec == NULL)
return NULL;
iGeom_scaleEnt(self->handle,entity->handle,coords[0],coords[1],coords[2],
&err);
Py_DECREF(vec);
return NULL;
Py_RETURN_NONE;
#endif
----- Original Message -----
| On Mon, Dec 16, 2013 at 7:49 AM, Paul Wilson < wilsonp at engr.wisc.edu
| > wrote:
| | Hi Andy, Iulian,
| | I've added Anthony Scopatz into this conversation, as he has a
| | growing interest in PyTAPS. He is also a python expert. I'm not
| | sure
| | if he is on the CGMA list yet.
| Hello All,
| I didn't know there was a cgma-dev list :) I have applied now.
| | <nudge>Tim was also planning to move it to bitbucket soon (last
| | month?) to facilitate collaborative development </nudge>
| <doublenudge />
| | On 12/13/2013 12:22 PM, Iulian Grindeanu wrote:
| | | It looks like in python there is no equivalent to ifdefs.
| It isn't entirely clear to me what you are trying to ifdef around
| here. The code here was for the OS but Andy was mentioning code
| version. Still, I would say that the ifdef concept doesn't exactly
| apply. In Python, the API should be the same across all platforms
| and the implementation should vary based on the system you are on.
| Think of this kind of a environment-based duck typing :). It is much
| more normal in Python to write something like the following:
| import os
| def foo(x):
| if os.name == 'posix':
| rtn = x * x
| else:
| rtn = x + 42
| return rtn
| This is different than the version written by Iulian because you are
| guaranteed the same foo() object no matter where you are. If you are
| going to be doing this comparison a lot it might behoove you to bank
| the result globally.
| import os
| ON_POSIX = os.name == 'posix'
| def foo(x):
| if ON_POSIX:
| rtn = x * x
| else:
| rtn = x + 42
| return rtn
| Hope this helps!
| Be Well
| Anthony
| | | We could simply use an if statement, but we need to have
| | | something
| | | different for cgm >= 13
| | | Python is an interpreted language, and we can do something like
| | | this:
| | | import os if os . name == "posix" : def foo ( x ): return x * x
| | | else
| | | : def foo ( x ): return x + 42 Now, we need to export somehow the
| | | version from iGeom.h / iBase.h, to be visible in pytaps.
| | | Another solution is to create an svn branch for pytaps too (I
| | | prefer
| | | not to, because there is not much difference, so far) And as long
| | | as
| | | iGeom.h does not change, we do not really need different
| | | branches.
| | | Any suggestions?
| | | Iulian
| | | | Hello,
| | | | Does anybody know how to do ifdefs in python? Or something
| | | | similar?
| | | | This is what I am using for pytaps built with cgm trunk
| | | | (actually,
| | | | cgm/tags/13.1.1)
| | | | (you should be able to apply this patch on pytaps source, and
| | | | use
| | | | it
| | | | also for trunk version)
| | | | Iulian
| | | | | HI
| | | | | I think the iMesh implmentation in CGM13.1 is mismatched for
| | | | | the
| | | | | PyTAPS
| | | | | 1.4, PyTAPS 1.4 failed to build when using CGM 13.1, but is
| | | | | fine
| | | | | with
| | | | | 12.2. The error messages are all code issues regarding
| | | | | mismatched
| | | | | arguments to functions, passing ints when it should be
| | | | | doubles
| | | | | and
| | | | | so
| | | | | on.
| | | | | I figured this should be reported here since I couldnt find
| | | | | PyTAPS
| | | | | dev
| | | | | Thanks
| | | | | Andy
| | Paul Wilson ~ UW-Madison ~ 608-263-0807 ~ cal:
| | http://bit.ly/pphw-cal
| | Professor, Engineering Physics. ~ http://cnerg.engr.wisc.edu
| | Faculty
| | Director, Advanced Computing Infrastructure
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20131216/8d842f00/attachment.html>
More information about the cgma-dev
